Skip to content
Commits on Source (55)
# Patro - A Python library to make patterns for fashion design
# Copyright (C) 2017 Fabrice Salvaire
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
"""Module to implement argparse actions.
__all__ = [
'PathAction',
import argparse
from pathlib import Path
class PathAction(argparse.Action):
"""Class to implement argparse action for path."""
def __call__(self, parser, namespace, values, option_string=None):
if values is not None:
if isinstance(values, list):
path = [Path(x) for x in values]
else:
path = Path(values)
else:
path = None
setattr(namespace, self.dest, path)
...@@ -78,27 +78,56 @@ def cubic_root(a, b, c, d): ...@@ -78,27 +78,56 @@ def cubic_root(a, b, c, d):
def cubic_root_sympy(a, b, c, d): def x_symbol():
return sympy.Symbol('x', real=True)
def real_roots(expression, x):
return [i.n() for i in sympy.real_roots(expression, x)]
x = sympy.Symbol('x', real=True) ####################################################################################################
x = x_symbol()
E = a*x**3 + b*x**2 + c*x + d E = a*x**3 + b*x**2 + c*x + d
return real_roots(E, x)
return [i.n() for i in sympy.real_roots(E, x)] ####################################################################################################
def cubic_root_normalised(a, b, c):
x = x_symbol()
E = x**3 + a*x**2 + b*x + c
def fifth_root_normalised(a, b, c, d, e): def fourth_root_normalised(a, b, c, d):
x = x_symbol()
E = x**4 + a*x**3 + b*x**2 + c*x + d
E = x**5 + a*x**4 + b*x**3 + c*x**2 + d*x + e
return [i.n() for i in sympy.real_roots(E, x)] def fifth_root_sympy(a, b, c, d, e, f):
x = x_symbol()
E = a*x**5 + b*x**4 + c*x**3 + d*x**2 + e*x + f
x = x_symbol()
def fifth_root(*args): def fifth_root(*args):
# Fixme: RuntimeWarning: divide by zero encountered in double_scalars
a = args[0] a = args[0]
return fifth_root_normalised(*[x/a for x in args[1:]]) if a == 0:
return fifth_root_sympy(*args)
else:
...@@ -39,8 +39,13 @@ class XmlFileMixin: ...@@ -39,8 +39,13 @@ class XmlFileMixin:
def __init__(self, path): def __init__(self, path, data=None):
self._path = Path(path)
if path is not None:
else:
self._path = None
self._data = data
...@@ -52,8 +57,17 @@ class XmlFileMixin: ...@@ -52,8 +57,17 @@ class XmlFileMixin:
def parse(self): def parse(self):
"""Parse a XML file and return the etree""" """Parse a XML file and return the etree"""
with open(str(self._path), 'rb') as f:
source = f.read() data = self._data
if data is None:
source = f.read()
else:
if isinstance(data, bytes):
source = data
else:
source = bytes(str(self._data).strip(), 'utf-8')
return etree.fromstring(source) return etree.fromstring(source)
...@@ -128,15 +128,15 @@ class DxfImporter: ...@@ -128,15 +128,15 @@ class DxfImporter:
major_axis = self._to_vector(item_dxf.major_axis) major_axis = self._to_vector(item_dxf.major_axis)
minor_axis = major_axis * item_dxf.ratio minor_axis = major_axis * item_dxf.ratio
domain = AngularDomain(item_dxf.start_param, item_dxf.end_param, degrees=False) domain = AngularDomain(item_dxf.start_param, item_dxf.end_param, degrees=False)
x_radius, y_radius = major_axis.magnitude, minor_axis.magnitude radius_x, radius_y = major_axis.magnitude, minor_axis.magnitude
angle = major_axis.orientation angle = major_axis.orientation
if angle == 90: if angle == 90:
x_radius, y_radius = y_radius, x_radius radius_x, radius_y = radius_y, radius_x
angle = 0 angle = 0
# Fixme: ... # Fixme: ...
ellipse = Ellipse2D( ellipse = Ellipse2D(
center, center,
x_radius, y_radius, radius_x, radius_y,
angle, angle,
domain=domain, domain=domain,
...@@ -221,7 +221,7 @@ class Polyline: ...@@ -221,7 +221,7 @@ class Polyline:
stop_angle += 360 stop_angle += 360
if vertex1.bulge < 0: if vertex1.bulge < 0:
start_angle, stop_angle = stop_angle, start_angle start_angle, stop_angle = stop_angle, start_angle
print('bulb', vertex1, vertex2, vertex1.bulge, start_angle, stop_angle) # print('bulb', vertex1, vertex2, vertex1.bulge, start_angle, stop_angle)
arc.domain = AngularDomain(start_angle, stop_angle) arc.domain = AngularDomain(start_angle, stop_angle)
# arc = Circle2D(center, vertex1.bulge_radius, domain=AngularDomain(start_angle, stop_angle)) # arc = Circle2D(center, vertex1.bulge_radius, domain=AngularDomain(start_angle, stop_angle))
items.append(arc) items.append(arc)
...@@ -27,6 +27,7 @@ Import Algorithm: ...@@ -27,6 +27,7 @@ Import Algorithm:
* line with a small polygon at extremities is a grainline * line with a small polygon at extremities is a grainline
* expect pieces are delimited by a path * expect pieces are delimited by a path
* check for paths sharing vertexes and stroke style * check for paths sharing vertexes and stroke style
...@@ -35,7 +36,10 @@ import logging ...@@ -35,7 +36,10 @@ import logging
from lxml import etree from lxml import etree
from IntervalArithmetic import Interval2D
from Patro.Common.Xml.XmlFile import XmlFileMixin from Patro.Common.Xml.XmlFile import XmlFileMixin
from Patro.GeometryEngine.Transformation import AffineTransformation2D
from . import SvgFormat from . import SvgFormat
...@@ -46,19 +50,126 @@ _module_logger = logging.getLogger(__name__) ...@@ -46,19 +50,126 @@ _module_logger = logging.getLogger(__name__)
class RenderState: class RenderState:
# Fixme: convert type !!!
STATES = [name for name in SvgFormat.PresentationAttributes.__dict__.keys()
if not name.startswith('_')]
@classmethod
def to_python(cls, value):
# Fixme: move ???
if isinstance(value, str):
if value == 'none':
return None
else:
try:
float_value = float(value)
if '.' in value:
return float_value
else:
return int(float_value)
except ValueError:
pass
return value
def __init__(self, item=None):
# Init from item else use default value
for state in self.STATES:
if item is not None and hasattr(item, state):
value = self.to_python(getattr(item, state))
else:
value = getattr(SvgFormat.PresentationAttributes, state)
setattr(self, state, value)
def clone(self):
return self.__class__(self)
def to_dict(self, all=False):
if all:
return {state:getattr(self, state) for state in self.STATES}
else:
d = {}
value = getattr(self, state)
if value is not None:
d[state] = value
return d
def merge(self, item):
if hasattr(item, state):
value = getattr(item, state)
if state == 'transform':
# Transform matrix is composed from top to item
# thus left to right
self.transform = self.transform * value
elif state == 'style':
pass
else:
setattr(self, state, self.to_python(value))
# Merge style
style = getattr(item, 'style', None)
if style is not None:
for pair in style.split(';'):
state, value = [x.strip() for x in pair.split(':')]
state = state.replace('-', '_')
else:
return self
def __str__(self):
return str(self.to_dict())
class RenderStateStack:
def __init__(self): def __init__(self):
self._transformations = [] self._stack = [RenderState()]
@property
def state(self):
return self._stack[-1]
def push_transformation(self, transformation): def push(self, kwargs):
self._transformations.append(transformation) new_state = self.state.clone()
new_state.merge(kwargs)
self._stack.append(new_state)
def pop_transformation(self): def pop(self):
self._transformations.pop() self._stack.pop()
...@@ -107,18 +218,30 @@ class SvgDispatcher: ...@@ -107,18 +218,30 @@ class SvgDispatcher:
# 'use', # 'use',
_logger = _module_logger.getChild('SvgDispatcher')
def __init__(self, root): def __init__(self, reader):
self._reader =reader
self.reset()
# self.on_root(root)
self._state = RenderState() ##############################################
self.on_root(root) def reset(self):
self._state_stack = RenderStateStack()
def element_tag(self, element): @property
def state(self):
return self._state_stack.state
tag = element.tag tag = element.tag
if '{' in tag: if '{' in tag:
tag = tag[tag.find('}')+1:] tag = tag[tag.find('}')+1:]
...@@ -131,7 +254,7 @@ class SvgDispatcher: ...@@ -131,7 +254,7 @@ class SvgDispatcher:
tag = self.element_tag(element) tag = self.element_tag(element)
tag_class = self.__TAGS__[tag] tag_class = self.__TAGS__[tag]
if tag_class is not None: if tag_class is not None:
print(element, tag_class) # self._logger.info('\n{} / {}'.format(element, tag_class))
return tag_class(element) return tag_class(element)
else: else:
raise NotImplementedError raise NotImplementedError
...@@ -149,44 +272,54 @@ class SvgDispatcher: ...@@ -149,44 +272,54 @@ class SvgDispatcher:
def on_group(self, group): def on_group(self, element):
self.on_root(group) group = self.from_xml(element)
# self._logger.info('Group: {}\n{}'.format(group.id, group))
self._reader.on_group(group)
self._state_stack.push(group)
# self._logger.info('State:\n' + str(self.state))
self.on_root(element)
def on_graphic_item(self, element): def on_graphic_item(self, element):
item = self.from_xml(element) item = self.from_xml(element)
print(item) # self._logger.info('Item: {}\n{}'.format(item.id, item))
self._reader.on_graphic_item(item)
class SvgFile(XmlFileMixin): class SvgFileMixin:
"""Class to read/write SVG file."""
_logger = _module_logger.getChild('SvgFile')
SVG_DOCTYPE = '<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">' SVG_DOCTYPE = '<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">'
SVG_xmlns = 'http://www.w3.org/2000/svg' SVG_xmlns = 'http://www.w3.org/2000/svg'
SVG_xmlns_xlink = 'http://www.w3.org/1999/xlink' SVG_xmlns_xlink = 'http://www.w3.org/1999/xlink'
SVG_version = '1.1' SVG_version = '1.1'
class SvgFileInternal(XmlFileMixin, SvgFileMixin):
def __init__(self, path=None): """Class to read/write SVG file."""
__dispatcher_cls__ = SvgDispatcher
# Fixme: path def __init__(self, path, data=None):
if path is None:
path = ''
XmlFileMixin.__init__(self, path) super().__init__(path, data)
# Fixme: # Fixme: API
# if path is not None: # purpose of dispatcher, where must be state ???
if path != '': self._dispatcher = self.__dispatcher_cls__(self)
self._read() self._read()
...@@ -200,14 +333,70 @@ class SvgFile(XmlFileMixin): ...@@ -200,14 +333,70 @@ class SvgFile(XmlFileMixin):
# width="1000.0pt" height="1000.0" viewBox="0 0 1000.0 1000.0" # width="1000.0pt" height="1000.0" viewBox="0 0 1000.0 1000.0"
# ></svg> # ></svg>
tree = self._parse() tree = self.parse()
dispatch = SvgDispatcher(tree)
# Fixme: ... svg_root = self._dispatcher.from_xml(tree)
self.on_svg_root(svg_root)
self._dispatcher.on_root(tree)
@property
def view_box(self):
return self._view_box
@property
def width(self):
return self._width
@property
def height(self):
return self._height
def on_svg_root(self, svg_root):
x_inf, y_inf, x_sup, y_sup = svg_root.view_box
self._view_box = Interval2D((x_inf, x_sup), (y_inf, y_sup))
self._width = svg_root.width
self._height = svg_root.height
def on_graphic_item(self, item):
state = self._dispatcher.state.clone().merge(item)
self._logger.info('Item State:\n' + str(state))
class SvgFileWriter(SvgFileMixin):
"""Class to write a SVF file."""
_logger = _module_logger.getChild('SvgFileWriter')
COMMENT = 'Pattern created with Patro (https://github.com/FabriceSalvaire/Patro)'
def __init__(self, path, paper, root_tree, transformation=None):
self._path = str(path)
self._write(paper, root_tree, transformation)
@classmethod @classmethod
def new_root(cls, paper): def _new_root(cls, paper):
nsmap = { nsmap = {
None: cls.SVG_xmlns, None: cls.SVG_xmlns,
...@@ -223,15 +412,15 @@ class SvgFile(XmlFileMixin): ...@@ -223,15 +412,15 @@ class SvgFile(XmlFileMixin):
attrib['viewBox'] = '0 0 {:.3f} {:.3f}'.format(paper.width, paper.height) attrib['viewBox'] = '0 0 {:.3f} {:.3f}'.format(paper.width, paper.height)
# Fixme: from conf # Fixme: from conf
root.append(etree.Comment('Pattern created with Patro (https://github.com/FabriceSalvaire/Patro)')) root.append(etree.Comment(cls.COMMENT))
return root return root
def write(self, paper, root_tree, transformation=None, path=None): def _write(self, paper, root_tree, transformation=None):
root = self.new_root(paper) root = self._new_root(paper)
# Fixme: implement tree, look at lxml # Fixme: implement tree, look at lxml
if transformation: if transformation:
...@@ -244,14 +433,20 @@ class SvgFile(XmlFileMixin): ...@@ -244,14 +433,20 @@ class SvgFile(XmlFileMixin):
for element in root_tree: for element in root_tree:
group.append(element.to_xml()) group.append(element.to_xml())
if path is None:
path = self.path
tree = etree.ElementTree(root) tree = etree.ElementTree(root)
tree.write(str(path), tree.write(self._path,
pretty_print=True, pretty_print=True,
xml_declaration=True, xml_declaration=True,
encoding='utf-8', encoding='utf-8',
standalone=False, standalone=False,
doctype=self.SVG_DOCTYPE, doctype=self.SVG_DOCTYPE,
class SvgFile:
self._interval = SvgFileInternal(path)
...@@ -66,7 +66,8 @@ __all__ = [ ...@@ -66,7 +66,8 @@ __all__ = [
# import logging import logging
from Patro.Common.Xml.Objectivity import ( from Patro.Common.Xml.Objectivity import (
# BoolAttribute, # BoolAttribute,
IntAttribute, FloatAttribute, IntAttribute, FloatAttribute,
...@@ -76,8 +77,14 @@ from Patro.Common.Xml.Objectivity import ( ...@@ -76,8 +77,14 @@ from Patro.Common.Xml.Objectivity import (
TextXmlObjectAdaptator, TextXmlObjectAdaptator,
# from Patro.GeometryEngine.Vector import Vector2D # Fixme: should we mix SVG format and ... ???
from Patro.GeometryEngine.Path import Path2D
from Patro.GeometryEngine.Transformation import AffineTransformation2D from Patro.GeometryEngine.Transformation import AffineTransformation2D
...@@ -127,71 +134,78 @@ class IdMixin: ...@@ -127,71 +134,78 @@ class IdMixin:
# Presentation Attributes
# alignment-baseline
# baseline-shift
# clip
# clip-path
# clip-rule
# color
# color-interpolation
# color-interpolation-filters
# color-profile
# color-rendering
# cursor
# direction
# display
# dominant-baseline
# enable-background
# fill
# fill-opacity
# fill-rule
# filter
# flood-color
# flood-opacity
# font-family
# font-size
# font-size-adjust
# font-stretch
# font-style
# font-variant
# font-weight
# glyph-orientation-horizontal
# glyph-orientation-vertical
# image-rendering
# kerning
# letter-spacing
# lighting-color
# marker-end
# marker-mid
# marker-start
# mask
# opacity
# overflow
# pointer-events
# shape-rendering
# stop-color
# stop-opacity
# stroke
# stroke-dasharray
# stroke-dashoffset
# stroke-linecap
# stroke-linejoin
# stroke-miterlimit
# stroke-opacity
# stroke-width
# text-anchor
# text-decoration
# text-rendering
# unicode-bidi
# visibility
# word-spacing
# writing-mode
class PresentationAttributes:
# https://developer.mozilla.org/en-US/docs/Web/SVG/Attribute
# Fixme: type !!!
alignment_baseline = None # check
baseline_shift = None # check
clip = None # check
clip_path = None # check
clip_rule = None # check
color = None # check
color_interpolation = None # check
color_interpolation_filters = None # check
color_profile = None # check
color_rendering = None # check
cursor = None # check
direction = None # check
display = None # check
dominant_baseline = None # check
enable_background = None # check
fill = None
fill_opacity = 1
fill_rule = 'nonzero'
#! filter = None # check
flood_color = None # check
flood_opacity = None # check
font_family = None # check
font_size = None # check
font_size_adjust = None # check
font_stretch = None # check
font_style = None # check
font_variant = None # check
font_weight = None # check
glyph_orientation_horizontal = None # check
glyph_orientation_vertical = None # check
image_rendering = None # check
kerning = None # check
letter_spacing = None # check
lighting_color = None # check
marker_end = None # check
marker_mid = None # check
marker_start = None # check
mask = None # check
opacity = 1
overflow = None # check
paint_order = None
pointer_events = None # check
shape_rendering = None # check
stop_color = None # check
stop_opacity = None # check
stroke = None
stroke_dasharray = None # check
stroke_dashoffset = None # check
stroke_linecap = 'butt'
stroke_linejoin = 'miter'
stroke_miterlimit = 4
stroke_opacity = 1
stroke_width = 1 # px
style = None
text_anchor = None # check
text_decoration = None # check
text_rendering = None # check
transform = AffineTransformation2D.Identity()
unicode_bidi = None # check
vector_effect = None
visibility = None # check
word_spacing = None # check
writing_mode = None # check
class InheritAttribute(StringAttribute): class InheritAttribute(StringAttribute):
...@@ -439,13 +453,59 @@ class TransformAttribute(StringAttribute): ...@@ -439,13 +453,59 @@ class TransformAttribute(StringAttribute):
values = [float(x) for x in value[pos0+1:-1].split(',')] values = [float(x) for x in value[pos0+1:-1].split(',')]
transforms.append((transform_type, values)) transforms.append((transform_type, values))
# Fixme: # Fixme:
return transforms
# return transforms
return cls.to_python(transforms, concat=True)
def to_xml(cls, value): def to_xml(cls, value):
return 'matrix({})'.format(' '.join([str(x) for x in value.to_list()])) # Fixme: to func # Fixme: wrong if value is AffineTransformation2D !!!
# Fixme: to func
@classmethod
def to_python(cls, transforms, concat=True):
def complete(values, size):
return values + [0]*(size - len(values))
global_transform = AffineTransformation2D.Identity()
py_transforms = []
for name, values in transforms:
transform = None
if name == 'matrix':
array = [values[i] for i in (0, 2, 4, 1, 3, 5)] + [0, 0, 1]
transform = AffineTransformation2D(array)
elif name == 'translate':
vector = Vector2D(complete(values, 2))
transform = AffineTransformation2D.Translation(vector)
elif name == 'scale':
transform = AffineTransformation2D.Scale(*values)
elif name == 'rotate':
angle, *vector = complete(values, 3)
vector = Vector2D(vector)
transform = AffineTransformation2D.RotationAt(vector, angle)
elif name == 'skewX':
angle = values[0]
elif name == 'skewY':
angle = values[0]
else:
if concat:
global_transform = transform * global_transform
else:
py_transforms.append(transform)
if concat:
return global_transform
else:
return py_transforms
...@@ -891,23 +951,27 @@ class PathDataAttribute(StringAttribute): ...@@ -891,23 +951,27 @@ class PathDataAttribute(StringAttribute):
COMMANDS = ''.join(NUMBER_OF_ARGS.keys()) COMMANDS = ''.join(NUMBER_OF_ARGS.keys())
_logger = _module_logger.getChild('PathDataAttribute')
def from_xml(cls, value): def from_xml(cls, svg_path):
# cls._logger.info('SVG path:\n'+ svg_path)
# Replace comma separator by space # Replace comma separator by space
value = value.replace(',', ' ') cleaned_svg_path = svg_path.replace(',', ' ')
# Add space after letter # Add space after letter
data_path = '' data_path = ''
for c in value: for c in cleaned_svg_path:
data_path += c data_path += c
if c.isalpha: if c.isalpha:
data_path += ' ' data_path += ' '
# Convert float # Convert float values
parts = [] parts = []
for part in split_space_list(value): for part in split_space_list(cleaned_svg_path):
if not(len(part) == 1 and part.isalpha): if not(len(part) == 1 and part.isalpha()):
part = float(part) part = float(part)
parts.append(part) parts.append(part)
...@@ -921,17 +985,23 @@ class PathDataAttribute(StringAttribute): ...@@ -921,17 +985,23 @@ class PathDataAttribute(StringAttribute):
command = part command = part
command_lower = command.lower() command_lower = command.lower()
if command_lower not in cls.COMMANDS: if command_lower not in cls.COMMANDS:
raise ValueError('Invalid path instruction') raise ValueError("Invalid path instruction: '{}' in\n{}".format(command, svg_path))
number_of_args = cls.NUMBER_OF_ARGS[command_lower] number_of_args = cls.NUMBER_OF_ARGS[command_lower]
i += 1 # move to first arg
# else repeated instruction # else repeated instruction
next_i = i + number_of_args + 1 next_i = i + number_of_args
values = parts[i+1:next_i] args = parts[i:next_i]
#! points = [Vector2D(values[2*i], values[2*i+1]) for i in range(number_of_args / 2)] commands.append((command, args))
points = values
commands.append((command, points))
i = next_i i = next_i
# for implicit line to
if command == 'm':
command = 'l'
elif command == 'M':
command = 'L'
return commands # return commands
# Fixme: do later ???
return cls.to_geometry(commands)
...@@ -945,6 +1015,62 @@ class PathDataAttribute(StringAttribute): ...@@ -945,6 +1015,62 @@ class PathDataAttribute(StringAttribute):
path_data += ' '.join(list(command[0]) + [str(x) for x in command[1]]) path_data += ' '.join(list(command[0]) + [str(x) for x in command[1]])
return path_data return path_data
@classmethod
def as_vector(cls, args):
number_of_args = len(args)
number_of_vectors = number_of_args // 2
if number_of_args != number_of_vectors * 2:
raise ValueError('len(args) is not // 2: {}'.format(number_of_args))
return [Vector2D(args[i:i+2]) for i in range(0, number_of_args, 2)]
@classmethod
def to_geometry(cls, commands):
# cls._logger.info('Path:\n' + str(commands).replace('), ', '),\n '))
path = None
for command, args in commands:
absolute = command_lower != command # Upper case means absolute
# if is_lower:
# cls._logger.warning('incremental command')
# raise NotImplementedError
if path is None:
if command_lower != 'm':
raise NameError('Path must start with m')
path = Path2D(args) # Vector2D()
else:
if command_lower == 'l':
path.line_to(args, absolute=absolute)
elif command == 'h':
path.horizontal_to(*args, absolute=False)
elif command == 'H':
path.absolute_horizontal_to(*args)
elif command_lower == 'v':
path.vertical_to(*args, absolute=absolute)
elif command == 'V':
path.absolute_vertical_to(*args)
elif command_lower == 'c':
path.cubic_to(*cls.as_vector(args), absolute=absolute)
elif command_lower == 's':
path.stringed_quadratic_to(*cls.as_vector(args), absolute=absolute)
elif command_lower == 'q':
path.quadratic_to(*cls.as_vector(args), absolute=absolute)
elif command_lower == 't':
path.stringed_cubic_to(*cls.as_vector(args), absolute=absolute)
elif command_lower == 'a':
radius_x, radius_y, angle, large_arc, sweep, x, y = args
point = Vector2D(x, y)
path.arc_to(point, radius_x, radius_y, angle, bool(large_arc), bool(sweep), absolute=absolute)
elif command_lower == 'z':
path.close()
return path
class Path(PathMixin, SvgElementMixin, XmlObjectAdaptator): class Path(PathMixin, SvgElementMixin, XmlObjectAdaptator):
...@@ -1028,6 +1154,32 @@ class Rect(PositionMixin, RadiusMixin, SizeMixin, PathMixin, SvgElementMixin, Xm ...@@ -1028,6 +1154,32 @@ class Rect(PositionMixin, RadiusMixin, SizeMixin, PathMixin, SvgElementMixin, Xm
__tag__ = 'rect' __tag__ = 'rect'
@property
def geometry(self):
# Fixme: width is str
width = float(self.width)
height = float(self.height)
# Fixme: which one ???
radius_x = self.rx
radius_y = self.ry
if radius_y == 0:
radius = None
else:
radius = radius_y
point = Vector2D(self.x, self.y)
path = Path2D(point)
path.horizontal_to(width)
path.vertical_to(height, radius=radius)
path.horizontal_to(-width, radius=radius)
path.close(radius=radius, close_radius=radius)
return path
class Stop(XmlObjectAdaptator): class Stop(XmlObjectAdaptator):
...@@ -75,7 +75,7 @@ class VitFileInternal(XmlFileMixin): ...@@ -75,7 +75,7 @@ class VitFileInternal(XmlFileMixin):
def __init__(self, path): def __init__(self, path):
XmlFileMixin.__init__(self, path) super().__init__(path)
self.measurements = ValentinaMeasurements() self.measurements = ValentinaMeasurements()
self.read() self.read()
...@@ -20,185 +20,20 @@ ...@@ -20,185 +20,20 @@
r"""Module to implement Bézier curve. r"""Module to implement Bézier curve.
Definitions For resources on Bézier curve see :ref:`this section <bezier-geometry-ressources-page>`.
A Bézier curve is defined by a set of control points :math:`\mathbf{P}_0` through
:math:`\mathbf{P}_n`, where :math:`n` is called its order (:math:`n = 1` for linear, 2 for
quadratic, 3 for cubic etc.). The first and last control points are always the end points of the
curve;
In the following :math:`0 \le t \le 1`.
Linear Bézier Curves
Given distinct points :math:`\mathbf{P}_0` and :math:`\mathbf{P}_1`, a linear Bézier curve is simply
a straight line between those two points. The curve is given by
.. math::
\begin{align}
\mathbf{B}(t) &= \mathbf{P}_0 + t (\mathbf{P}_1 - \mathbf{P}_0) \\
&= (1-t) \mathbf{P}_0 + t \mathbf{P}_1
\end{align}
and is equivalent to linear interpolation.
Quadratic Bézier Curves
A quadratic Bézier curve is the path traced by the function :math:`\mathbf{B}(t)`, given points
:math:`\mathbf{P}_0`, :math:`\mathbf{P}_1`, and :math:`\mathbf{P}_2`,
.. math::
\mathbf{B}(t) = (1 - t)[(1 - t) \mathbf{P}_0 + t \mathbf{P}_1] + t [(1 - t) \mathbf{P}_1 + t \mathbf{P}_2]
which can be interpreted as the linear interpolant of corresponding points on the linear Bézier
curves from :math:`\mathbf{P}_0` to :math:`\mathbf{P}_1` and from :math:`\mathbf{P}_1` to
:math:`\mathbf{P}_2` respectively.
Rearranging the preceding equation yields:
.. math::
\mathbf{B}(t) = (1 - t)^{2} \mathbf{P}_0 + 2(1 - t)t \mathbf{P}_1 + t^{2} \mathbf{P}_2
This can be written in a way that highlights the symmetry with respect to :math:`\mathbf{P}_1`:
.. math::
\mathbf{B}(t) = \mathbf{P}_1 + (1 - t)^{2} ( \mathbf{P}_0 - \mathbf{P}_1) + t^{2} (\mathbf{P}_2 - \mathbf{P}_1)
Which immediately gives the derivative of the Bézier curve with respect to `t`:
.. math::
\mathbf{B}'(t) = 2(1 - t) (\mathbf{P}_1 - \mathbf{P}_0) + 2t (\mathbf{P}_2 - \mathbf{P}_1)
from which it can be concluded that the tangents to the curve at :math:`\mathbf{P}_0` and
:math:`\mathbf{P}_2` intersect at :math:`\mathbf{P}_1`. As :math:`t` increases from 0 to 1, the
curve departs from :math:`\mathbf{P}_0` in the direction of :math:`\mathbf{P}_1`, then bends to
arrive at :math:`\mathbf{P}_2` from the direction of :math:`\mathbf{P}_1`.
The second derivative of the Bézier curve with respect to :math:`t` is
.. math::
\mathbf{B}''(t) = 2 (\mathbf{P}_2 - 2 \mathbf{P}_1 + \mathbf{P}_0)
Cubic Bézier Curves
Four points :math:`\mathbf{P}_0`, :math:`\mathbf{P}_1`, :math:`\mathbf{P}_2` and
:math:`\mathbf{P}_3` in the plane or in higher-dimensional space define a cubic Bézier curve. The
curve starts at :math:`\mathbf{P}_0` going toward :math:`\mathbf{P}_1` and arrives at
:math:`\mathbf{P}_3` coming from the direction of :math:`\mathbf{P}_2`. Usually, it will not pass
through :math:`\mathbf{P}_1` or :math:`\mathbf{P}_2`; these points are only there to provide
directional information. The distance between :math:`\mathbf{P}_1` and :math:`\mathbf{P}_2`
determines "how far" and "how fast" the curve moves towards :math:`\mathbf{P}_1` before turning
towards :math:`\mathbf{P}_2`.
Writing :math:`\mathbf{B}_{\mathbf P_i,\mathbf P_j,\mathbf P_k}(t)` for the quadratic Bézier curve
defined by points :math:`\mathbf{P}_i`, :math:`\mathbf{P}_j`, and :math:`\mathbf{P}_k`, the cubic
Bézier curve can be defined as an affine combination of two quadratic Bézier curves:
.. math::
\mathbf{B}(t) = (1-t) \mathbf{B}_{\mathbf P_0,\mathbf P_1,\mathbf P_2}(t) +
t \mathbf{B}_{\mathbf P_1,\mathbf P_2,\mathbf P_3}(t)
The explicit form of the curve is:
.. math::
\mathbf{B}(t) = (1-t)^3 \mathbf{P}_0 + 3(1-t)^2t \mathbf{P}_1 + 3(1-t)t^2 \mathbf{P}_2 + t^3\mathbf{P}_3
For some choices of :math:`\mathbf{P}_1` and :math:`\mathbf{P}_2` the curve may intersect itself, or
contain a cusp.
The derivative of the cubic Bézier curve with respect to :math:`t` is
.. math::
\mathbf{B}'(t) = 3(1-t)^2 (\mathbf{P}_1 - \mathbf{P}_0) + 6(1-t)t (\mathbf{P}_2 - \mathbf{P}_1) + 3t^2 (\mathbf{P}_3 - \mathbf{P}_2)
.. math::
\mathbf{B}''(t) = 6(1-t) (\mathbf{P}_2 - 2 \mathbf{P}_1 + \mathbf{P}_0) + 6t (\mathbf{P}_3 - 2 \mathbf{P}_2 + \mathbf{P}_1)
Recursive definition
A recursive definition for the Bézier curve of degree :math:`n` expresses it as a point-to-point
linear combination of a pair of corresponding points in two Bézier curves of degree :math:`n-1`.
Let :math:`\mathbf{B}_{\mathbf{P}_0\mathbf{P}_1\ldots\mathbf{P}_n}` denote the Bézier curve
determined by any selection of points :math:`\mathbf{P}_0`, :math:`\mathbf{P}_1`, :math:`\ldots`,
:math:`\mathbf{P}_{n-1}`.
The recursive definition is
.. math::
\begin{align}
\mathbf{B}_{\mathbf{P}_0}(t) &= \mathbf{P}_0 \\[1em]
\mathbf{B}(t) &= \mathbf{B}_{\mathbf{P}_0\mathbf{P}_1\ldots\mathbf{P}_n}(t) \\
&= (1-t) \mathbf{B}_{\mathbf{P}_0\mathbf{P}_1\ldots\mathbf{P}_{n-1}}(t) +
t \mathbf{B}_{\mathbf{P}_1\mathbf{P}_2\ldots\mathbf{P}_n}(t)
\end{align}
The formula can be expressed explicitly as follows:
.. math::
\begin{align}
\mathbf{B}(t) &= \sum_{i=0}^n b_{i,n}(t) \mathbf{P}_i \\
&= \sum_{i=0}^n {n\choose i}(1 - t)^{n - i}t^i \mathbf{P}_i \\
&= (1 - t)^n \mathbf{P}_0 +
{n\choose 1}(1 - t)^{n - 1}t \mathbf{P}_1 +
\cdots +
{n\choose n - 1}(1 - t)t^{n - 1} \mathbf{P}_{n - 1} +
t^n \mathbf{P}_n
\end{align}
where :math:`b_{i,n}(t)` are the Bernstein basis polynomials of degree :math:`n` and :math:`n
\choose i` are the binomial coefficients.
Degree elevation
A Bézier curve of degree :math:`n` can be converted into a Bézier curve of degree :math:`n + 1` with
the same shape.
To do degree elevation, we use the equality
.. math::
\mathbf{B}(t) = (1-t) \mathbf{B}(t) + t \mathbf{B}(t)`
Each component :math:`\mathbf{b}_{i,n}(t) \mathbf{P}_i` is multiplied by :math:`(1-t)` and
:math:`t`, thus increasing a degree by one, without changing the value.
For arbitrary :math:`n`, we have
.. math::
\begin{align}
\mathbf{B}(t) &= (1 - t) \sum_{i=0}^n \mathbf{b}_{i,n}(t) \mathbf{P}_i +
t \sum_{i=0}^n \mathbf{b}_{i,n}(t) \mathbf{P}_i \\
&= \sum_{i=0}^n \frac{n + 1 - i}{n + 1} \mathbf{b}_{i, n + 1}(t) \mathbf{P}_i +
\sum_{i=0}^n \frac{i + 1}{n + 1} \mathbf{b}_{i + 1, n + 1}(t) \mathbf{P}_i \\
&= \sum_{i=0}^{n + 1} \mathbf{b}_{i, n + 1}(t)
\left(\frac{i}{n + 1} \mathbf{P}_{i - 1} +
\frac{n + 1 - i}{n + 1} \mathbf{P}_i\right) \\
&= \sum_{i=0}^{n + 1} \mathbf{b}_{i, n + 1}(t) \mathbf{P'}_i
\end{align}
Therefore the new control points are
.. math::
\mathbf{P'}_i = \frac{i}{n + 1} \mathbf{P}_{i - 1} + \frac{n + 1 - i}{n + 1} \mathbf{P}_i
It introduces two arbitrary points :math:`\mathbf{P}_{-1}` and :math:`\mathbf{P}_{n+1}` which are
cancelled in :math:`\mathbf{P'}_i`.
# Notes: algorithm details are on bezier.rst
# Fixme: # Fixme:
# max distance to the chord for linear approximation # max distance to the chord for linear approximation
# fitting # fitting
# C0 = continuous # C0 = continuous
# G1 = geometric continuity # G1 = geometric continuity
# Tangents point to the same direction # Tangents point to the same direction
...@@ -216,6 +51,8 @@ __all__ = [ ...@@ -216,6 +51,8 @@ __all__ = [
import logging
from math import log, sqrt from math import log, sqrt
import numpy as np import numpy as np
...@@ -229,12 +66,18 @@ from .Vector import Vector2D ...@@ -229,12 +66,18 @@ from .Vector import Vector2D
class BezierMixin2D(Primitive2DMixin): class BezierMixin2D(Primitive2DMixin):
"""Mixin to implements 2D Bezier Curve.""" """Mixin to implements 2D Bezier Curve."""
LineInterpolationPrecision = 0.05 LineInterpolationPrecision = 0.05
_logger = _module_logger.getChild('BezierMixin2D')
def interpolated_length(self, dt=None): def interpolated_length(self, dt=None):
...@@ -368,16 +211,6 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -368,16 +211,6 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
"""Class to implements 2D Quadratic Bezier Curve.""" """Class to implements 2D Quadratic Bezier Curve."""
# Q(t) = Transformation * Control * Basis * T(t)
# / P1x P2x P3x \ / 1 -2 1 \ / 1 \
# Q(t) = Tr | P1y P2x P3x | | 0 2 -2 | | t |
# \ 1 1 1 / \ 0 0 1 / \ t**2 /
# Q(t) = P0 * (1 - 2*t + t**2) +
# P1 * ( 2*t - t**2) +
# P2 * t**2
BASIS = np.array(( BASIS = np.array((
(1, -2, 1), (1, -2, 1),
(0, 2, -2), (0, 2, -2),
...@@ -390,6 +223,8 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -390,6 +223,8 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
(-1, -1, -2), (-1, -1, -2),
_logger = _module_logger.getChild('QuadraticBezier2D')
def __init__(self, p0, p1, p2): def __init__(self, p0, p1, p2):
...@@ -405,28 +240,11 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -405,28 +240,11 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
@property @property
def length(self): def length(self):
# Algorithm: r"""Compute the length of the curve.
# http://www.gamedev.net/topic/551455-length-of-a-generalized-quadratic-bezier-curve-in-3d For more details see :ref:`this section <bezier-curve-length-section>`.
# Dave Eberly Posted October 25, 2009
# The quadratic Bezier is
# (x(t),y(t)) = (1-t)^2*(x0,y0) + 2*t*(1-t)*(x1,y1) + t^2*(x2,y2)
# The derivative is
# (x'(t),y'(t)) = -2*(1-t)*(x0,y0) + (2-4*t)*(x1,y1) + 2*t*(x2,y2)
# The length of the curve for 0 <= t <= 1 is
# Integral[0,1] sqrt((x'(t))^2 + (y'(t))^2) dt
# The integrand is of the form sqrt(c*t^2 + b*t + a)
# You have three separate cases: c = 0, c > 0, or c < 0.
# * The case c = 0 is easy.
# * For the case c > 0, an antiderivative is
# (2*c*t+b)*sqrt(c*t^2+b*t+a)/(4*c) + (0.5*k)*log(2*sqrt(c*(c*t^2+b*t+a)) + 2*c*t + b)/sqrt(c)
# where k = 4*c/q with q = 4*a*c - b*b.
# * For the case c < 0, an antiderivative is
# (2*c*t+b)*sqrt(c*t^2+b*t+a)/(4*c) - (0.5*k)*arcsin((2*c*t+b)/sqrt(-q))/sqrt(-c)
A0 = self._p1 - self._p0 A0 = self._p1 - self._p0
A1 = self._p0 - self._p1 * 2 + self._p2 A1 = self._p0 - self._p1 * 2 + self._p2
...@@ -505,19 +323,10 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -505,19 +323,10 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
"""Find the intersections of the curve with a line. """Find the intersections of the curve with a line.
Algorithm For more details see :ref:`this section <bezier-curve-line-intersection-section>`.
* Apply a transformation to the curve that maps the line onto the X-axis.
* Then we only need to test the Y-values for a zero.
# t, p0, p1, p2, p3 = symbols('t p0 p1 p2 p3')
# u = 1 - t
# B = p0 * u**2 + p1 * 2*t*u + p2 * t**2
# collect(expand(B), t)
# solveset(B, t)
curve = self._map_to_line(line) curve = self._map_to_line(line)
p0 = curve.p0.y p0 = curve.p0.y
...@@ -566,48 +375,10 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -566,48 +375,10 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
"""Return the closest point on the curve to the given *point*. """Return the closest point on the curve to the given *point*.
Reference For more details see :ref:`this section <bezier-curve-closest-point-section>`.
* https://hal.archives-ouvertes.fr/inria-00518379/document
Improved Algebraic Algorithm On Point Projection For Bézier Curves
Xiao-Diao Chen, Yin Zhou, Zhenyu Shu, Hua Su, Jean-Claude Paul
# Condition:
# (P - B(t)) . B'(t) = 0 where t in [0,1]
# P. B'(t) - B(t). B'(t) = 0
# A = P1 - P0
# B = P2 - P1 - A
# M = P0 - P
# Q(t) = P0*(1-t)**2 + P1*2*t*(1-t) + P2*t**2
# Q'(t) = -2*P0*(1 - t) + 2*P1*(1 - 2*t) + 2*P2*t
# = 2*(A + B*t)
# P0, P1, P2, P, t = symbols('P0 P1 P2 P t')
# Q = P0 * (1-t)**2 + P1 * 2*t*(1-t) + P2 * t**2
# Qp = simplify(Q.diff(t))
# collect(expand((P*Qp - Q*Qp)/-2), t)
# (P0**2 - 4*P0*P1 + 2*P0*P2 + 4*P1**2 - 4*P1*P2 + P2**2) * t**3
# (-3*P0**2 + 9*P0*P1 - 3*P0*P2 - 6*P1**2 + 3*P1*P2) * t**2
# (-P*P0 + 2*P*P1 - P*P2 + 3*P0**2 - 6*P0*P1 + P0*P2 + 2*P1**2) * t
# P*P0 - P*P1 - P0**2 + P0*P1
# factorisation
# (P0 - 2*P1 + P2)**2 * t**3
# 3*(P1 - P0)*(P0 - 2*P1 + P2) * t**2
# (P0 - P)*(P1 - P0)
# B**2 * t**3
# 3*A*B * t**2
# (2*A**2 + M*B) * t
# M*A
A = self._p1 - self._p0 A = self._p1 - self._p0
B = self._p2 - self._p1 - A B = self._p2 - self._p1 - A
M = self._p0 - point M = self._p0 - point
...@@ -622,7 +393,8 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -622,7 +393,8 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
if not t: if not t:
return None return None
elif len(t) > 1: elif len(t) > 1:
raise NameError("Found more than on root") self._logger.warning("Found more than one root {} for {} and point {}".format(t, self, point))
return None
else: else:
return self.point_at_t(t) return self.point_at_t(t)
...@@ -632,22 +404,14 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P): ...@@ -632,22 +404,14 @@ class QuadraticBezier2D(BezierMixin2D, Primitive3P):
r"""Elevate the quadratic Bézier curve to a cubic Bézier cubic with the same shape. r"""Elevate the quadratic Bézier curve to a cubic Bézier cubic with the same shape.
The new control points are For more details see :ref:`this section <bezier-curve-degree-elevation-section>`.
.. math::
\begin{align}
\mathbf{P'}_0 &= \mathbf{P}_0 \\
\mathbf{P'}_1 &= \mathbf{P}_0 + \frac{2}{3} (\mathbf{P}_1 - \mathbf{P}_0) \\
\mathbf{P'}_1 &= \mathbf{P}_2 + \frac{2}{3} (\mathbf{P}_1 - \mathbf{P}_2) \\
\mathbf{P'}_2 &= \mathbf{P}_2
\end{align}
p1 = (self._p0 + self._p1 * 2) / 3 p1 = (self._p0 + self._p1 * 2) / 3
p2 = (self._p2 + self._p1 * 2) / 3 p2 = (self._p2 + self._p1 * 2) / 3
return CubicBezier2D(self._p0, p1, p2, self._p3) return CubicBezier2D(self._p0, p1, p2, self._p2)
...@@ -662,13 +426,6 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -662,13 +426,6 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
InterpolationPrecision = 0.001 InterpolationPrecision = 0.001
# / P1x P2x P3x P4x \ / 1 -3 3 -1 \ / 1 \
# Q(t) = Tr | P1y P2x P3x P4x | | 0 3 -6 3 | | t |
# | 0 0 0 0 | | 0 0 3 -3 | | t**2 |
# \ 1 1 1 1 / \ 0 0 0 1 / \ t**3 /
(1, -3, 3, -1), (1, -3, 3, -1),
(0, 3, -6, 3), (0, 3, -6, 3),
...@@ -683,6 +440,8 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -683,6 +440,8 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
(0, 0, 0, 1), (0, 0, 0, 1),
_logger = _module_logger.getChild('CubicMixin2D')
def __init__(self, p0, p1, p2, p3): def __init__(self, p0, p1, p2, p3):
...@@ -698,7 +457,7 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -698,7 +457,7 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
def to_spline(self): def to_spline(self):
from .Spline import CubicUniformSpline2D from .Spline import CubicUniformSpline2D
basis = np.dot(self.BASIS, CubicUniformSpline2D.INVERSE_BASIS) basis = np.dot(self.BASIS, CubicUniformSpline2D.INVERSE_BASIS)
points = np.dot(self.geometry_matrix, basis).transpose() points = np.dot(self.point_array, basis).transpose()
return CubicUniformSpline2D(*points) return CubicUniformSpline2D(*points)
...@@ -804,7 +563,6 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -804,7 +563,6 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
# Algorithm: same as for quadratic # Algorithm: same as for quadratic
# t, p0, p1, p2, p3, p4 = symbols('t p0 p1 p2 p3 p4')
# u = 1 - t # u = 1 - t
# B = p0 * u**3 + # B = p0 * u**3 +
# p1 * 3 * u**2 * t + # p1 * 3 * u**2 * t +
...@@ -977,10 +735,15 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -977,10 +735,15 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
locations=[], locations=[],
# Code inspired from """Compute the intersection of two Bézier curves.
# https://github.com/paperjs/paper.js/blob/master/src/path/Curve.js
# http://nbviewer.jupyter.org/gist/hkrish/0a128f21a5b9e5a7a914 The Bezier Clipping Algorithm Code inspired from
# https://gist.github.com/hkrish/5ef0f2da7f9882341ee5 hkrish/bezclip_manual.py
* https://github.com/paperjs/paper.js/blob/master/src/path/Curve.js
* http://nbviewer.jupyter.org/gist/hkrish/0a128f21a5b9e5a7a914 The Bezier Clipping Algorithm
* https://gist.github.com/hkrish/5ef0f2da7f9882341ee5 hkrish/bezclip_manual.py
# Note: # Note:
# see https://github.com/paperjs/paper.js/issues/565 # see https://github.com/paperjs/paper.js/issues/565
...@@ -1071,58 +834,25 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -1071,58 +834,25 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
def is_flat_enough(self, flatness): def is_flat_enough(self, flatness):
"""Determines if a curve is sufficiently flat, meaning it appears as a straight line and has r"""Determines if a curve is sufficiently flat, meaning it appears as a straight line and has
curve-time that is enough linear, as specified by the given *flatness* parameter. curve-time that is enough linear, as specified by the given *flatness* parameter.
*flatness* is the maximum error allowed for the straight line to deviate from the curve. For more details see :ref:`this section <bezier-curve-flatness-section>`.
Reference u = 3*self._p1 - 2*self._p0 - self._p3
v = 3*self._p2 - 2*self._p3 - self._p0
* Kaspar Fischer and Roger Willcocks http://hcklbrrfnn.files.wordpress.com/2012/08/bez.pdf criterion = max(u.x**2, v.x**2) + max(u.y**2, v.y**2)
* PostScript Language Reference. Addison- Wesley, third edition, 1999 threshold = 16 * flatness**2
""" self._logger.warning("is flat {} <= {} with flatness {}".format(criterion, threshold, flatness))
# We define the flatness of the curve as the argmax of the distance from the curve to the return criterion <= threshold
# line passing by the start and stop point.
# flatness = argmax(d(t)) for t in [0, 1] where d(t) = | B(t) - L(t) |
# L = (1-t)*P0 + t*P1
# Let
# u = 3*P1 - 2*P0 - P3
# v = 3*P2 - P0 - 2*P3
# d(t) = (1-t)**2 * t * (3*P1 - 2*P0 - P3) + (1-t) * t**2 * (3*P2 - P0 - 2*P3)
# = (1-t)**2 * t * u + (1-t) * t**2 * v
# d(t)**2 = (1 - t)**2 * t**2 * (((1 - t)*ux + t*vx)**2 + ((1 - t)*uy + t*vy)**2
# argmax((1 - t)**2 * t**2) = 1/16
# argmax((1 - t)*a + t*b) = argmax(a, b)
# flatness**2 = argmax(d(t)**2) <= 1/16 * (argmax(ux**2, vx**2) + argmax(uy**2, vy**2))
# argmax(ux**2, vx**2) + argmax(uy**2, vy**2) is thus an upper bound of 16 * flatness**2
# x0, y0 = list(self._p0)
# x1, y1 = list(self._p1)
# x2, y2 = list(self._p2)
# x3, y3 = list(self._p3)
# ux = 3*x1 - 2*x0 - x3
# uy = 3*y1 - 2*y0 - y3
# vx = 3*x2 - 2*x3 - x0
# vy = 3*y2 - 2*y3 - y0
v = 3*P2 - 2*P3 - P0
return max(u.x**2, v.x**2) + max(u.y**2, v.y**2) <= 16 * flatness**2
@property @property
def area(self): def area(self):
...@@ -1145,31 +875,11 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -1145,31 +875,11 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
def closest_point(self, point): def closest_point(self, point):
# Q(t) = (P3 - 3*P2 + 3*P1 - P0) * t**3 + """Return the closest point on the curve to the given *point*.
# 3*(P2 - 2*P1 + P0) * t**2 +
# 3*(P1 - P0) * t +
# P0
# n = P3 - 3*P2 + 3*P1 - P0
# r = 3*(P2 - 2*P1 + P0
# s = 3*(P1 - P0)
# v = P0
# Q(t) = n*t**3 + r*t**2 + s*t + v
# Q'(t) = 3*n*t**2 + 2*r*t + s
# P0, P1, P2, P3, P, t = symbols('P0 P1 P2 P3 P t') For more details see :ref:`this section <bezier-curve-closest-point-section>`.
# n, r, s, v = symbols('n r s v')
# Q = n*t**3 + r*t**2 + s*t + v
# collect(expand((P*Qp - Q*Qp)), t)
# -3*n**2 * t**5 """
# -5*n*r * t**4
# -2*(2*n*s + r**2) * t**3
# 3*(P*n - n*v - r*s) * t**2
# (2*P*r - 2*r*v - s**2) * t
# P*s - s*v
n = self._p3 - self._p2*3 + self._p1*3 - self._p0 n = self._p3 - self._p2*3 + self._p1*3 - self._p0
r = (self._p2 - self._p1*2 + self._p0)*3 r = (self._p2 - self._p1*2 + self._p0)*3
...@@ -1189,6 +899,18 @@ class CubicBezier2D(BezierMixin2D, Primitive4P): ...@@ -1189,6 +899,18 @@ class CubicBezier2D(BezierMixin2D, Primitive4P):
if not t: if not t:
raise NameError("Found more than on root") # Fixme:
# Found more than one root [0, 0.516373783749732]
# for CubicBezier2D(
# Vector2D[1394.4334 1672.0004], Vector2D[1394.4334 1672.0004],
# Vector2D[1585.0004 1624.9634], Vector2D[1585.0004 1622.0004])
# and point Vector2D[1495.11502887 1649.7386517 ]
# raise NameError("Found more than one root: {}".format(t))
# self._logger.warning("is flat {}".format(self.is_flat_enough(.1)))
if len(t) == 2 and t[0] == 0:
return self.point_at_t(t[1])
else:
return None
else: else:
return self.point_at_t(t[0]) return self.point_at_t(t[0])
...@@ -20,16 +20,16 @@ ...@@ -20,16 +20,16 @@
"""Module to implement conic geometry like circle and ellipse. """Module to implement conic geometry like circle and ellipse.
Valentina Requirements *Valentina Requirements*
* circle with angular domain * circle with angular domain
* circle with start angle and arc length * circle with start angle and arc length
* curvilinear distance on circle * curvilinear distance on circle
* line-circle intersection * line-circle intersection
* circle-circle intersection * circle-circle intersection
* point constructed from a virtual circle and a point on a tangent : right triangle * point constructed from a virtual circle and a point on a tangent : right triangle
* point from tangent circle and segment ??? * point from tangent circle and segment ???
* ellipse with angular domain and rotation * ellipse with angular domain and rotation
...@@ -48,6 +48,8 @@ __all__ = [ ...@@ -48,6 +48,8 @@ __all__ = [
import logging
import math import math
from math import fabs, sqrt, radians, pi, cos, sin # , degrees from math import fabs, sqrt, radians, pi, cos, sin # , degrees
...@@ -59,6 +61,11 @@ from .Line import Line2D ...@@ -59,6 +61,11 @@ from .Line import Line2D
from .Mixin import AngularDomainMixin, CenterMixin, AngularDomain from .Mixin import AngularDomainMixin, CenterMixin, AngularDomain
from .Primitive import Primitive, Primitive2DMixin from .Primitive import Primitive, Primitive2DMixin
from .Segment import Segment2D from .Segment import Segment2D
from .Transformation import Transformation2D
...@@ -436,35 +443,144 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -436,35 +443,144 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
\ge e_1 > 0`. The ellipse points are \ge e_1 > 0`. The ellipse points are
.. math:: .. math::
P = C + x_0 U_0 + x_1 U_1 \begin{equation}
\end{equation}
where where
.. math:: .. math::
\begin{equation}
\left(\frac{x_0}{e_0}\right)^2 + \left(\frac{x_1}{e_1}\right)^2 = 1 \left(\frac{x_0}{e_0}\right)^2 + \left(\frac{x_1}{e_1}\right)^2 = 1
\end{equation}
If :math:`e_0 = e_1`, then the ellipse is a circle with center `C` and radius :math:`e_0`.
If :math:`e_0 = e_1`, then the ellipse is a circle with center `C` and radius :math:`e_0`. The The orthonormality of the axis directions and Equation (1) imply :math:`x_i = U_i \dot (P −
C)`. Substituting this into Equation (2) we obtain C)`. Substituting this into Equation (2) we obtain
.. math:: .. math::
(P − C)^T M (P − C) = 1 (P − C)^T M (P − C) = 1
where :math:`M = R D R^T`, `R` is an orthogonal matrix whose columns are :math:`U_0` and where :math:`M = R D R^T`, `R` is an orthogonal matrix whose columns are :math:`U_0` and
:math:`U_1` , and `D` is a diagonal matrix whose diagonal entries are :math:`1/e_0^2` and :math:`U_1` , and `D` is a diagonal matrix whose diagonal entries are :math:`1/e_0^2` and
:math:`1/e_1^2`. :math:`1/e_1^2`.
An ellipse can also be parameterised by an angle :math:`\theta`
.. math::
\begin{pmatrix} x \\ y \end{pmatrix} =
\begin{bmatrix}
\cos\phi & \sin\phi \\
-\sin\phi & \cos\phi
\end{bmatrix}
\begin{pmatrix} r_x \cos\theta \\ r_y \sin\theta \end{pmatrix}
+ \begin{pmatrix} C_x \\ C_y \end{pmatrix}
where :math:`\phi` is the angle from the x-axis, :math:`r_x` is the semi-major and :math:`r_y`
semi-minor axes.
_logger = _module_logger.getChild('Ellipse2D')
@classmethod
def svg_arc(cls, point1, point2, radius_x, radius_y, angle, large_arc, sweep):
"""Implement SVG Arc.
Parameters
* *point1* is the start point and *point2* is the end point.
* *radius_x* and *radius_y* are the radii of the ellipse, also known as its semi-major and
semi-minor axes.
* *angle* is the angle from the x-axis of the current coordinate system to the x-axis of the ellipse.
* if the *large arc* flag is unset then arc spanning less than or equal to 180 degrees is
chosen, else an arc spanning greater than 180 degrees is chosen.
* if the *sweep* flag is unset then the line joining centre to arc sweeps through decreasing
angles, else if it sweeps through increasing angles.
References
* https://www.w3.org/TR/SVG/implnote.html#ArcConversionEndpointToCenter
* https://www.w3.org/TR/SVG/implnote.html#ArcCorrectionOutOfRangeRadii
# Ensure radii are non-zero
if radius_x == 0 or radius_y == 0:
return Segment2D(point1, point2)
# Ensure radii are positive
radius_x = abs(radius_x)
radius_y = abs(radius_y)
# step 1
radius_x2 = radius_x**2
radius_y2 = radius_y**2
# We define a new referential with the origin is set to the middle of P1 — P2
origin_prime = (point1 + point2)/2
# P1 is exprimed in this referential where the ellipse major axis line up with the x axis
point1_prime = Transformation2D.Rotation(-angle) * (point1 - point2)/2
# Ensure radii are large enough
radii_scale = point1_prime.x**2/radius_x2 + point1_prime.y**2/radius_y2
if radii_scale > 1:
self._logger.warning('SVG Arc: radii must be scale')
radii_scale = math.sqrt(radii_scale)
radius_x = radii_scale * radius_x
radius_y = radii_scale * radius_y
# step 2
den = radius_x2 * point1_prime.y**2 + radius_y2 * point1_prime.x**2
num = radius_x2*radius_y2 - den
ratio = radius_x/radius_y
sign = 1 if large_arc != sweep else -1
# print(point1_prime)
# print(point1_prime.anti_normal)
# print(ratio)
# print(point1_prime.anti_normal.scale(ratio, 1/ratio))
sign *= -1 # Fixme: solve mirroring artefacts for y-axis pointing to the top
center_prime = sign * math.sqrt(num / den) * point1_prime.anti_normal.scale(ratio, 1/ratio)
center = Transformation2D.Rotation(angle) * center_prime + origin_prime
vector1 = (point1_prime - center_prime).divide(radius_x, radius_y)
vector2 = - (point1_prime + center_prime).divide(radius_x, radius_y)
theta = cls.__vector_cls__(1, 0).angle_with(vector1)
delta_theta = vector1.angle_with(vector2)
# if theta < 0:
# theta = 180 + theta
# if delta_theta < 0:
# delta_theta = 180 + delta_theta
delta_theta = delta_theta % 360
# print('theta', theta, delta_theta)
if not sweep and delta_theta > 0:
delta_theta -= 360
elif sweep and delta_theta < 0:
delta_theta += 360
# print('theta', theta, delta_theta, theta + delta_theta)
domain = domain = AngularDomain(theta, theta + delta_theta)
return cls(center, radius_x, radius_y, angle, domain)
def __init__(self, center, x_radius, y_radius, angle, domain=None): def __init__(self, center, radius_x, radius_y, angle, domain=None):
self.center = center self.center = center
self.x_radius = x_radius self.radius_x = radius_x
self.y_radius = y_radius self.radius_y = radius_y
self.angle = angle self.angle = angle
self.domain = domain self.domain = domain
...@@ -475,7 +591,7 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -475,7 +591,7 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
def clone(self): def clone(self):
return self.__class__( return self.__class__(
self._center, self._center,
self._x_radius, self._y_radius, self._radius_x, self._radius_y,
self._angle, self._angle,
self._domain, self._domain,
...@@ -484,32 +600,32 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -484,32 +600,32 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
def apply_transformation(self, transformation): def apply_transformation(self, transformation):
self._center = transformation * self._center self._center = transformation * self._center
self._x_radius = transformation * self._x_radius self._radius_x = transformation * self._radius_x
self._y_radius = transformation * self._y_radius self._radius_y = transformation * self._radius_y
self._bounding_box = None self._bounding_box = None
def __repr__(self): def __repr__(self):
return '{0}({1._center}, {1._x_radius}, {1._x_radius}, {1._angle})'.format(self.__class__.__name__, self) return '{0}({1._center}, {1._radius_x}, {1._radius_x}, {1._angle})'.format(self.__class__.__name__, self)
@property @property
def x_radius(self): def radius_x(self):
return self._x_radius return self._radius_x
@x_radius.setter @radius_x.setter
def x_radius(self, value): def radius_x(self, value):
self._x_radius = float(value) self._radius_x = float(value)
@property @property
def y_radius(self): def radius_y(self):
return self._y_radius return self._radius_y
@y_radius.setter @radius_y.setter
def y_radius(self, value): def radius_y(self, value):
self._y_radius = float(value) self._radius_y = float(value)
@property @property
def angle(self): def angle(self):
...@@ -522,21 +638,21 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -522,21 +638,21 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
@property @property
def major_vector(self): def major_vector(self):
# Fixme: x < y # Fixme: x < y
return self.__vector_cls__.from_polar(self._angle, self._x_radius) return self.__vector_cls__.from_polar(self._angle, self._radius_x)
@property @property
def minor_vector(self): def minor_vector(self):
return self.__vector_cls__.from_polar(self._angle + 90, self._y_radius) return self.__vector_cls__.from_polar(self._angle + 90, self._radius_y)
@property @property
def eccentricity(self): def eccentricity(self):
# focal distance # focal distance
# c = sqrt(self._x_radius**2 - self._y_radius**2) # c = sqrt(self._radius_x**2 - self._radius_y**2)
# e = c / a # e = c / a
return sqrt(1 - (self._y_radius/self._x_radius)**2) return sqrt(1 - (self._radius_y/self._radius_x)**2)
...@@ -550,8 +666,8 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -550,8 +666,8 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
c2 = c**2 c2 = c**2
s2 = s**2 s2 = s**2
a = self._x_radius a = self._radius_x
b = self._y_radius b = self._radius_y
a2 = a**2 a2 = a**2
b2 = b**2 b2 = b**2
...@@ -584,9 +700,9 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -584,9 +700,9 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
def point_at_angle(self, angle): def point_at_angle(self, angle):
# point = self.__vector_cls__.from_ellipse(self._x_radius, self._y_radius, angle) # point = self.__vector_cls__.from_ellipse(self._radius_x, self._radius_y, angle)
# return self.point_from_ellipse_frame(point) # return self.point_from_ellipse_frame(point)
point = self.__vector_cls__.from_ellipse(self._x_radius, self._y_radius, self._angle + angle) point = self.__vector_cls__.from_ellipse(self._radius_x, self._radius_y, self._angle + angle)
return self._center + point return self._center + point
...@@ -595,21 +711,21 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -595,21 +711,21 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
def bounding_box(self): def bounding_box(self):
if self._bounding_box is None: if self._bounding_box is None:
x_radius, y_radius = self._x_radius, self._y_radius radius_x, radius_y = self._radius_x, self._radius_y
if self._angle == 0: if self._angle == 0:
bounding_box = self._center.bounding_box bounding_box = self._center.bounding_box
bounding_box.x.enlarge(x_radius) bounding_box.x.enlarge(radius_x)
bounding_box.y.enlarge(y_radius) bounding_box.y.enlarge(radius_y)
self._bounding_box = bounding_box self._bounding_box = bounding_box
else: else:
angle_x = self._angle angle_x = self._angle
angle_y = angle_x + 90 angle_y = angle_x + 90
Vector2D = self.__vector_cls__ Vector2D = self.__vector_cls__
points = [self._center + offset for offset in ( points = [self._center + offset for offset in (
Vector2D.from_polar(angle_x, x_radius), Vector2D.from_polar(angle_x, radius_x),
Vector2D.from_polar(angle_x, -x_radius), Vector2D.from_polar(angle_x, -radius_x),
Vector2D.from_polar(angle_y, y_radius), Vector2D.from_polar(angle_y, radius_y),
Vector2D.from_polar(angle_y, -y_radius), Vector2D.from_polar(angle_y, -radius_y),
self._bounding_box = bounding_box_from_points(points) self._bounding_box = bounding_box_from_points(points)
...@@ -672,7 +788,7 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -672,7 +788,7 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
# Fixme: make a 3D plot to check the algorithm on a 2D grid and rotated ellipse # Fixme: make a 3D plot to check the algorithm on a 2D grid and rotated ellipse
y0, y1 = point y0, y1 = point
e0, e1 = self._x_radius, self._y_radius e0, e1 = self._radius_x, self._radius_y
if y1 > 0: if y1 > 0:
if y0 > 0: if y0 > 0:
...@@ -749,11 +865,11 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive): ...@@ -749,11 +865,11 @@ class Ellipse2D(Primitive2DMixin, CenterMixin, AngularDomainMixin, Primitive):
# Fixme: to be checked # Fixme: to be checked
# Map segment in ellipse frame and scale y axis so as to transform the ellipse to a circle # Map segment in ellipse frame and scale y axis so as to transform the ellipse to a circle
y_scale = self._x_radius / self._y_radius y_scale = self._radius_x / self._radius_y
points = [self.point_in_ellipse_frame(point) for point in segment.points] points = [self.point_in_ellipse_frame(point) for point in segment.points]
points = [self.__vector_cls__(point.x, point.y * y_scale) for point in points] points = [self.__vector_cls__(point.x, point.y * y_scale) for point in points]
segment_in_frame = Segment2D(*points) segment_in_frame = Segment2D(*points)
circle = Circle2D(self.__vector_cls__(0, 0), self._x_radius) circle = Circle2D(self.__vector_cls__(0, 0), self._radius_x)
points = circle.intersect_segment(segment_in_frame) points = circle.intersect_segment(segment_in_frame)
points = [self.__vector_cls__(point.x, point.y / y_scale) for point in points] points = [self.__vector_cls__(point.x, point.y / y_scale) for point in points]
...@@ -111,21 +111,21 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -111,21 +111,21 @@ class Line2D(Primitive2DMixin, Primitive):
def get_y_from_x(self, x): def get_y_from_x(self, x):
"""Return y corresponding to x""" """Return y corresponding to x"""
return self.v.tan() * (x - self.p.x) + self.p.y return self.v.tan * (x - self.p.x) + self.p.y
def get_x_from_y(self, y): def get_x_from_y(self, y):
"""Return x corresponding to y""" """Return x corresponding to y"""
return self.v.inverse_tan() * (y - self.p.y) + self.p.x return self.v.inverse_tan * (y - self.p.y) + self.p.x
# Fixme: is_parallel_to # Fixme: is_parallel_to
def is_parallel(self, other, cross=False): def is_parallel(self, other, return_cross=False):
"""Self is parallel to other""" """Self is parallel to other"""
return self.v.is_parallel(other.v, cross) return self.v.is_parallel(other.v, return_cross)
...@@ -139,7 +139,7 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -139,7 +139,7 @@ class Line2D(Primitive2DMixin, Primitive):
"""Return the shifted parallel line""" """Return the shifted parallel line"""
n = self.v.normal() n = self.v.normal
n.normalise() n.normalise()
point = self.p + n*shift point = self.p + n*shift
...@@ -152,7 +152,7 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -152,7 +152,7 @@ class Line2D(Primitive2DMixin, Primitive):
"""Return the orthogonal line at abscissa s""" """Return the orthogonal line at abscissa s"""
point = self.interpolate(s) point = self.interpolate(s)
vector = self.v.normal() vector = self.v.normal
return self.__class__(point, vector) return self.__class__(point, vector)
...@@ -170,7 +170,7 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -170,7 +170,7 @@ class Line2D(Primitive2DMixin, Primitive):
# delta x v1 = - s2 * v2 x v1 = s2 * v1 x v2 # delta x v1 = - s2 * v2 x v1 = s2 * v1 x v2
# delta x v2 = s1 * v1 x v2 # delta x v2 = s1 * v1 x v2
test, cross = l1.is_parallel(l2, cross=True) test, cross = l1.is_parallel(l2, return_cross=True)
if test: if test:
return (None, None) return (None, None)
else: else:
...@@ -255,7 +255,7 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -255,7 +255,7 @@ class Line2D(Primitive2DMixin, Primitive):
left, bottom, right, top = interval.bounding_box() left, bottom, right, top = interval.bounding_box()
vb = Vector2D(interval.size()) vb = Vector2D(interval.size())
if abs(self.v.tan()) > vb.tan(): if abs(self.v.tan) > vb.tan:
x_min, y_min = self.get_x_from_y(bottom), bottom x_min, y_min = self.get_x_from_y(bottom), bottom
x_max, y_max = self.get_x_from_y(top), top x_max, y_max = self.get_x_from_y(top), top
else: else:
...@@ -20,6 +20,8 @@ ...@@ -20,6 +20,8 @@
"""Module to implement path. """Module to implement path.
For resources on path see :ref:`this section <path-geometry-ressources-page>`.
...@@ -33,24 +35,35 @@ __all__ = [ ...@@ -33,24 +35,35 @@ __all__ = [
import logging
from Patro.Common.Math.Functions import sign
from .Primitive import Primitive1P, Primitive2DMixin from .Primitive import Primitive1P, Primitive2DMixin
from .Bezier import QuadraticBezier2D, CubicBezier2D from .Bezier import QuadraticBezier2D, CubicBezier2D
from .Conic import Circle2D, AngularDomain from .Conic import AngularDomain, Circle2D, Ellipse2D
from .Vector import Vector2D from .Vector import Vector2D
class PathPart: class PathPart:
def __init__(self, path, position): def __init__(self, path, index):
self._path = path self._path = path
self._position = position self._index = index
def _init_absolute(self, absolute):
self._absolute = bool(absolute)
...@@ -60,7 +73,7 @@ class PathPart: ...@@ -60,7 +73,7 @@ class PathPart:
return self.__class__.__name__ return '{0}(@{1._index})'.format(self.__class__.__name__, self)
...@@ -69,22 +82,22 @@ class PathPart: ...@@ -69,22 +82,22 @@ class PathPart:
return self._path return self._path
@property @property
def position(self): def index(self):
return self._position return self._index
@position.setter @index.setter
def position(self, value): def index(self, value):
self._position = int(value) self._index = int(value)
@property @property
def prev_part(self): def prev_part(self):
return self._path[self._position -1] return self._path[self._index -1]
@property @property
def next_part(self): def next_part(self):
return self._path[self._position +1] return self._path[self._index +1]
...@@ -103,6 +116,17 @@ class PathPart: ...@@ -103,6 +116,17 @@ class PathPart:
def stop_point(self): def stop_point(self):
def to_absolute_point(self, point):
# Fixme: cache ???
if self._absolute:
return point
else:
return point + self.start_point
@property @property
def geometry(self): def geometry(self):
...@@ -115,36 +139,87 @@ class PathPart: ...@@ -115,36 +139,87 @@ class PathPart:
class LinearSegment(PathPart): class OnePointMixin:
@property
def point(self):
return self._point
@point.setter
def point(self, value):
self._point = Vector2D(value) # self._path.__vector_cls__
@property
return self.to_absolute_point(self._point)
# Fixme: right for relative ???
self._point = transformation * self._point
class TwoPointMixin:
@property
def point1(self):
return self.to_absolute_point(self._point1)
r""" @point1.setter
def point1(self, value):
self._point1 = Vector2D(value) # self._path.__vector_cls__
Bulge ##############################################
Let `P0`, `P1`, `P2` the vertices and `R` the bulge radius. @property
def point2(self):
return self.to_absolute_point(self._point2)
The deflection :math:`\theta = 2 \alpha` at the corner is @point2.setter
def point2(self, value):
self._point2 = Vector2D(value)
.. math:: ##############################################
D_1 \cdot D_0 = (P_2 - P_1) \cdot (P_1 - P_0) = \cos \theta def apply_transformation(self, transformation):
self._point1 = transformation * self._point1
self._point2 = transformation * self._point2
The bisector direction is ####################################################################################################
.. math:: class ThreePointMixin(TwoPointMixin):
Bis = D_1 - D_0 = (P_2 - P_1) - (P_1 - P_0) = P_2 -2 P_1 + P_0 ##############################################
Bulge Center is @property
def point3(self):
return self.to_absolute_point(self._point3)
.. math:: @point3.setter
def point3(self, value):
self._point3 = Vector2D(value) # self._path.__vector_cls__
C = P_1 + Bis \times \frac{R}{\sin \alpha} ##############################################
TwoPointMixin.apply_transformation(self, transformation)
self._point3 = transformation * self._point3
Extremities are ####################################################################################################
\prime P_1 = P_1 - d_0 \times \frac{R}{\tan \alpha} class LinearSegment(PathPart):
\prime P_1 = P_1 + d_1 \times \frac{R}{\tan \alpha}
"""Class to implement a linear segment.
...@@ -153,15 +228,19 @@ class LinearSegment(PathPart): ...@@ -153,15 +228,19 @@ class LinearSegment(PathPart):
# If two successive vertices share the same circle, then it should be merged to one. # If two successive vertices share the same circle, then it should be merged to one.
_logger = _module_logger.getChild('LinearSegment')
def __init__(self, path, position, radius): def __init__(self, path, index, radius, closing=False):
super().__init__(path, position) super().__init__(path, index)
self._bissector = None self._bissector = None
self._direction = None self._direction = None
self._start_bulge = False
self._closing = bool(closing)
self.radius = radius self.radius = radius
if self._radius is not None: if self._radius is not None:
if not isinstance(self.prev_part, LinearSegment): if not isinstance(self.prev_part, LinearSegment):
...@@ -179,6 +258,31 @@ class LinearSegment(PathPart): ...@@ -179,6 +258,31 @@ class LinearSegment(PathPart):
def close(self, radius):
"""Set the bulge radius at the closure"""
self._reset_cache()
self._start_bulge = True
@property
if self._start_bulge:
return self._path.stop_segment # or [-1] don't work
else:
# Fixme: super
@property
if self._closing:
return self._path.start_segment # or [0]
else:
@property @property
def points(self): def points(self):
...@@ -204,9 +308,10 @@ class LinearSegment(PathPart): ...@@ -204,9 +308,10 @@ class LinearSegment(PathPart):
@radius.setter @radius.setter
def radius(self, value): def radius(self, value):
if value is not None: if value is not None:
self._radius = float(value) value = abs(float(value))
else: if value == 0:
self._radius = None radius = None
self._radius = value
...@@ -231,7 +336,12 @@ class LinearSegment(PathPart): ...@@ -231,7 +336,12 @@ class LinearSegment(PathPart):
@property @property
def bulge_angle_rad(self): def bulge_angle_rad(self):
if self._bulge_angle is None: if self._bulge_angle is None:
angle = self.direction.orientation_with(self.prev_part.direction) # Fixme: rad vs degree
angle = self.direction.angle_with(self.prev_part.direction)
if angle >= 0:
angle = 180 - angle
else:
angle = -(180 + angle)
self._bulge_angle = math.radians(angle) self._bulge_angle = math.radians(angle)
return self._bulge_angle return self._bulge_angle
...@@ -241,15 +351,16 @@ class LinearSegment(PathPart): ...@@ -241,15 +351,16 @@ class LinearSegment(PathPart):
@property @property
def half_bulge_angle(self): def half_bulge_angle(self):
return abs(self.bulge_angle_rad / 2) return self.bulge_angle_rad / 2
@property @property
def bulge_center(self): def bulge_center(self):
if self._bulge_center is None: if self._bulge_center is None:
offset = self.bissector * self._radius / math.sin(self.half_bulge_angle) offset = self.bissector * self._radius / math.sin(abs(self.half_bulge_angle))
self._bulge_center = self.start_point + offset self._bulge_center = self.start_point + offset
# Note: -offset create external loop
return self._bulge_center return self._bulge_center
...@@ -257,15 +368,18 @@ class LinearSegment(PathPart): ...@@ -257,15 +368,18 @@ class LinearSegment(PathPart):
@property @property
def bulge_start_point(self): def bulge_start_point(self):
if self._start_bulge_point is None: if self._start_bulge_point is None:
offset = self.prev_part.direction * self._radius / math.tan(self.half_bulge_angle) angle = self.half_bulge_angle
self._start_bulge_point = self.start_point - offset offset = self.prev_part.direction * self._radius / math.tan(angle)
self._start_bulge_point = self.start_point - sign(angle) *offset
# Note: -offset create internal loop
return self._start_bulge_point return self._start_bulge_point
@property @property
def bulge_stop_point(self): def bulge_stop_point(self):
if self._stop_bulge_point is None: if self._stop_bulge_point is None:
offset = self.direction * self._radius / math.tan(self.half_bulge_angle) offset = self.direction * self._radius / math.tan(self.half_bulge_angle)
self._stop_bulge_point = self.start_point + offset self._stop_bulge_point = self.start_point + sign(angle) * offset
return self._stop_bulge_point return self._stop_bulge_point
...@@ -279,80 +393,201 @@ class LinearSegment(PathPart): ...@@ -279,80 +393,201 @@ class LinearSegment(PathPart):
if self.bulge_angle < 0: if self.bulge_angle < 0:
start_angle, stop_angle = stop_angle, start_angle start_angle, stop_angle = stop_angle, start_angle
arc.domain = AngularDomain(start_angle, stop_angle) arc.domain = AngularDomain(start_angle, stop_angle)
# self._dump_bulge(arc)
return arc return arc
def _dump_bulge(self, arc):
self._logger.info(
'Bulge @{}\n'.format(self._index) +
str(arc)
class PathSegment(LinearSegment): class PathSegment(OnePointMixin, LinearSegment):
def __init__(self, path, position, point, radius=None, absolute=False): def __init__(self, path, index, point, radius=None, absolute=False, closing=False):
super().__init__(path, position, radius) super().__init__(path, index, radius, closing)
self.point = point self.point = point
self._absolute = bool(absolute) self._init_absolute(absolute)
def clone(self, path): def clone(self, path):
return self.__class__(path, self._position, self._point, self._radius, self._absolute)
# Fixme: check
if obj._start_bulge:
radius = None
else:
radius = self._radius
obj = self.__class__(path, self._index, self._point, radius, self._absolute, self._closing)
self.close(self._radius)
return obj
def to_absolute(self):
self._point = self.stop_point
self._absolute = True
self._point = transformation * self._point OnePointMixin.apply_transformation(self, transformation)
self._radius = transformation * self._radius self._radius = transformation * self._radius
@property @property
def point(self): def geometry(self):
return self._point # Fixme: cache ???
return Segment2D(*self.points)
@point.setter ####################################################################################################
self._point = Vector2D(value) # self._path.__vector_cls__ class DirectionalSegmentMixin(LinearSegment):
@property def apply_transformation(self, transformation):
def stop_point(self): # Since a rotation will change the direction
if self._absolute: # DirectionalSegment must be casted to PathSegment
return self._point raise NotImplementedError
else:
return self._point + self.start_point
@property @property
# Fixme: cache ??? # Fixme: cache ???
return Segment2D(*self.points) return Segment2D(self.start_point, self.stop_point)
class AbsoluteHVSegment(DirectionalSegmentMixin):
def to_path_segment(self):
# Fixme: duplicted
if self._index == 0 and self._radius is not None:
radius = None
close = True
else:
close = False
path = PathSegment(self._path, self._index, self.stop_point, radius, absolute=True)
if close:
path.close(self._radius)
return path
class DirectionalSegment(LinearSegment): class AbsoluteHorizontalSegment(AbsoluteHVSegment):
def __init__(self, path, index, x, radius=None):
super().__init__(path, index, radius)
self.x = x
self._init_absolute(False) # Fixme: mix
def __repr__(self):
return '{0}(@{1._index}, {1._x})'.format(self.__class__.__name__, self)
return self.__class__(path, self._index, self._x, self._radius)
@property
def x(self):
return self._x
@x.setter
def x(self, value):
self._x = float(value)
@property
return Vector2D(self._x, self.start_point.y)
class AbsoluteVerticalSegment(AbsoluteHVSegment):
def __init__(self, path, index, y, radius=None):
self.y = y
def __repr__(self):
return '{0}(@{1._index}, {1._y})'.format(self.__class__.__name__, self)
return self.__class__(path, self._index, self._y, self._radius)
@property
def y(self):
return self._y
@y.setter
def y(self, value):
self._y = float(value)
@property
return Vector2D(self.start_point.x, self._y)
class DirectionalSegment(DirectionalSegmentMixin):
__angle__ = None __angle__ = None
def __init__(self, path, position, length, radius=None): def __init__(self, path, index, length, radius=None):
super().__init__(path, position, radius) super().__init__(path, index, radius)
self.length = length self.length = length
def apply_transformation(self, transformation): def __repr__(self):
# Since a rotation will change the direction return '{0}(@{1._index}, {1.offset})'.format(self.__class__.__name__, self)
return self.__class__(path, self._position, self._length, self._radius) return self.__class__(path, self._index, self._length, self._radius)
...@@ -378,15 +613,21 @@ class DirectionalSegment(LinearSegment): ...@@ -378,15 +613,21 @@ class DirectionalSegment(LinearSegment):
@property def to_path_segment(self):
def geometry(self):
# Fixme: cache ???
############################################## if self._index == 0 and self._radius is not None:
radius = None
close = True
else:
close = False
def to_path_segment(self): path = PathSegment(self._path, self._index, self.offset, radius, absolute=False)
return PathSegment(self._path, self._position, self.offset, self._radius, absolute=False)
if close:
return path
...@@ -422,118 +663,208 @@ class SouthWestSegment(DirectionalSegment): ...@@ -422,118 +663,208 @@ class SouthWestSegment(DirectionalSegment):
class TwoPointsMixin: class QuadraticBezierSegment(PathPart, TwoPointMixin):
@property # Fixme: abs / inc
def point1(self):
return self._point1
@point1.setter ##############################################
self._point1 = Vector2D(value) # self._path.__vector_cls__ def __init__(self, path, index, point1, point2, absolute=False):
PathPart.__init__(self, path, index)
self.point1 = point1
self.point2 = point2
return self.__class__(path, self._index, self._point1, self._point2, self._absolute)
self._point1 = self.point1
self._point2 = self.point2
@property @property
def point2(self): def stop_point(self):
return self._point2 return self.point2
@point2.setter @property
def point2(self, value): def points(self):
self._point2 = Vector2D(value) return (self.start_point, self.point1, self.point2)
def apply_transformation(self, transformation): @property
self._point1 = transformation * self._point1 def geometry(self):
self._point2 = transformation * self._point2 # Fixme: cache ???
return QuadraticBezier2D(*self.points)
class QuadraticBezierSegment(PathPart, TwoPointsMixin): class CubicBezierSegment(PathPart, ThreePointMixin):
# Fixme: abs / inc
def __init__(self, path, position, point1, point2): def __init__(self, path, index, point1, point2, point3, absolute=False):
PathPart.__init__(self, path, position) PathPart.__init__(self, path, index)
self.point1 = point1 self.point1 = point1
self.point2 = point2 self.point2 = point2
self.point3 = point3
return self.__class__(path, self._position, self._point1, self._point2) return self.__class__(path, self._index, self._point1, self._point2, self._point3, absolute)
self._point3 = self.point3
@property @property
return self._point2 return self.point3
@property @property
return (self.start_point, self._point1, self._point2) return (self.start_point, self.point1, self.point2, self.point3)
@property @property
return QuadraticBezier2D(self.start_point, self._point1, self._point2) return CubicBezier2D(*self.points)
class CubicBezierSegment(PathPart, TwoPointsMixin): class StringedQuadtraticBezierSegment(PathPart, TwoPointMixin):
def __init__(self, path, position, point1, point2, point3): def __init__(self, path, index, point1, absolute=False):
return self.__class__(path, self._position, self._point1, self._point2, self._point3) return self.__class__(path, self._index, self._point1, absolute)
TwoPointsMixin.transform(self, transformation) def geometry(self):
self._point3 = transformation * self._point3 # Fixme: cache ???
# Fixme: !!!
return Segment2D(self.start_point, self._point2)
# return CubicBezier2D(self.start_point, self._point1, self._point2, self._point3)
class StringedCubicBezierSegment(PathPart, TwoPointMixin):
@property def __init__(self, path, index, point1, point2, absolute=False):
def point3(self):
return self._point3
@point3.setter PathPart.__init__(self, path, index)
def point3(self, value): self._init_absolute(absolute)
# self.point1 = point1
return self.__class__(path, self._index, self._point1, self._point2, absolute)
@property @property
def stop_point(self): def geometry(self):
return self._point3 # Fixme: cache ???
# Fixme: !!!
class ArcSegment(OnePointMixin, PathPart):
def __init__(self, path, index, point, radius_x, radius_y, angle, large_arc, sweep, absolute=False):
self.point = point
self._large_arc = bool(large_arc)
self._sweep = bool(sweep)
self._radius_x = radius_x
self._radius_y = radius_y
self._angle = angle
path,
self._index,
self._point,
self._angle,
self._large_arc, self._sweep,
self._absolute,
def __repr__(self):
template = '{0}(@{1._index} {1._point} rx={1._radius_x} ry={1._radius_y} a={1._angle} la={1._large_arc} s={1._sweep})'
return template.format(self.__class__.__name__, self)
@property @property
return (self.start_point, self._point1, self._point2, self._point3) return self.start_point, self.stop_point
@property @property
# Fixme: cache ??? return Ellipse2D.svg_arc(
return CubicBezier2D(self.start_point, self._point1, self._point2, self._point3) self.start_point, self.stop_point,
self._angle,
...@@ -541,13 +872,16 @@ class Path2D(Primitive2DMixin, Primitive1P): ...@@ -541,13 +872,16 @@ class Path2D(Primitive2DMixin, Primitive1P):
"""Class to implements 2D Path.""" """Class to implements 2D Path."""
_logger = _module_logger.getChild('Path2D')
def __init__(self, start_point): def __init__(self, start_point):
Primitive1P.__init__(self, start_point) Primitive1P.__init__(self, start_point)
self._parts = [] self._parts = [] # Fixme: segment ???
self._is_closed = False
...@@ -570,39 +904,89 @@ class Path2D(Primitive2DMixin, Primitive1P): ...@@ -570,39 +904,89 @@ class Path2D(Primitive2DMixin, Primitive1P):
def __iter__(self): def __iter__(self):
return iter(self._parts) return iter(self._parts)
def __getitem__(self, position): def __getitem__(self, index):
# try: # try:
# return self._parts[slice_] # return self._parts[slice_]
# except IndexError: # except IndexError:
# return None # return None
position = int(position) index = int(index)
if 0 <= position < len(self._parts): number_of_parts = len(self._parts)
return self._parts[position] if 0 <= index < number_of_parts:
else: return self._parts[index]
return None # elif self._is_closed:
# if index == -1:
# return self.start_segment
# elif index == number_of_parts:
# return self.stop_segment
return None
@property
def start_segment(self):
# Fixme: start_part ???
return self._parts[0]
@property
def stop_segment(self):
return self._parts[-1]
@property
def is_closed(self):
return self._is_closed
def _add_part(self, part_cls, *args, **kwargs): def _add_part(self, part_cls, *args, **kwargs):
obj = part_cls(self, len(self._parts), *args, **kwargs) if not self._is_closed:
self._parts.append(obj) obj = part_cls(self, len(self._parts), *args, **kwargs)
return obj self._parts.append(obj)
return obj
self._p0 = transformation * self._p0 # self._logger.info(str(self) + '\n' + str(transformation.type) + '\n' + str(transformation) )
for i, part in enumerate(self._parts): for part in self._parts:
# print(part)
if isinstance(part, PathSegment): if isinstance(part, PathSegment):
part._reset_cache() part._reset_cache()
if isinstance(part, DirectionalSegment): if isinstance(part, DirectionalSegmentMixin):
# Since a rotation will change the direction # Since a rotation will change the direction
# DirectionalSegment must be casted to PathSegment # DirectionalSegment must be casted to PathSegment
part = part.to_path_segment() part = part.to_path_segment()
self._parts[i] = part self._parts[part.index] = part
if part._absolute is False:
# print('incremental', part, part.points)
part.to_absolute()
# print('->', part.points)
# print()
# print('p0', self._p0)
# print(part)
part.apply_transformation(transformation) part.apply_transformation(transformation)
@property
# Fixme: cache
bounding_box = None
for item in self._parts:
interval = item.geometry.bounding_box
if bounding_box is None:
bounding_box = interval
else:
bounding_box |= interval
return bounding_box
...@@ -611,52 +995,124 @@ class Path2D(Primitive2DMixin, Primitive1P): ...@@ -611,52 +995,124 @@ class Path2D(Primitive2DMixin, Primitive1P):
def horizontal_to(self, distance, radius=None): def horizontal_to(self, length, radius=None, absolute=False):
return self._add_part(HorizontalSegment, distance, radius) if absolute:
return self._add_part(PathSegment, self.__vector_cls__(length, 0), radius,
absolute=True)
else:
return self._add_part(HorizontalSegment, length, radius)
def vertical_to(self, length, radius=None, absolute=False):
if absolute:
return self._add_part(PathSegment, self.__vector_cls__(0, length), radius,
absolute=True)
else:
return self._add_part(VerticalSegment, length, radius)
def absolute_horizontal_to(self, x, radius=None):
return self._add_part(AbsoluteHorizontalSegment, x, radius)
def absolute_vertical_to(self, y, radius=None):
return self._add_part(AbsoluteVerticalSegment, y, radius)
def north_to(self, length, radius=None):
return self._add_part(NorthSegment, length, radius)
def south_to(self, length, radius=None):
return self._add_part(SouthSegment, length, radius)
def west_to(self, length, radius=None):
return self._add_part(WestSegment, length, radius)
def east_to(self, length, radius=None):
return self._add_part(EastSegment, length, radius)
def north_east_to(self, length, radius=None):
return self._add_part(NorthEastSegment, length, radius)
def south_east_to(self, length, radius=None):
return self._add_part(SouthEastSegment, length, radius)
def north_west_to(self, length, radius=None):
return self._add_part(NorthWestSegment, length, radius)
def south_west_to(self, length, radius=None):
return self._add_part(SouthWestSegment, length, radius)
def line_to(self, point, radius=None, absolute=False):
return self._add_part(PathSegment, point, radius, absolute=absolute)
def vertical_to(self, distance, radius=None): ##############################################
return self._add_part(VerticalSegment, distance, radius)
def north_to(self, distance, radius=None): def close(self, radius=None, close_radius=None):
return self._add_part(NorthSegment, distance, radius)
def south_to(self, distance, radius=None): # Fixme: identify as close for SVG export <-- meaning ???
return self._add_part(SouthSegment, distance, radius)
def west_to(self, distance, radius=None): closing = close_radius is not None
return self._add_part(WestSegment, distance, radius) segment = self._add_part(PathSegment, self._p0, radius, absolute=True, closing=closing)
if closing:
self.start_segment.close(close_radius)
self._is_closed = True
def east_to(self, distance, radius=None): return segment
return self._add_part(EastSegment, distance, radius)
def north_east_to(self, distance, radius=None): ##############################################
return self._add_part(NorthEastSegment, distance, radius)
def south_east_to(self, distance, radius=None): def quadratic_to(self, point1, point2, absolute=False):
return self._add_part(SouthEastSegment, distance, radius) return self._add_part(QuadraticBezierSegment, point1, point2, absolute=absolute)
def north_west_to(self, distance, radius=None): ##############################################
return self._add_part(NorthWestSegment, distance, radius)
def south_west_to(self, distance, radius=None): def cubic_to(self, point1, point2, point3, absolute=False):
return self._add_part(SouthWestSegment, distance, radius) return self._add_part(CubicBezierSegment, point1, point2, point3, absolute=absolute)
def line_to(self, point, radius=None): def stringed_quadratic_to(self, point, absolute=False):
return self._add_part(PathSegment, point, radius) return self._add_part(StringedQuadraticBezierSegment, point, absolute=absolute)
def stringed_cubic_to(self, point1, point2, absolute=False):
return self._add_part(StringedCubicBezierSegment, point1, point2, absolute=absolute)
def close(self, radius=None): def arc_to(self, point, radius_x, radius_y, angle, large_arc, sweep, absolute=False):
# Fixme: identify as close for SVG export return self._add_part(ArcSegment, point, radius_x, radius_y, angle, large_arc, sweep,
# Fixme: radius must apply to start and stop absolute=absolute)
return self._add_part(PathSegment, self._p0, radius, absolute=True)
def quadratic_to(self, point1, point2): @classmethod
return self._add_part(QuadraticBezierSegment, point1, point2) def rounded_rectangle(cls, point, width, height, radius=None):
path = cls(point)
path.horizontal_to(width)
path.vertical_to(height, radius=radius)
path.horizontal_to(-width, radius=radius)
path.close(radius=radius, close_radius=radius)
return path
def cubic_to(self, point1, point2, point3): @classmethod
return self._add_part(CubicBezierSegment, point1, point2, point3) def circle(cls, point, radius):
diameter = 2*float(radius)
path = cls(point)
path.horizontal_to(diameter)
path.vertical_to(diameter, radius=radius)
path.horizontal_to(-diameter, radius=radius)
return path
...@@ -19,6 +19,7 @@ ...@@ -19,6 +19,7 @@
"""Module to implement polygon. """Module to implement polygon.
...@@ -29,14 +30,18 @@ __all__ = ['Polygon2D'] ...@@ -29,14 +30,18 @@ __all__ = ['Polygon2D']
from Patro.Common.Math.Functions import sign import numpy as np
from .Primitive import PrimitiveNP, Primitive2DMixin
from .Primitive import PrimitiveNP, ClosedPrimitiveMixin, PathMixin, Primitive2DMixin
from .Triangle import Triangle2D from .Triangle import Triangle2D
class Polygon2D(Primitive2DMixin, PrimitiveNP): # Fixme: PrimitiveNP last ???
class Polygon2D(Primitive2DMixin, ClosedPrimitiveMixin, PathMixin, PrimitiveNP):
"""Class to implements 2D Polygon.""" """Class to implements 2D Polygon."""
...@@ -86,11 +91,14 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP): ...@@ -86,11 +91,14 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP):
self._is_simple = None self._is_simple = None
self._is_convex = None self._is_convex = None
############################################## self._area = None
# self._cross = None
# self._barycenter = None
@property # self._major_axis_angle = None
def is_closed(self): self._major_axis = None
return True # self._minor_axis = None
# self._axis_ratio = None
...@@ -106,20 +114,17 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP): ...@@ -106,20 +114,17 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP):
# barycenter
# momentum
@property @property
def edges(self): def edges(self):
if self._edges is None: if self._edges is None:
edges = []
N = self.number_of_points N = self.number_of_points
for i in range(N): for i in range(N):
j = (i+1) % N j = (i+1) % N
edge = Segment2D(self._points[i], self._points[j]) edge = Segment2D(self._points[i], self._points[j])
self._edges.append(edge) edges.append(edge)
self._edges = edges
return iter(self._edges) return iter(self._edges)
...@@ -147,6 +152,7 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP): ...@@ -147,6 +152,7 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP):
# two edge intersect # two edge intersect
# intersections.append(intersection) # intersections.append(intersection)
return False return False
return True
...@@ -192,29 +198,258 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP): ...@@ -192,29 +198,258 @@ class Polygon2D(Primitive2DMixin, PrimitiveNP):
@property @property
def perimeter(self): def perimeter(self):
return sum([edge.magnitude for edge in self.edges]) return sum([edge.length for edge in self.edges])
@property @property
def area(self): def point_barycenter(self):
for point in self.iter_from_second_point():
center += point
return center / self.number_of_points
def _compute_area_barycenter(self):
r"""Compute polygon area and barycenter.
Polygon area is determined by
.. math::
\begin{align}
\mathbf{A} &= \frac{1}{2} \sum_{i=0}^{n-1} P_i \otimes P_{i+1} \\
\begin{vmatrix}
x_i & x_{i+1} \\
y_i & y_{i+1}
\end{vmatrix} \\
&= \frac{1}{2} \sum_{i=0}^{n-1} x_i y_{i+1} - x_{i+1} y_i
\end{align}
where :math:`x_n = x_0`
Polygon barycenter is determined by
.. math::
\begin{align}
\mathbf{C} &= \frac{1}{6\mathbf{A}} \sum_{i=0}^{n-1}
(P_i + P_{i+1}) \times (P_i \otimes P_{i+1}) \\
\begin{pmatrix}
(x_i + x_{i+1}) (x_i y_{i+1} - x_{i+1} y_i) \\
(y_i + y_{i+1}) (x_i y_{i+1} - x_{i+1} y_i)
\end{pmatrix}
\end{align}
References
* On the Calculation of Arbitrary Moments of Polygons,
Carsten Steger,
Technical Report FGBV–96–05,
October 1996
* http://mathworld.wolfram.com/PolygonArea.html
* https://en.wikipedia.org/wiki/Polygon#Area_and_centroid
if not self.is_simple: if not self.is_simple:
# http://mathworld.wolfram.com/PolygonArea.html # area = self._points[-1].cross(self._points[0])
# for i in range(self.number_of_points):
# area *= self._points[i].cross(self._points[i+1])
# P0, P1, Pn-1, P0
points = self.closed_point_array
# from 0 to n-1 : P0, ..., Pn-1
xi = points[0,:-1]
yi = points[1,:-1]
# from 1 to n : P1, ..., Pn-1, P0
xi1 = points[0,1:]
yi1 = points[1,1:]
# Fixme: np.cross ???
cross = xi * yi1 - xi1 * yi
self._cross = cross
area = .5 * np.sum(cross)
if area == 0:
# print('Null area')
self._area = 0
self._barycenter = self.start_point
else:
factor = 1 / (6*area)
x = factor * np.sum((xi + xi1) * cross)
y = factor * np.sum((yi + yi1) * cross)
# area of a convex polygon is defined to be positive if the points are arranged in a
# counterclockwise order, and negative if they are in clockwise order (Beyer 1987).
self._area = abs(area)
self._barycenter = self.__vector_cls__(x, y)
def _compute_inertia_moment(self):
r"""Compute inertia moment on vertices.
.. warning:: untrusted formulae
.. math::
\begin{align}
I_x &= \frac{1}{12} \sum (y_i^2 + y_i y_{i+1} + y_{i+1}^2) (x_i y_{i+1} - x_{i+1} y_i) \\
I_y &= \frac{1}{12} \sum (x_i^2 + x_i x_{i+1} + x_{i+1}^2) (x_i y_{i+1} - x_{i+1} y_i) \\
I_{xy} &= \frac{1}{24} \sum (x_i y_{i+1} + 2 x_i y_i + 2 x_{i+1} y_{i+1} + x_{i+1} y_i) (x_i y_{i+1} - x_{i+1} y_i)
\end{align}
Reference
* https://en.wikipedia.org/wiki/Second_moment_of_area#Any_cross_section_defined_as_polygon
# self.recenter()
# Fixme: duplicated code
# P0, P1, Pn-1, P0
# A = 1/2 (x1*y2 - x2*y1 + x2*y3 - x3*y2 + ... + x(n-1)*yn - xn*y(n-1) + xn*y1 - x1*yn) # from 0 to n-1 : P0, ..., Pn-1
# determinant xi = points[0,:-1]
yi = points[1,:-1]
xi1 = points[0,1:]
yi1 = points[1,1:]
area = self._points[-1].cross(self._points[0]) # computation on vertices
for i in range(self.number_of_points): number_of_points = self.number_of_points
area *= self._points[i].cross(self._points[i+1]) Ix = np.sum(yi**2) / number_of_points
Iy = np.sum(xi**2) / number_of_points
Ixy = - np.sum(xi*yi) / number_of_points
# area of a convex polygon is defined to be positive if the points are arranged in a # cross = xi * yi1 - xi1 * yi
# counterclockwise order, and negative if they are in clockwise order (Beyer 1987). # cross = self._cross
# Ix = 1/(12*self._area) * np.sum((yi**2 + yi*yi1 + yi1**2) * cross)
# Iy = 1/(12*self._area) * np.sum((xi**2 + xi*xi1 + xi1**2) * cross)
# Ixy = 1/(24*self._area) * np.sum((xi*yi1 + 2*(xi*yi + xi1*yi1) + xi1*yi) * cross)
# cx, cy = self._barycenter
# Ix -= cy**2
# Iy -= cx**2
# Ixy -= cx*cy
# Ix = -Ix
# Iy = -Iy
# print(Ix, Iy, Ixy)
return abs(area) / 2 if Ixy == 0:
if Iy >= Ix:
self._major_axis_angle = 0
lambda1 = Iy
lambda2 = Ix
vx = 0
v1y = 1
v2y = 0
else:
self._major_axis_angle = 90
lambda1 = Ix
lambda2 = Iy
vx = 1
v1y = 0
v2y = 1
else:
Is = Iy + Ix
Id = Ix - Iy
sqrt0 = math.sqrt(Id*Id + 4*Ixy*Ixy)
lambda1 = (Is + sqrt0) / 2
lambda2 = (Is - sqrt0) / 2
vx = Ixy
v1y = (Id + sqrt0) / 2
v2y = (Id - sqrt0) / 2
if lambda1 < lambda2:
v1y, v2y = v2y, v1y
lambda1, lambda2 = lambda2, lambda1
self._major_axis_angle = - math.degrees(math.atan(v1y/vx))
self._major_axis = 4 * math.sqrt(math.fabs(lambda1))
self._minor_axis = 4 * math.sqrt(math.fabs(lambda2))
if self._minor_axis != 0:
self._axis_ratio = self._major_axis / self._minor_axis
else:
self._axis_ratio = 0
def _check_area(self):
if self.is_simple and self._area is None:
self._compute_area_barycenter()
@property
def area(self):
"""Return polygon area."""
self._check_area()
return self._area
@property
def barycenter(self):
"""Return polygon barycenter."""
self._check_area()
return self._barycenter
def recenter(self):
"""Recenter the polygon to the barycenter."""
# if self._centred:
# return
barycenter = self._barycenter
for point in self._points:
point -= barycenter
# self._centred = True
def _check_moment(self):
if self.is_simple and self._major_axis is None:
self._compute_inertia_moment()
@property
def major_axis_angle(self):
self._check_moment()
return self._major_axis_angle
@property
def major_axis(self):
@property
def minor_axis(self):
return self._minor_axis
@property
def axis_ratio(self):
return self._axis_ratio
...@@ -28,6 +28,7 @@ __all__ = ['Polyline2D'] ...@@ -28,6 +28,7 @@ __all__ = ['Polyline2D']
from .Path import Path2D
from .Primitive import PrimitiveNP, Primitive2DMixin from .Primitive import PrimitiveNP, Primitive2DMixin
...@@ -74,3 +75,13 @@ class Polyline2D(Primitive2DMixin, PrimitiveNP): ...@@ -74,3 +75,13 @@ class Polyline2D(Primitive2DMixin, PrimitiveNP):
if distance is None or edge_distance < distance: if distance is None or edge_distance < distance:
distance = edge_distance distance = edge_distance
return distance return distance
def to_path(self):
path = Path2D(self.start_point)
path.line_to(point)
return path
...@@ -22,6 +22,10 @@ ...@@ -22,6 +22,10 @@
# Fixme:
# length, interpolate path
# area
__all__ = [ __all__ = [
...@@ -35,7 +39,7 @@ __all__ = [ ...@@ -35,7 +39,7 @@ __all__ = [
import collections from collections import abc as collections
import numpy as np import numpy as np
...@@ -45,18 +49,10 @@ from .BoundingBox import bounding_box_from_points ...@@ -45,18 +49,10 @@ from .BoundingBox import bounding_box_from_points
# Fixme:
# area
class Primitive: class Primitive:
"""Base class for geometric primitive""" """Base class for geometric primitive"""
# __dimension__ = None # in [2, 3] for 2D / 3D primitive
__vector_cls__ = None __vector_cls__ = None
...@@ -134,9 +130,7 @@ class Primitive: ...@@ -134,9 +130,7 @@ class Primitive:
Return None if primitive is infinite. Return None if primitive is infinite.
# Fixme: cache # Fixme: cache
if self.is_infinite: if self.is_infinite:
else: else:
...@@ -156,9 +150,8 @@ class Primitive: ...@@ -156,9 +150,8 @@ class Primitive:
obj = self.clone() if clone else self obj = self.clone() if clone else self
# for point in obj.points: if not transformation.is_identity:
# point *= transformation # don't work obj.apply_transformation(transformation)
return obj return obj
...@@ -198,29 +191,83 @@ class Primitive: ...@@ -198,29 +191,83 @@ class Primitive:
@property @property
def geometry_matrix(self): def point_array(self):
r"""Return the geometry matrix as a Numpy array.
.. math::
\mathrm{Geometry\ Matrix} =
\begin{bmatrix}
x_0 & x_1 & \ldots & x_{n-1} \\
y_0 & y_1 & \ldots & y_{n-1}
\end{bmatrix}
# Fixme: geometry_matrix vs point_array
# Fixme: cache ??? but point set and init
# if self._point_array is None:
# self._point_array = np.array(list(self.points)).transpose()
# return self._point_array
return np.array(list(self.points)).transpose() return np.array(list(self.points)).transpose()
def is_close(self, other): def is_point_close(self, other):
# Fixme: verus is_closed # Fixme: verus is_closed
return np.allclose(self.geometry_matrix, other.geometry_matrix) # is_similar
return np.allclose(self.point_array, other.point_array)
class Primitive2DMixin: class Primitive2DMixin:
# __dimension__ = 2
__vector_cls__ = None # Fixme: due to import, done in module's __init__.py __vector_cls__ = None # Fixme: due to import, done in module's __init__.py
# __dimension__ = 2
@property @property
def dimension(self): def dimension(self):
return 2 return 2
class ClosedPrimitiveMixin:
# Fixme: should be reversible
@property
"""True if the primitive is a closed path."""
return True
@property
def closed_points(self):
points = list(self.points)
points.append(self.start_point)
return points
@property
def closed_point_array(self):
r"""Return the geometry matrix as a Numpy array for a closed primitive.
.. math::
\begin{bmatrix}
x_0 & x_1 & \ldots & x_{n-1} & x_0 \\
y_0 & y_1 & \ldots & y_{n-1} & y_0
\end{bmatrix}
# Fixme: place, func for closed_point
# Fixme: cache ???
return np.array(self.closed_points).transpose()
class ReversiblePrimitiveMixin: class ReversiblePrimitiveMixin:
...@@ -258,7 +305,6 @@ class Primitive1P(Primitive): ...@@ -258,7 +305,6 @@ class Primitive1P(Primitive):
def __init__(self, p0): def __init__(self, p0):
self.p0 = p0 self.p0 = p0
...@@ -297,7 +343,6 @@ class Primitive2P(Primitive1P, ReversiblePrimitiveMixin): ...@@ -297,7 +343,6 @@ class Primitive2P(Primitive1P, ReversiblePrimitiveMixin):
def __init__(self, p0, p1): def __init__(self, p0, p1):
# We don't call super().__init__(p0) for speed # We don't call super().__init__(p0) for speed
self.p1 = p1 self.p1 = p1
...@@ -356,7 +401,6 @@ class Primitive3P(Primitive2P): ...@@ -356,7 +401,6 @@ class Primitive3P(Primitive2P):
def __init__(self, p0, p1, p2): def __init__(self, p0, p1, p2):
self.p2 = p2 self.p2 = p2
...@@ -389,8 +433,13 @@ class Primitive3P(Primitive2P): ...@@ -389,8 +433,13 @@ class Primitive3P(Primitive2P):
@property @property
def reversed_points(self): def reversed_points(self):
# Fixme: share code ???
return iter((self._p2, self._p1, self._p0)) return iter((self._p2, self._p1, self._p0))
def iter_from_second_point(self):
return iter(self._p1, self._p2)
def _set_points(self, points): def _set_points(self, points):
...@@ -403,7 +452,6 @@ class Primitive4P(Primitive3P): ...@@ -403,7 +452,6 @@ class Primitive4P(Primitive3P):
def __init__(self, p0, p1, p2, p3): def __init__(self, p0, p1, p2, p3):
...@@ -439,6 +487,9 @@ class Primitive4P(Primitive3P): ...@@ -439,6 +487,9 @@ class Primitive4P(Primitive3P):
return iter((self._p3, self._p2, self._p1, self._p0)) return iter((self._p3, self._p2, self._p1, self._p0))
return iter(self._p1, self._p2, self._p3)
...@@ -490,13 +541,8 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin): ...@@ -490,13 +541,8 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin):
return reversed(self._points) return reversed(self._points)
############################################## def iter_from_second_point(self):
return iter(self._points[1:])
@property
self._point_array = np.array([point for point in self._points])
...@@ -518,3 +564,33 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin): ...@@ -518,3 +564,33 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin):
for i in range(self.number_of_points - size +1): for i in range(self.number_of_points - size +1):
yield self._points[i:i+size] yield self._points[i:i+size]
class PolygonMixin:
def to_polygon(self):
from .Polygon import Polygon2D
return Polygon2D(self.points)
class PathMixin:
def to_path(self):
path.line_to(point)
if self.is_closed:
path.close()
return path
...@@ -30,12 +30,13 @@ __all__ = ['Rectangle2D'] ...@@ -30,12 +30,13 @@ __all__ = ['Rectangle2D']
from .Primitive import Primitive2P, Primitive2DMixin from .Path import Path2D
from .Primitive import Primitive2P, ClosedPrimitiveMixin, PathMixin, PolygonMixin, Primitive2DMixin
class Rectangle2D(Primitive2DMixin, Primitive2P): class Rectangle2D(Primitive2DMixin, ClosedPrimitiveMixin, PathMixin, PolygonMixin, Primitive2P):
"""Class to implements 2D Rectangle.""" """Class to implements 2D Rectangle."""
...@@ -76,7 +76,7 @@ class Segment2D(Primitive2DMixin, Primitive2P): ...@@ -76,7 +76,7 @@ class Segment2D(Primitive2DMixin, Primitive2P):
def to_line(self): def to_line(self):
return Line2D.from_two_points(self._p1, self._p0) return Line2D.from_two_points(self._p0, self._p1)
...@@ -116,7 +116,7 @@ class Segment2D(Primitive2DMixin, Primitive2P): ...@@ -116,7 +116,7 @@ class Segment2D(Primitive2DMixin, Primitive2P):
s1, s2 = line1.intersection_abscissae(line2) s1, s2 = line1.intersection_abscissae(line2)
if s1 is None: if s1 is None:
return None return None, None
else: else:
intersect = (0 <= s1 <= 1) and (0 <= s2 <= 1) intersect = (0 <= s1 <= 1) and (0 <= s2 <= 1)
return self.interpolate(s1), intersect return self.interpolate(s1), intersect
...@@ -20,256 +20,15 @@ ...@@ -20,256 +20,15 @@
r"""Module to implement Spline curve. r"""Module to implement Spline curve.
B-spline Basis For resources on Spline curve see :ref:`this section <spline-geometry-ressources-page>`.
A nonuniform, nonrational B-spline of order `k` is a piecewise polynomial function of degree
:math:`k - 1` in a variable `t`.
.. check: k+1 knots ???
.. It is defined over :math:`k + 1` locations :math:`t_i`, called knots, which must be in
non-descending order :math:`t_i \leq t_{i+1}`. This series defines a knot vector :math:`T = (t_0,
\ldots, t_{k})`.
A set of non-descending breaking points, called knot, :math:`t_0 \le t_1 \le \ldots \le t_m` defines
a knot vector :math:`T = (t_0, \ldots, t_{m})`.
If each knot is separated by the same distance `h` (where :math:`h = t_{i+1} - t_i`) from its
predecessor, the knot vector and the corresponding B-splines are called "uniform".
Given a knot vector `T`, the associated B-spline basis functions, :math:`B_i^k(t)` are defined as:
.. t \in [t_i, t_{i+1}[
.. math::
B_i^1(t) =
\left\lbrace
\begin{array}{l}
1 \;\textrm{if}\; t_i \le t < t_{i+1} \\
0 \;\textrm{otherwise}
\end{array}
\right.
.. math::
\begin{split}
B_i^k(t) &= \frac{t - t_i}{t_{i+k-1} - t_i} B_i^{k-1}(t)
+ \frac{t_{i+k} - t}{t_{i+k} - t_{i+1}} B_{i+1}^{k-1}(t) \\
&= w_i^{k-1}(t) B_i^{k-1}(t) + [1 - w_{i+1}^{k-1}(t)] B_{i+1}^{k-1}(t)
\end{split}
where
.. math::
w_i^k(t) =
\left\lbrace
\begin{array}{l}
\frac{t - t_i}{t_{i+k} - t_i} \;\textrm{if}\; t_i < t_{i+k} \\
\end{array}
\right.
These equations have the following properties, for :math:`k > 1` and :math:`i = 0, 1, \ldots, n` :
* Positivity: :math:`B_i^k(t) > 0`, for :math:`t_i < t < t_{i+k}`
* Local Support: :math:`B_i^k(t) = 0`, for :math:`t_0 \le t \le t_i` and :math:`t_{i+k} \le t \le t_{n+k}`
* Partition of unity: :math:`\sum_{i=0}^n B_i^k(t)= 1`, for :math:`t \in [t_0, t_m]`
* Continuity: :math:`B_i^k(t)` as :math:`C^{k-2}` continuity at each simple knot
.. The B-spline contributes only in the range between the first and last of these knots and is zero
elsewhere.
B-spline Curve
A B-spline curve of order `k` is defined as a linear combination of control points :math:`p_i` and
B-spline basis functions :math:`B_i^k(t)` given by
.. math::
S^k(t) = \sum_{i=0}^{n} p_i\; B_i^k(t) ,\quad n \ge k - 1,\; t \in [t_{k-1}, t_{n+1}]
In this context the control points are called De Boor points. The basis functions :math:`B_i^k(t)`
is defined on a knot vector
.. math::
T = (t_0, t_1, \ldots, t_{k-1}, t_k, t_{k+1}, \ldots, t_{n-1}, t_n, t_{n+1}, \ldots, t_{n+k})
where there are :math:`n+k+1` elements, i.e. the number of control points :math:`n+1` plus the order
of the curve `k`. Each knot span :math:`t_i \le t \le t_{i+1}` is mapped onto a polynomial curve
between two successive joints :math:`S(t_i)` and :math:`S(t_{i+1})`.
Unlike Bézier curves, B-spline curves do not in general pass through the two end control points.
Increasing the multiplicity of a knot reduces the continuity of the curve at that knot.
Specifically, the curve is :math:`(k-p-1)` times continuously differentiable at a knot with
multiplicity :math:`p (\le k)`, and thus has :math:`C^{k-p-1}` continuity. Therefore, the control
polygon will coincide with the curve at a knot of multiplicity :math:`k-1`, and a knot with
multiplicity `k` indicates :math:`C^{-1}` continuity, or a discontinuous curve. Repeating the knots
at the end `k` times will force the endpoints to coincide with the control polygon. Thus the first
and the last control points of a curve with a knot vector described by
.. math::
\begin{eqnarray}
T = (
\underbrace{t_0, t_1, \ldots, t_{k-1},}_{\mbox{$k$ equal knots}}
\quad
\underbrace{t_k, t_{k+1}, \ldots, t_{n-1}, t_n,}_{\mbox{$n$-$k$+1 internal knots}}
\quad
\underbrace{t_{n+1}, \ldots, t_{n+k}}_{\mbox{$k$ equal knots}})
\end{eqnarray}
coincide with the endpoints of the curve. Such knot vectors and curves are known as *clamped*. In
other words, *clamped/unclamped* refers to whether both ends of the knot vector have multiplicity
equal to `k` or not.
**Local support property**: A single span of a B-spline curve is controlled only by `k` control
points, and any control point affects `k` spans. Specifically, changing :math:`p_i` affects the
curve in the parameter range :math:`t_i < t < t_{i+k}` and the curve at a point where :math:`t_r < t
< t_{r+1}` is determined completely by the control points :math:`p_{r-(k-1)}, \ldots, p_r`.
**B-spline to Bézier property**: From the discussion of end points geometric property, it can be
seen that a Bézier curve of order `k` (degree :math:`k-1`) is a B-spline curve with no internal
knots and the end knots repeated `k` times. The knot vector is thus
.. math::
\begin{eqnarray}
T = (
\underbrace{t_0, t_1, \ldots, t_{k-1}}_{\mbox{$k$ equal knots}}
,\quad
\end{eqnarray}
where :math:`n+k+1 = 2k` or :math:`n = k-1`.
Algorithms for B-spline curves
Evaluation and subdivision algorithm
A B-spline curve can be evaluated at a specific parameter value `t` using the de Boor algorithm,
which is a generalization of the de Casteljau algorithm. The repeated substitution of the recursive
definition of the B-spline basis function into the previous definition and re-indexing leads to the
following de Boor algorithm:
.. math::
S(t) = \sum_{i=0}^{n+j} p_i^j B_i^{k-j}(t) ,\quad j = 0, 1, \ldots, k-1
where
.. math::
p_i^j = \Big[1 - w_i^j\Big] p_{i-1}^{j-1} + w_i^j p_i^{j-1}, \; j > 0
with
.. math::
w_i^j = \frac{t - t_i}{t_{i+k-j} - t_i} \quad \textrm{and} \; p_j^0 = p_j
For :math:`j = k-1`, the B-spline basis function reduces to :math:`B_l^1` for :math:`t \in [t_l,
t_{l+1}]`, and :math:`p_l^{k-1}` coincides with the curve :math:`S(t) = p_l^{k-1}`.
The de Boor algorithm is a generalization of the de Casteljau algorithm. The de Boor algorithm also
permits the subdivision of the B-spline curve into two segments of the same order.
De Boor Algorithm
Let the index `l` define the knot interval that contains the position, :math:`t \in [t_l ,
t_{l+1}]`. We can see in the recursion formula that only B-splines with :math:`i = l-K, \dots, l`
are non-zero for this knot interval, where :math:`K = k - 1` is the degree. Thus, the sum is
reduced to:
.. math::
S^k(t) = \sum _{i=l-K}^{l} p_{i} B_i^k(t)
The algorithm does not compute the B-spline functions :math:`B_i^k(t)` directly. Instead it
evaluates :math:`S(t)` through an equivalent recursion formula.
Let :math:`d _i^r` be new control points with :math:`d_i^1 = p_i` for :math:`i = l-K, \dots, l`.
For :math:`r = 2, \dots, k` the following recursion is applied:
.. math::
d_i^r = (1 - w_i^r) d_{i-1}^{r-1} + w_i^r d_i^{r-1} \quad i = l-K+r, \dots, l
w_i^r = \frac{t - t_i}{t_{i+1+l-r} - t_{i}}
Once the iterations are complete, we have :math:`S^k(t) = d_l^k`.
.. , meaning that :math:`d_l^k` is the desired result.
De Boor's algorithm is more efficient than an explicit calculation of B-splines :math:`B_i^k(t)`
with the Cox-de Boor recursion formula, because it does not compute terms which are guaranteed to be
multiplied by zero.
:math:`S(t) = p_j^k` for :math:`t \in [t_j , t_{j+1}[` for :math:`k \le j \le n` with the following relation:
.. math::
\begin{split}
p_i^{r+1} &= \frac{t - t_i}{t_{i+k-r} - t} p_i^r + \frac{t_{i+k-r} - t_i}{t_{i+k-r} - t_i} p_{i-1}^r \\
&= w_i^{k-r}(t) p_i^r + (1 - w_i^{k-r}(t)) p_{i-1}^r
\end{split}
Knot insertion
A knot can be inserted into a B-spline curve without changing the
geometry of the curve. The new curve is identical to
.. math::
\begin{array}{lcl}
\sum_{i=0}^n p_i B_i^k(t) & \textrm{becomes} & \sum_{i=0}^{n+1} \bar{p}_i \bar B_i^k(t) \\
\mbox{over}\; T = (t_0, t_1, \ldots, t_l, t_{l+1}, \ldots) & &
\mbox{over}\; T = (t_0, t_1, \ldots, t_l, \bar t, t_{l+1}, \ldots) & &
\end{array}
when a new knot :math:`\bar t` is inserted between knots :math:`t_l` and :math:`t_{l+1}`. The new
de Boor points are given by
.. math::
\bar{p}_i = (1 - w_i) p_{i-1} + w_i p_i
where
.. math::
w_i =
\left\{ \begin{array}{ll}
1 & i \le l-k+1 \\
0 & i \ge l+1 \\
\frac{\bar{t} - t_i}{t_{l+k-1} - t_i} & l-k+2 \le i \leq l
\end{array}
\right.
The above algorithm is also known as **Boehm's algorithm**. A more general (but also more complex)
insertion algorithm permitting insertion of several (possibly multiple) knots into a B-spline knot
vector, known as the Oslo algorithm, was developed by Cohen et al.
A B-spline curve is :math:`C^{\infty}` continuous in the interior of a span. Within exact
arithmetic, inserting a knot does not change the curve, so it does not change the continuity.
However, if any of the control points are moved after knot insertion, the continuity at the knot
will become :math:`C^{k-p-1}`, where `p` is the multiplicity of the knot.
The B-spline curve can be subdivided into Bézier segments by knot insertion at each internal knot
until the multiplicity of each internal knot is equal to `k`.
References
* Computer Graphics, Principle and Practice, Foley et al., Adison Wesley
* http://web.mit.edu/hyperbook/Patrikalakis-Maekawa-Cho/node15.html
# The DeBoor-Cox algorithm permits to evaluate recursively a B-Spline in a similar way to the De ####################################################################################################
# Casteljaud algorithm for Bézier curves.
# Given `k` the degree of the B-spline, `n + 1` control points :math:`p_0, \ldots, p_n`, and an # Notes: algorithm details are on spline.rst
# increasing series of scalars :math:`t_0 \le t_1 \le \ldots \le t_m` with :math:`m = n + k + 1`,
# called knots.
# The number of points must respect the condition :math:`n + 1 \le k`, e.g. a B-spline of degree 3 ####################################################################################################
# must have 4 control points.
...@@ -316,7 +75,7 @@ class QuadraticUniformSpline2D(Primitive2DMixin, Primitive3P): ...@@ -316,7 +75,7 @@ class QuadraticUniformSpline2D(Primitive2DMixin, Primitive3P):
def to_bezier(self): def to_bezier(self):
basis = np.dot(self.BASIS, QuadraticBezier2D.INVERSE_BASIS) basis = np.dot(self.BASIS, QuadraticBezier2D.INVERSE_BASIS)
points = np.dot(self.geometry_matrix, basis).transpose() points = np.dot(self.point_array, basis).transpose()
return QuadraticBezier2D(*points) return QuadraticBezier2D(*points)
...@@ -376,7 +135,7 @@ class CubicUniformSpline2D(Primitive2DMixin, Primitive4P): ...@@ -376,7 +135,7 @@ class CubicUniformSpline2D(Primitive2DMixin, Primitive4P):
basis = np.dot(self.BASIS, CubicBezier2D.INVERSE_BASIS) basis = np.dot(self.BASIS, CubicBezier2D.INVERSE_BASIS)
if self._start: if self._start:
# list(self.points)[:2] # list(self.points)[:2]
points[:2] = self._p0, self._p1 points[:2] = self._p0, self._p1
...@@ -18,7 +18,9 @@ ...@@ -18,7 +18,9 @@
"""Module to implement transformations like scale, rotation and translation. r"""Module to implement transformations like scale, rotation and translation.
For resources on transformations see :ref:`this section <transformation-geometry-ressources-page>`.
...@@ -56,10 +58,17 @@ class TransformationType(Enum): ...@@ -56,10 +58,17 @@ class TransformationType(Enum):
Rotation = auto() Rotation = auto()
Translation = auto()
Generic = auto() Generic = auto()
class IncompatibleArrayDimension(ValueError):
pass
class Transformation: class Transformation:
__dimension__ = None __dimension__ = None
...@@ -79,17 +88,26 @@ class Transformation: ...@@ -79,17 +88,26 @@ class Transformation:
if self.same_dimension(obj): if self.same_dimension(obj):
array = obj.array # *._m array = obj.array # *._m
else: else:
raise ValueError raise IncompatibleArrayDimension
elif isinstance(obj, np.ndarray): elif isinstance(obj, np.ndarray):
if obj.shape == (self.__size__, self.__size__): if obj.shape == (self.__size__, self.__size__):
array = obj array = obj
else: else:
elif isinstance(obj, (list, tuple)):
if len(obj) == self.__size__ **2:
array = np.array(obj)
array.shape = (self.__size__, self.__size__)
else:
else: else:
array = np.array((self.__size__, self.__size__)) array = np.array((self.__size__, self.__size__))
array[...] = obj array[...] = obj
self._m = np.array(array) self._m = np.array(array)
if transformation_type == TransformationType.Generic:
transformation_type = self._check_type()
self._type = transformation_type self._type = transformation_type
...@@ -110,6 +128,10 @@ class Transformation: ...@@ -110,6 +128,10 @@ class Transformation:
def type(self): def type(self):
return self._type return self._type
@property
def is_identity(self):
return self._type == TransformationType.Identity
def __repr__(self): def __repr__(self):
...@@ -125,13 +147,45 @@ class Transformation: ...@@ -125,13 +147,45 @@ class Transformation:
def same_dimension(self, other): def same_dimension(self, other):
return self.__size__ == other.dimension return self.__size__ == other.dimension
def _check_type(self):
def _mul_type(self, obj):
# Fixme: check matrix value ???
# usage identity/rotation, scale/parity test
# metric test ?
# if t in (parity, xparity, yparity) t*t = Id
# if t in (rotation, scale) t*t = t
if self._type == obj._type:
if self._type in (
TransformationType.Parity,
TransformationType.XParity,
TransformationType.YParity
return TransformationType.Identity
elif self._type not in (TransformationType.Rotation, TransformationType.Scale):
return TransformationType.Generic
else:
return self._type
else: # shear, generic
def __mul__(self, obj): def __mul__(self, obj):
"""Return self * obj composition."""
if isinstance(obj, Transformation): if isinstance(obj, Transformation):
# T = T1 * T2
array = np.matmul(self._m, obj.array) array = np.matmul(self._m, obj.array)
return self.__class__(array) return self.__class__(array, self._mul_type(obj))
elif isinstance(obj, Vector2D): elif isinstance(obj, Vector2D):
array = np.matmul(self._m, np.transpose(obj.v)) array = np.matmul(self._m, np.transpose(obj.v))
return Vector2D(array) return Vector2D(array)
...@@ -150,23 +204,19 @@ class Transformation: ...@@ -150,23 +204,19 @@ class Transformation:
def __imul__(self, obj): def __imul__(self, obj):
"""Set transformation to obj * self composition."""
# Fixme: order ???
if obj._type != TransformationType.Identity: if obj.type != TransformationType.Identity:
self._m = np.matmul(self._m, obj.array) # (T = T1) *= T2
# Fixme: check matrix value ??? # T = T2 * T1
# usage identity/rotation, scale/parity test # order is inverted !
# metric test ? self._m = np.matmul(obj.array, self._m)
# if t in (parity, xparity, yparity) t*t = Id self._type = self._mul_type(obj)
# if t in (rotation, scale) t*t = t if self._type == TransformationType.Generic:
if self._type == obj._type: self._type = self._check_type()
if self._type in (TransformationType.Parity,
TransformationType.YParity):
self._type = TransformationType.Identity
self._type = TransformationType.Generic
else: else:
raise ValueError raise ValueError
...@@ -181,17 +231,6 @@ class Transformation2D(Transformation): ...@@ -181,17 +231,6 @@ class Transformation2D(Transformation):
@classmethod
def Rotation(cls, angle):
angle = radians(angle)
c = cos(angle)
s = sin(angle)
return cls(np.array(((c, -s), (s, c))), TransformationType.Rotation)
@classmethod @classmethod
def type_for_scale(cls, x_scale, y_scale): def type_for_scale(cls, x_scale, y_scale):
...@@ -214,6 +253,51 @@ class Transformation2D(Transformation): ...@@ -214,6 +253,51 @@ class Transformation2D(Transformation):
@classmethod
def check_matrix_type(self, matrix):
# Fixme: check
m00, m01, m10, m11 = matrix
if m01 == 0 and m10 == 0:
if m00 == 1:
if m11 == 1:
elif m11 == -1:
return TransformationType.YParity
elif m00 == -1:
if m11 == 1:
return TransformationType.XParity
elif m11 == -1:
return TransformationType.Parity
elif m00 == m11:
return TransformationType.Scale
# Fixme: check for rotation
return self._check_matrix_type(self.to_list())
@classmethod
c = cos(angle)
s = sin(angle)
return cls(
np.array((
(c, -s),
(s, c))),
def Scale(cls, x_scale, y_scale=None): def Scale(cls, x_scale, y_scale=None):
if y_scale is None: if y_scale is None:
...@@ -250,6 +334,7 @@ class AffineTransformation(Transformation): ...@@ -250,6 +334,7 @@ class AffineTransformation(Transformation):
transformation = cls.Identity() transformation = cls.Identity()
transformation.translation_part[...] = vector.v[...] transformation.translation_part[...] = vector.v[...]
transformation._type = TransformationType.Translation
return transformation return transformation
...@@ -257,9 +342,11 @@ class AffineTransformation(Transformation): ...@@ -257,9 +342,11 @@ class AffineTransformation(Transformation):
def RotationAt(cls, center, angle): def RotationAt(cls, center, angle):
transformation = cls.Translation(center) # return cls.Translation(center) * cls.Rotation(angle) * cls.Translation(-center)
transformation = cls.Translation(-center)
transformation *= cls.Rotation(angle) transformation *= cls.Rotation(angle)
transformation *= cls.Translation(-center) transformation *= cls.Translation(center)
...@@ -281,6 +368,12 @@ class AffineTransformation2D(AffineTransformation): ...@@ -281,6 +368,12 @@ class AffineTransformation2D(AffineTransformation):
matrix_type = Transformation2D.check_matrix_type(self.matrix_part.flat)
# Fixme: translation etc. !!!
def Rotation(cls, angle): def Rotation(cls, angle):
...@@ -294,13 +387,25 @@ class AffineTransformation2D(AffineTransformation): ...@@ -294,13 +387,25 @@ class AffineTransformation2D(AffineTransformation):
def Scale(cls, x_scale, y_scale): def Scale(cls, x_scale, y_scale):
# Fixme: others, use *= ? # Fixme: others, use *= ? (comment means ???)
transformation.matrix_part[...] = Transformation2D.Scale(x_scale, y_scale).array transformation.matrix_part[...] = Transformation2D.Scale(x_scale, y_scale).array
transformation._type = cls.type_for_scale(x_scale, y_scale) transformation._type = cls.type_for_scale(x_scale, y_scale)
@classmethod
def Screen(cls, y_height):
# Fixme: better ?
transformation.matrix_part[...] = Transformation2D.YReflection().array
transformation.translation_part[...] = Vector2D(0, y_height).v[...]
transformation._type = TransformationType.Generic
...@@ -310,7 +415,8 @@ class AffineTransformation2D(AffineTransformation): ...@@ -310,7 +415,8 @@ class AffineTransformation2D(AffineTransformation):
return obj.__class__(array) return obj.__class__(array)
array = np.matmul(self._m, HomogeneousVector2D(obj).v) array = np.matmul(self._m, HomogeneousVector2D(obj).v)
return HomogeneousVector2D(array) # return HomogeneousVector2D(array).to_vector()
return Vector2D(array[:2])
else: else:
return super(AffineTransformation, self).__mul__(obj) return super(AffineTransformation, self).__mul__(obj)
...@@ -30,7 +30,7 @@ __all__ = ['Triangle2D'] ...@@ -30,7 +30,7 @@ __all__ = ['Triangle2D']
import math import math
from .Primitive import Primitive3P, Primitive2DMixin from .Primitive import Primitive3P, ClosedPrimitiveMixin, PathMixin, PolygonMixin, Primitive2DMixin
from .Line import Line2D from .Line import Line2D
...@@ -78,7 +78,7 @@ def same_side(p1, p2, a, b): ...@@ -78,7 +78,7 @@ def same_side(p1, p2, a, b):
class Triangle2D(Primitive2DMixin, Primitive3P): class Triangle2D(Primitive2DMixin, ClosedPrimitiveMixin, PathMixin, PolygonMixin, Primitive3P):
"""Class to implements 2D Triangle.""" """Class to implements 2D Triangle."""
...@@ -215,7 +215,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P): ...@@ -215,7 +215,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P):
@property @property
def is_isosceles(self): def is_isosceles(self):
self._cache_length() self._cache_length()
# two sides of equal length # two sides of equal length
return not(self.is_equilateral) and not(self.is_scalene) return not(self.is_equilateral) and not(self.is_scalene)
...@@ -224,7 +223,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P): ...@@ -224,7 +223,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P):
@property @property
def is_right(self): def is_right(self):
self._cache_angle() self._cache_angle()
# one angle = 90 # one angle = 90
raise NotImplementedError raise NotImplementedError
...@@ -233,7 +231,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P): ...@@ -233,7 +231,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P):
@property @property
def is_obtuse(self): def is_obtuse(self):
# one angle > 90 # one angle > 90
return max(self._a10, self._a21, self._a02) > 90 return max(self._a10, self._a21, self._a02) > 90
...@@ -242,7 +239,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P): ...@@ -242,7 +239,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P):
@property @property
def is_acute(self): def is_acute(self):
# all angle < 90 # all angle < 90
return max(self._a10, self._a21, self._a02) < 90 return max(self._a10, self._a21, self._a02) < 90
...@@ -251,7 +247,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P): ...@@ -251,7 +247,6 @@ class Triangle2D(Primitive2DMixin, Primitive3P):
@property @property
def is_oblique(self): def is_oblique(self):
return not self.is_equilateral return not self.is_equilateral
