Skip to content
Commits on Source (4)
...@@ -92,6 +92,10 @@ int beacon_main(int argc, char *argv[]) ...@@ -92,6 +92,10 @@ int beacon_main(int argc, char *argv[])
data = argv[1]; data = argv[1];
else if(argc == 1)
data = "HELLO 73";
else else
return beacon_usage(); return beacon_usage();
...@@ -138,7 +142,7 @@ int beacon_main(int argc, char *argv[]) ...@@ -138,7 +142,7 @@ int beacon_main(int argc, char *argv[])
printf("write failed, errno=%d\n", errno); printf("write failed, errno=%d\n", errno);
break; break;
sleep(1); sleep(2);
seqnum += 1; seqnum += 1;
* hn70ap/apps/export/leds.h
* Copyright (C) 2018 Sebastien Lorquet. All rights reserved.
* Author: Sebastien Lorquet <sebastien@lorquet.fr>
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name NuttX nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#ifndef HN70AP_TIMER
#define HN70AP_TIMER
int leds_init(void);
int leds_state(int led, int state);
#endif //HN70AP_TIMER
* hn70ap/apps/export/timer.h
* are met:
* distribution.
int timer_init(void);
...@@ -36,7 +36,7 @@ ...@@ -36,7 +36,7 @@
-include $(TOPDIR)/Make.defs -include $(TOPDIR)/Make.defs
ASRCS = ASRCS =
CSRCS = eeprom.c CSRCS = eeprom.c leds.c timer.c
CSRCS += tlv.c crc.c sha256.c hdlc.c CSRCS += tlv.c crc.c sha256.c hdlc.c
CSRCS += update.c CSRCS += update.c
* hn70ap/apps/libhn70ap/timer.c
* are met:
* distribution.
#include <nuttx/config.h>
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <unistd.h>
#include <nuttx/leds/userled.h>
#include <hn70ap/timer.h>
int leds_init(void)
int leds_state(int lednum, bool state)
struct userled_s led;
int fd;
int ret;
fd = open("/dev/userleds", O_RDWR);
if(fd<0)
fprintf(stderr, "Failed to open LEDS device\n");
return -1;
led.ul_led = lednum;
led.ul_on = state;
ret = ioctl(fd, ULEDIOC_SETLED, (unsigned long)&led);
if(ret<0)
fprintf(stderr, "Failed to change LED state\n");
return -1;
close(fd);
return 0;
* are met:
* distribution.
#include <stdint.h>
return 0;
...@@ -45,6 +45,8 @@ ...@@ -45,6 +45,8 @@
#include <sys/mount.h> #include <sys/mount.h>
#include <hn70ap/eeprom.h> #include <hn70ap/eeprom.h>
#include <hn70ap/leds.h>
#include "sysdaemon_internal.h" #include "sysdaemon_internal.h"
...@@ -79,10 +81,33 @@ int main(int argc, FAR char *argv[]) ...@@ -79,10 +81,33 @@ int main(int argc, FAR char *argv[])
int sysdaemon_main(int argc, char *argv[]) int sysdaemon_main(int argc, char *argv[])
#endif #endif
int ret;
bool defaults; bool defaults;
char call[9]; char call[9];
printf("\nhn70ap system daemon starting\n"); printf("\nhn70ap system daemon starting\n");
/* Initialize timer thread to help us schedule delays */
ret = timer_init();
if(ret != 0)
printf("FATAL: Failed to initialize timers\n");
goto lfail;
/* Initialize the leds */
/* Requires timer for blinking */
ret = leds_init();
if(ret != 0)
printf("FATAL: Failed to initialize Leds\n");
goto lfail;
/* Initialize the EEPROM */
hn70ap_eeconfig_init(&defaults); hn70ap_eeconfig_init(&defaults);
if(defaults) if(defaults)
...@@ -91,8 +116,15 @@ int sysdaemon_main(int argc, char *argv[]) ...@@ -91,8 +116,15 @@ int sysdaemon_main(int argc, char *argv[])
else else
hn70ap_eeconfig_getcall("call", call); hn70ap_eeconfig_getcall("call", call);
call[8] = 0; if(call[0] == 0)
printf("Hello %s, best 73's\n", call); {
printf("Callsign not defined yet, please use the config tool\n");
else
call[8] = 0;
hn70ap_mount_storage(); hn70ap_mount_storage();
...@@ -108,5 +140,11 @@ int sysdaemon_main(int argc, char *argv[]) ...@@ -108,5 +140,11 @@ int sysdaemon_main(int argc, char *argv[])
printf("Back from nsh, now sleeping forever.\n"); printf("Back from nsh, now sleeping forever.\n");
return 0; return 0;
lfail:
/* Panic... something could not be initialized
* Try to switch on the red LED
return ERROR;
...@@ -18,7 +18,7 @@ be installed via JTAG, and it cannot be upgraded. ...@@ -18,7 +18,7 @@ be installed via JTAG, and it cannot be upgraded.
OLED screen on the i2c bus. It contains a "fb" example application that will OLED screen on the i2c bus. It contains a "fb" example application that will
draw some rectangles on the screen. It also initializes the external memories. draw some rectangles on the screen. It also initializes the external memories.
3_updates: This configuration contains the full bootloader and an application This configuration contains the full bootloader and an application
that can receive a software update from the serial console, then write it to that can receive a software update from the serial console, then write it to
the bootloader partition, then reboot. After the reboot, the bootloader will the bootloader partition, then reboot. After the reboot, the bootloader will
check the validity of the contents in the external flash, and if an update is check the validity of the contents in the external flash, and if an update is
...@@ -27,15 +27,54 @@ control to it. You can use the hn70ap_makeupdate utility to build an updater ...@@ -27,15 +27,54 @@ control to it. You can use the hn70ap_makeupdate utility to build an updater
image to be sent to the board. You can use the hn70ap_serialupdate utility image to be sent to the board. You can use the hn70ap_serialupdate utility
to transfer the update to the board. to transfer the update to the board.
4_ethernet: This configuration will attempt to initialize the external PHY and 3_ethernet: This configuration will attempt to initialize the external PHY and
internal MAC. Then a daemon is started in the background to manage link up/down internal MAC. Then a daemon is started in the background to manage link up/down
events, and start a DHCP request when the link is up. events, and start a DHCP request when the link is up.
5_radios: This configuration will attempt to detect and initialize radio modules 4_auxradio: This configuration will attempt to detect and initialize the
connected to the board. It requires a specific branch of the NuttX code that auxiliary radio module connected to the board. It requires a specific branch
contains the proper radio driver. More informations about that will be added in of the NuttX code that contains the proper radio driver, found at:
the future.
https://bitbucket.com/slorquet/nuttx/branches/radio
This branch contains development code for the si4463 driver. For the moment
a canned config generated by SiLabs WDS is used, but the goal is to reverse
engineer this tool and allow the user to configure the radio at runtime.
Once development is finished, this driver will be added to the official NuttX
tree, but this event is not expected to happen soon.
Other configurations assume a fully functional board, and are made for real Other configurations assume a fully functional board, and are made for real
hn70ap applications, eg router, access point, freedv hotspot. hn70ap applications, eg router, access point, freedv hotspot.
They will be defined later. They will be defined later.
full: This is the latest configuration. It contains code to initialize all
peripherals and boots the hn70ap system daemon that will mount the flash file
system, initialize EEPROM settings, then start the shell.
beacon: This configuration initializes the aux radio and does not have
ethernet enabled. At boot, the beacon app is autostarted, and the code sends
regular data packet on 435 MHz. This is currently used on a secondary board
to test packet reception on my main prototype board.
Applications
beacon: A radio beacon that sends data on the air, until the board is stopped.
Future improvements will start a background thread and leave the shell available
so the beacon can be stopped.
config: This tool can be user to manipulate the contents of the configuration
EEPROM. You can list and change settings.
update: A firmware updater that is able to download a new firmware image in the
external flash. Download can be made via a serial port (via the console) or via
tftp (this is faster). Future improvements will support the use of LZF
compression to speed up the data transfer.
sysdaemon: This is the main hn70ap application. It is started on boot in most
useful configuration. The tool initializes some executive framework that will
- init and read the configuration settings in the EEPROM
- mount the external flash SMART filesystem
- start a network monitor to detect cable insertion/removal events, and start
DHCP operations (if enabled) right after the cable is detected.
# Automatically generated file; DO NOT EDIT.
# Nuttx/ Configuration
# Build Setup
CONFIG_EXPERIMENTAL=y
# CONFIG_DEFAULT_SMALL is not set
CONFIG_HOST_LINUX=y
# CONFIG_HOST_OSX is not set
# CONFIG_HOST_WINDOWS is not set
# CONFIG_HOST_OTHER is not set
# Build Configuration
CONFIG_APPS_DIR="../apps"
CONFIG_BUILD_FLAT=y
# CONFIG_BUILD_2PASS is not set
# Binary Output Formats
# CONFIG_RRLOAD_BINARY is not set
# CONFIG_INTELHEX_BINARY is not set
# CONFIG_MOTOROLA_SREC is not set
# CONFIG_RAW_BINARY is not set
# CONFIG_UBOOT_UIMAGE is not set
# CONFIG_DFU_BINARY is not set
# Customize Header Files
# CONFIG_ARCH_STDINT_H is not set
# CONFIG_ARCH_STDBOOL_H is not set
# CONFIG_ARCH_MATH_H is not set
# CONFIG_ARCH_FLOAT_H is not set
# CONFIG_ARCH_STDARG_H is not set
# CONFIG_ARCH_DEBUG_H is not set
# Debug Options
CONFIG_DEBUG_ALERT=y
CONFIG_DEBUG_FEATURES=y
# Debug SYSLOG Output Controls
CONFIG_DEBUG_ERROR=y
CONFIG_DEBUG_WARN=y
CONFIG_DEBUG_INFO=y
CONFIG_DEBUG_ASSERTIONS=y
# Subsystem Debug Options
# CONFIG_DEBUG_BINFMT is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_DEBUG_GRAPHICS is not set
# CONFIG_DEBUG_LIB is not set
# CONFIG_DEBUG_MM is not set
# CONFIG_DEBUG_NET is not set
# CONFIG_DEBUG_POWER is not set
# CONFIG_DEBUG_WIRELESS is not set
# CONFIG_DEBUG_SCHED is not set
# OS Function Debug Options
# CONFIG_DEBUG_DMA is not set
# CONFIG_DEBUG_IRQ is not set
# Driver Debug Options
# CONFIG_DEBUG_LCD is not set
# CONFIG_DEBUG_LEDS is not set
# CONFIG_DEBUG_GPIO is not set
# CONFIG_DEBUG_I2C is not set
# CONFIG_DEBUG_SPI is not set
# CONFIG_DEBUG_TIMER is not set
CONFIG_ARCH_HAVE_STACKCHECK=y
# CONFIG_STACK_COLORATION is not set
CONFIG_ARCH_HAVE_HEAPCHECK=y
# CONFIG_HEAP_COLORATION is not set
CONFIG_DEBUG_SYMBOLS=y
CONFIG_ARCH_HAVE_CUSTOMOPT=y
CONFIG_DEBUG_NOOPT=y
# CONFIG_DEBUG_CUSTOMOPT is not set
# CONFIG_DEBUG_FULLOPT is not set
# System Type
CONFIG_ARCH_ARM=y
# CONFIG_ARCH_AVR is not set
# CONFIG_ARCH_HC is not set
# CONFIG_ARCH_MIPS is not set
# CONFIG_ARCH_MISOC is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_RISCV is not set
# CONFIG_ARCH_SIM is not set
# CONFIG_ARCH_X86 is not set
# CONFIG_ARCH_XTENSA is not set
# CONFIG_ARCH_Z16 is not set
# CONFIG_ARCH_Z80 is not set
CONFIG_ARCH="arm"
# ARM Options
# CONFIG_ARCH_CHIP_A1X is not set
# CONFIG_ARCH_CHIP_BCM2708 is not set
# CONFIG_ARCH_CHIP_C5471 is not set
# CONFIG_ARCH_CHIP_DM320 is not set
# CONFIG_ARCH_CHIP_EFM32 is not set
# CONFIG_ARCH_CHIP_IMX1 is not set
# CONFIG_ARCH_CHIP_IMX6 is not set
# CONFIG_ARCH_CHIP_KINETIS is not set
# CONFIG_ARCH_CHIP_KL is not set
# CONFIG_ARCH_CHIP_LC823450 is not set
# CONFIG_ARCH_CHIP_LM is not set
# CONFIG_ARCH_CHIP_LPC11XX is not set
# CONFIG_ARCH_CHIP_LPC17XX is not set
# CONFIG_ARCH_CHIP_LPC214X is not set
# CONFIG_ARCH_CHIP_LPC2378 is not set
# CONFIG_ARCH_CHIP_LPC31XX is not set
# CONFIG_ARCH_CHIP_LPC43XX is not set
# CONFIG_ARCH_CHIP_LPC54XX is not set
# CONFIG_ARCH_CHIP_MOXART is not set
# CONFIG_ARCH_CHIP_NUC1XX is not set
# CONFIG_ARCH_CHIP_SAMA5 is not set
# CONFIG_ARCH_CHIP_SAMD is not set
# CONFIG_ARCH_CHIP_SAML is not set
# CONFIG_ARCH_CHIP_SAM34 is not set
# CONFIG_ARCH_CHIP_SAMV7 is not set
CONFIG_ARCH_CHIP_STM32=y
# CONFIG_ARCH_CHIP_STM32F0 is not set
# CONFIG_ARCH_CHIP_STM32F7 is not set
# CONFIG_ARCH_CHIP_STM32L4 is not set
# CONFIG_ARCH_CHIP_STR71X is not set
# CONFIG_ARCH_CHIP_TMS570 is not set
# CONFIG_ARCH_CHIP_TIVA is not set
# CONFIG_ARCH_CHIP_XMC4 is not set
# CONFIG_ARCH_ARM7TDMI is not set
# CONFIG_ARCH_ARM920T is not set
# CONFIG_ARCH_ARM926EJS is not set
# CONFIG_ARCH_ARM1136J is not set
# CONFIG_ARCH_ARM1156T2 is not set
# CONFIG_ARCH_ARM1176JZ is not set
# CONFIG_ARCH_CORTEXM0 is not set
# CONFIG_ARCH_CORTEXM23 is not set
# CONFIG_ARCH_CORTEXM3 is not set
# CONFIG_ARCH_CORTEXM33 is not set
CONFIG_ARCH_CORTEXM4=y
# CONFIG_ARCH_CORTEXM7 is not set
# CONFIG_ARCH_CORTEXA5 is not set
# CONFIG_ARCH_CORTEXA8 is not set
# CONFIG_ARCH_CORTEXA9 is not set
# CONFIG_ARCH_CORTEXR4 is not set
# CONFIG_ARCH_CORTEXR4F is not set
# CONFIG_ARCH_CORTEXR5 is not set
# CONFIG_ARCH_CORTEXR5F is not set
# CONFIG_ARCH_CORTEXR7 is not set
# CONFIG_ARCH_CORTEXR7F is not set
CONFIG_ARCH_FAMILY="armv7-m"
CONFIG_ARCH_CHIP="stm32"
# CONFIG_ARMV7M_USEBASEPRI is not set
CONFIG_ARCH_HAVE_CMNVECTOR=y
# CONFIG_ARMV7M_CMNVECTOR is not set
# CONFIG_ARMV7M_LAZYFPU is not set
CONFIG_ARCH_HAVE_FPU=y
# CONFIG_ARCH_HAVE_DPFPU is not set
# CONFIG_ARCH_FPU is not set
# CONFIG_ARCH_HAVE_TRUSTZONE is not set
CONFIG_ARM_HAVE_MPU_UNIFIED=y
# CONFIG_ARM_MPU is not set
# CONFIG_DEBUG_HARDFAULT is not set
# ARMV7M Configuration Options
# CONFIG_ARMV7M_HAVE_ICACHE is not set
# CONFIG_ARMV7M_HAVE_DCACHE is not set
# CONFIG_ARMV7M_HAVE_ITCM is not set
# CONFIG_ARMV7M_HAVE_DTCM is not set
# CONFIG_ARMV7M_TOOLCHAIN_IARL is not set
# CONFIG_ARMV7M_TOOLCHAIN_BUILDROOT is not set
# CONFIG_ARMV7M_TOOLCHAIN_CODEREDL is not set
# CONFIG_ARMV7M_TOOLCHAIN_CODESOURCERYL is not set
CONFIG_ARMV7M_TOOLCHAIN_GNU_EABIL=y
# CONFIG_ARMV7M_TOOLCHAIN_CLANGL is not set
CONFIG_ARMV7M_HAVE_STACKCHECK=y
# CONFIG_ARMV7M_STACKCHECK is not set
# CONFIG_ARMV7M_ITMSYSLOG is not set
# STM32 Configuration Options
# CONFIG_ARCH_CHIP_STM32L151C6 is not set
# CONFIG_ARCH_CHIP_STM32L151C8 is not set
# CONFIG_ARCH_CHIP_STM32L151CB is not set
# CONFIG_ARCH_CHIP_STM32L151R6 is not set
# CONFIG_ARCH_CHIP_STM32L151R8 is not set
# CONFIG_ARCH_CHIP_STM32L151RB is not set
# CONFIG_ARCH_CHIP_STM32L151V6 is not set
# CONFIG_ARCH_CHIP_STM32L151V8 is not set
# CONFIG_ARCH_CHIP_STM32L151VB is not set
# CONFIG_ARCH_CHIP_STM32L152C6 is not set
# CONFIG_ARCH_CHIP_STM32L152C8 is not set
# CONFIG_ARCH_CHIP_STM32L152CB is not set
# CONFIG_ARCH_CHIP_STM32L152R6 is not set
# CONFIG_ARCH_CHIP_STM32L152R8 is not set
# CONFIG_ARCH_CHIP_STM32L152RB is not set
# CONFIG_ARCH_CHIP_STM32L152V6 is not set
# CONFIG_ARCH_CHIP_STM32L152V8 is not set
# CONFIG_ARCH_CHIP_STM32L152VB is not set
# CONFIG_ARCH_CHIP_STM32L152CC is not set
# CONFIG_ARCH_CHIP_STM32L152RC is not set
# CONFIG_ARCH_CHIP_STM32L152VC is not set
# CONFIG_ARCH_CHIP_STM32L162ZD is not set
# CONFIG_ARCH_CHIP_STM32L162VE is not set
# CONFIG_ARCH_CHIP_STM32F100C8 is not set
# CONFIG_ARCH_CHIP_STM32F100CB is not set
# CONFIG_ARCH_CHIP_STM32F100R8 is not set
# CONFIG_ARCH_CHIP_STM32F100RB is not set
# CONFIG_ARCH_CHIP_STM32F100RC is not set
# CONFIG_ARCH_CHIP_STM32F100RD is not set
# CONFIG_ARCH_CHIP_STM32F100RE is not set
# CONFIG_ARCH_CHIP_STM32F100V8 is not set
# CONFIG_ARCH_CHIP_STM32F100VB is not set
# CONFIG_ARCH_CHIP_STM32F100VC is not set
# CONFIG_ARCH_CHIP_STM32F100VD is not set
# CONFIG_ARCH_CHIP_STM32F100VE is not set
# CONFIG_ARCH_CHIP_STM32F102CB is not set
# CONFIG_ARCH_CHIP_STM32F103T8 is not set
# CONFIG_ARCH_CHIP_STM32F103TB is not set
# CONFIG_ARCH_CHIP_STM32F103C4 is not set
# CONFIG_ARCH_CHIP_STM32F103C8 is not set
# CONFIG_ARCH_CHIP_STM32F103CB is not set
# CONFIG_ARCH_CHIP_STM32F103R8 is not set
# CONFIG_ARCH_CHIP_STM32F103RB is not set
# CONFIG_ARCH_CHIP_STM32F103RC is not set
# CONFIG_ARCH_CHIP_STM32F103RD is not set
# CONFIG_ARCH_CHIP_STM32F103RE is not set
# CONFIG_ARCH_CHIP_STM32F103RG is not set
# CONFIG_ARCH_CHIP_STM32F103V8 is not set
# CONFIG_ARCH_CHIP_STM32F103VB is not set
# CONFIG_ARCH_CHIP_STM32F103VC is not set
# CONFIG_ARCH_CHIP_STM32F103VE is not set
# CONFIG_ARCH_CHIP_STM32F103ZE is not set
# CONFIG_ARCH_CHIP_STM32F105VB is not set
# CONFIG_ARCH_CHIP_STM32F105RB is not set
# CONFIG_ARCH_CHIP_STM32F107VC is not set
# CONFIG_ARCH_CHIP_STM32F205RG is not set
# CONFIG_ARCH_CHIP_STM32F207IG is not set
# CONFIG_ARCH_CHIP_STM32F207ZE is not set
# CONFIG_ARCH_CHIP_STM32F302K6 is not set
# CONFIG_ARCH_CHIP_STM32F302K8 is not set
# CONFIG_ARCH_CHIP_STM32F302CB is not set
# CONFIG_ARCH_CHIP_STM32F302CC is not set
# CONFIG_ARCH_CHIP_STM32F302RB is not set
# CONFIG_ARCH_CHIP_STM32F302RC is not set
# CONFIG_ARCH_CHIP_STM32F302VB is not set
# CONFIG_ARCH_CHIP_STM32F302VC is not set
# CONFIG_ARCH_CHIP_STM32F303K6 is not set
# CONFIG_ARCH_CHIP_STM32F303K8 is not set
# CONFIG_ARCH_CHIP_STM32F303C6 is not set
# CONFIG_ARCH_CHIP_STM32F303C8 is not set
# CONFIG_ARCH_CHIP_STM32F303CB is not set
# CONFIG_ARCH_CHIP_STM32F303CC is not set
# CONFIG_ARCH_CHIP_STM32F303RB is not set
# CONFIG_ARCH_CHIP_STM32F303RC is not set
# CONFIG_ARCH_CHIP_STM32F303RD is not set
# CONFIG_ARCH_CHIP_STM32F303RE is not set
# CONFIG_ARCH_CHIP_STM32F303VB is not set
# CONFIG_ARCH_CHIP_STM32F303VC is not set
# CONFIG_ARCH_CHIP_STM32F334K4 is not set
# CONFIG_ARCH_CHIP_STM32F334K6 is not set
# CONFIG_ARCH_CHIP_STM32F334K8 is not set
# CONFIG_ARCH_CHIP_STM32F334C4 is not set
# CONFIG_ARCH_CHIP_STM32F334C6 is not set
# CONFIG_ARCH_CHIP_STM32F334C8 is not set
# CONFIG_ARCH_CHIP_STM32F334R4 is not set
# CONFIG_ARCH_CHIP_STM32F334R6 is not set
# CONFIG_ARCH_CHIP_STM32F334R8 is not set
# CONFIG_ARCH_CHIP_STM32F372C8 is not set
# CONFIG_ARCH_CHIP_STM32F372R8 is not set
# CONFIG_ARCH_CHIP_STM32F372V8 is not set
# CONFIG_ARCH_CHIP_STM32F372CB is not set
# CONFIG_ARCH_CHIP_STM32F372RB is not set
# CONFIG_ARCH_CHIP_STM32F372VB is not set
# CONFIG_ARCH_CHIP_STM32F372CC is not set
# CONFIG_ARCH_CHIP_STM32F372RC is not set
# CONFIG_ARCH_CHIP_STM32F372VC is not set
# CONFIG_ARCH_CHIP_STM32F373C8 is not set
# CONFIG_ARCH_CHIP_STM32F373R8 is not set
# CONFIG_ARCH_CHIP_STM32F373V8 is not set
# CONFIG_ARCH_CHIP_STM32F373CB is not set
# CONFIG_ARCH_CHIP_STM32F373RB is not set
# CONFIG_ARCH_CHIP_STM32F373VB is not set
# CONFIG_ARCH_CHIP_STM32F373CC is not set
# CONFIG_ARCH_CHIP_STM32F373RC is not set
# CONFIG_ARCH_CHIP_STM32F373VC is not set
# CONFIG_ARCH_CHIP_STM32F401CB is not set
# CONFIG_ARCH_CHIP_STM32F401RB is not set
# CONFIG_ARCH_CHIP_STM32F401VB is not set
# CONFIG_ARCH_CHIP_STM32F401CC is not set
# CONFIG_ARCH_CHIP_STM32F401RC is not set
# CONFIG_ARCH_CHIP_STM32F401VC is not set
# CONFIG_ARCH_CHIP_STM32F401CD is not set
# CONFIG_ARCH_CHIP_STM32F401RD is not set
# CONFIG_ARCH_CHIP_STM32F401VD is not set
# CONFIG_ARCH_CHIP_STM32F401CE is not set
# CONFIG_ARCH_CHIP_STM32F401RE is not set
# CONFIG_ARCH_CHIP_STM32F401VE is not set
# CONFIG_ARCH_CHIP_STM32F410RB is not set
# CONFIG_ARCH_CHIP_STM32F411RE is not set
# CONFIG_ARCH_CHIP_STM32F411VE is not set
# CONFIG_ARCH_CHIP_STM32F405RG is not set
# CONFIG_ARCH_CHIP_STM32F405VG is not set
# CONFIG_ARCH_CHIP_STM32F405ZG is not set
# CONFIG_ARCH_CHIP_STM32F407VE is not set
# CONFIG_ARCH_CHIP_STM32F407VG is not set
# CONFIG_ARCH_CHIP_STM32F407ZE is not set
# CONFIG_ARCH_CHIP_STM32F407ZG is not set
# CONFIG_ARCH_CHIP_STM32F407IE is not set
# CONFIG_ARCH_CHIP_STM32F407IG is not set
# CONFIG_ARCH_CHIP_STM32F427V is not set
# CONFIG_ARCH_CHIP_STM32F427Z is not set
# CONFIG_ARCH_CHIP_STM32F427I is not set
# CONFIG_ARCH_CHIP_STM32F429V is not set
CONFIG_ARCH_CHIP_STM32F429Z=y
# CONFIG_ARCH_CHIP_STM32F429I is not set
# CONFIG_ARCH_CHIP_STM32F429B is not set
# CONFIG_ARCH_CHIP_STM32F429N is not set
# CONFIG_ARCH_CHIP_STM32F446M is not set
# CONFIG_ARCH_CHIP_STM32F446R is not set
# CONFIG_ARCH_CHIP_STM32F446V is not set
# CONFIG_ARCH_CHIP_STM32F446Z is not set
# CONFIG_ARCH_CHIP_STM32F469A is not set
# CONFIG_ARCH_CHIP_STM32F469I is not set
# CONFIG_ARCH_CHIP_STM32F469B is not set
# CONFIG_ARCH_CHIP_STM32F469N is not set
CONFIG_STM32_FLASH_CONFIG_DEFAULT=y
# CONFIG_STM32_FLASH_CONFIG_4 is not set
# CONFIG_STM32_FLASH_CONFIG_6 is not set
# CONFIG_STM32_FLASH_CONFIG_8 is not set
# CONFIG_STM32_FLASH_CONFIG_B is not set
# CONFIG_STM32_FLASH_CONFIG_C is not set
# CONFIG_STM32_FLASH_CONFIG_D is not set
# CONFIG_STM32_FLASH_CONFIG_E is not set
# CONFIG_STM32_FLASH_CONFIG_F is not set
# CONFIG_STM32_FLASH_CONFIG_G is not set
# CONFIG_STM32_FLASH_CONFIG_I is not set
# CONFIG_STM32_STM32L15XX is not set
# CONFIG_STM32_ENERGYLITE is not set
# CONFIG_STM32_STM32F10XX is not set
# CONFIG_STM32_VALUELINE is not set
# CONFIG_STM32_CONNECTIVITYLINE is not set
# CONFIG_STM32_PERFORMANCELINE is not set
# CONFIG_STM32_USBACCESSLINE is not set
# CONFIG_STM32_HIGHDENSITY is not set
# CONFIG_STM32_MEDIUMDENSITY is not set
# CONFIG_STM32_LOWDENSITY is not set
# CONFIG_STM32_STM32F20XX is not set
# CONFIG_STM32_STM32F205 is not set
# CONFIG_STM32_STM32F207 is not set
# CONFIG_STM32_STM32F30XX is not set
# CONFIG_STM32_STM32F302 is not set
# CONFIG_STM32_STM32F303 is not set
# CONFIG_STM32_STM32F33XX is not set
# CONFIG_STM32_STM32F37XX is not set
CONFIG_STM32_STM32F4XXX=y
# CONFIG_STM32_STM32F401xBC is not set
# CONFIG_STM32_STM32F401xDE is not set
# CONFIG_STM32_STM32F401 is not set
# CONFIG_STM32_STM32F410 is not set
# CONFIG_STM32_STM32F411 is not set
# CONFIG_STM32_STM32F405 is not set
# CONFIG_STM32_STM32F407 is not set
# CONFIG_STM32_STM32F427 is not set
CONFIG_STM32_STM32F429=y
# CONFIG_STM32_STM32F446 is not set
# CONFIG_STM32_STM32F469 is not set
# CONFIG_STM32_DFU is not set
# STM32 Peripheral Support
CONFIG_STM32_HAVE_CCM=y
# CONFIG_STM32_HAVE_USBDEV is not set
CONFIG_STM32_HAVE_OTGFS=y
CONFIG_STM32_HAVE_FSMC=y
# CONFIG_STM32_HAVE_HRTIM1 is not set
CONFIG_STM32_HAVE_LTDC=y
CONFIG_STM32_HAVE_USART3=y
CONFIG_STM32_HAVE_UART4=y
CONFIG_STM32_HAVE_UART5=y
CONFIG_STM32_HAVE_USART6=y
CONFIG_STM32_HAVE_UART7=y
CONFIG_STM32_HAVE_UART8=y
CONFIG_STM32_HAVE_TIM1=y
# CONFIG_STM32_HAVE_TIM2 is not set
CONFIG_STM32_HAVE_TIM3=y
CONFIG_STM32_HAVE_TIM4=y
CONFIG_STM32_HAVE_TIM5=y
CONFIG_STM32_HAVE_TIM6=y
CONFIG_STM32_HAVE_TIM7=y
CONFIG_STM32_HAVE_TIM8=y
CONFIG_STM32_HAVE_TIM9=y
CONFIG_STM32_HAVE_TIM10=y
CONFIG_STM32_HAVE_TIM11=y
CONFIG_STM32_HAVE_TIM12=y
CONFIG_STM32_HAVE_TIM13=y
CONFIG_STM32_HAVE_TIM14=y
# CONFIG_STM32_HAVE_TIM15 is not set
# CONFIG_STM32_HAVE_TIM16 is not set
# CONFIG_STM32_HAVE_TIM17 is not set
CONFIG_STM32_HAVE_ADC2=y
CONFIG_STM32_HAVE_ADC3=y
# CONFIG_STM32_HAVE_ADC4 is not set
# CONFIG_STM32_HAVE_ADC1_DMA is not set
# CONFIG_STM32_HAVE_ADC2_DMA is not set
# CONFIG_STM32_HAVE_ADC3_DMA is not set
# CONFIG_STM32_HAVE_ADC4_DMA is not set
# CONFIG_STM32_HAVE_SDADC1 is not set
# CONFIG_STM32_HAVE_SDADC2 is not set
# CONFIG_STM32_HAVE_SDADC3 is not set
# CONFIG_STM32_HAVE_SDADC1_DMA is not set
# CONFIG_STM32_HAVE_SDADC2_DMA is not set
# CONFIG_STM32_HAVE_SDADC3_DMA is not set
CONFIG_STM32_HAVE_CAN1=y
CONFIG_STM32_HAVE_CAN2=y
# CONFIG_STM32_HAVE_COMP1 is not set
# CONFIG_STM32_HAVE_COMP2 is not set
# CONFIG_STM32_HAVE_COMP3 is not set
# CONFIG_STM32_HAVE_COMP4 is not set
# CONFIG_STM32_HAVE_COMP5 is not set
# CONFIG_STM32_HAVE_COMP6 is not set
# CONFIG_STM32_HAVE_COMP7 is not set
CONFIG_STM32_HAVE_DAC1=y
CONFIG_STM32_HAVE_DAC2=y
CONFIG_STM32_HAVE_RNG=y
CONFIG_STM32_HAVE_ETHMAC=y
CONFIG_STM32_HAVE_I2C2=y
CONFIG_STM32_HAVE_I2C3=y
CONFIG_STM32_HAVE_SPI2=y
CONFIG_STM32_HAVE_SPI3=y
CONFIG_STM32_HAVE_I2S3=y
CONFIG_STM32_HAVE_SPI4=y
CONFIG_STM32_HAVE_SPI5=y
CONFIG_STM32_HAVE_SPI6=y
# CONFIG_STM32_HAVE_SAIPLL is not set
# CONFIG_STM32_HAVE_I2SPLL is not set
# CONFIG_STM32_HAVE_OPAMP1 is not set
# CONFIG_STM32_HAVE_OPAMP2 is not set
# CONFIG_STM32_HAVE_OPAMP3 is not set
# CONFIG_STM32_HAVE_OPAMP4 is not set
# CONFIG_STM32_ADC1 is not set
# CONFIG_STM32_ADC2 is not set
# CONFIG_STM32_ADC3 is not set
# CONFIG_STM32_BKPSRAM is not set
# CONFIG_STM32_CAN1 is not set
# CONFIG_STM32_CAN2 is not set
# CONFIG_STM32_CCMDATARAM is not set
# CONFIG_STM32_CRC is not set
# CONFIG_STM32_CRYP is not set
CONFIG_STM32_DMA1=y
CONFIG_STM32_DMA2=y
# CONFIG_STM32_DAC1 is not set
# CONFIG_STM32_DAC2 is not set
# CONFIG_STM32_DCMI is not set
# CONFIG_STM32_ETHMAC is not set
# CONFIG_STM32_FSMC is not set
# CONFIG_STM32_HASH is not set
# CONFIG_HRTIM is not set
# CONFIG_STM32_I2C1 is not set
# CONFIG_STM32_I2C2 is not set
CONFIG_STM32_I2C3=y
# CONFIG_STM32_LTDC is not set
# CONFIG_STM32_DMA2D is not set
# CONFIG_STM32_OPAMP is not set
# CONFIG_STM32_OTGFS is not set
# CONFIG_STM32_OTGHS is not set
CONFIG_STM32_PWR=y
# CONFIG_STM32_RNG is not set
# CONFIG_STM32_SDIO is not set
# CONFIG_STM32_SPI1 is not set
CONFIG_STM32_SPI2=y
# CONFIG_STM32_SPI3 is not set
# CONFIG_STM32_I2S3 is not set
CONFIG_STM32_SPI4=y
# CONFIG_STM32_SPI5 is not set
# CONFIG_STM32_SPI6 is not set
CONFIG_STM32_SYSCFG=y
# CONFIG_STM32_TIM1 is not set
# CONFIG_STM32_TIM2 is not set
# CONFIG_STM32_TIM3 is not set
# CONFIG_STM32_TIM4 is not set
# CONFIG_STM32_TIM5 is not set
# CONFIG_STM32_TIM6 is not set
# CONFIG_STM32_TIM7 is not set
# CONFIG_STM32_TIM8 is not set
# CONFIG_STM32_TIM9 is not set
# CONFIG_STM32_TIM10 is not set
# CONFIG_STM32_TIM11 is not set
# CONFIG_STM32_TIM12 is not set
# CONFIG_STM32_TIM13 is not set
# CONFIG_STM32_TIM14 is not set
# CONFIG_STM32_USART1 is not set
# CONFIG_STM32_USART2 is not set
# CONFIG_STM32_USART3 is not set
CONFIG_STM32_UART4=y
# CONFIG_STM32_UART5 is not set
# CONFIG_STM32_USART6 is not set
# CONFIG_STM32_UART7 is not set
# CONFIG_STM32_UART8 is not set
# CONFIG_STM32_IWDG is not set
# CONFIG_STM32_WWDG is not set
CONFIG_STM32_SPI=y
CONFIG_STM32_I2C=y
# CONFIG_STM32_NOEXT_VECTORS is not set
# Alternate Pin Mapping
# CONFIG_STM32_FLASH_PREFETCH is not set
# CONFIG_STM32_FLASH_WORKAROUND_DATA_CACHE_CORRUPTION_ON_RWW is not set
# CONFIG_STM32_JTAG_DISABLE is not set
CONFIG_STM32_JTAG_FULL_ENABLE=y
# CONFIG_STM32_JTAG_NOJNTRST_ENABLE is not set
# CONFIG_STM32_JTAG_SW_ENABLE is not set
CONFIG_STM32_DISABLE_IDLE_SLEEP_DURING_DEBUG=y
# CONFIG_STM32_FORCEPOWER is not set
# CONFIG_ARCH_BOARD_STM32_CUSTOM_CLOCKCONFIG is not set
CONFIG_STM32_CCMEXCLUDE=y
# CONFIG_STM32_DMACAPABLE is not set
# Timer Configuration
# CONFIG_STM32_ONESHOT is not set
# CONFIG_STM32_FREERUN is not set
# CONFIG_STM32_TIM1_CAP is not set
# CONFIG_STM32_TIM3_CAP is not set
# CONFIG_STM32_TIM4_CAP is not set
# CONFIG_STM32_TIM5_CAP is not set
# CONFIG_STM32_TIM8_CAP is not set
# CONFIG_STM32_TIM9_CAP is not set
# CONFIG_STM32_TIM10_CAP is not set
# CONFIG_STM32_TIM11_CAP is not set
# CONFIG_STM32_TIM12_CAP is not set
# CONFIG_STM32_TIM13_CAP is not set
# CONFIG_STM32_TIM14_CAP is not set
# HRTIM Configuration
CONFIG_STM32_USART=y
CONFIG_STM32_SERIALDRIVER=y
# U[S]ART Configuration
# U[S]ART Device Configuration
CONFIG_STM32_UART4_SERIALDRIVER=y
# CONFIG_STM32_UART4_1WIREDRIVER is not set
# CONFIG_UART4_RS485 is not set
# CONFIG_UART4_RXDMA is not set
# Serial Driver Configuration
# CONFIG_SERIAL_DISABLE_REORDERING is not set
# CONFIG_STM32_FLOWCONTROL_BROKEN is not set
# CONFIG_STM32_USART_BREAKS is not set
# CONFIG_STM32_USART_SINGLEWIRE is not set
# SPI Configuration
# CONFIG_STM32_SPI_INTERRUPTS is not set
CONFIG_STM32_SPI_DMA=y
# I2C Configuration
# CONFIG_STM32_I2C_ALT is not set
# CONFIG_STM32_I2C_DYNTIMEO is not set
CONFIG_STM32_I2CTIMEOSEC=0
CONFIG_STM32_I2CTIMEOMS=500
CONFIG_STM32_I2CTIMEOTICKS=500
# CONFIG_STM32_I2C_DUTY16_9 is not set
# CONFIG_STM32_I2C_DMA is not set
# CONFIG_STM32_HAVE_RTC_COUNTER is not set
# CONFIG_STM32_HAVE_RTC_SUBSECONDS is not set
# USB FS Host Configuration
# USB HS Host Configuration
# USB Host Debug Configuration
# USB Device Configuration
# CONFIG_ARCH_TOOLCHAIN_IAR is not set
CONFIG_ARCH_TOOLCHAIN_GNU=y
# Architecture Options
# CONFIG_ARCH_NOINTC is not set
# CONFIG_ARCH_VECNOTIRQ is not set
CONFIG_ARCH_DMA=y
CONFIG_ARCH_HAVE_IRQPRIO=y
# CONFIG_ARCH_L2CACHE is not set
# CONFIG_ARCH_HAVE_COHERENT_DCACHE is not set
# CONFIG_ARCH_HAVE_ADDRENV is not set
# CONFIG_ARCH_NEED_ADDRENV_MAPPING is not set
# CONFIG_ARCH_HAVE_MULTICPU is not set
CONFIG_ARCH_HAVE_VFORK=y
# CONFIG_ARCH_HAVE_MMU is not set
CONFIG_ARCH_HAVE_MPU=y
# CONFIG_ARCH_NAND_HWECC is not set
# CONFIG_ARCH_HAVE_EXTCLK is not set
# CONFIG_ARCH_HAVE_POWEROFF is not set
CONFIG_ARCH_HAVE_PROGMEM=y
CONFIG_ARCH_HAVE_RESET=y
CONFIG_ARCH_HAVE_FETCHADD=y
# CONFIG_ARCH_HAVE_RTC_SUBSECONDS is not set
# CONFIG_ARCH_GLOBAL_IRQDISABLE is not set
# CONFIG_ARCH_USE_MPU is not set
# CONFIG_ARCH_IRQPRIO is not set
CONFIG_ARCH_STACKDUMP=y
# CONFIG_ENDIAN_BIG is not set
# CONFIG_ARCH_IDLE_CUSTOM is not set
# CONFIG_ARCH_HAVE_RAMFUNCS is not set
CONFIG_ARCH_HAVE_RAMVECTORS=y
# CONFIG_ARCH_RAMVECTORS is not set
# CONFIG_ARCH_MINIMAL_VECTORTABLE is not set
# Board Settings
CONFIG_BOARD_LOOPSPERMSEC=16717
# CONFIG_ARCH_CALIBRATION is not set
# Interrupt options
CONFIG_ARCH_HAVE_INTERRUPTSTACK=y
CONFIG_ARCH_INTERRUPTSTACK=0
CONFIG_ARCH_HAVE_HIPRI_INTERRUPT=y
# CONFIG_ARCH_HIPRI_INTERRUPT is not set
# Boot options
# CONFIG_BOOT_RUNFROMEXTSRAM is not set
CONFIG_BOOT_RUNFROMFLASH=y
# CONFIG_BOOT_RUNFROMISRAM is not set
# CONFIG_BOOT_RUNFROMSDRAM is not set
# CONFIG_BOOT_COPYTORAM is not set
# Boot Memory Configuration
CONFIG_RAM_START=0x20000000
CONFIG_RAM_SIZE=114688
# CONFIG_ARCH_HAVE_SDRAM is not set
# Board Selection
# CONFIG_ARCH_BOARD_STM32F429I_DISCO is not set
CONFIG_ARCH_BOARD_CUSTOM=y
# Custom Board Configuration
CONFIG_ARCH_BOARD_CUSTOM_NAME="hn70ap"
CONFIG_ARCH_BOARD_CUSTOM_DIR="configs/hn70ap"
CONFIG_ARCH_BOARD_CUSTOM_DIR_RELPATH=y
# CONFIG_BOARD_CUSTOM_LEDS is not set
# CONFIG_BOARD_CUSTOM_BUTTONS is not set
# CONFIG_BOARD_CUSTOM_INTERRUPT is not set
# Common Board Options
CONFIG_ARCH_HAVE_LEDS=y
CONFIG_ARCH_LEDS=y
# Board-Specific Options
# ----- hn70ap board features -----
# CONFIG_HN70AP_HWDEBUG_BLINK is not set
CONFIG_HN70AP_EEPROM=y
CONFIG_HN70AP_SPIFLASH=y
CONFIG_HN70AP_SCREEN=y
# CONFIG_HN70AP_ETHERNET is not set
CONFIG_HN70AP_RADIO=y
# CONFIG_HN70AP_MAINRADIO is not set
CONFIG_HN70AP_AUXRADIO=y
# CONFIG_HN70AP_AUXRADIO_HIGHPOWER is not set
# CONFIG_BOARD_CRASHDUMP is not set
CONFIG_LIB_BOARDCTL=y
CONFIG_BOARDCTL_RESET=y
# CONFIG_BOARDCTL_UNIQUEID is not set
# CONFIG_BOARDCTL_APP_SYMTAB is not set
# CONFIG_BOARDCTL_IOCTL is not set
# RTOS Features
CONFIG_DISABLE_OS_API=y
# CONFIG_DISABLE_POSIX_TIMERS is not set
# CONFIG_DISABLE_PTHREAD is not set
# CONFIG_DISABLE_SIGNALS is not set
# CONFIG_DISABLE_MQUEUE is not set
# CONFIG_DISABLE_ENVIRON is not set
# Clocks and Timers
CONFIG_ARCH_HAVE_TICKLESS=y
# CONFIG_SCHED_TICKLESS is not set
CONFIG_USEC_PER_TICK=10000
# CONFIG_SYSTEM_TIME64 is not set
# CONFIG_CLOCK_MONOTONIC is not set
CONFIG_ARCH_HAVE_TIMEKEEPING=y
# CONFIG_CLOCK_TIMEKEEPING is not set
# CONFIG_JULIAN_TIME is not set
CONFIG_START_YEAR=2011
CONFIG_START_MONTH=12
CONFIG_START_DAY=6
CONFIG_MAX_WDOGPARMS=2
CONFIG_PREALLOC_WDOGS=4
CONFIG_WDOG_INTRESERVE=0
CONFIG_PREALLOC_TIMERS=4
# Tasks and Scheduling
# CONFIG_SPINLOCK is not set
# CONFIG_INIT_NONE is not set
CONFIG_INIT_ENTRYPOINT=y
# CONFIG_INIT_FILEPATH is not set
CONFIG_USER_ENTRYPOINT="beacon_main"
CONFIG_RR_INTERVAL=200
# CONFIG_SCHED_SPORADIC is not set
CONFIG_TASK_NAME_SIZE=0
CONFIG_MAX_TASKS=16
# CONFIG_SCHED_HAVE_PARENT is not set
CONFIG_SCHED_WAITPID=y
# Pthread Options
CONFIG_NPTHREAD_KEYS=4
# CONFIG_PTHREAD_MUTEX_TYPES is not set
CONFIG_PTHREAD_MUTEX_ROBUST=y
# CONFIG_PTHREAD_MUTEX_UNSAFE is not set
# CONFIG_PTHREAD_MUTEX_BOTH is not set
# CONFIG_PTHREAD_CLEANUP is not set
# CONFIG_CANCELLATION_POINTS is not set
# Performance Monitoring
# CONFIG_SCHED_CPULOAD is not set
# CONFIG_SCHED_INSTRUMENTATION is not set
# Files and I/O
CONFIG_DEV_CONSOLE=y
# CONFIG_FDCLONE_DISABLE is not set
# CONFIG_FDCLONE_STDIO is not set
CONFIG_SDCLONE_DISABLE=y
CONFIG_NFILE_DESCRIPTORS=8
CONFIG_NFILE_STREAMS=8
CONFIG_NAME_MAX=32
# CONFIG_PRIORITY_INHERITANCE is not set
# RTOS hooks
CONFIG_BOARD_INITIALIZE=y
CONFIG_BOARD_INITTHREAD=y
CONFIG_BOARD_INITTHREAD_STACKSIZE=2048
CONFIG_BOARD_INITTHREAD_PRIORITY=240
# CONFIG_SCHED_STARTHOOK is not set
# CONFIG_SCHED_ATEXIT is not set
# CONFIG_SCHED_ONEXIT is not set
# CONFIG_SIG_EVTHREAD is not set
# Signal Numbers
CONFIG_SIG_SIGUSR1=1
CONFIG_SIG_SIGUSR2=2
CONFIG_SIG_SIGALARM=3
CONFIG_SIG_SIGCONDTIMEDOUT=16
CONFIG_SIG_SIGWORK=17
# POSIX Message Queue Options
CONFIG_PREALLOC_MQ_MSGS=4
CONFIG_MQ_MAXMSGSIZE=32
# CONFIG_MODULE is not set
# Work queue support
CONFIG_SCHED_WORKQUEUE=y
CONFIG_SCHED_HPWORK=y
CONFIG_SCHED_HPWORKPRIORITY=224
CONFIG_SCHED_HPWORKPERIOD=50000
CONFIG_SCHED_HPWORKSTACKSIZE=2048
# CONFIG_SCHED_LPWORK is not set
# Stack and heap information
CONFIG_IDLETHREAD_STACKSIZE=1024
CONFIG_USERMAIN_STACKSIZE=2048
CONFIG_PTHREAD_STACK_MIN=256
CONFIG_PTHREAD_STACK_DEFAULT=2048
# CONFIG_LIB_SYSCALL is not set
# Device Drivers
# CONFIG_DISABLE_POLL is not set
# CONFIG_DEV_NULL is not set
# CONFIG_DEV_ZERO is not set
# CONFIG_DEV_URANDOM is not set
# CONFIG_DEV_LOOP is not set
# Buffering
# CONFIG_DRVR_WRITEBUFFER is not set
# CONFIG_DRVR_READAHEAD is not set
# CONFIG_RAMDISK is not set
# CONFIG_CAN is not set
# CONFIG_ARCH_HAVE_PWM_PULSECOUNT is not set
# CONFIG_ARCH_HAVE_PWM_MULTICHAN is not set
# CONFIG_PWM is not set
CONFIG_ARCH_HAVE_I2CRESET=y
CONFIG_I2C=y
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_POLLED is not set
# CONFIG_I2C_RESET is not set
# CONFIG_I2C_TRACE is not set
CONFIG_I2C_DRIVER=y
# I2C Multiplexer Support
# CONFIG_I2CMULTIPLEXER_PCA9540BDP is not set
# CONFIG_ARCH_HAVE_SPI_CRCGENERATION is not set
# CONFIG_ARCH_HAVE_SPI_CS_CONTROL is not set
CONFIG_ARCH_HAVE_SPI_BITORDER=y
CONFIG_SPI=y
# CONFIG_SPI_SLAVE is not set
CONFIG_SPI_EXCHANGE=y
# CONFIG_SPI_CMDDATA is not set
# CONFIG_SPI_CALLBACK is not set
# CONFIG_SPI_HWFEATURES is not set
# CONFIG_SPI_BITORDER is not set
# CONFIG_SPI_CS_DELAY_CONTROL is not set
# CONFIG_SPI_DRIVER is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_I2S is not set
# Timer Driver Support
# CONFIG_TIMER is not set
# CONFIG_ONESHOT is not set
# CONFIG_RTC is not set
# CONFIG_WATCHDOG is not set
# CONFIG_TIMERS_CS2100CP is not set
# CONFIG_ANALOG is not set
# CONFIG_DRIVERS_AUDIO is not set
CONFIG_DRIVERS_VIDEO=y
CONFIG_VIDEO_FB=y
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_BCH is not set
# CONFIG_INPUT is not set
# IO Expander/GPIO Support
# CONFIG_IOEXPANDER is not set
# CONFIG_DEV_GPIO is not set
# LCD Driver Support
CONFIG_LCD=y
CONFIG_LCD_PACKEDMSFIRST=y
CONFIG_LCD_UPDATE=y
# Common Graphic LCD Settings
CONFIG_LCD_FRAMEBUFFER=y
# CONFIG_LCD_EXTERNINIT is not set
# LCD driver selection
# CONFIG_LCD_CONSOLE is not set
CONFIG_LCD_NOGETRUN=y
CONFIG_LCD_MAXCONTRAST=255
CONFIG_LCD_MAXPOWER=1
# Graphic LCD Devices
# CONFIG_LCD_P14201 is not set
# CONFIG_LCD_NOKIA6100 is not set
# CONFIG_LCD_MAX7219 is not set
# CONFIG_LCD_MIO283QT2 is not set
# CONFIG_LCD_MIO283QT9A is not set
# CONFIG_LCD_UG9664HSWAG01 is not set
# CONFIG_LCD_SH1106_OLED_132 is not set
CONFIG_LCD_UG2864HSWEG01=y
# CONFIG_LCD_UG2832HSWEG04 is not set
# CONFIG_LCD_DD12864WO4A is not set
# CONFIG_LCD_HILETGO is not set
CONFIG_LCD_SSD1306=y
# CONFIG_LCD_SSD1306_SPI is not set
CONFIG_LCD_SSD1306_I2C=y
CONFIG_SSD1306_I2CADDR=60
CONFIG_SSD1306_I2CFREQ=400000
# CONFIG_LCD_SSD1351 is not set
# CONFIG_LCD_PCD8544 is not set
# CONFIG_LCD_ST7565 is not set
# CONFIG_LCD_ST7567 is not set
# CONFIG_LCD_UG2864AMBAG01 is not set
# CONFIG_LCD_SSD1289 is not set
# CONFIG_LCD_SHARP_MEMLCD is not set
CONFIG_LCD_LANDSCAPE=y
# CONFIG_LCD_PORTRAIT is not set
# CONFIG_LCD_RPORTRAIT is not set
# CONFIG_LCD_RLANDSCAPE is not set
# CONFIG_LCD_ILI9341 is not set
# CONFIG_LCD_RA8875 is not set
# CONFIG_LCD_FT80X is not set
# CONFIG_SLCD is not set
# LED Support
CONFIG_USERLED=y
CONFIG_USERLED_LOWER=y
# CONFIG_LEDS_APA102 is not set
# CONFIG_RGBLED is not set
# CONFIG_PCA9635PW is not set
# CONFIG_NCP5623C is not set
# CONFIG_MMCSD is not set
# CONFIG_MODEM is not set
CONFIG_MTD=y
# MTD Configuration
CONFIG_MTD_PARTITION=y
# CONFIG_MTD_SECT512 is not set
# CONFIG_MTD_BYTE_WRITE is not set
# CONFIG_MTD_PROGMEM is not set
# CONFIG_MTD_CONFIG is not set
# MTD Device Drivers
# CONFIG_MTD_NAND is not set
# CONFIG_RAMMTD is not set
# CONFIG_FILEMTD is not set
# CONFIG_MTD_AT24XX is not set
# CONFIG_MTD_AT25 is not set
# CONFIG_MTD_AT45DB is not set
# CONFIG_MTD_IS25XP is not set
# CONFIG_MTD_M25P is not set
# CONFIG_MTD_MX25L is not set
# CONFIG_MTD_MX35 is not set
# CONFIG_MTD_S25FL1 is not set
# CONFIG_MTD_N25QXXX is not set
# CONFIG_MTD_MX25RXX is not set
CONFIG_MTD_SMART=y
# CONFIG_SMART_DEV_LOOP is not set
CONFIG_MTD_SMART_SECTOR_SIZE=1024
CONFIG_MTD_SMART_WEAR_LEVEL=y
# CONFIG_MTD_SMART_CONVERT_WEAR_FORMAT is not set
# CONFIG_MTD_SMART_ENABLE_CRC is not set
CONFIG_MTD_SMART_MINIMIZE_RAM=y
CONFIG_MTD_SMART_SECTOR_CACHE_SIZE=32
CONFIG_MTD_SMART_SECTOR_PACK_COUNTS=y
# CONFIG_MTD_SMART_SECTOR_ERASE_DEBUG is not set
# CONFIG_MTD_SMART_ALLOC_DEBUG is not set
# CONFIG_MTD_RAMTRON is not set
# CONFIG_MTD_SST25 is not set
# CONFIG_MTD_SST25XX is not set
CONFIG_MTD_SST26=y
CONFIG_SST26_SPIMODE=0
CONFIG_SST26_SPIFREQUENCY=64000000
CONFIG_SST26_MANUFACTURER=0xBF
CONFIG_SST26_MEMORY_TYPE=0x26
# CONFIG_MTD_SST39FV is not set
# CONFIG_MTD_W25 is not set
CONFIG_EEPROM=y
# CONFIG_SPI_EE_25XX is not set
CONFIG_I2C_EE_24XX=y
CONFIG_EE24XX_FREQUENCY=100000
CONFIG_NETDEVICES=y
# General Ethernet MAC Driver Options
# CONFIG_NETDEV_LOOPBACK is not set
# CONFIG_NETDEV_TELNET is not set
# CONFIG_ARCH_HAVE_NETDEV_STATISTICS is not set
# CONFIG_NETDEV_LATEINIT is not set
# CONFIG_NET_DUMPPACKET is not set
# External Ethernet MAC Device Support
# CONFIG_NET_DM90x0 is not set
# CONFIG_ENC28J60 is not set
# CONFIG_ENCX24J600 is not set
# CONFIG_NET_SLIP is not set
# CONFIG_NET_FTMAC100 is not set
# CONFIG_PIPES is not set
# CONFIG_PM is not set
# CONFIG_DRIVERS_POWERLED is not set
# CONFIG_DRIVERS_SMPS is not set
# CONFIG_POWER is not set
# CONFIG_SENSORS is not set
CONFIG_SERIAL=y
# CONFIG_DEV_LOWCONSOLE is not set
# CONFIG_SERIAL_REMOVABLE is not set
CONFIG_SERIAL_CONSOLE=y
# CONFIG_16550_UART is not set
# CONFIG_OTHER_UART_SERIALDRIVER is not set
CONFIG_MCU_SERIAL=y
CONFIG_STANDARD_SERIAL=y
CONFIG_SERIAL_NPOLLWAITERS=2
# CONFIG_SERIAL_IFLOWCONTROL is not set
# CONFIG_SERIAL_OFLOWCONTROL is not set
# CONFIG_SERIAL_DMA is not set
# CONFIG_SERIAL_TIOCSERGSTRUCT is not set
CONFIG_ARCH_HAVE_SERIAL_TERMIOS=y
CONFIG_SERIAL_TERMIOS=y
CONFIG_UART4_SERIAL_CONSOLE=y
# CONFIG_OTHER_SERIAL_CONSOLE is not set
# CONFIG_NO_SERIAL_CONSOLE is not set
# CONFIG_UART_SERIALDRIVER is not set
# CONFIG_UART0_SERIALDRIVER is not set
# CONFIG_UART1_SERIALDRIVER is not set
# CONFIG_UART2_SERIALDRIVER is not set
# CONFIG_UART3_SERIALDRIVER is not set
CONFIG_UART4_SERIALDRIVER=y
# CONFIG_UART5_SERIALDRIVER is not set
# CONFIG_UART6_SERIALDRIVER is not set
# CONFIG_UART7_SERIALDRIVER is not set
# CONFIG_UART8_SERIALDRIVER is not set
# UART4 Configuration
CONFIG_UART4_RXBUFSIZE=256
CONFIG_UART4_TXBUFSIZE=256
CONFIG_UART4_BAUD=230400
CONFIG_UART4_BITS=8
CONFIG_UART4_PARITY=0
CONFIG_UART4_2STOP=0
# CONFIG_UART4_IFLOWCONTROL is not set
# CONFIG_UART4_OFLOWCONTROL is not set
# CONFIG_UART4_DMA is not set
# CONFIG_LPUART_SERIALDRIVER is not set
# CONFIG_LPUART0_SERIALDRIVER is not set
# CONFIG_LPUART1_SERIALDRIVER is not set
# CONFIG_LPUART2_SERIALDRIVER is not set
# CONFIG_LPUART3_SERIALDRIVER is not set
# CONFIG_LPUART4_SERIALDRIVER is not set
# CONFIG_LPUART5_SERIALDRIVER is not set
# CONFIG_LPUART6_SERIALDRIVER is not set
# CONFIG_LPUART7_SERIALDRIVER is not set
# CONFIG_LPUART8_SERIALDRIVER is not set
# CONFIG_USART0_SERIALDRIVER is not set
# CONFIG_USART1_SERIALDRIVER is not set
# CONFIG_USART2_SERIALDRIVER is not set
# CONFIG_USART3_SERIALDRIVER is not set
# CONFIG_USART4_SERIALDRIVER is not set
# CONFIG_USART5_SERIALDRIVER is not set
# CONFIG_USART6_SERIALDRIVER is not set
# CONFIG_USART7_SERIALDRIVER is not set
# CONFIG_USART8_SERIALDRIVER is not set
# CONFIG_USART9_SERIALDRIVER is not set
# CONFIG_SCI0_SERIALDRIVER is not set
# CONFIG_SCI1_SERIALDRIVER is not set
# CONFIG_PSEUDOTERM is not set
# CONFIG_USBDEV is not set
# CONFIG_USBHOST is not set
# CONFIG_USBMISC is not set
# CONFIG_HAVE_USBTRACE is not set
CONFIG_DRIVERS_WIRELESS=y
# CONFIG_WL_CC1101 is not set
# CONFIG_WL_CC3000 is not set
# CONFIG_WL_SPIRIT is not set
# CONFIG_SPIRIT_NETDEV is not set
# CONFIG_DRIVERS_IEEE802154 is not set
# CONFIG_DRIVERS_IEEE80211 is not set
CONFIG_DRIVERS_GENERICRADIO=y
CONFIG_GENERICRADIO_UPPER=y
CONFIG_GENERICRADIO_SI4463=y
# CONFIG_GENERICRADIO_SI4463_FRAMING_L1 is not set
CONFIG_GENERICRADIO_SI4463_FRAMING_L2B=y
# CONFIG_GENERICRADIO_SI4463_FRAMING_L2L is not set
CONFIG_GENERICRADIO_SI4463_USE_WDS_CONFIG=y
# CONFIG_WL_NRF24L01 is not set
# CONFIG_DRIVERS_CONTACTLESS is not set
# System Logging
# CONFIG_ARCH_SYSLOG is not set
CONFIG_SYSLOG_WRITE=y
# CONFIG_RAMLOG is not set
# CONFIG_SYSLOG_BUFFER is not set
# CONFIG_SYSLOG_INTBUFFER is not set
# CONFIG_SYSLOG_TIMESTAMP is not set
CONFIG_SYSLOG_SERIAL_CONSOLE=y
# CONFIG_SYSLOG_CHAR is not set
CONFIG_SYSLOG_CONSOLE=y
# CONFIG_SYSLOG_NONE is not set
# CONFIG_SYSLOG_FILE is not set
# CONFIG_SYSLOG_CHARDEV is not set
# Networking Support
CONFIG_ARCH_HAVE_NET=y
# CONFIG_ARCH_HAVE_PHY is not set
# CONFIG_NET_WRITE_BUFFERS is not set
CONFIG_NET_READAHEAD=y
CONFIG_NET=y
# CONFIG_NET_PROMISCUOUS is not set
# Driver buffer configuration
CONFIG_NET_ETH_MTU=590
CONFIG_NET_ETH_TCP_RECVWNDO=536
CONFIG_NET_GUARDSIZE=2
# Link layer support
# CONFIG_NET_USER_DEVFMT is not set
CONFIG_NET_ETHERNET=y
# CONFIG_NET_LOOPBACK is not set
# CONFIG_NET_TUN is not set
# CONFIG_NET_USRSOCK is not set
# Network Device Operations
CONFIG_NETDEV_IOCTL=y
CONFIG_NETDEV_PHY_IOCTL=y
# CONFIG_NETDEV_WIRELESS_IOCTL is not set
# Internet Protocol Selection
CONFIG_NET_IPv4=y
# CONFIG_NET_IPv6 is not set
# CONFIG_NET_IPFORWARD is not set
# Socket Support
CONFIG_NSOCKET_DESCRIPTORS=8
CONFIG_NET_NACTIVESOCKETS=16
CONFIG_NET_SOCKOPTS=y
CONFIG_NET_TCPPROTO_OPTIONS=y
# CONFIG_NET_SOLINGER is not set
# Raw Socket Support
# CONFIG_NET_PKT is not set
# Unix Domain Socket Support
# CONFIG_NET_LOCAL is not set
# TCP/IP Networking
CONFIG_NET_TCP=y
# CONFIG_NET_TCP_NO_STACK is not set
CONFIG_NET_TCP_KEEPALIVE=y
# CONFIG_NET_TCPURGDATA is not set
# CONFIG_NET_TCP_REASSEMBLY is not set
CONFIG_NET_TCP_CONNS=8
CONFIG_NET_MAX_LISTENPORTS=20
CONFIG_NET_TCP_READAHEAD=y
# CONFIG_NET_TCP_WRITE_BUFFERS is not set
CONFIG_NET_TCP_RECVDELAY=0
# CONFIG_NET_TCPBACKLOG is not set
# CONFIG_NET_TCP_SPLIT is not set
# CONFIG_NET_SENDFILE is not set
# CONFIG_NET_TCP_RWND_CONTROL is not set
# UDP Networking
CONFIG_NET_UDP=y
# CONFIG_NET_UDP_NO_STACK is not set
CONFIG_NET_UDP_CHECKSUMS=y
CONFIG_NET_UDP_CONNS=8
CONFIG_NET_BROADCAST=y
# CONFIG_NET_UDP_READAHEAD is not set
# CONFIG_NET_UDP_WRITE_BUFFERS is not set
# IEEE 802.15.4 socket support
# ICMP Networking Support
CONFIG_NET_ICMP=y
CONFIG_NET_ICMP_SOCKET=y
CONFIG_NET_ICMP_NCONNS=4
# CONFIG_NET_IGMP is not set
# ARP Configuration
CONFIG_NET_ARP=y
CONFIG_NET_ARPTAB_SIZE=16
CONFIG_NET_ARP_MAXAGE=120
CONFIG_NET_ARP_IPIN=y
CONFIG_NET_ARP_SEND=y
CONFIG_ARP_SEND_MAXTRIES=5
CONFIG_ARP_SEND_DELAYMSEC=20
# User-space networking stack API
# CONFIG_NET_ARCH_INCR32 is not set
# CONFIG_NET_ARCH_CHKSUM is not set
# CONFIG_NET_STATISTICS is not set
# CONFIG_NET_HAVE_STAR is not set
# Network Topologies
# Routing Table Configuration
CONFIG_NET_ROUTE=y
CONFIG_ROUTE_IPv4_RAMROUTE=y
# CONFIG_ROUTE_IPv4_ROMROUTE is not set
# CONFIG_ROUTE_IPv4_FILEROUTE is not set
CONFIG_ROUTE_MAX_IPv4_RAMROUTES=4
CONFIG_NET_HOSTNAME=""
# Crypto API
# CONFIG_CRYPTO is not set
# File Systems
# File system configuration
# CONFIG_DISABLE_MOUNTPOINT is not set
# CONFIG_FS_AUTOMOUNTER is not set
# CONFIG_DISABLE_PSEUDOFS_OPERATIONS is not set
# CONFIG_PSEUDOFS_SOFTLINKS is not set
CONFIG_FS_READABLE=y
CONFIG_FS_WRITABLE=y
# CONFIG_FS_NAMED_SEMAPHORES is not set
CONFIG_FS_MQUEUE_MPATH="/var/mqueue"
# CONFIG_FS_RAMMAP is not set
# CONFIG_FS_FAT is not set
# CONFIG_NFS is not set
# CONFIG_FS_NXFFS is not set
# CONFIG_FS_ROMFS is not set
# CONFIG_FS_TMPFS is not set
CONFIG_FS_SMARTFS=y
CONFIG_SMARTFS_ERASEDSTATE=0xff
CONFIG_SMARTFS_MAXNAMLEN=16
# CONFIG_SMARTFS_MULTI_ROOT_DIRS is not set
# CONFIG_SMARTFS_ALIGNED_ACCESS is not set
# CONFIG_FS_BINFS is not set
# CONFIG_FS_PROCFS is not set
# CONFIG_FS_UNIONFS is not set
# Graphics Support
# CONFIG_NX is not set
# CONFIG_NXFONTS is not set
# Font Cache Pixel Depths
CONFIG_NXFONTS_DISABLE_1BPP=y
# CONFIG_NXFONTS_DISABLE_2BPP is not set
# CONFIG_NXFONTS_DISABLE_4BPP is not set
# CONFIG_NXFONTS_DISABLE_8BPP is not set
# CONFIG_NXFONTS_DISABLE_16BPP is not set
# CONFIG_NXFONTS_DISABLE_24BPP is not set
# CONFIG_NXFONTS_DISABLE_32BPP is not set
CONFIG_NXFONTS_PACKEDMSFIRST=y
# CONFIG_NXGLIB is not set
# Memory Management
# CONFIG_MM_SMALL is not set
CONFIG_MM_REGIONS=2
# CONFIG_ARCH_HAVE_HEAP2 is not set
# CONFIG_GRAN is not set
# Common I/O Buffer Support
CONFIG_MM_IOB=y
CONFIG_IOB_NBUFFERS=24
CONFIG_IOB_BUFSIZE=196
CONFIG_IOB_NCHAINS=8
CONFIG_IOB_THROTTLE=0
# CONFIG_IOB_DEBUG is not set
# Audio Support
# CONFIG_AUDIO is not set
# Wireless Support
# CONFIG_WIRELESS is not set
# Binary Loader
# CONFIG_BINFMT_DISABLE is not set
# CONFIG_BINFMT_EXEPATH is not set
# CONFIG_NXFLAT is not set
# CONFIG_ELF is not set
CONFIG_BUILTIN=y
# CONFIG_PIC is not set
# CONFIG_SYMTAB_ORDEREDBYNAME is not set
# Library Routines
# Standard C Library Options
# Standard C I/O
# CONFIG_STDIO_DISABLE_BUFFERING is not set
CONFIG_STDIO_BUFFER_SIZE=64
CONFIG_STDIO_LINEBUFFER=y
CONFIG_NUNGET_CHARS=2
# CONFIG_NOPRINTF_FIELDWIDTH is not set
# CONFIG_LIBC_FLOATINGPOINT is not set
CONFIG_LIBC_LONG_LONG=y
# CONFIG_LIBC_SCANSET is not set
# CONFIG_EOL_IS_CR is not set
# CONFIG_EOL_IS_LF is not set
# CONFIG_EOL_IS_BOTH_CRLF is not set
CONFIG_EOL_IS_EITHER_CRLF=y
# CONFIG_MEMCPY_VIK is not set
# CONFIG_LIBM is not set
# Architecture-Specific Support
CONFIG_ARCH_LOWPUTC=y
# CONFIG_ARCH_ROMGETC is not set
# CONFIG_LIBC_ARCH_MEMCPY is not set
# CONFIG_LIBC_ARCH_MEMCMP is not set
# CONFIG_LIBC_ARCH_MEMMOVE is not set
# CONFIG_LIBC_ARCH_MEMSET is not set
# CONFIG_LIBC_ARCH_STRCHR is not set
# CONFIG_LIBC_ARCH_STRCMP is not set
# CONFIG_LIBC_ARCH_STRCPY is not set
# CONFIG_LIBC_ARCH_STRNCPY is not set
# CONFIG_LIBC_ARCH_STRLEN is not set
# CONFIG_LIBC_ARCH_STRNLEN is not set
# CONFIG_LIBC_ARCH_ELF is not set
# CONFIG_ARMV7M_MEMCPY is not set
# stdlib Options
CONFIG_LIB_RAND_ORDER=1
CONFIG_LIB_HOMEDIR="/"
CONFIG_LIBC_TMPDIR="/tmp"
CONFIG_LIBC_MAX_TMPFILE=32
# Program Execution Options
# CONFIG_LIBC_EXECFUNCS is not set
CONFIG_POSIX_SPAWN_PROXY_STACKSIZE=1024
CONFIG_TASK_SPAWN_DEFAULT_STACKSIZE=2048
# errno Decode Support
# CONFIG_LIBC_STRERROR is not set
# CONFIG_LIBC_PERROR_STDOUT is not set
# memcpy/memset Options
# CONFIG_MEMSET_OPTSPEED is not set
# CONFIG_LIBC_DLLFCN is not set
# CONFIG_LIBC_MODLIB is not set
# CONFIG_LIBC_WCHAR is not set
# CONFIG_LIBC_LOCALE is not set
# CONFIG_LIBC_LZF is not set
# Time/Time Zone Support
# CONFIG_LIBC_LOCALTIME is not set
# CONFIG_TIME_EXTENDED is not set
CONFIG_ARCH_HAVE_TLS=y
# Thread Local Storage (TLS)
# CONFIG_TLS is not set
# Network-Related Options
# CONFIG_LIBC_IPv6_ADDRCONV is not set
CONFIG_LIBC_NETDB=y
# NETDB Support
# CONFIG_NETDB_HOSTFILE is not set
# CONFIG_NETDB_DNSCLIENT is not set
# CONFIG_LIBC_IOCTL_VARIADIC is not set
CONFIG_LIB_SENDFILE_BUFSIZE=512
# Non-standard Library Support
# CONFIG_LIB_CRC64_FAST is not set
# CONFIG_LIB_KBDCODEC is not set
# CONFIG_LIB_SLCDCODEC is not set
# CONFIG_LIB_HEX2BIN is not set
# Basic CXX Support
# CONFIG_C99_BOOL8 is not set
# CONFIG_HAVE_CXX is not set
# Application Configuration
# Built-In Applications
CONFIG_BUILTIN_PROXY_STACKSIZE=1024
# CAN Utilities
# CONFIG_CANUTILS_CANDUMP is not set
# Examples
# CONFIG_EXAMPLES_APA102 is not set
# CONFIG_EXAMPLES_BRIDGE is not set
# CONFIG_EXAMPLES_CCTYPE is not set
# CONFIG_EXAMPLES_CHAT is not set
# CONFIG_EXAMPLES_CONFIGDATA is not set
# CONFIG_EXAMPLES_DHCPD is not set
# CONFIG_EXAMPLES_DISCOVER is not set
CONFIG_EXAMPLES_FB=y
CONFIG_EXAMPLES_FB_DEFAULTFB="/dev/fb0"
CONFIG_EXAMPLES_FB_PRIORITY=100
CONFIG_EXAMPLES_FB_STACKSIZE=2048
# CONFIG_EXAMPLES_FLASH_TEST is not set
# CONFIG_EXAMPLES_FLOWC is not set
# CONFIG_EXAMPLES_FSTEST is not set
# CONFIG_EXAMPLES_FTPC is not set
# CONFIG_EXAMPLES_FTPD is not set
# CONFIG_EXAMPLES_HELLO is not set
# CONFIG_EXAMPLES_HIDKBD is not set
# CONFIG_EXAMPLES_IGMP is not set
# CONFIG_EXAMPLES_INA219 is not set
# CONFIG_EXAMPLES_JSON is not set
# CONFIG_EXAMPLES_LVGLDEMO is not set
# CONFIG_EXAMPLES_MEDIA is not set
# CONFIG_EXAMPLES_MM is not set
# CONFIG_EXAMPLES_MODBUS is not set
# CONFIG_EXAMPLES_MOUNT is not set
# CONFIG_EXAMPLES_MTDPART is not set
# CONFIG_EXAMPLES_NETTEST is not set
# CONFIG_EXAMPLES_NRF24L01TERM is not set
CONFIG_EXAMPLES_NSH=y
# CONFIG_EXAMPLES_NULL is not set
# CONFIG_EXAMPLES_NXFFS is not set
# CONFIG_EXAMPLES_OBD2 is not set
# CONFIG_EXAMPLES_OSTEST is not set
# CONFIG_EXAMPLES_PCA9635 is not set
# CONFIG_EXAMPLES_PDCURSES is not set
# CONFIG_EXAMPLES_POSIXSPAWN is not set
# CONFIG_EXAMPLES_POWERLED is not set
# CONFIG_EXAMPLES_POWERMONITOR is not set
# CONFIG_EXAMPLES_PPPD is not set
# CONFIG_EXAMPLES_RFID_READUID is not set
# CONFIG_EXAMPLES_RGBLED is not set
# CONFIG_EXAMPLES_SENDMAIL is not set
# CONFIG_EXAMPLES_SERIALBLASTER is not set
# CONFIG_EXAMPLES_SERIALRX is not set
# CONFIG_EXAMPLES_SERLOOP is not set
# CONFIG_EXAMPLES_SLCD is not set
# CONFIG_EXAMPLES_SMART is not set
# CONFIG_EXAMPLES_SMART_TEST is not set
# CONFIG_EXAMPLES_SMP is not set
# CONFIG_EXAMPLES_SMPS is not set
# CONFIG_EXAMPLES_STAT is not set
# CONFIG_EXAMPLES_TCPECHO is not set
# CONFIG_EXAMPLES_TIFF is not set
# CONFIG_EXAMPLES_TOUCHSCREEN is not set
# CONFIG_EXAMPLES_UDPBLASTER is not set
# CONFIG_EXAMPLES_UDP is not set
# CONFIG_EXAMPLES_USBSERIAL is not set
# CONFIG_EXAMPLES_USERFS is not set
# CONFIG_EXAMPLES_WATCHDOG is not set
# CONFIG_EXAMPLES_WEBSERVER is not set
# CONFIG_EXAMPLES_XBC_TEST is not set
# CONFIG_EXAMPLES_XMLRPC is not set
# File System Utilities
# CONFIG_FSUTILS_FLASH_ERASEALL is not set
# CONFIG_FSUTILS_INIFILE is not set
CONFIG_FSUTILS_MKSMARTFS=y
# CONFIG_FSUTILS_PASSWD is not set
# Generic Radio apps
# CONFIG_GENRADIO_GR is not set
# CONFIG_GENRADIO_LIBGENRADIO is not set
# GPS Utilities
# CONFIG_GPSUTILS_MINMEA_LIB is not set
# Graphics Support
# CONFIG_GRAPHICS_FT80X is not set
# CONFIG_GRAPHICS_LVGL is not set
# NxWidgets/NxWM
# CONFIG_GRAPHICS_PDCURSES is not set
# CONFIG_TIFF is not set
# CONFIG_GRAPHICS_TRAVELER is not set
# hn70ap apps
CONFIG_HN70AP_BEACON=y
CONFIG_HN70AP_BEACON_PRIORITY=100
CONFIG_HN70AP_BEACON_STACKSIZE=2048
CONFIG_HN70AP_CONFIG=y
CONFIG_HN70AP_CONFIG_PRIORITY=100
CONFIG_HN70AP_CONFIG_STACKSIZE=2048
CONFIG_LIBHN70AP=y
CONFIG_HN70AP_RXT=y
CONFIG_HN70AP_RXT_PRIORITY=100
CONFIG_HN70AP_RXT_STACKSIZE=2048
CONFIG_HN70AP_SYSDAEMON=y
CONFIG_HN70AP_SYSDAEMON_PRIORITY=100
CONFIG_HN70AP_SYSDAEMON_STACKSIZE=2048
CONFIG_HN70AP_TXT=y
CONFIG_HN70AP_TXT_PRIORITY=100
CONFIG_HN70AP_TXT_STACKSIZE=2048
CONFIG_HN70AP_UPDATE=y
CONFIG_HN70AP_UPDATE_PRIORITY=100
CONFIG_HN70AP_UPDATE_STACKSIZE=2048
# Interpreters
# CONFIG_INTERPRETERS_BAS is not set
# CONFIG_INTERPRETERS_FICL is not set
# CONFIG_INTERPRETERS_LUA is not set
# CONFIG_INTERPRETERS_MICROPYTHON is not set
# CONFIG_INTERPRETERS_MINIBASIC is not set
# CONFIG_INTERPRETERS_PCODE is not set
# FreeModBus
# CONFIG_MODBUS is not set
# Network Utilities
# CONFIG_NETUTILS_CHAT is not set
# CONFIG_NETUTILS_CODECS is not set
CONFIG_NETUTILS_DHCPC=y
# CONFIG_NETUTILS_DHCPD is not set
# CONFIG_NETUTILS_DISCOVER is not set
# CONFIG_NETUTILS_ESP8266 is not set
# CONFIG_NETUTILS_FTPC is not set
# CONFIG_NETUTILS_FTPD is not set
# CONFIG_NETUTILS_JSON is not set
CONFIG_NETUTILS_NETLIB=y
# CONFIG_NETUTILS_NTPCLIENT is not set
# CONFIG_NETUTILS_PPPD is not set
# CONFIG_NETUTILS_SMTP is not set
# CONFIG_NETUTILS_TELNETC is not set
# CONFIG_NETUTILS_TELNETD is not set
CONFIG_NETUTILS_TFTPC=y
# CONFIG_NETUTILS_WEBCLIENT is not set
# CONFIG_NETUTILS_WEBSERVER is not set
# CONFIG_NETUTILS_XMLRPC is not set
# NSH Library
CONFIG_NSH_LIBRARY=y
# CONFIG_NSH_MOTD is not set
# Command Line Configuration
CONFIG_NSH_READLINE=y
# CONFIG_NSH_CLE is not set
CONFIG_NSH_LINELEN=64
# CONFIG_NSH_DISABLE_SEMICOLON is not set
CONFIG_NSH_CMDPARMS=y
CONFIG_NSH_MAXARGUMENTS=6
CONFIG_NSH_ARGCAT=y
CONFIG_NSH_NESTDEPTH=3
# CONFIG_NSH_DISABLEBG is not set
CONFIG_NSH_BUILTIN_APPS=y
# Disable Individual commands
# CONFIG_NSH_DISABLE_ADDROUTE is not set
# CONFIG_NSH_DISABLE_ARP is not set
CONFIG_NSH_DISABLE_BASENAME=y
# CONFIG_NSH_DISABLE_CAT is not set
# CONFIG_NSH_DISABLE_CD is not set
# CONFIG_NSH_DISABLE_CP is not set
# CONFIG_NSH_DISABLE_CMP is not set
CONFIG_NSH_DISABLE_DATE=y
# CONFIG_NSH_DISABLE_DD is not set
# CONFIG_NSH_DISABLE_DF is not set
# CONFIG_NSH_DISABLE_DELROUTE is not set
CONFIG_NSH_DISABLE_DIRNAME=y
# CONFIG_NSH_DISABLE_ECHO is not set
CONFIG_NSH_DISABLE_EXEC=y
# CONFIG_NSH_DISABLE_EXIT is not set
# CONFIG_NSH_DISABLE_FREE is not set
# CONFIG_NSH_DISABLE_GET is not set
# CONFIG_NSH_DISABLE_HELP is not set
# CONFIG_NSH_DISABLE_HEXDUMP is not set
CONFIG_NSH_DISABLE_IFCONFIG=y
CONFIG_NSH_DISABLE_IFUPDOWN=y
# CONFIG_NSH_DISABLE_KILL is not set
CONFIG_NSH_DISABLE_LOSETUP=y
CONFIG_NSH_DISABLE_LOSMART=y
# CONFIG_NSH_DISABLE_LS is not set
CONFIG_NSH_DISABLE_MB=y
# CONFIG_NSH_DISABLE_MKDIR is not set
# CONFIG_NSH_DISABLE_MKRD is not set
# CONFIG_NSH_DISABLE_MKSMARTFS is not set
CONFIG_NSH_DISABLE_MH=y
# CONFIG_NSH_DISABLE_MOUNT is not set
CONFIG_NSH_DISABLE_MV=y
CONFIG_NSH_DISABLE_MW=y
CONFIG_NSH_DISABLE_PRINTF=y
# CONFIG_NSH_DISABLE_PS is not set
# CONFIG_NSH_DISABLE_PUT is not set
# CONFIG_NSH_DISABLE_PWD is not set
# CONFIG_NSH_DISABLE_REBOOT is not set
# CONFIG_NSH_DISABLE_RM is not set
# CONFIG_NSH_DISABLE_RMDIR is not set
# CONFIG_NSH_DISABLE_SET is not set
# CONFIG_NSH_DISABLE_SH is not set
CONFIG_NSH_DISABLE_SHUTDOWN=y
# CONFIG_NSH_DISABLE_SLEEP is not set
CONFIG_NSH_DISABLE_TIME=y
# CONFIG_NSH_DISABLE_TEST is not set
CONFIG_NSH_DISABLE_TELNETD=y
CONFIG_NSH_DISABLE_TRUNCATE=y
# CONFIG_NSH_DISABLE_UMOUNT is not set
# CONFIG_NSH_DISABLE_UNAME is not set
# CONFIG_NSH_DISABLE_UNSET is not set
# CONFIG_NSH_DISABLE_USLEEP is not set
# CONFIG_NSH_DISABLE_WGET is not set
CONFIG_NSH_DISABLE_XD=y
CONFIG_NSH_MMCSDMINOR=0
# Configure Command Options
# CONFIG_NSH_CMDOPT_DD_STATS is not set
CONFIG_NSH_CODECS_BUFSIZE=128
CONFIG_NSH_CMDOPT_HEXDUMP=y
CONFIG_NSH_FILEIOSIZE=512
# Scripting Support
CONFIG_NSH_DISABLESCRIPT=y
# Console Configuration
CONFIG_NSH_CONSOLE=y
# CONFIG_NSH_ALTCONDEV is not set
# CONFIG_NSH_ARCHINIT is not set
# Networking Configuration
# CONFIG_NSH_NETINIT is not set
# CONFIG_NSH_LOGIN is not set
# CONFIG_NSH_CONSOLE_LOGIN is not set
# Platform-specific Support
# CONFIG_PLATFORM_CONFIGDATA is not set
# System Libraries and NSH Add-Ons
# CONFIG_SYSTEM_CLE is not set
# CONFIG_SYSTEM_CUTERM is not set
# CONFIG_SYSTEM_DHCPC_RENEW is not set
# CONFIG_SYSTEM_FLASH_ERASEALL is not set
# CONFIG_SYSTEM_HEX2BIN is not set
# CONFIG_SYSTEM_HEXED is not set
CONFIG_SYSTEM_I2CTOOL=y
CONFIG_I2CTOOL_MINBUS=0
CONFIG_I2CTOOL_MAXBUS=3
CONFIG_I2CTOOL_MINADDR=0x03
CONFIG_I2CTOOL_MAXADDR=0x77
CONFIG_I2CTOOL_MAXREGADDR=0xff
CONFIG_I2CTOOL_DEFFREQ=400000
# CONFIG_SYSTEM_INSTALL is not set
# CONFIG_SYSTEM_MDIO is not set
# CONFIG_SYSTEM_NETDB is not set
# CONFIG_SYSTEM_NTPC is not set
CONFIG_SYSTEM_PING=y
CONFIG_SYSTEM_PING_PRIORITY=100
CONFIG_SYSTEM_PING_STACKSIZE=2048
# CONFIG_SYSTEM_RAMTEST is not set
CONFIG_READLINE_HAVE_EXTMATCH=y
CONFIG_SYSTEM_READLINE=y
CONFIG_READLINE_ECHO=y
# CONFIG_READLINE_TABCOMPLETION is not set
# CONFIG_READLINE_CMD_HISTORY is not set
# CONFIG_SYSTEM_SETLOGMASK is not set
# CONFIG_SYSTEM_SUDOKU is not set
# CONFIG_SYSTEM_SYSTEM is not set
# CONFIG_SYSTEM_TEE is not set
# CONFIG_SYSTEM_TELNET_CHATD is not set
# CONFIG_SYSTEM_TELNET_CLIENT is not set
# CONFIG_SYSTEM_UBLOXMODEM is not set
# CONFIG_SYSTEM_VI is not set
# CONFIG_SYSTEM_ZMODEM is not set
# Wireless Libraries and NSH Add-Ons
# IEEE 802.15.4 applications
# CONFIG_IEEE802154_LIBMAC is not set
# CONFIG_IEEE802154_LIBUTILS is not set
# CONFIG_IEEE802154_I8SAK is not set
# CONFIG_WIRELESS_IWPAN is not set
# CONFIG_WIRELESS_WAPI is not set
...@@ -189,3 +189,9 @@ int board_app_initialize(uintptr_t arg) ...@@ -189,3 +189,9 @@ int board_app_initialize(uintptr_t arg)
return 0; return 0;
#if !defined(CONFIG_HN70AP_ETHERNET)
void up_netinitialize(void)
#endif
...@@ -63,50 +63,50 @@ static void *g_phy_arg; ...@@ -63,50 +63,50 @@ static void *g_phy_arg;
void hn70ap_net_initialize(void) void hn70ap_net_initialize(void)
_info("Configuring PHY GPIOs\n"); _info("Configuring PHY GPIOs\n");
stm32_configgpio(GPIO_IRQ_ETHERNET); stm32_configgpio(GPIO_IRQ_ETHERNET);
stm32_configgpio(GPIO_ETHERNET_RST); stm32_configgpio(GPIO_ETHERNET_RST);
g_phy_handler = NULL; g_phy_handler = NULL;
g_phy_arg = NULL; g_phy_arg = NULL;
* Name: stm32_phy_boardinitialize * Name: stm32_phy_boardinitialize
int stm32_phy_boardinitialize(int intf) int stm32_phy_boardinitialize(int intf)
_info("called (intf=%d)\n", intf); _info("called (intf=%d)\n", intf);
_info("PHY reset...\n"); _info("PHY reset...\n");
stm32_gpiowrite(GPIO_ETHERNET_RST, 0); stm32_gpiowrite(GPIO_ETHERNET_RST, 0);
up_mdelay(1); up_mdelay(1);
_info("PHY reset done.\n"); _info("PHY reset done.\n");
stm32_gpiowrite(GPIO_ETHERNET_RST, 1); stm32_gpiowrite(GPIO_ETHERNET_RST, 1);
return 0; return 0;
* Name: stm32_phy_enable * Name: stm32_phy_enable
static void stm32_phy_enable(bool enable) static void stm32_phy_enable(bool enable)
//_info("PHY IRQ enable :%d\n", enable);
if (enable)
//_info("PHY IRQ enable :%d\n", enable); stm32_gpiosetevent(GPIO_IRQ_ETHERNET, /*rising*/ FALSE, /*falling*/ TRUE, TRUE,
if (enable) g_phy_handler, /*arg*/ g_phy_arg);
else
stm32_gpiosetevent(GPIO_IRQ_ETHERNET, /*rising*/ FALSE, /*falling*/ FALSE, FALSE,
NULL, /*arg*/ NULL);
else
* Name: arch_phy_irq * Name: arch_phy_irq
...@@ -169,37 +169,38 @@ static void stm32_phy_enable(bool enable) ...@@ -169,37 +169,38 @@ static void stm32_phy_enable(bool enable)
* failure. * failure.
int arch_phy_irq(FAR const char *intf, xcpt_t handler, void *arg, phy_enable_t *enable) int arch_phy_irq(FAR const char *intf, xcpt_t handler, void *arg,
{ FAR phy_enable_t *enable)
irqstate_t flags; {
irqstate_t flags;
/* Disable interrupts until we are done. This guarantees that the /* Disable interrupts until we are done. This guarantees that the
* following operations are atomic. * following operations are atomic.
flags = enter_critical_section(); flags = enter_critical_section();
/* Get the old interrupt handler and save the new one */ /* Get the old interrupt handler and save the new one */
g_phy_handler = handler; g_phy_handler = handler;
g_phy_arg = arg; g_phy_arg = arg;
if (handler) if (handler)
_info("Attach PHY IRQ\n"); _info("Attach PHY IRQ\n");
*enable = stm32_phy_enable; *enable = stm32_phy_enable;
else else
_info("Detach PHY IRQ\n"); _info("Detach PHY IRQ\n");
*enable = NULL; *enable = NULL;
/* Return with the interrupt disabled in either case */
stm32_phy_enable(FALSE);
leave_critical_section(flags);
return 0;
return 0;
...@@ -155,7 +155,7 @@ int hn70ap_genradio_initialize(void) ...@@ -155,7 +155,7 @@ int hn70ap_genradio_initialize(void)
#if defined(CONFIG_HN70AP_MAINRADIO) #if defined(CONFIG_HN70AP_MAINRADIO)
_info("Prepare main radio\n"); _info("Prepare main radio\n");
si4463_priv_main.gpio_irq = GPIO_IRQ_RADIOMAIN; si4463_priv_main.gpio_irq = GPIO_IRQ_RADIOMAIN;
radio = RFM26_init(spi4, 0, SI4463_IO0, SI4463_IO1, &si4463_lower_main); radio = si4463_init(spi4, 0, 30000000, SI4463_IO1, SI4463_IO3, &si4463_lower_main);
if(radio==NULL) if(radio==NULL)
_err("Unable to initialize si4463\n"); _err("Unable to initialize si4463\n");
