Skip to content
GitLab
Explore
Sign in
hn70ap
Compare revisions
d929e49b0fdb3f20a101b92915174e55a4e89f02 to 54abe12cc8b3812e16515a1cf0d430f1028a451f
Commits on Source (2)
update full defconfig to enable radio and tcp keepalive
· e80414cd
authored
Mar 14, 2018
e80414cd
Merge branch 'master' of
https://github.com/f4grx/hn70ap
· 54abe12c
authored
Mar 15, 2018
54abe12c
Hide whitespace changes
Inline
Side-by-side
Kconfig
View file @
54abe12c
@@ -15,16 +15,16 @@ config HN70AP_HWDEBUG_BLINK
bool "Just Blink leds instead of starting NuttX"
config HN70AP_EEPROM
bool "Enable EEPROM"
bool "Enable EEPROM
(requires I2C3)
config HN70AP_SPIFLASH
bool "Enable SPI FLASH"
(requires SPI2)
config HN70AP_SCREEN
bool "Enable OLED screen"
(requires I2C3)
config HN70AP_ETHERNET
bool "Enable Ethernet"
(requires ETHMAC)
select ARCH_PHY_INTERRUPT if NETDEVICES
if HN70AP_ETHERNET
if HN70AP_ETHERNET
@@ -39,7 +39,7 @@ config HN70AP_RADIO
bool
bool
config HN70AP_MAINRADIO
bool "Enable main radio"
(requires SPI4)
select HN70AP_RADIO
select HN70AP_RADIO
if HN70AP_MAINRADIO
if HN70AP_MAINRADIO
@@ -50,7 +50,7 @@ config HN70AP_MAINRADIO_TCXO
endif
endif
config HN70AP_AUXRADIO
bool "Enable aux radio"
(requires SPI4)
select HN70AP_RADIO
select HN70AP_RADIO
if HN70AP_AUXRADIO
if HN70AP_AUXRADIO
apps/update/update_write.c
View file @
54abe12c
@@ -190,7 +190,7 @@ again:
/* Write last partial page */
if
ctx
block_received
0
if
ctx
block_received
0
printf
"WRITE LAST [%u]:"
ctx
block_id
printf
\n
WRITE LAST [%u]:"
ctx
block_id
if
ctx
block_id
63
if
ctx
block_id
63
ctx
datacrc
crc32_do
ctx
datacrc
ctx
block
ctx
block_received
ctx
datacrc
crc32_do
ctx
datacrc
ctx
block
ctx
block_received
build/full/defconfig
View file @
54abe12c
@@ -1245,7 +1245,7 @@ CONFIG_NET_IPv4=y
CONFIG_NSOCKET_DESCRIPTORS=8
CONFIG_NET_NACTIVESOCKETS=16
CONFIG_NET_SOCKOPTS=y
CONFIG_NET_TCPPROTO_OPTIONS
is not set
=y
# CONFIG_NET_SOLINGER is not set
@@ -1263,7 +1263,7 @@ CONFIG_NET_SOCKOPTS=y
CONFIG_NET_TCP=y
CONFIG_NET_TCP=y
# CONFIG_NET_TCP_NO_STACK is not set
CONFIG_NET_TCP_KEEPALIVE
is not set
=y
# CONFIG_NET_TCPURGDATA is not set
# CONFIG_NET_TCP_REASSEMBLY is not set
CONFIG_NET_TCP_CONNS=8
