Skip to content
Commits on Source (15)
* Author : Victor Dubois
#include <ros.h>
#include <goal_strategy/servos_cmd.h>
#include <VarSpeedServo.h>
#define BRAK 0
#define BRAK_PIN 10//Todo check
#define PAVILLON 1
#define PAVILLON_PIN 11//Todo check
#define NB_SERVOS 2
ros::NodeHandle nh;
VarSpeedServo myServos[NB_SERVOS];
bool stopped = true;
void cmd_servos_cb(const goal_strategy::servos_cmd& command)
if (!command.enable) {
if (!stopped) {
for( int i = 0; i< NB_SERVOS; i++ ) {
myServos[i].detach();
stopped = true;
return;
if(stopped)
stopped = false;
myServos[BRAK].attach(BRAK_PIN);
myServos[PAVILLON].attach(PAVILLON_PIN);
myServos[BRAK].write(command.brak_speed, command.brak_angle, false);
myServos[PAVILLON].write(command.pavillon_speed, command.pavillon_angle, false);
ros::Subscriber<goal_strategy::servos_cmd> servos_cmd_sub("cmd_servos", cmd_servos_cb);
void setup()
pinMode(BRAK_PIN, OUTPUT);
pinMode(PAVILLON_PIN, OUTPUT);
nh.initNode();
nh.subscribe(servos_cmd_sub);
void loop()
nh.spinOnce();
delay(50);
...@@ -3,48 +3,215 @@ ...@@ -3,48 +3,215 @@
#include <ros.h> #include <ros.h>
#include <krabi_msgs/servos_cmd.h> #include <krabi_msgs/servo_cmd.h>
#include <VarSpeedServo.h> #include <krabi_msgs/actuators.h>
#include <krabi_msgs/vacuum_pump.h>
#include <std_msgs/Float32.h>
#include <Wire.h> #include <Wire.h>
#include <LiquidCrystal_I2C.h> #include <LiquidCrystal_I2C.h> // https://github.com/johnrickman/LiquidCrystal_I2C
#include <VarSpeedServo.h> // https://github.com/netlabtoolkit/VarSpeedServo
#define BASE_SERVO 0
#define BASE_SERVO_PIN 9
#define MID_SERVO 1
#define MID_SERVO_PIN 10
#define SUCTION_SERVO 2
#define SUCTION_SERVO_PIN 5
#define PUSHER_SERVO 3
#define PUSHER_SERVO_PIN 6
#define NB_SERVOS 4
// 3 J5
// 5 J6
// 6 J7
// 7 J18
// 13 J19
// 9 J8
// 10 J9
// 11 J10
#define SUCTION_CUP_PIN 8
#define VALVE_PIN 2
#define BRAK 0 #define SERVOMIN 150 // This is the 'minimum' pulse length count (out of 4096)
#define BRAK_PIN 9 #define SERVOMAX 600 // This is the 'maximum' pulse length count (out of 4096)
#define PAVILLON 1 #define USMIN 600 // This is the rounded 'minimum' microsecond length based on the minimum pulse of 150
#define PAVILLON_PIN 10 #define USMAX 2400 // This is the rounded 'maximum' microsecond length based on the maximum pulse of 600
#define TAPETTE_PHARE 2 #define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
#define TAPETTE_PHARE_PIN 11
#define NB_SERVOS 3
ros::NodeHandle nh; ros::NodeHandle nh;
bool stopped = true; bool stopped = true;
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
uint8_t current_score; uint8_t current_score;
krabi_msgs::actuators persistent_actuators_command;
std_msgs::Float32 vacuum_msg;
int16_t sent_servos_angles[NB_SERVOS];
uint8_t servo_pins[NB_SERVOS];
bool stopped_servos_last_update[NB_SERVOS];
VarSpeedServo myservos[NB_SERVOS];
pressure_range (kPa) K value
131<P≤260 32
65<P≤131 64
32<P≤65 128
16<P≤32 256
8<P≤16 512
4<P≤8 1024
2≤P≤4 2048
1≤P<2 4096
P<1 8192
#define K 512 // @TODO see table above to choose the correct value for your application
#define I2C_address 0x6D // Unfortunately, it does not seem possible to change it. To use multiple sensors, use the analog version (XGZP6897A)
void cmd_servos_cb(const krabi_msgs::servos_cmd& command)
double readPressure()
current_score = command.s4_speed;// hack to store the score unsigned char pressure_H, pressure_M, pressure_L, temperature_H, temperature_L;
if (!command.enable) { //temporary variables of pressure and temperature
if (!stopped) { long int pressure_adc, temperature_adc;
for( int i = 0; i< NB_SERVOS; i++ ) { //The value of pressure and temperature converted by the sensor’s ADC
myServos[i].detach(); double pressure, temperature;
//The calibrated value of pressure
write_one_byte(I2C_address, 0x30, 0x0A);
//indicate a combined conversion (once temperature conversion immediately followed by once sensor signal conversion)
//more measurement method, check Register 0x30
long timeout = 0;
while ((Read_One_Byte(I2C_address, 0x30) & 0x08) > 0)// && timeout < 65000)
timeout++;
if (timeout > 5000)
//Serial.println("Timeout! Please check the connections");
break;
//Judge whether Data collection is over
delay(20);
pressure_H = Read_One_Byte(I2C_address, 0x06);
pressure_M = Read_One_Byte(I2C_address, 0x07);
pressure_L = Read_One_Byte(I2C_address, 0x08);
// Read ADC output Data of Pressure
pressure_adc = pressure_H * 65536 + pressure_M * 256 + pressure_L;
//Compute the value of pressure converted by ADC
if (pressure_adc > 8388608)
pressure = (pressure_adc - 16777216) / K; //unit is Pa, select appropriate K value according to pressure range.
else
pressure = pressure_adc / K; //unit is Pa, select appropriate K value according to pressure range. //The conversion formula of calibrated pressure, its unit is Pa
// Debug, feel free to comment this out
/*Serial.print("Pressure: ");
Serial.print(int(pressure));
Serial.print(", Temperature: ");
Serial.println(int(temperature));*/
temperature_H = Read_One_Byte(I2C_address, 0x09);
temperature_L = Read_One_Byte(I2C_address, 0x0A);
//Read ADC output data of temperature
temperature_adc = temperature_H * 256 + temperature_L;
//Compute the value of temperature converted by ADC
temperature = (temperature_adc - 65536)/256; // is deg C
//else // I do not understand this else without an "if" in the documentation
temperature = temperature_adc / 256; //unit is ℃
//The conversion formula of calibrated temperature, its unit is Centigrade
return pressure;
//----write One Byte of Data,Data from Arduino to the sensor----
// Write "thedata" to the sensor's address of "addr"
void write_one_byte(uint8_t device_address, uint8_t addr, uint8_t thedata)
Wire.beginTransmission(device_address);
Wire.write(addr);
Wire.write(thedata);
Wire.endTransmission();
//----Read One Byte of Data,Data from the sensor to the Arduino ----
uint8_t Read_One_Byte(uint8_t device_address, uint8_t addr)
uint8_t nb_bytes = 1;
Wire.write(addr);
Wire.requestFrom(device_address, nb_bytes);
return Wire.read(); // Receive a byte as character
void write_servo_cmd(uint8_t servo_id, int16_t servo_cmd_angle, int16_t servo_cmd_speed)
if (servo_cmd_angle == sent_servos_angles[servo_id])
return;
delay(50);
if (servo_cmd_angle > sent_servos_angles[servo_id] + servo_cmd_speed)
sent_servos_angles[servo_id] += servo_cmd_speed;
else if (servo_cmd_angle < sent_servos_angles[servo_id] - servo_cmd_speed)
sent_servos_angles[servo_id] -= servo_cmd_speed;
else
sent_servos_angles[servo_id] = servo_cmd_angle;
//pwm.setPWM(servo_pins[servo_id], 0, map(sent_servos_angles[servo_id], 0, 255, SERVOMIN, SERVOMAX));
myservos[servo_id].write(sent_servos_angles[servo_id]);
void actuators_cb(const krabi_msgs::actuators& command)
persistent_actuators_command = command;
current_score = command.score;
stopped = true;
void write_servo_cmd_from_actuator(uint8_t servo_id, const krabi_msgs::servo_cmd& command)
/* if (!stopped_servos_last_update[servo_id])
pwm.setPin(servo_pins[servo_id], 0, true);
stopped_servos_last_update[servo_id] = true;
return; return;
if(stopped) if(stopped_servos_last_update[servo_id])
stopped = false; stopped_servos_last_update[servo_id] = false;
myServos[BRAK].attach(BRAK_PIN); }
myServos[PAVILLON].attach(PAVILLON_PIN); write_servo_cmd(servo_id, command.angle, command.speed);
myServos[TAPETTE_PHARE].attach(TAPETTE_PHARE_PIN);
myServos[BRAK].write(command.brak_angle, command.brak_speed, false); void update_actuators()
myServos[PAVILLON].write(command.pavillon_angle, command.pavillon_speed, false); {
myServos[TAPETTE_PHARE].write(command.s3_angle, command.s3_speed, false); write_servo_cmd_from_actuator(BASE_SERVO, persistent_actuators_command.arm_base_servo);
write_servo_cmd_from_actuator(MID_SERVO, persistent_actuators_command.arm_mid_servo);
write_servo_cmd_from_actuator(SUCTION_SERVO, persistent_actuators_command.arm_suction_cup_servo);
write_servo_cmd_from_actuator(PUSHER_SERVO, persistent_actuators_command.pusher_servo);
digitalWrite(SUCTION_CUP_PIN, persistent_actuators_command.arm_vacuum.enable_pump);
digitalWrite(VALVE_PIN, persistent_actuators_command.arm_vacuum.release);
void drawLCD() void drawLCD()
...@@ -103,20 +270,11 @@ void createCrab() ...@@ -103,20 +270,11 @@ void createCrab()
lcd.createChar(0, Crab1); lcd.createChar(0, Crab1);
lcd.createChar(1, Crab2); lcd.createChar(1, Crab2);
ros::Subscriber<krabi_msgs::servos_cmd> servos_cmd_sub("cmd_servos", cmd_servos_cb); ros::Subscriber<krabi_msgs::actuators> actuators_sub("actuators_msg", actuators_cb);
ros::Publisher pub_vacuum("vacuum", &vacuum_msg);
void setup() void writeFullScreen()
pinMode(TAPETTE_PHARE_PIN, OUTPUT);
nh.initNode();
current_score = 0;
lcd.init(); // initialize the lcd
lcd.backlight();
createCrab();
lcd.setCursor(0,0); lcd.setCursor(0,0);
lcd.write(byte(0)); lcd.write(byte(0));
...@@ -130,12 +288,82 @@ lcd.write(byte(1)); ...@@ -130,12 +288,82 @@ lcd.write(byte(1));
lcd.setCursor(7,1); lcd.setCursor(7,1);
lcd.print("Score:"); lcd.print("Score:");
void setup()
Serial.begin(57600);
Wire.begin();
Wire.setClock(100000);
delay(10);
nh.initNode();
nh.subscribe(actuators_sub);
nh.advertise(pub_vacuum);
nh.spinOnce();
lcd.backlight();
createCrab();
writeFullScreen();
for(int i = 0; i < NB_SERVOS; i++) {
sent_servos_angles[i] = 100;
stopped_servos_last_update[i] = true;
persistent_actuators_command.arm_base_servo.enable = false;
persistent_actuators_command.arm_mid_servo.enable = false;
persistent_actuators_command.arm_suction_cup_servo.enable = false;
persistent_actuators_command.pusher_servo.enable = false;
persistent_actuators_command.arm_vacuum.enable_pump = false;
persistent_actuators_command.arm_vacuum.release = true;
persistent_actuators_command.fake_statuette_vacuum.enable_pump = false;
persistent_actuators_command.fake_statuette_vacuum.release = false;
servo_pins[BASE_SERVO] = BASE_SERVO_PIN;
servo_pins[MID_SERVO] = MID_SERVO_PIN;
servo_pins[SUCTION_SERVO] = SUCTION_SERVO_PIN;
servo_pins[PUSHER_SERVO] = PUSHER_SERVO_PIN;
for (int i = 0; i < NB_SERVOS ; i++)
myservos[i].attach(servo_pins[i]);
delay(10);
pinMode(BASE_SERVO_PIN, OUTPUT);
pinMode(MID_SERVO_PIN, OUTPUT);
pinMode(SUCTION_SERVO_PIN, OUTPUT);
pinMode(PUSHER_SERVO_PIN, OUTPUT);
pinMode(SUCTION_CUP_PIN, OUTPUT);
pinMode(VALVE_PIN, OUTPUT);
//digitalWrite(SUCTION_CUP_PIN, HIGH);
//digitalWrite(VALVE_PIN, HIGH);
current_score = 0;
void loop() void loop()
nh.spinOnce(); writeFullScreen();
double pressure = readPressure();
vacuum_msg.data = pressure;
pub_vacuum.publish(&vacuum_msg);
for (int i = 0; i < 10; i++)
drawLCD(); drawLCD();
delay(50); for (int j = 0; j < 10; j++)
nh.spinOnce();
update_actuators();
delay(5);
