- ADC driver has been re-organized; configuration is now handled in code
instead of Kconfig to help reduce bloat and confusion. - Timer changed to remove ADC coupling in Kconfig to code and moved configuration up from arch/arm/src/tiva to configs/tm4c123g-launchpad/src. - GPIO driver needed small fixes in the configuration routines and discovered false-positive bugs in interrupt testing: interrupts are now verified to actually be working reliably. - Attempt to apply some consistency in the tiva arch/ level's interface to the config/board/ level driver configuration. From Calvin Maguranis
parent
528478be
