Skip to content
# Patro - A Python library to make patterns for fashion design
# Copyright (C) 2017 Fabrice Salvaire
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
from .Primitive import PrimitiveNP, Primitive2DMixin
from .Segment import Segment2D
class Polyline2D(Primitive2DMixin, PrimitiveNP):
"""Class to implements 2D Polyline."""
def __init__(self, *points):
if len(points) < 2:
raise ValueError('Polyline require at least 2 vertexes')
PrimitiveNP.__init__(self, points)
self._edges = None
@property
def edges(self):
if self._edges is None:
self._edges = [Segment2D(self._points[i], self._points[i+1])
for i in range(self.number_of_points -1)]
return iter(self._edges)
@property
def length(self):
return sum([edge.magnitude for edge in self.edges])
def distance_to_point(self, point):
distance = None
for edge in self.edges:
edge_distance = edge.distance_to_point(point)
if distance is None or edge_distance < distance:
distance = edge_distance
return distance
...@@ -31,6 +31,8 @@ __all__ = [ ...@@ -31,6 +31,8 @@ __all__ = [
import collections import collections
import numpy as np
from .BoundingBox import bounding_box_from_points from .BoundingBox import bounding_box_from_points
...@@ -143,6 +145,18 @@ class Primitive: ...@@ -143,6 +145,18 @@ class Primitive:
self._set_points([transformation*p for p in self.points]) self._set_points([transformation*p for p in self.points])
@property
def geometry_matrix(self):
return np.array(list(self.points)).transpose()
def is_close(self, other):
# Fixme: verus is_closed
return np.allclose(self.geometry_matrix, other.geometry_matrix)
class Primitive2DMixin: class Primitive2DMixin:
...@@ -386,12 +400,19 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin): ...@@ -386,12 +400,19 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin):
def __init__(self, *points): @staticmethod
def handle_points(points):
if len(points) == 1 and isinstance(points[0], collections.Iterable): if len(points) == 1 and isinstance(points[0], collections.Iterable):
points = points[0] points = points[0]
return points
points = self.handle_points(points)
self._points = [self.__vector_cls__(p) for p in points] self._points = [self.__vector_cls__(p) for p in points]
self._point_array = None
...@@ -421,10 +442,29 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin): ...@@ -421,10 +442,29 @@ class PrimitiveNP(Primitive, ReversiblePrimitiveMixin):
@property
def point_array(self):
if self._point_array is None:
self._point_array = np.array([point for point in self._points])
return self._point_array
def _set_points(self, points): def _set_points(self, points):
self._points = points self._points = points
def __getitem__(self, _slice): def __getitem__(self, _slice):
return self._points[_slice] return self._points[_slice]
def iter_on_nuplets(self, size):
if size > self.number_of_points:
raise ValueError('size {} > number of points {}'.format(size, self.number_of_points))
for i in range(self.number_of_points - size +1):
yield self._points[i:i+size]
...@@ -108,3 +108,8 @@ class Rectangle2D(Primitive2DMixin, Primitive2P): ...@@ -108,3 +108,8 @@ class Rectangle2D(Primitive2DMixin, Primitive2P):
bounding_box = self.bounding_box bounding_box = self.bounding_box
return (point.x in bounding_box.x and return (point.x in bounding_box.x and
point.y in bounding_box.y) point.y in bounding_box.y)
raise NotImplementedError
...@@ -50,12 +50,12 @@ class Segment2D(Primitive2DMixin, Primitive2P): ...@@ -50,12 +50,12 @@ class Segment2D(Primitive2DMixin, Primitive2P):
@property @property
def length(self): def length(self):
return self.vector.magnitude() return self.vector.magnitude
@property @property
def center(self): def center(self):
# midpoint, barycenter # midpoint, barycenter
return (self._p0 * self._p1) / 2 return (self._p0 + self._p1) / 2
...@@ -67,6 +67,7 @@ class Segment2D(Primitive2DMixin, Primitive2P): ...@@ -67,6 +67,7 @@ class Segment2D(Primitive2DMixin, Primitive2P):
def to_line(self): def to_line(self):
# Fixme: cache
return Line2D.from_two_points(self._p1, self._p0) return Line2D.from_two_points(self._p1, self._p0)
...@@ -160,3 +161,22 @@ class Segment2D(Primitive2DMixin, Primitive2P): ...@@ -160,3 +161,22 @@ class Segment2D(Primitive2DMixin, Primitive2P):
def is_collinear(self, point): def is_collinear(self, point):
"""Tests if a point is on line""" """Tests if a point is on line"""
return self.side_of(point) == 0 return self.side_of(point) == 0
line = self.to_line()
if line.v.magnitude_square == 0:
return (self._p0 - point).magnitude
d, s = line.distance_and_abscissa_to_line(point)
if 0 <= s <= self.length:
return abs(d)
else:
if s < 0:
p = self._p0
else:
p = self._p1
return (p - point).magnitude
This diff is collapsed.
...@@ -238,6 +238,8 @@ class Vector2DFloatBase(Vector2DBase): ...@@ -238,6 +238,8 @@ class Vector2DFloatBase(Vector2DBase):
@property @property
def magnitude(self): def magnitude(self):
"""Return the magnitude of the vector""" """Return the magnitude of the vector"""
# Note: To avoid float overflow use
# abs(x) * sqrt(1 + (y/x)**2) if x > y
return math.sqrt(self.magnitude_square) return math.sqrt(self.magnitude_square)
...@@ -463,6 +465,19 @@ class Vector2D(Vector2DFloatBase): ...@@ -463,6 +465,19 @@ class Vector2D(Vector2DFloatBase):
@staticmethod
def from_ellipse(x_radius, y_radius, angle):
"""Create the vector (x_radius*cos(angle), y_radius*sin(angle)). *angle* is in degree."""
angle = math.radians(angle)
x = x_radius * cos(angle)
y = y_radius * sin(angle)
return Vector2D(x, y) # Fixme: classmethod
@staticmethod @staticmethod
def middle(p0, p1): def middle(p0, p1):
"""Return the middle point.""" """Return the middle point."""
...@@ -499,6 +514,7 @@ class Vector2D(Vector2DFloatBase): ...@@ -499,6 +514,7 @@ class Vector2D(Vector2DFloatBase):
def normalise(self): def normalise(self):
"""Normalise the vector""" """Normalise the vector"""
self._v /= self.magnitude self._v /= self.magnitude
return self
...@@ -18,8 +18,35 @@ ...@@ -18,8 +18,35 @@
"""This module implements a 2D geometry engine suitable for a low number of graphic entities. It """This module implements a 2D geometry engine which implement standard primitives like line, conic
implements standard primitives like line, segment and Bezier curve. and Bézier curve.
.. note:: This module is a candidate for a dedicated project.
Purpose
The purpose of this module is to provide all the required algorithms in Python language for a 2D
geometry engine. In particular it must avoid the use of a third-party libraries which could be over
sized for our purpose and challenging to trust.
It is not designed to provide optimised algorithms for a large number of graphic entities. Such
optimisations could be provided in addition, in particular if the Python implementation has dramatic
performances.
Bibliographical References
All complex algorithms in this module should have strong references matching theses criteria by
preference order:
* a citation to an article from a well known peer reviewed journal,
* a citation to a reference book authored by a well known author,
* a well written article which can be easily trusted ( in this case an electronic copy of this
article should be added to the repository).
However a Wikipedia article will usually not fulfils the criteria due to the weakness of this
collaborative encyclopedia: article quality, review process, content modification over time.
...@@ -18,12 +18,25 @@ ...@@ -18,12 +18,25 @@
"""Module to implement a graphic scene.
__class__ = ['GraphicScene']
import logging import logging
import rtree
from Patro.GeometryEngine.Transformation import AffineTransformation2D from Patro.GeometryEngine.Transformation import AffineTransformation2D
from .GraphicItem import CoordinateItem, TextItem, CircleItem, SegmentItem, CubicBezierItem from Patro.GeometryEngine.Vector import Vector2D
from . import GraphicItem
...@@ -33,6 +46,21 @@ _module_logger = logging.getLogger(__name__) ...@@ -33,6 +46,21 @@ _module_logger = logging.getLogger(__name__)
class GraphicSceneScope: class GraphicSceneScope:
"""Class to implement a graphic scene."""
__ITEM_CTOR__ = {
'circle': GraphicItem.CircleItem,
'cubic_bezier': GraphicItem.CubicBezierItem,
'ellipse': GraphicItem.EllipseItem,
'image': GraphicItem.ImageItem,
# 'path': GraphicItem.PathItem,
# 'polygon': GraphicItem.PolygonItem,
'rectangle': GraphicItem.RectangleItem,
'segment': GraphicItem.SegmentItem,
'polyline': GraphicItem.PolylineItem,
'text': GraphicItem.TextItem,
def __init__(self, transformation=None): def __init__(self, transformation=None):
...@@ -40,7 +68,15 @@ class GraphicSceneScope: ...@@ -40,7 +68,15 @@ class GraphicSceneScope:
if transformation is None: if transformation is None:
transformation = AffineTransformation2D.Identity() transformation = AffineTransformation2D.Identity()
self._transformation = transformation self._transformation = transformation
self._items = []
self._coordinates = {}
self._items = {} # id(item) -> item, e.g. for rtree query
self._user_data_map = {}
self._rtree = rtree.index.Index()
# item_id -> bounding_box, used to delete item in rtree (cf. rtree api)
self._item_bounding_box_cache = {}
...@@ -48,90 +84,219 @@ class GraphicSceneScope: ...@@ -48,90 +84,219 @@ class GraphicSceneScope:
def transformation(self): def transformation(self):
return self._transformation return self._transformation
# @transformation.setter
# def transformation(self, value):
# self._transformation = value
def __iter__(self): def __iter__(self):
return iter(self._items) # must be an ordered item list
return iter(self._items.values())
def _add_item(self, cls, *args, **kwargs): def z_value_iter(self):
# Fixme: cache ???
# Group by z_value and keep inserting order
z_map = {}
for item in self._items.values():
if item.visible:
items = z_map.setdefault(item.z_value, [])
items.append(item)
for z_value in sorted(z_map.keys()):
for item in z_map[z_value]:
yield item
item = cls(*args, **kwargs) @property
self._items.append(item) def selected_items(self):
# Fixme: cache ?
return [item for item in self._items.values() if item.selected]
def unselect_items(self):
for item in self.selected_items:
item.selected = False
def add_coordinate(self, name, position):
item = CoordinateItem(name, position)
self._coordinates[name] = item
return item return item
def add_scope(self, *args, **kwargs): def remove_coordinate(self, name):
return self._add_item(GraphicSceneScope, self, *args, **kwargs) del self._coordinates[name]
def add_coordinate(self, *args, **kwargs): ##############################################
return self._add_item(CoordinateItem, *args, **kwargs)
def add_text(self, *args, **kwargs): def coordinate(self, name):
return self._add_item(TextItem, *args, **kwargs) return self._coordinates[name]
def add_segment(self, *args, **kwargs): ##############################################
return self._add_item(SegmentItem, *args, **kwargs)
def add_circle(self, *args, **kwargs): def cast_position(self, position):
return self._add_item(CircleItem, *args, **kwargs)
def add_cubic_bezier(self, *args, **kwargs): """Cast coordinate and apply scope transformation, *position* can be a coordinate name string of a
return self._add_item(CubicBezierItem, *args, **kwargs) :class:`Patro.GeometryEngine.Vector.Vector2D`.
class GraphicScene: # Fixme: cache ?
if isinstance(position, str):
vector = self._coordinates[position].position
elif isinstance(position, Vector2D):
vector = position
return self._transformation * vector
def __init__(self): def add_item(self, cls, *args, **kwargs):
item = cls(self, *args, **kwargs)
# print(item, item.user_data, hash(item))
# if item in self._items:
# print('Warning duplicate', item.user_data)
# Fixme: root scope ??? item_id = id(item) # Fixme: hash ???
self._root_scope = GraphicSceneScope() self._items[item_id] = item
# Fixme: don't want to reimplement bounding box for graphic item
# - solution 1 : pass geometric object user_data = item.user_data
# but we want to use named coordinate -> Coordinate union of Vector2D or name if user_data is not None:
# - solution 2 : item -> geometric object -> bounding box user_data_id = id(user_data) # Fixme: hash ???
# need to convert coordinate to vector2d items = self._user_data_map.setdefault(user_data_id, [])
self._bounding_box = None items.append(item)
return item
@property def remove_item(self, item):
def root_scope(self):
return self._root_scope
@property self.update_rtree(item, insert=False)
def bounding_box(self):
return self._bounding_box items = self.item_for_user_data(item.user_data)
if items:
items.remove(item)
del self._items[item]
def item_for_user_data(self, user_data):
return self._user_data_map.get(user_data_id, None)
def update_rtree(self):
if item.dirty:
self.update_rtree_item(item)
def update_rtree_item(self, item, insert=True):
item_id = id(item)
old_bounding_box = self._item_bounding_box_cache.pop(item_id, None)
if old_bounding_box is not None:
self._rtree.delete(item_id, old_bounding_box)
if insert:
# try:
bounding_box = item.bounding_box.bounding_box # Fixme: name
# print(item, bounding_box)
self._rtree.insert(item_id, bounding_box)
self._item_bounding_box_cache[item_id] = bounding_box
# except AttributeError:
# print('bounding_box not implemented for', item)
# pass # Fixme:
@bounding_box.setter def item_in_bounding_box(self, bounding_box):
def bounding_box(self, value):
self._bounding_box = value # Fixme: Interval2D ok ?
# print('item_in_bounding_box', bounding_box)
item_ids = self._rtree.intersection(bounding_box)
if item_ids:
return [self._items[item_id] for item_id in item_ids]
else:
return None
def item_at(self, position, radius):
x, y = list(position)
bounding_box = (
x - radius, y - radius,
x + radius, y + radius,
items = []
for item in self.item_in_bounding_box(bounding_box):
try: # Fixme
distance = item.distance_to_point(position)
# print('distance_to_point {:6.2f} {}'.format(distance, item))
if distance <= radius:
items.append((distance, item))
except NotImplementedError:
pass
return sorted(items, key=lambda pair: pair[0])
def add_scope(self, *args, **kwargs): # Fixme: !!!
return self._root_scope.add_scope(*args, **kwargs) # def add_scope(self, *args, **kwargs):
# return self.add_item(GraphicSceneScope, self, *args, **kwargs)
def bezier_path(self, points, degree, *args, **kwargs):
if degree == 1:
method = self.segment
elif degree == 2:
method = self.quadratic_bezier
elif degree == 3:
method = self.cubic_bezier
else:
raise ValueError('Unsupported degree for Bezier curve: {}'.format(degree))
def add_coordinate(self, *args, **kwargs): # Fixme: generic code
return self._root_scope.add_coordinate(*args, **kwargs)
def add_text(self, *args, **kwargs): number_of_points = len(points)
return self._root_scope.add_text(*args, **kwargs) n = number_of_points -1
if n % degree:
raise ValueError('Wrong number of points for Bezier {} curve: {}'.format(degree, number_of_points))
def add_circle(self, *args, **kwargs): items = []
return self._root_scope.add_circle(*args, **kwargs) for i in range(number_of_points // degree):
j = degree * i
k = j + degree
item = method(*points[j:k+1], *args, **kwargs)
items.append(item)
def add_segment(self, *args, **kwargs): return items
return self._root_scope.add_segment(*args, **kwargs)
# Register a method in GraphicSceneScope class for each type of graphic item
def _make_add_item_wrapper(cls):
def wrapper(self, *args, **kwargs):
return self.add_item(cls, *args, **kwargs)
return wrapper
for name, cls in GraphicSceneScope.__ITEM_CTOR__.items():
setattr(GraphicSceneScope, name, _make_add_item_wrapper(cls))
def add_cubic_bezier(self, *args, **kwargs): class GraphicScene(GraphicSceneScope):
return self._root_scope.add_cubic_bezier(*args, **kwargs) """Class to implement a graphic scene."""
pass
# Copyright (C) 2019 Fabrice Salvaire
"""This module implements a 2D graphic engine as a scene rendered by a painter class.
A scene contains graphic items like text, image line, circle and Bézier curve. A painter class is
responsible to render the scene on the screen or a graphic file format.
These painters are available for screen rendering:
* Matplotlib : :mod:`Patro.GraphicEngine.Painter.MplPainter`
* Qt : :mod:`Patro.GraphicEngine.Painter.QtPainter`
These painters are available for graphic file format:
* DXF : :mod:`Patro.GraphicEngine.Painter.DxfPainter`
* LaTeX : :mod:`Patro.GraphicEngine.Painter.TexPainter`
* PDF : :mod:`Patro.GraphicEngine.Painter.PdfPainter`
* SVG : :mod:`Patro.GraphicEngine.Painter.SvgPainter`
