Skip to content
Commits on Source (21)
...@@ -14,12 +14,6 @@ config ARCH_HAVE_LEDS ...@@ -14,12 +14,6 @@ config ARCH_HAVE_LEDS
config HN70AP_HWDEBUG_BLINK config HN70AP_HWDEBUG_BLINK
bool "Just Blink leds instead of starting NuttX" bool "Just Blink leds instead of starting NuttX"
config HN70AP_EEPROM
bool "Enable EEPROM (requires I2C3)"
config HN70AP_SPIFLASH
bool "Enable SPI FLASH (requires SPI2)"
config HN70AP_SCREEN config HN70AP_SCREEN
bool "Enable OLED screen (requires I2C3)" bool "Enable OLED screen (requires I2C3)"
...@@ -5,7 +5,7 @@ ...@@ -5,7 +5,7 @@
config HN70AP_CONFIG config HN70AP_CONFIG
bool "system configuration app" bool "system configuration app"
default y default n
---help--- ---help---
The config app manages the system settings. The config app manages the system settings.
...@@ -77,7 +77,7 @@ int config_list(void) ...@@ -77,7 +77,7 @@ int config_list(void)
else if(type == EECONFIG_TYPE_IP) else if(type == EECONFIG_TYPE_IP)
struct in_addr val; struct in_addr val;
ret = hn70ap_eeconfig_getip(name, &val); ret = hn70ap_eeconfig_getip(name, &val.s_addr);
if(ret == OK) if(ret == OK)
printf("%s\n", inet_ntoa(val)); printf("%s\n", inet_ntoa(val));
...@@ -37,7 +37,7 @@ ...@@ -37,7 +37,7 @@
#define HN70AP_LCD_H #define HN70AP_LCD_H
int hn70ap_lcd_init(void); int hn70ap_lcd_init(void);
int hn70ap_lcd_drawchar(int row, int col, char *ch); int hn70ap_lcd_drawchar(int row, int col, char ch);
int hn70ap_lcd_drawstr(int row, int col, char *ch); int hn70ap_lcd_drawstr(int row, int col, char *ch);
#endif #endif
...@@ -42,9 +42,11 @@ ...@@ -42,9 +42,11 @@
#define HN70AP_RADIO_MAIN 1 #define HN70AP_RADIO_MAIN 1
#define HN70AP_RADIO_AUX 2 #define HN70AP_RADIO_AUX 2
typedef int (*radiorxfunction_f)(uint8_t device, FAR void *arg, FAR uint8_t *data, int length);
int hn70ap_radio_init(void); int hn70ap_radio_init(void);
int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len); int hn70ap_radio_rxfunction(uint8_t device, radiorxfunction_f rx, FAR void *arg, FAR uint8_t *userbuf, int userbuflen);
int hn70ap_radio_receive (uint8_t device, uint8_t *buf, size_t len); int hn70ap_radio_transmit(uint8_t device, FAR uint8_t *buf, size_t len);
#endif /* HN70AP_SYSTEM_H */ #endif /* HN70AP_SYSTEM_H */
* hn70ap/apps/export/tun.h
* Copyright (C) 2018 Sebastien Lorquet. All rights reserved.
* Author: Sebastien Lorquet <sebastien@lorquet.fr>
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name NuttX nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#ifndef HN70AP_TUN_H
#define HN70AP_TUN_H
#include <stdint.h>
#include <stdbool.h>
#include <netinet/in.h>
#include <net/if.h>
typedef int (*tunrxfunction_f)(uint8_t tun, FAR void *arg, FAR uint8_t *data, int length);
int hn70ap_tun_init(void);
int hn70ap_tun_devinit(char ifname[IFNAMSIZ]);
int hn70ap_tun_addroute(int tunnel, in_addr_t destination, int maskbits);
int hn70ap_tun_rxfunction(int tunnel, tunrxfunction_f rx, FAR void *arg, FAR uint8_t *userbuf, int userbuflen);
int hn70ap_tun_transmit(int tunnel, FAR uint8_t *buf, size_t len);
...@@ -5,4 +5,4 @@ ...@@ -5,4 +5,4 @@
config LIBHN70AP config LIBHN70AP
bool "Common Library" bool "Common Library"
default y default n
...@@ -37,6 +37,11 @@ ...@@ -37,6 +37,11 @@
ASRCS = ASRCS =
CSRCS = eeprom.c leds.c lcd.c timer.c system.c radio.c CSRCS = eeprom.c leds.c lcd.c timer.c system.c radio.c
ifeq ($(CONFIG_NET_TUN),y)
CSRCS += tun.c
endif
CSRCS += tlv.c crc.c sha256.c hdlc.c CSRCS += tlv.c crc.c sha256.c hdlc.c
CSRCS += update.c CSRCS += update.c
...@@ -33,6 +33,19 @@ ...@@ -33,6 +33,19 @@
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/mman.h>
#include <nuttx/video/fb.h>
#include <nuttx/nx/nxglib.h>
#include <hn70ap/lcd.h>
//Manage the 128x64 LCD //Manage the 128x64 LCD
//Using aligned character positions, we can write 8 lines of 16 chars //Using aligned character positions, we can write 8 lines of 16 chars
...@@ -304,8 +317,87 @@ unsigned char font[2048] = ...@@ -304,8 +317,87 @@ unsigned char font[2048] =
* hn70ap_lcd_init * hn70ap_lcd_init
struct fb_state_s
int fd;
struct fb_videoinfo_s vinfo;
struct fb_planeinfo_s pinfo;
FAR void *fbmem;
struct fb_state_s state;
int hn70ap_lcd_init(void) int hn70ap_lcd_init(void)
int ret;
state.fd = open("/dev/fb0", O_RDWR);
if (state.fd < 0)
int errcode = errno;
fprintf(stderr, "ERROR: Failed to open /dev/fb0: %d\n", errcode);
return EXIT_FAILURE;
ret = ioctl(state.fd, FBIOGET_VIDEOINFO,
(unsigned long)((uintptr_t)&state.vinfo));
if (ret < 0)
fprintf(stderr, "ERROR: ioctl(FBIOGET_VIDEOINFO) failed: %d\n",
errcode);
close(state.fd);
ret = ioctl(state.fd, FBIOGET_PLANEINFO,
(unsigned long)((uintptr_t)&state.pinfo));
if (ret < 0)
fprintf(stderr, "ERROR: ioctl(FBIOGET_PLANEINFO) failed: %d\n",
errcode);
close(state.fd);
if (state.pinfo.bpp != 1)
fprintf(stderr, "ERROR: bpp=%u not supported\n", state.pinfo.bpp);
close(state.fd);
state.fbmem = mmap(NULL, state.pinfo.fblen, PROT_READ|PROT_WRITE,
MAP_SHARED|MAP_FILE, state.fd, 0);
if (state.fbmem == MAP_FAILED)
errcode);
close(state.fd);
hn70ap_lcd_drawstr(0,0,"hn70ap!\r");
return 0;
* hn70ap_lcd_drawchar
static int hn70ap_lcd_drawchar_internal(int row, int col, char ch)
int i;
uint8_t *ptr = state.fbmem + (8 * row * state.pinfo.stride) + col;
for(i=0;i<8;i++)
*ptr = font [ch * 8 + i];
ptr += state.pinfo.stride;
return 0; return 0;
...@@ -315,6 +407,24 @@ int hn70ap_lcd_init(void) ...@@ -315,6 +407,24 @@ int hn70ap_lcd_init(void)
int hn70ap_lcd_drawchar(int row, int col, char ch) int hn70ap_lcd_drawchar(int row, int col, char ch)
struct nxgl_rect_s rect;
int ret = hn70ap_lcd_drawchar_internal(row,col,ch);
#ifdef CONFIG_LCD_UPDATE
rect.pt1.x = col*8;
rect.pt1.y = row*8;
rect.pt2.x = rect.pt1.x + 8;
rect.pt2.y = rect.pt1.y + 8;
ret = ioctl(state.fd, FBIO_UPDATE, (unsigned long)((uintptr_t)&rect));
if (ret < 0)
fprintf(stderr, "ERROR: ioctl(FBIO_UPDATE) failed: %d\n",
errcode);
#endif
return 0; return 0;
...@@ -324,9 +434,41 @@ int hn70ap_lcd_drawchar(int row, int col, char ch) ...@@ -324,9 +434,41 @@ int hn70ap_lcd_drawchar(int row, int col, char ch)
int hn70ap_lcd_drawstr(int row, int col, char *ch) int hn70ap_lcd_drawstr(int row, int col, char *ch)
int ret;
int cr = row; int cr = row;
int cc = col; int cc = col;
while(*ch)
if(*ch == '\r')
rect.pt1.x = col*8;
rect.pt1.y = cr*8;
rect.pt2.x = (cc*8) + 8;
if (ret < 0)
fprintf(stderr, "ERROR: ioctl(FBIO_UPDATE) failed: %d\n", errno);
#endif
cc = col;
else if(*ch == '\n')
cr += 1;
else
hn70ap_lcd_drawchar_internal(cr,cc,*ch);
cc += 1;
ch++;
return 0; return 0;
...@@ -41,32 +41,49 @@ ...@@ -41,32 +41,49 @@
#include <fcntl.h> #include <fcntl.h>
#include <syslog.h> #include <syslog.h>
#include <unistd.h> #include <unistd.h>
#include <errno.h>
#include <pthread.h> #include <pthread.h>
#include <hn70ap/radio.h> #include <hn70ap/radio.h>
#include <hn70ap/leds.h> #include <hn70ap/leds.h>
static int g_hn70ap_fdmainradio; /* management variables for one radio */
static int g_hn70ap_fdauxradio; struct radio_s
int devfd;
bool alive;
pthread_t rxthread;
/*data reception and calling back to the user*/
FAR uint8_t * userbuf;
int userbuflen;
radiorxfunction_f callback;
FAR void * arg;
static bool g_hn70ap_radioalive; static struct radio_s g_hn70ap_mainradio;
static pthread_t g_hn70ap_txthreadid; static struct radio_s g_hn70ap_auxradio;
* hn70ap_radio_txthread * hn70ap_radio_receive
* This thread waits for radio transmit requests from other processes,
* and sends packets.
void *hn70ap_radio_txthread(void *arg) static int hn70ap_radio_receive(struct radio_s *radio, uint8_t *buf, size_t len)
syslog(LOG_INFO, "Started radio RX thread\n"); int ret;
while(g_hn70ap_radioalive)
{ /* Turn on radio LED in receive mode */
//Wait for messages in transmit queue hn70ap_leds_state(LED_1A, LED_STATE_OFF);
//Transmit these messages hn70ap_leds_state(LED_1B, LED_STATE_ON);
syslog(LOG_INFO, "Stopped radio RX thread\n"); /* Receive */
ret = read(radio->devfd, buf, len);
/* Turn off radio LED */
hn70ap_leds_state(LED_1B, LED_STATE_OFF);
return ret;
...@@ -75,16 +92,16 @@ void *hn70ap_radio_txthread(void *arg) ...@@ -75,16 +92,16 @@ void *hn70ap_radio_txthread(void *arg)
int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len) int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len)
int fd; struct radio_s *radio;
int ret; int ret;
if(device == HN70AP_RADIO_MAIN) if(device == HN70AP_RADIO_MAIN)
fd = g_hn70ap_fdmainradio; radio = &g_hn70ap_mainradio;
else if(device == HN70AP_RADIO_AUX) else if(device == HN70AP_RADIO_AUX)
fd = g_hn70ap_fdauxradio; radio = &g_hn70ap_auxradio;
else else
...@@ -96,7 +113,7 @@ int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len) ...@@ -96,7 +113,7 @@ int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len)
hn70ap_leds_state(LED_1B, LED_STATE_OFF); hn70ap_leds_state(LED_1B, LED_STATE_OFF);
/* Transmit */ /* Transmit */
ret = write(fd, buf, len); ret = write(radio->devfd, buf, len);
/* Turn off radio LED */ /* Turn off radio LED */
hn70ap_leds_state(LED_1A, LED_STATE_OFF); hn70ap_leds_state(LED_1A, LED_STATE_OFF);
...@@ -106,78 +123,114 @@ int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len) ...@@ -106,78 +123,114 @@ int hn70ap_radio_transmit(uint8_t device, uint8_t *buf, size_t len)
* hn70ap_radio_receive * hn70ap_radio_rxthread
* This thread waits for radio packets on the air, and sends them to processes.
int hn70ap_radio_receive(uint8_t device, uint8_t *buf, size_t len) void *hn70ap_radio_rxthread(void *arg)
int fd; struct radio_s *radio = (struct radio_s*)arg;
int ret; int ret;
if(device == HN70AP_RADIO_MAIN) while(radio->alive)
fd = g_hn70ap_fdmainradio; if(radio->callback)
//Wait for messages on the air
ret = hn70ap_radio_receive(radio, radio->userbuf, radio->userbuflen);
if(ret > 0)
//Dispatch them to the callback
radio->callback((radio==&g_hn70ap_mainradio)?HN70AP_RADIO_MAIN:HN70AP_RADIO_AUX, radio->arg, radio->userbuf, ret);
fd = g_hn70ap_fdauxradio; //syslog(LOG_ERR, "radio rx failed -> errno=%d\n", errno);
} //callback defined
else else
return ERROR; pthread_yield();
} //radio alive
return NULL;
/* Turn on radio LED in transmit mode */ /****************************************************************************
hn70ap_leds_state(LED_1A, LED_STATE_OFF); * hn70ap_radio_devinit
hn70ap_leds_state(LED_1B, LED_STATE_ON); ****************************************************************************/
/* Transmit */ int hn70ap_radio_devinit(struct radio_s *radio, const char *dev)
ret = read(fd, buf, len); {
int ret = 0;
/* Turn off radio LED */ radio->devfd = open(dev, O_RDWR);
hn70ap_leds_state(LED_1A, LED_STATE_OFF); if(radio->devfd<0)
hn70ap_leds_state(LED_1B, LED_STATE_OFF); {
syslog(LOG_ERR, "Failed to access main radio!\n");
ret = -1;
goto lret;
radio->callback = NULL;
radio->alive = true;
ret = pthread_create(&radio->rxthread, NULL, hn70ap_radio_rxthread, radio);
if(ret < 0)
syslog(LOG_ERR, "Failed to start the receive thread\n");
lret:
return ret; return ret;
* hn70ap_radio_rxfunction
else
return ERROR;
radio->userbuf = userbuf;
radio->userbuflen = userbuflen;
radio->arg = arg;
radio->callback = rx;
return OK;
* hn70ap_radio_init * hn70ap_radio_init
int hn70ap_radio_init(void) int hn70ap_radio_init(void)
int ret = 0;
#ifdef CONFIG_HN70AP_MAINRADIO #ifdef CONFIG_HN70AP_MAINRADIO
syslog(LOG_INFO, "Checking main radio\n"); syslog(LOG_INFO, "Checking main radio\n");
g_hn70ap_fdmainradio = open("/dev/rmain", O_RDWR); hn70ap_radio_devinit(&g_hn70ap_mainradio, "/dev/rmain");
if(g_hn70ap_fdmainradio<0)
ret = -1;
goto lret;
#endif #endif
#ifdef CONFIG_HN70AP_AUXRADIO #ifdef CONFIG_HN70AP_AUXRADIO
syslog(LOG_INFO, "Checking aux radio\n"); syslog(LOG_INFO, "Checking aux radio\n");
g_hn70ap_fdauxradio = open("/dev/raux", O_RDWR); hn70ap_radio_devinit(&g_hn70ap_auxradio, "/dev/raux");
if(g_hn70ap_fdauxradio<0)
syslog(LOG_ERR, "Failed to access aux radio!\n");
ret = -1;
goto lret;
#endif #endif
g_hn70ap_radioalive = true; return OK;
ret = pthread_create(&g_hn70ap_txthreadid, NULL, hn70ap_radio_txthread, NULL);
if(ret < 0)
syslog(LOG_ERR, "Failed to start the transmit thread\n");
lret:
return ret;
...@@ -37,20 +37,27 @@ ...@@ -37,20 +37,27 @@
#include <stdint.h> #include <stdint.h>
#include <stdbool.h> #include <stdbool.h>
#include <string.h>
#include <net/if.h>
#include <hn70ap/eeprom.h> #include <hn70ap/eeprom.h>
#include <hn70ap/timer.h> #include <hn70ap/timer.h>
#include <hn70ap/tun.h>
static bool hn70ap_system_initialized = false; static bool hn70ap_system_initialized = false;
int hn70ap_system_init(void) int hn70ap_system_init(void)
int ret; int ret;
int tunid = -1;
bool defaults; bool defaults;
char tunname[IFNAMSIZ];
if(hn70ap_system_initialized) if(hn70ap_system_initialized)
...@@ -90,13 +97,36 @@ int hn70ap_system_init(void) ...@@ -90,13 +97,36 @@ int hn70ap_system_init(void)
syslog(LOG_ERR, "WARNING: Default config values loaded in EEPROM\n"); syslog(LOG_ERR, "WARNING: Default config values loaded in EEPROM\n");
ret = hn70ap_lcd_init();
if(ret != OK)
syslog(LOG_ERR, "WARNING: Failed to initialize Screen\n");
#ifdef CONFIG_NET_TUN
ret = hn70ap_tun_init();
if(ret != 0)
syslog(LOG_ERR, "WARNING: Failed to initialize tunnels\n");
strncpy(tunname, "uhf0", IFNAMSIZ);
ret = hn70ap_tun_devinit(tunname);
if(ret < 0)
syslog(LOG_ERR, "WARNING: Failed to initialize TUN interface\n");
tunid = ret;
#endif
ret = hn70ap_radio_init(); ret = hn70ap_radio_init();
if(ret != 0) if(ret != 0)
syslog(LOG_ERR, "FATAL: Failed to initialize Radios\n"); syslog(LOG_ERR, "WARNING: Failed to initialize Radios\n");
return ERROR;
// bind the tunnel and the aux radio
hn70ap_system_initialized = true; hn70ap_system_initialized = true;
return OK; return OK;
* hn70ap/apps/libhn70ap/tun.c
* are met:
* distribution.
#include <nuttx/config.h>
#include <stdio.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <errno.h>
#include <syslog.h>
#include <nuttx/net/tun.h>
struct iptunnel_s
int fd;
char ifname[IFNAMSIZ];
bool alive;
pthread_t rxthread;
int userbuflen;
tunrxfunction_f callback;
FAR void * arg;
struct iptunnel_s tunnels[2];
* hn70ap_tun_rxthread
* This thread waits for packets from the tun interface, and sends them to processes.
void *hn70ap_tun_rxthread(void *arg)
struct iptunnel_s *tunnel = (struct iptunnel_s*)arg;
syslog(LOG_INFO, "Started tun RX thread\n");
int ret;
while(tunnel->alive)
if(tunnel->callback)
ret = read(tunnel->fd, tunnel->userbuf, tunnel->userbuflen);
if(ret > 0)
tunnel->callback((tunnel==tunnels)?0:1, tunnel->arg, tunnel->userbuf, ret);
else
//syslog(LOG_ERR, "tunnel rx failed -> errno=%d\n", errno);
else
pthread_yield();
} //tunnel alive
syslog(LOG_INFO, "Stopped tunnel RX thread\n");
return NULL;
* hn70ap_tun_transmit
if(tunnel != 0 && tunnel != 1)
return -1;
return write(tunnels[tunnel].fd, buf, len);
* hn70ap_tun_rxfunction
return -1;
tunnels[tunnel].userbuf = userbuf;
tunnels[tunnel].userbuflen = userbuflen;
tunnels[tunnel].arg = arg;
tunnels[tunnel].callback = rx;
return OK;
* hn70ap_tun_devinit
int hn70ap_tun_devinit(char name[IFNAMSIZ])
struct ifreq ifr;
int errcode;
int fd;
int ret;
struct iptunnel_s *tunnel = &tunnels[0];
if(tunnel->fd != 0)
tunnel = &tunnels[1];
if(tunnel->fd != 0)
syslog(LOG_ERR, "No tunnel available");
return -1;
if ((fd = open("/dev/tun", O_RDWR)) < 0)
return fd;
memset(&ifr, 0, sizeof(ifr));
ifr.ifr_flags = IFF_TUN;
if (name[0])
strncpy(ifr.ifr_name, name, IFNAMSIZ);
errcode = ioctl(fd, TUNSETIFF, (unsigned long)&ifr);
if(errcode < 0)
close(fd);
return errcode;
tunnel->fd = fd;
strncpy(tunnel->ifname, ifr.ifr_name, IFNAMSIZ);
syslog(LOG_INFO, "Started interface: %s\n", tunnel->ifname);
//Start RX thread
tunnel->alive = true;
tunnel->callback = NULL;
ret = pthread_create(&tunnel->rxthread, NULL, hn70ap_tun_rxthread, tunnel);
if(ret < 0)
return fd;
* hn70ap_tun_addroute
return ERROR;
* hn70ap_tun_init
tunnels[0].fd = 0;
tunnels[1].fd = 0;
return 0;
config HN70AP_RXT config HN70AP_RXT
bool "RX test" bool "RX test"
default y default n
Test Radio Reception. Test Radio Reception.
...@@ -55,8 +55,22 @@ ...@@ -55,8 +55,22 @@
* Public Functions * Public Functions
* status_main * rxt_callback
int rxt_callback(uint8_t device, FAR void *arg, FAR uint8_t *data, int length)
int i;
for(i=0; i<length; i++)
printf("%c", (data[i]<0x20 && data[i]!=0x0a)?'.':data[i]);
return 0;
* rxt_main
#ifdef CONFIG_BUILD_KERNEL #ifdef CONFIG_BUILD_KERNEL
...@@ -66,9 +80,7 @@ int rxt_main(int argc, char *argv[]) ...@@ -66,9 +80,7 @@ int rxt_main(int argc, char *argv[])
#endif #endif
int ret = OK; int ret = OK;
int fd;
int buflen = 1024; int buflen = 1024;
int i;
uint8_t *buf; uint8_t *buf;
...@@ -84,32 +96,13 @@ int rxt_main(int argc, char *argv[]) ...@@ -84,32 +96,13 @@ int rxt_main(int argc, char *argv[])
goto done; goto done;
do hn70ap_radio_rxfunction(HN70AP_RADIO_AUX, rxt_callback, NULL, buf, buflen);
ret = hn70ap_radio_receive(HN70AP_RADIO_AUX, buf, buflen); printf("type return to quit\n");
//printf("read done, ret = %d, errno=%d\n", ret, errno); getchar();
if(ret > 0)
/* for(i=0; i<ret; i++)
printf("%02X ", buf[i]);
printf("\n");*/
printf("%c", (buf[i]<0x20 && buf[i]!=0x0a)?'.':buf[i]);
else if(ret < 0 && errno==ETIMEDOUT)
printf("RX timeout\n");
// ret = 1;
// continue;
while(ret > 0);
printf("Read sequence done.\n"); printf("Stopping reception\n");
hn70ap_radio_rxfunction(HN70AP_RADIO_AUX, NULL, NULL, NULL, 0);
free(buf); free(buf);
done: done:
config HN70AP_SYSDAEMON config HN70AP_SYSDAEMON
bool "system daemon" bool "system daemon"
default y default n
The system daemon manages the ethernet link status, the oled screen, then starts nsh. The system daemon manages the ethernet link status, the oled screen, then starts nsh.
...@@ -47,6 +47,8 @@ ...@@ -47,6 +47,8 @@
#include <hn70ap/system.h> #include <hn70ap/system.h>
#include "sysdaemon_internal.h" #include "sysdaemon_internal.h"
...@@ -72,10 +74,33 @@ void hn70ap_mount_storage(void) ...@@ -72,10 +74,33 @@ void hn70ap_mount_storage(void)
printf("Mass Storage mounted at /data\n"); printf("Mass Storage mounted at /data\n");
#endif #endif
#ifdef CONFIG_FS_PROCFS
ret = mount(NULL, "/proc", "procfs", 0, NULL);
if (ret < 0)
fprintf(stderr, "Failed to mount /proc\n");
else
printf("Mounted /proc\n");
#endif
* status_main * sysdaemon_radiocallback
uint8_t radiobuf[512];
int sysdaemon_radiocallback(uint8_t device, FAR void *arg, FAR uint8_t *data, int length)
printf("RADIORX len %d\n", length);
return OK;
* sysdaemon_main
...@@ -110,11 +135,14 @@ int sysdaemon_main(int argc, char *argv[]) ...@@ -110,11 +135,14 @@ int sysdaemon_main(int argc, char *argv[])
printf("Hello %s, best 73's\n", call); printf("Hello %s, best 73's\n", call);
printf("TODO start screen management\n");
/* Try to open radio devices. */ /* Try to open radio devices. */
ret = hn70ap_radio_rxfunction(HN70AP_RADIO_AUX, sysdaemon_radiocallback, NULL, radiobuf, sizeof(radiobuf));
if(ret == 0)
printf("aux radio cb installed ok\n");
#if defined(CONFIG_EXAMPLES_NSH) #if defined(CONFIG_SYSTEM_NSH)
printf("*** Launching nsh\n"); printf("*** Launching nsh\n");
nsh_main(argc, argv); nsh_main(argc, argv);
#endif #endif
...@@ -192,6 +192,7 @@ static void* netmonitor_thread(void *arg) ...@@ -192,6 +192,7 @@ static void* netmonitor_thread(void *arg)
struct timespec reltime; struct timespec reltime;
struct ifreq ifr; struct ifreq ifr;
struct sigaction act; struct sigaction act;
struct sigaction oact;
bool devup; bool devup;
int ret; int ret;
int sd; int sd;
...@@ -221,7 +222,7 @@ static void* netmonitor_thread(void *arg) ...@@ -221,7 +222,7 @@ static void* netmonitor_thread(void *arg)
act.sa_sigaction = netmonitor_signal; act.sa_sigaction = netmonitor_signal;
act.sa_flags = SA_SIGINFO; act.sa_flags = SA_SIGINFO;
ret = sigaction(SIGUSR2, &act, NULL); ret = sigaction(SIGUSR2, &act, &oact);
if (ret < 0) if (ret < 0)
ret = -errno; ret = -errno;
...@@ -394,7 +395,7 @@ static void* netmonitor_thread(void *arg) ...@@ -394,7 +395,7 @@ static void* netmonitor_thread(void *arg)
errout_with_notification: errout_with_notification:
# warning Missing logic # warning Missing logic
errout_with_sigaction: errout_with_sigaction:
# warning Missing logic (void)sigaction(SIGUSR2, &oact, NULL);
errout_with_socket: errout_with_socket:
close(sd); close(sd);
errout: errout:
config HN70AP_TXT config HN70AP_TXT
bool "TX test" bool "TX test"
default y default n
Test Radio Transmission. Test Radio Transmission.
This diff is collapsed.
...@@ -702,8 +702,6 @@ CONFIG_ARCH_BOARD_CUSTOM_DIR_RELPATH=y ...@@ -702,8 +702,6 @@ CONFIG_ARCH_BOARD_CUSTOM_DIR_RELPATH=y
# ----- hn70ap board features ----- # ----- hn70ap board features -----
# CONFIG_HN70AP_HWDEBUG_BLINK is not set # CONFIG_HN70AP_HWDEBUG_BLINK is not set
CONFIG_HN70AP_EEPROM=y
CONFIG_HN70AP_SPIFLASH=y
# CONFIG_HN70AP_SCREEN is not set # CONFIG_HN70AP_SCREEN is not set
# CONFIG_HN70AP_ETHERNET is not set # CONFIG_HN70AP_ETHERNET is not set
CONFIG_HN70AP_RADIO=y CONFIG_HN70AP_RADIO=y
