Skip to content
Commits on Source (2)
...@@ -7,9 +7,9 @@ ...@@ -7,9 +7,9 @@
xmlns="http://www.w3.org/2000/svg" xmlns="http://www.w3.org/2000/svg"
xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd" xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape" xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
width="450mm" width="453mm"
height="100mm" height="50mm"
viewBox="0 0 450 100" viewBox="0 0 453 50"
version="1.1" version="1.1"
id="svg2" id="svg2"
inkscape:version="0.91 r13725" inkscape:version="0.91 r13725"
...@@ -38,50 +38,45 @@ ...@@ -38,50 +38,45 @@
inkscape:pageopacity="0" inkscape:pageopacity="0"
inkscape:pageshadow="2" inkscape:pageshadow="2"
inkscape:window-width="2560" inkscape:window-width="2560"
inkscape:window-height="1414" inkscape:window-height="680"
id="namedview20" id="namedview20"
showgrid="false" showgrid="false"
inkscape:zoom="0.8771024" inkscape:zoom="0.62020505"
inkscape:cx="935.79414" inkscape:cx="894.99646"
inkscape:cy="261.42567" inkscape:cy="133.89006"
inkscape:window-x="0" inkscape:window-x="2560"
inkscape:window-y="0" inkscape:window-y="27"
inkscape:window-maximized="1" inkscape:window-maximized="0"
inkscape:current-layer="svg2" /> inkscape:current-layer="svg2" />
<g <g
id="Sketch" id="Sketch"
transform="matrix(1,0,0,-1,201.81397,54.5)"> transform="matrix(1,0,0,-1,201.81397,4.5000032)">
<title <title
id="title18">b'Sketch'</title> id="title18">b'Sketch'</title>
</g> </g>
<g <g
transform="matrix(-1,0,0,-1,226.59872,54.5)" transform="matrix(1,0,0,-1,259.52502,-70.587356)"
id="g4152">
<path
id="circle4176"
style="fill:none;stroke:#000000;stroke-width:0.34999999;stroke-miterlimit:4;stroke-dasharray:none"
d="m -189.5,12.5 c 0,1.380712 -1.11929,2.5 -2.5,2.5 -1.38071,0 -2.5,-1.119288 -2.5,-2.5 0,-1.380712 1.11929,-2.5 2.5,-2.5 1.38071,0 2.5,1.119288 2.5,2.5 z m 38.5,4.5 1,0 0,-9 -1,0 0,9 m -10,0 1,0 0,-9 -1,0 0,9 m -10,0 1,0 0,-9 -1,0 0,9 m 45.28571,-17.3 2.85715,0 m -8.57143,0 2.85714,0 m 2.85714,-25.2 2.85715,0 m -8.57143,0 2.85714,0 M -134.5,15 l 9,0 0,-1 -9,0 0,1 m -2.64286,-40.5 2.85715,0 m -2.85715,25.2 2.85715,0 m 323.79443,12.8 c 0,1.380712 1.11929,2.5 2.5,2.5 1.38071,0 2.5,-1.119288 2.5,-2.5 0,-1.380712 -1.11929,-2.5 -2.5,-2.5 -1.38071,0 -2.5,1.119288 -2.5,2.5 z m -38.5,4.5 -1,0 0,-9 1,0 0,9 m 10,0 -1,0 0,-9 1,0 0,9 m 10,0 -1,0 0,-9 1,0 0,9 m -45.28571,-17.3 -2.85715,0 m 8.57143,0 -2.85714,0 m -2.85714,-25.2 -2.85715,0 m 8.57143,0 -2.85714,0 m 5.92857,40.5 -9,0 0,-1 9,0 0,1 m 2.64286,-40.5 -2.85715,0 m 2.85715,25.2 -2.85715,0 M 195.49349,19.722083 194.07927,25 l 0.92945,0 c 2.76142,0 5,-2.238576 5,-5 l 0,-15 c 0,-2.7614237 -2.23858,-5 -5,-5 l -0.92945,0 1.41422,5.2779169 L 193.56163,5.795555 192.00872,0 l -52,0 0,-37 -6,0 0,-1.5 2,0 -2,-5 -8,0 -2,5 2,0 0,1.5 -6,0 0,37 L 0.00436,0 -120,0 l 0,-37 -6,0 0,-1.5 2,0 -2,-5 -8,0 -2,5 2,0 0,1.5 -6,0 0,37 -52,0 -1.55291,5.795555 -1.93186,-0.5176381 L -194.07055,0 -195,0 c -2.76142,0 -5,2.2385763 -5,5 l 0,15 c 0,2.761424 2.23858,5 5,5 l 0.92945,0 -1.41422,-5.277917 m 390.97826,0 -1.93186,-0.517638 L 192.00872,25 0.00436,25 -192,25 l -1.55291,-5.795555 -1.93186,0.517638"
inkscape:connector-curvature="0"
sodipodi:nodetypes="sssssccccccccccccccccccccccccccccccccsssssccccccccccccccccccccccccccccccccccsssscccccccccccccccccccccccccccccccccssssccccccccc" />
<title
id="title4178">b'Sketch'</title>
</g>
<g
transform="matrix(1,0,0,-1,259.52502,-20.587359)"
id="Sketch001"> id="Sketch001">
<title <title
id="title4187">b'support_visiere'</title> id="title4187">b'support_visiere'</title>
</g> </g>
<g <g
id="g4198" id="g4359"
transform="matrix(-1,0,0,-1,225.78395,16.094029)"> transform="translate(-2.3122682,-55.649581)" />
<path <path
id="path4200" id="path4311"
style="fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.34999999;stroke-miterlimit:4;stroke-dasharray:none" style="fill:none;stroke:#000000;stroke-width:0.34999999"
d="m -221,-6 -5,2.8867513 0,6.2264974 L -221,6 l 0,-2 1,0 0,7 220.022205,0 220.022205,0 0,-7 1,0 0,2 5,-2.8867513 0,-6.2264974 -5,-2.8867513 m 0,0 0,2 -1,0 0,-7 L 0.022205,-11 -220,-11 l 0,7 -1,0 0,-2" d="m 374.94036,23.080286 13.86642,-7.026455 57.99997,2.007559 0,-1.981104 1,0 0,2.000001 5.00002,-2.8868 0,-6.2265017 -5.00002,-2.8868 0,2.000001 -1,0 0,-4.065285 -71.86639,-2.934714 -148.15361,0 -148.153612,0 -71.8663862,2.934714 0,4.065285 -1,0 0,-2.000001 -4.99999996,2.8868 0,6.2265017 4.99999996,2.8868 0,-2.000001 1,0 0,1.981104 57.9999862,-2.007559 13.8664,7.026455 148.153612,0 z"
inkscape:connector-curvature="0" inkscape:connector-curvature="0"
sodipodi:nodetypes="cccccccccccccccccccccccc" /> sodipodi:nodetypes="ccccccccccccccccccccccccccccc" />
<title <g
id="title4202">b'support_visiere'</title> id="g4369"
transform="matrix(-1,0,0,0.99999999,435.96466,-5.1322278)">
<path
id="path4385"
style="fill:none;stroke:#000000;stroke-width:0.34999996"
d="m 91.561697,34.925971 2.631151,0 0,15.463678 -2.631151,0 0,-15.463678 m -69.154952,-1.605499 0.870748,0 0,17.745276 -0.870748,0 z m 16.211684,0.139623 0.996195,0.08716 -0.860951,9.840718 -0.996195,-0.08716 0.860951,-9.840718 m 10,0 0.996195,0.08716 -0.860951,9.840718 -0.996195,-0.08716 0.860951,-9.840718 m 10,0 0.996195,0.08716 -0.860951,9.840718 -0.996195,-0.08716 0.860951,-9.840718 M 19.686051,42 c 0,-1.3807 -1.1193,-2.5 -2.5,-2.5 -1.3807,0 -2.5,1.1193 -2.5,2.5 0,1.3807 1.1193,2.5 2.5,2.5 1.3807,0 2.5,-1.1193 2.5,-2.5 z m -10.0774933,-8.679528 2.0000003,0 0,17.745276 -2.0000003,0 z M 209.1779,29.49958 l -192.009999,0 -1.56,5.796 -1.929575,-0.51761 1.412325,-5.27797 -3.25069,0 c -2.7614003,0 -5.0000003,2.2386 -5.0000003,5 l 0,15 c 0,2.7614 2.2386,5 5.0000003,5 l 3.25069,0 -1.4142,-5.2779 1.93,-0.5177 1.55,5.7956 52,0 19.999996,0 120.021453,0 m 117.6162,-19.574029 -2.63115,0 0,15.463678 2.63115,0 0,-15.463678 m 69.15495,-1.605499 -0.87074,0 0,17.745276 0.87074,0 z m -16.21168,0.139623 -0.9962,0.08716 0.86096,9.840718 0.99619,-0.08716 -0.86095,-9.840718 m -10,0 -0.9962,0.08716 0.86096,9.840718 0.99619,-0.08716 -0.86095,-9.840718 m -10,0 -0.9962,0.08716 0.86096,9.840718 0.99619,-0.08716 -0.86095,-9.840718 M 398.66975,42 c 0,-1.3807 1.1193,-2.5 2.5,-2.5 1.3807,0 2.5,1.1193 2.5,2.5 0,1.3807 -1.1193,2.5 -2.5,2.5 -1.3807,0 -2.5,-1.1193 -2.5,-2.5 z m 10.07749,-8.679528 -2,0 0,17.745276 2,0 z M 209.1779,29.49958 l 192.01,0 1.56,5.796 1.92957,-0.51761 -1.41232,-5.27797 3.25069,0 c 2.7614,0 5,2.2386 5,5 l 0,15 c 0,2.7614 -2.2386,5 -5,5 l -3.25069,0 1.4142,-5.2779 -1.93,-0.5177 -1.55,5.7956 -52,0 -20,0 -120.02145,0"
sodipodi:nodetypes="cccccccccccccccccccccccccsssssccccccccccssssccccccccccccccccccccccccccccccccsssssccccccccccssssccccccc" />
</g> </g>
</svg> </svg>
