Skip to content
Commits on Source (70)
*.aux *.aux
*.qmlc
*.val.lock *.val.lock
*.vit.bak
.directory
__pycache__ __pycache__
du.log
MANIFEST MANIFEST
auto/
build/ build/
dist/ dist/
doc/sphinx/build doc/sphinx/build/
doc/sphinx/source/api/ doc/sphinx/source/api/
Valentina/Geometry/reference.txt Patro/QtApplication/rcc/PatroRessource.py
du.log Patro/QtApplication/rcc/patro.rcc
examples/output-old/
Patro/QtApplication/rcc/icons/36x36/add-black.png
Patro/QtApplication/rcc/icons/36x36/close-black.png
Patro/QtApplication/rcc/icons/36x36/delete-black.png
Patro/QtApplication/rcc/icons/36x36/search-black.png
examples/patterns/demo-custom-seam-allowance.details.png
examples/patterns/demo-custom-seam-allowance.draw.png
examples/patterns/detail-demo1.details.png
examples/patterns/detail-demo1.draw.png
examples/patterns/flat-city-trouser.draw.png
examples/patterns/layout-demo.details.png
examples/patterns/layout-demo.draw.png
examples/patterns/operations-demo.draw-1.png
examples/patterns/operations-demo.draw-2.png
examples/patterns/operations-demo.draw.png
examples/patterns/path-bezier.draw.png
examples/output/ examples/output/
examples/patterns/backup/ output/
examples/patterns/layout/
notes/ examples/dxf/protection-circulaire-seul-v1.dxf
old-todo.txt examples/dxf/protection-circulaire.dxf
todo.txt examples/dxf/protection-rectangulaire-v1.dxf
tools/upload-www examples/dxf/protection-rectangulaire-v2.dxf
trash/ examples/dxf/test-dxf-r15.pdf
tmp.py
Patro/GraphicEngine/TeX/__MERGE_MUSICA__ Patro/GraphicEngine/TeX/__MERGE_MUSICA__
Patro/Pattern/dev/
Patro/QtApplication/rcc/icons/36x36-unused/
devel-experimentations/
doc/sphinx/source/features-all.txt
examples/output-2017/ examples/output-2017/
examples/patterns/veravenus-little-bias-dress.pattern-a0.pdf examples/patterns/veravenus-little-bias-dress.pattern-a0.pdf
examples/patterns/veravenus-little-bias-dress.pattern-a0.svg examples/patterns/veravenus-little-bias-dress.pattern-a0.svg
notes.txt notes.txt
notes/
open-doc.sh open-doc.sh
outdated.txt outdated.txt
ressources ressources
src/ tools/upload-www
trash/
language: python
python:
- "3.5"
env:
before_script:
install:
- pip install -q -r requirements.txt
- pip install .
script:
# fixme:
# Patro - A Python library to make patterns for fashion design
# Copyright (C) 2018 Fabrice Salvaire
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
__all__ = ['AtomicCounter']
import threading
class AtomicCounter:
"""A thread-safe incrementing counter.
def __init__(self, initial=0):
"""Initialize a new atomic counter to given initial value (default 0)."""
self._value = initial
self._lock = threading.Lock()
def __int__(self):
return self._value
def increment(self, value=1):
"""Atomically increment the counter by value (default 1) and return the
new value.
with self._lock:
self._value += value
return self._value
def set(self, value):
"""Atomically set the counter to a value."""
with self._lock:
if value <= self._value:
raise ValueError
self._value = value
...@@ -26,6 +26,8 @@ ...@@ -26,6 +26,8 @@
__all__ = [ __all__ = [
'quadratic_root', 'quadratic_root',
'cubic_root', 'cubic_root',
'fifth_root',
'fifth_root_normalised',
...@@ -78,13 +80,28 @@ def cubic_root(a, b, c, d): ...@@ -78,13 +80,28 @@ def cubic_root(a, b, c, d):
def cubic_root_sympy(a, b, c, d): def cubic_root_sympy(a, b, c, d):
x = sympy.Symbol('x') x = sympy.Symbol('x', real=True)
E = a*x**3 + b*x**2 + c*x + d E = a*x**3 + b*x**2 + c*x + d
return [i.n() for i in sympy.real_roots(E, x)] return [i.n() for i in sympy.real_roots(E, x)]
def fifth_root_normalised(a, b, c, d, e):
E = x**5 + a*x**4 + b*x**3 + c*x**2 + d*x + e
def fifth_root(*args):
a = args[0]
return fifth_root_normalised(*[x/a for x in args[1:]])
def cubic_root_normalised(a, b, c): def cubic_root_normalised(a, b, c):
# Reference: ??? # Reference: ???
__all__ = ['ObjectNameMixin', 'ObjectGlobalIdMixin']
from .AtomicCounter import AtomicCounter
class ObjectNameMixin:
"""Mixin for object with name"""
def __init__(self, name=None):
self.name = name
@property
def name(self):
return self._name
@name.setter
def name(self, value):
if value is None:
self._name = None
else:
self._name = str(value)
def __repr__(self):
return self.__class__.__name__ + ' {0._name}'.format(self)
def __str__(self):
return self._name
class ObjectGlobalIdMixin:
"""Mixin for object with a global id"""
__object_counter__ = AtomicCounter(-1)
def __init__(self, id=None):
# Note: sub-classes share the same counter !
if id is not None:
ObjectGlobalIdMixin.__object_counter__.set(id)
self._id = id
else:
self._id = ObjectGlobalIdMixin.__object_counter__.increment()
@property
def id(self):
return self._id
def __int__(self):
return self._id
def __repr__(self):
return self.__class__.__name__ + ' {0._id}'.format(self)
class ObjectCkeckedIdMixin:
"""Mixin for object with id"""
if id is None:
self._id = self.new_id()
else:
self.check_id(id)
self._id = id
@property
def id(self):
return self._id
def __repr__(self):
def __int__(self):
return self._id
def new_id(self):
raise NotImplementedError
def check_id(self, id):
return True
# Copyright (C) 2017 Fabrice Salvaire
"""Implement Singleton
import threading
class SingletonMetaClass(type):
"""A singleton metaclass.
This implementation supports subclassing and is thread safe.
def __init__(cls, class_name, super_classes, class_attribute_dict):
# It is called just after cls creation in order to complete cls.
# print('MetaSingleton __init__:', cls, class_name, super_classes, class_attribute_dict, sep='\n... ')
type.__init__(cls, class_name, super_classes, class_attribute_dict)
cls._instance = None
cls._rlock = threading.RLock() # A factory function that returns a new reentrant lock object.
def __call__(cls, *args, **kwargs):
# It is called when cls is instantiated: cls(...).
# type.__call__ dispatches to the cls.__new__ and cls.__init__ methods.
# print('MetaSingleton __call__:', cls, args, kwargs, sep='\n... ')
with cls._rlock:
if cls._instance is None:
cls._instance = type.__call__(cls, *args, **kwargs)
return cls._instance
class singleton:
""" A singleton class decorator.
This implementation doesn't support subclassing.
def __init__(self, cls):
# print('singleton __init__: On @ decoration', cls, sep='\n... ')
self._cls = cls
self._instance = None
def __call__(self, *args, **kwargs):
# print('singleton __call__: On instance creation', self, args, kwargs, sep='\n... ')
if self._instance is None:
self._instance = self._cls(*args, **kwargs)
return self._instance
def singleton_func(cls):
""" A singleton function decorator.
# print('singleton_func: On @ decoration', cls, sep='\n... ')
instances = {}
def get_instance(*args, **kwargs):
# print('singleton_func: On instance creation', cls, sep='\n... ')
if cls not in instances:
instances[cls] = cls(*args, **kwargs)
return instances[cls]
return get_instance
class monostate:
""" A monostate base class.
_shared_state = {}
def __new__(cls, *args, **kwargs):
# print('monostate __new__:', cls, args, kwargs, sep='\n... ')
obj = super(monostate, cls).__new__(cls, *args, **kwargs)
obj.__dict__ = cls._shared_state
return obj
...@@ -50,7 +50,7 @@ class XmlFileMixin: ...@@ -50,7 +50,7 @@ class XmlFileMixin:
def _parse(self): def parse(self):
"""Parse a XML file and return the etree""" """Parse a XML file and return the etree"""
with open(str(self._path), 'rb') as f: with open(str(self._path), 'rb') as f:
source = f.read() source = f.read()
...@@ -59,6 +59,24 @@ class XmlFileMixin: ...@@ -59,6 +59,24 @@ class XmlFileMixin:
@staticmethod @staticmethod
def _get_xpath_element(root, path): def get_xpath_elements(root, path):
"""Utility function to get elements from a xpath and a root"""
return root.xpath(path)
@staticmethod
def get_xpath_element(root, path):
"""Utility function to get an element from a xpath and a root""" """Utility function to get an element from a xpath and a root"""
return root.xpath(path)[0] return root.xpath(path)[0]
@classmethod
def get_text_element(cls, root, path):
"""Utility function to a text element from a xpath and a root"""
element = cls.get_xpath_element(root, path)
if hasattr(element, 'text'):
return element.text
else:
return None
...@@ -23,9 +23,10 @@ ...@@ -23,9 +23,10 @@
import os import os
import sys import sys
#################################################################################################### from pathlib import Path
import Patro.Common.Path as PathTools # Fixme: why ? # Fixme: why ?
import Patro.Common.Path as PathTools # due to Path class
...@@ -64,12 +65,12 @@ OS = OsFactory() ...@@ -64,12 +65,12 @@ OS = OsFactory()
_this_file = PathTools.to_absolute_path(__file__) _this_file = Path(__file__).resolve()
class Path: class Path:
musica_module_directory = PathTools.parent_directory_of(_this_file, step=2) patro_module_directory = _this_file.parents[1]
config_directory = os.path.dirname(_this_file) config_directory = _this_file.parent
...@@ -21,7 +21,7 @@ handlers: ...@@ -21,7 +21,7 @@ handlers:
console: console:
class: logging.StreamHandler class: logging.StreamHandler
level: DEBUG level: INFO
# formatter: ansi # formatter: ansi
stream: ext://sys.stdout stream: ext://sys.stdout
"""Module to handle the DXF file format.
__all__ = ['DxfImporter']
import ezdxf # Python packahe to read/write DXF
from Patro.GeometryEngine.Conic import Circle2D, Ellipse2D, AngularDomain
from Patro.GeometryEngine.Segment import Segment2D
from Patro.GeometryEngine.Spline import BSpline2D
from Patro.GeometryEngine.Vector import Vector2D
from .Polyline import Polyline
class DxfImporter:
"""Class to implement a DXF importer.
def __init__(self, path):
path = str(path)
self._drawing = ezdxf.readfile(path)
self._model_space = self._drawing.modelspace()
self._items = []
self._read()
def __len__(self):
return len(self._items)
def __iter__(self):
return iter(self._items)
def __getitem__(self, slice_):
return self._items[slice_]
@staticmethod
def _to_vector(point):
return Vector2D(point[:2])
@classmethod
def _to_vectors(cls, points):
return [cls._to_vector(x) for x in points]
def _add(self, item):
self._items.append(item)
def _read(self):
for item in self._model_space:
dxf_type = item.dxftype()
if dxf_type == 'LINE':
self._on_line(item)
elif dxf_type in ('CIRCLE', 'ARC'):
self._on_circle(item, dxf_type == 'ARC')
elif dxf_type == 'ELLIPSE':
self._on_ellipse(item)
elif dxf_type == 'LWPOLYLINE':
self._on_polyline(item)
elif dxf_type == 'SPLINE':
self._on_spline(item)
# else skip
def _on_line(self, item):
item_dxf = item.dxf
segment = Segment2D(*self._to_vectors((item_dxf.start, item_dxf.end)))
self._add(segment)
def _on_circle(self, item, is_arc):
item_dxf = item.dxf
center = self._to_vector(item_dxf.center)
if is_arc:
domain = AngularDomain(item_dxf.start_angle, item_dxf.end_angle)
else:
domain = None
circle = Circle2D(center, item_dxf.radius, domain=domain)
self._add(circle)
def _on_ellipse(self, item):
item_dxf = item.dxf
major_axis = self._to_vector(item_dxf.major_axis)
minor_axis = major_axis * item_dxf.ratio
domain = AngularDomain(item_dxf.start_param, item_dxf.end_param, degrees=False)
x_radius, y_radius = major_axis.magnitude, minor_axis.magnitude
angle = major_axis.orientation
if angle == 90:
x_radius, y_radius = y_radius, x_radius
angle = 0
# Fixme: ...
ellipse = Ellipse2D(
center,
x_radius, y_radius,
angle,
domain=domain,
self._add(ellipse)
def _on_polyline(self, item):
polyline = Polyline(item.closed)
for x, y, s, e, b in item.get_points():
polyline.add(Vector2D(x, y), b)
geometry = polyline.geometry()
self._add(geometry)
def _on_spline(self, item):
with item.edit_data() as data:
points = self._to_vectors(data.control_points)
item_dxf = item.dxf
spline = BSpline2D(points, item_dxf.degree, item.closed)
self._add(spline)
from Patro.Common.Math.Functions import sign
from Patro.GeometryEngine.Conic import Circle2D, AngularDomain
import math
class PolylineVertex:
# sagitta of a circular arc is the distance from the center of the arc to the center of its base.
# bulge = sagitta / half the length of the chord
# a bulge value of 1 defines a semicircle
# The sign of the bulge value defines the side of the bulge:
# positive value (> 0): bulge is right of line (count clockwise)
# negative value (< 0): bulge is left of line (clockwise)
# 0 = no bulge
# points = item.get_points(format='xyseb') # ???
# r = (s**2 + l**2) / (2*s)
# b = s / l
# s = b*l
# r = ((b*l)**2 + l**2) / (2*b*l)
# = l/2 * (b + 1/b)
# r - s = l/2 * (b + 1/b) - b*l
# = l/2 * (1/b - b)
def __init__(self, polyline, index, point, bulge=0):
self._polyline = polyline
self._index = index
self._point = point
self._bulge = bulge
@property
def point(self):
return self._point
@property
def x(self):
return self._point.x
@property
def y(self):
return self._point.y
@property
def bulge(self):
return self._bulge
@property
def prev(self):
if self._index == 0 and not self._polyline.closed:
return None
return self._polyline[self._index -1]
@property
def next(self):
if self._polyline.is_last_index(self._index):
if self._polyline.closed:
return self._polyline[0]
else:
return None
return self._polyline[self._index +1]
def __str__(self):
return '({0.x:5.2f} {0.y:5.2f} {0._bulge:5.2f})'.format(self)
@property
def segment_vector(self):
return self.next.point - self._point
@property
def demi_chord(self):
return self.segment_vector.magnitude / 2
@property
def sagitta(self):
return self.bulge * self.demi_chord
@property
def bulge_radius(self):
if self._bulge == 0:
return 0
else:
return self.demi_chord/2 * (self._bulge + 1/self._bulge)
@property
def sagitta_dual(self):
return 0
else:
return self.demi_chord/2 * (1/self._bulge - self._bulge)
@property
def angle(self):
return 0
else:
return math.degrees(2 * math.atan(self.bulge_radius/self.demi_chord - self._bulge))
class Polyline:
def __init__(self, closed=False):
self._vertices = []
self._closed = closed
@property
def closed(self):
return self._closed
def __len__(self):
return len(self._vertices)
def __iter__(self):
return iter(self._vertices)
def __getitem__(self, index):
return self._vertices[index]
def is_last_index(self, index):
return index == len(self) - 1
def add(self, *args, **kwargs):
vertex = PolylineVertex(self, len(self), *args, **kwargs)
self._vertices.append(vertex)
def __str__(self):
return ' '.join(['{:5.2f}'.format(vertex) for vertex in self])
def iter_on_segment(self):
for i in range(len(self._vertices) -1):
yield self._vertices[i], self._vertices[i+1]
if self._closed:
yield self._vertices[-1], self._vertices[0]
def geometry(self):
items = []
for vertex1, vertex2 in self.iter_on_segment():
segment = Segment2D(vertex1.point, vertex2.point)
if vertex1.bulge:
segment_center = segment.center
direction = vertex1.segment_vector.normalise()
normal = direction.normal
# offset = vertex1.bulge_radius - vertex1.sagitta
offset = vertex1.sagitta_dual
center = segment_center + normal * sign(vertex1.bulge) * offset
arc = Circle2D(center, vertex1.bulge_radius)
start_angle, stop_angle = [arc.angle_for_point(vertex.point) for vertex in (vertex1, vertex2)]
if start_angle < 0:
start_angle += 360
if stop_angle < 0:
stop_angle += 360
if vertex1.bulge < 0:
start_angle, stop_angle = stop_angle, start_angle
print('bulb', vertex1, vertex2, vertex1.bulge, start_angle, stop_angle)
arc.domain = AngularDomain(start_angle, stop_angle)
# arc = Circle2D(center, vertex1.bulge_radius, domain=AngularDomain(start_angle, stop_angle))
items.append(arc)
else:
items.append(segment)
return items
...@@ -67,7 +67,7 @@ class XmlMeasurement(XmlObjectAdaptator): ...@@ -67,7 +67,7 @@ class XmlMeasurement(XmlObjectAdaptator):
class VitFile(XmlFileMixin): class VitFileInternal(XmlFileMixin):
_logger = _module_logger.getChild('VitFile') _logger = _module_logger.getChild('VitFile')
...@@ -76,43 +76,52 @@ class VitFile(XmlFileMixin): ...@@ -76,43 +76,52 @@ class VitFile(XmlFileMixin):
def __init__(self, path): def __init__(self, path):
XmlFileMixin.__init__(self, path) XmlFileMixin.__init__(self, path)
self._measurements = ValentinaMeasurements() self.measurements = ValentinaMeasurements()
self._read() self.read()
@property def read(self):
def measurements(self):
return self._measurements
def _read(self):
self._logger.info('Load measurements from ' + str(self._path)) self._logger.info('Load measurements from ' + str(self._path))
tree = self._parse() tree = self.parse()
measurements = self._measurements measurements = self.measurements
version = self._get_xpath_element(tree, 'version').text version = self.get_xpath_element(tree, 'version').text
# self._read_only = self._get_xpath_element(tree, 'read-only').text # self.read_only = self.get_xpath_element(tree, 'read-only').text
# self._notes = self._get_xpath_element(tree, 'notes').text # self.notes = self.get_xpath_element(tree, 'notes').text
self.unit = self._get_xpath_element(tree, 'unit').text self.unit = self.get_xpath_element(tree, 'unit').text
self.pattern_making_system = self._get_xpath_element(tree, 'pm_system').text self.pattern_making_system = self.get_xpath_element(tree, 'pm_system').text
personal = measurements.personal personal = measurements.personal
personal_element = self._get_xpath_element(tree, 'personal') personal_element = self.get_xpath_element(tree, 'personal')
personal.last_name = self._get_xpath_element(personal_element, 'family-name').text personal.last_name = self.get_xpath_element(personal_element, 'family-name').text
personal.first_name = self._get_xpath_element(personal_element, 'given-name').text personal.first_name = self.get_xpath_element(personal_element, 'given-name').text
personal.birth_date = self._get_xpath_element(personal_element, 'birth-date').text personal.birth_date = self.get_xpath_element(personal_element, 'birth-date').text
personal.gender = Gender[self._get_xpath_element(personal_element, 'gender').text.upper()] personal.gender = Gender[self.get_xpath_element(personal_element, 'gender').text.upper()]
personal.email = self._get_xpath_element(personal_element, 'email').text personal.email = self.get_xpath_element(personal_element, 'email').text
elements = self._get_xpath_element(tree, 'body-measurements') elements = self.get_xpath_element(tree, 'body-measurements')
for element in elements: for element in elements:
if element.tag == XmlMeasurement.__tag__: if element.tag == XmlMeasurement.__tag__:
xml_measurement = XmlMeasurement(element) xml_measurement = XmlMeasurement(element)
measurements.add(**xml_measurement.to_dict()) measurements.add(**xml_measurement.to_dict())
else: else:
raise NotImplementedError raise NotImplementedError
class VitFile:
self._interval = VitFileInternal(path)
@property
return self._interval.measurements
...@@ -18,7 +18,7 @@ ...@@ -18,7 +18,7 @@
"""This module implements the val XML file format. """This module implements the Valentina val XML file format.
...@@ -31,7 +31,7 @@ from lxml import etree ...@@ -31,7 +31,7 @@ from lxml import etree
from Patro.Common.Xml.XmlFile import XmlFileMixin from Patro.Common.Xml.XmlFile import XmlFileMixin
from Patro.Pattern.Pattern import Pattern from Patro.Pattern.Pattern import Pattern
from .Measurements import VitFile from .Measurement import VitFile
from .VitFormat import ( from .VitFormat import (
Point, Point,
Line, Line,
...@@ -51,6 +51,32 @@ _module_logger = logging.getLogger(__name__) ...@@ -51,6 +51,32 @@ _module_logger = logging.getLogger(__name__)
# Last valentina version supported
VAL_VERSION = '0.7.10'
class Modeling:
"""Class to implement a modeling mapper."""
def __init__(self):
self._id_map = {}
def __getitem__(self, id):
return self._id_map[id]
def add(self, item):
self._id_map[item.id] = item
class Dispatcher: class Dispatcher:
"""Baseclass to dispatch XML to Python class.""" """Baseclass to dispatch XML to Python class."""
...@@ -61,15 +87,15 @@ class Dispatcher: ...@@ -61,15 +87,15 @@ class Dispatcher:
def from_xml(self, element): def from_xml(self, element):
tag_class = self.__TAGS__[element.tag] tag_cls = self.__TAGS__[element.tag]
if tag_class is not None: if tag_cls is not None:
return tag_class(element) return tag_cls(element)
else: else:
class CalculationDispatcher: class CalculationDispatcher(Dispatcher):
"""Class to implement a dispatcher for calculations.""" """Class to implement a dispatcher for calculations."""
...@@ -94,35 +120,35 @@ class CalculationDispatcher: ...@@ -94,35 +120,35 @@ class CalculationDispatcher:
def _register_mapping(self, xml_class): def _register_mapping(self, xml_cls):
calculation_class = xml_class.__calculation__ operation_cls = xml_cls.__operation__
if calculation_class: if operation_cls:
self._mapping[xml_class] = calculation_class self._mapping[xml_cls] = operation_cls
self._mapping[calculation_class] = xml_class self._mapping[operation_cls] = xml_cls
def _init_mapper(self): def _init_mapper(self):
for tag_class in self.__TAGS__.values(): for tag_cls in self.__TAGS__.values():
if hasattr(tag_class, '__TYPES__'): if hasattr(tag_cls, '__TYPES__'):
for xml_class in tag_class.__TYPES__.values(): for xml_cls in tag_cls.__TYPES__.values():
if xml_class is not None: if xml_cls is not None:
self._register_mapping(xml_class) self._register_mapping(xml_cls)
else: else:
self._register_mapping(tag_class) self._register_mapping(tag_cls)
cls = tag_class.__TYPES__[element.attrib['type']] cls = tag_cls.__TYPES__[element.attrib['type']]
else: else:
cls = tag_class cls = tag_cls
if cls is not None: if cls is not None:
return cls(element) return cls(element)
else: else:
...@@ -130,34 +156,15 @@ class CalculationDispatcher: ...@@ -130,34 +156,15 @@ class CalculationDispatcher:
def from_calculation(self, calculation): def from_operation(self, operation):
return self._mapping[calculation.__class__].from_calculation(calculation) return self._mapping[operation.__class__].from_operation(operation)
class Modeling:
def __init__(self):
self._items = []
self._id_map = {}
def append(self, item):
class ModelingDispatcher(Dispatcher): class ModelingDispatcher(Dispatcher):
"""Class to implement a dispatcher for modeling."""
__TAGS__ = { __TAGS__ = {
'point': ModelingPoint, 'point': ModelingPoint,
'spline': ModelingSpline, 'spline': ModelingSpline,
...@@ -167,6 +174,8 @@ class ModelingDispatcher(Dispatcher): ...@@ -167,6 +174,8 @@ class ModelingDispatcher(Dispatcher):
class DetailDispatcher(Dispatcher): class DetailDispatcher(Dispatcher):
"""Class to implement a dispatcher for detail."""
'grainline': DetailGrainline, 'grainline': DetailGrainline,
'patternInfo': DetailPatternInfo, 'patternInfo': DetailPatternInfo,
...@@ -175,65 +184,62 @@ class DetailDispatcher(Dispatcher): ...@@ -175,65 +184,62 @@ class DetailDispatcher(Dispatcher):
class ValFile(XmlFileMixin):
"""Class to read/write val file."""
_logger = _module_logger.getChild('ValFile')
_calculation_dispatcher = CalculationDispatcher() _calculation_dispatcher = CalculationDispatcher()
_modeling_dispatcher = ModelingDispatcher() _modeling_dispatcher = ModelingDispatcher()
_detail_dispatcher = DetailDispatcher() _detail_dispatcher = DetailDispatcher()
def __init__(self, path=None): class ValFileReaderInternal(XmlFileMixin):
# Fixme: path """Class to read val file."""
if path is None:
path = '' _logger = _module_logger.getChild('ValFileReader')
self._vit_file = None
self._pattern = None
# Fixme:
# if path is not None:
if path != '':
self._read()
def Write(self, path, vit_file, pattern): def __init__(self, path):
# Fixme: write XmlFileMixin.__init__(self, path)
self._vit_file = vit_file
self._pattern = pattern self.root = None
self.write(path) self.attribute = {}
self.vit_file = None
self.pattern = None
self.read()
@property @property
def measurements(self): def measurements(self):
return self._vit_file.measurements if self.vit_file is not None:
return self.vit_file.measurements
@property else:
def pattern(self): return None
return self._pattern
def _read(self): def read(self):
# <?xml version='1.0' encoding='UTF-8'?> # <?xml version="1.0" encoding="UTF-8"?>
# <pattern> # <pattern>
# <!--Pattern created with Valentina (http://www.valentina-project.org/).--> # <!--Pattern created with Valentina v0.6.0.912b (https://valentinaproject.bitbucket.io/).-->
# <version>0.4.0</version> # <version>0.7.10</version>
# <unit>cm</unit> # <unit>cm</unit>
# <author/>
# <description/> # <description/>
# <notes/> # <notes/>
# <measurements/> # <patternName>pattern name</patternName>
# <patternNumber>pattern number</patternNumber>
# <company>company/Designer name</company>
# <patternLabel>
# <line alignment="0" bold="true" italic="false" sfIncrement="4" text="%author%"/>
# </patternLabel>
# <patternMaterials/>
# <measurements>measurements.vit</measurements>
# <increments/> # <increments/>
# <draw name="Pattern piece 1"> # <previewCalculations/>
# <draw name="...">
# <calculation/> # <calculation/>
# <modeling/> # <modeling/>
# <details/> # <details/>
...@@ -241,86 +247,182 @@ class ValFile(XmlFileMixin): ...@@ -241,86 +247,182 @@ class ValFile(XmlFileMixin):
# </draw> # </draw>
# </pattern> # </pattern>
tree = self._parse() self._logger.info('Read Valentina file "{}"'.format(self.path))
self.root = self.parse()
self.read_attributes()
self.read_measurements()
# patternLabel
# patternMaterials
# increments
# previewCalculations
self.pattern = Pattern(self.measurements, self.attribute['unit'])
for piece in self.get_xpath_elements(self.root, 'draw'):
self.read_piece(piece)
def read_measurements(self):
measurements_path = Path(self._get_xpath_element(tree, 'measurements').text) measurements_path = self.get_xpath_element(self.root, 'measurements').text
if measurements_path is not None:
measurements_path = Path(measurements_path)
if not measurements_path.exists(): if not measurements_path.exists():
measurements_path = self._path.parent.joinpath(measurements_path) measurements_path = self.path.parent.joinpath(measurements_path)
raise NameError("Cannot find {}".format(measurements_path)) raise NameError("Cannot find {}".format(measurements_path))
self.vit_file = VitFile(measurements_path)
else:
self._vit_file = VitFile(measurements_path) ##############################################
unit = self._get_xpath_element(tree, 'unit').text def read_attributes(self):
pattern = Pattern(self._vit_file.measurements, unit) required_attributes = (
self._pattern = pattern 'unit',
optional_attributes = (
'description',
'notes',
'patternName',
'patternNumber',
'company',
attribute_names = list(required_attributes) + list(optional_attributes)
self.attribute = {name:self.get_text_element(self.root, name) for name in attribute_names}
for name in required_attributes:
if self.attribute[name] is None:
raise NameError('{} is undefined'.format(name))
def read_piece(self, piece):
for element in self._get_xpath_element(tree, 'draw/calculation'): piece_name = piece.attrib['name']
self._logger.info('Create scope "{}"'.format(piece_name))
scope = self.pattern.add_scope(piece_name)
sketch = scope.sketch
for element in self.get_xpath_element(piece, 'calculation'):
try: try:
xml_calculation = self._calculation_dispatcher.from_xml(element) xml_calculation = _calculation_dispatcher.from_xml(element)
xml_calculation.to_calculation(pattern) operation = xml_calculation.to_operation(sketch)
self._logger.info('Add operation {}'.format(operation))
except NotImplementedError: except NotImplementedError:
self._logger.warning('Not implemented calculation\n' + str(etree.tostring(element))) self._logger.warning('Not implemented calculation\n' + str(etree.tostring(element)))
sketch.eval()
pattern.eval()
modeling = Modeling() modeling = Modeling()
for element in self._get_xpath_element(tree, 'draw/modeling'): for element in self.get_xpath_element(piece, 'modeling'):
xml_modeling_item = self._modeling_dispatcher.from_xml(element) xml_modeling_item = _modeling_dispatcher.from_xml(element)
modeling.append(xml_modeling_item) modeling.add(xml_modeling_item)
# print(xml_modeling_item) self._logger.info('Modeling {}'.format(xml_modeling_item))
# details = []
for detail_element in self.get_xpath_element(piece, 'details'):
self.read_detail(scope, modeling, detail_element)
# details.append(xml_detail)
def read_detail(self, scope, modeling, detail_element):
details = []
for detail_element in self._get_xpath_element(tree, 'draw/details'):
xml_detail = Detail(modeling, detail_element) xml_detail = Detail(modeling, detail_element)
details.append(xml_detail) self._logger.info('Detail {}'.format(xml_detail))
print(xml_detail)
for element in detail_element: for element in detail_element:
if element.tag == 'nodes': if element.tag == 'nodes':
for node in element: for node in element:
xml_node = DetailNode(node) xml_node = DetailNode(node)
# print(xml_node)
xml_detail.append_node(xml_node) xml_detail.append_node(xml_node)
else: else:
xml_modeling_item = self._detail_dispatcher.from_xml(element) xml_modeling_item = _detail_dispatcher.from_xml(element)
# Fixme: xml_detail. = xml_modeling_item # Fixme: xml_detail. = xml_modeling_item
# print(xml_modeling_item) print(xml_modeling_item)
for node, modeling_item in xml_detail.iter_on_nodes(): for node, modeling_item in xml_detail.iter_on_nodes():
# print(node.object_id, '->', modeling_item, '->', modeling_item.object_id) # print(node.object_id, '->', modeling_item, '->', modeling_item.object_id)
print(node, '->\n', modeling_item, '->\n', pattern.get_calculation(modeling_item.object_id)) print(node, '->\n', modeling_item, '->\n', scope.sketch.get_operation(modeling_item.object_id))
class ValFileReader:
def write(self, path=None): def __init__(self, path):
self._internal = ValFileReaderInternal(path)
@property
return self._internal.measurements
@property
def pattern(self):
return self._internal.pattern
class ValFileWriter:
"""Class to write val file."""
_logger = _module_logger.getChild('ValFileWriter')
def __init__(self, path, vit_file, pattern):
self._path = str(path)
root = self._build_xml_tree()
self._write(root)
def _build_xml_tree(self):
root = etree.Element('pattern') root = etree.Element('pattern')
root.append(etree.Comment('Pattern created with Patro (https://github.com/FabriceSalvaire/Patro)')) root.append(etree.Comment('Pattern created with Patro (https://github.com/FabriceSalvaire/Patro)'))
etree.SubElement(root, 'version').text = '0.4.0' etree.SubElement(root, 'version').text = self.VAL_VERSION
etree.SubElement(root, 'unit').text = self._pattern.unit etree.SubElement(root, 'unit').text = self._pattern.unit
etree.SubElement(root, 'author') etree.SubElement(root, 'author')
etree.SubElement(root, 'description') etree.SubElement(root, 'description')
etree.SubElement(root, 'notes') etree.SubElement(root, 'notes')
etree.SubElement(root, 'measurements').text = str(self._vit_file.path) measurements = etree.SubElement(root, 'measurements')
if self._vit_file is not None:
measurements.text = str(self._vit_file.path)
etree.SubElement(root, 'increments') etree.SubElement(root, 'increments')
draw_element = etree.SubElement(root, 'draw') # Fixme: for scope in self._pattern.scopes:
draw_element.attrib['name'] = 'Pattern piece 1' # Fixme: draw_element = etree.SubElement(root, 'draw')
draw_element.attrib['name'] = scope.name
calculation_element = etree.SubElement(draw_element, 'calculation') calculation_element = etree.SubElement(draw_element, 'calculation')
modeling_element = etree.SubElement(draw_element, 'modeling') modeling_element = etree.SubElement(draw_element, 'modeling')
details_element = etree.SubElement(draw_element, 'details') details_element = etree.SubElement(draw_element, 'details')
# group_element = etree.SubElement(draw_element, 'groups') # group_element = etree.SubElement(draw_element, 'groups')
for calculation in self._pattern.calculations: for operation in scope.sketch.operations:
xml_calculation = self._calculation_dispatcher.from_calculation(calculation) xml_calculation = _calculation_dispatcher.from_operation(operation)
# print(xml_calculation) # print(xml_calculation)
# print(xml_calculation.to_xml_string()) # print(xml_calculation.to_xml_string())
calculation_element.append(xml_calculation.to_xml()) calculation_element.append(xml_calculation.to_xml())
if path is None: return root
path = self.path
with open(str(path), 'wb') as f: ##############################################
def _write(self, root):
with open(self._path, 'wb') as fh:
# ElementTree.write() ? # ElementTree.write() ?
f.write(etree.tostring(root, pretty_print=True)) fh.write(etree.tostring(root, pretty_print=True))
...@@ -24,6 +24,23 @@ and the calculation API. ...@@ -24,6 +24,23 @@ and the calculation API.
The purpose of each XmlObjectAdaptator sub-classes is to serve as a bidirectional adaptor between The purpose of each XmlObjectAdaptator sub-classes is to serve as a bidirectional adaptor between
the XML format and the API. the XML format and the API.
Valentina File Format Concept
* all entities which are referenced later in the file are identified by a unique positive integer
over the file, usually incremented from 1.
* a file contains one or several "pieces"
* pieces correspond to independent scopes, one cannot access calculations of another piece
* pieces share the same referential, usually the root point of a piece is placed next
to the previous piece
* a piece has "calculations" and "details"
* a calculations corresponds to a point, a segment, or a Bézier curve ...
* a detail corresponds to a garment piece defined by segments and curves
* one can define several details within a piece
...@@ -43,14 +60,65 @@ __all__ = [ ...@@ -43,14 +60,65 @@ __all__ = [
import Patro.Pattern.Calculation as Calculation import Patro.Pattern.SketchOperation as SketchOperation
from Patro.Common.Xml.Objectivity import ( from Patro.Common.Xml.Objectivity import (
Attribute,
BoolAttribute, BoolAttribute,
IntAttribute, FloatAttribute, IntAttribute, FloatAttribute,
StringAttribute, StringAttribute,
XmlObjectAdaptator XmlObjectAdaptator
from Patro.GeometryEngine.Vector import Vector2D from Patro.GeometryEngine.Vector import Vector2D
from Patro.GraphicStyle import Colors, StrokeStyle
class ColorAttribute(Attribute):
__COLORS__ = (
'black',
'blue',
'cornflowerblue',
'darkBlue',
'darkGreen',
'darkRed',
'darkviolet',
'deeppink',
'deepskyblue',
'goldenrod',
'green',
'lightsalmon',
'lime',
'mediumseagreen',
'orange',
'violet',
'yellow',
@classmethod
def from_xml(cls, value):
return Colors.ensure_color(value)
class StrokeStyleAttribute(Attribute):
__STROKE_STYLE__ = {
'dashDotDotLine': StrokeStyle.DashDotDotLine,
'dashDotLine': StrokeStyle.DashDotLine,
'dashLine': StrokeStyle.DashLine,
'dotLine': StrokeStyle.DotLine,
'hair': StrokeStyle.SolidLine, # should be solid
'none': StrokeStyle.NoPen,
@classmethod
return cls.__STROKE_STYLE__[value]
...@@ -208,22 +276,24 @@ class CalculationMixin: ...@@ -208,22 +276,24 @@ class CalculationMixin:
IntAttribute('id'), IntAttribute('id'),
__calculation__ = None # calculation's class __operation__ = None # operation's class
def call_calculation_function(self, pattern, kwargs): def call_operation_function(self, sketch, kwargs):
return getattr(pattern, self.__calculation__.__name__)(**kwargs) # Fixme: map valentina name -> ...
method = getattr(sketch, self.__operation__.__name__)
return method(**kwargs)
def to_calculation(self, pattern): def to_operation(self, sketch):
@classmethod @classmethod
def from_calculation(calculation): def from_operation(operation):
...@@ -240,37 +310,8 @@ class CalculationTypeMixin(CalculationMixin): ...@@ -240,37 +310,8 @@ class CalculationTypeMixin(CalculationMixin):
class LinePropertiesMixin: class LinePropertiesMixin:
__attributes__ = ( __attributes__ = (
StringAttribute('line_color', 'lineColor'), ColorAttribute('line_color', 'lineColor'),
StringAttribute('line_style', 'typeLine'), StrokeStyleAttribute('line_style', 'typeLine'),
__COLORS__ = (
'black',
'blue',
'cornflowerblue',
'darkBlue',
'darkGreen',
'darkRed',
'darkviolet',
'deeppink',
'deepskyblue',
'goldenrod',
'green',
'lightsalmon',
'lime',
'mediumseagreen',
'orange',
'violet',
'yellow',
__LINE_STYLE__ = (
'dashDotDotLine',
'dashDotLine',
'dashLine',
'dotLine',
'hair', # should be solid
'none',
class XyMixin: class XyMixin:
...@@ -334,19 +375,19 @@ class PointMixin(CalculationTypeMixin, MxMyMixin): ...@@ -334,19 +375,19 @@ class PointMixin(CalculationTypeMixin, MxMyMixin):
kwargs = self.to_dict(exclude=('mx', 'my')) # id' kwargs = self.to_dict(exclude=('mx', 'my')) # id'
kwargs['label_offset'] = Vector2D(self.mx, self.my) kwargs['label_offset'] = Vector2D(self.mx, self.my)
return self.call_calculation_function(pattern, kwargs) return self.call_operation_function(sketch, kwargs)
def from_calculation(cls, calculation): def from_operation(cls, operation):
kwargs = cls.get_dict(calculation, exclude=('mx', 'my')) kwargs = cls.get_dict(operation, exclude=('mx', 'my'))
label_offset = calculation.label_offset label_offset = operation.label_offset
kwargs['mx'] = label_offset.x kwargs['mx'] = label_offset.x
kwargs['my'] = label_offset.y kwargs['my'] = label_offset.y
return cls(**kwargs) return cls(**kwargs)
...@@ -364,7 +405,7 @@ class AlongLinePoint(PointLinePropertiesMixin, FirstSecondPointMixin, LengthMixi ...@@ -364,7 +405,7 @@ class AlongLinePoint(PointLinePropertiesMixin, FirstSecondPointMixin, LengthMixi
# length="-Line_Bt_Ct" name="Dt" lineColor="black" type="alongLine" my="0.2"/> # length="-Line_Bt_Ct" name="Dt" lineColor="black" type="alongLine" my="0.2"/>
__type__ = 'alongLine' __type__ = 'alongLine'
__calculation__ = Calculation.AlongLinePoint __operation__ = SketchOperation.AlongLinePoint
...@@ -374,7 +415,7 @@ class BissectorPoint(PointLinePropertiesMixin, FirstSecondThirdPointMixin, Lengt ...@@ -374,7 +415,7 @@ class BissectorPoint(PointLinePropertiesMixin, FirstSecondThirdPointMixin, Lengt
# length="Line_A_X" name="B" lineColor="deepskyblue" type="bisector" my="0.2"/> # length="Line_A_X" name="B" lineColor="deepskyblue" type="bisector" my="0.2"/>
__type__ = 'bisector' __type__ = 'bisector'
# __calculation__ = Calculation.BissectorPoint # __operation__ = SketchOperation.BissectorPoint
...@@ -399,7 +440,7 @@ class EndLinePoint(PointLinePropertiesMixin, BasePointMixin, LengthAngleMixin, X ...@@ -399,7 +440,7 @@ class EndLinePoint(PointLinePropertiesMixin, BasePointMixin, LengthAngleMixin, X
# lineColor="blue" type="endLine" angle="360" my="0.25"/> # lineColor="blue" type="endLine" angle="360" my="0.25"/>
__type__ = 'endLine' __type__ = 'endLine'
__calculation__ = Calculation.EndLinePoint __operation__ = SketchOperation.EndLinePoint
...@@ -409,7 +450,7 @@ class HeightPoint(PointLinePropertiesMixin, BasePointMixin, Line1Mixin, XmlObjec ...@@ -409,7 +450,7 @@ class HeightPoint(PointLinePropertiesMixin, BasePointMixin, Line1Mixin, XmlObjec
# lineColor="mediumseagreen" type="height" my="0.2"/> # lineColor="mediumseagreen" type="height" my="0.2"/>
__type__ = 'height' __type__ = 'height'
# __calculation__ = Calculation.HeightPoint # __operation__ = SketchOperation.HeightPoint
...@@ -419,7 +460,7 @@ class LineIntersectPoint(PointMixin, Line12Mixin, XmlObjectAdaptator): ...@@ -419,7 +460,7 @@ class LineIntersectPoint(PointMixin, Line12Mixin, XmlObjectAdaptator):
# p2Line1="12" p2Line2="14"/> # p2Line1="12" p2Line2="14"/>
__type__ = 'lineIntersect' __type__ = 'lineIntersect'
__calculation__ = Calculation.LineIntersectPoint __operation__ = SketchOperation.LineIntersectPoint
...@@ -429,7 +470,7 @@ class LineIntersectAxisPoint(PointLinePropertiesMixin, BasePointMixin, Line1Mixi ...@@ -429,7 +470,7 @@ class LineIntersectAxisPoint(PointLinePropertiesMixin, BasePointMixin, Line1Mixi
# lineColor="goldenrod" type="lineIntersectAxis" angle="150" my="-1.8"/> # lineColor="goldenrod" type="lineIntersectAxis" angle="150" my="-1.8"/>
__type__ = 'lineIntersectAxis' __type__ = 'lineIntersectAxis'
# __calculation__ = Calculation.LineIntersectAxisPoint # __operation__ = SketchOperation.LineIntersectAxisPoint
...@@ -439,7 +480,7 @@ class NormalPoint(PointLinePropertiesMixin, FirstSecondPointMixin, LengthAngleMi ...@@ -439,7 +480,7 @@ class NormalPoint(PointLinePropertiesMixin, FirstSecondPointMixin, LengthAngleMi
# name="Ct" lineColor="blue" type="normal" angle="0" my="0.1"/> # name="Ct" lineColor="blue" type="normal" angle="0" my="0.1"/>
__type__ = 'normal' __type__ = 'normal'
__calculation__ = Calculation.NormalPoint __operation__ = SketchOperation.NormalPoint
...@@ -459,7 +500,7 @@ class PointOfIntersection(PointMixin, FirstSecondPointMixin, XmlObjectAdaptator) ...@@ -459,7 +500,7 @@ class PointOfIntersection(PointMixin, FirstSecondPointMixin, XmlObjectAdaptator)
# <point id="14" firstPoint="2" mx="0.1" secondPoint="5" name="XY" type="pointOfIntersection" my="0.2"/> # <point id="14" firstPoint="2" mx="0.1" secondPoint="5" name="XY" type="pointOfIntersection" my="0.2"/>
__type__ = 'pointOfIntersection' __type__ = 'pointOfIntersection'
__calculation__ = Calculation.PointOfIntersection __operation__ = SketchOperation.PointOfIntersection
...@@ -482,7 +523,7 @@ class ShoulderPoint(PointLinePropertiesMixin, Line1Mixin, LengthMixin, XmlObject ...@@ -482,7 +523,7 @@ class ShoulderPoint(PointLinePropertiesMixin, Line1Mixin, LengthMixin, XmlObject
# p1Line="5" lineColor="lightsalmon" type="shoulder" my="-1.3"/> # p1Line="5" lineColor="lightsalmon" type="shoulder" my="-1.3"/>
__type__ = 'shoulder' __type__ = 'shoulder'
# __calculation__ = Calculation.ShoulderPoint # __operation__ = SketchOperation.ShoulderPoint
IntAttribute('shoulder_point', 'pShoulder'), IntAttribute('shoulder_point', 'pShoulder'),
...@@ -494,7 +535,7 @@ class SinglePoint(PointMixin, XyMixin, XmlObjectAdaptator): ...@@ -494,7 +535,7 @@ class SinglePoint(PointMixin, XyMixin, XmlObjectAdaptator):
# <point id="1" mx="0.1" x="0.79375" y="1.05833" name="A" type="single" my="0.2"/> # <point id="1" mx="0.1" x="0.79375" y="1.05833" name="A" type="single" my="0.2"/>
__type__ = 'single' __type__ = 'single'
__calculation__ = Calculation.SinglePoint __operation__ = SketchOperation.SinglePoint
...@@ -544,18 +585,18 @@ class Line(CalculationMixin, LinePropertiesMixin, FirstSecondPointMixin, XmlObje ...@@ -544,18 +585,18 @@ class Line(CalculationMixin, LinePropertiesMixin, FirstSecondPointMixin, XmlObje
# <line id="47" firstPoint="38" typeLine="hair" secondPoint="45" lineColor="blue"/> # <line id="47" firstPoint="38" typeLine="hair" secondPoint="45" lineColor="blue"/>
__tag__ = 'line' __tag__ = 'line'
__calculation__ = Calculation.Line __operation__ = SketchOperation.Line
return self.call_calculation_function(pattern, self.to_dict()) # exclude=('id') return self.call_operation_function(sketch, self.to_dict()) # exclude=('id')
kwargs = cls.get_dict(calculation) kwargs = cls.get_dict(operation)
...@@ -580,18 +621,18 @@ class SimpleInteractiveSpline(SplineMixin, XmlObjectAdaptator): ...@@ -580,18 +621,18 @@ class SimpleInteractiveSpline(SplineMixin, XmlObjectAdaptator):
StringAttribute('angle2'), StringAttribute('angle2'),
StringAttribute('line_color', 'color'), StringAttribute('line_color', 'color'),
__calculation__ = Calculation.SimpleInteractiveSpline __operation__ = SketchOperation.SimpleInteractiveSpline
...@@ -18,99 +18,59 @@ ...@@ -18,99 +18,59 @@
"""Module to implement Bézier curve.
# C0 = continuous
# G1 = geometric continuity
# Tangents point to the same direction
# C1 = parametric continuity
# Tangents are the same, implies G1
# C2 = curvature continuity
# Tangents and their derivatives are the same
from math import log, sqrt, pow from math import log, sqrt
import numpy as np
from Patro.Common.Math.Root import quadratic_root, cubic_root from Patro.Common.Math.Root import quadratic_root, cubic_root, fifth_root
from .Interpolation import interpolate_two_points from .Interpolation import interpolate_two_points
from .Line import Line2D from .Line import Line2D
from .Primitive import Primitive3P, Primitive4P, Primitive2DMixin from .Primitive import Primitive3P, Primitive4P, PrimitiveNP, Primitive2DMixin
from .Transformation import AffineTransformation from .Transformation import AffineTransformation
from .Vector import Vector2D from .Vector import Vector2D
# Fixme: implement intersection # Fixme:
# max distance to the chord for linear approximation
# fitting
class QuadraticBezier2D(Primitive2DMixin, Primitive3P): class BezierMixin2D(Primitive2DMixin):
"""Class to implements 2D Quadratic Bezier Curve.""" """Mixin to implements 2D Bezier Curve."""
LineInterpolationPrecision = 0.05 LineInterpolationPrecision = 0.05
def __init__(self, p0, p1, p2):
Primitive3P.__init__(self, p0, p1, p2)
def __repr__(self):
return self.__class__.__name__ + '({0._p0}, {0._p1}, {0._p2})'.format(self)
@property
def length(self):
# Algorithm:
# http://www.gamedev.net/topic/551455-length-of-a-generalized-quadratic-bezier-curve-in-3d
# Dave Eberly Posted October 25, 2009
# The quadratic Bezier is
# (x(t),y(t)) = (1-t)^2*(x0,y0) + 2*t*(1-t)*(x1,y1) + t^2*(x2,y2)
# The derivative is
# (x'(t),y'(t)) = -2*(1-t)*(x0,y0) + (2-4*t)*(x1,y1) + 2*t*(x2,y2)
# The length of the curve for 0 <= t <= 1 is
# Integral[0,1] sqrt((x'(t))^2 + (y'(t))^2) dt
# The integrand is of the form sqrt(c*t^2 + b*t + a)
# You have three separate cases: c = 0, c > 0, or c < 0.
# * The case c = 0 is easy.
# * For the case c > 0, an antiderivative is
# (2*c*t+b)*sqrt(c*t^2+b*t+a)/(4*c) + (0.5*k)*log(2*sqrt(c*(c*t^2+b*t+a)) + 2*c*t + b)/sqrt(c)
# where k = 4*c/q with q = 4*a*c - b*b.
# * For the case c < 0, an antiderivative is
# (2*c*t+b)*sqrt(c*t^2+b*t+a)/(4*c) - (0.5*k)*arcsin((2*c*t+b)/sqrt(-q))/sqrt(-c)
A0 = self._p1 - self._p0
A1 = self._p0 - self._p1 * 2 + self._p2
if A1.magnitude_square() != 0:
c = 4 * A1.dot(A1)
b = 8 * A0.dot(A1)
a = 4 * A0.dot(A0)
q = 4 * a * c - b * b
two_cb = 2 * c + b
sum_cba = c + b + a
m0 = 0.25 / c
m1 = q / (8 * c**1.5)
return (m0 * (two_cb * sqrt(sum_cba) - b * sqrt(a)) +
m1 * (log(2 * sqrt(c * sum_cba) + two_cb) - log(2 * sqrt(c * a) + b)))
else:
return 2 * A0.magnitude()
def interpolated_length(self, dt=None): def interpolated_length(self, dt=None):
# Length of the curve obtained via line interpolation # Length of the curve obtained via line interpolation
if dt is None: if dt is None:
dt = self.LineInterpolationPrecision / (self.end_point - self.start_point).magnitude() dt = self.LineInterpolationPrecision / (self.end_point - self.start_point).magnitude
length = 0 length = 0
t = 0 t = 0
while t < 1: while t < 1:
t0 = t t0 = t
t = min(t + dt, 1) t = min(t + dt, 1)
length += (self.point_at_t(t) - self.point_at_t(t0)).magnitude() length += (self.point_at_t(t) - self.point_at_t(t0)).magnitude
return length return length
...@@ -170,6 +130,143 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P): ...@@ -170,6 +130,143 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P):
def split_at_two_t(self, t1, t2):
if t1 == t2:
return self.point_at_t(t1)
if t2 < t1:
# Fixme: raise ?
t1, t2 = t2, t1
# curve = self
# if t1 > 0:
curve = self.split_at_t(t1)[1] # right
if t2 < 1:
# Interpolate the parameter at t2 in the new curve
t = (t2 - t1) / (1 - t1)
curve = curve.split_at_t(t)[0] # left
return curve
def _map_to_line(self, line):
transformation = AffineTransformation.Rotation(-line.v.orientation)
# Fixme: use __vector_cls__
transformation *= AffineTransformation.Translation(Vector2D(0, -line.p.y))
# Fixme: better API ?
return self.clone().transform(transformation)
def non_parametric_curve(self, line):
"""Return the non-parametric Bezier curve D(ti, di(t)) where di(t) is the distance of the curve from
the baseline of the fat-line, ti is equally spaced in [0, 1].
ts = np.arange(0, 1, 1/(self.number_of_points-1))
distances = [line.distance_to_line(p) for p in self.points]
points = [Vector2D(t, d) for t, f in zip(ts, distances)]
return self.__class__(*points)
def distance_to_point(self, point):
p = self.closest_point(point)
if p is not None:
return (point - p).magnitude
else:
return None
class QuadraticBezier2D(BezierMixin2D, Primitive3P):
# Q(t) = Transformation * Control * Basis * T(t)
# / P1x P2x P3x \ / 1 -2 1 \ / 1 \
# Q(t) = Tr | P1y P2x P3x | | 0 2 -2 | | t |
# \ 1 1 1 / \ 0 0 1 / \ t**2 /
# Q(t) = P0 * (1 - 2*t + t**2) +
# P1 * ( 2*t - t**2) +
# P2 * t**2
BASIS = np.array((
(1, -2, 1),
(0, 2, -2),
(0, 0, 1),
INVERSE_BASIS = np.array((
(-2, 1, -2),
(-1, -3, 1),
(-1, -1, -2),
def __repr__(self):
@property
def length(self):
# Algorithm:
# The derivative is
if A1.magnitude_square != 0:
c = 4 * A1.dot(A1)
b = 8 * A0.dot(A1)
a = 4 * A0.dot(A0)
two_cb = 2 * c + b
sum_cba = c + b + a
m0 = 0.25 / c
else:
def point_at_t(self, t): def point_at_t(self, t):
# if 0 < t or 1 < t: # if 0 < t or 1 < t:
# raise ValueError() # raise ValueError()
...@@ -195,27 +292,6 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P): ...@@ -195,27 +292,6 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P):
if t1 == t2:
if t2 < t1:
# Fixme: raise ?
t1, t2 = t2, t1
# curve = self
# if t1 > 0:
if t2 < 1:
return curve
@property @property
def tangent0(self): def tangent0(self):
return (self._p1 - self._p0).normalise() return (self._p1 - self._p0).normalise()
...@@ -246,16 +322,6 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P): ...@@ -246,16 +322,6 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P):
def intersect_line(self, line): def intersect_line(self, line):
"""Find the intersections of the curve with a line.""" """Find the intersections of the curve with a line."""
...@@ -314,17 +380,64 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P): ...@@ -314,17 +380,64 @@ class QuadraticBezier2D(Primitive2DMixin, Primitive3P):
def non_parametric_curve(self, line): def closest_point(self, point):
""" # Reference:
# https://hal.archives-ouvertes.fr/inria-00518379/document
# Improved Algebraic Algorithm On Point Projection For Bézier Curves
# Xiao-Diao Chen, Yin Zhou, Zhenyu Shu, Hua Su, Jean-Claude Paul
ts = np.arange(0, 1, 1/(self.number_of_points-1)) # Condition:
distances = [line.distance_to_line(p) for p in self.points] # (P - B(t)) . B'(t) = 0 where t in [0,1]
points = [Vector2D(t, d) for t, f in zip(ts, distances)] #
return self.__class__(*points) # P. B'(t) - B(t). B'(t) = 0
# A = P1 - P0
# B = P2 - P1 - A
# M = P0 - P
# Q(t) = P0*(1-t)**2 + P1*2*t*(1-t) + P2*t**2
# Q'(t) = -2*P0*(1 - t) + 2*P1*(1 - 2*t) + 2*P2*t
# = 2*(A + B*t)
# P0, P1, P2, P, t = symbols('P0 P1 P2 P t')
# Q = P0 * (1-t)**2 + P1 * 2*t*(1-t) + P2 * t**2
# Qp = simplify(Q.diff(t))
# collect(expand((P*Qp - Q*Qp)/-2), t)
# (P0**2 - 4*P0*P1 + 2*P0*P2 + 4*P1**2 - 4*P1*P2 + P2**2) * t**3
# (-3*P0**2 + 9*P0*P1 - 3*P0*P2 - 6*P1**2 + 3*P1*P2) * t**2
# (-P*P0 + 2*P*P1 - P*P2 + 3*P0**2 - 6*P0*P1 + P0*P2 + 2*P1**2) * t
# P*P0 - P*P1 - P0**2 + P0*P1
# factorisation
# (P0 - 2*P1 + P2)**2 * t**3
# 3*(P1 - P0)*(P0 - 2*P1 + P2) * t**2
# (P0 - P)*(P1 - P0)
# B**2 * t**3
# 3*A*B * t**2
# (2*A**2 + M*B) * t
# M*A
A = self._p1 - self._p0
B = self._p2 - self._p1 - A
M = self._p0 - point
roots = cubic_root(
B.magnitude_square,
3*A.dot(B),
2*A.magnitude_square + M.dot(B),
M.dot(A),
t = [root for root in roots if 0 <= root <= 1]
if not t:
return None
elif len(t) > 1:
raise NameError("Found more than on root")
else:
return self.point_at_t(t)
...@@ -333,16 +446,36 @@ _Div18Sqrt3 = 18 / _Sqrt3 ...@@ -333,16 +446,36 @@ _Div18Sqrt3 = 18 / _Sqrt3
_OneThird = 1 / 3 _OneThird = 1 / 3
_Sqrt3Div36 = _Sqrt3 / 36 _Sqrt3Div36 = _Sqrt3 / 36
class CubicBezier2D(Primitive4P, QuadraticBezier2D): class CubicBezier2D(BezierMixin2D, Primitive4P):
"""Class to implements 2D Cubic Bezier Curve.""" """Class to implements 2D Cubic Bezier Curve."""
InterpolationPrecision = 0.001 InterpolationPrecision = 0.001
# / P1x P2x P3x P4x \ / 1 -3 3 -1 \ / 1 \
# Q(t) = Tr | P1y P2x P3x P4x | | 0 3 -6 3 | | t |
# | 0 0 0 0 | | 0 0 3 -3 | | t**2 |
# \ 1 1 1 1 / \ 0 0 0 1 / \ t**3 /
BASIS = np.array((
(1, -3, 3, -1),
(0, 3, -6, 3),
(0, 0, 3, -3),
(0, 0, 0, 1),
(1, 1, 1, 1),
(0, 1/3, 2/3, 1),
(0, 0, 1/3, 1),
(0, 0, 0, 1),
def __init__(self, p0, p1, p2, p3): def __init__(self, p0, p1, p2, p3):
Primitive4P.__init__(self, p0, p1, p2, p3) Primitive4P.__init__(self, p0, p1, p2, p3)
...@@ -352,6 +485,14 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D): ...@@ -352,6 +485,14 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D):
def to_spline(self):
from .Spline import CubicUniformSpline2D
basis = np.dot(self.BASIS, CubicUniformSpline2D.INVERSE_BASIS)
points = np.dot(self.geometry_matrix, basis).transpose()
return CubicUniformSpline2D(*points)
@property @property
def length(self): def length(self):
return self.adaptive_length_approximation() return self.adaptive_length_approximation()
...@@ -366,6 +507,8 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D): ...@@ -366,6 +507,8 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D):
(self._p2 - self._p1*2 + self._p0) * 3 * t**2 + (self._p2 - self._p1*2 + self._p0) * 3 * t**2 +
(self._p3 - self._p2*3 + self._p1*3 - self._p0) * t**3) (self._p3 - self._p2*3 + self._p1*3 - self._p0) * t**3)
# interpolate = point_at_t
def _q_point(self): def _q_point(self):
...@@ -399,7 +542,7 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D): ...@@ -399,7 +542,7 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D):
def _d01(self): def _d01(self):
"""Return the distance between 0 and 1 quadratic aproximations""" """Return the distance between 0 and 1 quadratic aproximations"""
return (self._p3 - self._p2 * 3 + self._p1 * 3 - self._p0).magnitude() / 2 return (self._p3 - self._p2 * 3 + self._p1 * 3 - self._p0).magnitude / 2
...@@ -786,3 +929,55 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D): ...@@ -786,3 +929,55 @@ class CubicBezier2D(Primitive4P, QuadraticBezier2D):
return (3 * ((y3 - y0) * (x1 + x2) - (x3 - x0) * (y1 + y2) return (3 * ((y3 - y0) * (x1 + x2) - (x3 - x0) * (y1 + y2)
+ y1 * (x0 - x2) - x1 * (y0 - y2) + y1 * (x0 - x2) - x1 * (y0 - y2)
+ y3 * (x2 + x0 / 3) - x3 * (y2 + y0 / 3)) / 20) + y3 * (x2 + x0 / 3) - x3 * (y2 + y0 / 3)) / 20)
# Q(t) = (P3 - 3*P2 + 3*P1 - P0) * t**3 +
# 3*(P2 - 2*P1 + P0) * t**2 +
# 3*(P1 - P0) * t +
# P0
# n = P3 - 3*P2 + 3*P1 - P0
# r = 3*(P2 - 2*P1 + P0
# s = 3*(P1 - P0)
# v = P0
# Q(t) = n*t**3 + r*t**2 + s*t + v
# Q'(t) = 3*n*t**2 + 2*r*t + s
# P0, P1, P2, P3, P, t = symbols('P0 P1 P2 P3 P t')
# n, r, s, v = symbols('n r s v')
# Q = n*t**3 + r*t**2 + s*t + v
# collect(expand((P*Qp - Q*Qp)), t)
# -3*n**2 * t**5
# -5*n*r * t**4
# -2*(2*n*s + r**2) * t**3
# 3*(P*n - n*v - r*s) * t**2
# (2*P*r - 2*r*v - s**2) * t
# P*s - s*v
n = self._p3 - self._p2*3 + self._p1*3 - self._p0
r = (self._p2 - self._p1*2 + self._p0)*3
s = (self._p1 - self._p0)*3
v = self._p0
roots = fifth_root(
-3 * n.magnitude_square,
-5 * n.dot(r),
-2 * (2*n.dot(s) + r.magnitude_square),
3 * (point.dot(n) - n.dot(v) - r.dot(s)),
2*point.dot(r) - 2*r.dot(v) - s.magnitude_square,
point.dot(s) - s.dot(v),
# Fixme: to func
if not t:
return None
elif len(t) > 1:
else:
return self.point_at_t(t[0])
...@@ -91,7 +91,8 @@ def convex_hull(points): ...@@ -91,7 +91,8 @@ def convex_hull(points):
convex_hull = [] convex_hull = []
sorted_points = _sort_point_for_graham_scan(points) sorted_points = _sort_point_for_graham_scan(points)
for p in sorted_points: for p in sorted_points:
# if we turn clockwise to reach this point, pop the last point from the stack, else, append this point to it. # if we turn clockwise to reach this point,
# pop the last point from the stack, else, append this point to it.
while len(convex_hull) > 1 and _ccw(convex_hull[-1], convex_hull[-2], p) >= 0: # Fixme: check while len(convex_hull) > 1 and _ccw(convex_hull[-1], convex_hull[-2], p) >= 0: # Fixme: check
convex_hull.pop() convex_hull.pop()
convex_hull.append(p) convex_hull.append(p)
...@@ -18,23 +18,148 @@ ...@@ -18,23 +18,148 @@
"""Module to implement conic geometry like circle and ellipse.
Valentina Requirements
* circle with angular domain
* circle with start angle and arc length
* curvilinear distance on circle
* line-circle intersection
* circle-circle intersection
* point constructed from a virtual circle and a point on a tangent : right triangle
* point from tangent circle and segment ???
* ellipse with angular domain and rotation
from math import sqrt, radians, cos, sin, fabs, pi __all__ = [
'AngularDomain',
'Circle2D',
'Ellipse2D',
import math
from math import fabs, sqrt, radians, pi, cos, sin # , degrees
import numpy as np import numpy as np
from IntervalArithmetic import Interval from IntervalArithmetic import Interval2D
from Patro.Common.Math.Functions import sign from Patro.Common.Math.Functions import sign, epsilon_float
from .BoundingBox import bounding_box_from_points
from .Primitive import Primitive, Primitive2DMixin from .Primitive import Primitive, Primitive2DMixin
from .Segment import Segment2D from .Segment import Segment2D
class DomainMixin: class AngularDomain:
"""Class to define an angular domain"""
def __init__(self, start=0, stop=360, degrees=True):
if not degrees:
start = math.degrees(start)
stop = math.degrees(stop)
self.start = start
self.stop = stop
def __clone__(self):
return self.__class__(self._start, self._stop)
def __repr__(self):
return '{0}({1._start}, {1._stop})'.format(self.__class__.__name__, self)
@property
def start(self):
return self._start
@start.setter
def start(self, value):
self._start = float(value)
@property
def stop(self):
return self._stop
@stop.setter
def stop(self, value):
self._stop = float(value)
@property
def start_radians(self):
return radians(self._start)
@property
def stop_radians(self):
return radians(self._stop)
@property
def is_null(self):
return self._stop == self._start
@property
def is_closed(self):
return abs(self._stop - self._start) >= 360
@property
def is_over_closed(self):
return abs(self._stop - self._start) > 360
@property
def is_counterclockwise(self):
"""Return True if start <= stop, e.g. 10 <= 300"""
# Fixme: name ???
return self.start <= self.stop
@property
def is_clockwise(self):
"""Return True if stop < start, e.g. 300 < 10"""
return self.stop < self.start
@property
def length(self):
"""Return the length for an unitary circle"""
if self.is_closed:
return 2*pi
else:
length = self.stop_radians - self.start_radians
if self.is_counterclockwise:
return length
else:
return 2*pi - length
def is_inside(self, angle):
return self._start <= angle <= self._stop
else:
# Fixme: check !!!
return not(self._stop < angle < self._start)
class AngularDomainMixin:
...@@ -43,9 +168,9 @@ class DomainMixin: ...@@ -43,9 +168,9 @@ class DomainMixin:
return self._domain return self._domain
@domain.setter @domain.setter
def domain(self, interval): def domain(self, value):
if interval is not None and interval.length < 360: if value is not None:
self._domain = Interval(interval) self._domain = value # Fixme: AngularDomain() ??
else: else:
self._domain = None self._domain = None
...@@ -60,7 +185,7 @@ class DomainMixin: ...@@ -60,7 +185,7 @@ class DomainMixin:
def start_stop_point(self, start=True): def start_stop_point(self, start=True):
if self._domain is not None: if self._domain is not None:
angle = self.domain.inf if start else self.domain.sup angle = self.domain.start if start else self.domain.stop
return self.point_at_angle(angle) return self.point_at_angle(angle)
else: else:
return None return None
...@@ -77,9 +202,15 @@ class DomainMixin: ...@@ -77,9 +202,15 @@ class DomainMixin:
def stop_point(self): def stop_point(self):
return self.start_stop_point(start=False) return self.start_stop_point(start=False)
class Circle2D(Primitive2DMixin, DomainMixin, Primitive): class PointNotOnCircleError(ValueError):
pass
class Circle2D(Primitive2DMixin, AngularDomainMixin, Primitive):
"""Class to implements 2D Circle.""" """Class to implements 2D Circle."""
...@@ -106,32 +237,64 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -106,32 +237,64 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
# @classmethod
# def from_start_angle_distance(cls, center, radius, start_angle, distance):
# """Construct a circle from a center point, a starting angle and a distance point"""
# if distance > 2*pi*radius:
# domain = None
# else:
# stop_angle = start_angle + math.degrees(distance / radius)
# domain = AngularDomain(start_angle, stop_angle)
# return cls(center, radius, domain)
# Fixme: tangent constructs ... # Fixme: tangent constructs ...
def __init__(self, center, radius, domain=None, diameter=False): def __init__(self, center, radius,
domain=None,
diameter=False,
start_angle=None,
distance=None,
"""Construct a 2D circle from a center point and a radius. """Construct a 2D circle from a center point and a radius.
If the circle is not closed, *domain* is an interval in degrees. If the circle is not closed, *domain* is a an :class:`AngularDomain` instance in degrees.
If *start_angle and *distance* is given then the stop angle is computed from them.
if diameter: if diameter:
radius /= 2 radius /= 2
self._radius = radius self._radius = radius
self.center = center self.center = center
if start_angle is not None and distance is not None:
self._domain = None
else:
self._domain = AngularDomain(start_angle, stop_angle)
else:
self.domain = domain # Fixme: name ??? self.domain = domain # Fixme: name ???
def __repr__(self):
return '{0}({1._center}, {1._radius}, {1._domain})'.format(self.__class__.__name__, self)
@property @property
def center(self): def center(self):
return self._center return self._center
@center.setter @center.setter
def center(self, value): def center(self, value):
self._center = Vector2D(value) self._center = self.__vector_cls__(value)
@property @property
def radius(self): def radius(self):
...@@ -153,21 +316,51 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -153,21 +316,51 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
@property @property
def perimeter(self): def perimeter(self):
return 2*pi * self._radius return 2*pi * self._radius
else:
return self._radius * self._domain.length
@property @property
def area(self): def area(self):
# Fixme: domain
return pi * self._radius**2 return pi * self._radius**2
def point_at_angle(self, angle): def point_at_angle(self, angle):
return Vector2D.from_polar(self._radius, angle) + self._center return self.__vector_cls__.from_polar(self._radius, angle) + self._center
def point_in_circle_frame(self, point):
return point - self._center
def angle_for_point(self, point):
offset = self.point_in_circle_frame(point)
# distance = offset.magnitude_square
# if not epsilon_float(distance, self._radius**2):
# raise PointNotOnCircleError # ValueError('Point is not on circle')
# Fixme:
orientation = offset.orientation
if orientation < 0:
orientation = 360 + orientation
return orientation
def point_at_distance(self, distance):
angle = math.degrees(distance / self._radius)
def tangent_at_angle(self, angle): def tangent_at_angle(self, angle):
point = Vector2D.from_polar(self._radius, angle) + self._center point = self.__vector_cls__.from_polar(self._radius, angle) + self._center
tangent = (point - self._center).normal tangent = (point - self._center).normal
return Line2D(point, tangent) return Line2D(point, tangent)
...@@ -175,10 +368,43 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -175,10 +368,43 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
@property @property
def bounding_box(self): def bounding_box(self):
# Fixme: wrong for arc
return self._center.bounding_box.enlarge(self._radius) return self._center.bounding_box.enlarge(self._radius)
def signed_distance_to_point(self, point):
# d = |P - C| - R
# < 0 if inside
# = 0 on circle
# > 0 if outside
return (point - self._center).magnitude - self._radius
def _circle_distance_to_point(self, point):
return abs(self.signed_distance_to_point(point))
# Fixme: check !!!
# try:
angle = self.angle_for_point(point)
# print('distance_to_circle', point, angle)
if self._domain.is_inside(angle):
# print('point is inside')
return self._circle_distance_to_point(point)
# except PointNotOnCircleError:
# pass
# print('point is outside')
return min([(point - vertex).magnitude for vertex in (self.start_point, self.stop_point)])
else:
def is_point_inside(self, point): def is_point_inside(self, point):
return (point - self._center).magnitude_square <= self._radius**2 return (point - self._center).magnitude_square <= self._radius**2
...@@ -186,21 +412,35 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -186,21 +412,35 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
def intersect_segment(self, segment): def intersect_segment(self, segment):
# Fixme: check domain !!! r"""Compute the intersection of a circle and a segment.
# http://mathworld.wolfram.com/Circle-LineIntersection.html Reference
# Reference: Rhoad et al. 1984, p. 429
# Rhoad, R.; Milauskas, G.; and Whipple, R. Geometry for Enjoyment and Challenge,
# rev. ed. Evanston, IL: McDougal, Littell & Company, 1984.
# Definitions * http://mathworld.wolfram.com/Circle-LineIntersection.html
# dx = x1 - x0 * Rhoad et al. 1984, p. 429
# dy = y1 - y0 * Rhoad, R.; Milauskas, G.; and Whipple, R. Geometry for Enjoyment and Challenge,
# D = x0 * y1 - x1 * y0 * rev. ed. Evanston, IL: McDougal, Littell & Company, 1984.
# Equations System of equations
# x**2 + y**2 = r**2
# dx * y = dy * x - D .. math::
\begin{split}
x^2 + y^2 = r^2 \\
dx \times y = dy \times x - D
\end{split}
where
.. math::
\begin{align}
dx &= x1 - x0 \\
dy &= y1 - y0 \\
D &= x0 \times y1 - x1 \times y0
\end{align}
dx = segment.vector.x dx = segment.vector.x
dy = segment.vector.y dy = segment.vector.y
...@@ -217,6 +457,7 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -217,6 +457,7 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
# solution = nonlinsolve(system, vars) # solution = nonlinsolve(system, vars)
# solution.subs(dx**2 + dy**2, dr**2) # solution.subs(dx**2 + dy**2, dr**2)
Vector2D = self.__vector_cls__
discriminant = self.radius**2 * dr2 - D**2 discriminant = self.radius**2 * dr2 - D**2
if discriminant < 0: if discriminant < 0:
...@@ -325,19 +566,53 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -325,19 +566,53 @@ class Circle2D(Primitive2DMixin, DomainMixin, Primitive):
class Conic2D(Primitive2DMixin, DomainMixin, Primitive): class Ellipse2D(Primitive2DMixin, AngularDomainMixin, Primitive):
r"""Class to implements 2D Ellipse.
A general ellipse in 2D is represented by a center point `C`, an orthonormal set of
axis-direction vectors :math:`{U_0 , U_1 }`, and associated extents :math:`e_i` with :math:`e_0
\ge e_1 > 0`. The ellipse points are
"""Class to implements 2D Conic.""" .. math::
P = C + x_0 U_0 + x_1 U_1
where
.. math::
\left(\frac{x_0}{e_0}\right)^2 + \left(\frac{x_1}{e_1}\right)^2 = 1
If :math:`e_0 = e_1`, then the ellipse is a circle with center `C` and radius :math:`e_0`. The
orthonormality of the axis directions and Equation (1) imply :math:`x_i = U_i \dot (P −
C)`. Substituting this into Equation (2) we obtain
.. math::
(P − C)^T M (P − C) = 1
where :math:`M = R D R^T`, `R` is an orthogonal matrix whose columns are :math:`U_0` and
:math:`U_1` , and `D` is a diagonal matrix whose diagonal entries are :math:`1/e_0^2` and
:math:`1/e_1^2`.
def __init__(self, center, x_radius, y_radius, angle, domain=None): def __init__(self, center, x_radius, y_radius, angle, domain=None):
self._x_radius = x_radius self.x_radius = x_radius
self._y_radius = y_radius self.y_radius = y_radius
self._angle = angle self.angle = angle
self.domain = Interval(domain) self.domain = domain
self._bounding_box = None
def __repr__(self):
return '{0}({1._center}, {1._x_radius}, {1._x_radius}, {1._angle})'.format(self.__class__.__name__, self)
...@@ -347,7 +622,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -347,7 +622,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive):
@property @property
def x_radius(self): def x_radius(self):
...@@ -355,7 +630,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -355,7 +630,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive):
@x_radius.setter @x_radius.setter
def x_radius(self, value): def x_radius(self, value):
self._x_radius = value self._x_radius = float(value)
@property @property
def y_radius(self): def y_radius(self):
...@@ -363,7 +638,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -363,7 +638,7 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive):
@y_radius.setter @y_radius.setter
def y_radius(self, value): def y_radius(self, value):
self._y_radius = value self._y_radius = float(value)
@property @property
def angle(self): def angle(self):
...@@ -371,7 +646,17 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -371,7 +646,17 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive):
@angle.setter @angle.setter
def angle(self, value): def angle(self, value):
self._angle = value self._angle = float(value)
@property
def major_vector(self):
# Fixme: x < y
return self.__vector_cls__.from_polar(self._angle, self._x_radius)
@property
def minor_vector(self):
# Fixme: x < y
return self.__vector_cls__.from_polar(self._angle + 90, self._y_radius)
...@@ -411,33 +696,213 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive): ...@@ -411,33 +696,213 @@ class Conic2D(Primitive2DMixin, DomainMixin, Primitive):
E = -B*xc - 2*C*yc E = -B*xc - 2*C*yc
F = A*xc2 + B*xc*yc + C*yc2 - a2*b2 F = A*xc2 + B*xc*yc + C*yc2 - a2*b2
return np.array((( A, B/2, D/2), return np.array((
( A, B/2, D/2),
(B/2, C, E/2), (B/2, C, E/2),
(D/2, E/2, F), (D/2, E/2, F),
def point_in_ellipse_frame(self, point):
return (point - self._center).rotate(-self._angle)
def point_from_ellipse_frame(self, point):
return self._center + point.rotate(self._angle)
raise NotImplementedError # point = self.__vector_cls__.from_ellipse(self._x_radius, self._y_radius, angle)
# return self.point_from_ellipse_frame(point)
point = self.__vector_cls__.from_ellipse(self._x_radius, self._y_radius, self._angle + angle)
@property @property
if self._bounding_box is None:
x_radius, y_radius = self._x_radius, self._y_radius
if self._angle == 0:
bounding_box = self._center.bounding_box
bounding_box.x.enlarge(x_radius)
bounding_box.y.enlarge(y_radius)
self._bounding_box = bounding_box
else:
angle_x = self._angle
angle_y = angle_x + 90
points = [self._center + offset for offset in (
Vector2D.from_polar(angle_x, x_radius),
Vector2D.from_polar(angle_x, -x_radius),
Vector2D.from_polar(angle_y, y_radius),
Vector2D.from_polar(angle_y, -y_radius),
self._bounding_box = bounding_box_from_points(points)
return self._bounding_box
@staticmethod
def _robust_length(x, y):
if x < y:
x, y = y, x
return abs(x) * math.sqrt(1 + (y/x)**2)
def _distance_point_bisection(self, r0, z0, z1, g):
n0 = r0 * z0
s0 = z1 - 1
if g < 0:
s1 = 0
else:
s1 = self._robust_length(n0 , z1) - 1
s = 0
MAX_ITERATION = 1074 # for double
for i in range(MAX_ITERATION):
s = (s0 + s1) / 2
if s == s0 or s == s1:
break
ratio0 = n0 / (s + r0)
ratio1 = z1 / (s + 1)
g = ratio0**2 + ratio1**2 -1
if g > 0:
s0 = s
elif g < 0:
s1 = s
else:
break
return s
def _eberly_distance(self, point):
"""Compute distance to point using the algorithm described in
Distance from a Point to an Ellipse, an Ellipsoid, or a Hyperellipsoid
David Eberly, Geometric Tools, Redmond WA 98052
September 28, 2018
https://www.geometrictools.com/Documentation/Documentation.html
https://www.geometrictools.com/Documentation/DistancePointEllipseEllipsoid.pdf
The point is expressed in the ellipse coordinate system.
The preconditions are e0 ≥ e1 > 0, y0 ≥ 0, and y1 ≥ 0.
# Fixme: make a 3D plot to check the algorithm on a 2D grid and rotated ellipse
y0, y1 = point
e0, e1 = self._x_radius, self._y_radius
if y1 > 0:
if y0 > 0:
z0 = y0 / e0
z1 = y1 / e1
g = z0**2 + z1**2 - 1
if g != 0:
r0 = (e0 / e1)**2
sbar = self._distance_point_bisection(r0, z0, z1, g)
x0 = r0 * y0 / (sbar + r0)
x1 = y1 / (sbar + 1)
distance = math.sqrt((x0 - y0)**2 + (x1 - y1)**2)
else:
x0 = y0
x1 = y1
distance = 0
else:
# y0 == 0
x0 = 0
x1 = e1
distance = abs(y1 - e1)
else:
# y1 == 0
numer0 = e0 * y0
denom0 = e0**2 - e1**2
if numer0 < denom0:
xde0 = numer0 / denom0
x0 = e0 * xde0
x1 = e1 * math.sqrt(1 - xde0**2)
distance = math.sqrt((x0 - y0)**2 + x1**2)
else:
x0 = e0
x1 = 0
distance = abs(y0 - e0)
return distance, self.__vector_cls__(x0, x1)
def distance_to_point(self, point, return_point=False, is_inside=False):
# Fixme: can be transform the problem to a circle using transformation ???
point_in_frame = self.point_in_ellipse_frame(point)
point_in_frame_abs = self.__vector_cls__(abs(point_in_frame.x), abs(point_in_frame.y))
distance, point_in_ellipse = self._eberly_distance(point_in_frame_abs)
if is_inside:
# Fixme: right ???
return (
(point_in_frame_abs - self._center).magnitude_square
(point_in_ellipse - self._center).magnitude_square
elif return_point:
point_in_ellipse = self.__vector_cls__(
sign(point_in_frame.x)*(point_in_ellipse.x),
sign(point_in_frame.y)*(point_in_ellipse.y),
point_in_ellipse = self.point_from_ellipse_frame(point_in_ellipse)
return distance, point_in_ellipse
else:
return distance
raise NotImplementedError return self.distance_to_point(point, is_inside=True)
# Fixme: to be checked
# Map segment in ellipse frame and scale y axis so as to transform the ellipse to a circle
y_scale = self._x_radius / self._y_radius
points = [self.point_in_ellipse_frame(point) for point in segment.points]
points = [self.__vector_cls__(point.x, point.y * y_scale) for point in points]
segment_in_frame = Segment2D(*points)
circle = Circle2D(self.__vector_cls__(0, 0), self._x_radius)
points = circle.intersect_segment(segment_in_frame)
points = [self.__vector_cls__(point.x, point.y / y_scale) for point in points]
points = [self.point_from_ellipse_frame(point) for point in points]
return points
def intersect_conic(self, conic): def intersect_conic(self, conic):
Reference
* Intersection of Ellipses
* David Eberly, Geometric Tools, Redmond WA 98052
* June 23, 2015
* https://www.geometrictools.com/
* https://www.geometrictools.com/Documentation/IntersectionOfEllipses.pdf
...@@ -58,13 +58,13 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -58,13 +58,13 @@ class Line2D(Primitive2DMixin, Primitive):
def __str__(self): def __str__(self):
text = '''Line str_format = '''Line
Point %s Point {0.p}
Vector %s Vector {0.v}
magnitude %g magnitude {1}
return text % (str(self.p), str(self.v), self.v.magnitude()) return str_format.format(self, self.v.magnitude)
...@@ -230,10 +230,12 @@ class Line2D(Primitive2DMixin, Primitive): ...@@ -230,10 +230,12 @@ class Line2D(Primitive2DMixin, Primitive):
"""Return the distance of a point to the line""" """Return the distance of a point to the line"""
delta = point - self.p delta = point - self.p
if delta.magnitude_square == 0:
return 0, 0
else:
d = delta.deviation_with(self.v) d = delta.deviation_with(self.v)
s = delta.projection_on(self.v) s = delta.projection_on(self.v)
return d, s # distance to line, abscissa
return (d, s) # distance to line, abscissa
# Patro - A Python library to make patterns for fashion design
# Copyright (C) 2019 Fabrice Salvaire
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
__all__ = [
'LinearSegment',
'QuadraticBezierSegment',
'CubicBezierSegment',
'Path2D',
import math
from .Primitive import Primitive1P, Primitive2DMixin
from .Bezier import QuadraticBezier2D, CubicBezier2D
from .Conic import Circle2D, AngularDomain
class PathPart:
def __init__(self, path, position):
self._path = path
self._position = position
def __repr__(self):
@property
def path(self):
return self._path
@property
def position(self):
return self._position
@position.setter
def position(self, value):
self._position = int(value)
@property
def prev_part(self):
return self._path[self._position -1]
@property
def next_part(self):
return self._path[self._position +1]
@property
def start_point(self):
prev_part = self.prev_part
if prev_part is not None:
return prev_part.stop_point
else:
return self._path.p0
@property
@property
def geometry(self):
@property
return self.geometry.bounding_box
class LinearSegment(PathPart):
r"""
Bulge
Let `P0`, `P1`, `P2` the vertices and `R` the bulge radius.
The deflection :math:`\theta = 2 \alpha` at the corner is
.. math::
D_1 \cdot D_0 = (P_2 - P_1) \cdot (P_1 - P_0) = \cos \theta
The bisector direction is
.. math::
Bis = D_1 - D_0 = (P_2 - P_1) - (P_1 - P_0) = P_2 -2 P_1 + P_0
Bulge Center is
.. math::
C = P_1 + Bis \times \frac{R}{\sin \alpha}
Extremities are
\prime P_1 = P_1 - d_0 \times \frac{R}{\tan \alpha}
\prime P_1 = P_1 + d_1 \times \frac{R}{\tan \alpha}
def __init__(self, path, position, radius):
super().__init__(path, position)
self._bissector = None
self._direction = None
self.radius = radius
if self._radius is not None:
if not isinstance(self.prev_part, LinearSegment):
raise ValueError('Previous path segment must be linear')
self._bulge_angle = None
self._bulge_center = None
self._start_bulge_point = None
self._stop_bulge_point = None
@property
def points(self):
start_point = self.bulge_stop_point
else:
start_point = self.start_point
next_part = self.next_part
if isinstance(next_part, LinearSegment) and next_part.radius is not None:
stop_point = next_part.bulge_start_point
else:
stop_point = self.stop_point
return start_point, stop_point
@property
def radius(self):
return self._radius
@radius.setter
def radius(self, value):
self._radius = float(value)
else:
self._radius = None
@property
def direction(self):
if self._direction is None:
self._direction = (self.stop_point - self.start_point).normalise()
return self._direction
@property
def bissector(self):
if self._radius is None:
return None
else:
if self._bissector is None:
# self._bissector = (self.prev_part.direction + self.direction).normalise().normal
self._bissector = (self.direction - self.prev_part.direction).normalise()
return self._bissector
@property
def bulge_angle_rad(self):
if self._bulge_angle is None:
angle = self.direction.orientation_with(self.prev_part.direction)
self._bulge_angle = math.radians(angle)
return self._bulge_angle
@property
def bulge_angle(self):
return math.degrees(self.bulge_angle_rad)
@property
def half_bulge_angle(self):
return abs(self.bulge_angle_rad / 2)
@property
def bulge_center(self):
if self._bulge_center is None:
offset = self.bissector * self._radius / math.sin(self.half_bulge_angle)
self._bulge_center = self.start_point + offset
return self._bulge_center
@property
def bulge_start_point(self):
if self._start_bulge_point is None:
offset = self.prev_part.direction * self._radius / math.tan(self.half_bulge_angle)
self._start_bulge_point = self.start_point - offset
return self._start_bulge_point
@property
def bulge_stop_point(self):
if self._stop_bulge_point is None:
offset = self.direction * self._radius / math.tan(self.half_bulge_angle)
self._stop_bulge_point = self.start_point + offset
return self._stop_bulge_point
@property
def bulge_geometry(self):
# Fixme: check start and stop are within segment
arc = Circle2D(self.bulge_center, self._radius)
start_angle, stop_angle = [arc.angle_for_point(point)
for point in (self.bulge_start_point, self.bulge_stop_point)]
if self.bulge_angle < 0:
start_angle, stop_angle = stop_angle, start_angle
arc.domain = AngularDomain(start_angle, stop_angle)
return arc
class PathSegment(LinearSegment):
def __init__(self, path, position, point, radius=None, absolute=False):
super().__init__(path, position, radius)
self.point = point
self._absolute = bool(absolute)
@property
def point(self):
return self._point
@point.setter
def point(self, value):
self._point = Vector2D(value) # self._path.__vector_cls__
@property
if self._absolute:
return self._point
else:
return self._point + self.start_point
@property
def geometry(self):
# Fixme: cache ???
return Segment2D(*self.points)
class DirectionalSegment(LinearSegment):
__angle__ = None
def __init__(self, path, position, length, radius=None):
self.length = length
@property
def length(self):
return self._length
@length.setter
def length(self, value):
self._length = float(value)
@property
# Fixme: cache ???
return self.start_point + Vector2D.from_polar(self._length, self.__angle__)
@property
def geometry(self):
# Fixme: cache ???
return Segment2D(self.start_point, self.stop_point)
class HorizontalSegment(DirectionalSegment):
__angle__ = 0
class VerticalSegment(DirectionalSegment):
__angle__ = 90
class NorthSegment(DirectionalSegment):
__angle__ = 90
class SouthSegment(DirectionalSegment):
__angle__ = -90
class EastSegment(DirectionalSegment):
__angle__ = 0
class WestSegment(DirectionalSegment):
__angle__ = 180
class NorthEastSegment(DirectionalSegment):
__angle__ = 45
class NorthWestSegment(DirectionalSegment):
__angle__ = 180 - 45
class SouthEastSegment(DirectionalSegment):
__angle__ = -45
class SouthWestSegment(DirectionalSegment):
__angle__ = -180 + 45
class TwoPointsMixin:
@property
def point1(self):
return self._point1
@point1.setter
def point1(self, value):
self._point1 = Vector2D(value) # self._path.__vector_cls__
@property
def point2(self):
return self._point2
@point2.setter
def point2(self, value):
self._point2 = Vector2D(value)
class QuadraticBezierSegment(PathPart, TwoPointsMixin):
# Fixme: abs / inc
def __init__(self, path, position, point1, point2):
PathPart.__init__(self, path, position)
self.point1 = point1
self.point2 = point2
@property
return self._point2
@property
def points(self):
return (self.start_point, self._point1, self._point2)
@property
def geometry(self):
# Fixme: cache ???
return QuadraticBezier2D(self.start_point, self._point1, self._point2)
class CubicBezierSegment(PathPart, TwoPointsMixin):
def __init__(self, path, position, point1, point2, point3):
self.point3 = point3
@property
def point3(self):
return self._point3
@point3.setter
def point3(self, value):
self._point3 = Vector2D(value) # self._path.__vector_cls__
@property
return self._point3
@property
def points(self):
return (self.start_point, self._point1, self._point2, self._point3)
@property
def geometry(self):
# Fixme: cache ???
return CubicBezier2D(self.start_point, self._point1, self._point2, self._point3)
class Path2D(Primitive2DMixin, Primitive1P):
"""Class to implements 2D Path."""
def __init__(self, start_point):
Primitive1P.__init__(self, start_point)
self._parts = []
def __len__(self):
return len(self._parts)
def __iter__(self):
return iter(self._parts)
def __getitem__(self, position):
# try:
# return self._parts[slice_]
# except IndexError:
# return None
position = int(position)
if 0 <= position < len(self._parts):
return self._parts[position]
else:
return None
def _add_part(self, part_cls, *args, **kwargs):
obj = part_cls(self, len(self._parts), *args, **kwargs)
self._parts.append(obj)
return obj
def move_to(self, point):
self.p0 = point
def horizontal_to(self, distance, radius=None):
return self._add_part(HorizontalSegment, distance, radius)
def vertical_to(self, distance, radius=None):
return self._add_part(VerticalSegment, distance, radius)
def north_to(self, distance, radius=None):
return self._add_part(NorthSegment, distance, radius)
def south_to(self, distance, radius=None):
return self._add_part(SouthSegment, distance, radius)
def west_to(self, distance, radius=None):
return self._add_part(WestSegment, distance, radius)
def east_to(self, distance, radius=None):
return self._add_part(EastSegment, distance, radius)
def north_east_to(self, distance, radius=None):
return self._add_part(NorthEastSegment, distance, radius)
def south_east_to(self, distance, radius=None):
return self._add_part(SouthEastSegment, distance, radius)
def north_west_to(self, distance, radius=None):
return self._add_part(NorthWestSegment, distance, radius)
def south_west_to(self, distance, radius=None):
return self._add_part(SouthWestSegment, distance, radius)
def line_to(self, point, radius=None):
return self._add_part(PathSegment, point, radius)
def close(self, radius=None):
# Fixme: radius must apply to start and stop
return self._add_part(PathSegment, self._p0, radius, absolute=True)
def quadratic_to(self, point1, point2):
return self._add_part(QuadraticBezierSegment, point1, point2)
def cubic_to(self, point1, point2, point3):
return self._add_part(CubicBezierSegment, point1, point2, point3)
