Skip to content
Commits on Source (2)
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
(general (general
(thickness 1.6) (thickness 1.6)
(drawings 4) (drawings 6)
(tracks 87) (tracks 87)
(zones 0) (zones 0)
(modules 6) (modules 6)
...@@ -328,6 +328,30 @@ ...@@ -328,6 +328,30 @@
(dimension 19 (width 0.15) (layer Cmts.User)
(gr_text "19,000 mm" (at 213.05 99.5 270) (layer Cmts.User)
(effects (font (size 1 1) (thickness 0.15)))
(feature1 (pts (xy 201 109) (xy 212.336421 109)))
(feature2 (pts (xy 201 90) (xy 212.336421 90)))
(crossbar (pts (xy 211.75 90) (xy 211.75 109)))
(arrow1a (pts (xy 211.75 109) (xy 211.163579 107.873496)))
(arrow1b (pts (xy 211.75 109) (xy 212.336421 107.873496)))
(arrow2a (pts (xy 211.75 90) (xy 211.163579 91.126504)))
(arrow2b (pts (xy 211.75 90) (xy 212.336421 91.126504)))
(dimension 101 (width 0.15) (layer Cmts.User)
(gr_text "101,000 mm" (at 150.5 76.95) (layer Cmts.User)
(feature1 (pts (xy 201 89.95) (xy 201 77.663579)))
(feature2 (pts (xy 100 89.95) (xy 100 77.663579)))
(crossbar (pts (xy 100 78.25) (xy 201 78.25)))
(arrow1a (pts (xy 201 78.25) (xy 199.873496 78.836421)))
(arrow1b (pts (xy 201 78.25) (xy 199.873496 77.663579)))
(arrow2a (pts (xy 100 78.25) (xy 101.126504 78.836421)))
(arrow2b (pts (xy 100 78.25) (xy 101.126504 77.663579)))
(gr_line (start 100 109) (end 100 90) (layer Edge.Cuts) (width 0.05)) (gr_line (start 100 109) (end 100 90) (layer Edge.Cuts) (width 0.05))
(gr_line (start 201 109) (end 100 109) (layer Edge.Cuts) (width 0.05)) (gr_line (start 201 109) (end 100 109) (layer Edge.Cuts) (width 0.05))
(gr_line (start 201 90) (end 201 109) (layer Edge.Cuts) (width 0.05)) (gr_line (start 201 90) (end 201 109) (layer Edge.Cuts) (width 0.05))
update=dim. 26 avril 2020 00:30:14 CEST update=lun. 27 avril 2020 13:47:00 CEST
version=1 version=1
last_client=kicad last_client=kicad
[general] [general]
...@@ -12,16 +12,6 @@ NetIExt=net ...@@ -12,16 +12,6 @@ NetIExt=net
version=1 version=1
LibDir= LibDir=
[eeschema/libraries] [eeschema/libraries]
[schematic_editor]
version=1
PageLayoutDescrFile=
PlotDirectoryName=doc/
SubpartIdSeparator=0
SubpartFirstId=65
NetFmtName=Pcbnew
SpiceAjustPassiveValues=0
LabSize=50
ERC_TestSimilarLabels=1
[pcbnew] [pcbnew]
version=1 version=1
PageLayoutDescrFile= PageLayoutDescrFile=
...@@ -246,3 +236,13 @@ uViaDrill=0.1 ...@@ -246,3 +236,13 @@ uViaDrill=0.1
dPairWidth=0.2 dPairWidth=0.2
dPairGap=0.25 dPairGap=0.25
dPairViaGap=0.25 dPairViaGap=0.25
[schematic_editor]
version=1
PlotDirectoryName=
SubpartFirstId=65
NetFmtName=Pcbnew
LabSize=50
...@@ -5,8 +5,8 @@ $Descr A4 11693 8268 ...@@ -5,8 +5,8 @@ $Descr A4 11693 8268
encoding utf-8 encoding utf-8
Sheet 1 1 Sheet 1 1
Title "" Title ""
Date "" Date "2020-04-27"
Rev "" Rev "1.0"
Comp "" Comp ""
Comment1 "" Comment1 ""
Comment2 "" Comment2 ""
Component,Part,References,Value,Footprint,Quantity Per PCB,Datasheet,SKU,Vendor,Remarque
1,Conn_01x01,J103 J104,Conn_01x01,9774020360R,2,~,710-9774020360R,MOUSER,
2,Conn_02x01,J101,PRESSURE,PinHeader_1x02_P2.54mm_Horizontal,1,~,,,"Connecteur male 2.54mm standard, le capteur est dans la bom mecanique il est equipé d’un connecteur femelle"
3,RJ45,J102,RJ45,RJ45_Amphenol_54602-x08_Horizontal,1,~,649-54602-908LF,MOUSER,
4,SW_Push_SPDT,SW101,SW_Push_SPDT,D2F_L2_A1,1,~,653-D2F-L2-A1,MOUSER,
5,EC12E2424407,U101,EC12E2424407,EC12E2424407,1,,1520813,FARNELL,
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Interactive BOM for KiCAD</title>
<style type="text/css">
:root {
--pcb-edge-color: black;
--pad-color: #878787;
--pad-color-highlight: #D04040;
--pin1-outline-color: #ffb629;
--pin1-outline-color-highlight: #b4ff03;
--silkscreen-edge-color: #aa4;
--silkscreen-polygon-color: #4aa;
--silkscreen-text-color: #4aa;
--fabrication-edge-color: #907651;
--fabrication-polygon-color: #907651;
--fabrication-text-color: #a27c24;
--track-color: #def5f1;
--track-color-highlight: #D04040;
--zone-color: #def5f1;
--zone-color-highlight: #d0404080;
html, body {
margin: 0px;
height: 100%;
font-family: Verdana, sans-serif;
.dark.topmostdiv {
--pcb-edge-color: #eee;
--pad-color: #808080;
--pin1-outline-color: #ffa800;
--pin1-outline-color-highlight: #ccff00;
--track-color: #42524f;
--zone-color: #42524f;
background-color: #252c30;
color: #eee;
button {
background-color: #eee;
border: 1px solid #888;
color: black;
height: 44px;
width: 44px;
text-align: center;
text-decoration: none;
display: inline-block;
font-size: 14px;
font-weight: bolder;
.dark button {
/* This will be inverted */
background-color: #c3b7b5;
button.depressed {
background-color: #0a0;
color: white;
.dark button.depressed {
background-color: #b3b;
button:focus {
outline: 0;
button#tb-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 8.47 8.47'%3E%3Crect transform='translate(0 -288.53)' ry='1.17' y='288.8' x='.27' height='7.94' width='7.94' fill='%23f9f9f9'/%3E%3Cg transform='translate(0 -288.53)'%3E%3Crect width='7.94' height='7.94' x='.27' y='288.8' ry='1.17' fill='none' stroke='%23000' stroke-width='.4' stroke-linejoin='round'/%3E%3Cpath d='M1.32 290.12h5.82M1.32 291.45h5.82' fill='none' stroke='%23000' stroke-width='.4'/%3E%3Cpath d='M4.37 292.5v4.23M.26 292.63H8.2' fill='none' stroke='%23000' stroke-width='.3'/%3E%3Ctext font-weight='700' font-size='3.17' font-family='sans-serif'%3E%3Ctspan x='1.35' y='295.73'%3EF%3C/tspan%3E%3Ctspan x='5.03' y='295.68'%3EB%3C/tspan%3E%3C/text%3E%3C/g%3E%3C/svg%3E%0A");
button#lr-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 8.47 8.47'%3E%3Crect transform='translate(0 -288.53)' ry='1.17' y='288.8' x='.27' height='7.94' width='7.94' fill='%23f9f9f9'/%3E%3Cg transform='translate(0 -288.53)'%3E%3Crect width='7.94' height='7.94' x='.27' y='288.8' ry='1.17' fill='none' stroke='%23000' stroke-width='.4' stroke-linejoin='round'/%3E%3Cpath d='M1.06 290.12H3.7m-2.64 1.33H3.7m-2.64 1.32H3.7m-2.64 1.3H3.7m-2.64 1.33H3.7' fill='none' stroke='%23000' stroke-width='.4'/%3E%3Cpath d='M4.37 288.8v7.94m0-4.11h3.96' fill='none' stroke='%23000' stroke-width='.3'/%3E%3Ctext font-weight='700' font-size='3.17' font-family='sans-serif'%3E%3Ctspan x='5.11' y='291.96'%3EF%3C/tspan%3E%3Ctspan x='5.03' y='295.68'%3EB%3C/tspan%3E%3C/text%3E%3C/g%3E%3C/svg%3E%0A");
button#bom-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 8.47 8.47'%3E%3Crect transform='translate(0 -288.53)' ry='1.17' y='288.8' x='.27' height='7.94' width='7.94' fill='%23f9f9f9'/%3E%3Cg transform='translate(0 -288.53)' fill='none' stroke='%23000' stroke-width='.4'%3E%3Crect width='7.94' height='7.94' x='.27' y='288.8' ry='1.17' stroke-linejoin='round'/%3E%3Cpath d='M1.59 290.12h5.29M1.59 291.45h5.33M1.59 292.75h5.33M1.59 294.09h5.33M1.59 295.41h5.33'/%3E%3C/g%3E%3C/svg%3E");
button#bom-grouped-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='32' height='32'%3E%3Cg stroke='%23000' stroke-linejoin='round' class='layer'%3E%3Crect width='29' height='29' x='1.5' y='1.5' stroke-width='2' fill='%23fff' rx='5' ry='5'/%3E%3Cpath stroke-linecap='square' stroke-width='2' d='M6 10h4m4 0h5m4 0h3M6.1 22h3m3.9 0h5m4 0h4m-16-8h4m4 0h4'/%3E%3Cpath stroke-linecap='null' d='M5 17.5h22M5 26.6h22M5 5.5h22'/%3E%3C/g%3E%3C/svg%3E");
button#bom-ungrouped-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='32' height='32'%3E%3Cg stroke='%23000' stroke-linejoin='round' class='layer'%3E%3Crect width='29' height='29' x='1.5' y='1.5' stroke-width='2' fill='%23fff' rx='5' ry='5'/%3E%3Cpath stroke-linecap='square' stroke-width='2' d='M6 10h4m-4 8h3m-3 8h4'/%3E%3Cpath stroke-linecap='null' d='M5 13.5h22m-22 8h22M5 5.5h22'/%3E%3C/g%3E%3C/svg%3E");
button#bom-netlist-btn {
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='32' height='32'%3E%3Cg fill='none' stroke='%23000' class='layer'%3E%3Crect width='29' height='29' x='1.5' y='1.5' stroke-width='2' fill='%23fff' rx='5' ry='5'/%3E%3Cpath stroke-width='2' d='M6 26l6-6v-8m13.8-6.3l-6 6v8'/%3E%3Ccircle cx='11.8' cy='9.5' r='2.8' stroke-width='2'/%3E%3Ccircle cx='19.8' cy='22.8' r='2.8' stroke-width='2'/%3E%3C/g%3E%3C/svg%3E");
button#copy {
background-image: url("data:image/svg+xml,%3Csvg height='48' viewBox='0 0 48 48' width='48' xmlns='http://www.w3.org/2000/svg'%3E%3Cpath d='M0 0h48v48h-48z' fill='none'/%3E%3Cpath d='M32 2h-24c-2.21 0-4 1.79-4 4v28h4v-28h24v-4zm6 8h-22c-2.21 0-4 1.79-4 4v28c0 2.21 1.79 4 4 4h22c2.21 0 4-1.79 4-4v-28c0-2.21-1.79-4-4-4zm0 32h-22v-28h22v28z'/%3E%3C/svg%3E");
background-position: 6px 6px;
background-repeat: no-repeat;
background-size: 26px 26px;
border-radius: 6px;
height: 40px;
width: 40px;
margin: 10px 5px;
button#copy:active {
box-shadow: inset 0px 0px 5px #6c6c6c;
textarea.clipboard-temp {
position: fixed;
top: 0;
left: 0;
width: 2em;
height: 2em;
padding: 0;
border: None;
outline: None;
box-shadow: None;
background: transparent;
.left-most-button {
border-right: 0;
border-top-left-radius: 6px;
border-bottom-left-radius: 6px;
.middle-button {
border-right: 0;
.right-most-button {
border-top-right-radius: 6px;
border-bottom-right-radius: 6px;
.button-container {
font-size: 0;
margin: 10px 10px 10px 0px;
.dark .button-container {
filter: invert(1);
.button-container button {
background-size: 32px 32px;
background-position: 5px 5px;
@media print {
.hideonprint {
display: none;
canvas {
cursor: crosshair;
canvas:active {
cursor: grabbing;
.fileinfo {
width: 100%;
max-width: 1000px;
border: none;
padding: 5px;
.fileinfo .title {
font-size: 20pt;
font-weight: bold;
.fileinfo td {
overflow: hidden;
white-space: nowrap;
max-width: 1px;
width: 50%;
text-overflow: ellipsis;
.bom {
border-collapse: collapse;
font-family: Consolas, "DejaVu Sans Mono", Monaco, monospace;
font-size: 10pt;
table-layout: fixed;
width: 100%;
margin-top: 1px;
.bom th, .bom td {
border: 1px solid black;
padding: 5px;
word-wrap: break-word;
text-align: center;
position: relative;
.dark .bom th, .dark .bom td {
border: 1px solid #777;
.bom th {
background-color: #CCCCCC;
background-clip: padding-box;
.dark .bom th {
background-color: #3b4749;
.bom tr.highlighted:nth-child(n) {
background-color: #cfc;
.dark .bom tr.highlighted:nth-child(n) {
background-color: #226022;
.bom tr:nth-child(even) {
background-color: #f2f2f2;
.dark .bom tr:nth-child(even) {
background-color: #313b40;
.bom tr.checked {
color: #aaa;
.dark .bom tr.checked {
color: #666;
.bom tr {
transition: background-color 0.2s;
.bom .numCol {
width: 25px;
.bom .Description {
width: 10%;
.bom .Part {
width: 10%;
.bom .Value {
width: 15%;
.bom .Quantity {
width: 65px;
.bom th .sortmark {
position: absolute;
right: 1px;
top: 1px;
margin-top: -5px;
border-width: 5px;
border-style: solid;
border-color: transparent transparent #221 transparent;
transform-origin: 50% 85%;
transition: opacity 0.2s, transform 0.4s;
.dark .bom th .sortmark {
filter: invert(1);
.bom th .sortmark.none {
opacity: 0;
.bom th .sortmark.desc {
transform: rotate(180deg);
.bom th:hover .sortmark.none {
opacity: 0.5;
.bom .bom-checkbox {
width: 30px;
position: relative;
user-select: none;
-moz-user-select: none;
.bom .bom-checkbox:before {
content: "";
position: absolute;
border-width: 15px;
border-color: #51829f transparent transparent transparent;
visibility: hidden;
top: -15px;
.bom .bom-checkbox:after {
content: "Double click to set/unset all";
position: absolute;
color: white;
top: -35px;
left: -26px;
background: #51829f;
padding: 5px 15px;
border-radius: 8px;
visibility: hidden;
.bom .bom-checkbox:hover:before, .bom .bom-checkbox:hover:after {
visibility: visible;
transition: visibility 0.2s linear 1s;
.split {
-webkit-box-sizing: border-box;
-moz-box-sizing: border-box;
overflow-y: auto;
overflow-x: hidden;
background-color: inherit;
.split.split-horizontal, .gutter.gutter-horizontal {
height: 100%;
float: left;
.gutter {
background-color: #ddd;
background-position: 50%;
transition: background-color 0.3s;
.dark .gutter {
background-color: #777;
background-image: url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAeCAYAAADkftS9AAAAIklEQVQoU2M4c+bMfxAGAgYYmwGrIIiDjrELjpo5aiZeMwF+yNnOs5KSvgAAAABJRU5ErkJggg==');
cursor: ew-resize;
width: 5px;
.gutter.gutter-vertical {
background-image: url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAB4AAAAFAQMAAABo7865AAAABlBMVEVHcEzMzMzyAv2sAAAAAXRSTlMAQObYZgAAABBJREFUeF5jOAMEEAIEEFwAn3kMwcB6I2AAAAAASUVORK5CYII=');
cursor: ns-resize;
height: 5px;
.searchbox {
float: left;
height: 40px;
margin: 10px 5px;
padding: 12px 32px;
font-size: 18px;
border-radius: 6px;
outline: none;
transition: background-color 0.2s, border 0.2s;
background-image: url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAABNklEQVQ4T8XSMUvDQBQH8P/LElFa/AIZHcTBQSz0I/gFstTBRR2KUC4ldDxw7h0Bl3RRUATxi4iiODgoiLNrbQYp5J6cpJJqomkX33Z37/14d/dIa33MzDuYI4johOI4XhyNRteO46zNYjDzAxE1yBZprVeZ+QbAUhXEGJMA2Ox2u4+fQIa0mPmsCgCgJYQ4t7lfgF0opQYAdv9ABkKI/UnOFCClXKjX61cA1osQY8x9kiRNKeV7IWA3oyhaSdP0FkAtjxhj3hzH2RBCPOf3pzqYHCilfAAX+URm9oMguPzeWSGQvUcMYC8rOBJCHBRdqxTo9/vbRHRqi8bj8XKv1xvODbiuW2u32/bvf0SlDv4XYOY7z/Mavu+nM1+BmQ+NMc0wDF/LprP0DbTWW0T00ul0nn4b7Q87+X4Qmfiq2wAAAABJRU5ErkJggg==');
background-position: 10px 10px;
.dark .searchbox {
background-color: #111;
color: #eee;
.searchbox::placeholder {
color: #ccc;
.dark .searchbox::placeholder {
color: #666;
.filter {
width: calc(60% - 64px);
.reflookup {
width: calc(40% - 10px);
input[type=text]:focus {
background-color: white;
border: 1px solid #333;
.dark input[type=text]:focus {
background-color: #333;
border: 1px solid #ccc;
mark.highlight {
background-color: #5050ff;
color: #fff;
padding: 2px;
border-radius: 6px;
.dark mark.highlight {
background-color: #76a6da;
color: #111;
.menubtn {
border: none;
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='36' height='36' viewBox='0 0 20 20'%3E%3Cpath fill='none' d='M0 0h20v20H0V0z'/%3E%3Cpath d='M15.95 10.78c.03-.25.05-.51.05-.78s-.02-.53-.06-.78l1.69-1.32c.15-.12.19-.34.1-.51l-1.6-2.77c-.1-.18-.31-.24-.49-.18l-1.99.8c-.42-.32-.86-.58-1.35-.78L12 2.34c-.03-.2-.2-.34-.4-.34H8.4c-.2 0-.36.14-.39.34l-.3 2.12c-.49.2-.94.47-1.35.78l-1.99-.8c-.18-.07-.39 0-.49.18l-1.6 2.77c-.1.18-.06.39.1.51l1.69 1.32c-.04.25-.07.52-.07.78s.02.53.06.78L2.37 12.1c-.15.12-.19.34-.1.51l1.6 2.77c.1.18.31.24.49.18l1.99-.8c.42.32.86.58 1.35.78l.3 2.12c.04.2.2.34.4.34h3.2c.2 0 .37-.14.39-.34l.3-2.12c.49-.2.94-.47 1.35-.78l1.99.8c.18.07.39 0 .49-.18l1.6-2.77c.1-.18.06-.39-.1-.51l-1.67-1.32zM10 13c-1.65 0-3-1.35-3-3s1.35-3 3-3 3 1.35 3 3-1.35 3-3 3z'/%3E%3C/svg%3E%0A");
background-position: center;
.statsbtn {
border: none;
background-image: url("data:image/svg+xml,%3Csvg width='36' height='36' xmlns='http://www.w3.org/2000/svg'%3E%3Cpath d='M4 6h28v24H4V6zm0 8h28v8H4m9-16v24h10V5.8' fill='none' stroke='%23000' stroke-width='2'/%3E%3C/svg%3E");
.iobtn {
border: none;
background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='36' height='36'%3E%3Cpath fill='none' stroke='%23000' stroke-width='2' d='M3 33v-7l6.8-7h16.5l6.7 7v7H3zM3.2 26H33M21 9l5-5.9 5 6h-2.5V15h-5V9H21zm-4.9 0l-5 6-5-6h2.5V3h5v6h2.5z'/%3E%3Cpath fill='none' stroke='%23000' d='M6.1 29.5H10'/%3E%3C/svg%3E");
.dark .statsbtn, .dark .savebtn, .dark .menubtn, .dark .iobtn {
filter: invert(1);
.flexbox {
display: flex;
align-items: center;
justify-content: space-between;
width: 100%;
.savebtn {
background-color: #d6d6d6;
width: auto;
height: 30px;
flex-grow: 1;
margin: 5px;
border-radius: 4px;
.savebtn:active {
color: white;
.dark .savebtn:active {
.stats {
font-size: 12pt;
width: 100%;
min-width: 450px;
.dark .stats td {
border: 1px solid #bbb;
.stats td {
padding: 5px;
text-align: center;
position: relative;
#checkbox-stats div {
position: absolute;
left: 0;
top: 0;
height: 100%;
width: 100%;
display: flex;
justify-content: center;
#checkbox-stats .bar {
background-color: rgba(28, 251, 0, 0.6);
.menu {
position: relative;
.menu-content {
display: none;
position: absolute;
right: 0;
min-width: 300px;
box-shadow: 0px 8px 16px 0px rgba(0, 0, 0, 0.2);
z-index: 100;
padding: 8px;
.dark .menu-content {
.menu:hover .menu-content {
display: block;
.menu:hover .menubtn, .menu:hover .iobtn, .menu:hover .statsbtn {
.menu-label {
padding: 8px;
border-top: 0;
width: calc(100% - 18px);
.menu-label-top {
border-top: 1px solid #ccc;
.menu-textbox {
float: left;
height: 24px;
margin: 10px 5px;
padding: 5px 5px;
font-size: 14px;
border-radius: 4px;
outline: none;
width: calc(100% - 10px);
.menu-textbox.invalid, .dark .menu-textbox.invalid {
color: red;
.dark .menu-textbox {
background-color: #222;
color: #eee;
.radio-container {
margin: 4px;
.topmostdiv {
width: 100%;
height: 100%;
#top {
height: 78px;
border-bottom: 2px solid black;
.dark #top {
border-bottom: 2px solid #ccc;
#dbg {
display: block;
::-webkit-scrollbar {
width: 8px;
::-webkit-scrollbar-track {
background: #aaa;
::-webkit-scrollbar-thumb {
background: #666;
border-radius: 3px;
::-webkit-scrollbar-thumb:hover {
background: #555;
.slider {
-webkit-appearance: none;
width: 100%;
margin: 3px 0;
padding: 0;
outline: none;
opacity: 0.7;
-webkit-transition: .2s;
transition: opacity .2s;
border-radius: 3px;
.slider:hover {
opacity: 1;
.slider:focus {
outline: none;
.slider::-webkit-slider-runnable-track {
width: 100%;
height: 8px;
background: #d3d3d3;
border-radius: 3px;
border: none;
.slider::-webkit-slider-thumb {
width: 15px;
height: 15px;
border-radius: 50%;
background: #0a0;
cursor: pointer;
margin-top: -4px;
.dark .slider::-webkit-slider-thumb {
background: #3d3;
.slider::-moz-range-thumb {
width: 15px;
height: 15px;
border-radius: 50%;
background: #0a0;
cursor: pointer;
.slider::-moz-range-track {
height: 8px;
border-radius: 3px;
.dark .slider::-moz-range-thumb {
background: #3d3;
.slider::-ms-track {
width: 100%;
height: 8px;
border-width: 3px 0;
border-color: transparent;
color: transparent;
.slider::-ms-fill-lower {
border: none;
border-radius: 3px;
.slider::-ms-fill-upper {
border: none;
border-radius: 3px;
.slider::-ms-thumb {
width: 15px;
height: 15px;
border-radius: 50%;
background: #0a0;
cursor: pointer;
margin: 0;
.shameless-plug {
font-size: 0.8em;
text-align: center;
display: block;
a {
color: #0278a4;
.dark a {
color: #00b9fd;
#frontcanvas, #backcanvas {
touch-action: none;
</style>
<script type="text/javascript" >
Split.js - v1.3.5
MIT License
https://github.com/nathancahill/Split.js
!function(e,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t():"function"==typeof define&&define.amd?define(t):e.Split=t()}(this,function(){"use strict";var e=window,t=e.document,n="addEventListener",i="removeEventListener",r="getBoundingClientRect",s=function(){return!1},o=e.attachEvent&&!e[n],a=["","-webkit-","-moz-","-o-"].filter(function(e){var n=t.createElement("div");return n.style.cssText="width:"+e+"calc(9px)",!!n.style.length}).shift()+"calc",l=function(e){return"string"==typeof e||e instanceof String?t.querySelector(e):e};return function(u,c){function z(e,t,n){var i=A(y,t,n);Object.keys(i).forEach(function(t){return e.style[t]=i[t]})}function h(e,t){var n=B(y,t);Object.keys(n).forEach(function(t){return e.style[t]=n[t]})}function f(e){var t=E[this.a],n=E[this.b],i=t.size+n.size;t.size=e/this.size*i,n.size=i-e/this.size*i,z(t.element,t.size,this.aGutterSize),z(n.element,n.size,this.bGutterSize)}function m(e){var t;this.dragging&&((t="touches"in e?e.touches[0][b]-this.start:e[b]-this.start)<=E[this.a].minSize+M+this.aGutterSize?t=E[this.a].minSize+this.aGutterSize:t>=this.size-(E[this.b].minSize+M+this.bGutterSize)&&(t=this.size-(E[this.b].minSize+this.bGutterSize)),f.call(this,t),c.onDrag&&c.onDrag())}function g(){var e=E[this.a].element,t=E[this.b].element;this.size=e[r]()[y]+t[r]()[y]+this.aGutterSize+this.bGutterSize,this.start=e[r]()[G]}function d(){var t=this,n=E[t.a].element,r=E[t.b].element;t.dragging&&c.onDragEnd&&c.onDragEnd(),t.dragging=!1,e[i]("mouseup",t.stop),e[i]("touchend",t.stop),e[i]("touchcancel",t.stop),t.parent[i]("mousemove",t.move),t.parent[i]("touchmove",t.move),delete t.stop,delete t.move,n[i]("selectstart",s),n[i]("dragstart",s),r[i]("selectstart",s),r[i]("dragstart",s),n.style.userSelect="",n.style.webkitUserSelect="",n.style.MozUserSelect="",n.style.pointerEvents="",r.style.userSelect="",r.style.webkitUserSelect="",r.style.MozUserSelect="",r.style.pointerEvents="",t.gutter.style.cursor="",t.parent.style.cursor=""}function S(t){var i=this,r=E[i.a].element,o=E[i.b].element;!i.dragging&&c.onDragStart&&c.onDragStart(),t.preventDefault(),i.dragging=!0,i.move=m.bind(i),i.stop=d.bind(i),e[n]("mouseup",i.stop),e[n]("touchend",i.stop),e[n]("touchcancel",i.stop),i.parent[n]("mousemove",i.move),i.parent[n]("touchmove",i.move),r[n]("selectstart",s),r[n]("dragstart",s),o[n]("selectstart",s),o[n]("dragstart",s),r.style.userSelect="none",r.style.webkitUserSelect="none",r.style.MozUserSelect="none",r.style.pointerEvents="none",o.style.userSelect="none",o.style.webkitUserSelect="none",o.style.MozUserSelect="none",o.style.pointerEvents="none",i.gutter.style.cursor=j,i.parent.style.cursor=j,g.call(i)}function v(e){e.forEach(function(t,n){if(n>0){var i=F[n-1],r=E[i.a],s=E[i.b];r.size=e[n-1],s.size=t,z(r.element,r.size,i.aGutterSize),z(s.element,s.size,i.bGutterSize)}})}function p(){F.forEach(function(e){e.parent.removeChild(e.gutter),E[e.a].element.style[y]="",E[e.b].element.style[y]=""})}void 0===c&&(c={});var y,b,G,E,w=l(u[0]).parentNode,D=e.getComputedStyle(w).flexDirection,U=c.sizes||u.map(function(){return 100/u.length}),k=void 0!==c.minSize?c.minSize:100,x=Array.isArray(k)?k:u.map(function(){return k}),L=void 0!==c.gutterSize?c.gutterSize:10,M=void 0!==c.snapOffset?c.snapOffset:30,O=c.direction||"horizontal",j=c.cursor||("horizontal"===O?"ew-resize":"ns-resize"),C=c.gutter||function(e,n){var i=t.createElement("div");return i.className="gutter gutter-"+n,i},A=c.elementStyle||function(e,t,n){var i={};return"string"==typeof t||t instanceof String?i[e]=t:i[e]=o?t+"%":a+"("+t+"% - "+n+"px)",i},B=c.gutterStyle||function(e,t){return n={},n[e]=t+"px",n;var n};"horizontal"===O?(y="width","clientWidth",b="clientX",G="left","paddingLeft"):"vertical"===O&&(y="height","clientHeight",b="clientY",G="top","paddingTop");var F=[];return E=u.map(function(e,t){var i,s={element:l(e),size:U[t],minSize:x[t]};if(t>0&&(i={a:t-1,b:t,dragging:!1,isFirst:1===t,isLast:t===u.length-1,direction:O,parent:w},i.aGutterSize=L,i.bGutterSize=L,i.isFirst&&(i.aGutterSize=L/2),i.isLast&&(i.bGutterSize=L/2),"row-reverse"===D||"column-reverse"===D)){var a=i.a;i.a=i.b,i.b=a}if(!o&&t>0){var c=C(t,O);h(c,L),c[n]("mousedown",S.bind(i)),c[n]("touchstart",S.bind(i)),w.insertBefore(c,s.element),i.gutter=c}0===t||t===u.length-1?z(s.element,s.size,L/2):z(s.element,s.size,L);var f=s.element[r]()[y];return f<s.minSize&&(s.minSize=f),t>0&&F.push(i),s}),o?{setSizes:v,destroy:p}:{setSizes:v,getSizes:function(){return E.map(function(e){return e.size})},collapse:function(e){if(e===F.length){var t=F[e-1];g.call(t),o||f.call(t,t.size-t.bGutterSize)}else{var n=F[e];g.call(n),o||f.call(n,n.aGutterSize)}},destroy:p}}});
// Copyright (c) 2013 Pieroxy <pieroxy@pieroxy.net>
// This work is free. You can redistribute it and/or modify it
// under the terms of the WTFPL, Version 2
// For more information see LICENSE.txt or http://www.wtfpl.net/
// For more information, the home page:
// http://pieroxy.net/blog/pages/lz-string/testing.html
// LZ-based compression algorithm, version 1.4.4
var LZString=function(){var o=String.fromCharCode,i={};var n={decompressFromBase64:function(o){return null==o?"":""==o?null:n._decompress(o.length,32,function(n){return function(o,n){if(!i[o]){i[o]={};for(var t=0;t<o.length;t++)i[o][o.charAt(t)]=t}return i[o][n]}("ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=",o.charAt(n))})},_decompress:function(i,n,t){var r,e,a,s,p,u,l,f=[],c=4,d=4,h=3,v="",g=[],m={val:t(0),position:n,index:1};for(r=0;r<3;r+=1)f[r]=r;for(a=0,p=Math.pow(2,2),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;switch(a){case 0:for(a=0,p=Math.pow(2,8),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;l=o(a);break;case 1:for(a=0,p=Math.pow(2,16),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;l=o(a);break;case 2:return""}for(f[3]=l,e=l,g.push(l);;){if(m.index>i)return"";for(a=0,p=Math.pow(2,h),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;switch(l=a){case 0:for(a=0,p=Math.pow(2,8),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;f[d++]=o(a),l=d-1,c--;break;case 1:for(a=0,p=Math.pow(2,16),u=1;u!=p;)s=m.val&m.position,m.position>>=1,0==m.position&&(m.position=n,m.val=t(m.index++)),a|=(s>0?1:0)*u,u<<=1;f[d++]=o(a),l=d-1,c--;break;case 2:return g.join("")}if(0==c&&(c=Math.pow(2,h),h++),f[l])v=f[l];else{if(l!==d)return null;v=e+e.charAt(0)}g.push(v),f[d++]=e+v.charAt(0),e=v,0==--c&&(c=Math.pow(2,h),h++)}}};return n}();"function"==typeof define&&define.amd?define(function(){return LZString}):"undefined"!=typeof module&&null!=module?module.exports=LZString:"undefined"!=typeof angular&&null!=angular&&angular.module("LZString",[]).factory("LZString",function(){return LZString});
* PEP v0.4.3 | https://github.com/jquery/PEP
* Copyright jQuery Foundation and other contributors | http://jquery.org/license
!function(a,b){"object"==typeof exports&&"undefined"!=typeof module?module.exports=b():"function"==typeof define&&define.amd?define(b):a.PointerEventsPolyfill=b()}(this,function(){"use strict";function a(a,b){b=b||Object.create(null);var c=document.createEvent("Event");c.initEvent(a,b.bubbles||!1,b.cancelable||!1);
for(var d,e=2;e<m.length;e++)d=m[e],c[d]=b[d]||n[e];c.buttons=b.buttons||0;
var f=0;return f=b.pressure&&c.buttons?b.pressure:c.buttons?.5:0,c.x=c.clientX,c.y=c.clientY,c.pointerId=b.pointerId||0,c.width=b.width||0,c.height=b.height||0,c.pressure=f,c.tiltX=b.tiltX||0,c.tiltY=b.tiltY||0,c.twist=b.twist||0,c.tangentialPressure=b.tangentialPressure||0,c.pointerType=b.pointerType||"",c.hwTimestamp=b.hwTimestamp||0,c.isPrimary=b.isPrimary||!1,c}function b(){this.array=[],this.size=0}function c(a,b,c,d){this.addCallback=a.bind(d),this.removeCallback=b.bind(d),this.changedCallback=c.bind(d),A&&(this.observer=new A(this.mutationWatcher.bind(this)))}function d(a){return"body /shadow-deep/ "+e(a)}function e(a){return'[touch-action="'+a+'"]'}function f(a){return"{ -ms-touch-action: "+a+"; touch-action: "+a+"; }"}function g(){if(F){D.forEach(function(a){String(a)===a?(E+=e(a)+f(a)+"\n",G&&(E+=d(a)+f(a)+"\n")):(E+=a.selectors.map(e)+f(a.rule)+"\n",G&&(E+=a.selectors.map(d)+f(a.rule)+"\n"))});var a=document.createElement("style");a.textContent=E,document.head.appendChild(a)}}function h(){if(!window.PointerEvent){if(window.PointerEvent=a,window.navigator.msPointerEnabled){var b=window.navigator.msMaxTouchPoints;Object.defineProperty(window.navigator,"maxTouchPoints",{value:b,enumerable:!0}),u.registerSource("ms",_)}else Object.defineProperty(window.navigator,"maxTouchPoints",{value:0,enumerable:!0}),u.registerSource("mouse",N),void 0!==window.ontouchstart&&u.registerSource("touch",V);u.register(document)}}function i(a){if(!u.pointermap.has(a)){var b=new Error("InvalidPointerId");throw b.name="InvalidPointerId",b}}function j(a){for(var b=a.parentNode;b&&b!==a.ownerDocument;)b=b.parentNode;if(!b){var c=new Error("InvalidStateError");throw c.name="InvalidStateError",c}}function k(a){var b=u.pointermap.get(a);return 0!==b.buttons}function l(){window.Element&&!Element.prototype.setPointerCapture&&Object.defineProperties(Element.prototype,{setPointerCapture:{value:W},releasePointerCapture:{value:X},hasPointerCapture:{value:Y}})}
var m=["bubbles","cancelable","view","detail","screenX","screenY","clientX","clientY","ctrlKey","altKey","shiftKey","metaKey","button","relatedTarget","pageX","pageY"],n=[!1,!1,null,null,0,0,0,0,!1,!1,!1,!1,0,null,0,0],o=window.Map&&window.Map.prototype.forEach,p=o?Map:b;b.prototype={set:function(a,b){return void 0===b?this["delete"](a):(this.has(a)||this.size++,void(this.array[a]=b))},has:function(a){return void 0!==this.array[a]},"delete":function(a){this.has(a)&&(delete this.array[a],this.size--)},get:function(a){return this.array[a]},clear:function(){this.array.length=0,this.size=0},forEach:function(a,b){return this.array.forEach(function(c,d){a.call(b,c,d,this)},this)}};var q=["bubbles","cancelable","view","detail","screenX","screenY","clientX","clientY","ctrlKey","altKey","shiftKey","metaKey","button","relatedTarget","buttons","pointerId","width","height","pressure","tiltX","tiltY","pointerType","hwTimestamp","isPrimary","type","target","currentTarget","which","pageX","pageY","timeStamp"],r=[!1,!1,null,null,0,0,0,0,!1,!1,!1,!1,0,null,0,0,0,0,0,0,0,"",0,!1,"",null,null,0,0,0,0],s={pointerover:1,pointerout:1,pointerenter:1,pointerleave:1},t="undefined"!=typeof SVGElementInstance,u={pointermap:new p,eventMap:Object.create(null),captureInfo:Object.create(null),eventSources:Object.create(null),eventSourceList:[],registerSource:function(a,b){var c=b,d=c.events;d&&(d.forEach(function(a){c[a]&&(this.eventMap[a]=c[a].bind(c))},this),this.eventSources[a]=c,this.eventSourceList.push(c))},register:function(a){for(var b,c=this.eventSourceList.length,d=0;d<c&&(b=this.eventSourceList[d]);d++)
b.register.call(b,a)},unregister:function(a){for(var b,c=this.eventSourceList.length,d=0;d<c&&(b=this.eventSourceList[d]);d++)
b.unregister.call(b,a)},contains:function(a,b){try{return a.contains(b)}catch(c){return!1}},down:function(a){a.bubbles=!0,this.fireEvent("pointerdown",a)},move:function(a){a.bubbles=!0,this.fireEvent("pointermove",a)},up:function(a){a.bubbles=!0,this.fireEvent("pointerup",a)},enter:function(a){a.bubbles=!1,this.fireEvent("pointerenter",a)},leave:function(a){a.bubbles=!1,this.fireEvent("pointerleave",a)},over:function(a){a.bubbles=!0,this.fireEvent("pointerover",a)},out:function(a){a.bubbles=!0,this.fireEvent("pointerout",a)},cancel:function(a){a.bubbles=!0,this.fireEvent("pointercancel",a)},leaveOut:function(a){this.out(a),this.propagate(a,this.leave,!1)},enterOver:function(a){this.over(a),this.propagate(a,this.enter,!0)},eventHandler:function(a){if(!a._handledByPE){var b=a.type,c=this.eventMap&&this.eventMap[b];c&&c(a),a._handledByPE=!0}},listen:function(a,b){b.forEach(function(b){this.addEvent(a,b)},this)},unlisten:function(a,b){b.forEach(function(b){this.removeEvent(a,b)},this)},addEvent:function(a,b){a.addEventListener(b,this.boundHandler)},removeEvent:function(a,b){a.removeEventListener(b,this.boundHandler)},makeEvent:function(b,c){this.captureInfo[c.pointerId]&&(c.relatedTarget=null);var d=new a(b,c);return c.preventDefault&&(d.preventDefault=c.preventDefault),d._target=d._target||c.target,d},fireEvent:function(a,b){var c=this.makeEvent(a,b);return this.dispatchEvent(c)},cloneEvent:function(a){for(var b,c=Object.create(null),d=0;d<q.length;d++)b=q[d],c[b]=a[b]||r[d],!t||"target"!==b&&"relatedTarget"!==b||c[b]instanceof SVGElementInstance&&(c[b]=c[b].correspondingUseElement);return a.preventDefault&&(c.preventDefault=function(){a.preventDefault()}),c},getTarget:function(a){var b=this.captureInfo[a.pointerId];return b?a._target!==b&&a.type in s?void 0:b:a._target},propagate:function(a,b,c){for(var d=a.target,e=[];d!==document&&!d.contains(a.relatedTarget);) if(e.push(d),d=d.parentNode,!d)return;c&&e.reverse(),e.forEach(function(c){a.target=c,b.call(this,a)},this)},setCapture:function(b,c,d){this.captureInfo[b]&&this.releaseCapture(b,d),this.captureInfo[b]=c,this.implicitRelease=this.releaseCapture.bind(this,b,d),document.addEventListener("pointerup",this.implicitRelease),document.addEventListener("pointercancel",this.implicitRelease);var e=new a("gotpointercapture");e.pointerId=b,e._target=c,d||this.asyncDispatchEvent(e)},releaseCapture:function(b,c){var d=this.captureInfo[b];if(d){this.captureInfo[b]=void 0,document.removeEventListener("pointerup",this.implicitRelease),document.removeEventListener("pointercancel",this.implicitRelease);var e=new a("lostpointercapture");e.pointerId=b,e._target=d,c||this.asyncDispatchEvent(e)}},dispatchEvent:/*scope.external.dispatchEvent || */function(a){var b=this.getTarget(a);if(b)return b.dispatchEvent(a)},asyncDispatchEvent:function(a){requestAnimationFrame(this.dispatchEvent.bind(this,a))}};u.boundHandler=u.eventHandler.bind(u);var v={shadow:function(a){if(a)return a.shadowRoot||a.webkitShadowRoot},canTarget:function(a){return a&&Boolean(a.elementFromPoint)},targetingShadow:function(a){var b=this.shadow(a);if(this.canTarget(b))return b},olderShadow:function(a){var b=a.olderShadowRoot;if(!b){var c=a.querySelector("shadow");c&&(b=c.olderShadowRoot)}return b},allShadows:function(a){for(var b=[],c=this.shadow(a);c;)b.push(c),c=this.olderShadow(c);return b},searchRoot:function(a,b,c){if(a){var d,e,f=a.elementFromPoint(b,c);for(e=this.targetingShadow(f);e;){if(d=e.elementFromPoint(b,c)){var g=this.targetingShadow(d);return this.searchRoot(g,b,c)||d} e=this.olderShadow(e)} return f}},owner:function(a){
for(var b=a;b.parentNode;)b=b.parentNode;
return b.nodeType!==Node.DOCUMENT_NODE&&b.nodeType!==Node.DOCUMENT_FRAGMENT_NODE&&(b=document),b},findTarget:function(a){var b=a.clientX,c=a.clientY,d=this.owner(a.target);
return d.elementFromPoint(b,c)||(d=document),this.searchRoot(d,b,c)}},w=Array.prototype.forEach.call.bind(Array.prototype.forEach),x=Array.prototype.map.call.bind(Array.prototype.map),y=Array.prototype.slice.call.bind(Array.prototype.slice),z=Array.prototype.filter.call.bind(Array.prototype.filter),A=window.MutationObserver||window.WebKitMutationObserver,B="[touch-action]",C={subtree:!0,childList:!0,attributes:!0,attributeOldValue:!0,attributeFilter:["touch-action"]};c.prototype={watchSubtree:function(a){
this.observer&&v.canTarget(a)&&this.observer.observe(a,C)},enableOnSubtree:function(a){this.watchSubtree(a),a===document&&"complete"!==document.readyState?this.installOnLoad():this.installNewSubtree(a)},installNewSubtree:function(a){w(this.findElements(a),this.addElement,this)},findElements:function(a){return a.querySelectorAll?a.querySelectorAll(B):[]},removeElement:function(a){this.removeCallback(a)},addElement:function(a){this.addCallback(a)},elementChanged:function(a,b){this.changedCallback(a,b)},concatLists:function(a,b){return a.concat(y(b))},
installOnLoad:function(){document.addEventListener("readystatechange",function(){"complete"===document.readyState&&this.installNewSubtree(document)}.bind(this))},isElement:function(a){return a.nodeType===Node.ELEMENT_NODE},flattenMutationTree:function(a){
var b=x(a,this.findElements,this);
return b.push(z(a,this.isElement)),b.reduce(this.concatLists,[])},mutationWatcher:function(a){a.forEach(this.mutationHandler,this)},mutationHandler:function(a){if("childList"===a.type){var b=this.flattenMutationTree(a.addedNodes);b.forEach(this.addElement,this);var c=this.flattenMutationTree(a.removedNodes);c.forEach(this.removeElement,this)}else"attributes"===a.type&&this.elementChanged(a.target,a.oldValue)}};var D=["none","auto","pan-x","pan-y",{rule:"pan-x pan-y",selectors:["pan-x pan-y","pan-y pan-x"]}],E="",F=window.PointerEvent||window.MSPointerEvent,G=!window.ShadowDOMPolyfill&&document.head.createShadowRoot,H=u.pointermap,I=25,J=[1,4,2,8,16],K=!1;try{K=1===new MouseEvent("test",{buttons:1}).buttons}catch(L){}
var M,N={POINTER_ID:1,POINTER_TYPE:"mouse",events:["mousedown","mousemove","mouseup","mouseover","mouseout"],register:function(a){u.listen(a,this.events)},unregister:function(a){u.unlisten(a,this.events)},lastTouches:[],
isEventSimulatedFromTouch:function(a){for(var b,c=this.lastTouches,d=a.clientX,e=a.clientY,f=0,g=c.length;f<g&&(b=c[f]);f++){
var h=Math.abs(d-b.x),i=Math.abs(e-b.y);if(h<=I&&i<=I)return!0}},prepareEvent:function(a){var b=u.cloneEvent(a),c=b.preventDefault;return b.preventDefault=function(){a.preventDefault(),c()},b.pointerId=this.POINTER_ID,b.isPrimary=!0,b.pointerType=this.POINTER_TYPE,b},prepareButtonsForMove:function(a,b){var c=H.get(this.POINTER_ID);
0!==b.which&&c?a.buttons=c.buttons:a.buttons=0,b.buttons=a.buttons},mousedown:function(a){if(!this.isEventSimulatedFromTouch(a)){var b=H.get(this.POINTER_ID),c=this.prepareEvent(a);K||(c.buttons=J[c.button],b&&(c.buttons|=b.buttons),a.buttons=c.buttons),H.set(this.POINTER_ID,a),b&&0!==b.buttons?u.move(c):u.down(c)}},mousemove:function(a){if(!this.isEventSimulatedFromTouch(a)){var b=this.prepareEvent(a);K||this.prepareButtonsForMove(b,a),b.button=-1,H.set(this.POINTER_ID,a),u.move(b)}},mouseup:function(a){if(!this.isEventSimulatedFromTouch(a)){var b=H.get(this.POINTER_ID),c=this.prepareEvent(a);if(!K){var d=J[c.button];
c.buttons=b?b.buttons&~d:0,a.buttons=c.buttons}H.set(this.POINTER_ID,a),
c.buttons&=~J[c.button],0===c.buttons?u.up(c):u.move(c)}},mouseover:function(a){if(!this.isEventSimulatedFromTouch(a)){var b=this.prepareEvent(a);K||this.prepareButtonsForMove(b,a),b.button=-1,H.set(this.POINTER_ID,a),u.enterOver(b)}},mouseout:function(a){if(!this.isEventSimulatedFromTouch(a)){var b=this.prepareEvent(a);K||this.prepareButtonsForMove(b,a),b.button=-1,u.leaveOut(b)}},cancel:function(a){var b=this.prepareEvent(a);u.cancel(b),this.deactivateMouse()},deactivateMouse:function(){H["delete"](this.POINTER_ID)}},O=u.captureInfo,P=v.findTarget.bind(v),Q=v.allShadows.bind(v),R=u.pointermap,S=2500,T=200,U="touch-action",V={events:["touchstart","touchmove","touchend","touchcancel"],register:function(a){M.enableOnSubtree(a)},unregister:function(){},elementAdded:function(a){var b=a.getAttribute(U),c=this.touchActionToScrollType(b);c&&(a._scrollType=c,u.listen(a,this.events),
Q(a).forEach(function(a){a._scrollType=c,u.listen(a,this.events)},this))},elementRemoved:function(a){a._scrollType=void 0,u.unlisten(a,this.events),
Q(a).forEach(function(a){a._scrollType=void 0,u.unlisten(a,this.events)},this)},elementChanged:function(a,b){var c=a.getAttribute(U),d=this.touchActionToScrollType(c),e=this.touchActionToScrollType(b);
d&&e?(a._scrollType=d,Q(a).forEach(function(a){a._scrollType=d},this)):e?this.elementRemoved(a):d&&this.elementAdded(a)},scrollTypes:{EMITTER:"none",XSCROLLER:"pan-x",YSCROLLER:"pan-y",SCROLLER:/^(?:pan-x pan-y)|(?:pan-y pan-x)|auto$/},touchActionToScrollType:function(a){var b=a,c=this.scrollTypes;return"none"===b?"none":b===c.XSCROLLER?"X":b===c.YSCROLLER?"Y":c.SCROLLER.exec(b)?"XY":void 0},POINTER_TYPE:"touch",firstTouch:null,isPrimaryTouch:function(a){return this.firstTouch===a.identifier},setPrimaryTouch:function(a){
(0===R.size||1===R.size&&R.has(1))&&(this.firstTouch=a.identifier,this.firstXY={X:a.clientX,Y:a.clientY},this.scrolling=!1,this.cancelResetClickCount())},removePrimaryPointer:function(a){a.isPrimary&&(this.firstTouch=null,this.firstXY=null,this.resetClickCount())},clickCount:0,resetId:null,resetClickCount:function(){var a=function(){this.clickCount=0,this.resetId=null}.bind(this);this.resetId=setTimeout(a,T)},cancelResetClickCount:function(){this.resetId&&clearTimeout(this.resetId)},typeToButtons:function(a){var b=0;return"touchstart"!==a&&"touchmove"!==a||(b=1),b},touchToPointer:function(a){var b=this.currentTouchEvent,c=u.cloneEvent(a),d=c.pointerId=a.identifier+2;c.target=O[d]||P(c),c.bubbles=!0,c.cancelable=!0,c.detail=this.clickCount,c.button=0,c.buttons=this.typeToButtons(b.type),c.width=2*(a.radiusX||a.webkitRadiusX||0),c.height=2*(a.radiusY||a.webkitRadiusY||0),c.pressure=a.force||a.webkitForce||.5,c.isPrimary=this.isPrimaryTouch(a),c.pointerType=this.POINTER_TYPE,
c.altKey=b.altKey,c.ctrlKey=b.ctrlKey,c.metaKey=b.metaKey,c.shiftKey=b.shiftKey;
var e=this;return c.preventDefault=function(){e.scrolling=!1,e.firstXY=null,b.preventDefault()},c},processTouches:function(a,b){var c=a.changedTouches;this.currentTouchEvent=a;for(var d,e=0;e<c.length;e++)d=c[e],b.call(this,this.touchToPointer(d))},
shouldScroll:function(a){if(this.firstXY){var b,c=a.currentTarget._scrollType;if("none"===c)
b=!1;else if("XY"===c)
b=!0;else{var d=a.changedTouches[0],e=c,f="Y"===c?"X":"Y",g=Math.abs(d["client"+e]-this.firstXY[e]),h=Math.abs(d["client"+f]-this.firstXY[f]);
b=g>=h}return this.firstXY=null,b}},findTouch:function(a,b){for(var c,d=0,e=a.length;d<e&&(c=a[d]);d++)if(c.identifier===b)return!0},
vacuumTouches:function(a){var b=a.touches;
if(R.size>=b.length){var c=[];R.forEach(function(a,d){
if(1!==d&&!this.findTouch(b,d-2)){var e=a.out;c.push(e)}},this),c.forEach(this.cancelOut,this)}},touchstart:function(a){this.vacuumTouches(a),this.setPrimaryTouch(a.changedTouches[0]),this.dedupSynthMouse(a),this.scrolling||(this.clickCount++,this.processTouches(a,this.overDown))},overDown:function(a){R.set(a.pointerId,{target:a.target,out:a,outTarget:a.target}),u.enterOver(a),u.down(a)},touchmove:function(a){this.scrolling||(this.shouldScroll(a)?(this.scrolling=!0,this.touchcancel(a)):(a.preventDefault(),this.processTouches(a,this.moveOverOut)))},moveOverOut:function(a){var b=a,c=R.get(b.pointerId);
if(c){var d=c.out,e=c.outTarget;u.move(b),d&&e!==b.target&&(d.relatedTarget=b.target,b.relatedTarget=e,
d.target=e,b.target?(u.leaveOut(d),u.enterOver(b)):(
b.target=e,b.relatedTarget=null,this.cancelOut(b))),c.out=b,c.outTarget=b.target}},touchend:function(a){this.dedupSynthMouse(a),this.processTouches(a,this.upOut)},upOut:function(a){this.scrolling||(u.up(a),u.leaveOut(a)),this.cleanUpPointer(a)},touchcancel:function(a){this.processTouches(a,this.cancelOut)},cancelOut:function(a){u.cancel(a),u.leaveOut(a),this.cleanUpPointer(a)},cleanUpPointer:function(a){R["delete"](a.pointerId),this.removePrimaryPointer(a)},
dedupSynthMouse:function(a){var b=N.lastTouches,c=a.changedTouches[0];
if(this.isPrimaryTouch(c)){
var d={x:c.clientX,y:c.clientY};b.push(d);var e=function(a,b){var c=a.indexOf(b);c>-1&&a.splice(c,1)}.bind(null,b,d);setTimeout(e,S)}}};M=new c(V.elementAdded,V.elementRemoved,V.elementChanged,V);var W,X,Y,Z=u.pointermap,$=window.MSPointerEvent&&"number"==typeof window.MSPointerEvent.MSPOINTER_TYPE_MOUSE,_={events:["MSPointerDown","MSPointerMove","MSPointerUp","MSPointerOut","MSPointerOver","MSPointerCancel","MSGotPointerCapture","MSLostPointerCapture"],register:function(a){u.listen(a,this.events)},unregister:function(a){u.unlisten(a,this.events)},POINTER_TYPES:["","unavailable","touch","pen","mouse"],prepareEvent:function(a){var b=a;return $&&(b=u.cloneEvent(a),b.pointerType=this.POINTER_TYPES[a.pointerType]),b},cleanup:function(a){Z["delete"](a)},MSPointerDown:function(a){Z.set(a.pointerId,a);var b=this.prepareEvent(a);u.down(b)},MSPointerMove:function(a){var b=this.prepareEvent(a);u.move(b)},MSPointerUp:function(a){var b=this.prepareEvent(a);u.up(b),this.cleanup(a.pointerId)},MSPointerOut:function(a){var b=this.prepareEvent(a);u.leaveOut(b)},MSPointerOver:function(a){var b=this.prepareEvent(a);u.enterOver(b)},MSPointerCancel:function(a){var b=this.prepareEvent(a);u.cancel(b),this.cleanup(a.pointerId)},MSLostPointerCapture:function(a){var b=u.makeEvent("lostpointercapture",a);u.dispatchEvent(b)},MSGotPointerCapture:function(a){var b=u.makeEvent("gotpointercapture",a);u.dispatchEvent(b)}},aa=window.navigator;aa.msPointerEnabled?(W=function(a){i(a),j(this),k(a)&&(u.setCapture(a,this,!0),this.msSetPointerCapture(a))},X=function(a){i(a),u.releaseCapture(a,!0),this.msReleasePointerCapture(a)}):(W=function(a){i(a),j(this),k(a)&&u.setCapture(a,this)},X=function(a){i(a),u.releaseCapture(a)}),Y=function(a){return!!u.captureInfo[a]},g(),h(),l();var ba={dispatcher:u,Installer:c,PointerEvent:a,PointerMap:p,targetFinding:v};return ba});
var config = {"dark_mode": false, "show_pads": true, "show_fabrication": false, "show_silkscreen": true, "highlight_pin1": false, "redraw_on_drag": true, "board_rotation": 0, "checkboxes": "Sourced,Placed", "bom_view": "left-right", "layer_view": "FB", "extra_fields": []}
var pcbdata = JSON.parse(LZString.decompressFromBase64("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"))
/* Utility functions */
var storagePrefix = 'KiCad_HTML_BOM__' + pcbdata.metadata.title + '__' +
pcbdata.metadata.revision + '__#';
var storage;
function initStorage(key) {
try {
window.localStorage.getItem("blank");
storage = window.localStorage;
} catch (e) {
// localStorage not available
if (!storage) {
try {
window.sessionStorage.getItem("blank");
storage = window.sessionStorage;
} catch (e) {
// sessionStorage also not available
function readStorage(key) {
if (storage) {
return storage.getItem(storagePrefix + key);
} else {
return null;
function writeStorage(key, value) {
if (storage) {
storage.setItem(storagePrefix + key, value);
function fancyDblClickHandler(el, onsingle, ondouble) {
return function() {
if (el.getAttribute("data-dblclick") == null) {
el.setAttribute("data-dblclick", 1);
setTimeout(function() {
if (el.getAttribute("data-dblclick") == 1) {
onsingle();
el.removeAttribute("data-dblclick");
}, 200);
} else {
ondouble();
function smoothScrollToRow(rowid) {
document.getElementById(rowid).scrollIntoView({
behavior: "smooth",
block: "center",
inline: "nearest"
function focusInputField(input) {
input.scrollIntoView(false);
input.focus();
input.select();
function copyToClipboard() {
var text = '';
for (var node of bomhead.childNodes[0].childNodes) {
if (node.firstChild) {
text = text + node.firstChild.nodeValue;
if (node != bomhead.childNodes[0].lastChild) {
text += '\t';
text += '\n';
for (var row of bombody.childNodes) {
for (var cell of row.childNodes) {
for (var node of cell.childNodes) {
if (node.nodeName == "INPUT") {
if (node.checked) {
text = text + '✓';
} else if (node.nodeName == "MARK") {
} else {
text = text + node.nodeValue;
if (cell != row.lastChild) {
text += '\t';
text += '\n';
var textArea = document.createElement("textarea");
textArea.classList.add('clipboard-temp');
textArea.value = text;
document.body.appendChild(textArea);
textArea.focus();
textArea.select();
try {
if (document.execCommand('copy')) {
console.log('Bom copied to clipboard.');
} catch (err) {
console.log('Can not copy to clipboard.');
document.body.removeChild(textArea);
function removeGutterNode(node) {
for (var i = 0; i < node.childNodes.length; i++) {
if (node.childNodes[i].classList &&
node.childNodes[i].classList.contains("gutter")) {
node.removeChild(node.childNodes[i]);
break;
function cleanGutters() {
removeGutterNode(document.getElementById("bot"));
removeGutterNode(document.getElementById("canvasdiv"));
var units = {
prefixes: {
giga: ["G", "g", "giga", "Giga", "GIGA"],
mega: ["M", "mega", "Mega", "MEGA"],
kilo: ["K", "k", "kilo", "Kilo", "KILO"],
milli: ["m", "milli", "Milli", "MILLI"],
micro: ["U", "u", "micro", "Micro", "MICRO", "μ", "µ"], // different utf8 μ
nano: ["N", "n", "nano", "Nano", "NANO"],
pico: ["P", "p", "pico", "Pico", "PICO"],
unitsShort: ["R", "r", "Ω", "F", "f", "H", "h"],
unitsLong: [
"OHM", "Ohm", "ohm", "ohms",
"FARAD", "Farad", "farad",
"HENRY", "Henry", "henry"
getMultiplier: function(s) {
if (this.prefixes.giga.includes(s)) return 1e9;
if (this.prefixes.mega.includes(s)) return 1e6;
if (this.prefixes.kilo.includes(s)) return 1e3;
if (this.prefixes.milli.includes(s)) return 1e-3;
if (this.prefixes.micro.includes(s)) return 1e-6;
if (this.prefixes.nano.includes(s)) return 1e-9;
if (this.prefixes.pico.includes(s)) return 1e-12;
return 1;
valueRegex: null,
function initUtils() {
var allPrefixes = units.prefixes.giga
.concat(units.prefixes.mega)
.concat(units.prefixes.kilo)
.concat(units.prefixes.milli)
.concat(units.prefixes.micro)
.concat(units.prefixes.nano)
.concat(units.prefixes.pico);
var allUnits = units.unitsShort.concat(units.unitsLong);
units.valueRegex = new RegExp("^([0-9\.]+)" +
"\\s*(" + allPrefixes.join("|") + ")?" +
"(" + allUnits.join("|") + ")?" +
"(\\b.*)?$", "");
units.valueAltRegex = new RegExp("^([0-9]*)" +
"(" + units.unitsShort.join("|") + ")?" +
"([GgMmKkUuNnPp])?" +
"([0-9]*)" +
"(\\b.*)?$", "");
for (var bom_type of ["both", "F", "B"]) {
for (var row of pcbdata.bom[bom_type]) {
row.push(parseValue(row[1], row[3][0][0]));
function parseValue(val, ref) {
var inferUnit = (unit, ref) => {
if (unit) {
unit = unit.toLowerCase();
if (unit == 'Ω' || unit == "ohm" || unit == "ohms") {
unit = 'r';
unit = unit[0];
} else {
ref = /^([a-z]+)\d+$/i.exec(ref);
if (ref) {
ref = ref[1].toLowerCase();
if (ref == "c") unit = 'f';
else if (ref == "l") unit = 'h';
else if (ref == "r" || ref == "rv") unit = 'r';
else unit = null;
return unit;
val = val.replace(/,/g, "");
var match = units.valueRegex.exec(val);
var unit;
if (match) {
val = parseFloat(match[1]);
if (match[2]) {
val = val * units.getMultiplier(match[2]);
unit = inferUnit(match[3], ref);
if (!unit) return null;
else return {
val: val,
unit: unit,
extra: match[4],
match = units.valueAltRegex.exec(val);
if (match && (match[1] || match[4])) {
val = parseFloat(match[1] + "." + match[4]);
if (match[3]) {
val = val * units.getMultiplier(match[3]);
unit = inferUnit(match[2], ref);
else return {
val: val,
unit: unit,
extra: match[5],
return null;
function valueCompare(a, b, stra, strb) {
if (a === null && b === null) {
// Failed to parse both values, compare them as strings.
if (stra != strb) return stra > strb ? 1 : -1;
else return 0;
} else if (a === null) {
return 1;
} else if (b === null) {
return -1;
} else {
if (a.unit != b.unit) return a.unit > b.unit ? 1 : -1;
else if (a.val != b.val) return a.val > b.val ? 1 : -1;
else if (a.extra != b.extra) return a.extra > b.extra ? 1 : -1;
else return 0;
function validateSaveImgDimension(element) {
var valid = false;
var intValue = 0;
if (/^[1-9]\d*$/.test(element.value)) {
intValue = parseInt(element.value);
if (intValue <= 16000) {
valid = true;
if (valid) {
element.classList.remove("invalid");
} else {
element.classList.add("invalid");
return intValue;
function saveImage(layer) {
var width = validateSaveImgDimension(document.getElementById("render-save-width"));
var height = validateSaveImgDimension(document.getElementById("render-save-height"));
var bgcolor = null;
if (!document.getElementById("render-save-transparent").checked) {
var style = getComputedStyle(topmostdiv);
bgcolor = style.getPropertyValue("background-color");
if (!width || !height) return;
// Prepare image
var canvas = document.createElement("canvas");
var layerdict = {
transform: {
x: 0,
y: 0,
s: 1,
panx: 0,
pany: 0,
zoom: 1,
bg: canvas,
fab: canvas,
silk: canvas,
highlight: canvas,
layer: layer,
// Do the rendering
recalcLayerScale(layerdict, width, height);
prepareLayer(layerdict);
clearCanvas(canvas, bgcolor);
drawBackground(layerdict, false);
drawHighlightsOnLayer(layerdict, false);
// Save image
var imgdata = canvas.toDataURL("image/png");
var filename = pcbdata.metadata.title;
if (pcbdata.metadata.revision) {
filename += `.${pcbdata.metadata.revision}`;
filename += `.${layer}.png`;
saveFile(filename, dataURLtoBlob(imgdata));
function saveSettings() {
var data = {
type: "InteractiveHtmlBom settings",
version: 1,
pcbmetadata: pcbdata.metadata,
settings: settings,
var blob = new Blob([JSON.stringify(data, null, 4)], {type: "application/json"});
saveFile(`${pcbdata.metadata.title}.settings.json`, blob);
function loadSettings() {
var input = document.createElement("input");
input.type = "file";
input.accept = ".settings.json";
input.onchange = function(e) {
var file = e.target.files[0];
var reader = new FileReader();
reader.onload = readerEvent => {
var content = readerEvent.target.result;
var newSettings;
try {
newSettings = JSON.parse(content);
} catch(e) {
alert("Selected file is not InteractiveHtmlBom settings file.");
return;
if (newSettings.type != "InteractiveHtmlBom settings") {
return;
var metadataMatches = newSettings.hasOwnProperty("pcbmetadata");
if (metadataMatches) {
for (var k in pcbdata.metadata) {
if (!newSettings.pcbmetadata.hasOwnProperty(k) || newSettings.pcbmetadata[k] != pcbdata.metadata[k]) {
metadataMatches = false;
if (!metadataMatches) {
var currentMetadata = JSON.stringify(pcbdata.metadata, null, 4);
var fileMetadata = JSON.stringify(newSettings.pcbmetadata, null, 4);
if (!confirm(
`Settins file metadata does not match current metadata.\n\n` +
`Page metadata:\n${currentMetadata}\n\n` +
`Settings file metadata:\n${fileMetadata}\n\n` +
`Press OK if you would like to import settings anyway.`)) {
return;
overwriteSettings(newSettings.settings);
reader.readAsText(file, 'UTF-8');
input.click();
function overwriteSettings(newSettings) {
initDone = false;
Object.assign(settings, newSettings);
writeStorage("bomlayout", settings.bomlayout);
writeStorage("bommode", settings.bommode);
writeStorage("canvaslayout", settings.canvaslayout);
writeStorage("bomCheckboxes", settings.checkboxes.join(","));
document.getElementById("bomCheckboxes").value = settings.checkboxes.join(",");
for (var checkbox of settings.checkboxes) {
writeStorage("checkbox_" + checkbox, settings.checkboxStoredRefs[checkbox]);
writeStorage("darkenWhenChecked", settings.darkenWhenChecked);
padsVisible(settings.renderPads);
document.getElementById("padsCheckbox").checked = settings.renderPads;
fabricationVisible(settings.renderFabrication);
document.getElementById("fabricationCheckbox").checked = settings.renderFabrication;
silkscreenVisible(settings.renderSilkscreen);
document.getElementById("silkscreenCheckbox").checked = settings.renderSilkscreen;
referencesVisible(settings.renderReferences);
document.getElementById("referencesCheckbox").checked = settings.renderReferences;
valuesVisible(settings.renderValues);
document.getElementById("valuesCheckbox").checked = settings.renderValues;
tracksVisible(settings.renderTracks);
document.getElementById("tracksCheckbox").checked = settings.renderTracks;
zonesVisible(settings.renderZones);
document.getElementById("zonesCheckbox").checked = settings.renderZones;
dnpOutline(settings.renderDnpOutline);
document.getElementById("dnpOutlineCheckbox").checked = settings.renderDnpOutline;
setRedrawOnDrag(settings.redrawOnDrag);
document.getElementById("dragCheckbox").checked = settings.redrawOnDrag;
setDarkMode(settings.darkMode);
document.getElementById("darkmodeCheckbox").checked = settings.darkMode;
setHighlightPin1(settings.highlightpin1);
document.getElementById("highlightpin1Checkbox").checked = settings.highlightpin1;
writeStorage("boardRotation", settings.boardRotation);
document.getElementById("boardRotation").value = settings.boardRotation / 5;
document.getElementById("rotationDegree").textContent = settings.boardRotation;
initDone = true;
prepCheckboxes();
changeBomLayout(settings.bomlayout);
function saveFile(filename, blob) {
var link = document.createElement("a");
var objurl = URL.createObjectURL(blob);
link.download = filename;
link.href = objurl;
link.click();
function dataURLtoBlob(dataurl) {
var arr = dataurl.split(','), mime = arr[0].match(/:(.*?);/)[1],
bstr = atob(arr[1]), n = bstr.length, u8arr = new Uint8Array(n);
while(n--){
u8arr[n] = bstr.charCodeAt(n);
return new Blob([u8arr], {type:mime});
var settings = {
canvaslayout: "default",
bomlayout: "default",
bommode: "grouped",
checkboxes: [],
checkboxStoredRefs: {},
darkMode: false,
highlightpin1: false,
redrawOnDrag: true,
boardRotation: 0,
renderPads: true,
renderReferences: true,
renderValues: true,
renderSilkscreen: true,
renderFabrication: true,
renderDnpOutline: false,
renderTracks: true,
renderZones: true,
function initDefaults() {
settings.bomlayout = readStorage("bomlayout");
if (settings.bomlayout === null) {
settings.bomlayout = config.bom_view;
if (!['bom-only', 'left-right', 'top-bottom'].includes(settings.bomlayout)) {
settings.bommode = readStorage("bommode");
if (settings.bommode === null) {
settings.bommode = "grouped";
if (!["grouped", "ungrouped", "netlist"].includes(settings.bommode)) {
settings.canvaslayout = readStorage("canvaslayout");
if (settings.canvaslayout === null) {
settings.canvaslayout = config.layer_view;
var bomCheckboxes = readStorage("bomCheckboxes");
if (bomCheckboxes === null) {
bomCheckboxes = config.checkboxes;
settings.checkboxes = bomCheckboxes.split(",").filter((e) => e);
document.getElementById("bomCheckboxes").value = bomCheckboxes;
settings.darkenWhenChecked = readStorage("darkenWhenChecked") || "";
populateDarkenWhenCheckedOptions();
function initBooleanSetting(storageString, def, elementId, func) {
var b = readStorage(storageString);
if (b === null) {
b = def;
} else {
b = (b == "true");
document.getElementById(elementId).checked = b;
func(b);
initBooleanSetting("padsVisible", config.show_pads, "padsCheckbox", padsVisible);
initBooleanSetting("fabricationVisible", config.show_fabrication, "fabricationCheckbox", fabricationVisible);
initBooleanSetting("silkscreenVisible", config.show_silkscreen, "silkscreenCheckbox", silkscreenVisible);
initBooleanSetting("referencesVisible", true, "referencesCheckbox", referencesVisible);
initBooleanSetting("valuesVisible", true, "valuesCheckbox", valuesVisible);
if ("tracks" in pcbdata) {
initBooleanSetting("tracksVisible", true, "tracksCheckbox", tracksVisible);
initBooleanSetting("zonesVisible", true, "zonesCheckbox", zonesVisible);
} else {
document.getElementById("tracksAndZonesCheckboxes").style.display = "none";
tracksVisible(false);
zonesVisible(false);
initBooleanSetting("dnpOutline", false, "dnpOutlineCheckbox", dnpOutline);
initBooleanSetting("redrawOnDrag", config.redraw_on_drag, "dragCheckbox", setRedrawOnDrag);
initBooleanSetting("darkmode", config.dark_mode, "darkmodeCheckbox", setDarkMode);
initBooleanSetting("highlightpin1", config.highlight_pin1, "highlightpin1Checkbox", setHighlightPin1);
settings.boardRotation = readStorage("boardRotation");
if (settings.boardRotation === null) {
settings.boardRotation = config.board_rotation * 5;
} else {
settings.boardRotation = parseInt(settings.boardRotation);
/* PCB rendering code */
var emptyContext2d = document.createElement("canvas").getContext("2d");
function deg2rad(deg) {
return deg * Math.PI / 180;
function calcFontPoint(linepoint, text, offsetx, offsety, tilt) {
var point = [
linepoint[0] * text.width + offsetx,
linepoint[1] * text.height + offsety
// Adding half a line height here is technically a bug
// but pcbnew currently does the same, text is slightly shifted.
point[0] -= (point[1] + text.height * 0.5) * tilt;
return point;
function drawtext(ctx, text, color, flip) {
if ("ref" in text && !settings.renderReferences) return;
if ("val" in text && !settings.renderValues) return;
ctx.save();
ctx.fillStyle = color;
ctx.strokeStyle = color;
ctx.lineCap = "round";
ctx.lineJoin = "round";
ctx.lineWidth = text.thickness;
if (text.svgpath) {
ctx.stroke(new Path2D(text.svgpath));
ctx.restore();
return;
ctx.translate(...text.pos);
var angle = -text.angle;
if (text.attr.includes("mirrored")) {
ctx.scale(-1, 1);
angle = -angle;
var tilt = 0;
if (text.attr.includes("italic")) {
tilt = 0.125;
var interline = (text.height * 1.5 + text.thickness) / 2;
var txt = text.text.split("\n");
// KiCad ignores last empty line.
if (txt[txt.length - 1] == '') txt.pop();
ctx.rotate(deg2rad(angle));
for (var i in txt) {
var offsety = (-(txt.length - 1) + i * 2) * interline + text.height / 2;
var lineWidth = 0;
for (var c of txt[i]) {
if (c == '\t') {
var fourSpaces = 4 * pcbdata.font_data[' '].w * text.width;
lineWidth += fourSpaces - lineWidth % fourSpaces;
} else {
lineWidth += pcbdata.font_data[c].w * text.width;
var offsetx = 0;
switch (text.horiz_justify) {
case -1:
// Justify left, do nothing
break;
case 0:
// Justify center
offsetx -= lineWidth / 2;
break;
case 1:
// Justify right
offsetx -= lineWidth;
break;
if (c == '\t') {
offsetx += fourSpaces - offsetx % fourSpaces;
continue;
for (var line of pcbdata.font_data[c].l) {
ctx.beginPath();
ctx.moveTo(...calcFontPoint(line[0], text, offsetx, offsety, tilt));
for (var i = 1; i < line.length; i++) {
ctx.lineTo(...calcFontPoint(line[i], text, offsetx, offsety, tilt));
ctx.stroke();
offsetx += pcbdata.font_data[c].w * text.width;
ctx.restore();
function drawedge(ctx, scalefactor, edge, color) {
ctx.lineWidth = Math.max(1 / scalefactor, edge.width);
if (edge.svgpath) {
ctx.stroke(new Path2D(edge.svgpath));
} else {
ctx.beginPath();
if (edge.type == "segment") {
ctx.moveTo(...edge.start);
ctx.lineTo(...edge.end);
if (edge.type == "arc") {
ctx.arc(
...edge.start,
edge.radius,
deg2rad(edge.startangle),
deg2rad(edge.endangle));
if (edge.type == "circle") {
ctx.arc(
...edge.start,
edge.radius,
0, 2 * Math.PI);
ctx.closePath();
if (edge.type == "curve") {
ctx.bezierCurveTo(...edge.cpa, ...edge.cpb, ...edge.end);
ctx.stroke();
function getChamferedRectPath(size, radius, chamfpos, chamfratio) {
// chamfpos is a bitmask, left = 1, right = 2, bottom left = 4, bottom right = 8
var path = new Path2D();
var width = size[0];
var height = size[1];
var x = width * -0.5;
var y = height * -0.5;
var chamfOffset = Math.min(width, height) * chamfratio;
path.moveTo(x, 0);
if (chamfpos & 4) {
path.lineTo(x, y + height - chamfOffset);
path.lineTo(x + chamfOffset, y + height);
path.lineTo(0, y + height);
} else {
path.arcTo(x, y + height, x + width, y + height, radius);
if (chamfpos & 8) {
path.lineTo(x + width - chamfOffset, y + height);
path.lineTo(x + width, y + height - chamfOffset);
path.lineTo(x + width, 0);
} else {
path.arcTo(x + width, y + height, x + width, y, radius);
if (chamfpos & 2) {
path.lineTo(x + width, y + chamfOffset);
path.lineTo(x + width - chamfOffset, y);
path.lineTo(0, y);
} else {
path.arcTo(x + width, y, x, y, radius);
if (chamfpos & 1) {
path.lineTo(x + chamfOffset, y);
path.lineTo(x, y + chamfOffset);
path.lineTo(x, 0);
} else {
path.arcTo(x, y, x, y + height, radius);
path.closePath();
return path;
function getOblongPath(size) {
return getChamferedRectPath(size, Math.min(size[0], size[1]) / 2, 0, 0);
function getPolygonsPath(shape) {
if (shape.path2d) {
return shape.path2d;
if (shape.svgpath) {
shape.path2d = new Path2D(shape.svgpath);
} else {
for (var polygon of shape.polygons) {
path.moveTo(...polygon[0]);
for (var i = 1; i < polygon.length; i++) {
path.lineTo(...polygon[i]);
path.closePath();
shape.path2d = path;
function drawPolygonShape(ctx, shape, color) {
ctx.save();
if (!shape.svgpath) {
ctx.translate(...shape.pos);
ctx.rotate(deg2rad(-shape.angle));
ctx.fill(getPolygonsPath(shape));
ctx.restore();
function drawDrawing(ctx, layer, scalefactor, drawing, color) {
if (["segment", "arc", "circle", "curve"].includes(drawing.type)) {
drawedge(ctx, scalefactor, drawing, color);
} else if (drawing.type == "polygon") {
drawPolygonShape(ctx, drawing, color);
} else {
drawtext(ctx, drawing, color, layer == "B");
function getCirclePath(radius) {
path.arc(0, 0, radius, 0, 2 * Math.PI);
path.closePath();
return path;
function getCachedPadPath(pad) {
if (!pad.path2d) {
// if path2d is not set, build one and cache it on pad object
if (pad.shape == "rect") {
pad.path2d = new Path2D();
pad.path2d.rect(...pad.size.map(c => -c * 0.5), ...pad.size);
} else if (pad.shape == "oval") {
pad.path2d = getOblongPath(pad.size);
} else if (pad.shape == "circle") {
pad.path2d = getCirclePath(pad.size[0] / 2);
} else if (pad.shape == "roundrect") {
pad.path2d = getChamferedRectPath(pad.size, pad.radius, 0, 0);
} else if (pad.shape == "chamfrect") {
pad.path2d = getChamferedRectPath(pad.size, pad.radius, pad.chamfpos, pad.chamfratio)
} else if (pad.shape == "custom") {
pad.path2d = getPolygonsPath(pad);
return pad.path2d;
function drawPad(ctx, pad, color, outline, hole) {
ctx.save();
ctx.translate(...pad.pos);
ctx.rotate(deg2rad(pad.angle));
if (pad.offset) {
ctx.translate(...pad.offset);
var path = getCachedPadPath(pad);
if (outline) {
ctx.stroke(path);
} else {
ctx.fill(path);
if (pad.type == "th" && hole) {
if (pad.offset) {
ctx.translate(-pad.offset[0], -pad.offset[1]);
ctx.fillStyle = "#CCCCCC";
if (pad.drillshape == "oblong") {
ctx.fill(getOblongPath(pad.drillsize));
} else {
ctx.fill(getCirclePath(pad.drillsize[0] / 2));
ctx.restore();
function drawModule(ctx, layer, scalefactor, module, padcolor, outlinecolor, highlight, outline) {
if (highlight) {
// draw bounding box
if (module.layer == layer) {
ctx.save();
ctx.globalAlpha = 0.2;
ctx.translate(...module.bbox.pos);
ctx.rotate(deg2rad(-module.bbox.angle));
ctx.translate(...module.bbox.relpos);
ctx.fillStyle = padcolor;
ctx.fillRect(0, 0, ...module.bbox.size);
ctx.globalAlpha = 1;
ctx.strokeStyle = padcolor;
ctx.strokeRect(0, 0, ...module.bbox.size);
ctx.restore();
// draw drawings
for (var drawing of module.drawings) {
if (drawing.layer == layer) {
drawDrawing(ctx, layer, scalefactor, drawing.drawing, padcolor);
// draw pads
if (settings.renderPads) {
for (var pad of module.pads) {
if (pad.layers.includes(layer)) {
drawPad(ctx, pad, padcolor, outline, true);
if (pad.pin1 && settings.highlightpin1) {
drawPad(ctx, pad, outlinecolor, true, false);
function drawEdgeCuts(canvas, scalefactor) {
var ctx = canvas.getContext("2d");
var edgecolor = getComputedStyle(topmostdiv).getPropertyValue('--pcb-edge-color');
for (var edge of pcbdata.edges) {
drawedge(ctx, scalefactor, edge, edgecolor);
function drawModules(canvas, layer, scalefactor, highlight) {
ctx.lineWidth = 3 / scalefactor;
var padcolor = style.getPropertyValue('--pad-color');
var outlinecolor = style.getPropertyValue('--pin1-outline-color');
if (highlight) {
padcolor = style.getPropertyValue('--pad-color-highlight');
outlinecolor = style.getPropertyValue('--pin1-outline-color-highlight');
for (var i = 0; i < pcbdata.modules.length; i++) {
var mod = pcbdata.modules[i];
var outline = settings.renderDnpOutline && pcbdata.bom.skipped.includes(i);
if (!highlight || highlightedModules.includes(i)) {
drawModule(ctx, layer, scalefactor, mod, padcolor, outlinecolor, highlight, outline);
function drawBgLayer(layername, canvas, layer, scalefactor, edgeColor, polygonColor, textColor) {
for (var d of pcbdata[layername][layer]) {
if (["segment", "arc", "circle", "curve"].includes(d.type)) {
drawedge(ctx, scalefactor, d, edgeColor);
} else if (d.type == "polygon") {
drawPolygonShape(ctx, d, polygonColor);
} else {
drawtext(ctx, d, textColor, layer == "B");
function drawTracks(canvas, layer, color, highlight) {
for(var track of pcbdata.tracks[layer]) {
if (highlight && highlightedNet != track.net) continue;
ctx.lineWidth = track.width;
ctx.beginPath();
ctx.moveTo(...track.start);
ctx.lineTo(...track.end);
ctx.stroke();
function drawZones(canvas, layer, color, highlight) {
for(var zone of pcbdata.zones[layer]) {
if (!zone.path2d) {
zone.path2d = getPolygonsPath(zone);
if (highlight && highlightedNet != zone.net) continue;
ctx.lineWidth = zone.width ? zone.width : 0;
ctx.fill(zone.path2d);
ctx.stroke(zone.path2d);
function clearCanvas(canvas, color = null) {
ctx.save();
ctx.setTransform(1, 0, 0, 1, 0, 0);
if (color) {
ctx.fillRect(0, 0, canvas.width, canvas.height);
} else {
ctx.clearRect(0, 0, canvas.width, canvas.height);
ctx.restore();
function drawNets(canvas, layer, highlight) {
if (settings.renderTracks) {
var trackColor = style.getPropertyValue(highlight ? '--track-color-highlight' : '--track-color');
drawTracks(canvas, layer, trackColor, highlight);
if (settings.renderZones) {
var zoneColor = style.getPropertyValue(highlight ? '--zone-color-highlight' : '--zone-color');
drawZones(canvas, layer, zoneColor, highlight);
if (highlight && settings.renderPads) {
var padColor = style.getPropertyValue('--pad-color-highlight');
for (var mod of pcbdata.modules) {
// draw pads
for (var pad of mod.pads) {
if (highlightedNet != pad.net) continue;
drawPad(ctx, pad, padColor, false, true);
function drawHighlightsOnLayer(canvasdict, clear = true) {
if (clear) {
clearCanvas(canvasdict.highlight);
if (highlightedModules.length > 0) {
drawModules(canvasdict.highlight, canvasdict.layer,
canvasdict.transform.s * canvasdict.transform.zoom, true);
if (highlightedNet !== null) {
drawNets(canvasdict.highlight, canvasdict.layer, true);
function drawHighlights() {
drawHighlightsOnLayer(allcanvas.front);
drawHighlightsOnLayer(allcanvas.back);
function drawBackground(canvasdict, clear = true) {
if (clear) {
clearCanvas(canvasdict.bg);
clearCanvas(canvasdict.fab);
clearCanvas(canvasdict.silk);
drawNets(canvasdict.bg, canvasdict.layer, false);
drawModules(canvasdict.bg, canvasdict.layer,
canvasdict.transform.s * canvasdict.transform.zoom, false);
drawEdgeCuts(canvasdict.bg, canvasdict.transform.s);
var edgeColor = style.getPropertyValue('--silkscreen-edge-color');
var polygonColor = style.getPropertyValue('--silkscreen-polygon-color');
var textColor = style.getPropertyValue('--silkscreen-text-color');
if (settings.renderSilkscreen) {
drawBgLayer(
"silkscreen", canvasdict.silk, canvasdict.layer,
edgeColor, polygonColor, textColor);
edgeColor = style.getPropertyValue('--fabrication-edge-color');
polygonColor = style.getPropertyValue('--fabrication-polygon-color');
textColor = style.getPropertyValue('--fabrication-text-color');
if (settings.renderFabrication) {
drawBgLayer(
"fabrication", canvasdict.fab, canvasdict.layer,
function prepareCanvas(canvas, flip, transform) {
var fontsize = 1.55;
ctx.scale(transform.zoom, transform.zoom);
ctx.translate(transform.panx, transform.pany);
if (flip) {
ctx.scale(-1, 1);
ctx.translate(transform.x, transform.y);
ctx.rotate(deg2rad(settings.boardRotation));
ctx.scale(transform.s, transform.s);
function prepareLayer(canvasdict) {
var flip = (canvasdict.layer == "B");
for (var c of ["bg", "fab", "silk", "highlight"]) {
prepareCanvas(canvasdict[c], flip, canvasdict.transform);
function rotateVector(v, angle) {
angle = deg2rad(angle);
return [
v[0] * Math.cos(angle) - v[1] * Math.sin(angle),
v[0] * Math.sin(angle) + v[1] * Math.cos(angle)
function applyRotation(bbox) {
var corners = [
[bbox.minx, bbox.miny],
[bbox.minx, bbox.maxy],
[bbox.maxx, bbox.miny],
[bbox.maxx, bbox.maxy],
corners = corners.map((v) => rotateVector(v, settings.boardRotation));
return {
minx: corners.reduce((a, v) => Math.min(a, v[0]), Infinity),
miny: corners.reduce((a, v) => Math.min(a, v[1]), Infinity),
maxx: corners.reduce((a, v) => Math.max(a, v[0]), -Infinity),
maxy: corners.reduce((a, v) => Math.max(a, v[1]), -Infinity),
function recalcLayerScale(layerdict, width, height) {
var bbox = applyRotation(pcbdata.edges_bbox);
var scalefactor = 0.98 * Math.min(
width / (bbox.maxx - bbox.minx),
height / (bbox.maxy - bbox.miny)
if (scalefactor < 0.1) {
scalefactor = 1;
layerdict.transform.s = scalefactor;
var flip = (layerdict.layer == "B");
if (flip) {
layerdict.transform.x = -((bbox.maxx + bbox.minx) * scalefactor + width) * 0.5;
} else {
layerdict.transform.x = -((bbox.maxx + bbox.minx) * scalefactor - width) * 0.5;
layerdict.transform.y = -((bbox.maxy + bbox.miny) * scalefactor - height) * 0.5;
canvas = layerdict[c];
canvas.width = width;
canvas.height = height;
canvas.style.width = (width / devicePixelRatio) + "px";
canvas.style.height = (height / devicePixelRatio) + "px";
function redrawCanvas(layerdict) {
drawBackground(layerdict);
drawHighlightsOnLayer(layerdict);
function resizeCanvas(layerdict) {
var canvasdivid = {
"F": "frontcanvas",
"B": "backcanvas"
} [layerdict.layer];
var width = document.getElementById(canvasdivid).clientWidth * devicePixelRatio;
var height = document.getElementById(canvasdivid).clientHeight * devicePixelRatio;
redrawCanvas(layerdict);
function resizeAll() {
resizeCanvas(allcanvas.front);
resizeCanvas(allcanvas.back);
function pointWithinDistanceToSegment(x, y, x1, y1, x2, y2, d) {
var A = x - x1;
var B = y - y1;
var C = x2 - x1;
var D = y2 - y1;
var dot = A * C + B * D;
var len_sq = C * C + D * D;
var dx, dy;
if (len_sq == 0) {
// start and end of the segment coincide
dx = x - x1;
dy = y - y1;
} else {
var param = dot / len_sq;
var xx, yy;
if (param < 0) {
xx = x1;
yy = y1;
} else if (param > 1) {
xx = x2;
yy = y2;
} else {
xx = x1 + param * C;
yy = y1 + param * D;
dx = x - xx;
dy = y - yy;
return dx * dx + dy * dy <= d * d;
function pointWithinPad(x, y, pad) {
var v = [x - pad.pos[0], y - pad.pos[1]];
v = rotateVector(v, -pad.angle);
if (pad.offset) {
v[0] -= pad.offset[0];
v[1] -= pad.offset[1];
return emptyContext2d.isPointInPath(getCachedPadPath(pad), ...v);
function netHitScan(layer, x, y) {
// Check track segments
if (settings.renderTracks && pcbdata.tracks) {
if (pointWithinDistanceToSegment(x, y, ...track.start, ...track.end, track.width / 2)) {
return track.net;
// Check pads
for(var pad of mod.pads) {
if (pad.layers.includes(layer) && pointWithinPad(x, y, pad)) {
return pad.net;
return null;
function pointWithinModuleBbox(x, y, bbox) {
var v = [x - bbox.pos[0], y - bbox.pos[1]];
v = rotateVector(v, bbox.angle);
return bbox.relpos[0] <= v[0] && v[0] <= bbox.relpos[0] + bbox.size[0] &&
bbox.relpos[1] <= v[1] && v[1] <= bbox.relpos[1] + bbox.size[1];
function bboxHitScan(layer, x, y) {
var result = [];
var module = pcbdata.modules[i];
if (pointWithinModuleBbox(x, y, module.bbox)) {
result.push(i);
return result;
function handlePointerDown(e, layerdict) {
if (e.button != 0) {
return;
e.preventDefault();
e.stopPropagation();
if (!e.hasOwnProperty("offsetX")) {
// The polyfill doesn't set this properly
e.offsetX = e.pageX - e.currentTarget.offsetLeft;
e.offsetY = e.pageY - e.currentTarget.offsetTop;
layerdict.pointerStates[e.pointerId] = {
distanceTravelled: 0,
lastX: e.offsetX,
lastY: e.offsetY,
downTime: Date.now(),
function handleMouseClick(e, layerdict) {
var x = e.offsetX;
var y = e.offsetY;
var t = layerdict.transform;
if (layerdict.layer == "B") {
x = (devicePixelRatio * x / t.zoom - t.panx + t.x) / -t.s;
} else {
x = (devicePixelRatio * x / t.zoom - t.panx - t.x) / t.s;
y = (devicePixelRatio * y / t.zoom - t.y - t.pany) / t.s;
var v = rotateVector([x, y], -settings.boardRotation);
if ("nets" in pcbdata) {
var net = netHitScan(layerdict.layer, ...v);
if (net !== highlightedNet) {
netClicked(net);
if (highlightedNet === null) {
var modules = bboxHitScan(layerdict.layer, ...v);
if (modules.length > 0) {
modulesClicked(modules);
function handlePointerLeave(e, layerdict) {
e.preventDefault();
if (!settings.redrawOnDrag) {
delete layerdict.pointerStates[e.pointerId];
function resetTransform(layerdict) {
layerdict.transform.panx = 0;
layerdict.transform.pany = 0;
layerdict.transform.zoom = 1;
function handlePointerUp(e, layerdict) {
e.preventDefault();
if (e.button == 2) {
// Reset pan and zoom on right click.
resetTransform(layerdict);
layerdict.anotherPointerTapped = false;
return;
// We haven't necessarily had a pointermove event since the interaction started, so make sure we update this now
var ptr = layerdict.pointerStates[e.pointerId];
ptr.distanceTravelled += Math.abs(e.offsetX - ptr.lastX) + Math.abs(e.offsetY - ptr.lastY);
if (e.button == 0 && ptr.distanceTravelled < 10 && Date.now() - ptr.downTime <= 500) {
if (Object.keys(layerdict.pointerStates).length == 1) {
if (layerdict.anotherPointerTapped) {
// This is the second pointer coming off of a two-finger tap
} else {
// This is just a regular tap
handleMouseClick(e, layerdict);
} else {
// This is the first finger coming off of what could become a two-finger tap
layerdict.anotherPointerTapped = true;
} else {
function handlePointerMove(e, layerdict) {
if (!layerdict.pointerStates.hasOwnProperty(e.pointerId)) {
return;
e.preventDefault();
var thisPtr = layerdict.pointerStates[e.pointerId];
var dx = e.offsetX - thisPtr.lastX;
var dy = e.offsetY - thisPtr.lastY;
// If this number is low on pointer up, we count the action as a click
thisPtr.distanceTravelled += Math.abs(dx) + Math.abs(dy);
// This is a simple drag
layerdict.transform.panx += devicePixelRatio * dx / layerdict.transform.zoom;
layerdict.transform.pany += devicePixelRatio * dy / layerdict.transform.zoom;
} else if (Object.keys(layerdict.pointerStates).length == 2) {
var otherPtr = Object.values(layerdict.pointerStates).filter((ptr) => ptr != thisPtr)[0];
var oldDist = Math.sqrt(Math.pow(thisPtr.lastX - otherPtr.lastX, 2) + Math.pow(thisPtr.lastY - otherPtr.lastY, 2));
var newDist = Math.sqrt(Math.pow(e.offsetX - otherPtr.lastX, 2) + Math.pow(e.offsetY - otherPtr.lastY, 2));
var scaleFactor = newDist/oldDist;
if (scaleFactor != NaN) {
layerdict.transform.zoom *= scaleFactor;
var zoomd = (1 - scaleFactor) / layerdict.transform.zoom;
layerdict.transform.panx += devicePixelRatio * otherPtr.lastX * zoomd;
layerdict.transform.pany += devicePixelRatio * otherPtr.lastY * zoomd;
thisPtr.lastX = e.offsetX;
thisPtr.lastY = e.offsetY;
if (settings.redrawOnDrag) {
function handleMouseWheel(e, layerdict) {
e.preventDefault();
var wheeldelta = e.deltaY;
if (e.deltaMode == 1) {
// FF only, scroll by lines
wheeldelta *= 30;
} else if (e.deltaMode == 2) {
wheeldelta *= 300;
var m = Math.pow(1.1, -wheeldelta / 40);
// Limit amount of zoom per tick.
if (m > 2) {
m = 2;
} else if (m < 0.5) {
m = 0.5;
t.zoom *= m;
var zoomd = (1 - m) / t.zoom;
t.panx += devicePixelRatio * e.offsetX * zoomd;
t.pany += devicePixelRatio * e.offsetY * zoomd;
function addMouseHandlers(div, layerdict) {
div.addEventListener("pointerdown", function(e) {
handlePointerDown(e, layerdict);
div.addEventListener("pointermove", function(e) {
handlePointerMove(e, layerdict);
div.addEventListener("pointerup", function(e) {
handlePointerUp(e, layerdict);
var pointerleave = function(e) {
handlePointerLeave(e, layerdict);
div.addEventListener("pointercancel", pointerleave);
div.addEventListener("pointerleave", pointerleave);
div.addEventListener("pointerout", pointerleave);
div.onwheel = function(e) {
handleMouseWheel(e, layerdict);
for (var element of [div, layerdict.bg, layerdict.fab, layerdict.silk, layerdict.highlight]) {
element.addEventListener("contextmenu", function(e) {
e.preventDefault();
}, false);
function setRedrawOnDrag(value) {
settings.redrawOnDrag = value;
writeStorage("redrawOnDrag", value);
function setBoardRotation(value) {
settings.boardRotation = value * 5;
resizeAll();
function initRender() {
allcanvas = {
front: {
transform: {
x: 0,
y: 0,
s: 1,
panx: 0,
pany: 0,
zoom: 1,
pointerStates: {},
anotherPointerTapped: false,
bg: document.getElementById("F_bg"),
fab: document.getElementById("F_fab"),
silk: document.getElementById("F_slk"),
highlight: document.getElementById("F_hl"),
layer: "F",
back: {
transform: {
x: 0,
y: 0,
s: 1,
panx: 0,
pany: 0,
zoom: 1,
pointerStates: {},
bg: document.getElementById("B_bg"),
fab: document.getElementById("B_fab"),
silk: document.getElementById("B_slk"),
highlight: document.getElementById("B_hl"),
layer: "B",
addMouseHandlers(document.getElementById("frontcanvas"), allcanvas.front);
addMouseHandlers(document.getElementById("backcanvas"), allcanvas.back);
/* DOM manipulation and misc code */
var bomsplit;
var canvassplit;
var initDone = false;
var bomSortFunction = null;
var currentSortColumn = null;
var currentSortOrder = null;
var currentHighlightedRowId;
var highlightHandlers = [];
var moduleIndexToHandler = {};
var netsToHandler = {};
var highlightedModules = [];
var highlightedNet = null;
var lastClicked;
function dbg(html) {
dbgdiv.innerHTML = html;
function redrawIfInitDone() {
if (initDone) {
redrawCanvas(allcanvas.front);
redrawCanvas(allcanvas.back);
function padsVisible(value) {
writeStorage("padsVisible", value);
settings.renderPads = value;
redrawIfInitDone();
function referencesVisible(value) {
writeStorage("referencesVisible", value);
settings.renderReferences = value;
redrawIfInitDone();
function valuesVisible(value) {
writeStorage("valuesVisible", value);
settings.renderValues = value;
redrawIfInitDone();
function tracksVisible(value) {
writeStorage("tracksVisible", value);
settings.renderTracks = value;
redrawIfInitDone();
function zonesVisible(value) {
writeStorage("zonesVisible", value);
settings.renderZones = value;
redrawIfInitDone();
function dnpOutline(value) {
writeStorage("dnpOutline", value);
settings.renderDnpOutline = value;
redrawIfInitDone();
function setDarkMode(value) {
if (value) {
topmostdiv.classList.add("dark");
} else {
topmostdiv.classList.remove("dark");
writeStorage("darkmode", value);
settings.darkMode = value;
redrawIfInitDone();
function setFullscreen(value) {
if (value) {
document.documentElement.requestFullscreen();
} else {
document.exitFullscreen();
function fabricationVisible(value) {
writeStorage("fabricationVisible", value);
settings.renderFabrication = value;
redrawIfInitDone();
function silkscreenVisible(value) {
writeStorage("silkscreenVisible", value);
settings.renderSilkscreen = value;
redrawIfInitDone();
function setHighlightPin1(value) {
writeStorage("highlightpin1", value);
settings.highlightpin1 = value;
redrawIfInitDone();
function getStoredCheckboxRefs(checkbox) {
function convert(ref) {
var intref = parseInt(ref);
if (isNaN(intref)) {
if (pcbdata.modules[i].ref == ref) {
return i;
return -1;
} else {
return intref;
if (!(checkbox in settings.checkboxStoredRefs)) {
var val = readStorage("checkbox_" + checkbox);
settings.checkboxStoredRefs[checkbox] = val ? val : "";
if (!settings.checkboxStoredRefs[checkbox]) {
return new Set();
} else {
return new Set(settings.checkboxStoredRefs[checkbox].split(",").map(r => convert(r)).filter(a => a >= 0));
function getCheckboxState(checkbox, references) {
var storedRefsSet = getStoredCheckboxRefs(checkbox);
var currentRefsSet = new Set(references.map(r => r[1]));
// Get difference of current - stored
var difference = new Set(currentRefsSet);
for (ref of storedRefsSet) {
difference.delete(ref);
if (difference.size == 0) {
// All the current refs are stored
return "checked";
} else if (difference.size == currentRefsSet.size) {
// None of the current refs are stored
return "unchecked";
} else {
// Some of the refs are stored
return "indeterminate";
function setBomCheckboxState(checkbox, element, references) {
var state = getCheckboxState(checkbox, references);
element.checked = (state == "checked");
element.indeterminate = (state == "indeterminate");
function createCheckboxChangeHandler(checkbox, references) {
return function(evt) {
refsSet = getStoredCheckboxRefs(checkbox);
var darkenWhenChecked = settings.darkenWhenChecked == checkbox;
if (this.checked) {
// checkbox ticked
for (var ref of references) {
refsSet.add(ref[1]);
if (darkenWhenChecked) {
evt.target.parentElement.parentElement.classList.add("checked");
} else {
// checkbox unticked
refsSet.delete(ref[1]);
evt.target.parentElement.parentElement.classList.remove("checked");
settings.checkboxStoredRefs[checkbox] = [...refsSet].join(",");
updateCheckboxStats(checkbox);
function clearHighlightedModules() {
if (currentHighlightedRowId) {
document.getElementById(currentHighlightedRowId).classList.remove("highlighted");
currentHighlightedRowId = null;
function createRowHighlightHandler(rowid, refs, net) {
return function() {
if (currentHighlightedRowId == rowid) {
return;
document.getElementById(rowid).classList.add("highlighted");
currentHighlightedRowId = rowid;
highlightedModules = refs ? refs.map(r => r[1]) : [];
highlightedNet = net;
drawHighlights();
function entryMatches(entry) {
if (settings.bommode == "netlist") {
// entry is just a net name
return entry.toLowerCase().indexOf(filter) >= 0;
// check refs
for (var ref of entry[3]) {
if (ref[0].toLowerCase().indexOf(filter) >= 0) {
return true;
// check extra fields
for (var i in config.extra_fields) {
if (entry[4][i].toLowerCase().indexOf(filter) >= 0) {
return true;
// check value
if (entry[1].toLowerCase().indexOf(filter) >= 0) {
return true;
// check footprint
if (entry[2].toLowerCase().indexOf(filter) >= 0) {
return true;
return false;
function findRefInEntry(entry) {
return entry[3].filter(r => r[0].toLowerCase() == reflookup);
function highlightFilter(s) {
if (!filter) {
return s;
var parts = s.toLowerCase().split(filter);
if (parts.length == 1) {
return s;
var r = "";
var pos = 0;
for (var i in parts) {
if (i > 0) {
r += '<mark class="highlight">' +
s.substring(pos, pos + filter.length) +
'</mark>';
pos += filter.length;
r += s.substring(pos, pos + parts[i].length);
pos += parts[i].length;
return r;
function checkboxSetUnsetAllHandler(checkboxname) {
return function() {
var checkboxnum = 0;
while (checkboxnum < settings.checkboxes.length &&
settings.checkboxes[checkboxnum].toLowerCase() != checkboxname.toLowerCase()) {
checkboxnum++;
if (checkboxnum >= settings.checkboxes.length) {
return;
var allset = true;
var checkbox;
var row;
for (row of bombody.childNodes) {
checkbox = row.childNodes[checkboxnum + 1].childNodes[0];
if (!checkbox.checked || checkbox.indeterminate) {
allset = false;
break;
checkbox.checked = !allset;
checkbox.indeterminate = false;
checkbox.onchange();
function createColumnHeader(name, cls, comparator) {
var th = document.createElement("TH");
th.innerHTML = name;
th.classList.add(cls);
th.style.cursor = "pointer";
var span = document.createElement("SPAN");
span.classList.add("sortmark");
span.classList.add("none");
th.appendChild(span);
th.onclick = function() {
if (currentSortColumn && this !== currentSortColumn) {
// Currently sorted by another column
currentSortColumn.childNodes[1].classList.remove(currentSortOrder);
currentSortColumn.childNodes[1].classList.add("none");
if (currentSortColumn && this === currentSortColumn) {
// Already sorted by this column
if (currentSortOrder == "asc") {
// Sort by this column, descending order
bomSortFunction = function(a, b) {
return -comparator(a, b);
currentSortColumn.childNodes[1].classList.remove("asc");
currentSortColumn.childNodes[1].classList.add("desc");
currentSortOrder = "desc";
} else {
// Unsort
currentSortColumn.childNodes[1].classList.remove("desc");
} else {
// Sort by this column, ascending order
bomSortFunction = comparator;
currentSortColumn = this;
currentSortColumn.childNodes[1].classList.remove("none");
currentSortColumn.childNodes[1].classList.add("asc");
currentSortOrder = "asc";
populateBomBody();
return th;
function populateBomHeader() {
while (bomhead.firstChild) {
bomhead.removeChild(bomhead.firstChild);
var tr = document.createElement("TR");
th.classList.add("numCol");
tr.appendChild(th);
var checkboxCompareClosure = function(checkbox) {
return (a, b) => {
var stateA = getCheckboxState(checkbox, a[3]);
var stateB = getCheckboxState(checkbox, b[3]);
if (stateA > stateB) return -1;
if (stateA < stateB) return 1;
return 0;
th = createColumnHeader("Net name", "bom-netname", (a, b) => {
if (a > b) return -1;
if (a < b) return 1;
return 0;
tr.appendChild(th);
} else {
checkbox, "bom-checkbox", checkboxCompareClosure(checkbox));
th.onclick = fancyDblClickHandler(
th, th.onclick.bind(th), checkboxSetUnsetAllHandler(checkbox));
tr.appendChild(th);
tr.appendChild(createColumnHeader("References", "References", (a, b) => {
var i = 0;
while (i < a[3].length && i < b[3].length) {
if (a[3][i] != b[3][i]) return a[3][i] > b[3][i] ? 1 : -1;
i++;
return a[3].length - b[3].length;
// Extra fields
if (config.extra_fields.length > 0) {
var extraFieldCompareClosure = function(fieldIndex) {
return (a, b) => {
var fa = a[4][fieldIndex];
var fb = b[4][fieldIndex];
if (fa != fb) return fa > fb ? 1 : -1;
else return 0;
config.extra_fields[i], "extra", extraFieldCompareClosure(i)));
tr.appendChild(createColumnHeader("Value", "Value", (a, b) => {
return valueCompare(a[5], b[5], a[1], b[1]);
tr.appendChild(createColumnHeader("Footprint", "Footprint", (a, b) => {
if (a[2] != b[2]) return a[2] > b[2] ? 1 : -1;
else return 0;
if (settings.bommode == "grouped") {
tr.appendChild(createColumnHeader("Quantity", "Quantity", (a, b) => {
bomhead.appendChild(tr);
function populateBomBody() {
while (bom.firstChild) {
bom.removeChild(bom.firstChild);
netsToHandler = {};
var first = true;
bomtable = pcbdata.nets.slice();
} else {
switch (settings.canvaslayout) {
case 'F':
bomtable = pcbdata.bom.F.slice();
break;
case 'FB':
bomtable = pcbdata.bom.both.slice();
break;
case 'B':
bomtable = pcbdata.bom.B.slice();
break;
if (settings.bommode == "ungrouped") {
// expand bom table
expandedTable = []
for (var bomentry of bomtable) {
for (var ref of bomentry[3]) {
expandedTable.push([1, bomentry[1], bomentry[2], [ref], bomentry[4], bomentry[5]]);
bomtable = expandedTable;
if (bomSortFunction) {
bomtable = bomtable.sort(bomSortFunction);
for (var i in bomtable) {
var bomentry = bomtable[i];
if (filter && !entryMatches(bomentry)) {
continue;
var references = null;
var netname = null;
var td = document.createElement("TD");
var rownum = +i + 1;
tr.id = "bomrow" + rownum;
td.textContent = rownum;
tr.appendChild(td);
netname = bomentry;
td.innerHTML = highlightFilter(netname ? netname : "&lt;no net&gt;");
tr.appendChild(td);
} else {
if (reflookup) {
references = findRefInEntry(bomentry);
if (references.length == 0) {
continue;
} else {
references = bomentry[3];
// Checkboxes
if (checkbox) {
input.type = "checkbox";
input.onchange = createCheckboxChangeHandler(checkbox, references);
setBomCheckboxState(checkbox, input, references);
if (input.checked && settings.darkenWhenChecked == checkbox) {
tr.classList.add("checked");
td.appendChild(input);
tr.appendChild(td);
// References
td.innerHTML = highlightFilter(references.map(r => r[0]).join(", "));
tr.appendChild(td);
// Extra fields
td.innerHTML = highlightFilter(bomentry[4][i]);
tr.appendChild(td);
// Value
td.innerHTML = highlightFilter(bomentry[1]);
tr.appendChild(td);
// Footprint
td.innerHTML = highlightFilter(bomentry[2]);
tr.appendChild(td);
// Quantity
td.textContent = bomentry[3].length;
tr.appendChild(td);
bom.appendChild(tr);
var handler = createRowHighlightHandler(tr.id, references, netname);
tr.onmousemove = handler;
highlightHandlers.push({
handler: handler,
if (references !== null) {
for (var refIndex of references.map(r => r[1])) {
moduleIndexToHandler[refIndex] = handler;
if (netname !== null) {
netsToHandler[netname] = handler;
if ((filter || reflookup) && first) {
handler();
first = false;
function highlightPreviousRow() {
if (!currentHighlightedRowId) {
highlightHandlers[highlightHandlers.length - 1].handler();
} else {
if (highlightHandlers.length > 1 &&
highlightHandlers[0].id == currentHighlightedRowId) {
} else {
for (var i = 0; i < highlightHandlers.length - 1; i++) {
if (highlightHandlers[i + 1].id == currentHighlightedRowId) {
highlightHandlers[i].handler();
break;
smoothScrollToRow(currentHighlightedRowId);
function highlightNextRow() {
highlightHandlers[0].handler();
} else {
highlightHandlers[highlightHandlers.length - 1].id == currentHighlightedRowId) {
} else {
for (var i = 1; i < highlightHandlers.length; i++) {
if (highlightHandlers[i - 1].id == currentHighlightedRowId) {
break;
function populateBomTable() {
populateBomHeader();
populateBomBody();
function modulesClicked(moduleIndexes) {
var lastClickedIndex = moduleIndexes.indexOf(lastClicked);
for (var i = 1; i <= moduleIndexes.length; i++) {
var refIndex = moduleIndexes[(lastClickedIndex + i) % moduleIndexes.length];
if (refIndex in moduleIndexToHandler) {
lastClicked = refIndex;
moduleIndexToHandler[refIndex]();
break;
function netClicked(net) {
if (net in netsToHandler) {
netsToHandler[net]();
} else {
clearHighlightedModules();
drawHighlights();
function updateFilter(input) {
filter = input.toLowerCase();
populateBomTable();
function updateRefLookup(input) {
reflookup = input.toLowerCase();
populateBomTable();
function changeCanvasLayout(layout) {
document.getElementById("fl-btn").classList.remove("depressed");
document.getElementById("fb-btn").classList.remove("depressed");
document.getElementById("bl-btn").classList.remove("depressed");
switch (layout) {
case 'F':
document.getElementById("fl-btn").classList.add("depressed");
if (settings.bomlayout != "bom-only") {
canvassplit.collapse(1);
break;
case 'B':
document.getElementById("bl-btn").classList.add("depressed");
canvassplit.collapse(0);
break;
default:
document.getElementById("fb-btn").classList.add("depressed");
canvassplit.setSizes([50, 50]);
settings.canvaslayout = layout;
writeStorage("canvaslayout", layout);
resizeAll();
changeBomMode(settings.bommode);
function populateMetadata() {
document.getElementById("title").innerHTML = pcbdata.metadata.title;
document.getElementById("revision").innerHTML = "Rev: " + pcbdata.metadata.revision;
document.getElementById("company").innerHTML = pcbdata.metadata.company;
document.getElementById("filedate").innerHTML = pcbdata.metadata.date;
if (pcbdata.metadata.title != "") {
document.title = pcbdata.metadata.title + " BOM";
// Calculate board stats
var fp_f = 0, fp_b = 0, pads_f = 0, pads_b = 0, pads_th = 0;
if (pcbdata.bom.skipped.includes(i)) continue;
if (mod.layer == "F") {
fp_f++;
} else {
fp_b++;
if (pad.type == "th") {
pads_th++;
} else {
if (pad.layers.includes("F")) {
pads_f++;
if (pad.layers.includes("B")) {
pads_b++;
document.getElementById("stats-components-front").innerHTML = fp_f;
document.getElementById("stats-components-back").innerHTML = fp_b;
document.getElementById("stats-components-total").innerHTML = fp_f + fp_b;
document.getElementById("stats-groups-front").innerHTML = pcbdata.bom.F.length;
document.getElementById("stats-groups-back").innerHTML = pcbdata.bom.B.length;
document.getElementById("stats-groups-total").innerHTML = pcbdata.bom.both.length;
document.getElementById("stats-smd-pads-front").innerHTML = pads_f;
document.getElementById("stats-smd-pads-back").innerHTML = pads_b;
document.getElementById("stats-smd-pads-total").innerHTML = pads_f + pads_b;
document.getElementById("stats-th-pads").innerHTML = pads_th;
// Update version string
document.getElementById("github-link").innerHTML = "InteractiveHtmlBom&nbsp;" +
/^v\d+\.\d+/.exec(pcbdata.ibom_version)[0];
function changeBomLayout(layout) {
document.getElementById("bom-btn").classList.remove("depressed");
document.getElementById("lr-btn").classList.remove("depressed");
document.getElementById("tb-btn").classList.remove("depressed");
switch (layout) {
case 'bom-only':
document.getElementById("bom-btn").classList.add("depressed");
if (bomsplit) {
bomsplit.destroy();
bomsplit = null;
canvassplit.destroy();
canvassplit = null;
document.getElementById("frontcanvas").style.display = "none";
document.getElementById("backcanvas").style.display = "none";
document.getElementById("bot").style.height = "";
break;
case 'top-bottom':
document.getElementById("tb-btn").classList.add("depressed");
document.getElementById("frontcanvas").style.display = "";
document.getElementById("backcanvas").style.display = "";
document.getElementById("bot").style.height = "calc(100% - 80px)";
document.getElementById("bomdiv").classList.remove("split-horizontal");
document.getElementById("canvasdiv").classList.remove("split-horizontal");
document.getElementById("frontcanvas").classList.add("split-horizontal");
document.getElementById("backcanvas").classList.add("split-horizontal");
if (bomsplit) {
bomsplit.destroy();
bomsplit = null;
canvassplit = null;
bomsplit = Split(['#bomdiv', '#canvasdiv'], {
sizes: [50, 50],
onDragEnd: resizeAll,
direction: "vertical",
gutterSize: 5
canvassplit = Split(['#frontcanvas', '#backcanvas'], {
sizes: [50, 50],
gutterSize: 5,
break;
case 'left-right':
document.getElementById("lr-btn").classList.add("depressed");
document.getElementById("bomdiv").classList.add("split-horizontal");
document.getElementById("canvasdiv").classList.add("split-horizontal");
document.getElementById("frontcanvas").classList.remove("split-horizontal");
document.getElementById("backcanvas").classList.remove("split-horizontal");
if (bomsplit) {
bomsplit.destroy();
bomsplit = null;
canvassplit = null;
sizes: [50, 50],
gutterSize: 5
sizes: [50, 50],
gutterSize: 5,
settings.bomlayout = layout;
writeStorage("bomlayout", layout);
changeCanvasLayout(settings.canvaslayout);
function changeBomMode(mode) {
document.getElementById("bom-grouped-btn").classList.remove("depressed");
document.getElementById("bom-ungrouped-btn").classList.remove("depressed");
document.getElementById("bom-netlist-btn").classList.remove("depressed");
switch (mode) {
case 'grouped':
document.getElementById("bom-grouped-btn").classList.add("depressed");
break;
case 'ungrouped':
document.getElementById("bom-ungrouped-btn").classList.add("depressed");
break;
case 'netlist':
document.getElementById("bom-netlist-btn").classList.add("depressed");
writeStorage("bommode", mode);
if (mode != settings.bommode) {
settings.bommode = mode;
populateBomTable();
function focusFilterField() {
focusInputField(document.getElementById("filter"));
function focusRefLookupField() {
focusInputField(document.getElementById("reflookup"));
function toggleBomCheckbox(bomrowid, checkboxnum) {
if (!bomrowid || checkboxnum > settings.checkboxes.length) {
return;
var bomrow = document.getElementById(bomrowid);
var checkbox = bomrow.childNodes[checkboxnum].childNodes[0];
checkbox.checked = !checkbox.checked;
function checkBomCheckbox(bomrowid, checkboxname) {
checkboxnum++;
if (!bomrowid || checkboxnum >= settings.checkboxes.length) {
return;
var checkbox = bomrow.childNodes[checkboxnum + 1].childNodes[0];
checkbox.checked = true;
function setBomCheckboxes(value) {
writeStorage("bomCheckboxes", value);
settings.checkboxes = value.split(",").filter((e) => e);
prepCheckboxes();
populateBomTable();
function setDarkenWhenChecked(value) {
writeStorage("darkenWhenChecked", value);
settings.darkenWhenChecked = value;
populateBomTable();
function prepCheckboxes() {
var table = document.getElementById("checkbox-stats");
while (table.childElementCount > 1) {
table.removeChild(table.lastChild);
if (settings.checkboxes.length) {
table.style.display = "";
} else {
table.style.display = "none";
td.innerHTML = checkbox;
tr.appendChild(td);
td.id = "checkbox-stats-" + checkbox;
var progressbar = document.createElement("div");
progressbar.classList.add("bar");
td.appendChild(progressbar);
var text = document.createElement("div");
text.classList.add("text");
td.appendChild(text);
tr.appendChild(td);
table.appendChild(tr);
function populateDarkenWhenCheckedOptions() {
var container = document.getElementById("darkenWhenCheckedContainer");
if (settings.checkboxes.length == 0) {
container.parentElement.style.display = "none";
return;
container.innerHTML = '';
container.parentElement.style.display = "inline-block";
function createOption(name, displayName) {
var id = "darkenWhenChecked-" + name;
var div = document.createElement("div");
div.classList.add("radio-container");
input.type = "radio";
input.name = "darkenWhenChecked";
input.value = name;
input.id = id;
input.onchange = () => setDarkenWhenChecked(name);
div.appendChild(input);
// Preserve the selected element when the checkboxes change
if (name == settings.darkenWhenChecked) {
input.checked = true;
var label = document.createElement("label");
label.innerHTML = displayName;
label.htmlFor = id;
div.appendChild(label);
container.appendChild(div);
createOption("", "None");
createOption(checkbox, checkbox);
function updateCheckboxStats(checkbox) {
var checked = getStoredCheckboxRefs(checkbox).size;
var total = pcbdata.modules.length - pcbdata.bom.skipped.length;
var percent = checked * 100.0 / total;
var td = document.getElementById("checkbox-stats-" + checkbox);
td.firstChild.style.width = percent + "%";
td.lastChild.innerHTML = checked + "/" + total + " (" + Math.round(percent) + "%)";
document.onkeydown = function(e) {
switch (e.key) {
case "n":
if (document.activeElement.type == "text") {
return;
if (currentHighlightedRowId !== null) {
checkBomCheckbox(currentHighlightedRowId, "placed");
highlightNextRow();
e.preventDefault();
break;
case "ArrowUp":
highlightPreviousRow();
e.preventDefault();
break;
case "ArrowDown":
highlightNextRow();
e.preventDefault();
break;
default:
break;
if (e.altKey) {
switch (e.key) {
case "f":
focusFilterField();
e.preventDefault();
break;
case "r":
focusRefLookupField();
e.preventDefault();
break;
case "z":
changeBomLayout("bom-only");
e.preventDefault();
break;
case "x":
changeBomLayout("left-right");
e.preventDefault();
break;
case "c":
changeBomLayout("top-bottom");
e.preventDefault();
break;
case "v":
changeCanvasLayout("F");
e.preventDefault();
break;
case "b":
changeCanvasLayout("FB");
e.preventDefault();
break;
case "n":
changeCanvasLayout("B");
e.preventDefault();
break;
default:
break;
if (e.key >= '1' && e.key <= '9') {
toggleBomCheckbox(currentHighlightedRowId, parseInt(e.key));
function hideNetlistButton() {
document.getElementById("bom-ungrouped-btn").classList.remove("middle-button");
document.getElementById("bom-ungrouped-btn").classList.add("right-most-button");
document.getElementById("bom-netlist-btn").style.display = "none";
window.onload = function(e) {
initUtils();
initRender();
initStorage();
initDefaults();
cleanGutters();
populateMetadata();
dbgdiv = document.getElementById("dbg");
bom = document.getElementById("bombody");
bomhead = document.getElementById("bomhead");
filter = "";
reflookup = "";
if (!("nets" in pcbdata)) {
hideNetlistButton();
initDone = true;
prepCheckboxes();
// Triggers render
// Users may leave fullscreen without touching the checkbox. Uncheck.
document.addEventListener('fullscreenchange', () => {
if (!document.fullscreenElement)
document.getElementById('fullscreenCheckbox').checked = false;
window.onresize = resizeAll;
window.matchMedia("print").addListener(resizeAll);
</script>
</head>
<body>
<div id="topmostdiv" class="topmostdiv">
<div id="top">
<div style="float: right; height: 100%;">
<div class="hideonprint menu" style="float: right; top: 8px;">
<button class="menubtn"></button>
<div class="menu-content">
<label class="menu-label menu-label-top" style="width: calc(50% - 18px)">
<input id="darkmodeCheckbox" type="checkbox" onchange="setDarkMode(this.checked)">
Dark mode
</label><!-- This comment eats space! All of it!
--><label class="menu-label menu-label-top" style="width: calc(50% - 17px); border-left: 0;">
<input id="fullscreenCheckbox" type="checkbox" onchange="setFullscreen(this.checked)">
Full Screen
</label>
<label class="menu-label" style="width: calc(50% - 18px)">
<input id="fabricationCheckbox" type="checkbox" checked onchange="fabricationVisible(this.checked)">
Fab layer
--><label class="menu-label" style="width: calc(50% - 17px); border-left: 0;">
<input id="silkscreenCheckbox" type="checkbox" checked onchange="silkscreenVisible(this.checked)">
Silkscreen
</label>
<input id="referencesCheckbox" type="checkbox" checked onchange="referencesVisible(this.checked)">
References
<input id="valuesCheckbox" type="checkbox" checked onchange="valuesVisible(this.checked)">
Values
</label>
<div id="tracksAndZonesCheckboxes">
<input id="tracksCheckbox" type="checkbox" checked onchange="tracksVisible(this.checked)">
Tracks
<input id="zonesCheckbox" type="checkbox" checked onchange="zonesVisible(this.checked)">
Zones
</label>
</div>
<input id="padsCheckbox" type="checkbox" checked onchange="padsVisible(this.checked)">
Pads
<input id="dnpOutlineCheckbox" type="checkbox" checked onchange="dnpOutline(this.checked)">
DNP outlined
</label>
<label class="menu-label">
<input id="highlightpin1Checkbox" type="checkbox" onchange="setHighlightPin1(this.checked)">
Highlight first pin
</label>
<input id="dragCheckbox" type="checkbox" checked onchange="setRedrawOnDrag(this.checked)">
Continuous redraw on drag
</label>
<span>Board rotation</span>
<span style="float: right"><span id="rotationDegree">0</span>&#176;</span>
<input id="boardRotation" type="range" min="-36" max="36" value="0" class="slider" oninput="setBoardRotation(this.value)">
</label>
<div style="margin-left: 5px">Bom checkboxes</div>
<input id="bomCheckboxes" class="menu-textbox" type=text
oninput="setBomCheckboxes(this.value)">
</label>
<div style="margin-left: 5px">Darken when checked</div>
<div id="darkenWhenCheckedContainer"></div>
</label>
<span class="shameless-plug">
<span>Created using</span>
<a id="github-link" target="blank" href="https://github.com/openscopeproject/InteractiveHtmlBom">InteractiveHtmlBom</a>
</span>
</label>
</div>
</div>
<div class="button-container hideonprint"
style="float: right; position: relative; top: 8px">
<button id="fl-btn" class="left-most-button" onclick="changeCanvasLayout('F')"
title="Front only">F
</button>
<button id="fb-btn" class="middle-button" onclick="changeCanvasLayout('FB')"
title="Front and Back">FB
</button>
<button id="bl-btn" class="right-most-button" onclick="changeCanvasLayout('B')"
title="Back only">B
</button>
</div>
<button id="bom-btn" class="left-most-button" onclick="changeBomLayout('bom-only')"
title="BOM only"></button>
<button id="lr-btn" class="middle-button" onclick="changeBomLayout('left-right')"
title="BOM left, drawings right"></button>
<button id="tb-btn" class="right-most-button" onclick="changeBomLayout('top-bottom')"
title="BOM top, drawings bot"></button>
</div>
<button id="bom-grouped-btn" class="left-most-button" onclick="changeBomMode('grouped')"
title="Grouped BOM"></button>
<button id="bom-ungrouped-btn" class="middle-button" onclick="changeBomMode('ungrouped')"
title="Ungrouped BOM"></button>
<button id="bom-netlist-btn" class="right-most-button" onclick="changeBomMode('netlist')"
title="Netlist"></button>
</div>
<button class="statsbtn"></button>
<table class="stats">
<tbody>
<tr>
<td width="40%">Board stats</td>
<td>Front</td>
<td>Back</td>
<td>Total</td>
</tr>
<tr>
<td>Components</td>
<td id="stats-components-front">~</td>
<td id="stats-components-back">~</td>
<td id="stats-components-total">~</td>
</tr>
<tr>
<td>Groups</td>
<td id="stats-groups-front">~</td>
<td id="stats-groups-back">~</td>
<td id="stats-groups-total">~</td>
</tr>
<tr>
<td>SMD pads</td>
<td id="stats-smd-pads-front">~</td>
<td id="stats-smd-pads-back">~</td>
<td id="stats-smd-pads-total">~</td>
</tr>
<tr>
<td>TH pads</td>
<td colspan=3 id="stats-th-pads">~</td>
</tr>
</tbody>
</table>
<col width="40%"/><col />
<tbody id="checkbox-stats">
<tr>
<td colspan=2 style="border-top: 0">Checkboxes</td>
</tr>
</tbody>
</table>
</div>
</div>
<button class="iobtn"></button>
<div class="menu-label menu-label-top">
<div style="margin-left: 5px;">Save board image</div>
<div class="flexbox">
<input id="render-save-width" class="menu-textbox" type="text" value="1000" placeholder="Width"
style="flex-grow: 1; width: 50px;" oninput="validateSaveImgDimension(this)">
<span>X</span>
<input id="render-save-height" class="menu-textbox" type="text" value="1000" placeholder="Height"
</div>
<label>
<input id="render-save-transparent" type="checkbox">
Transparent background
</label>
<button class="savebtn" onclick="saveImage('F')">Front</button>
<button class="savebtn" onclick="saveImage('B')">Back</button>
</div>
</div>
<div class="menu-label">
<span style="margin-left: 5px;">Config and checkbox state</span>
<button class="savebtn" onclick="saveSettings()">Export</button>
<button class="savebtn" onclick="loadSettings()">Import</button>
</div>
</div>
</div>
</div>
</div>
<div id="fileinfodiv" style="overflow: auto;">
<table class="fileinfo">
<tbody>
<tr>
<td id="title" class="title" style="width: 70%">
Title
</td>
<td id="revision" class="title" style="width: 30%">
Revision
</td>
</tr>
<tr>
<td id="company">
Company
</td>
<td id="filedate">
Date
</td>
</tr>
</tbody>
</table>
</div>
</div>
<div id="bot" class="split" style="height: calc(100% - 80px)">
<div id="bomdiv" class="split split-horizontal">
<div style="width: 100%">
<input id="reflookup" class="textbox searchbox reflookup hideonprint" type="text" placeholder="Ref lookup"
oninput="updateRefLookup(this.value)">
<input id="filter" class="textbox searchbox filter hideonprint" type="text" placeholder="Filter"
oninput="updateFilter(this.value)">
<div class="button-container hideonprint" style="float: left; margin: 0;">
<button id="copy" title="Copy bom table to clipboard"
onclick="copyToClipboard()"></button>
</div>
</div>
<div id="dbg"></div>
<table class="bom">
<thead id="bomhead">
</thead>
<tbody id="bombody">
</tbody>
</table>
</div>
<div id="canvasdiv" class="split split-horizontal">
<div id="frontcanvas" class="split" touch-action="none" style="overflow: hidden">
<div style="position: relative; width: 100%; height: 100%;">
<canvas id="F_bg" style="position: absolute; left: 0; top: 0; z-index: 0;"></canvas>
<canvas id="F_fab" style="position: absolute; left: 0; top: 0; z-index: 1;"></canvas>
<canvas id="F_slk" style="position: absolute; left: 0; top: 0; z-index: 2;"></canvas>
<canvas id="F_hl" style="position: absolute; left: 0; top: 0; z-index: 3;"></canvas>
</div>
</div>
<div id="backcanvas" class="split" touch-action="none" style="overflow: hidden">
<canvas id="B_bg" style="position: absolute; left: 0; top: 0; z-index: 0;"></canvas>
<canvas id="B_fab" style="position: absolute; left: 0; top: 0; z-index: 1;"></canvas>
<canvas id="B_slk" style="position: absolute; left: 0; top: 0; z-index: 2;"></canvas>
<canvas id="B_hl" style="position: absolute; left: 0; top: 0; z-index: 3;"></canvas>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
ISO-10303-21;
HEADER;
/* Generated by software containing ST-Developer
* from STEP Tools, Inc. (www.steptools.com)
FILE_DESCRIPTION(
/* description */ (''),
/* implementation_level */ '2;1');
FILE_NAME(
/* name */ 'C:/Users/Airman/Downloads/Buzzer_piezo_KPEG132.step',
/* time_stamp */ '2020-04-26T18:58:26+02:00',
/* author */ (''),
/* organization */ (''),
/* preprocessor_version */ 'ST-DEVELOPER v18.1',
/* originating_system */ 'Autodesk Translation Framework v9.2.0.1227',
/* authorisation */ '');
FILE_SCHEMA (('AUTOMOTIVE_DESIGN { 1 0 10303 214 3 1 1 }'));
ENDSEC;
DATA;
#10=MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION('',(#13,#14,
#15,#16,#17),#2274);
#11=SHAPE_REPRESENTATION_RELATIONSHIP('SRR','None',#2281,#12);
#12=ADVANCED_BREP_SHAPE_REPRESENTATION('',(#18,#19,#20,#21,#22),#2273);
#13=STYLED_ITEM('',(#2291),#18);
#14=STYLED_ITEM('',(#2292),#19);
#15=STYLED_ITEM('',(#2292),#20);
#16=STYLED_ITEM('',(#2292),#21);
#17=STYLED_ITEM('',(#2292),#22);
#18=MANIFOLD_SOLID_BREP('Body1',#1262);
#19=MANIFOLD_SOLID_BREP('Body3',#1263);
#20=MANIFOLD_SOLID_BREP('Body4',#1264);
#21=MANIFOLD_SOLID_BREP('Body5',#1265);
#22=MANIFOLD_SOLID_BREP('Body6',#1266);
#23=FACE_BOUND('',#330,.T.);
#24=FACE_BOUND('',#336,.T.);
#25=FACE_BOUND('',#341,.T.);
#26=FACE_BOUND('',#343,.T.);
#27=FACE_BOUND('',#349,.T.);
#28=FACE_BOUND('',#351,.T.);
#29=FACE_BOUND('',#357,.T.);
#30=FACE_BOUND('',#359,.T.);
#31=FACE_BOUND('',#377,.T.);
#32=FACE_BOUND('',#380,.T.);
#33=PLANE('',#1297);
#34=PLANE('',#1312);
#35=PLANE('',#1326);
#36=PLANE('',#1327);
#37=PLANE('',#1328);
#38=PLANE('',#1329);
#39=PLANE('',#1333);
#40=PLANE('',#1334);
#41=PLANE('',#1335);
#42=PLANE('',#1336);
#43=PLANE('',#1337);
#44=PLANE('',#1342);
#45=PLANE('',#1343);
#46=PLANE('',#1344);
#47=PLANE('',#1345);
#48=PLANE('',#1347);
#49=PLANE('',#1354);
#50=PLANE('',#1355);
#51=PLANE('',#1356);
#52=PLANE('',#1357);
#53=PLANE('',#1359);
#54=PLANE('',#1360);
#55=PLANE('',#1361);
#56=PLANE('',#1363);
#57=PLANE('',#1364);
#58=PLANE('',#1365);
#59=PLANE('',#1366);
#60=PLANE('',#1374);
#61=PLANE('',#1379);
#62=PLANE('',#1380);
#63=PLANE('',#1405);
#64=PLANE('',#1406);
#65=PLANE('',#1431);
#66=PLANE('',#1432);
#67=PLANE('',#1457);
#68=PLANE('',#1458);
#69=LINE('',#1909,#146);
#70=LINE('',#1913,#147);
#71=LINE('',#1917,#148);
#72=LINE('',#1921,#149);
#73=LINE('',#1925,#150);
#74=LINE('',#1929,#151);
#75=LINE('',#1933,#152);
#76=LINE('',#1937,#153);
#77=LINE('',#1941,#154);
#78=LINE('',#1945,#155);
#79=LINE('',#1956,#156);
#80=LINE('',#1961,#157);
#81=LINE('',#1964,#158);
#82=LINE('',#1968,#159);
#83=LINE('',#1972,#160);
#84=LINE('',#1978,#161);
#85=LINE('',#1991,#162);
#86=LINE('',#1996,#163);
#87=LINE('',#2000,#164);
#88=LINE('',#2006,#165);
#89=LINE('',#2010,#166);
#90=LINE('',#2012,#167);
#91=LINE('',#2013,#168);
#92=LINE('',#2016,#169);
#93=LINE('',#2017,#170);
#94=LINE('',#2018,#171);
#95=LINE('',#2019,#172);
#96=LINE('',#2021,#173);
#97=LINE('',#2025,#174);
#98=LINE('',#2029,#175);
#99=LINE('',#2031,#176);
#100=LINE('',#2035,#177);
#101=LINE('',#2036,#178);
#102=LINE('',#2038,#179);
#103=LINE('',#2039,#180);
#104=LINE('',#2042,#181);
#105=LINE('',#2043,#182);
#106=LINE('',#2044,#183);
#107=LINE('',#2045,#184);
#108=LINE('',#2047,#185);
#109=LINE('',#2052,#186);
#110=LINE('',#2057,#187);
#111=LINE('',#2059,#188);
#112=LINE('',#2063,#189);
#113=LINE('',#2064,#190);
#114=LINE('',#2066,#191);
#115=LINE('',#2067,#192);
#116=LINE('',#2071,#193);
#117=LINE('',#2073,#194);
#118=LINE('',#2074,#195);
#119=LINE('',#2075,#196);
#120=LINE('',#2076,#197);
#121=LINE('',#2079,#198);
#122=LINE('',#2085,#199);
#123=LINE('',#2089,#200);
#124=LINE('',#2094,#201);
#125=LINE('',#2096,#202);
#126=LINE('',#2098,#203);
#127=LINE('',#2102,#204);
#128=LINE('',#2104,#205);
#129=LINE('',#2108,#206);
#130=LINE('',#2110,#207);
#131=LINE('',#2124,#208);
#132=LINE('',#2130,#209);
#133=LINE('',#2135,#210);
#134=LINE('',#2143,#211);
#135=LINE('',#2155,#212);
#136=LINE('',#2167,#213);
#137=LINE('',#2179,#214);
#138=LINE('',#2187,#215);
#139=LINE('',#2199,#216);
#140=LINE('',#2211,#217);
#141=LINE('',#2223,#218);
#142=LINE('',#2231,#219);
#143=LINE('',#2243,#220);
#144=LINE('',#2255,#221);
#145=LINE('',#2267,#222);
#146=VECTOR('',#1475,14.3);
#147=VECTOR('',#1478,10.);
#148=VECTOR('',#1481,10.);
#149=VECTOR('',#1484,10.);
#150=VECTOR('',#1487,10.);
#151=VECTOR('',#1490,10.);
#152=VECTOR('',#1493,10.);
#153=VECTOR('',#1496,10.);
#154=VECTOR('',#1499,10.);
#155=VECTOR('',#1502,10.);
#156=VECTOR('',#1515,0.5);
#157=VECTOR('',#1522,10.);
#158=VECTOR('',#1525,10.);
#159=VECTOR('',#1528,10.);
#160=VECTOR('',#1531,10.);
#161=VECTOR('',#1538,0.5);
#162=VECTOR('',#1555,13.8);
#163=VECTOR('',#1560,10.);
#164=VECTOR('',#1563,10.);
#165=VECTOR('',#1570,0.5);
#166=VECTOR('',#1575,10.);
#167=VECTOR('',#1576,10.);
#168=VECTOR('',#1577,10.);
#169=VECTOR('',#1580,10.);
#170=VECTOR('',#1581,10.);
#171=VECTOR('',#1582,10.);
#172=VECTOR('',#1583,10.);
#173=VECTOR('',#1586,10.);
#174=VECTOR('',#1591,10.);
#175=VECTOR('',#1596,10.);
#176=VECTOR('',#1599,10.);
#177=VECTOR('',#1602,10.);
#178=VECTOR('',#1603,10.);
#179=VECTOR('',#1604,10.);
#180=VECTOR('',#1605,10.);
#181=VECTOR('',#1608,10.);
#182=VECTOR('',#1609,10.);
#183=VECTOR('',#1610,10.);
#184=VECTOR('',#1611,10.);
#185=VECTOR('',#1614,10.);
#186=VECTOR('',#1619,10.);
#187=VECTOR('',#1626,10.);
#188=VECTOR('',#1629,10.);
#189=VECTOR('',#1632,10.);
#190=VECTOR('',#1633,10.);
#191=VECTOR('',#1634,10.);
#192=VECTOR('',#1635,10.);
#193=VECTOR('',#1638,10.);
#194=VECTOR('',#1639,10.);
#195=VECTOR('',#1640,10.);
#196=VECTOR('',#1641,10.);
#197=VECTOR('',#1642,10.);
#198=VECTOR('',#1645,10.);
#199=VECTOR('',#1652,10.);
#200=VECTOR('',#1657,10.);
#201=VECTOR('',#1664,10.);
#202=VECTOR('',#1667,10.);
#203=VECTOR('',#1670,10.);
#204=VECTOR('',#1677,10.);
#205=VECTOR('',#1680,10.);
#206=VECTOR('',#1687,10.);
#207=VECTOR('',#1690,10.);
#208=VECTOR('',#1707,12.8);
#209=VECTOR('',#1716,2.2299993510874);
#210=VECTOR('',#1721,13.8);
#211=VECTOR('',#1732,0.300000000000001);
#212=VECTOR('',#1747,0.300000000000001);
#213=VECTOR('',#1762,0.3);
#214=VECTOR('',#1777,0.3);
#215=VECTOR('',#1788,0.300000000000001);
#216=VECTOR('',#1803,0.300000000000001);
#217=VECTOR('',#1818,0.3);
#218=VECTOR('',#1833,0.3);
#219=VECTOR('',#1844,0.300000000000001);
#220=VECTOR('',#1859,0.3);
#221=VECTOR('',#1874,0.3);
#222=VECTOR('',#1889,0.3);
#223=CYLINDRICAL_SURFACE('',#1286,14.3);
#224=CYLINDRICAL_SURFACE('',#1300,0.5);
#225=CYLINDRICAL_SURFACE('',#1303,14.3);
#226=CYLINDRICAL_SURFACE('',#1306,2.80000000000002);
#227=CYLINDRICAL_SURFACE('',#1309,0.5);
#228=CYLINDRICAL_SURFACE('',#1317,13.8);
#229=CYLINDRICAL_SURFACE('',#1320,2.80000000000002);
#230=CYLINDRICAL_SURFACE('',#1323,0.5);
#231=CYLINDRICAL_SURFACE('',#1331,2.80000000000002);
#232=CYLINDRICAL_SURFACE('',#1340,2.80000000000002);
#233=CYLINDRICAL_SURFACE('',#1350,2.80000000000002);
#234=CYLINDRICAL_SURFACE('',#1352,2.80000000000002);
#235=CYLINDRICAL_SURFACE('',#1358,14.3);
#236=CYLINDRICAL_SURFACE('',#1362,14.3);
#237=CYLINDRICAL_SURFACE('',#1371,12.8);
#238=CYLINDRICAL_SURFACE('',#1375,2.2299993510874);
#239=CYLINDRICAL_SURFACE('',#1376,13.8);
#240=CYLINDRICAL_SURFACE('',#1381,0.300000000000001);
#241=CYLINDRICAL_SURFACE('',#1389,0.3);
#242=CYLINDRICAL_SURFACE('',#1396,0.3);
#243=CYLINDRICAL_SURFACE('',#1403,0.3);
#244=CYLINDRICAL_SURFACE('',#1407,0.300000000000001);
#245=CYLINDRICAL_SURFACE('',#1415,0.3);
#246=CYLINDRICAL_SURFACE('',#1422,0.3);
#247=CYLINDRICAL_SURFACE('',#1429,0.3);
#248=CYLINDRICAL_SURFACE('',#1433,0.300000000000001);
#249=CYLINDRICAL_SURFACE('',#1441,0.3);
#250=CYLINDRICAL_SURFACE('',#1448,0.3);
#251=CYLINDRICAL_SURFACE('',#1455,0.3);
#252=FACE_OUTER_BOUND('',#327,.T.);
#253=FACE_OUTER_BOUND('',#328,.T.);
#254=FACE_OUTER_BOUND('',#329,.T.);
#255=FACE_OUTER_BOUND('',#331,.T.);
#256=FACE_OUTER_BOUND('',#332,.T.);
#257=FACE_OUTER_BOUND('',#333,.T.);
#258=FACE_OUTER_BOUND('',#334,.T.);
#259=FACE_OUTER_BOUND('',#335,.T.);
#260=FACE_OUTER_BOUND('',#337,.T.);
#261=FACE_OUTER_BOUND('',#338,.T.);
#262=FACE_OUTER_BOUND('',#339,.T.);
#263=FACE_OUTER_BOUND('',#340,.T.);
#264=FACE_OUTER_BOUND('',#342,.T.);
#265=FACE_OUTER_BOUND('',#344,.T.);
#266=FACE_OUTER_BOUND('',#345,.T.);
#267=FACE_OUTER_BOUND('',#346,.T.);
#268=FACE_OUTER_BOUND('',#347,.T.);
#269=FACE_OUTER_BOUND('',#348,.T.);
#270=FACE_OUTER_BOUND('',#350,.T.);
#271=FACE_OUTER_BOUND('',#352,.T.);
#272=FACE_OUTER_BOUND('',#353,.T.);
#273=FACE_OUTER_BOUND('',#354,.T.);
#274=FACE_OUTER_BOUND('',#355,.T.);
#275=FACE_OUTER_BOUND('',#356,.T.);
#276=FACE_OUTER_BOUND('',#358,.T.);
#277=FACE_OUTER_BOUND('',#360,.T.);
#278=FACE_OUTER_BOUND('',#361,.T.);
#279=FACE_OUTER_BOUND('',#362,.T.);
#280=FACE_OUTER_BOUND('',#363,.T.);
#281=FACE_OUTER_BOUND('',#364,.T.);
#282=FACE_OUTER_BOUND('',#365,.T.);
#283=FACE_OUTER_BOUND('',#366,.T.);
#284=FACE_OUTER_BOUND('',#367,.T.);
#285=FACE_OUTER_BOUND('',#368,.T.);
#286=FACE_OUTER_BOUND('',#369,.T.);
#287=FACE_OUTER_BOUND('',#370,.T.);
#288=FACE_OUTER_BOUND('',#371,.T.);
#289=FACE_OUTER_BOUND('',#372,.T.);
#290=FACE_OUTER_BOUND('',#373,.T.);
#291=FACE_OUTER_BOUND('',#374,.T.);
#292=FACE_OUTER_BOUND('',#375,.T.);
#293=FACE_OUTER_BOUND('',#376,.T.);
#294=FACE_OUTER_BOUND('',#378,.T.);
#295=FACE_OUTER_BOUND('',#379,.T.);
#296=FACE_OUTER_BOUND('',#381,.T.);
#297=FACE_OUTER_BOUND('',#382,.T.);
#298=FACE_OUTER_BOUND('',#383,.T.);
#299=FACE_OUTER_BOUND('',#384,.T.);
#300=FACE_OUTER_BOUND('',#385,.T.);
#301=FACE_OUTER_BOUND('',#386,.T.);
#302=FACE_OUTER_BOUND('',#387,.T.);
#303=FACE_OUTER_BOUND('',#388,.T.);
#304=FACE_OUTER_BOUND('',#389,.T.);
#305=FACE_OUTER_BOUND('',#390,.T.);
#306=FACE_OUTER_BOUND('',#391,.T.);
#307=FACE_OUTER_BOUND('',#392,.T.);
#308=FACE_OUTER_BOUND('',#393,.T.);
#309=FACE_OUTER_BOUND('',#394,.T.);
#310=FACE_OUTER_BOUND('',#395,.T.);
#311=FACE_OUTER_BOUND('',#396,.T.);
#312=FACE_OUTER_BOUND('',#397,.T.);
#313=FACE_OUTER_BOUND('',#398,.T.);
#314=FACE_OUTER_BOUND('',#399,.T.);
#315=FACE_OUTER_BOUND('',#400,.T.);
#316=FACE_OUTER_BOUND('',#401,.T.);
#317=FACE_OUTER_BOUND('',#402,.T.);
#318=FACE_OUTER_BOUND('',#403,.T.);
#319=FACE_OUTER_BOUND('',#404,.T.);
#320=FACE_OUTER_BOUND('',#405,.T.);
#321=FACE_OUTER_BOUND('',#406,.T.);
#322=FACE_OUTER_BOUND('',#407,.T.);
#323=FACE_OUTER_BOUND('',#408,.T.);
#324=FACE_OUTER_BOUND('',#409,.T.);
#325=FACE_OUTER_BOUND('',#410,.T.);
#326=FACE_OUTER_BOUND('',#411,.T.);
#327=EDGE_LOOP('',(#815,#816,#817,#818,#819,#820));
#328=EDGE_LOOP('',(#821,#822,#823,#824,#825,#826,#827,#828,#829,#830,#831,
#832,#833,#834,#835,#836,#837,#838,#839,#840,#841,#842,#843,#844,#845,#846));
#329=EDGE_LOOP('',(#847,#848));
#330=EDGE_LOOP('',(#849,#850));
#331=EDGE_LOOP('',(#851,#852,#853,#854));
#332=EDGE_LOOP('',(#855,#856,#857,#858));
#333=EDGE_LOOP('',(#859,#860,#861,#862));
#334=EDGE_LOOP('',(#863,#864,#865,#866));
#335=EDGE_LOOP('',(#867,#868,#869,#870,#871,#872,#873,#874,#875,#876));
#336=EDGE_LOOP('',(#877,#878));
#337=EDGE_LOOP('',(#879,#880,#881,#882,#883,#884));
#338=EDGE_LOOP('',(#885,#886,#887,#888));
#339=EDGE_LOOP('',(#889,#890,#891,#892));
#340=EDGE_LOOP('',(#893,#894,#895,#896,#897));
#341=EDGE_LOOP('',(#898));
#342=EDGE_LOOP('',(#899,#900,#901,#902,#903));
#343=EDGE_LOOP('',(#904));
#344=EDGE_LOOP('',(#905,#906,#907));
#345=EDGE_LOOP('',(#908,#909,#910,#911));
#346=EDGE_LOOP('',(#912,#913,#914,#915));
#347=EDGE_LOOP('',(#916,#917,#918));
#348=EDGE_LOOP('',(#919,#920,#921,#922,#923));
#349=EDGE_LOOP('',(#924));
#350=EDGE_LOOP('',(#925,#926,#927,#928,#929));
#351=EDGE_LOOP('',(#930));
#352=EDGE_LOOP('',(#931,#932,#933));
#353=EDGE_LOOP('',(#934,#935,#936,#937));
#354=EDGE_LOOP('',(#938,#939,#940,#941));
#355=EDGE_LOOP('',(#942,#943,#944));
#356=EDGE_LOOP('',(#945,#946,#947,#948,#949));
#357=EDGE_LOOP('',(#950));
#358=EDGE_LOOP('',(#951,#952,#953,#954,#955));
#359=EDGE_LOOP('',(#956));
#360=EDGE_LOOP('',(#957,#958,#959));
#361=EDGE_LOOP('',(#960,#961,#962,#963));
#362=EDGE_LOOP('',(#964,#965,#966,#967));
#363=EDGE_LOOP('',(#968,#969,#970,#971));
#364=EDGE_LOOP('',(#972,#973,#974));
#365=EDGE_LOOP('',(#975,#976,#977,#978));
#366=EDGE_LOOP('',(#979,#980,#981,#982,#983));
#367=EDGE_LOOP('',(#984,#985,#986,#987,#988));
#368=EDGE_LOOP('',(#989,#990,#991,#992));
#369=EDGE_LOOP('',(#993,#994,#995,#996));
#370=EDGE_LOOP('',(#997,#998,#999,#1000,#1001));
#371=EDGE_LOOP('',(#1002,#1003,#1004,#1005,#1006));
#372=EDGE_LOOP('',(#1007,#1008,#1009,#1010));
#373=EDGE_LOOP('',(#1011,#1012,#1013,#1014));
#374=EDGE_LOOP('',(#1015,#1016,#1017,#1018,#1019));
#375=EDGE_LOOP('',(#1020,#1021,#1022,#1023,#1024));
#376=EDGE_LOOP('',(#1025,#1026));
#377=EDGE_LOOP('',(#1027,#1028));
#378=EDGE_LOOP('',(#1029,#1030,#1031,#1032,#1033,#1034));
#379=EDGE_LOOP('',(#1035,#1036));
#380=EDGE_LOOP('',(#1037,#1038));
#381=EDGE_LOOP('',(#1039,#1040,#1041,#1042,#1043,#1044));
#382=EDGE_LOOP('',(#1045,#1046,#1047,#1048));
#383=EDGE_LOOP('',(#1049));
#384=EDGE_LOOP('',(#1050));
#385=EDGE_LOOP('',(#1051,#1052,#1053,#1054,#1055));
#386=EDGE_LOOP('',(#1056,#1057,#1058,#1059,#1060,#1061));
#387=EDGE_LOOP('',(#1062,#1063,#1064,#1065,#1066,#1067));
#388=EDGE_LOOP('',(#1068,#1069,#1070,#1071,#1072,#1073));
#389=EDGE_LOOP('',(#1074,#1075,#1076,#1077,#1078,#1079));
#390=EDGE_LOOP('',(#1080,#1081,#1082,#1083,#1084,#1085));
#391=EDGE_LOOP('',(#1086,#1087,#1088,#1089,#1090));
#392=EDGE_LOOP('',(#1091));
#393=EDGE_LOOP('',(#1092));
#394=EDGE_LOOP('',(#1093,#1094,#1095,#1096,#1097));
#395=EDGE_LOOP('',(#1098,#1099,#1100,#1101,#1102,#1103));
#396=EDGE_LOOP('',(#1104,#1105,#1106,#1107,#1108,#1109));
#397=EDGE_LOOP('',(#1110,#1111,#1112,#1113,#1114,#1115));
#398=EDGE_LOOP('',(#1116,#1117,#1118,#1119,#1120,#1121));
#399=EDGE_LOOP('',(#1122,#1123,#1124,#1125,#1126,#1127));
#400=EDGE_LOOP('',(#1128,#1129,#1130,#1131,#1132));
#401=EDGE_LOOP('',(#1133));
#402=EDGE_LOOP('',(#1134));
#403=EDGE_LOOP('',(#1135,#1136,#1137,#1138,#1139));
#404=EDGE_LOOP('',(#1140,#1141,#1142,#1143,#1144,#1145));
#405=EDGE_LOOP('',(#1146,#1147,#1148,#1149,#1150,#1151));
#406=EDGE_LOOP('',(#1152,#1153,#1154,#1155,#1156,#1157));
#407=EDGE_LOOP('',(#1158,#1159,#1160,#1161,#1162,#1163));
#408=EDGE_LOOP('',(#1164,#1165,#1166,#1167,#1168,#1169));
#409=EDGE_LOOP('',(#1170,#1171,#1172,#1173,#1174));
#410=EDGE_LOOP('',(#1175));
#411=EDGE_LOOP('',(#1176));
#412=CIRCLE('',#1281,13.3);
#413=CIRCLE('',#1282,1.);
#414=CIRCLE('',#1283,14.3);
#415=CIRCLE('',#1284,14.3);
#416=CIRCLE('',#1285,13.3);
#417=CIRCLE('',#1287,14.3);
#418=CIRCLE('',#1288,14.3);
#419=CIRCLE('',#1289,14.3);
#420=CIRCLE('',#1290,14.3);
#421=CIRCLE('',#1291,14.3);
#422=CIRCLE('',#1292,14.3);
#423=CIRCLE('',#1293,14.3);
#424=CIRCLE('',#1294,14.3);
#425=CIRCLE('',#1295,14.3);
#426=CIRCLE('',#1296,14.3);
#427=CIRCLE('',#1298,2.22999949938702);
#428=CIRCLE('',#1299,2.22999949938702);
#429=CIRCLE('',#1301,0.5);
#430=CIRCLE('',#1302,0.5);
#431=CIRCLE('',#1304,14.3);
#432=CIRCLE('',#1305,14.3);
#433=CIRCLE('',#1307,2.80000000000002);
#434=CIRCLE('',#1308,2.80000000000002);
#435=CIRCLE('',#1310,0.5);
#436=CIRCLE('',#1311,0.5);
#437=CIRCLE('',#1313,14.3);
#438=CIRCLE('',#1314,14.3);
#439=CIRCLE('',#1315,13.8);
#440=CIRCLE('',#1316,13.8);
#441=CIRCLE('',#1318,13.8);
#442=CIRCLE('',#1319,13.8);
#443=CIRCLE('',#1321,2.80000000000002);
#444=CIRCLE('',#1322,2.80000000000002);
#445=CIRCLE('',#1324,0.5);
#446=CIRCLE('',#1325,0.5);
#447=CIRCLE('',#1330,2.80000000000002);
#448=CIRCLE('',#1332,2.80000000000002);
#449=CIRCLE('',#1338,2.80000000000002);
#450=CIRCLE('',#1339,14.3);
#451=CIRCLE('',#1341,2.80000000000002);
#452=CIRCLE('',#1346,2.80000000000002);
#453=CIRCLE('',#1348,2.80000000000002);
#454=CIRCLE('',#1349,14.3);
#455=CIRCLE('',#1351,2.80000000000002);
#456=CIRCLE('',#1353,2.80000000000002);
#457=CIRCLE('',#1367,12.8);
#458=CIRCLE('',#1368,12.8);
#459=CIRCLE('',#1369,2.22999920278778);
#460=CIRCLE('',#1370,2.22999920278778);
#461=CIRCLE('',#1372,12.8);
#462=CIRCLE('',#1373,12.8);
#463=CIRCLE('',#1377,13.8);
#464=CIRCLE('',#1378,13.8);
#465=CIRCLE('',#1382,0.300000000000001);
#466=CIRCLE('',#1383,0.300000000000001);
#467=CIRCLE('',#1384,0.300000000000001);
#468=CIRCLE('',#1386,0.499999999999989);
#469=CIRCLE('',#1387,0.300000000000001);
#470=CIRCLE('',#1388,0.300000000000001);
#471=CIRCLE('',#1390,0.3);
#472=CIRCLE('',#1391,0.3);
#473=CIRCLE('',#1393,0.699999999999998);
#474=CIRCLE('',#1394,0.3);
#475=CIRCLE('',#1395,0.3);
#476=CIRCLE('',#1397,0.3);
#477=CIRCLE('',#1398,0.3);
#478=CIRCLE('',#1400,0.900000000000001);
#479=CIRCLE('',#1401,0.3);
#480=CIRCLE('',#1402,0.3);
#481=CIRCLE('',#1404,0.3);
#482=CIRCLE('',#1408,0.300000000000001);
#483=CIRCLE('',#1409,0.300000000000001);
#484=CIRCLE('',#1410,0.300000000000001);
#485=CIRCLE('',#1412,0.499999999999989);
#486=CIRCLE('',#1413,0.300000000000001);
#487=CIRCLE('',#1414,0.300000000000001);
#488=CIRCLE('',#1416,0.3);
#489=CIRCLE('',#1417,0.3);
#490=CIRCLE('',#1419,0.699999999999998);
#491=CIRCLE('',#1420,0.3);
#492=CIRCLE('',#1421,0.3);
#493=CIRCLE('',#1423,0.3);
#494=CIRCLE('',#1424,0.3);
#495=CIRCLE('',#1426,0.900000000000001);
#496=CIRCLE('',#1427,0.3);
#497=CIRCLE('',#1428,0.3);
#498=CIRCLE('',#1430,0.3);
#499=CIRCLE('',#1434,0.300000000000001);
#500=CIRCLE('',#1435,0.300000000000001);
#501=CIRCLE('',#1436,0.300000000000001);
#502=CIRCLE('',#1438,0.499999999999989);
#503=CIRCLE('',#1439,0.300000000000001);
#504=CIRCLE('',#1440,0.300000000000001);
#505=CIRCLE('',#1442,0.3);
#506=CIRCLE('',#1443,0.3);
#507=CIRCLE('',#1445,0.699999999999998);
#508=CIRCLE('',#1446,0.3);
#509=CIRCLE('',#1447,0.3);
#510=CIRCLE('',#1449,0.3);
#511=CIRCLE('',#1450,0.3);
#512=CIRCLE('',#1452,0.900000000000001);
#513=CIRCLE('',#1453,0.3);
#514=CIRCLE('',#1454,0.3);
#515=CIRCLE('',#1456,0.3);
#516=VERTEX_POINT('',#1898);
#517=VERTEX_POINT('',#1899);
#518=VERTEX_POINT('',#1901);
#519=VERTEX_POINT('',#1903);
#520=VERTEX_POINT('',#1908);
#521=VERTEX_POINT('',#1910);
#522=VERTEX_POINT('',#1912);
#523=VERTEX_POINT('',#1914);
#524=VERTEX_POINT('',#1916);
#525=VERTEX_POINT('',#1918);
#526=VERTEX_POINT('',#1920);
#527=VERTEX_POINT('',#1922);
#528=VERTEX_POINT('',#1924);
#529=VERTEX_POINT('',#1926);
#530=VERTEX_POINT('',#1928);
#531=VERTEX_POINT('',#1930);
#532=VERTEX_POINT('',#1932);
#533=VERTEX_POINT('',#1934);
#534=VERTEX_POINT('',#1936);
#535=VERTEX_POINT('',#1938);
#536=VERTEX_POINT('',#1940);
#537=VERTEX_POINT('',#1942);
#538=VERTEX_POINT('',#1944);
#539=VERTEX_POINT('',#1948);
#540=VERTEX_POINT('',#1949);
#541=VERTEX_POINT('',#1953);
#542=VERTEX_POINT('',#1955);
#543=VERTEX_POINT('',#1960);
#544=VERTEX_POINT('',#1962);
#545=VERTEX_POINT('',#1966);
#546=VERTEX_POINT('',#1967);
#547=VERTEX_POINT('',#1969);
#548=VERTEX_POINT('',#1971);
#549=VERTEX_POINT('',#1975);
#550=VERTEX_POINT('',#1977);
#551=VERTEX_POINT('',#1983);
#552=VERTEX_POINT('',#1984);
#553=VERTEX_POINT('',#1988);
#554=VERTEX_POINT('',#1989);
#555=VERTEX_POINT('',#1994);
#556=VERTEX_POINT('',#1995);
#557=VERTEX_POINT('',#1997);
#558=VERTEX_POINT('',#1999);
#559=VERTEX_POINT('',#2003);
#560=VERTEX_POINT('',#2005);
#561=VERTEX_POINT('',#2009);
#562=VERTEX_POINT('',#2011);
#563=VERTEX_POINT('',#2015);
#564=VERTEX_POINT('',#2023);
#565=VERTEX_POINT('',#2027);
#566=VERTEX_POINT('',#2033);
#567=VERTEX_POINT('',#2034);
#568=VERTEX_POINT('',#2037);
#569=VERTEX_POINT('',#2041);
#570=VERTEX_POINT('',#2049);
#571=VERTEX_POINT('',#2051);
#572=VERTEX_POINT('',#2055);
#573=VERTEX_POINT('',#2061);
#574=VERTEX_POINT('',#2062);
#575=VERTEX_POINT('',#2065);
#576=VERTEX_POINT('',#2069);
#577=VERTEX_POINT('',#2070);
#578=VERTEX_POINT('',#2072);
#579=VERTEX_POINT('',#2078);
#580=VERTEX_POINT('',#2082);
#581=VERTEX_POINT('',#2084);
#582=VERTEX_POINT('',#2088);
#583=VERTEX_POINT('',#2092);
#584=VERTEX_POINT('',#2114);
#585=VERTEX_POINT('',#2115);
#586=VERTEX_POINT('',#2118);
#587=VERTEX_POINT('',#2119);
#588=VERTEX_POINT('',#2123);
#589=VERTEX_POINT('',#2125);
#590=VERTEX_POINT('',#2132);
#591=VERTEX_POINT('',#2134);
#592=VERTEX_POINT('',#2140);
#593=VERTEX_POINT('',#2142);
#594=VERTEX_POINT('',#2144);
#595=VERTEX_POINT('',#2148);
#596=VERTEX_POINT('',#2150);
#597=VERTEX_POINT('',#2154);
#598=VERTEX_POINT('',#2156);
#599=VERTEX_POINT('',#2160);
#600=VERTEX_POINT('',#2162);
#601=VERTEX_POINT('',#2166);
#602=VERTEX_POINT('',#2168);
#603=VERTEX_POINT('',#2172);
#604=VERTEX_POINT('',#2174);
#605=VERTEX_POINT('',#2178);
#606=VERTEX_POINT('',#2184);
#607=VERTEX_POINT('',#2186);
#608=VERTEX_POINT('',#2188);
#609=VERTEX_POINT('',#2192);
#610=VERTEX_POINT('',#2194);
#611=VERTEX_POINT('',#2198);
#612=VERTEX_POINT('',#2200);
#613=VERTEX_POINT('',#2204);
#614=VERTEX_POINT('',#2206);
#615=VERTEX_POINT('',#2210);
#616=VERTEX_POINT('',#2212);
#617=VERTEX_POINT('',#2216);
#618=VERTEX_POINT('',#2218);
#619=VERTEX_POINT('',#2222);
#620=VERTEX_POINT('',#2228);
#621=VERTEX_POINT('',#2230);
#622=VERTEX_POINT('',#2232);
#623=VERTEX_POINT('',#2236);
#624=VERTEX_POINT('',#2238);
#625=VERTEX_POINT('',#2242);
#626=VERTEX_POINT('',#2244);
#627=VERTEX_POINT('',#2248);
#628=VERTEX_POINT('',#2250);
#629=VERTEX_POINT('',#2254);
#630=VERTEX_POINT('',#2256);
#631=VERTEX_POINT('',#2260);
#632=VERTEX_POINT('',#2262);
#633=VERTEX_POINT('',#2266);
#634=EDGE_CURVE('',#516,#517,#412,.T.);
#635=EDGE_CURVE('',#517,#518,#413,.T.);
#636=EDGE_CURVE('',#518,#519,#414,.T.);
#637=EDGE_CURVE('',#519,#518,#415,.T.);
#638=EDGE_CURVE('',#517,#516,#416,.T.);
#639=EDGE_CURVE('',#518,#520,#69,.T.);
#640=EDGE_CURVE('',#520,#521,#417,.T.);
#641=EDGE_CURVE('',#521,#522,#70,.T.);
#642=EDGE_CURVE('',#522,#523,#418,.T.);
#643=EDGE_CURVE('',#523,#524,#71,.T.);
#644=EDGE_CURVE('',#524,#525,#419,.T.);
#645=EDGE_CURVE('',#526,#525,#72,.T.);
#646=EDGE_CURVE('',#525,#527,#420,.T.);
#647=EDGE_CURVE('',#527,#528,#73,.T.);
#648=EDGE_CURVE('',#528,#529,#421,.T.);
#649=EDGE_CURVE('',#529,#530,#74,.T.);
#650=EDGE_CURVE('',#531,#530,#422,.T.);
#651=EDGE_CURVE('',#532,#531,#75,.T.);
#652=EDGE_CURVE('',#531,#533,#423,.T.);
#653=EDGE_CURVE('',#533,#534,#76,.T.);
#654=EDGE_CURVE('',#534,#535,#424,.T.);
#655=EDGE_CURVE('',#535,#536,#77,.T.);
#656=EDGE_CURVE('',#536,#537,#425,.T.);
#657=EDGE_CURVE('',#538,#537,#78,.T.);
#658=EDGE_CURVE('',#537,#520,#426,.T.);
#659=EDGE_CURVE('',#539,#540,#427,.T.);
#660=EDGE_CURVE('',#540,#539,#428,.T.);
#661=EDGE_CURVE('',#541,#541,#429,.T.);
#662=EDGE_CURVE('',#541,#542,#79,.T.);
#663=EDGE_CURVE('',#542,#542,#430,.T.);
#664=EDGE_CURVE('',#521,#524,#431,.T.);
#665=EDGE_CURVE('',#524,#543,#80,.T.);
#666=EDGE_CURVE('',#544,#543,#432,.T.);
#667=EDGE_CURVE('',#521,#544,#81,.T.);
#668=EDGE_CURVE('',#545,#546,#82,.T.);
#669=EDGE_CURVE('',#547,#546,#433,.T.);
#670=EDGE_CURVE('',#548,#547,#83,.T.);
#671=EDGE_CURVE('',#545,#548,#434,.T.);
#672=EDGE_CURVE('',#549,#549,#435,.T.);
#673=EDGE_CURVE('',#549,#550,#84,.T.);
#674=EDGE_CURVE('',#550,#550,#436,.T.);
#675=EDGE_CURVE('',#533,#536,#437,.T.);
#676=EDGE_CURVE('',#530,#527,#438,.T.);
#677=EDGE_CURVE('',#551,#552,#439,.T.);
#678=EDGE_CURVE('',#552,#551,#440,.T.);
#679=EDGE_CURVE('',#553,#554,#441,.T.);
#680=EDGE_CURVE('',#554,#552,#85,.T.);
#681=EDGE_CURVE('',#554,#553,#442,.T.);
#682=EDGE_CURVE('',#555,#556,#86,.T.);
#683=EDGE_CURVE('',#557,#556,#443,.T.);
#684=EDGE_CURVE('',#558,#557,#87,.T.);
#685=EDGE_CURVE('',#555,#558,#444,.T.);
#686=EDGE_CURVE('',#559,#559,#445,.T.);
#687=EDGE_CURVE('',#559,#560,#88,.T.);
#688=EDGE_CURVE('',#560,#560,#446,.T.);
#689=EDGE_CURVE('',#543,#561,#89,.T.);
#690=EDGE_CURVE('',#562,#523,#90,.T.);
#691=EDGE_CURVE('',#561,#562,#91,.T.);
#692=EDGE_CURVE('',#546,#563,#92,.T.);
#693=EDGE_CURVE('',#526,#545,#93,.T.);
#694=EDGE_CURVE('',#526,#525,#94,.T.);
#695=EDGE_CURVE('',#563,#525,#95,.T.);
#696=EDGE_CURVE('',#563,#547,#96,.T.);
#697=EDGE_CURVE('',#561,#564,#447,.T.);
#698=EDGE_CURVE('',#564,#544,#97,.T.);
#699=EDGE_CURVE('',#565,#562,#448,.T.);
#700=EDGE_CURVE('',#565,#564,#98,.T.);
#701=EDGE_CURVE('',#548,#526,#99,.T.);
#702=EDGE_CURVE('',#566,#567,#100,.T.);
#703=EDGE_CURVE('',#536,#566,#101,.T.);
#704=EDGE_CURVE('',#568,#535,#102,.T.);
#705=EDGE_CURVE('',#567,#568,#103,.T.);
#706=EDGE_CURVE('',#556,#569,#104,.T.);
#707=EDGE_CURVE('',#538,#555,#105,.T.);
#708=EDGE_CURVE('',#538,#537,#106,.T.);
#709=EDGE_CURVE('',#569,#537,#107,.T.);
#710=EDGE_CURVE('',#569,#557,#108,.T.);
#711=EDGE_CURVE('',#567,#570,#449,.T.);
#712=EDGE_CURVE('',#570,#571,#109,.T.);
#713=EDGE_CURVE('',#571,#566,#450,.T.);
#714=EDGE_CURVE('',#572,#568,#451,.T.);
#715=EDGE_CURVE('',#572,#570,#110,.T.);
#716=EDGE_CURVE('',#558,#538,#111,.T.);
#717=EDGE_CURVE('',#573,#574,#112,.T.);
#718=EDGE_CURVE('',#530,#573,#113,.T.);
#719=EDGE_CURVE('',#575,#529,#114,.T.);
#720=EDGE_CURVE('',#574,#575,#115,.T.);
#721=EDGE_CURVE('',#576,#577,#116,.T.);
#722=EDGE_CURVE('',#578,#576,#117,.T.);
#723=EDGE_CURVE('',#532,#578,#118,.T.);
#724=EDGE_CURVE('',#532,#531,#119,.T.);
#725=EDGE_CURVE('',#577,#531,#120,.T.);
#726=EDGE_CURVE('',#577,#579,#121,.T.);
#727=EDGE_CURVE('',#579,#576,#452,.T.);
#728=EDGE_CURVE('',#574,#580,#453,.T.);
#729=EDGE_CURVE('',#580,#581,#122,.T.);
#730=EDGE_CURVE('',#581,#573,#454,.T.);
#731=EDGE_CURVE('',#582,#579,#123,.T.);
#732=EDGE_CURVE('',#578,#582,#455,.T.);
#733=EDGE_CURVE('',#583,#575,#456,.T.);
#734=EDGE_CURVE('',#583,#580,#124,.T.);
#735=EDGE_CURVE('',#582,#532,#125,.T.);
#736=EDGE_CURVE('',#522,#565,#126,.T.);
#737=EDGE_CURVE('',#533,#571,#127,.T.);
#738=EDGE_CURVE('',#534,#572,#128,.T.);
#739=EDGE_CURVE('',#527,#581,#129,.T.);
#740=EDGE_CURVE('',#528,#583,#130,.T.);
#741=EDGE_CURVE('',#584,#585,#457,.T.);
#742=EDGE_CURVE('',#585,#584,#458,.T.);
#743=EDGE_CURVE('',#586,#587,#459,.T.);
#744=EDGE_CURVE('',#587,#586,#460,.T.);
#745=EDGE_CURVE('',#585,#588,#131,.T.);
#746=EDGE_CURVE('',#589,#588,#461,.T.);
#747=EDGE_CURVE('',#588,#589,#462,.T.);
#748=EDGE_CURVE('',#540,#587,#132,.T.);
#749=EDGE_CURVE('',#590,#590,#463,.T.);
#750=EDGE_CURVE('',#590,#591,#133,.T.);
#751=EDGE_CURVE('',#591,#591,#464,.T.);
#752=EDGE_CURVE('',#592,#592,#465,.T.);
#753=EDGE_CURVE('',#592,#593,#134,.T.);
#754=EDGE_CURVE('',#593,#594,#466,.T.);
#755=EDGE_CURVE('',#594,#593,#467,.T.);
#756=EDGE_CURVE('',#594,#595,#468,.T.);
#757=EDGE_CURVE('',#595,#596,#469,.T.);
#758=EDGE_CURVE('',#596,#595,#470,.T.);
#759=EDGE_CURVE('',#596,#597,#135,.T.);
#760=EDGE_CURVE('',#597,#598,#471,.T.);
#761=EDGE_CURVE('',#598,#597,#472,.T.);
#762=EDGE_CURVE('',#598,#599,#473,.T.);
#763=EDGE_CURVE('',#599,#600,#474,.T.);
#764=EDGE_CURVE('',#600,#599,#475,.T.);
#765=EDGE_CURVE('',#600,#601,#136,.T.);
#766=EDGE_CURVE('',#601,#602,#476,.T.);
#767=EDGE_CURVE('',#602,#601,#477,.T.);
#768=EDGE_CURVE('',#602,#603,#478,.T.);
#769=EDGE_CURVE('',#603,#604,#479,.T.);
#770=EDGE_CURVE('',#604,#603,#480,.T.);
#771=EDGE_CURVE('',#604,#605,#137,.T.);
#772=EDGE_CURVE('',#605,#605,#481,.T.);
#773=EDGE_CURVE('',#606,#606,#482,.T.);
#774=EDGE_CURVE('',#606,#607,#138,.T.);
#775=EDGE_CURVE('',#607,#608,#483,.T.);
#776=EDGE_CURVE('',#608,#607,#484,.T.);
#777=EDGE_CURVE('',#608,#609,#485,.T.);
#778=EDGE_CURVE('',#609,#610,#486,.T.);
#779=EDGE_CURVE('',#610,#609,#487,.T.);
#780=EDGE_CURVE('',#610,#611,#139,.T.);
#781=EDGE_CURVE('',#611,#612,#488,.T.);
#782=EDGE_CURVE('',#612,#611,#489,.T.);
#783=EDGE_CURVE('',#612,#613,#490,.T.);
#784=EDGE_CURVE('',#613,#614,#491,.T.);
#785=EDGE_CURVE('',#614,#613,#492,.T.);
#786=EDGE_CURVE('',#614,#615,#140,.T.);
#787=EDGE_CURVE('',#615,#616,#493,.T.);
#788=EDGE_CURVE('',#616,#615,#494,.T.);
#789=EDGE_CURVE('',#616,#617,#495,.T.);
#790=EDGE_CURVE('',#617,#618,#496,.T.);
#791=EDGE_CURVE('',#618,#617,#497,.T.);
#792=EDGE_CURVE('',#618,#619,#141,.T.);
#793=EDGE_CURVE('',#619,#619,#498,.T.);
#794=EDGE_CURVE('',#620,#620,#499,.T.);
#795=EDGE_CURVE('',#620,#621,#142,.T.);
#796=EDGE_CURVE('',#621,#622,#500,.T.);
#797=EDGE_CURVE('',#622,#621,#501,.T.);
#798=EDGE_CURVE('',#622,#623,#502,.T.);
#799=EDGE_CURVE('',#623,#624,#503,.T.);
#800=EDGE_CURVE('',#624,#623,#504,.T.);
#801=EDGE_CURVE('',#624,#625,#143,.T.);
#802=EDGE_CURVE('',#625,#626,#505,.T.);
#803=EDGE_CURVE('',#626,#625,#506,.T.);
#804=EDGE_CURVE('',#626,#627,#507,.T.);
#805=EDGE_CURVE('',#627,#628,#508,.T.);
#806=EDGE_CURVE('',#628,#627,#509,.T.);
#807=EDGE_CURVE('',#628,#629,#144,.T.);
#808=EDGE_CURVE('',#629,#630,#510,.T.);
#809=EDGE_CURVE('',#630,#629,#511,.T.);
#810=EDGE_CURVE('',#630,#631,#512,.T.);
#811=EDGE_CURVE('',#631,#632,#513,.T.);
#812=EDGE_CURVE('',#632,#631,#514,.T.);
#813=EDGE_CURVE('',#632,#633,#145,.T.);
#814=EDGE_CURVE('',#633,#633,#515,.T.);
#815=ORIENTED_EDGE('',*,*,#634,.T.);
#816=ORIENTED_EDGE('',*,*,#635,.T.);
#817=ORIENTED_EDGE('',*,*,#636,.T.);
#818=ORIENTED_EDGE('',*,*,#637,.T.);
#819=ORIENTED_EDGE('',*,*,#635,.F.);
#820=ORIENTED_EDGE('',*,*,#638,.T.);
#821=ORIENTED_EDGE('',*,*,#637,.F.);
#822=ORIENTED_EDGE('',*,*,#636,.F.);
#823=ORIENTED_EDGE('',*,*,#639,.T.);
#824=ORIENTED_EDGE('',*,*,#640,.T.);
#825=ORIENTED_EDGE('',*,*,#641,.T.);
#826=ORIENTED_EDGE('',*,*,#642,.T.);
#827=ORIENTED_EDGE('',*,*,#643,.T.);
#828=ORIENTED_EDGE('',*,*,#644,.T.);
#829=ORIENTED_EDGE('',*,*,#645,.F.);
#830=ORIENTED_EDGE('',*,*,#645,.T.);
#831=ORIENTED_EDGE('',*,*,#646,.T.);
#832=ORIENTED_EDGE('',*,*,#647,.T.);
#833=ORIENTED_EDGE('',*,*,#648,.T.);
#834=ORIENTED_EDGE('',*,*,#649,.T.);
#835=ORIENTED_EDGE('',*,*,#650,.F.);
#836=ORIENTED_EDGE('',*,*,#651,.F.);
#837=ORIENTED_EDGE('',*,*,#651,.T.);
#838=ORIENTED_EDGE('',*,*,#652,.T.);
#839=ORIENTED_EDGE('',*,*,#653,.T.);
#840=ORIENTED_EDGE('',*,*,#654,.T.);
#841=ORIENTED_EDGE('',*,*,#655,.T.);
#842=ORIENTED_EDGE('',*,*,#656,.T.);
#843=ORIENTED_EDGE('',*,*,#657,.F.);
#844=ORIENTED_EDGE('',*,*,#657,.T.);
#845=ORIENTED_EDGE('',*,*,#658,.T.);
#846=ORIENTED_EDGE('',*,*,#639,.F.);
#847=ORIENTED_EDGE('',*,*,#634,.F.);
#848=ORIENTED_EDGE('',*,*,#638,.F.);
#849=ORIENTED_EDGE('',*,*,#659,.F.);
#850=ORIENTED_EDGE('',*,*,#660,.F.);
#851=ORIENTED_EDGE('',*,*,#661,.F.);
#852=ORIENTED_EDGE('',*,*,#662,.T.);
#853=ORIENTED_EDGE('',*,*,#663,.F.);
#854=ORIENTED_EDGE('',*,*,#662,.F.);
#855=ORIENTED_EDGE('',*,*,#664,.T.);
#856=ORIENTED_EDGE('',*,*,#665,.T.);
#857=ORIENTED_EDGE('',*,*,#666,.F.);
#858=ORIENTED_EDGE('',*,*,#667,.F.);
#859=ORIENTED_EDGE('',*,*,#668,.T.);
#860=ORIENTED_EDGE('',*,*,#669,.F.);
#861=ORIENTED_EDGE('',*,*,#670,.F.);
#862=ORIENTED_EDGE('',*,*,#671,.F.);
#863=ORIENTED_EDGE('',*,*,#672,.F.);
#864=ORIENTED_EDGE('',*,*,#673,.T.);
#865=ORIENTED_EDGE('',*,*,#674,.F.);
#866=ORIENTED_EDGE('',*,*,#673,.F.);
#867=ORIENTED_EDGE('',*,*,#664,.F.);
#868=ORIENTED_EDGE('',*,*,#640,.F.);
#869=ORIENTED_EDGE('',*,*,#658,.F.);
#870=ORIENTED_EDGE('',*,*,#656,.F.);
#871=ORIENTED_EDGE('',*,*,#675,.F.);
#872=ORIENTED_EDGE('',*,*,#652,.F.);
#873=ORIENTED_EDGE('',*,*,#650,.T.);
#874=ORIENTED_EDGE('',*,*,#676,.T.);
#875=ORIENTED_EDGE('',*,*,#646,.F.);
#876=ORIENTED_EDGE('',*,*,#644,.F.);
#877=ORIENTED_EDGE('',*,*,#677,.T.);
#878=ORIENTED_EDGE('',*,*,#678,.T.);
#879=ORIENTED_EDGE('',*,*,#679,.T.);
#880=ORIENTED_EDGE('',*,*,#680,.T.);
#881=ORIENTED_EDGE('',*,*,#677,.F.);
#882=ORIENTED_EDGE('',*,*,#678,.F.);
#883=ORIENTED_EDGE('',*,*,#680,.F.);
#884=ORIENTED_EDGE('',*,*,#681,.T.);
#885=ORIENTED_EDGE('',*,*,#682,.T.);
#886=ORIENTED_EDGE('',*,*,#683,.F.);
#887=ORIENTED_EDGE('',*,*,#684,.F.);
#888=ORIENTED_EDGE('',*,*,#685,.F.);
#889=ORIENTED_EDGE('',*,*,#686,.F.);
#890=ORIENTED_EDGE('',*,*,#687,.T.);
#891=ORIENTED_EDGE('',*,*,#688,.F.);
#892=ORIENTED_EDGE('',*,*,#687,.F.);
#893=ORIENTED_EDGE('',*,*,#689,.F.);
#894=ORIENTED_EDGE('',*,*,#665,.F.);
#895=ORIENTED_EDGE('',*,*,#643,.F.);
#896=ORIENTED_EDGE('',*,*,#690,.F.);
#897=ORIENTED_EDGE('',*,*,#691,.F.);
#898=ORIENTED_EDGE('',*,*,#661,.T.);
#899=ORIENTED_EDGE('',*,*,#692,.F.);
#900=ORIENTED_EDGE('',*,*,#668,.F.);
#901=ORIENTED_EDGE('',*,*,#693,.F.);
#902=ORIENTED_EDGE('',*,*,#694,.T.);
#903=ORIENTED_EDGE('',*,*,#695,.F.);
#904=ORIENTED_EDGE('',*,*,#663,.T.);
#905=ORIENTED_EDGE('',*,*,#692,.T.);
#906=ORIENTED_EDGE('',*,*,#696,.T.);
#907=ORIENTED_EDGE('',*,*,#669,.T.);
#908=ORIENTED_EDGE('',*,*,#689,.T.);
#909=ORIENTED_EDGE('',*,*,#697,.T.);
#910=ORIENTED_EDGE('',*,*,#698,.T.);
#911=ORIENTED_EDGE('',*,*,#666,.T.);
#912=ORIENTED_EDGE('',*,*,#691,.T.);
#913=ORIENTED_EDGE('',*,*,#699,.F.);
#914=ORIENTED_EDGE('',*,*,#700,.T.);
#915=ORIENTED_EDGE('',*,*,#697,.F.);
#916=ORIENTED_EDGE('',*,*,#693,.T.);
#917=ORIENTED_EDGE('',*,*,#671,.T.);
#918=ORIENTED_EDGE('',*,*,#701,.T.);
#919=ORIENTED_EDGE('',*,*,#702,.F.);
#920=ORIENTED_EDGE('',*,*,#703,.F.);
#921=ORIENTED_EDGE('',*,*,#655,.F.);
#922=ORIENTED_EDGE('',*,*,#704,.F.);
#923=ORIENTED_EDGE('',*,*,#705,.F.);
#924=ORIENTED_EDGE('',*,*,#672,.T.);
#925=ORIENTED_EDGE('',*,*,#706,.F.);
#926=ORIENTED_EDGE('',*,*,#682,.F.);
#927=ORIENTED_EDGE('',*,*,#707,.F.);
#928=ORIENTED_EDGE('',*,*,#708,.T.);
#929=ORIENTED_EDGE('',*,*,#709,.F.);
#930=ORIENTED_EDGE('',*,*,#674,.T.);
#931=ORIENTED_EDGE('',*,*,#706,.T.);
#932=ORIENTED_EDGE('',*,*,#710,.T.);
#933=ORIENTED_EDGE('',*,*,#683,.T.);
#934=ORIENTED_EDGE('',*,*,#702,.T.);
#935=ORIENTED_EDGE('',*,*,#711,.T.);
#936=ORIENTED_EDGE('',*,*,#712,.T.);
#937=ORIENTED_EDGE('',*,*,#713,.T.);
#938=ORIENTED_EDGE('',*,*,#705,.T.);
#939=ORIENTED_EDGE('',*,*,#714,.F.);
#940=ORIENTED_EDGE('',*,*,#715,.T.);
#941=ORIENTED_EDGE('',*,*,#711,.F.);
#942=ORIENTED_EDGE('',*,*,#707,.T.);
#943=ORIENTED_EDGE('',*,*,#685,.T.);
#944=ORIENTED_EDGE('',*,*,#716,.T.);
#945=ORIENTED_EDGE('',*,*,#717,.F.);
#946=ORIENTED_EDGE('',*,*,#718,.F.);
#947=ORIENTED_EDGE('',*,*,#649,.F.);
#948=ORIENTED_EDGE('',*,*,#719,.F.);
#949=ORIENTED_EDGE('',*,*,#720,.F.);
#950=ORIENTED_EDGE('',*,*,#686,.T.);
#951=ORIENTED_EDGE('',*,*,#721,.F.);
#952=ORIENTED_EDGE('',*,*,#722,.F.);
#953=ORIENTED_EDGE('',*,*,#723,.F.);
#954=ORIENTED_EDGE('',*,*,#724,.T.);
#955=ORIENTED_EDGE('',*,*,#725,.F.);
#956=ORIENTED_EDGE('',*,*,#688,.T.);
#957=ORIENTED_EDGE('',*,*,#721,.T.);
#958=ORIENTED_EDGE('',*,*,#726,.T.);
#959=ORIENTED_EDGE('',*,*,#727,.T.);
#960=ORIENTED_EDGE('',*,*,#717,.T.);
#961=ORIENTED_EDGE('',*,*,#728,.T.);
#962=ORIENTED_EDGE('',*,*,#729,.T.);
#963=ORIENTED_EDGE('',*,*,#730,.T.);
#964=ORIENTED_EDGE('',*,*,#722,.T.);
#965=ORIENTED_EDGE('',*,*,#727,.F.);
#966=ORIENTED_EDGE('',*,*,#731,.F.);
#967=ORIENTED_EDGE('',*,*,#732,.F.);
#968=ORIENTED_EDGE('',*,*,#720,.T.);
#969=ORIENTED_EDGE('',*,*,#733,.F.);
#970=ORIENTED_EDGE('',*,*,#734,.T.);
#971=ORIENTED_EDGE('',*,*,#728,.F.);
#972=ORIENTED_EDGE('',*,*,#723,.T.);
#973=ORIENTED_EDGE('',*,*,#732,.T.);
#974=ORIENTED_EDGE('',*,*,#735,.T.);
#975=ORIENTED_EDGE('',*,*,#690,.T.);
#976=ORIENTED_EDGE('',*,*,#642,.F.);
#977=ORIENTED_EDGE('',*,*,#736,.T.);
#978=ORIENTED_EDGE('',*,*,#699,.T.);
#979=ORIENTED_EDGE('',*,*,#641,.F.);
#980=ORIENTED_EDGE('',*,*,#667,.T.);
#981=ORIENTED_EDGE('',*,*,#698,.F.);
#982=ORIENTED_EDGE('',*,*,#700,.F.);
#983=ORIENTED_EDGE('',*,*,#736,.F.);
#984=ORIENTED_EDGE('',*,*,#670,.T.);
#985=ORIENTED_EDGE('',*,*,#696,.F.);
#986=ORIENTED_EDGE('',*,*,#695,.T.);
#987=ORIENTED_EDGE('',*,*,#694,.F.);
#988=ORIENTED_EDGE('',*,*,#701,.F.);
#989=ORIENTED_EDGE('',*,*,#675,.T.);
#990=ORIENTED_EDGE('',*,*,#703,.T.);
#991=ORIENTED_EDGE('',*,*,#713,.F.);
#992=ORIENTED_EDGE('',*,*,#737,.F.);
#993=ORIENTED_EDGE('',*,*,#704,.T.);
#994=ORIENTED_EDGE('',*,*,#654,.F.);
#995=ORIENTED_EDGE('',*,*,#738,.T.);
#996=ORIENTED_EDGE('',*,*,#714,.T.);
#997=ORIENTED_EDGE('',*,*,#653,.F.);
#998=ORIENTED_EDGE('',*,*,#737,.T.);
#999=ORIENTED_EDGE('',*,*,#712,.F.);
#1000=ORIENTED_EDGE('',*,*,#715,.F.);
#1001=ORIENTED_EDGE('',*,*,#738,.F.);
#1002=ORIENTED_EDGE('',*,*,#684,.T.);
#1003=ORIENTED_EDGE('',*,*,#710,.F.);
#1004=ORIENTED_EDGE('',*,*,#709,.T.);
#1005=ORIENTED_EDGE('',*,*,#708,.F.);
#1006=ORIENTED_EDGE('',*,*,#716,.F.);
#1007=ORIENTED_EDGE('',*,*,#718,.T.);
#1008=ORIENTED_EDGE('',*,*,#730,.F.);
#1009=ORIENTED_EDGE('',*,*,#739,.F.);
#1010=ORIENTED_EDGE('',*,*,#676,.F.);
#1011=ORIENTED_EDGE('',*,*,#719,.T.);
#1012=ORIENTED_EDGE('',*,*,#648,.F.);
#1013=ORIENTED_EDGE('',*,*,#740,.T.);
#1014=ORIENTED_EDGE('',*,*,#733,.T.);
#1015=ORIENTED_EDGE('',*,*,#647,.F.);
#1016=ORIENTED_EDGE('',*,*,#739,.T.);
#1017=ORIENTED_EDGE('',*,*,#729,.F.);
#1018=ORIENTED_EDGE('',*,*,#734,.F.);
#1019=ORIENTED_EDGE('',*,*,#740,.F.);
#1020=ORIENTED_EDGE('',*,*,#731,.T.);
#1021=ORIENTED_EDGE('',*,*,#726,.F.);
#1022=ORIENTED_EDGE('',*,*,#725,.T.);
#1023=ORIENTED_EDGE('',*,*,#724,.F.);
#1024=ORIENTED_EDGE('',*,*,#735,.F.);
#1025=ORIENTED_EDGE('',*,*,#741,.F.);
#1026=ORIENTED_EDGE('',*,*,#742,.F.);
#1027=ORIENTED_EDGE('',*,*,#743,.T.);
#1028=ORIENTED_EDGE('',*,*,#744,.T.);
#1029=ORIENTED_EDGE('',*,*,#741,.T.);
#1030=ORIENTED_EDGE('',*,*,#745,.T.);
#1031=ORIENTED_EDGE('',*,*,#746,.F.);
#1032=ORIENTED_EDGE('',*,*,#747,.F.);
#1033=ORIENTED_EDGE('',*,*,#745,.F.);
#1034=ORIENTED_EDGE('',*,*,#742,.T.);
#1035=ORIENTED_EDGE('',*,*,#679,.F.);
#1036=ORIENTED_EDGE('',*,*,#681,.F.);
#1037=ORIENTED_EDGE('',*,*,#746,.T.);
#1038=ORIENTED_EDGE('',*,*,#747,.T.);
#1039=ORIENTED_EDGE('',*,*,#659,.T.);
#1040=ORIENTED_EDGE('',*,*,#748,.T.);
#1041=ORIENTED_EDGE('',*,*,#743,.F.);
#1042=ORIENTED_EDGE('',*,*,#744,.F.);
#1043=ORIENTED_EDGE('',*,*,#748,.F.);
#1044=ORIENTED_EDGE('',*,*,#660,.T.);
#1045=ORIENTED_EDGE('',*,*,#749,.F.);
#1046=ORIENTED_EDGE('',*,*,#750,.T.);
#1047=ORIENTED_EDGE('',*,*,#751,.T.);
#1048=ORIENTED_EDGE('',*,*,#750,.F.);
#1049=ORIENTED_EDGE('',*,*,#749,.T.);
#1050=ORIENTED_EDGE('',*,*,#751,.F.);
#1051=ORIENTED_EDGE('',*,*,#752,.F.);
#1052=ORIENTED_EDGE('',*,*,#753,.T.);
#1053=ORIENTED_EDGE('',*,*,#754,.T.);
#1054=ORIENTED_EDGE('',*,*,#755,.T.);
#1055=ORIENTED_EDGE('',*,*,#753,.F.);
#1056=ORIENTED_EDGE('',*,*,#754,.F.);
#1057=ORIENTED_EDGE('',*,*,#755,.F.);
#1058=ORIENTED_EDGE('',*,*,#756,.T.);
#1059=ORIENTED_EDGE('',*,*,#757,.T.);
#1060=ORIENTED_EDGE('',*,*,#758,.T.);
#1061=ORIENTED_EDGE('',*,*,#756,.F.);
#1062=ORIENTED_EDGE('',*,*,#758,.F.);
#1063=ORIENTED_EDGE('',*,*,#759,.T.);
#1064=ORIENTED_EDGE('',*,*,#760,.T.);
#1065=ORIENTED_EDGE('',*,*,#761,.T.);
#1066=ORIENTED_EDGE('',*,*,#759,.F.);
#1067=ORIENTED_EDGE('',*,*,#757,.F.);
#1068=ORIENTED_EDGE('',*,*,#760,.F.);
#1069=ORIENTED_EDGE('',*,*,#761,.F.);
#1070=ORIENTED_EDGE('',*,*,#762,.T.);
#1071=ORIENTED_EDGE('',*,*,#763,.T.);
#1072=ORIENTED_EDGE('',*,*,#764,.T.);
#1073=ORIENTED_EDGE('',*,*,#762,.F.);
#1074=ORIENTED_EDGE('',*,*,#764,.F.);
#1075=ORIENTED_EDGE('',*,*,#765,.T.);
#1076=ORIENTED_EDGE('',*,*,#766,.T.);
#1077=ORIENTED_EDGE('',*,*,#767,.T.);
#1078=ORIENTED_EDGE('',*,*,#765,.F.);
#1079=ORIENTED_EDGE('',*,*,#763,.F.);
#1080=ORIENTED_EDGE('',*,*,#766,.F.);
#1081=ORIENTED_EDGE('',*,*,#767,.F.);
#1082=ORIENTED_EDGE('',*,*,#768,.T.);
#1083=ORIENTED_EDGE('',*,*,#769,.T.);
#1084=ORIENTED_EDGE('',*,*,#770,.T.);
#1085=ORIENTED_EDGE('',*,*,#768,.F.);
#1086=ORIENTED_EDGE('',*,*,#770,.F.);
#1087=ORIENTED_EDGE('',*,*,#771,.T.);
#1088=ORIENTED_EDGE('',*,*,#772,.T.);
#1089=ORIENTED_EDGE('',*,*,#771,.F.);
#1090=ORIENTED_EDGE('',*,*,#769,.F.);
#1091=ORIENTED_EDGE('',*,*,#752,.T.);
#1092=ORIENTED_EDGE('',*,*,#772,.F.);
#1093=ORIENTED_EDGE('',*,*,#773,.F.);
#1094=ORIENTED_EDGE('',*,*,#774,.T.);
#1095=ORIENTED_EDGE('',*,*,#775,.T.);
#1096=ORIENTED_EDGE('',*,*,#776,.T.);
#1097=ORIENTED_EDGE('',*,*,#774,.F.);
#1098=ORIENTED_EDGE('',*,*,#775,.F.);
#1099=ORIENTED_EDGE('',*,*,#776,.F.);
#1100=ORIENTED_EDGE('',*,*,#777,.T.);
#1101=ORIENTED_EDGE('',*,*,#778,.T.);
#1102=ORIENTED_EDGE('',*,*,#779,.T.);
#1103=ORIENTED_EDGE('',*,*,#777,.F.);
#1104=ORIENTED_EDGE('',*,*,#779,.F.);
#1105=ORIENTED_EDGE('',*,*,#780,.T.);
#1106=ORIENTED_EDGE('',*,*,#781,.T.);
#1107=ORIENTED_EDGE('',*,*,#782,.T.);
#1108=ORIENTED_EDGE('',*,*,#780,.F.);
#1109=ORIENTED_EDGE('',*,*,#778,.F.);
#1110=ORIENTED_EDGE('',*,*,#781,.F.);
#1111=ORIENTED_EDGE('',*,*,#782,.F.);
#1112=ORIENTED_EDGE('',*,*,#783,.T.);
#1113=ORIENTED_EDGE('',*,*,#784,.T.);
#1114=ORIENTED_EDGE('',*,*,#785,.T.);
#1115=ORIENTED_EDGE('',*,*,#783,.F.);
#1116=ORIENTED_EDGE('',*,*,#785,.F.);
#1117=ORIENTED_EDGE('',*,*,#786,.T.);
#1118=ORIENTED_EDGE('',*,*,#787,.T.);
#1119=ORIENTED_EDGE('',*,*,#788,.T.);
#1120=ORIENTED_EDGE('',*,*,#786,.F.);
#1121=ORIENTED_EDGE('',*,*,#784,.F.);
#1122=ORIENTED_EDGE('',*,*,#787,.F.);
#1123=ORIENTED_EDGE('',*,*,#788,.F.);
#1124=ORIENTED_EDGE('',*,*,#789,.T.);
#1125=ORIENTED_EDGE('',*,*,#790,.T.);
#1126=ORIENTED_EDGE('',*,*,#791,.T.);
#1127=ORIENTED_EDGE('',*,*,#789,.F.);
#1128=ORIENTED_EDGE('',*,*,#791,.F.);
#1129=ORIENTED_EDGE('',*,*,#792,.T.);
#1130=ORIENTED_EDGE('',*,*,#793,.T.);
#1131=ORIENTED_EDGE('',*,*,#792,.F.);
#1132=ORIENTED_EDGE('',*,*,#790,.F.);
#1133=ORIENTED_EDGE('',*,*,#773,.T.);
#1134=ORIENTED_EDGE('',*,*,#793,.F.);
#1135=ORIENTED_EDGE('',*,*,#794,.F.);
#1136=ORIENTED_EDGE('',*,*,#795,.T.);
#1137=ORIENTED_EDGE('',*,*,#796,.T.);
#1138=ORIENTED_EDGE('',*,*,#797,.T.);
#1139=ORIENTED_EDGE('',*,*,#795,.F.);
#1140=ORIENTED_EDGE('',*,*,#796,.F.);
#1141=ORIENTED_EDGE('',*,*,#797,.F.);
#1142=ORIENTED_EDGE('',*,*,#798,.T.);
#1143=ORIENTED_EDGE('',*,*,#799,.T.);
#1144=ORIENTED_EDGE('',*,*,#800,.T.);
#1145=ORIENTED_EDGE('',*,*,#798,.F.);
#1146=ORIENTED_EDGE('',*,*,#800,.F.);
#1147=ORIENTED_EDGE('',*,*,#801,.T.);
#1148=ORIENTED_EDGE('',*,*,#802,.T.);
#1149=ORIENTED_EDGE('',*,*,#803,.T.);
#1150=ORIENTED_EDGE('',*,*,#801,.F.);
#1151=ORIENTED_EDGE('',*,*,#799,.F.);
#1152=ORIENTED_EDGE('',*,*,#802,.F.);
#1153=ORIENTED_EDGE('',*,*,#803,.F.);
#1154=ORIENTED_EDGE('',*,*,#804,.T.);
#1155=ORIENTED_EDGE('',*,*,#805,.T.);
#1156=ORIENTED_EDGE('',*,*,#806,.T.);
#1157=ORIENTED_EDGE('',*,*,#804,.F.);
#1158=ORIENTED_EDGE('',*,*,#806,.F.);
#1159=ORIENTED_EDGE('',*,*,#807,.T.);
#1160=ORIENTED_EDGE('',*,*,#808,.T.);
#1161=ORIENTED_EDGE('',*,*,#809,.T.);
#1162=ORIENTED_EDGE('',*,*,#807,.F.);
#1163=ORIENTED_EDGE('',*,*,#805,.F.);
#1164=ORIENTED_EDGE('',*,*,#808,.F.);
#1165=ORIENTED_EDGE('',*,*,#809,.F.);
#1166=ORIENTED_EDGE('',*,*,#810,.T.);
#1167=ORIENTED_EDGE('',*,*,#811,.T.);
#1168=ORIENTED_EDGE('',*,*,#812,.T.);
#1169=ORIENTED_EDGE('',*,*,#810,.F.);
#1170=ORIENTED_EDGE('',*,*,#812,.F.);
#1171=ORIENTED_EDGE('',*,*,#813,.T.);
#1172=ORIENTED_EDGE('',*,*,#814,.T.);
#1173=ORIENTED_EDGE('',*,*,#813,.F.);
#1174=ORIENTED_EDGE('',*,*,#811,.F.);
#1175=ORIENTED_EDGE('',*,*,#794,.T.);
#1176=ORIENTED_EDGE('',*,*,#814,.F.);
#1177=TOROIDAL_SURFACE('',#1280,13.3,1.);
#1178=TOROIDAL_SURFACE('',#1385,0.79999999999999,0.300000000000001);
#1179=TOROIDAL_SURFACE('',#1392,0.999999999999998,0.3);
#1180=TOROIDAL_SURFACE('',#1399,1.2,0.3);
#1181=TOROIDAL_SURFACE('',#1411,0.79999999999999,0.300000000000001);
#1182=TOROIDAL_SURFACE('',#1418,0.999999999999998,0.3);
#1183=TOROIDAL_SURFACE('',#1425,1.2,0.3);
#1184=TOROIDAL_SURFACE('',#1437,0.79999999999999,0.300000000000001);
#1185=TOROIDAL_SURFACE('',#1444,0.999999999999998,0.3);
#1186=TOROIDAL_SURFACE('',#1451,1.2,0.3);
#1187=ADVANCED_FACE('',(#252),#1177,.T.);
#1188=ADVANCED_FACE('',(#253),#223,.T.);
#1189=ADVANCED_FACE('',(#254,#23),#33,.T.);
#1190=ADVANCED_FACE('',(#255),#224,.T.);
#1191=ADVANCED_FACE('',(#256),#225,.F.);
#1192=ADVANCED_FACE('',(#257),#226,.T.);
#1193=ADVANCED_FACE('',(#258),#227,.T.);
#1194=ADVANCED_FACE('',(#259,#24),#34,.T.);
#1195=ADVANCED_FACE('',(#260),#228,.F.);
#1196=ADVANCED_FACE('',(#261),#229,.T.);
#1197=ADVANCED_FACE('',(#262),#230,.T.);
#1198=ADVANCED_FACE('',(#263,#25),#35,.F.);
#1199=ADVANCED_FACE('',(#264,#26),#36,.F.);
#1200=ADVANCED_FACE('',(#265),#37,.T.);
#1201=ADVANCED_FACE('',(#266),#38,.T.);
#1202=ADVANCED_FACE('',(#267),#231,.T.);
#1203=ADVANCED_FACE('',(#268),#39,.F.);
#1204=ADVANCED_FACE('',(#269,#27),#40,.F.);
#1205=ADVANCED_FACE('',(#270,#28),#41,.F.);
#1206=ADVANCED_FACE('',(#271),#42,.T.);
#1207=ADVANCED_FACE('',(#272),#43,.T.);
#1208=ADVANCED_FACE('',(#273),#232,.T.);
#1209=ADVANCED_FACE('',(#274),#44,.F.);
#1210=ADVANCED_FACE('',(#275,#29),#45,.F.);
#1211=ADVANCED_FACE('',(#276,#30),#46,.F.);
#1212=ADVANCED_FACE('',(#277),#47,.T.);
#1213=ADVANCED_FACE('',(#278),#48,.T.);
#1214=ADVANCED_FACE('',(#279),#233,.T.);
#1215=ADVANCED_FACE('',(#280),#234,.T.);
#1216=ADVANCED_FACE('',(#281),#49,.F.);
#1217=ADVANCED_FACE('',(#282),#50,.F.);
#1218=ADVANCED_FACE('',(#283),#51,.T.);
#1219=ADVANCED_FACE('',(#284),#52,.T.);
#1220=ADVANCED_FACE('',(#285),#235,.F.);
#1221=ADVANCED_FACE('',(#286),#53,.F.);
#1222=ADVANCED_FACE('',(#287),#54,.T.);
#1223=ADVANCED_FACE('',(#288),#55,.T.);
#1224=ADVANCED_FACE('',(#289),#236,.F.);
#1225=ADVANCED_FACE('',(#290),#56,.F.);
#1226=ADVANCED_FACE('',(#291),#57,.T.);
#1227=ADVANCED_FACE('',(#292),#58,.T.);
#1228=ADVANCED_FACE('',(#293,#31),#59,.T.);
#1229=ADVANCED_FACE('',(#294),#237,.F.);
#1230=ADVANCED_FACE('',(#295,#32),#60,.T.);
#1231=ADVANCED_FACE('',(#296),#238,.F.);
#1232=ADVANCED_FACE('',(#297),#239,.T.);
#1233=ADVANCED_FACE('',(#298),#61,.T.);
#1234=ADVANCED_FACE('',(#299),#62,.F.);
#1235=ADVANCED_FACE('',(#300),#240,.T.);
#1236=ADVANCED_FACE('',(#301),#1178,.T.);
#1237=ADVANCED_FACE('',(#302),#241,.T.);
#1238=ADVANCED_FACE('',(#303),#1179,.T.);
#1239=ADVANCED_FACE('',(#304),#242,.T.);
#1240=ADVANCED_FACE('',(#305),#1180,.T.);
#1241=ADVANCED_FACE('',(#306),#243,.T.);
#1242=ADVANCED_FACE('',(#307),#63,.T.);
#1243=ADVANCED_FACE('',(#308),#64,.F.);
#1244=ADVANCED_FACE('',(#309),#244,.T.);
#1245=ADVANCED_FACE('',(#310),#1181,.T.);
#1246=ADVANCED_FACE('',(#311),#245,.T.);
#1247=ADVANCED_FACE('',(#312),#1182,.T.);
#1248=ADVANCED_FACE('',(#313),#246,.T.);
#1249=ADVANCED_FACE('',(#314),#1183,.T.);
#1250=ADVANCED_FACE('',(#315),#247,.T.);
#1251=ADVANCED_FACE('',(#316),#65,.T.);
#1252=ADVANCED_FACE('',(#317),#66,.F.);
#1253=ADVANCED_FACE('',(#318),#248,.T.);
#1254=ADVANCED_FACE('',(#319),#1184,.T.);
#1255=ADVANCED_FACE('',(#320),#249,.T.);
#1256=ADVANCED_FACE('',(#321),#1185,.T.);
#1257=ADVANCED_FACE('',(#322),#250,.T.);
#1258=ADVANCED_FACE('',(#323),#1186,.T.);
#1259=ADVANCED_FACE('',(#324),#251,.T.);
#1260=ADVANCED_FACE('',(#325),#67,.T.);
#1261=ADVANCED_FACE('',(#326),#68,.F.);
#1262=CLOSED_SHELL('',(#1187,#1188,#1189,#1190,#1191,#1192,#1193,#1194,
#1195,#1196,#1197,#1198,#1199,#1200,#1201,#1202,#1203,#1204,#1205,#1206,
#1207,#1208,#1209,#1210,#1211,#1212,#1213,#1214,#1215,#1216,#1217,#1218,
#1219,#1220,#1221,#1222,#1223,#1224,#1225,#1226,#1227,#1228,#1229,#1230,
#1231));
#1263=CLOSED_SHELL('',(#1232,#1233,#1234));
#1264=CLOSED_SHELL('',(#1235,#1236,#1237,#1238,#1239,#1240,#1241,#1242,
#1243));
#1265=CLOSED_SHELL('',(#1244,#1245,#1246,#1247,#1248,#1249,#1250,#1251,
#1252));
#1266=CLOSED_SHELL('',(#1253,#1254,#1255,#1256,#1257,#1258,#1259,#1260,
#1261));
#1267=DERIVED_UNIT_ELEMENT(#1269,1.);
#1268=DERIVED_UNIT_ELEMENT(#2276,3.);
#1269=(
MASS_UNIT()
NAMED_UNIT(*)
SI_UNIT(.KILO.,.GRAM.)
#1270=DERIVED_UNIT((#1267,#1268));
#1271=MEASURE_REPRESENTATION_ITEM('density measure',
POSITIVE_RATIO_MEASURE(7850.),#1270);
#1272=PROPERTY_DEFINITION_REPRESENTATION(#1277,#1274);
#1273=PROPERTY_DEFINITION_REPRESENTATION(#1278,#1275);
#1274=REPRESENTATION('material name',(#1276),#2273);
#1275=REPRESENTATION('density',(#1271),#2273);
#1276=DESCRIPTIVE_REPRESENTATION_ITEM('Steel','Steel');
#1277=PROPERTY_DEFINITION('material property','material name',#2283);
#1278=PROPERTY_DEFINITION('material property','density of part',#2283);
#1279=AXIS2_PLACEMENT_3D('placement',#1896,#1459,#1460);
#1280=AXIS2_PLACEMENT_3D('',#1897,#1461,#1462);
#1281=AXIS2_PLACEMENT_3D('',#1900,#1463,#1464);
#1282=AXIS2_PLACEMENT_3D('',#1902,#1465,#1466);
#1283=AXIS2_PLACEMENT_3D('',#1904,#1467,#1468);
#1284=AXIS2_PLACEMENT_3D('',#1905,#1469,#1470);
#1285=AXIS2_PLACEMENT_3D('',#1906,#1471,#1472);
#1286=AXIS2_PLACEMENT_3D('',#1907,#1473,#1474);
#1287=AXIS2_PLACEMENT_3D('',#1911,#1476,#1477);
#1288=AXIS2_PLACEMENT_3D('',#1915,#1479,#1480);
#1289=AXIS2_PLACEMENT_3D('',#1919,#1482,#1483);
#1290=AXIS2_PLACEMENT_3D('',#1923,#1485,#1486);
#1291=AXIS2_PLACEMENT_3D('',#1927,#1488,#1489);
#1292=AXIS2_PLACEMENT_3D('',#1931,#1491,#1492);
#1293=AXIS2_PLACEMENT_3D('',#1935,#1494,#1495);
#1294=AXIS2_PLACEMENT_3D('',#1939,#1497,#1498);
#1295=AXIS2_PLACEMENT_3D('',#1943,#1500,#1501);
#1296=AXIS2_PLACEMENT_3D('',#1946,#1503,#1504);
#1297=AXIS2_PLACEMENT_3D('',#1947,#1505,#1506);
#1298=AXIS2_PLACEMENT_3D('',#1950,#1507,#1508);
#1299=AXIS2_PLACEMENT_3D('',#1951,#1509,#1510);
#1300=AXIS2_PLACEMENT_3D('',#1952,#1511,#1512);
#1301=AXIS2_PLACEMENT_3D('',#1954,#1513,#1514);
#1302=AXIS2_PLACEMENT_3D('',#1957,#1516,#1517);
#1303=AXIS2_PLACEMENT_3D('',#1958,#1518,#1519);
#1304=AXIS2_PLACEMENT_3D('',#1959,#1520,#1521);
#1305=AXIS2_PLACEMENT_3D('',#1963,#1523,#1524);
#1306=AXIS2_PLACEMENT_3D('',#1965,#1526,#1527);
#1307=AXIS2_PLACEMENT_3D('',#1970,#1529,#1530);
#1308=AXIS2_PLACEMENT_3D('',#1973,#1532,#1533);
#1309=AXIS2_PLACEMENT_3D('',#1974,#1534,#1535);
#1310=AXIS2_PLACEMENT_3D('',#1976,#1536,#1537);
#1311=AXIS2_PLACEMENT_3D('',#1979,#1539,#1540);
#1312=AXIS2_PLACEMENT_3D('',#1980,#1541,#1542);
#1313=AXIS2_PLACEMENT_3D('',#1981,#1543,#1544);
#1314=AXIS2_PLACEMENT_3D('',#1982,#1545,#1546);
#1315=AXIS2_PLACEMENT_3D('',#1985,#1547,#1548);
#1316=AXIS2_PLACEMENT_3D('',#1986,#1549,#1550);
#1317=AXIS2_PLACEMENT_3D('',#1987,#1551,#1552);
#1318=AXIS2_PLACEMENT_3D('',#1990,#1553,#1554);
#1319=AXIS2_PLACEMENT_3D('',#1992,#1556,#1557);
#1320=AXIS2_PLACEMENT_3D('',#1993,#1558,#1559);
#1321=AXIS2_PLACEMENT_3D('',#1998,#1561,#1562);
#1322=AXIS2_PLACEMENT_3D('',#2001,#1564,#1565);
#1323=AXIS2_PLACEMENT_3D('',#2002,#1566,#1567);
#1324=AXIS2_PLACEMENT_3D('',#2004,#1568,#1569);
#1325=AXIS2_PLACEMENT_3D('',#2007,#1571,#1572);
#1326=AXIS2_PLACEMENT_3D('',#2008,#1573,#1574);
#1327=AXIS2_PLACEMENT_3D('',#2014,#1578,#1579);
#1328=AXIS2_PLACEMENT_3D('',#2020,#1584,#1585);
#1329=AXIS2_PLACEMENT_3D('',#2022,#1587,#1588);
#1330=AXIS2_PLACEMENT_3D('',#2024,#1589,#1590);
#1331=AXIS2_PLACEMENT_3D('',#2026,#1592,#1593);
#1332=AXIS2_PLACEMENT_3D('',#2028,#1594,#1595);
#1333=AXIS2_PLACEMENT_3D('',#2030,#1597,#1598);
#1334=AXIS2_PLACEMENT_3D('',#2032,#1600,#1601);
#1335=AXIS2_PLACEMENT_3D('',#2040,#1606,#1607);
#1336=AXIS2_PLACEMENT_3D('',#2046,#1612,#1613);
#1337=AXIS2_PLACEMENT_3D('',#2048,#1615,#1616);
#1338=AXIS2_PLACEMENT_3D('',#2050,#1617,#1618);
#1339=AXIS2_PLACEMENT_3D('',#2053,#1620,#1621);
#1340=AXIS2_PLACEMENT_3D('',#2054,#1622,#1623);
#1341=AXIS2_PLACEMENT_3D('',#2056,#1624,#1625);
#1342=AXIS2_PLACEMENT_3D('',#2058,#1627,#1628);
#1343=AXIS2_PLACEMENT_3D('',#2060,#1630,#1631);
#1344=AXIS2_PLACEMENT_3D('',#2068,#1636,#1637);
#1345=AXIS2_PLACEMENT_3D('',#2077,#1643,#1644);
#1346=AXIS2_PLACEMENT_3D('',#2080,#1646,#1647);
#1347=AXIS2_PLACEMENT_3D('',#2081,#1648,#1649);
#1348=AXIS2_PLACEMENT_3D('',#2083,#1650,#1651);
#1349=AXIS2_PLACEMENT_3D('',#2086,#1653,#1654);
#1350=AXIS2_PLACEMENT_3D('',#2087,#1655,#1656);
#1351=AXIS2_PLACEMENT_3D('',#2090,#1658,#1659);
#1352=AXIS2_PLACEMENT_3D('',#2091,#1660,#1661);
#1353=AXIS2_PLACEMENT_3D('',#2093,#1662,#1663);
#1354=AXIS2_PLACEMENT_3D('',#2095,#1665,#1666);
#1355=AXIS2_PLACEMENT_3D('',#2097,#1668,#1669);
#1356=AXIS2_PLACEMENT_3D('',#2099,#1671,#1672);
#1357=AXIS2_PLACEMENT_3D('',#2100,#1673,#1674);
#1358=AXIS2_PLACEMENT_3D('',#2101,#1675,#1676);
#1359=AXIS2_PLACEMENT_3D('',#2103,#1678,#1679);
#1360=AXIS2_PLACEMENT_3D('',#2105,#1681,#1682);
#1361=AXIS2_PLACEMENT_3D('',#2106,#1683,#1684);
#1362=AXIS2_PLACEMENT_3D('',#2107,#1685,#1686);
#1363=AXIS2_PLACEMENT_3D('',#2109,#1688,#1689);
#1364=AXIS2_PLACEMENT_3D('',#2111,#1691,#1692);
#1365=AXIS2_PLACEMENT_3D('',#2112,#1693,#1694);
#1366=AXIS2_PLACEMENT_3D('',#2113,#1695,#1696);
#1367=AXIS2_PLACEMENT_3D('',#2116,#1697,#1698);
#1368=AXIS2_PLACEMENT_3D('',#2117,#1699,#1700);
#1369=AXIS2_PLACEMENT_3D('',#2120,#1701,#1702);
#1370=AXIS2_PLACEMENT_3D('',#2121,#1703,#1704);
#1371=AXIS2_PLACEMENT_3D('',#2122,#1705,#1706);
#1372=AXIS2_PLACEMENT_3D('',#2126,#1708,#1709);
#1373=AXIS2_PLACEMENT_3D('',#2127,#1710,#1711);
#1374=AXIS2_PLACEMENT_3D('',#2128,#1712,#1713);
#1375=AXIS2_PLACEMENT_3D('',#2129,#1714,#1715);
#1376=AXIS2_PLACEMENT_3D('',#2131,#1717,#1718);
#1377=AXIS2_PLACEMENT_3D('',#2133,#1719,#1720);
#1378=AXIS2_PLACEMENT_3D('',#2136,#1722,#1723);
#1379=AXIS2_PLACEMENT_3D('',#2137,#1724,#1725);
#1380=AXIS2_PLACEMENT_3D('',#2138,#1726,#1727);
#1381=AXIS2_PLACEMENT_3D('',#2139,#1728,#1729);
#1382=AXIS2_PLACEMENT_3D('',#2141,#1730,#1731);
#1383=AXIS2_PLACEMENT_3D('',#2145,#1733,#1734);
#1384=AXIS2_PLACEMENT_3D('',#2146,#1735,#1736);
#1385=AXIS2_PLACEMENT_3D('',#2147,#1737,#1738);
#1386=AXIS2_PLACEMENT_3D('',#2149,#1739,#1740);
#1387=AXIS2_PLACEMENT_3D('',#2151,#1741,#1742);
#1388=AXIS2_PLACEMENT_3D('',#2152,#1743,#1744);
#1389=AXIS2_PLACEMENT_3D('',#2153,#1745,#1746);
#1390=AXIS2_PLACEMENT_3D('',#2157,#1748,#1749);
#1391=AXIS2_PLACEMENT_3D('',#2158,#1750,#1751);
#1392=AXIS2_PLACEMENT_3D('',#2159,#1752,#1753);
#1393=AXIS2_PLACEMENT_3D('',#2161,#1754,#1755);
#1394=AXIS2_PLACEMENT_3D('',#2163,#1756,#1757);
#1395=AXIS2_PLACEMENT_3D('',#2164,#1758,#1759);
#1396=AXIS2_PLACEMENT_3D('',#2165,#1760,#1761);
#1397=AXIS2_PLACEMENT_3D('',#2169,#1763,#1764);
#1398=AXIS2_PLACEMENT_3D('',#2170,#1765,#1766);
#1399=AXIS2_PLACEMENT_3D('',#2171,#1767,#1768);
#1400=AXIS2_PLACEMENT_3D('',#2173,#1769,#1770);
#1401=AXIS2_PLACEMENT_3D('',#2175,#1771,#1772);
#1402=AXIS2_PLACEMENT_3D('',#2176,#1773,#1774);
#1403=AXIS2_PLACEMENT_3D('',#2177,#1775,#1776);
#1404=AXIS2_PLACEMENT_3D('',#2180,#1778,#1779);
#1405=AXIS2_PLACEMENT_3D('',#2181,#1780,#1781);
#1406=AXIS2_PLACEMENT_3D('',#2182,#1782,#1783);
#1407=AXIS2_PLACEMENT_3D('',#2183,#1784,#1785);
#1408=AXIS2_PLACEMENT_3D('',#2185,#1786,#1787);
#1409=AXIS2_PLACEMENT_3D('',#2189,#1789,#1790);
#1410=AXIS2_PLACEMENT_3D('',#2190,#1791,#1792);
#1411=AXIS2_PLACEMENT_3D('',#2191,#1793,#1794);
#1412=AXIS2_PLACEMENT_3D('',#2193,#1795,#1796);
#1413=AXIS2_PLACEMENT_3D('',#2195,#1797,#1798);
#1414=AXIS2_PLACEMENT_3D('',#2196,#1799,#1800);
#1415=AXIS2_PLACEMENT_3D('',#2197,#1801,#1802);
#1416=AXIS2_PLACEMENT_3D('',#2201,#1804,#1805);
#1417=AXIS2_PLACEMENT_3D('',#2202,#1806,#1807);
#1418=AXIS2_PLACEMENT_3D('',#2203,#1808,#1809);
#1419=AXIS2_PLACEMENT_3D('',#2205,#1810,#1811);
#1420=AXIS2_PLACEMENT_3D('',#2207,#1812,#1813);
#1421=AXIS2_PLACEMENT_3D('',#2208,#1814,#1815);
#1422=AXIS2_PLACEMENT_3D('',#2209,#1816,#1817);
#1423=AXIS2_PLACEMENT_3D('',#2213,#1819,#1820);
#1424=AXIS2_PLACEMENT_3D('',#2214,#1821,#1822);
#1425=AXIS2_PLACEMENT_3D('',#2215,#1823,#1824);
#1426=AXIS2_PLACEMENT_3D('',#2217,#1825,#1826);
#1427=AXIS2_PLACEMENT_3D('',#2219,#1827,#1828);
#1428=AXIS2_PLACEMENT_3D('',#2220,#1829,#1830);
#1429=AXIS2_PLACEMENT_3D('',#2221,#1831,#1832);
#1430=AXIS2_PLACEMENT_3D('',#2224,#1834,#1835);
#1431=AXIS2_PLACEMENT_3D('',#2225,#1836,#1837);
#1432=AXIS2_PLACEMENT_3D('',#2226,#1838,#1839);
#1433=AXIS2_PLACEMENT_3D('',#2227,#1840,#1841);
#1434=AXIS2_PLACEMENT_3D('',#2229,#1842,#1843);
#1435=AXIS2_PLACEMENT_3D('',#2233,#1845,#1846);
#1436=AXIS2_PLACEMENT_3D('',#2234,#1847,#1848);
#1437=AXIS2_PLACEMENT_3D('',#2235,#1849,#1850);
#1438=AXIS2_PLACEMENT_3D('',#2237,#1851,#1852);
#1439=AXIS2_PLACEMENT_3D('',#2239,#1853,#1854);
#1440=AXIS2_PLACEMENT_3D('',#2240,#1855,#1856);
#1441=AXIS2_PLACEMENT_3D('',#2241,#1857,#1858);
#1442=AXIS2_PLACEMENT_3D('',#2245,#1860,#1861);
#1443=AXIS2_PLACEMENT_3D('',#2246,#1862,#1863);
#1444=AXIS2_PLACEMENT_3D('',#2247,#1864,#1865);
#1445=AXIS2_PLACEMENT_3D('',#2249,#1866,#1867);
#1446=AXIS2_PLACEMENT_3D('',#2251,#1868,#1869);
#1447=AXIS2_PLACEMENT_3D('',#2252,#1870,#1871);
#1448=AXIS2_PLACEMENT_3D('',#2253,#1872,#1873);
#1449=AXIS2_PLACEMENT_3D('',#2257,#1875,#1876);
#1450=AXIS2_PLACEMENT_3D('',#2258,#1877,#1878);
#1451=AXIS2_PLACEMENT_3D('',#2259,#1879,#1880);
#1452=AXIS2_PLACEMENT_3D('',#2261,#1881,#1882);
#1453=AXIS2_PLACEMENT_3D('',#2263,#1883,#1884);
#1454=AXIS2_PLACEMENT_3D('',#2264,#1885,#1886);
#1455=AXIS2_PLACEMENT_3D('',#2265,#1887,#1888);
#1456=AXIS2_PLACEMENT_3D('',#2268,#1890,#1891);
#1457=AXIS2_PLACEMENT_3D('',#2269,#1892,#1893);
#1458=AXIS2_PLACEMENT_3D('',#2270,#1894,#1895);
#1459=DIRECTION('axis',(0.,0.,1.));
#1460=DIRECTION('refdir',(1.,0.,0.));
#1461=DIRECTION('center_axis',(0.,0.,1.));
#1462=DIRECTION('ref_axis',(1.,0.,0.));
#1463=DIRECTION('center_axis',(0.,0.,-1.));
#1464=DIRECTION('ref_axis',(-1.,1.22464679914735E-16,0.));
#1465=DIRECTION('center_axis',(1.22464679914735E-16,-1.,0.));
#1466=DIRECTION('ref_axis',(-1.,-1.22464679914735E-16,0.));
#1467=DIRECTION('center_axis',(0.,0.,1.));
#1468=DIRECTION('ref_axis',(-1.,1.22464679914735E-16,0.));
#1469=DIRECTION('center_axis',(0.,0.,1.));
#1470=DIRECTION('ref_axis',(-1.,1.22464679914735E-16,0.));
#1471=DIRECTION('center_axis',(0.,0.,-1.));
#1472=DIRECTION('ref_axis',(-1.,1.22464679914735E-16,0.));
#1473=DIRECTION('center_axis',(0.,0.,1.));
#1474=DIRECTION('ref_axis',(1.,0.,0.));
#1475=DIRECTION('',(0.,0.,-1.));
#1476=DIRECTION('center_axis',(0.,0.,1.));
#1477=DIRECTION('ref_axis',(1.,0.,0.));
#1478=DIRECTION('',(0.,0.,1.));
#1479=DIRECTION('center_axis',(0.,0.,1.));
#1480=DIRECTION('ref_axis',(1.,0.,0.));
#1481=DIRECTION('',(0.,0.,-1.));
#1482=DIRECTION('center_axis',(0.,0.,1.));
#1483=DIRECTION('ref_axis',(1.,0.,0.));
#1484=DIRECTION('',(0.,0.,-1.));
#1485=DIRECTION('center_axis',(0.,0.,1.));
#1486=DIRECTION('ref_axis',(1.,0.,0.));
#1487=DIRECTION('',(0.,0.,1.));
#1488=DIRECTION('center_axis',(0.,0.,1.));
#1489=DIRECTION('ref_axis',(1.,0.,0.));
#1490=DIRECTION('',(0.,0.,-1.));
#1491=DIRECTION('center_axis',(0.,0.,-1.));
#1492=DIRECTION('ref_axis',(1.,0.,0.));
#1493=DIRECTION('',(0.,0.,-1.));
#1494=DIRECTION('center_axis',(0.,0.,1.));
#1495=DIRECTION('ref_axis',(1.,0.,0.));
#1496=DIRECTION('',(0.,0.,1.));
#1497=DIRECTION('center_axis',(0.,0.,1.));
#1498=DIRECTION('ref_axis',(1.,0.,0.));
#1499=DIRECTION('',(0.,0.,-1.));
#1500=DIRECTION('center_axis',(0.,0.,1.));
#1501=DIRECTION('ref_axis',(1.,0.,0.));
#1502=DIRECTION('',(0.,0.,-1.));
#1503=DIRECTION('center_axis',(0.,0.,1.));
#1504=DIRECTION('ref_axis',(1.,0.,0.));
#1505=DIRECTION('center_axis',(0.,0.,1.));
#1506=DIRECTION('ref_axis',(1.,0.,0.));
#1507=DIRECTION('center_axis',(0.,0.,1.));
#1508=DIRECTION('ref_axis',(1.,0.,0.));
#1509=DIRECTION('center_axis',(0.,0.,1.));
#1510=DIRECTION('ref_axis',(1.,0.,0.));
#1511=DIRECTION('center_axis',(0.0695846414945132,0.997576051069832,0.));
#1512=DIRECTION('ref_axis',(0.997576051069832,-0.0695846414945132,0.));
#1513=DIRECTION('center_axis',(0.0695846414945143,0.997576051069832,0.));
#1514=DIRECTION('ref_axis',(0.997576051069832,-0.0695846414945132,0.));
#1515=DIRECTION('',(-0.0695846414945132,-0.997576051069832,0.));
#1516=DIRECTION('center_axis',(-0.0695846414945144,-0.997576051069832,0.));
#1517=DIRECTION('ref_axis',(0.997576051069832,-0.0695846414945132,0.));
#1518=DIRECTION('center_axis',(0.,0.,-1.));
#1519=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1520=DIRECTION('center_axis',(0.,0.,1.));
#1521=DIRECTION('ref_axis',(1.,0.,0.));
#1522=DIRECTION('',(0.,0.,-1.));
#1523=DIRECTION('center_axis',(0.,0.,1.));
#1524=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1525=DIRECTION('',(0.,0.,-1.));
#1526=DIRECTION('center_axis',(0.,0.,-1.));
#1527=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1528=DIRECTION('',(0.,0.,-1.));
#1529=DIRECTION('center_axis',(0.,0.,-1.));
#1530=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1531=DIRECTION('',(0.,0.,-1.));
#1532=DIRECTION('center_axis',(0.,0.,1.));
#1533=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1534=DIRECTION('center_axis',(0.829133881686181,-0.559050092782397,0.));
#1535=DIRECTION('ref_axis',(-0.559050092782397,-0.829133881686181,0.));
#1536=DIRECTION('center_axis',(0.82913388168618,-0.559050092782398,0.));
#1537=DIRECTION('ref_axis',(-0.559050092782397,-0.829133881686181,0.));
#1538=DIRECTION('',(-0.829133881686181,0.559050092782397,0.));
#1539=DIRECTION('center_axis',(-0.82913388168618,0.559050092782398,0.));
#1540=DIRECTION('ref_axis',(-0.559050092782397,-0.829133881686181,0.));
#1541=DIRECTION('center_axis',(0.,0.,-1.));
#1542=DIRECTION('ref_axis',(-1.,0.,0.));
#1543=DIRECTION('center_axis',(0.,0.,1.));
#1544=DIRECTION('ref_axis',(1.,0.,0.));
#1545=DIRECTION('center_axis',(0.,0.,-1.));
#1546=DIRECTION('ref_axis',(1.,0.,0.));
#1547=DIRECTION('center_axis',(0.,0.,1.));
#1548=DIRECTION('ref_axis',(1.,0.,0.));
#1549=DIRECTION('center_axis',(0.,0.,1.));
#1550=DIRECTION('ref_axis',(1.,0.,0.));
#1551=DIRECTION('center_axis',(0.,0.,1.));
#1552=DIRECTION('ref_axis',(1.,0.,0.));
#1553=DIRECTION('center_axis',(0.,0.,1.));
#1554=DIRECTION('ref_axis',(1.,0.,0.));
#1555=DIRECTION('',(0.,0.,-1.));
#1556=DIRECTION('center_axis',(0.,0.,1.));
#1557=DIRECTION('ref_axis',(1.,0.,0.));
#1558=DIRECTION('center_axis',(0.,0.,-1.));
#1559=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1560=DIRECTION('',(0.,0.,-1.));
#1561=DIRECTION('center_axis',(0.,0.,-1.));
#1562=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1563=DIRECTION('',(0.,0.,-1.));
#1564=DIRECTION('center_axis',(0.,0.,1.));
#1565=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1566=DIRECTION('center_axis',(-0.898718523180693,-0.438525958287435,0.));
#1567=DIRECTION('ref_axis',(-0.438525958287435,0.898718523180693,0.));
#1568=DIRECTION('center_axis',(-0.898718523180694,-0.438525958287434,0.));
#1569=DIRECTION('ref_axis',(-0.438525958287435,0.898718523180693,0.));
#1570=DIRECTION('',(0.898718523180693,0.438525958287435,0.));
#1571=DIRECTION('center_axis',(0.898718523180694,0.438525958287434,0.));
#1572=DIRECTION('ref_axis',(-0.438525958287435,0.898718523180693,0.));
#1573=DIRECTION('center_axis',(0.0695846414945143,0.997576051069832,0.));
#1574=DIRECTION('ref_axis',(0.997576051069832,-0.0695846414945143,0.));
#1575=DIRECTION('',(-0.997576051069832,0.0695846414945143,0.));
#1576=DIRECTION('',(0.997576051069832,-0.0695846414945143,0.));
#1577=DIRECTION('',(0.,0.,1.));
#1578=DIRECTION('center_axis',(-0.0695846414945144,-0.997576051069832,0.));
#1579=DIRECTION('ref_axis',(-0.997576051069832,0.0695846414945144,0.));
#1580=DIRECTION('',(0.997576051069832,-0.0695846414945144,0.));
#1581=DIRECTION('',(-0.997576051069832,0.0695846414945144,0.));
#1582=DIRECTION('',(0.,0.,-1.));
#1583=DIRECTION('',(0.,0.,1.));
#1584=DIRECTION('center_axis',(0.,0.,-1.));
#1585=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1586=DIRECTION('',(-0.499999999999955,-0.866025403784465,0.));
#1587=DIRECTION('center_axis',(0.,0.,-1.));
#1588=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1589=DIRECTION('center_axis',(0.,0.,-1.));
#1590=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1591=DIRECTION('',(0.500000000000047,0.866025403784412,0.));
#1592=DIRECTION('center_axis',(0.,0.,-1.));
#1593=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1594=DIRECTION('center_axis',(0.,0.,1.));
#1595=DIRECTION('ref_axis',(0.866025403784438,-0.5,0.));
#1596=DIRECTION('',(0.,0.,-1.));
#1597=DIRECTION('center_axis',(0.,0.,-1.));
#1598=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1599=DIRECTION('',(0.499999999999955,0.866025403784465,0.));
#1600=DIRECTION('center_axis',(0.82913388168618,-0.559050092782398,0.));
#1601=DIRECTION('ref_axis',(-0.559050092782398,-0.82913388168618,0.));
#1602=DIRECTION('',(0.559050092782398,0.82913388168618,0.));
#1603=DIRECTION('',(0.,0.,-1.));
#1604=DIRECTION('',(-0.559050092782398,-0.82913388168618,0.));
#1605=DIRECTION('',(0.,0.,1.));
#1606=DIRECTION('center_axis',(-0.82913388168618,0.559050092782398,0.));
#1607=DIRECTION('ref_axis',(0.559050092782398,0.82913388168618,0.));
#1608=DIRECTION('',(-0.559050092782398,-0.82913388168618,0.));
#1609=DIRECTION('',(0.559050092782398,0.82913388168618,0.));
#1610=DIRECTION('',(0.,0.,-1.));
#1611=DIRECTION('',(0.,0.,1.));
#1612=DIRECTION('center_axis',(0.,0.,-1.));
#1613=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1614=DIRECTION('',(-0.500000000000046,0.866025403784412,0.));
#1615=DIRECTION('center_axis',(0.,0.,-1.));
#1616=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1617=DIRECTION('center_axis',(0.,0.,-1.));
#1618=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1619=DIRECTION('',(0.499999999999954,-0.866025403784465,0.));
#1620=DIRECTION('center_axis',(0.,0.,1.));
#1621=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1622=DIRECTION('center_axis',(0.,0.,-1.));
#1623=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1624=DIRECTION('center_axis',(0.,0.,1.));
#1625=DIRECTION('ref_axis',(-0.866025403784439,-0.5,0.));
#1626=DIRECTION('',(0.,0.,-1.));
#1627=DIRECTION('center_axis',(0.,0.,-1.));
#1628=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1629=DIRECTION('',(0.500000000000046,-0.866025403784412,0.));
#1630=DIRECTION('center_axis',(-0.898718523180694,-0.438525958287434,0.));
#1631=DIRECTION('ref_axis',(-0.438525958287434,0.898718523180694,0.));
#1632=DIRECTION('',(0.438525958287434,-0.898718523180694,0.));
#1633=DIRECTION('',(0.,0.,-1.));
#1634=DIRECTION('',(-0.438525958287434,0.898718523180694,0.));
#1635=DIRECTION('',(0.,0.,1.));
#1636=DIRECTION('center_axis',(0.898718523180694,0.438525958287434,0.));
#1637=DIRECTION('ref_axis',(0.438525958287434,-0.898718523180694,0.));
#1638=DIRECTION('',(-0.438525958287434,0.898718523180694,0.));
#1639=DIRECTION('',(0.,0.,-1.));
#1640=DIRECTION('',(0.438525958287434,-0.898718523180694,0.));
#1641=DIRECTION('',(0.,0.,-1.));
#1642=DIRECTION('',(0.,0.,1.));
#1643=DIRECTION('center_axis',(0.,0.,-1.));
#1644=DIRECTION('ref_axis',(1.,0.,0.));
#1645=DIRECTION('',(1.,5.28969698967948E-14,0.));
#1646=DIRECTION('center_axis',(0.,0.,-1.));
#1647=DIRECTION('ref_axis',(0.,1.,0.));
#1648=DIRECTION('center_axis',(0.,0.,-1.));
#1649=DIRECTION('ref_axis',(1.,0.,0.));
#1650=DIRECTION('center_axis',(0.,0.,-1.));
#1651=DIRECTION('ref_axis',(0.,1.,0.));
#1652=DIRECTION('',(-1.,5.3192483695101E-14,0.));
#1653=DIRECTION('center_axis',(0.,0.,1.));
#1654=DIRECTION('ref_axis',(1.,0.,0.));
#1655=DIRECTION('center_axis',(0.,0.,-1.));
#1656=DIRECTION('ref_axis',(0.,1.,0.));
#1657=DIRECTION('',(0.,0.,-1.));
#1658=DIRECTION('center_axis',(0.,0.,1.));
#1659=DIRECTION('ref_axis',(0.,1.,0.));
#1660=DIRECTION('center_axis',(0.,0.,-1.));
#1661=DIRECTION('ref_axis',(0.,1.,0.));
#1662=DIRECTION('center_axis',(0.,0.,1.));
#1663=DIRECTION('ref_axis',(0.,1.,0.));
#1664=DIRECTION('',(0.,0.,-1.));
#1665=DIRECTION('center_axis',(0.,0.,-1.));
#1666=DIRECTION('ref_axis',(1.,0.,0.));
#1667=DIRECTION('',(-1.,-5.28969698967948E-14,0.));
#1668=DIRECTION('center_axis',(0.,0.,-1.));
#1669=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1670=DIRECTION('',(-0.500000000000047,-0.866025403784412,0.));
#1671=DIRECTION('center_axis',(-0.866025403784412,0.500000000000047,0.));
#1672=DIRECTION('ref_axis',(0.500000000000047,0.866025403784412,0.));
#1673=DIRECTION('center_axis',(0.866025403784465,-0.499999999999955,0.));
#1674=DIRECTION('ref_axis',(-0.499999999999955,-0.866025403784465,0.));
#1675=DIRECTION('center_axis',(0.,0.,-1.));
#1676=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1677=DIRECTION('',(0.,0.,-1.));
#1678=DIRECTION('center_axis',(0.,0.,-1.));
#1679=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1680=DIRECTION('',(-0.499999999999954,0.866025403784465,0.));
#1681=DIRECTION('center_axis',(0.866025403784465,0.499999999999954,0.));
#1682=DIRECTION('ref_axis',(0.499999999999954,-0.866025403784465,0.));
#1683=DIRECTION('center_axis',(-0.866025403784412,-0.500000000000046,0.));
#1684=DIRECTION('ref_axis',(-0.500000000000046,0.866025403784412,0.));
#1685=DIRECTION('center_axis',(0.,0.,-1.));
#1686=DIRECTION('ref_axis',(1.,0.,0.));
#1687=DIRECTION('',(0.,0.,-1.));
#1688=DIRECTION('center_axis',(0.,0.,-1.));
#1689=DIRECTION('ref_axis',(1.,0.,0.));
#1690=DIRECTION('',(1.,-5.3192483695101E-14,0.));
#1691=DIRECTION('center_axis',(-5.31924836951009E-14,-1.,0.));
#1692=DIRECTION('ref_axis',(-1.,5.3192483695101E-14,0.));
#1693=DIRECTION('center_axis',(-5.28969698967948E-14,1.,0.));
#1694=DIRECTION('ref_axis',(1.,5.28969698967948E-14,0.));
#1695=DIRECTION('center_axis',(0.,0.,-1.));
#1696=DIRECTION('ref_axis',(-1.,0.,0.));
#1697=DIRECTION('center_axis',(0.,0.,1.));
#1698=DIRECTION('ref_axis',(1.,0.,0.));
#1699=DIRECTION('center_axis',(0.,0.,1.));
#1700=DIRECTION('ref_axis',(1.,0.,0.));
#1701=DIRECTION('center_axis',(0.,0.,1.));
#1702=DIRECTION('ref_axis',(1.,0.,0.));
#1703=DIRECTION('center_axis',(0.,0.,1.));
#1704=DIRECTION('ref_axis',(1.,0.,0.));
#1705=DIRECTION('center_axis',(0.,0.,1.));
#1706=DIRECTION('ref_axis',(1.,0.,0.));
#1707=DIRECTION('',(0.,0.,-1.));
#1708=DIRECTION('center_axis',(0.,0.,1.));
#1709=DIRECTION('ref_axis',(1.,0.,0.));
#1710=DIRECTION('center_axis',(0.,0.,1.));
#1711=DIRECTION('ref_axis',(1.,0.,0.));
#1712=DIRECTION('center_axis',(0.,0.,-1.));
#1713=DIRECTION('ref_axis',(-1.,0.,0.));
#1714=DIRECTION('center_axis',(0.,0.,1.));
#1715=DIRECTION('ref_axis',(1.,0.,0.));
#1716=DIRECTION('',(0.,0.,-1.));
#1717=DIRECTION('center_axis',(0.,0.,-1.));
#1718=DIRECTION('ref_axis',(1.,0.,0.));
#1719=DIRECTION('center_axis',(0.,0.,-1.));
#1720=DIRECTION('ref_axis',(1.,0.,0.));
#1721=DIRECTION('',(0.,0.,1.));
#1722=DIRECTION('center_axis',(0.,0.,-1.));
#1723=DIRECTION('ref_axis',(1.,0.,0.));
#1724=DIRECTION('center_axis',(0.,0.,-1.));
#1725=DIRECTION('ref_axis',(1.,0.,0.));
#1726=DIRECTION('center_axis',(0.,0.,-1.));
#1727=DIRECTION('ref_axis',(1.,0.,0.));
#1728=DIRECTION('center_axis',(-0.433937502508841,0.889314906078706,0.144281813623933));
#1729=DIRECTION('ref_axis',(0.835441100398808,0.33724829381454,0.43393750250884));
#1730=DIRECTION('center_axis',(-0.433937502508842,0.889314906078708,0.144281813623922));
#1731=DIRECTION('ref_axis',(0.835441100398807,0.337248293814544,0.433937502508841));
#1732=DIRECTION('',(0.433937502508841,-0.889314906078706,-0.144281813623933));
#1733=DIRECTION('center_axis',(-0.433937502508841,0.889314906078708,0.144281813623922));
#1734=DIRECTION('ref_axis',(0.835441100398807,0.337248293814544,0.433937502508841));
#1735=DIRECTION('center_axis',(-0.433937502508841,0.889314906078708,0.144281813623922));
#1736=DIRECTION('ref_axis',(0.835441100398807,0.337248293814544,0.433937502508841));
#1737=DIRECTION('center_axis',(-0.898718523180694,-0.438525958287434,3.44378012192187E-16));
#1738=DIRECTION('ref_axis',(0.,0.,1.));
#1739=DIRECTION('center_axis',(0.898718523180694,0.438525958287434,-3.44378012192187E-16));
#1740=DIRECTION('ref_axis',(3.09498898533266E-16,1.51018697809701E-16,1.));
#1741=DIRECTION('center_axis',(0.429325813916858,-0.879863675467542,0.20376274953331));
#1742=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,-0.429325813916858));
#1743=DIRECTION('center_axis',(0.429325813916858,-0.879863675467542,0.20376274953331));
#1744=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,-0.429325813916858));
#1745=DIRECTION('center_axis',(0.429325813916859,-0.879863675467545,0.2037627495333));
#1746=DIRECTION('ref_axis',(0.846879582736021,0.313806178794315,-0.429325813916859));
#1747=DIRECTION('',(-0.429325813916859,0.879863675467544,-0.2037627495333));
#1748=DIRECTION('center_axis',(0.429325813916858,-0.879863675467542,0.20376274953331));
#1749=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,-0.429325813916858));
#1750=DIRECTION('center_axis',(0.429325813916858,-0.879863675467542,0.20376274953331));
#1751=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,-0.429325813916858));
#1752=DIRECTION('center_axis',(0.898718523180694,0.438525958287434,0.));
#1753=DIRECTION('ref_axis',(0.,0.,-1.));
#1754=DIRECTION('center_axis',(-0.898718523180694,-0.438525958287434,0.));
#1755=DIRECTION('ref_axis',(0.,0.,-1.));
#1756=DIRECTION('center_axis',(-0.429325813916858,0.879863675467543,0.20376274953331));
#1757=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,0.429325813916858));
#1758=DIRECTION('center_axis',(-0.429325813916858,0.879863675467543,0.20376274953331));
#1759=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,0.429325813916858));
#1760=DIRECTION('center_axis',(-0.429325813916858,0.879863675467543,0.20376274953331));
#1761=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,0.429325813916858));
#1762=DIRECTION('',(0.429325813916858,-0.879863675467543,-0.20376274953331));
#1763=DIRECTION('center_axis',(-0.429325813916858,0.879863675467543,0.20376274953331));
#1764=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,0.429325813916858));
#1765=DIRECTION('center_axis',(-0.429325813916858,0.879863675467543,0.20376274953331));
#1766=DIRECTION('ref_axis',(0.846879582736023,0.313806178794311,0.429325813916858));
#1767=DIRECTION('center_axis',(-0.898718523180694,-0.438525958287434,0.));
#1768=DIRECTION('ref_axis',(0.,0.,1.));
#1769=DIRECTION('center_axis',(0.898718523180694,0.438525958287434,0.));
#1770=DIRECTION('ref_axis',(0.,0.,1.));
#1771=DIRECTION('center_axis',(0.,0.,1.));
#1772=DIRECTION('ref_axis',(1.,0.,0.));
#1773=DIRECTION('center_axis',(0.,0.,1.));
#1774=DIRECTION('ref_axis',(1.,0.,0.));
#1775=DIRECTION('center_axis',(0.,0.,1.));
#1776=DIRECTION('ref_axis',(1.,0.,0.));
#1777=DIRECTION('',(0.,0.,-1.));
#1778=DIRECTION('center_axis',(0.,0.,1.));
#1779=DIRECTION('ref_axis',(1.,0.,0.));
#1780=DIRECTION('center_axis',(-0.433937502508842,0.889314906078708,0.144281813623922));
#1781=DIRECTION('ref_axis',(0.835441100398806,0.337248293814544,0.433937502508842));
#1782=DIRECTION('center_axis',(0.,0.,1.));
#1783=DIRECTION('ref_axis',(1.,0.,0.));
#1784=DIRECTION('center_axis',(-0.553200549373912,-0.820458353866783,0.144281813623933));
#1785=DIRECTION('ref_axis',(-0.709786140025754,0.554889069403724,0.43393750250884));
#1786=DIRECTION('center_axis',(-0.553200549373913,-0.820458353866784,0.144281813623922));
#1787=DIRECTION('ref_axis',(-0.709786140025756,0.554889069403721,0.433937502508841));
#1788=DIRECTION('',(0.553200549373911,0.820458353866783,-0.144281813623933));
#1789=DIRECTION('center_axis',(-0.553200549373913,-0.820458353866784,0.144281813623922));
#1790=DIRECTION('ref_axis',(-0.709786140025756,0.55488906940372,0.433937502508841));
#1791=DIRECTION('center_axis',(-0.553200549373913,-0.820458353866784,0.144281813623922));
#1792=DIRECTION('ref_axis',(-0.709786140025756,0.55488906940372,0.433937502508841));
#1793=DIRECTION('center_axis',(0.82913388168618,-0.559050092782398,3.44378012192187E-16));
#1794=DIRECTION('ref_axis',(0.,0.,1.));
#1795=DIRECTION('center_axis',(-0.82913388168618,0.559050092782398,-3.44378012192187E-16));
#1796=DIRECTION('ref_axis',(-2.85535478016279E-16,1.9252455966826E-16,1.));
#1797=DIRECTION('center_axis',(0.54732138786361,0.811738899086201,0.20376274953331));
#1798=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,-0.429325813916858));
#1799=DIRECTION('center_axis',(0.54732138786361,0.811738899086201,0.20376274953331));
#1800=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,-0.429325813916858));
#1801=DIRECTION('center_axis',(0.547321387863611,0.811738899086203,0.2037627495333));
#1802=DIRECTION('ref_axis',(-0.695203914068409,0.576516143198602,-0.429325813916859));
#1803=DIRECTION('',(-0.547321387863611,-0.811738899086203,-0.2037627495333));
#1804=DIRECTION('center_axis',(0.54732138786361,0.811738899086201,0.20376274953331));
#1805=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,-0.429325813916858));
#1806=DIRECTION('center_axis',(0.54732138786361,0.811738899086201,0.20376274953331));
#1807=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,-0.429325813916858));
#1808=DIRECTION('center_axis',(-0.82913388168618,0.559050092782398,0.));
#1809=DIRECTION('ref_axis',(0.,0.,-1.));
#1810=DIRECTION('center_axis',(0.82913388168618,-0.559050092782398,0.));
#1811=DIRECTION('ref_axis',(0.,0.,-1.));
#1812=DIRECTION('center_axis',(-0.54732138786361,-0.811738899086201,0.20376274953331));
#1813=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,0.429325813916858));
#1814=DIRECTION('center_axis',(-0.54732138786361,-0.811738899086201,0.20376274953331));
#1815=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,0.429325813916858));
#1816=DIRECTION('center_axis',(-0.54732138786361,-0.811738899086201,0.20376274953331));
#1817=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,0.429325813916858));
#1818=DIRECTION('',(0.54732138786361,0.811738899086201,-0.20376274953331));
#1819=DIRECTION('center_axis',(-0.54732138786361,-0.811738899086201,0.20376274953331));
#1820=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,0.429325813916858));
#1821=DIRECTION('center_axis',(-0.54732138786361,-0.811738899086201,0.20376274953331));
#1822=DIRECTION('ref_axis',(-0.695203914068406,0.576516143198606,0.429325813916858));
#1823=DIRECTION('center_axis',(0.82913388168618,-0.559050092782398,0.));
#1824=DIRECTION('ref_axis',(0.,0.,1.));
#1825=DIRECTION('center_axis',(-0.82913388168618,0.559050092782398,0.));
#1826=DIRECTION('ref_axis',(0.,0.,1.));
#1827=DIRECTION('center_axis',(0.,0.,1.));
#1828=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1829=DIRECTION('center_axis',(0.,0.,1.));
#1830=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1831=DIRECTION('center_axis',(0.,0.,1.));
#1832=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1833=DIRECTION('',(0.,0.,-1.));
#1834=DIRECTION('center_axis',(0.,0.,1.));
#1835=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1836=DIRECTION('center_axis',(-0.553200549373912,-0.820458353866784,0.144281813623922));
#1837=DIRECTION('ref_axis',(-0.709786140025756,0.55488906940372,0.433937502508842));
#1838=DIRECTION('center_axis',(0.,0.,1.));
#1839=DIRECTION('ref_axis',(-0.5,0.866025403784439,0.));
#1840=DIRECTION('center_axis',(0.987138051882752,-0.0688565522119238,0.144281813623933));
#1841=DIRECTION('ref_axis',(-0.125654960373055,-0.892137363218264,0.43393750250884));
#1842=DIRECTION('center_axis',(0.987138051882754,-0.0688565522119241,0.144281813623922));
#1843=DIRECTION('ref_axis',(-0.12565496037305,-0.892137363218264,0.433937502508841));
#1844=DIRECTION('',(-0.987138051882752,0.0688565522119238,-0.144281813623933));
#1845=DIRECTION('center_axis',(0.987138051882754,-0.0688565522119241,0.144281813623922));
#1846=DIRECTION('ref_axis',(-0.12565496037305,-0.892137363218264,0.433937502508841));
#1847=DIRECTION('center_axis',(0.987138051882754,-0.0688565522119241,0.144281813623922));
#1848=DIRECTION('ref_axis',(-0.12565496037305,-0.892137363218264,0.433937502508841));
#1849=DIRECTION('center_axis',(0.0695846414945146,0.997576051069832,3.44378012192187E-16));
#1850=DIRECTION('ref_axis',(0.,0.,1.));
#1851=DIRECTION('center_axis',(-0.0695846414945146,-0.997576051069832,-3.44378012192187E-16));
#1852=DIRECTION('ref_axis',(-2.3963420516987E-17,-3.43543257477961E-16,
1.));
#1853=DIRECTION('center_axis',(-0.976647201780468,0.0681247763813418,0.20376274953331));
#1854=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,-0.429325813916858));
#1855=DIRECTION('center_axis',(-0.976647201780468,0.0681247763813418,0.20376274953331));
#1856=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,-0.429325813916858));
#1857=DIRECTION('center_axis',(-0.97664720178047,0.0681247763813421,0.2037627495333));
#1858=DIRECTION('ref_axis',(-0.151675668667613,-0.890322321992917,-0.429325813916859));
#1859=DIRECTION('',(0.97664720178047,-0.0681247763813421,-0.2037627495333));
#1860=DIRECTION('center_axis',(-0.976647201780468,0.0681247763813417,0.20376274953331));
#1861=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,-0.429325813916858));
#1862=DIRECTION('center_axis',(-0.976647201780468,0.0681247763813417,0.20376274953331));
#1863=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,-0.429325813916858));
#1864=DIRECTION('center_axis',(-0.0695846414945143,-0.997576051069832,0.));
#1865=DIRECTION('ref_axis',(0.,0.,-1.));
#1866=DIRECTION('center_axis',(0.0695846414945143,0.997576051069832,0.));
#1867=DIRECTION('ref_axis',(0.,0.,-1.));
#1868=DIRECTION('center_axis',(0.976647201780468,-0.068124776381342,0.20376274953331));
#1869=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,0.429325813916858));
#1870=DIRECTION('center_axis',(0.976647201780468,-0.068124776381342,0.20376274953331));
#1871=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,0.429325813916858));
#1872=DIRECTION('center_axis',(0.976647201780468,-0.0681247763813422,0.20376274953331));
#1873=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,0.429325813916858));
#1874=DIRECTION('',(-0.976647201780468,0.0681247763813422,-0.20376274953331));
#1875=DIRECTION('center_axis',(0.976647201780468,-0.0681247763813419,0.20376274953331));
#1876=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,0.429325813916858));
#1877=DIRECTION('center_axis',(0.976647201780468,-0.0681247763813419,0.20376274953331));
#1878=DIRECTION('ref_axis',(-0.151675668667617,-0.890322321992916,0.429325813916858));
#1879=DIRECTION('center_axis',(0.0695846414945144,0.997576051069832,0.));
#1880=DIRECTION('ref_axis',(0.,0.,1.));
#1881=DIRECTION('center_axis',(-0.0695846414945144,-0.997576051069832,0.));
#1882=DIRECTION('ref_axis',(0.,0.,1.));
#1883=DIRECTION('center_axis',(0.,0.,1.));
#1884=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1885=DIRECTION('center_axis',(0.,0.,1.));
#1886=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1887=DIRECTION('center_axis',(0.,0.,1.));
#1888=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1889=DIRECTION('',(0.,0.,-1.));
#1890=DIRECTION('center_axis',(0.,0.,1.));
#1891=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1892=DIRECTION('center_axis',(0.987138051882754,-0.0688565522119239,0.144281813623922));
#1893=DIRECTION('ref_axis',(-0.12565496037305,-0.892137363218264,0.433937502508842));
#1894=DIRECTION('center_axis',(0.,0.,1.));
#1895=DIRECTION('ref_axis',(-0.5,-0.866025403784438,0.));
#1896=CARTESIAN_POINT('',(0.,0.,0.));
#1897=CARTESIAN_POINT('Origin',(0.,0.,11.7));
#1898=CARTESIAN_POINT('',(13.3,-3.25756048573196E-15,12.7));
#1899=CARTESIAN_POINT('',(-13.3,-1.62878024286598E-15,12.7));
#1900=CARTESIAN_POINT('Origin',(0.,0.,12.7));
#1901=CARTESIAN_POINT('',(-14.3,-1.75124492278072E-15,11.7));
#1902=CARTESIAN_POINT('Origin',(-13.3,-1.62878024286598E-15,11.7));
#1903=CARTESIAN_POINT('',(14.3,0.,11.7));
#1904=CARTESIAN_POINT('Origin',(0.,0.,11.7));
#1905=CARTESIAN_POINT('Origin',(0.,0.,11.7));
#1906=CARTESIAN_POINT('Origin',(0.,0.,12.7));
#1907=CARTESIAN_POINT('Origin',(0.,0.,9.5));
#1908=CARTESIAN_POINT('',(-14.3,-1.75124492278072E-15,6.3));
#1909=CARTESIAN_POINT('',(-14.3,-1.75124492278072E-15,9.5));
#1910=CARTESIAN_POINT('',(-9.43646866610855,-10.7444431737318,6.3));
#1911=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1912=CARTESIAN_POINT('',(-9.43646866610855,-10.7444431737318,9.4));
#1913=CARTESIAN_POINT('',(-9.43646866610855,-10.7444431737318,9.5));
#1914=CARTESIAN_POINT('',(-6.56324704509696,-12.7048726174262,9.4));
#1915=CARTESIAN_POINT('Origin',(0.,0.,9.4));
#1916=CARTESIAN_POINT('',(-6.56324704509696,-12.7048726174262,6.3));
#1917=CARTESIAN_POINT('',(-6.56324704509696,-12.7048726174262,9.4));
#1918=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737317,6.3));
#1919=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1920=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737317,9.4));
#1921=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737318,9.5));
#1922=CARTESIAN_POINT('',(14.0231950710243,-2.79999999999997,6.3));
#1923=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1924=CARTESIAN_POINT('',(14.0231950710243,-2.79999999999997,9.4));
#1925=CARTESIAN_POINT('',(14.0231950710243,-2.79999999999997,9.5));
#1926=CARTESIAN_POINT('',(14.2843659610849,0.668497636345989,9.4));
#1927=CARTESIAN_POINT('Origin',(0.,0.,9.4));
#1928=CARTESIAN_POINT('',(14.2843659610849,0.668497636345988,6.3));
#1929=CARTESIAN_POINT('',(14.2843659610849,0.668497636345988,6.3));
#1930=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,6.3));
#1931=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1932=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,9.4));
#1933=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,9.5));
#1934=CARTESIAN_POINT('',(-4.58672640491575,13.5444431737318,6.3));
#1935=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1936=CARTESIAN_POINT('',(-4.58672640491575,13.5444431737318,9.4));
#1937=CARTESIAN_POINT('',(-4.58672640491575,13.5444431737318,9.5));
#1938=CARTESIAN_POINT('',(-7.72111891598791,12.0363749810802,9.4));
#1939=CARTESIAN_POINT('Origin',(0.,0.,9.4));
#1940=CARTESIAN_POINT('',(-7.72111891598791,12.0363749810802,6.3));
#1941=CARTESIAN_POINT('',(-7.72111891598791,12.0363749810802,9.4));
#1942=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,6.3));
#1943=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1944=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,9.4));
#1945=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,9.5));
#1946=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1947=CARTESIAN_POINT('Origin',(2.22999949938702,0.,12.7));
#1948=CARTESIAN_POINT('',(2.22999949938702,0.,12.7));
#1949=CARTESIAN_POINT('',(-2.2299993510874,-2.73096156740985E-16,12.7));
#1950=CARTESIAN_POINT('Origin',(0.,0.,12.7));
#1951=CARTESIAN_POINT('Origin',(0.,0.,12.7));
#1952=CARTESIAN_POINT('Origin',(-8.37591055522221,-12.929283036319,6.1));
#1953=CARTESIAN_POINT('',(-8.85034395623403,-12.545339097697,6.1));
#1954=CARTESIAN_POINT('Origin',(-8.35155593069912,-12.5801314184443,6.1));
#1955=CARTESIAN_POINT('',(-8.89905320528021,-13.2436423334462,6.1));
#1956=CARTESIAN_POINT('',(-8.87469858075713,-12.8944907155718,6.1));
#1957=CARTESIAN_POINT('Origin',(-8.40026517974529,-13.2784346541935,6.1));
#1958=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1959=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1960=CARTESIAN_POINT('',(-6.56324704509696,-12.7048726174262,4.));
#1961=CARTESIAN_POINT('',(-6.56324704509696,-12.7048726174262,6.3));
#1962=CARTESIAN_POINT('',(-9.43646866610855,-10.7444431737318,4.));
#1963=CARTESIAN_POINT('Origin',(0.,0.,4.));
#1964=CARTESIAN_POINT('',(-9.43646866610855,-10.7444431737318,6.3));
#1965=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,6.3));
#1966=CARTESIAN_POINT('',(-10.295659676778,-13.1462238353539,9.4));
#1967=CARTESIAN_POINT('',(-10.295659676778,-13.1462238353539,4.));
#1968=CARTESIAN_POINT('',(-10.295659676778,-13.1462238353539,6.3));
#1969=CARTESIAN_POINT('',(-5.07512886940356,-14.3903810567666,4.));
#1970=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,4.));
#1971=CARTESIAN_POINT('',(-5.07512886940356,-14.3903810567666,9.4));
#1972=CARTESIAN_POINT('',(-5.07512886940356,-14.3903810567666,6.3));
#1973=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,9.4));
#1974=CARTESIAN_POINT('Origin',(-7.00913228456036,13.7183928388082,6.1));
#1975=CARTESIAN_POINT('',(-6.43941037957878,13.9372922471773,6.1));
#1976=CARTESIAN_POINT('Origin',(-6.71893542596997,13.5227253063342,6.1));
#1977=CARTESIAN_POINT('',(-7.01980409675933,14.3286273121251,6.1));
#1978=CARTESIAN_POINT('',(-6.72960723816917,14.1329597796513,6.1));
#1979=CARTESIAN_POINT('Origin',(-7.29932914315053,13.914060371282,6.1));
#1980=CARTESIAN_POINT('Origin',(14.3,0.,6.3));
#1981=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1982=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1983=CARTESIAN_POINT('',(13.8,0.,6.3));
#1984=CARTESIAN_POINT('',(-13.8,-1.69001258282335E-15,6.3));
#1985=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1986=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#1987=CARTESIAN_POINT('Origin',(0.,0.,7.05));
#1988=CARTESIAN_POINT('',(13.8,0.,7.8));
#1989=CARTESIAN_POINT('',(-13.8,-1.69001258282335E-15,7.8));
#1990=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#1991=CARTESIAN_POINT('',(-13.8,-1.69001258282335E-15,7.05));
#1992=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#1993=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,6.3));
#1994=CARTESIAN_POINT('',(-6.23713396686397,15.4894147464857,9.4));
#1995=CARTESIAN_POINT('',(-6.23713396686397,15.4894147464857,4.));
#1996=CARTESIAN_POINT('',(-6.23713396686397,15.4894147464857,6.3));
#1997=CARTESIAN_POINT('',(-9.92487113059644,11.5903810567666,4.));
#1998=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,4.));
#1999=CARTESIAN_POINT('',(-9.92487113059644,11.5903810567666,9.4));
#2000=CARTESIAN_POINT('',(-9.92487113059644,11.5903810567666,6.3));
#2001=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,9.4));
#2002=CARTESIAN_POINT('Origin',(15.3850428397826,-0.789109802489146,6.1));
#2003=CARTESIAN_POINT('',(15.2897543358128,-1.39195314948021,6.1));
#2004=CARTESIAN_POINT('Origin',(15.0704913566691,-0.942593887889868,6.1));
#2005=CARTESIAN_POINT('',(15.9188573020395,-1.08498497867889,6.1));
#2006=CARTESIAN_POINT('',(15.6043058189263,-1.23846906407949,6.1));
#2007=CARTESIAN_POINT('Origin',(15.6995943228958,-0.635625717088541,6.1));
#2008=CARTESIAN_POINT('Origin',(-10.2688583184725,-12.4463924427074,9.4));
#2009=CARTESIAN_POINT('',(-10.2469504277318,-12.4479205996047,4.));
#2010=CARTESIAN_POINT('',(-5.97405951331474,-12.7459706401064,4.));
#2011=CARTESIAN_POINT('',(-10.2469504277318,-12.4479205996047,9.4));
#2012=CARTESIAN_POINT('',(-5.97405951331474,-12.7459706401064,9.4));
#2013=CARTESIAN_POINT('',(-10.2469504277318,-12.4479205996047,6.3));
#2014=CARTESIAN_POINT('Origin',(-4.58672640491576,-13.5444431737317,9.4));
#2015=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737317,4.));
#2016=CARTESIAN_POINT('',(-3.15734818105948,-13.6441476234932,4.));
#2017=CARTESIAN_POINT('',(-3.15734818105948,-13.6441476234932,9.4));
#2018=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737318,9.5));
#2019=CARTESIAN_POINT('',(-4.58672640491576,-13.5444431737317,6.3));
#2020=CARTESIAN_POINT('Origin',(-0.875000000000004,-1.51554445662277,4.));
#2021=CARTESIAN_POINT('',(-5.07512886940356,-14.3903810567666,4.));
#2022=CARTESIAN_POINT('Origin',(-0.875000000000004,-1.51554445662277,4.));
#2023=CARTESIAN_POINT('',(-9.92487113059645,-11.5903810567666,4.));
#2024=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,4.));
#2025=CARTESIAN_POINT('',(-9.92487113059645,-11.5903810567666,4.));
#2026=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,6.3));
#2027=CARTESIAN_POINT('',(-9.92487113059645,-11.5903810567666,9.4));
#2028=CARTESIAN_POINT('Origin',(-7.50000000000001,-12.9903810567666,9.4));
#2029=CARTESIAN_POINT('',(-9.92487113059645,-11.5903810567666,6.3));
#2030=CARTESIAN_POINT('Origin',(-0.875000000000004,-1.51554445662277,9.4));
#2031=CARTESIAN_POINT('',(-5.07512886940356,-14.3903810567666,9.4));
#2032=CARTESIAN_POINT('Origin',(-5.644462881619,15.116288393014,9.4));
#2033=CARTESIAN_POINT('',(-7.72111891598791,12.0363749810802,4.));
#2034=CARTESIAN_POINT('',(-5.65674024968342,15.0980796815379,4.));
#2035=CARTESIAN_POINT('',(-8.05130461356539,11.5466726223039,4.));
#2036=CARTESIAN_POINT('',(-7.72111891598791,12.0363749810802,6.3));
#2037=CARTESIAN_POINT('',(-5.65674024968342,15.0980796815379,9.4));
#2038=CARTESIAN_POINT('',(-8.05130461356539,11.5466726223039,9.4));
#2039=CARTESIAN_POINT('',(-5.65674024968342,15.0980796815379,6.3));
#2040=CARTESIAN_POINT('Origin',(-9.43646866610855,10.7444431737318,9.4));
#2041=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,4.));
#2042=CARTESIAN_POINT('',(-10.2375043644004,9.55641754513669,4.));
#2043=CARTESIAN_POINT('',(-10.2375043644004,9.55641754513669,9.4));
#2044=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,9.5));
#2045=CARTESIAN_POINT('',(-9.43646866610855,10.7444431737318,6.3));
#2046=CARTESIAN_POINT('Origin',(-0.875000000000003,1.51554445662277,4.));
#2047=CARTESIAN_POINT('',(-9.92487113059644,11.5903810567666,4.));
#2048=CARTESIAN_POINT('Origin',(-0.875000000000003,1.51554445662277,4.));
#2049=CARTESIAN_POINT('',(-5.07512886940355,14.3903810567666,4.));
#2050=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,4.));
#2051=CARTESIAN_POINT('',(-4.58672640491575,13.5444431737318,4.));
#2052=CARTESIAN_POINT('',(-5.07512886940355,14.3903810567666,4.));
#2053=CARTESIAN_POINT('Origin',(0.,0.,4.));
#2054=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,6.3));
#2055=CARTESIAN_POINT('',(-5.07512886940355,14.3903810567666,9.4));
#2056=CARTESIAN_POINT('Origin',(-7.5,12.9903810567666,9.4));
#2057=CARTESIAN_POINT('',(-5.07512886940355,14.3903810567666,6.3));
#2058=CARTESIAN_POINT('Origin',(-0.875000000000003,1.51554445662277,9.4));
#2059=CARTESIAN_POINT('',(-9.92487113059644,11.5903810567666,9.4));
#2060=CARTESIAN_POINT('Origin',(15.9133212000915,-2.66989595030662,9.4));
#2061=CARTESIAN_POINT('',(14.2843659610849,0.668497636345989,4.));
#2062=CARTESIAN_POINT('',(15.9036906774152,-2.65015908193318,4.));
#2063=CARTESIAN_POINT('',(14.0253641268801,1.19929801780255,4.));
#2064=CARTESIAN_POINT('',(14.2843659610849,0.668497636345988,6.3));
#2065=CARTESIAN_POINT('',(15.9036906774152,-2.65015908193318,9.4));
#2066=CARTESIAN_POINT('',(14.0253641268801,1.19929801780255,9.4));
#2067=CARTESIAN_POINT('',(15.9036906774152,-2.65015908193318,6.3));
#2068=CARTESIAN_POINT('Origin',(14.0231950710243,2.79999999999997,9.4));
#2069=CARTESIAN_POINT('',(16.5327936436419,-2.34319091113186,4.));
#2070=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,4.));
#2071=CARTESIAN_POINT('',(13.3948525454599,4.0877300783565,4.));
#2072=CARTESIAN_POINT('',(16.5327936436419,-2.34319091113186,9.4));
#2073=CARTESIAN_POINT('',(16.5327936436419,-2.34319091113186,6.3));
#2074=CARTESIAN_POINT('',(13.3948525454599,4.0877300783565,9.4));
#2075=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,9.5));
#2076=CARTESIAN_POINT('',(14.0231950710243,2.79999999999997,6.3));
#2077=CARTESIAN_POINT('Origin',(1.75000000000001,0.,4.));
#2078=CARTESIAN_POINT('',(15.,2.80000000000002,4.));
#2079=CARTESIAN_POINT('',(15.,2.80000000000002,4.));
#2080=CARTESIAN_POINT('Origin',(15.,0.,4.));
#2081=CARTESIAN_POINT('Origin',(1.75000000000001,0.,4.));
#2082=CARTESIAN_POINT('',(15.,-2.80000000000002,4.));
#2083=CARTESIAN_POINT('Origin',(15.,0.,4.));
#2084=CARTESIAN_POINT('',(14.0231950710243,-2.79999999999997,4.));
#2085=CARTESIAN_POINT('',(15.,-2.80000000000002,4.));
#2086=CARTESIAN_POINT('Origin',(0.,0.,4.));
#2087=CARTESIAN_POINT('Origin',(15.,0.,6.3));
#2088=CARTESIAN_POINT('',(15.,2.80000000000002,9.4));
#2089=CARTESIAN_POINT('',(15.,2.80000000000002,6.3));
#2090=CARTESIAN_POINT('Origin',(15.,0.,9.4));
#2091=CARTESIAN_POINT('Origin',(15.,0.,6.3));
#2092=CARTESIAN_POINT('',(15.,-2.80000000000002,9.4));
#2093=CARTESIAN_POINT('Origin',(15.,0.,9.4));
#2094=CARTESIAN_POINT('',(15.,-2.80000000000002,6.3));
#2095=CARTESIAN_POINT('Origin',(1.75000000000001,0.,9.4));
#2096=CARTESIAN_POINT('',(15.,2.80000000000002,9.4));
#2097=CARTESIAN_POINT('Origin',(-0.875000000000004,-1.51554445662277,9.4));
#2098=CARTESIAN_POINT('',(-9.92487113059645,-11.5903810567666,9.4));
#2099=CARTESIAN_POINT('Origin',(-9.92487113059645,-11.5903810567666,6.3));
#2100=CARTESIAN_POINT('Origin',(-4.58672640491576,-13.5444431737317,6.3));
#2101=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#2102=CARTESIAN_POINT('',(-4.58672640491575,13.5444431737318,6.3));
#2103=CARTESIAN_POINT('Origin',(-0.875000000000003,1.51554445662277,9.4));
#2104=CARTESIAN_POINT('',(-5.07512886940355,14.3903810567666,9.4));
#2105=CARTESIAN_POINT('Origin',(-5.07512886940355,14.3903810567666,6.3));
#2106=CARTESIAN_POINT('Origin',(-9.43646866610855,10.7444431737318,6.3));
#2107=CARTESIAN_POINT('Origin',(0.,0.,6.3));
#2108=CARTESIAN_POINT('',(14.0231950710243,-2.79999999999997,6.3));
#2109=CARTESIAN_POINT('Origin',(1.75000000000001,0.,9.4));
#2110=CARTESIAN_POINT('',(15.,-2.80000000000002,9.4));
#2111=CARTESIAN_POINT('Origin',(15.,-2.80000000000002,6.3));
#2112=CARTESIAN_POINT('Origin',(14.0231950710243,2.79999999999997,6.3));
#2113=CARTESIAN_POINT('Origin',(12.8,0.,10.6999999999999));
#2114=CARTESIAN_POINT('',(12.8,0.,10.6999999999999));
#2115=CARTESIAN_POINT('',(-12.8,-1.56754790290861E-15,10.6999999999999));
#2116=CARTESIAN_POINT('Origin',(0.,0.,10.6999999999999));
#2117=CARTESIAN_POINT('Origin',(0.,0.,10.6999999999999));
#2118=CARTESIAN_POINT('',(2.22999920278778,0.,10.7));
#2119=CARTESIAN_POINT('',(-2.2299993510874,-2.73096156740985E-16,10.7));
#2120=CARTESIAN_POINT('Origin',(0.,0.,10.7));
#2121=CARTESIAN_POINT('Origin',(0.,0.,10.7));
#2122=CARTESIAN_POINT('Origin',(0.,0.,9.24999999999996));
#2123=CARTESIAN_POINT('',(-12.8,-1.56754790290861E-15,7.8));
#2124=CARTESIAN_POINT('',(-12.8,-1.56754790290861E-15,9.24999999999996));
#2125=CARTESIAN_POINT('',(12.8,0.,7.8));
#2126=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#2127=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#2128=CARTESIAN_POINT('Origin',(13.8,0.,7.8));
#2129=CARTESIAN_POINT('Origin',(0.,0.,11.7));
#2130=CARTESIAN_POINT('',(-2.2299993510874,-2.73096156740985E-16,11.7));
#2131=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#2132=CARTESIAN_POINT('',(-13.8,1.69001258282335E-15,7.3));
#2133=CARTESIAN_POINT('Origin',(0.,0.,7.3));
#2134=CARTESIAN_POINT('',(-13.8,1.69001258282335E-15,7.8));
#2135=CARTESIAN_POINT('',(-13.8,1.69001258282335E-15,7.8));
#2136=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#2137=CARTESIAN_POINT('Origin',(0.,0.,7.3));
#2138=CARTESIAN_POINT('Origin',(0.,0.,7.8));
#2139=CARTESIAN_POINT('Origin',(15.4356598962489,-0.892844793258674,6.89162931052652));
#2140=CARTESIAN_POINT('',(13.956824560934,1.52306954796931,7.16981874924732));
#2141=CARTESIAN_POINT('Origin',(14.2074568910537,1.62424403611368,7.29999999999998));
#2142=CARTESIAN_POINT('',(15.1850275661292,-0.994019281403037,6.76144805977387));
#2143=CARTESIAN_POINT('',(15.1850275661292,-0.994019281403036,6.76144805977387));
#2144=CARTESIAN_POINT('',(15.416678500074,-0.853944171720096,6.59476831907907));
#2145=CARTESIAN_POINT('Origin',(15.4356598962489,-0.892844793258674,6.89162931052652));
#2146=CARTESIAN_POINT('Origin',(15.4356598962489,-0.892844793258674,6.89162931052652));
#2147=CARTESIAN_POINT('Origin',(15.3850428397826,-0.789109802489144,6.09999999999999));
#2148=CARTESIAN_POINT('',(15.4297204672838,-0.880672481159059,5.61048985150903));
#2149=CARTESIAN_POINT('Origin',(15.3850428397826,-0.789109802489144,6.09999999999999));
#2150=CARTESIAN_POINT('',(15.2024631689637,-1.02975194199929,5.4455815065895));
#2151=CARTESIAN_POINT('Origin',(15.4565270437845,-0.935610088361003,5.31678376241444));
#2152=CARTESIAN_POINT('Origin',(15.4565270437845,-0.935610088361003,5.31678376241444));
#2153=CARTESIAN_POINT('Origin',(12.7180149535605,4.67671797324357,4.0170558284163));
#2154=CARTESIAN_POINT('',(12.4639510787397,4.58257611960529,4.14585357259136));
#2155=CARTESIAN_POINT('',(12.4639510787397,4.58257611960528,4.14585357259136));
#2156=CARTESIAN_POINT('',(12.7448215300612,4.62178036604163,3.72334973932171));
#2157=CARTESIAN_POINT('Origin',(12.7180149535605,4.67671797324357,4.0170558284163));
#2158=CARTESIAN_POINT('Origin',(12.7180149535605,4.67671797324357,4.0170558284163));
#2159=CARTESIAN_POINT('Origin',(12.8073702085628,4.49359261590378,3.03803553143435));
#2160=CARTESIAN_POINT('',(12.7448215300612,4.62178036604165,2.35272132354699));
#2161=CARTESIAN_POINT('Origin',(12.8073702085628,4.49359261590378,3.03803553143435));
#2162=CARTESIAN_POINT('',(12.4639510787396,4.5825761196053,1.93021749027735));
#2163=CARTESIAN_POINT('Origin',(12.7180149535604,4.6767179732436,2.05901523445241));
#2164=CARTESIAN_POINT('Origin',(12.7180149535604,4.6767179732436,2.05901523445241));
#2165=CARTESIAN_POINT('Origin',(14.5809951560579,0.858711799009366,1.17482435637834));
#2166=CARTESIAN_POINT('',(14.3269312812371,0.764569945371072,1.04602661220328));
#2167=CARTESIAN_POINT('',(14.3269312812371,0.764569945371072,1.04602661220329));
#2168=CARTESIAN_POINT('',(14.5541885795572,0.913649406211309,0.881118267283758));
#2169=CARTESIAN_POINT('Origin',(14.5809951560579,0.858711799009366,1.17482435637834));
#2170=CARTESIAN_POINT('Origin',(14.5809951560579,0.858711799009366,1.17482435637834));
#2171=CARTESIAN_POINT('Origin',(14.4737688500551,1.07846222781714,0.));
#2172=CARTESIAN_POINT('',(14.8684422125138,0.269615556954516,0.));
#2173=CARTESIAN_POINT('Origin',(14.4737688500551,1.07846222781714,0.));
#2174=CARTESIAN_POINT('',(14.7,3.08321077002738E-13,0.));
#2175=CARTESIAN_POINT('Origin',(15.,3.08069542098721E-13,0.));
#2176=CARTESIAN_POINT('Origin',(15.,3.08069542098721E-13,0.));
#2177=CARTESIAN_POINT('Origin',(15.,3.08355771472257E-13,-3.5));
#2178=CARTESIAN_POINT('',(14.7,3.08319032068283E-13,-3.5));
#2179=CARTESIAN_POINT('',(14.7,3.08319032068283E-13,-3.5));
#2180=CARTESIAN_POINT('Origin',(15.,3.08355771472257E-13,-3.5));
#2181=CARTESIAN_POINT('Origin',(14.2074568910537,1.62424403611366,7.30000000000001));
#2182=CARTESIAN_POINT('Origin',(15.,3.08355771472257E-13,-3.5));
#2183=CARTESIAN_POINT('Origin',(-6.94460367552576,13.8140959909575,6.89162931052652));
#2184=CARTESIAN_POINT('',(-8.29742920073893,11.3254298519468,7.16981874924732));
#2185=CARTESIAN_POINT('Origin',(-8.51036504274666,11.4918965727679,7.29999999999998));
#2186=CARTESIAN_POINT('',(-6.73166783351803,13.6476292701364,6.76144805977387));
#2187=CARTESIAN_POINT('',(-6.73166783351803,13.6476292701364,6.76144805977387));
#2188=CARTESIAN_POINT('',(-6.96880190391374,13.7782073089015,6.59476831907907));
#2189=CARTESIAN_POINT('Origin',(-6.94460367552576,13.8140959909575,6.89162931052652));
#2190=CARTESIAN_POINT('Origin',(-6.94460367552576,13.8140959909575,6.89162931052652));
#2191=CARTESIAN_POINT('Origin',(-7.00913228456037,13.7183928388082,6.09999999999999));
#2192=CARTESIAN_POINT('',(-6.95217549254427,13.80286613854,5.61048985150903));
#2193=CARTESIAN_POINT('Origin',(-7.00913228456037,13.7183928388082,6.09999999999999));
#2194=CARTESIAN_POINT('',(-6.70944024311409,13.6805952754195,5.4455815065895));
#2195=CARTESIAN_POINT('Origin',(-6.91800141733461,13.8535501183791,5.31678376241444));
#2196=CARTESIAN_POINT('Origin',(-6.91800141733461,13.8535501183791,5.31678376241444));
#2197=CARTESIAN_POINT('Origin',(-10.4091640479444,8.67576504887194,4.0170558284163));
#2198=CARTESIAN_POINT('',(-10.2006028737239,8.50281020591236,4.14585357259136));
#2199=CARTESIAN_POINT('',(-10.2006028737239,8.50281020591236,4.14585357259136));
#2200=CARTESIAN_POINT('',(-10.3749899727348,8.72644902871102,3.72334973932171));
#2201=CARTESIAN_POINT('Origin',(-10.4091640479444,8.67576504887194,4.0170558284163));
#2202=CARTESIAN_POINT('Origin',(-10.4091640479444,8.67576504887194,4.0170558284163));
#2203=CARTESIAN_POINT('Origin',(-10.2952504639123,8.84471164833553,3.03803553143435));
#2204=CARTESIAN_POINT('',(-10.3749899727348,8.726449028711,2.35272132354699));
#2205=CARTESIAN_POINT('Origin',(-10.2952504639123,8.84471164833553,3.03803553143435));
#2206=CARTESIAN_POINT('',(-10.2006028737239,8.50281020591234,1.93021749027735));
#2207=CARTESIAN_POINT('Origin',(-10.4091640479444,8.67576504887192,2.05901523445241));
#2208=CARTESIAN_POINT('Origin',(-10.4091640479444,8.67576504887192,2.05901523445241));
#2209=CARTESIAN_POINT('Origin',(-8.03416381050051,12.1981563180993,1.17482435637834));
#2210=CARTESIAN_POINT('',(-7.82560263627999,12.0252014751398,1.04602661220328));
#2211=CARTESIAN_POINT('',(-7.82560263627999,12.0252014751398,1.04602661220329));
#2212=CARTESIAN_POINT('',(-8.06833788571017,12.1474723382603,0.881118267283758));
#2213=CARTESIAN_POINT('Origin',(-8.03416381050051,12.1981563180993,1.17482435637834));
#2214=CARTESIAN_POINT('Origin',(-8.03416381050051,12.1981563180993,1.17482435637834));
#2215=CARTESIAN_POINT('Origin',(-8.17086011133914,11.995420398743,0.));
#2216=CARTESIAN_POINT('',(-7.66771502783498,12.7416408922606,0.));
#2217=CARTESIAN_POINT('Origin',(-8.17086011133914,11.995420398743,0.));
#2218=CARTESIAN_POINT('',(-7.35000000000027,12.7305734356311,0.));
#2219=CARTESIAN_POINT('Origin',(-7.50000000000026,12.9903810567664,0.));
#2220=CARTESIAN_POINT('Origin',(-7.50000000000026,12.9903810567664,0.));
#2221=CARTESIAN_POINT('Origin',(-7.50000000000027,12.9903810567664,-3.5));
#2222=CARTESIAN_POINT('',(-7.35000000000027,12.7305734356311,-3.5));
#2223=CARTESIAN_POINT('',(-7.35000000000027,12.7305734356311,-3.5));
#2224=CARTESIAN_POINT('Origin',(-7.50000000000027,12.9903810567664,-3.5));
#2225=CARTESIAN_POINT('Origin',(-8.51036504274665,11.491896572768,7.30000000000001));
#2226=CARTESIAN_POINT('Origin',(-7.50000000000027,12.9903810567664,-3.5));
#2227=CARTESIAN_POINT('Origin',(-8.49105622072312,-12.9212511976989,6.89162931052652));
#2228=CARTESIAN_POINT('',(-5.65939536019513,-12.8484993999161,7.16981874924732));
#2229=CARTESIAN_POINT('Origin',(-5.69709184830704,-13.1161406088816,7.29999999999998));
#2230=CARTESIAN_POINT('',(-8.4533597326112,-12.6536099887334,6.76144805977387));
#2231=CARTESIAN_POINT('',(-8.4533597326112,-12.6536099887334,6.76144805977387));
#2232=CARTESIAN_POINT('',(-8.44787659616028,-12.9242631371814,6.59476831907907));
#2233=CARTESIAN_POINT('Origin',(-8.49105622072312,-12.9212511976989,6.89162931052652));
#2234=CARTESIAN_POINT('Origin',(-8.49105622072312,-12.9212511976989,6.89162931052652));
#2235=CARTESIAN_POINT('Origin',(-8.37591055522221,-12.929283036319,6.09999999999999));
#2236=CARTESIAN_POINT('',(-8.47754497473951,-12.9221936573809,5.61048985150903));
#2237=CARTESIAN_POINT('Origin',(-8.37591055522221,-12.929283036319,6.09999999999999));
#2238=CARTESIAN_POINT('',(-8.49302292584959,-12.6508433334202,5.4455815065895));
#2239=CARTESIAN_POINT('Origin',(-8.53852562644988,-12.917940030018,5.31678376241444));
#2240=CARTESIAN_POINT('Origin',(-8.53852562644988,-12.917940030018,5.31678376241444));
#2241=CARTESIAN_POINT('Origin',(-2.30885090561603,-13.3524830221155,4.0170558284163));
#2242=CARTESIAN_POINT('',(-2.26334820501574,-13.0853863255176,4.14585357259136));
#2243=CARTESIAN_POINT('',(-2.26334820501574,-13.0853863255176,4.14585357259136));
#2244=CARTESIAN_POINT('',(-2.3698315573264,-13.3482293947526,3.72334973932171));
#2245=CARTESIAN_POINT('Origin',(-2.30885090561603,-13.3524830221155,4.0170558284163));
#2246=CARTESIAN_POINT('Origin',(-2.30885090561603,-13.3524830221155,4.0170558284163));
#2247=CARTESIAN_POINT('Origin',(-2.51211974465058,-13.3383042642393,3.03803553143435));
#2248=CARTESIAN_POINT('',(-2.36983155732638,-13.3482293947526,2.35272132354699));
#2249=CARTESIAN_POINT('Origin',(-2.51211974465058,-13.3383042642393,3.03803553143435));
#2250=CARTESIAN_POINT('',(-2.26334820501572,-13.0853863255176,1.93021749027735));
#2251=CARTESIAN_POINT('Origin',(-2.308850905616,-13.3524830221155,2.05901523445241));
#2252=CARTESIAN_POINT('Origin',(-2.308850905616,-13.3524830221155,2.05901523445241));
#2253=CARTESIAN_POINT('Origin',(-6.54683134555743,-13.0568681171087,1.17482435637834));
#2254=CARTESIAN_POINT('',(-6.50132864495714,-12.7897714205108,1.04602661220328));
#2255=CARTESIAN_POINT('',(-6.50132864495714,-12.7897714205108,1.04602661220329));
#2256=CARTESIAN_POINT('',(-6.48585069384706,-13.0611217444716,0.881118267283758));
#2257=CARTESIAN_POINT('Origin',(-6.54683134555743,-13.0568681171087,1.17482435637834));
#2258=CARTESIAN_POINT('Origin',(-6.54683134555743,-13.0568681171087,1.17482435637834));
#2259=CARTESIAN_POINT('Origin',(-6.30290873871594,-13.0738826265601,0.));
#2260=CARTESIAN_POINT('',(-7.20072718467879,-13.0112564492151,0.));
#2261=CARTESIAN_POINT('Origin',(-6.30290873871594,-13.0738826265601,0.));
#2262=CARTESIAN_POINT('',(-7.34999999999974,-12.7305734356314,0.));
#2263=CARTESIAN_POINT('Origin',(-7.49999999999974,-12.9903810567667,0.));
#2264=CARTESIAN_POINT('Origin',(-7.49999999999974,-12.9903810567667,0.));
#2265=CARTESIAN_POINT('Origin',(-7.49999999999974,-12.9903810567667,-3.5));
#2266=CARTESIAN_POINT('',(-7.34999999999974,-12.7305734356314,-3.5));
#2267=CARTESIAN_POINT('',(-7.34999999999974,-12.7305734356314,-3.5));
#2268=CARTESIAN_POINT('Origin',(-7.49999999999974,-12.9903810567667,-3.5));
#2269=CARTESIAN_POINT('Origin',(-5.69709184830706,-13.1161406088816,7.30000000000001));
#2270=CARTESIAN_POINT('Origin',(-7.49999999999974,-12.9903810567667,-3.5));
#2271=UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(0.01),#2275,
'DISTANCE_ACCURACY_VALUE',
'Maximum model space distance between geometric entities at asserted c
onnectivities');
#2272=UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(0.01),#2275,
onnectivities');
#2273=(
GEOMETRIC_REPRESENTATION_CONTEXT(3)
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#2271))
GLOBAL_UNIT_ASSIGNED_CONTEXT((#2275,#2277,#2278))
REPRESENTATION_CONTEXT('','3D')
#2274=(
GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#2272))
#2275=(
LENGTH_UNIT()
NAMED_UNIT(*)
SI_UNIT(.MILLI.,.METRE.)
#2276=(
LENGTH_UNIT()
NAMED_UNIT(*)
SI_UNIT($,.METRE.)
#2277=(
NAMED_UNIT(*)
PLANE_ANGLE_UNIT()
SI_UNIT($,.RADIAN.)
#2278=(
NAMED_UNIT(*)
SI_UNIT($,.STERADIAN.)
SOLID_ANGLE_UNIT()
#2279=SHAPE_DEFINITION_REPRESENTATION(#2280,#2281);
#2280=PRODUCT_DEFINITION_SHAPE('',$,#2283);
#2281=SHAPE_REPRESENTATION('',(#1279),#2273);
#2282=PRODUCT_DEFINITION_CONTEXT('part definition',#2287,'design');
#2283=PRODUCT_DEFINITION('Buzzer_piezo_KPEG132',
'Buzzer_piezo_KPEG132 v3',#2284,#2282);
#2284=PRODUCT_DEFINITION_FORMATION('',$,#2289);
#2285=PRODUCT_RELATED_PRODUCT_CATEGORY('Buzzer_piezo_KPEG132 v3',
'Buzzer_piezo_KPEG132 v3',(#2289));
#2286=APPLICATION_PROTOCOL_DEFINITION('international standard',
'automotive_design',2009,#2287);
#2287=APPLICATION_CONTEXT(
'Core Data for Automotive Mechanical Design Process');
#2288=PRODUCT_CONTEXT('part definition',#2287,'mechanical');
#2289=PRODUCT('Buzzer_piezo_KPEG132','Buzzer_piezo_KPEG132 v3',$,(#2288));
#2290=PRESENTATION_STYLE_ASSIGNMENT((#2293));
#2291=PRESENTATION_STYLE_ASSIGNMENT((#2294));
#2292=PRESENTATION_STYLE_ASSIGNMENT((#2295));
#2293=SURFACE_STYLE_USAGE(.BOTH.,#2296);
#2294=SURFACE_STYLE_USAGE(.BOTH.,#2297);
#2295=SURFACE_STYLE_USAGE(.BOTH.,#2298);
#2296=SURFACE_SIDE_STYLE('',(#2299));
#2297=SURFACE_SIDE_STYLE('',(#2300));
#2298=SURFACE_SIDE_STYLE('',(#2301));
#2299=SURFACE_STYLE_FILL_AREA(#2302);
#2300=SURFACE_STYLE_FILL_AREA(#2303);
#2301=SURFACE_STYLE_FILL_AREA(#2304);
#2302=FILL_AREA_STYLE('Steel - Satin',(#2305));
#2303=FILL_AREA_STYLE('ABS (White)',(#2306));
#2304=FILL_AREA_STYLE('Brass - Matte',(#2307));
#2305=FILL_AREA_STYLE_COLOUR('Steel - Satin',#2308);
#2306=FILL_AREA_STYLE_COLOUR('ABS (White)',#2309);
#2307=FILL_AREA_STYLE_COLOUR('Brass - Matte',#2310);
#2308=COLOUR_RGB('Steel - Satin',0.627450980392157,0.627450980392157,0.627450980392157);
#2309=COLOUR_RGB('ABS (White)',0.,0.,0.);
#2310=COLOUR_RGB('Brass - Matte',0.952941176470588,0.796078431372549,0.486274509803922);
ENDSEC;
END-ISO-10303-21;
This source diff could not be displayed because it is too large. You can view the blob instead.
G04 #@! TF.GenerationSoftware,KiCad,Pcbnew,5.1.5-52549c5~86~ubuntu18.04.1* G04 #@! TF.GenerationSoftware,KiCad,Pcbnew,5.1.5-52549c5~86~ubuntu18.04.1*
G04 #@! TF.CreationDate,2020-04-26T03:07:55+02:00* G04 #@! TF.CreationDate,2020-04-27T12:29:14+02:00*
G04 #@! TF.ProjectId,opensyringepump_indus,6f70656e-7379-4726-996e-676570756d70,1.5* G04 #@! TF.ProjectId,opensyringepump_indus,6f70656e-7379-4726-996e-676570756d70,1.5*
G04 #@! TF.SameCoordinates,Original* G04 #@! TF.SameCoordinates,Original*
G04 #@! TF.FileFunction,Copper,L4,Bot* G04 #@! TF.FileFunction,Copper,L4,Bot*
G04 #@! TF.FilePolarity,Positive* G04 #@! TF.FilePolarity,Positive*
%FSLAX46Y46*% %FSLAX46Y46*%
G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)* G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)*
G04 Created by KiCad (PCBNEW 5.1.5-52549c5~86~ubuntu18.04.1) date 2020-04-26 03:07:55* G04 Created by KiCad (PCBNEW 5.1.5-52549c5~86~ubuntu18.04.1) date 2020-04-27 12:29:14*
%MOMM*% %MOMM*%
%LPD*% %LPD*%
G04 APERTURE LIST* G04 APERTURE LIST*
%ADD10C,2.100000*% %ADD10C,1.800000*%
%ADD11C,1.450000*% %ADD11C,2.100000*%
%ADD12C,2.500000*% %ADD12C,1.450000*%
%ADD13O,1.700000X1.700000*% %ADD13C,2.500000*%
%ADD14R,1.700000X1.700000*% %ADD14O,1.700000X1.700000*%
%ADD15O,1.740000X2.200000*% %ADD15R,1.700000X1.700000*%
%ADD16C,0.100000*% %ADD16O,1.740000X2.200000*%
%ADD17O,2.200000X1.740000*% %ADD17C,0.100000*%
%ADD18C,1.800000*% %ADD18O,2.200000X1.740000*%
%ADD19C,9.000000*% %ADD19C,9.000000*%
%ADD20C,0.350000*% %ADD20C,0.350000*%
%ADD21C,1.700000*% %ADD21C,1.700000*%
...@@ -29,9 +29,13 @@ G04 APERTURE LIST* ...@@ -29,9 +29,13 @@ G04 APERTURE LIST*
%ADD26C,0.150000*% %ADD26C,0.150000*%
G04 APERTURE END LIST* G04 APERTURE END LIST*
D10* D10*
X139988618Y-125582016D03*
X121617984Y-107211382D03*
X114893398Y-132306602D03*
D11*
X150540000Y-47900000D03* X150540000Y-47900000D03*
X145460000Y-47900000D03* X145460000Y-47900000D03*
D11* D12*
X78755000Y-123250000D03* X78755000Y-123250000D03*
X80025000Y-120710000D03* X80025000Y-120710000D03*
X81295000Y-123250000D03* X81295000Y-123250000D03*
...@@ -40,10 +44,10 @@ X83835000Y-123250000D03* ...@@ -40,10 +44,10 @@ X83835000Y-123250000D03*
X85105000Y-120710000D03* X85105000Y-120710000D03*
X86375000Y-123250000D03* X86375000Y-123250000D03*
X87645000Y-120710000D03* X87645000Y-120710000D03*
D12* D13*
X89375000Y-125800000D03* X89375000Y-125800000D03*
X77025000Y-125800000D03* X77025000Y-125800000D03*
D13* D14*
X70060000Y-127060000D03* X70060000Y-127060000D03*
X70060000Y-129600000D03* X70060000Y-129600000D03*
X67520000Y-127060000D03* X67520000Y-127060000D03*
...@@ -63,12 +67,12 @@ X52280000Y-129600000D03* ...@@ -63,12 +67,12 @@ X52280000Y-129600000D03*
X49740000Y-127060000D03* X49740000Y-127060000D03*
X49740000Y-129600000D03* X49740000Y-129600000D03*
X47200000Y-127060000D03* X47200000Y-127060000D03*
D14*
X47200000Y-129600000D03*
D15* D15*
D16*
X106240000Y-55900000D03* X106240000Y-55900000D03*
G04 #@! TA.AperFunction,ComponentPad* G04 #@! TA.AperFunction,ComponentPad*
D16* D17*
G36* G36*
X104344505Y-54801204D02* X104344505Y-54801204D02*
G01* G01*
...@@ -142,12 +146,12 @@ X104320001Y-54800000D01* ...@@ -142,12 +146,12 @@ X104320001Y-54800000D01*
X104344505Y-54801204D01* X104344505Y-54801204D01*
G37* G37*
G04 #@! TD.AperFunction* G04 #@! TD.AperFunction*
D17* D18*
X134300000Y-80080000D03* X134300000Y-80080000D03*
X134300000Y-82620000D03* X134300000Y-82620000D03*
X134300000Y-85160000D03* X134300000Y-85160000D03*
D16* D17*
G36* G36*
X135174505Y-86831204D02* X135174505Y-86831204D02*
G01* G01*
...@@ -221,10 +225,10 @@ X135150001Y-86830000D01* ...@@ -221,10 +225,10 @@ X135150001Y-86830000D01*
X135174505Y-86831204D01* X135174505Y-86831204D01*
G37* G37*
D15* D16*
X71040000Y-37300000D03* X71040000Y-37300000D03*
D16* D17*
G36* G36*
X69144505Y-36201204D02* X69144505Y-36201204D02*
G01* G01*
...@@ -298,10 +302,10 @@ X69120001Y-36200000D01* ...@@ -298,10 +302,10 @@ X69120001Y-36200000D01*
X69144505Y-36201204D01* X69144505Y-36201204D01*
G37* G37*
D15* D16*
X78540000Y-37300000D03* X78540000Y-37300000D03*
D16* D17*
G36* G36*
X76644505Y-36201204D02* X76644505Y-36201204D02*
G01* G01*
...@@ -375,10 +379,10 @@ X76620001Y-36200000D01* ...@@ -375,10 +379,10 @@ X76620001Y-36200000D01*
X76644505Y-36201204D01* X76644505Y-36201204D01*
G37* G37*
D17* D18*
X37600000Y-69860000D03* X37600000Y-69860000D03*
D16* D17*
G36* G36*
X38474505Y-71531204D02* X38474505Y-71531204D02*
G01* G01*
...@@ -452,10 +456,10 @@ X38450001Y-71530000D01* ...@@ -452,10 +456,10 @@ X38450001Y-71530000D01*
X38474505Y-71531204D01* X38474505Y-71531204D01*
G37* G37*
D17* D18*
X38100000Y-57660000D03* X38100000Y-57660000D03*
D16* D17*
G36* G36*
X38974505Y-59331204D02* X38974505Y-59331204D02*
G01* G01*
...@@ -529,30 +533,26 @@ X38950001Y-59330000D01* ...@@ -529,30 +533,26 @@ X38950001Y-59330000D01*
X38974505Y-59331204D01* X38974505Y-59331204D01*
G37* G37*
D18*
D19* D19*
X174200000Y-129000000D03* X174200000Y-129000000D03*
X36000000Y-39000000D03* X36000000Y-39000000D03*
X36000000Y-129000000D03* X36000000Y-129000000D03*
X174200000Y-39000000D03* X174200000Y-39000000D03*
D13* D14*
X36500000Y-98800000D03* X36500000Y-98800000D03*
X36500000Y-101340000D03* X36500000Y-101340000D03*
X36500000Y-103880000D03* X36500000Y-103880000D03*
X36500000Y-106420000D03* X36500000Y-106420000D03*
X36500000Y-108960000D03* X36500000Y-108960000D03*
D14* D15*
X36500000Y-111500000D03* X36500000Y-111500000D03*
D13* D14*
X37840000Y-94080000D03* X37840000Y-94080000D03*
X35300000Y-94080000D03* X35300000Y-94080000D03*
X37840000Y-91540000D03* X37840000Y-91540000D03*
X35300000Y-91540000D03* X35300000Y-91540000D03*
X37840000Y-89000000D03* X37840000Y-89000000D03*
D14* D15*
X35300000Y-89000000D03* X35300000Y-89000000D03*
D20* D20*
X67975000Y-85533334D03* X67975000Y-85533334D03*
...@@ -562,7 +562,7 @@ D21* ...@@ -562,7 +562,7 @@ D21*
X105303949Y-110503949D02* X105303949Y-110503949D02*
X105303949Y-110503949D01* X105303949Y-110503949D01*
D16* D17*
G36* G36*
X107100000Y-111097918D02* X107100000Y-111097918D02*
G01* G01*
G04 #@! TF.FileFunction,Soldermask,Bot* G04 #@! TF.FileFunction,Soldermask,Bot*
G04 #@! TF.FilePolarity,Negative* G04 #@! TF.FilePolarity,Negative*
%MOMM*% %MOMM*%
%LPD*% %LPD*%
%ADD13C,3.175000*% %ADD13C,2.500000*%
%ADD14O,1.700000X1.700000*% %ADD14C,3.175000*%
%ADD15R,1.700000X1.700000*% %ADD15O,1.700000X1.700000*%
%ADD16O,1.740000X2.200000*% %ADD16R,1.700000X1.700000*%
%ADD17C,0.100000*% %ADD17O,1.740000X2.200000*%
%ADD18O,2.200000X1.740000*% %ADD18C,0.100000*%
%ADD19C,1.800000*% %ADD19O,2.200000X1.740000*%
%ADD20C,9.000000*% %ADD20C,9.000000*%
%ADD21C,0.350000*% %ADD21C,0.350000*%
%ADD22C,1.700000*% %ADD22C,1.700000*%
...@@ -27,9 +27,13 @@ G04 APERTURE LIST* ...@@ -27,9 +27,13 @@ G04 APERTURE LIST*
%ADD24R,1.400000X1.400000*% %ADD24R,1.400000X1.400000*%
D10* D10*
D11*
D11* D12*
...@@ -38,13 +42,13 @@ X83835000Y-123250000D03* ...@@ -38,13 +42,13 @@ X83835000Y-123250000D03*
D12* D13*
D13* D14*
X88915000Y-129600000D03* X88915000Y-129600000D03*
X77485000Y-129600000D03* X77485000Y-129600000D03*
D14* D15*
...@@ -64,11 +68,11 @@ X52280000Y-129600000D03* ...@@ -64,11 +68,11 @@ X52280000Y-129600000D03*
D15*
D16* D16*
X106240000Y-55900000D03* X47200000Y-129600000D03*
D17* D17*
D18*
G36* G36*
G01* G01*
...@@ -141,11 +145,11 @@ X103079999Y-54800000D01* ...@@ -141,11 +145,11 @@ X103079999Y-54800000D01*
X104320001Y-54800000D01* X104320001Y-54800000D01*
G37* G37*
D18* D19*
D17* D18*
G36* G36*
G01* G01*
...@@ -218,9 +222,9 @@ X133449999Y-86830000D01* ...@@ -218,9 +222,9 @@ X133449999Y-86830000D01*
X135150001Y-86830000D01* X135150001Y-86830000D01*
G37* G37*
D16*
D17* D17*
D18*
G36* G36*
G01* G01*
...@@ -293,9 +297,9 @@ X67879999Y-36200000D01* ...@@ -293,9 +297,9 @@ X67879999Y-36200000D01*
X69120001Y-36200000D01* X69120001Y-36200000D01*
G37* G37*
D16*
D17* D17*
D18*
G36* G36*
G01* G01*
...@@ -368,9 +372,9 @@ X75379999Y-36200000D01* ...@@ -368,9 +372,9 @@ X75379999Y-36200000D01*
X76620001Y-36200000D01* X76620001Y-36200000D01*
G37* G37*
D18* D19*
D17* D18*
G36* G36*
G01* G01*
...@@ -443,9 +447,9 @@ X36749999Y-71530000D01* ...@@ -443,9 +447,9 @@ X36749999Y-71530000D01*
X38450001Y-71530000D01* X38450001Y-71530000D01*
G37* G37*
D18* D19*
D17* D18*
G36* G36*
G01* G01*
...@@ -518,30 +522,26 @@ X37249999Y-59330000D01* ...@@ -518,30 +522,26 @@ X37249999Y-59330000D01*
X38950001Y-59330000D01* X38950001Y-59330000D01*
G37* G37*
D19*
D20* D20*
D14* D15*
D15* D16*
D14* D15*
D15* D16*
D21* D21*
...@@ -550,7 +550,7 @@ X67975000Y-87466666D03* ...@@ -550,7 +550,7 @@ X67975000Y-87466666D03*
D22* D22*
D17* D18*
G36* G36*
G01* G01*
