Skip to content
GitLab
Explore
Sign in
NuttX RTOS
Compare revisions
49644be9a55a003a23a4555e846d42670c4e98df to 7d7b8a243b0ceecda239c4d86bf91783fc4c6638
Expand all
Show whitespace changes
Inline
Side-by-side
arch/arm/src/lc823450/lc823450_vectors.h
View file @
7d7b8a24
* arch/arm/src/lc823450/chip/lc823450_vectors.h
* Copyright
(C)
2014
2017 Sony
Corporation. All rights reserved
* Copyright 2014
2017 Sony
Video & Sound Products Inc
* Author: Masatoshi Tateishi <Masatoshi.Tateishi@jp.sony.com>
* Author: Masayuki Ishikawa <Masayuki.Ishikawa@jp.sony.com>
arch/arm/src/lc823450/lc823450_wdt.c
View file @
7d7b8a24
* arch/arm/src/lc823450/lc823450_wdt.c
* Copyright
(C) 2014-2017 Sony Corporation. All rights reserved
* Copyright
2014,2015,2017 Sony Video & Sound Products Inc
* Author: Nobutaka Toyoshima <Nobutaka.Toyoshima@jp.sony.com>
arch/arm/src/lc823450/lc823450_wdt.h
View file @
7d7b8a24
* arch/arm/src/lc823450/lc823450_wdt.h
* Copyright
(C)
2014
2017 Sony
* Copyright 2014
2017 Sony
arch/arm/src/stm32/Kconfig
View file @
7d7b8a24
@@ -2381,26 +2381,38 @@ if STM32_HRTIM1
config STM32_HRTIM_MASTER
bool "HRTIM MASTER"
bool "HRTIM MASTER"
default n
default n
---help---
Enable HRTIM Master Timer
config STM32_HRTIM_TIMA
bool "HRTIM TIMA"
bool "HRTIM TIMA"
default n
default n
---help---
Enable HRTIM Timer A
config STM32_HRTIM_TIMB
bool "HRTIM TIMB"
bool "HRTIM TIMB"
default n
default n
---help---
Enable HRTIM Timer B
config STM32_HRTIM_TIMC
bool "HRTIM TIMC"
bool "HRTIM TIMC"
default n
default n
---help---
Enable HRTIM Timer C
config STM32_HRTIM_TIMD
bool "HRTIM TIMD"
bool "HRTIM TIMD"
default n
default n
---help---
Enable HRTIM Timer D
config STM32_HRTIM_TIME
bool "HRTIM TIME"
bool "HRTIM TIME"
default n
default n
---help---
Enable HRTIM Timer E
endif # STM32_HRTIM
endif # STM32_HRTIM
@@ -5853,10 +5865,15 @@ if STM32_HRTIM1
config STM32_HRTIM_DISABLE_CHARDRV
bool "HRTIM Disable Character Driver"
default n
default n
---help---
In most cases we do not need HRTIM Character Driver, so we can disable it
and save some memory.
menuconfig STM32_HRTIM_ADC
bool "HRTIM ADC
Configuration
bool "HRTIM ADC
Triggering
default n
default n
---help---
Enable HRTIM ADC Triggering support.
if STM32_HRTIM_ADC
if STM32_HRTIM_ADC
@@ -5897,33 +5914,54 @@ endif # STM32_HRTIM_ADC
config STM32_HRTIM_DAC
bool "HRTIM DAC Triggering"
default n
default n
---help---
Enable HRTIM DAC Triggering support.
config STM32_HRTIM_PWM
bool "HRTIM PWM Outputs"
default n
default n
---help---
Enable HRTIM PWM Outputs support.
config STM32_HRTIM_CAP
bool "HRTIM Capture"
default n
default n
---help---
Enable HRTIM Capture support.
config STM32_HRTIM_INTERRUPTS
bool "HRTIM Interrupts"
default n
default n
---help---
Enable HRTIM Interrupts support.
config STM32_HRTIM_BURST
bool "HRTIM Burst Mode"
depends on STM32_HRTIM_PWM
default n
default n
---help---
Enable HRTIM Burst Mode support for PWM outputs.
config STM32_HRTIM_DEADTIME
bool "HRTIM Dead-time"
default n
default n
---help---
Enable HRTIM Deadtime support for PWM outputs.
config STM32_HRTIM_PUSHPULL
bool "HRTIM
p
ush-
p
ull
m
ode"
bool "HRTIM
P
ush-
P
ull
M
ode"
default n
default n
---help---
Enable HRTIM Push-Pull Mode support for PWM outputs.
config STM32_HRTIM_CHOPPER
bool "HRTIM Chopper"
default n
---help---
Enable HRTIM Chopper Mode for PWM outputs.
config STM32_HRTIM_DMA
bool "HRTIM DMA"
bool "HRTIM DMA"
@@ -5933,11 +5971,6 @@ config STM32_HRTIM_DMABURST
bool "HRTIM DMA Burst"
default n
default n
default n
config STM32_HRTIM_AUTODELAY
bool "HRTIM Autodelay"
@@ -5946,6 +5979,8 @@ config STM32_HRTIM_AUTODELAY
menuconfig STM32_HRTIM_EVENTS
bool "HRTIM Events Configuration"
default n
default n
---help---
Enable HRTIM Events support.
if STM32_HRTIM_EVENTS
@@ -5994,6 +6029,8 @@ endif # STM32_HRTIM_EVENTS
menuconfig STM32_HRTIM_FAULTS
bool "HRTIM Faults Configuration"
default n
default n
---help---
Enable HRTIM Faults support.
if STM32_HRTIM_FAULTS
@@ -6018,6 +6055,11 @@ endif # STM32_HRTIM_FAULTS
config STM32_HRTIM_CLK_FROM_PLL
bool "HRTIM Clock from PLL"
default n
default n
---help---
Set PLL as the clock source for HRTIM.
This configuration requires the following conditions:
1) system clock is PLL,
2) SYSCLK and PCLK2 ratio must be 1 o 2.
menu "HRTIM Master Configuration"
depends on STM32_HRTIM_MASTER
@@ -6446,6 +6488,22 @@ config STM32_ADC4_DMA
DMA transfer, which is necessary if multiple channels are read
or if very high trigger frequencies are used.
config STM32_ADC1_INJECTED
bool "ADC1 INJECTED"
depends on STM32_ADC1 && STM32_STM32F33XX
default n
---help---
Support for ADC1 injected channels.
Only for STM32_STM32F33XX at this moment.
config STM32_ADC2_INJECTED
bool "ADC2 INJECTED"
depends on STM32_ADC2 && STM32_STM32F33XX
default n
---help---
Support for ADC2 injected channels.
endmenu
endmenu
menu "SDADC Configuration"
arch/arm/src/stm32/chip/stm32f33xxx_hrtim.h
View file @
7d7b8a24
@@ -1042,13 +1042,13 @@
/* Common Control Register 1 */
#define HRTIM_CR1_MUDIS (1 << 0)
/* Bit 0 */
/* Bit 0
: Master Update Disable
#define HRTIM_CR1_TAUDIS (1 << 1)
/* Bit 1 */
/* Bit 1
: Timer A Update Disable
#define HRTIM_CR1_TBUDIS (1 << 2)
/* Bit 2 */
/* Bit 2
: Timer B Update Disable
#define HRTIM_CR1_TCUDIS (1 << 3)
/* Bit 3 */
/* Bit 3
: Timer C Update Disable
#define HRTIM_CR1_TDUDIS (1 << 4)
/* Bit 4 */
/* Bit 4
: Timer D Update Disable
#define HRTIM_CR1_TEUDIS (1 << 5)
/* Bit 5 */
/* Bit 5
: Timer E Update Disable
#define HRTIM_CR1_AD1USRC_SHIFT 16
/* Bits 16-18 */
/* Bits 16-18
: ADC Trigger 1 Update Source
#define HRTIM_CR1_AD1USRC_MASK (7 << HRTIM_CR1_AD1USRC_SHIFT)
# define HRTIM_CR1_AD1USRC_MT (0 << HRTIM_CR1_AD1USRC_SHIFT)
/* 000: Mater Timer */
# define HRTIM_CR1_AD1USRC_TA (1 << HRTIM_CR1_AD1USRC_SHIFT)
/* 001: Timer A */
/* 001: Timer A */
@@ -1056,7 +1056,7 @@
# define HRTIM_CR1_AD1USRC_TC (3 << HRTIM_CR1_AD1USRC_SHIFT)
/* 011: Timer C */
/* 011: Timer C */
# define HRTIM_CR1_AD1USRC_TD (4 << HRTIM_CR1_AD1USRC_SHIFT)
/* 100: Timer D */
/* 100: Timer D */
# define HRTIM_CR1_AD1USRC_TE (5 << HRTIM_CR1_AD1USRC_SHIFT)
/* 101: Timer A */
/* 101: Timer A */
#define HRTIM_CR1_AD2USRC_SHIFT 19
/* Bits 19-21 */
/* Bits 19-21
: ADC Trigger 2 Update Source
#define HRTIM_CR1_AD2USRC_MASK (7 << HRTIM_CR1_AD2USRC_SHIFT)
# define HRTIM_CR1_AD2USRC_MT (0 << HRTIM_CR1_AD2USRC_SHIFT)
# define HRTIM_CR1_AD2USRC_TA (1 << HRTIM_CR1_AD2USRC_SHIFT)
/* 001: Timer A */
/* 001: Timer A */
@@ -1064,7 +1064,7 @@
# define HRTIM_CR1_AD2USRC_TC (3 << HRTIM_CR1_AD2USRC_SHIFT)
/* 011: Timer C */
/* 011: Timer C */
# define HRTIM_CR1_AD2USRC_TD (4 << HRTIM_CR1_AD2USRC_SHIFT)
/* 100: Timer D */
/* 100: Timer D */
# define HRTIM_CR1_AD2USRC_TE (5 << HRTIM_CR1_AD2USRC_SHIFT)
/* 101: Timer A */
/* 101: Timer A */
#define HRTIM_CR1_AD3USRC_SHIFT 22
/* Bits 22-24 */
/* Bits 22-24
: ADC Trigger 3 Update Source
#define HRTIM_CR1_AD3USRC_MASK (7 << HRTIM_CR1_AD3USRC_SHIFT)
# define HRTIM_CR1_AD3USRC_MT (0 << HRTIM_CR1_AD3USRC_SHIFT)
# define HRTIM_CR1_AD3USRC_TA (1 << HRTIM_CR1_AD3USRC_SHIFT)
/* 001: Timer A */
/* 001: Timer A */
@@ -1072,7 +1072,7 @@
# define HRTIM_CR1_AD3USRC_TC (3 << HRTIM_CR1_AD3USRC_SHIFT)
/* 011: Timer C */
/* 011: Timer C */
# define HRTIM_CR1_AD3USRC_TD (4 << HRTIM_CR1_AD3USRC_SHIFT)
/* 100: Timer D */
/* 100: Timer D */
# define HRTIM_CR1_AD3USRC_TE (5 << HRTIM_CR1_AD3USRC_SHIFT)
/* 101: Timer A */
/* 101: Timer A */
#define HRTIM_CR1_AD4USRC_SHIFT 25
/* Bits 25-27 */
/* Bits 25-27
: ADC Trigger 4 Update Source
#define HRTIM_CR1_AD4USRC_MASK (7 << HRTIM_CR1_AD4USRC_SHIFT)
# define HRTIM_CR1_AD4USRC_MT (0 << HRTIM_CR1_AD4USRC_SHIFT)
# define HRTIM_CR1_AD4USRC_TA (1 << HRTIM_CR1_AD4USRC_SHIFT)
/* 001: Timer A */
/* 001: Timer A */
arch/arm/src/stm32/stm32_1wire.c
View file @
7d7b8a24
@@ -981,15 +981,12 @@ static int stm32_1wire_isr(int irq, void *context, void *arg)
stm32_1wire_send
priv
READ_TX
stm32_1wire_send
priv
READ_TX
break
break
case
ONEWIRETASK_WRITEBIT
priv
byte
0
priv
msgs
NULL
priv
result
OK
nxsem_post
priv
sem_isr
break
case
ONEWIRETASK_READBIT
case
ONEWIRETASK_READBIT
priv
byte
dr
READ_RX1
1
0
priv
byte
dr
READ_RX1
1
0
/* Fall through */
case
priv
msgs
NULL
priv
msgs
NULL
priv
result
OK
priv
result
OK
nxsem_post
priv
sem_isr
nxsem_post
priv
sem_isr
arch/arm/src/stm32/stm32_hrtim.c
View file @
7d7b8a24
* arch/arm/src/stm32/stm32_hrtim.c
* Copyright (C) 2017 Gregory Nutt. All rights reserved.
-2018
* Author: Mateusz Szafoni <raiden00@railab.me>
* Redistribution and use in source and binary forms, with or without
@@ -57,8 +57,6 @@
@@ -57,8 +57,6 @@
#if defined(CONFIG_STM32_STM32F33XX)
#warning "HRTIM UNDER DEVELOPMENT !"
#if defined(CONFIG_STM32_HRTIM_TIMA_PWM) || defined(CONFIG_STM32_HRTIM_TIMA_DAC) || \
defined(CONFIG_STM32_HRTIM_TIMA_CAP) || defined(CONFIG_STM32_HRTIM_TIMA_IRQ) || \
defined(CONFIG_STM32_HRTIM_TIMA_DT) || defined(CONFIG_STM32_HRTIM_TIMA_CHOP)
@@ -231,11 +229,6 @@
/* HRTIM default configuration **********************************************/
#ifndef HRTIM_MASTER_PRESCALER
# warning "HRTIM_MASTER_PRESCALER is not set. Set the default value HRTIM_PRESCALER_2"
# define HRTIM_MASTER_PRESCALER HRTIM_PRESCALER_2
#endif
#if defined(CONFIG_STM32_HRTIM_MASTER) && !defined(HRTIM_MASTER_MODE)
# warning "HRTIM_MASTER_MODE is not set. Set the default value 0"
# define HRTIM_MASTER_MODE 0
@@ -3604,7 +3597,46 @@ errout:
static
uint16_t
hrtim_deadtime_get
FAR
struct
hrtim_dev_s
dev
uint8_t
timer
static
uint16_t
hrtim_deadtime_get
FAR
struct
hrtim_dev_s
dev
uint8_t
timer
uint8_t
dt
uint8_t
dt
#warning missing logic
FAR
struct
stm32_hrtim_s
priv
FAR
struct
stm32_hrtim_s
dev
hd_priv
uint16_t
regval
0
uint32_t
shift
0
uint32_t
mask
0
/* Get shift value */
switch
dt
case
HRTIM_DT_EDGE_RISING
shift
HRTIM_TIMDT_DTR_SHIFT
mask
HRTIM_TIMDT_DTR_MASK
break
case
HRTIM_DT_EDGE_FALLING
shift
HRTIM_TIMDT_DTF_SHIFT
mask
HRTIM_TIMDT_DTF_MASK
break
default:
regval
0
goto
errout
/* Get Deadtime Register */
regval
hrtim_tim_getreg
priv
timer
STM32_HRTIM_TIM_DTR_OFFSET
/* Get Deadtime value */
regval
regval
mask
shift
errout:
return
regval
arch/arm/src/stm32/stm32_hrtim.h
View file @
7d7b8a24
@@ -212,6 +212,8 @@
@@ -212,6 +212,8 @@
(hrtim)->hd_ops->cmp_update(hrtim, tim, index, cmp)
#define HRTIM_PER_SET(hrtim, tim, per) \
(hrtim)->hd_ops->per_update(hrtim, tim, per)
#define HRTIM_REP_SET(hrtim, tim, per) \
(hrtim)->hd_ops->rep_update(hrtim, tim, per)
#define HRTIM_PER_GET(hrtim, tim) \
(hrtim)->hd_ops->per_get(hrtim, tim)
#define HRTIM_FCLK_GET(hrtim, tim) \
arch/arm/src/stm32/stm32f30xxx_rcc.c
View file @
7d7b8a24
@@ -660,6 +660,18 @@ static void stm32_stdclockconfig(void)
#endif
#endif
#if defined(CONFIG_RTC_LSECLOCK)
/* Normally peripheral clocks are enabled later in bootup, but we need
* clock on PWR *now* as without this setting registers that enable LSE
* won't work.
* NOTE: In this configuration, we can assume the CONFIG_STM32_PWR has
* been selected.
regval
getreg32
STM32_RCC_APB1ENR
regval
RCC_APB1ENR_PWREN
putreg32
regval
STM32_RCC_APB1ENR
/* Low speed external clock source LSE
* TODO: There is another case where the LSE needs to
arch/arm/src/stm32/stm32f33xxx_adc.c
View file @
7d7b8a24
@@ -119,6 +119,10 @@
# define ADC2_HAVE_JEXTSEL
#endif
#endif
#if defined(CONFIG_STM32_ADC_NOIRQ) && defined(ADC_HAVE_DMA)
# error "ADC DMA support requires common ADC interrupts"
#endif
/* RCC reset ****************************************************************/
#define STM32_RCC_RSTR STM32_RCC_AHBRSTR
@@ -162,10 +166,13 @@
#define ADC_MAX_CHANNELS_DMA 16
#define ADC_MAX_CHANNELS_NOIRQ 16
#define ADC_MAX_CHANNELS_NODMA 1
#ifdef
ADC_HAVE_DMA
#if
def
ined(
ADC_HAVE_DMA
# define ADC_REG_MAX_SAMPLES ADC_MAX_CHANNELS_DMA
#elif defined(CONFIG_STM32_ADC_NOIRQ)
# define ADC_REG_MAX_SAMPLES ADC_MAX_CHANNELS_NOIRQ
#else
#else
# define ADC_REG_MAX_SAMPLES ADC_MAX_CHANNELS_NODMA
#endif
#endif
@@ -1911,7 +1918,7 @@ static uint32_t adc_sqrbits(FAR struct stm32_dev_s *priv, int first, int last,
i
priv
rnchannels
i
last
i
priv
rnchannels
i
last
i
offset
ADC_SQ_OFFSET
i
offset
ADC_SQ_OFFSET
bits
uint32_t
priv
r_chanlist
i
offset
bits
uint32_t
priv
r_chanlist
i
offset
return
bits
return
bits
arch/arm/src/stm32f7/chip/stm32f72xx73xx_gpio.h
View file @
7d7b8a24
arch/arm/src/stm32l4/stm32l4_1wire.c
View file @
7d7b8a24
@@ -906,15 +906,12 @@ static int stm32_1wire_isr(int irq, void *context, void *arg)
stm32_1wire_send
priv
READ_TX
stm32_1wire_send
priv
READ_TX
break
break
case
priv
byte
0
priv
msgs
NULL
priv
result
OK
nxsem_post
priv
sem_isr
break
case
ONEWIRETASK_READBIT
case
ONEWIRETASK_READBIT
priv
byte
dr
READ_RX1
1
0
priv
byte
dr
READ_RX1
1
0
/* Fall through */
case
priv
msgs
NULL
priv
msgs
NULL
priv
result
OK
priv
result
OK
nxsem_post
priv
sem_isr
nxsem_post
priv
sem_isr
arch/arm/src/tiva/Kconfig
View file @
7d7b8a24
@@ -107,13 +107,6 @@ config ARCH_CHIP_TM4C129XNC
select ARCH_CHIP_TM4C
select ARCH_CHIP_TM4C129
select TIVA_HAVE_ETHERNET
config ARCH_CHIP_CC3200
bool "CC3200"
depends on ARCH_CHIP_TIVA
select ARCH_CORTEXM4
select TIVA_HAVE_I2C1
endchoice
endchoice
# Chip families
# Chip families
@@ -546,6 +539,22 @@ config TIVA_FLASH
endmenu
endmenu
config TIVA_RAMVBAR
bool "Set VBAR"
default n
---help---
Set the ARM VBAR register to position interrupt vectors at the
beginning of RAM (vs the beginning of FLASH). The beginning of RAM
is that address defined by CONFIG_RAM_START.
config TIVA_BOARD_CLOCKCONFIG
bool "Board-specific clock configuration"
default n
---help---
If CONFIG_TIVA_BOARD_CLOCKCONFIG is defined, then the board-specific
logic must provide the function tiva_board_clockconfig(). That
function will then be called to perform all clock initialization.
menu "Enable GPIO Interrupts"
config TIVA_GPIO_IRQS
arch/arm/src/tiva/chip/cc3200_memorymap.h
deleted
100644 → 0
View file @
49644be9
* arch/arm/src/tiva/chip/cc3200_memorymap.h
* Copyright (C) 2014 Droidifi LLC. All rights reserved.
* Jim Ewing <jim@droidifi.com>
* Adapted for the cc3200 from code:
* Copyright (C) Gregory Nutt.
* Gregory Nutt <gnutt@nuttx.org>
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name Droidifi nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#ifndef __ARCH_ARM_SRC_TIVA_CHIP_CC3200_MEMORYMAP_H
#define __ARCH_ARM_SRC_TIVA_CHIP_CC3200_MEMORYMAP_H
* Included Files
#include
<nuttx/config.h>
* Pre-processor Definitions
/* Memory map ***********************************************************************/
#if defined(CONFIG_ARCH_CHIP_CC3200)
# define TIVA_FLASH_BASE 0x00000000
/* -0x0007ffff: On-chip FLASH */
/* -0x00ffffff: Reserved */
# define TIVA_ROM_BASE 0x01000000
/* -0x1fffffff: Reserved for ROM */
# define TIVA_SRAM_BASE 0x20000000
/* -0x2003ffff: Bit-banded on-chip SRAM */
/* -0x21ffffff: Reserved */
# define TIVA_ASRAM_BASE 0x22000000
/* -0x23ffffff: Bit-band alias of 20000000- */
/* -0x3fffffff: Reserved */
# define TIVA_PERIPH_BASE 0x40000000
/* -0x4001ffff: FiRM Peripherals */
/* -0x41ffffff: Peripherals */
# define TIVA_APERIPH_BASE 0x42000000
/* -0x43ffffff: Bit-band alias of 40000000- */
# define TIVA_CRYPTO_BASE 0x44030000
/* -0x44039fff: Crypto HW base 44030000- */
/* -0xdfffffff: Reserved */
# define TIVA_ITM_BASE 0xe0000000
/* -0xe0000fff: Instrumentation Trace Macrocell */
# define TIVA_DWT_BASE 0xe0001000
/* -0xe0001fff: Data Watchpoint and Trace */
# define TIVA_FPB_BASE 0xe0002000
/* -0xe0002fff: Flash Patch and Breakpoint */
/* -0xe000dfff: Reserved */
# define TIVA_NVIC_BASE 0xe000e000
/* -0xe000efff: Nested Vectored Interrupt Controller */
/* -0xe003ffff: Reserved */
# define TIVA_TPIU_BASE 0xe0040000
/* -0xe0040fff: Trace Port Interface Unit */
# define TIVA_ETM_BASE 0xe0041000
/* -0xe0041fff: Embedded Trace Macrocell */
/* -0xffffffff: Reserved */
#else
# error "Memory map not specified for this TM4C chip"
#endif
/* Peripheral base addresses ********************************************************/
# define TIVA_WDOG0_BASE (TIVA_PERIPH_BASE + 0x00000)
/* -0x00fff: Watchdog Timer 0 */
# define TIVA_GPIOA_BASE (TIVA_PERIPH_BASE + 0x04000)
/* -0x04fff: GPIO Port A */
# define TIVA_GPIOB_BASE (TIVA_PERIPH_BASE + 0x05000)
/* -0x05fff: GPIO Port B */
# define TIVA_GPIOC_BASE (TIVA_PERIPH_BASE + 0x06000)
/* -0x06fff: GPIO Port C */
# define TIVA_GPIOD_BASE (TIVA_PERIPH_BASE + 0x07000)
/* -0x07fff: GPIO Port D */
# define TIVA_UART0_BASE (TIVA_PERIPH_BASE + 0x0c000)
/* -0x0cfff: UART0 */
# define TIVA_UART1_BASE (TIVA_PERIPH_BASE + 0x0d000)
/* -0x0dfff: UART1 */
# define TIVA_I2C0_BASE (TIVA_PERIPH_BASE + 0x20000)
/* -0x207ff: I2C0 */
# define TIVA_TIMER0_BASE (TIVA_PERIPH_BASE + 0x30000)
/* -0x30fff: 16/32 Timer 0 */
# define TIVA_TIMER1_BASE (TIVA_PERIPH_BASE + 0x31000)
/* -0x31fff: 16/32 Timer 1 */
# define TIVA_TIMER2_BASE (TIVA_PERIPH_BASE + 0x32000)
/* -0x32fff: 16/32 Timer 2 */
# define TIVA_TIMER3_BASE (TIVA_PERIPH_BASE + 0x33000)
/* -0x33fff: 16/32 Timer 3 */
// NOTE: ADC memory location not listed in CC3200 DS
# define TIVA_ADC0_BASE (TIVA_PERIPH_BASE + 0x38000)
/* -0x38fff: ADC 0 */
# define TIVA_CONF_REG (TIVA_PERIPH_BASE + 0xf7000)
/* -0xf7fff: Configuration registers */
# define TIVA_SYSCON_BASE (TIVA_PERIPH_BASE + 0xfe000)
/* -0xfefff: System Control */
# define TIVA_UDMA_BASE (TIVA_PERIPH_BASE + 0xff000)
/* -0xfffff: Micro Direct Memory Access */
# define TIVA_ASP_A0 (TIVA_PERIPH_BASE + 0x401c000)
/* -0x401efff: McASP A0 */
# define TIVA_SPI_A0 (TIVA_PERIPH_BASE + 0x4020000)
/* -0x4020fff: McSPI A0 */
# define TIVA_SPI_A1 (TIVA_PERIPH_BASE + 0x4021000)
/* -0x4022fff: McSPI A1 */
# define TIVA_APP_CLK_BASE (TIVA_PERIPH_BASE + 0x4025000)
/* -0x4025fff: App Clk */
# define TIVA_APP_CFG_BASE (TIVA_PERIPH_BASE + 0x4026000)
/* -0x4026fff: App config */
# define TIVA_OCP_GPRCM_BASE (TIVA_PERIPH_BASE + 0x402d000)
/* -0x402dfff: global reset, pwr, clk */
# define TIVA_OCP_SHR_BASE (TIVA_PERIPH_BASE + 0x402e000)
/* -0x402efff: OCP shared config */
# define TIVA_HIBERNATE_BASE (TIVA_PERIPH_BASE + 0x402f000)
/* -0x402ffff: Hibernation Controller */
/* Crypto Base Addresses */
# define TIVA_TCP_DTHE_BASE (TIVA_CRYPTO_BASE + 0x0000)
/* -0x0fff: TCP Checksum & DTHE regs */
# define TIVA_CCM_BASE TIVA_TCP_DTHE_BASE
# define TIVA_SHA_BASE (TIVA_CRYPTO_BASE + 0x5000)
/* -0x5fff: MD5/SHA */
# define TIVA_AES_BASE (TIVA_CRYPTO_BASE + 0x7000)
/* -0x7fff: AES */
# define TIVA_DES_BASE (TIVA_CRYPTO_BASE + 0x9000)
/* -0x9fff: DES */
// NOTE: the following locations are not listed in CC3200 DS
# define TIVA_GPIOAAHB_BASE (TIVA_PERIPH_BASE + 0x58000)
/* -0x58fff: GPIO Port A (AHB aperture) */
# define TIVA_GPIOBAHB_BASE (TIVA_PERIPH_BASE + 0x59000)
/* -0x59fff: GPIO Port B (AHB aperture) */
# define TIVA_GPIOCAHB_BASE (TIVA_PERIPH_BASE + 0x5a000)
/* -0x5afff: GPIO Port C (AHB aperture) */
# define TIVA_GPIODAHB_BASE (TIVA_PERIPH_BASE + 0x5b000)
/* -0x5bfff: GPIO Port D (AHB aperture) */
# define TIVA_EPI0_BASE (TIVA_PERIPH_BASE + 0xd0000)
/* -0xd0fff: EPI 0 */
# define TIVA_EEPROM_BASE (TIVA_PERIPH_BASE + 0xaf000)
/* -0xaffff: EEPROM and Key Locker */
# define TIVA_SYSEXC_BASE (TIVA_PERIPH_BASE + 0xf9000)
/* -0xf9fff: System Exception Control */
# define TIVA_FLASHCON_BASE (TIVA_PERIPH_BASE + 0xfd000)
/* -0xfdfff: FLASH Control */
#else
# error "Peripheral base addresses not specified for this Stellaris chip"
#endif
* Public Types
* Public Data
* Public Function Prototypes
#endif
/* __ARCH_ARM_SRC_TIVA_CHIP_CC3200_MEMORYMAP_H */
arch/arm/src/tiva/chip/cc3200_pinmap.h
deleted
100644 → 0
View file @
49644be9
* arch/arm/src/tiva/chip/cc3200_pinmap.h
* Author: Jim Ewing <jim@droidifi.com>
* are met:
* distribution.
#ifndef __ARCH_ARM_SRC_TIVA_CHIP_CC3200_PINMAP_H
#define __ARCH_ARM_SRC_TIVA_CHIP_CC3200_PINMAP_H
* Included Files
#include
<nuttx/config.h>
# define GPIO_ADC_IN0 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_3)
# define GPIO_ADC_IN1 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_2)
# define GPIO_ADC_IN2 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_1)
# define GPIO_ADC_IN3 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_0)
# define GPIO_ADC_IN4 (GPIO_FUNC_ANINPUT | GPIO_PORTD | GPIO_PIN_3)
# define GPIO_ADC_IN5 (GPIO_FUNC_ANINPUT | GPIO_PORTD | GPIO_PIN_2)
# define GPIO_ADC_IN6 (GPIO_FUNC_ANINPUT | GPIO_PORTD | GPIO_PIN_1)
# define GPIO_ADC_IN7 (GPIO_FUNC_ANINPUT | GPIO_PORTD | GPIO_PIN_0)
# define GPIO_ADC_IN8 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_5)
# define GPIO_ADC_IN9 (GPIO_FUNC_ANINPUT | GPIO_PORTE | GPIO_PIN_4)
# define GPIO_ADC_IN10 (GPIO_FUNC_ANINPUT | GPIO_PORTB | GPIO_PIN_4)
# define GPIO_ADC_IN11 (GPIO_FUNC_ANINPUT | GPIO_PORTB | GPIO_PIN_5)
# define GPIO_CORE_TRCLK (GPIO_FUNC_PFOUTPUT | GPIO_ALT_14 | GPIO_PADTYPE_ODWPU | GPIO_PORTF | GPIO_PIN_3)
# define GPIO_CORE_TRD0 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_14 | GPIO_PADTYPE_ODWPU | GPIO_PORTF | GPIO_PIN_2)
# define GPIO_CORE_TRD1 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_14 | GPIO_PADTYPE_ODWPU | GPIO_PORTF | GPIO_PIN_1)
# define GPIO_I2C0_SCL (GPIO_FUNC_PFOUTPUT | GPIO_ALT_3 | GPIO_PORTB | GPIO_PIN_2)
# define GPIO_I2C0_SDA (GPIO_FUNC_PFODIO | GPIO_ALT_3 | GPIO_PORTB | GPIO_PIN_3)
# define GPIO_I2C1_SCL (GPIO_FUNC_PFOUTPUT | GPIO_ALT_3 | GPIO_PORTA | GPIO_PIN_6)
# define GPIO_I2C1_SDA (GPIO_FUNC_PFODIO | GPIO_ALT_3 | GPIO_PORTA | GPIO_PIN_7)
# define GPIO_I2C2_SCL (GPIO_FUNC_PFOUTPUT | GPIO_ALT_3 | GPIO_PORTE | GPIO_PIN_4)
# define GPIO_I2C2_SDA (GPIO_FUNC_PFODIO | GPIO_ALT_3 | GPIO_PORTE | GPIO_PIN_5)
# define GPIO_I2C3_SCL (GPIO_FUNC_PFOUTPUT | GPIO_ALT_3 | GPIO_PORTD | GPIO_PIN_0)
# define GPIO_I2C3_SDA (GPIO_FUNC_PFODIO | GPIO_ALT_3 | GPIO_PORTD | GPIO_PIN_1)
# define GPIO_JTAG_SWCLK (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_0)
# define GPIO_JTAG_SWDIO (GPIO_FUNC_PFIO | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_1)
# define GPIO_JTAG_SWO (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_3)
# define GPIO_JTAG_TCK (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_0)
# define GPIO_JTAG_TDI (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_2)
# define GPIO_JTAG_TDO (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_3)
# define GPIO_JTAG_TMS (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTC | GPIO_PIN_1)
# define GPIO_SYSCON_NMI_1 (GPIO_FUNC_PFINPUT | GPIO_ALT_8 | GPIO_PORTD | GPIO_PIN_7)
# define GPIO_SYSCON_NMI_2 (GPIO_FUNC_PFINPUT | GPIO_ALT_8 | GPIO_PORTF | GPIO_PIN_0)
# define GPIO_TIM0_CCP0_1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_6)
# define GPIO_TIM0_CCP0_2 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTF | GPIO_PIN_0)
# define GPIO_TIM0_CCP1_1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_7)
# define GPIO_TIM0_CCP1_2 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTF | GPIO_PIN_1)
# define GPIO_TIM1_CCP0_1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_4)
# define GPIO_TIM1_CCP0_2 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTF | GPIO_PIN_2)
# define GPIO_TIM1_CCP1_1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_5)
# define GPIO_TIM1_CCP1_2 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTF | GPIO_PIN_3)
# define GPIO_TIM2_CCP0_1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_0)
# define GPIO_TIM2_CCP0_2 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTF | GPIO_PIN_4)
# define GPIO_TIM2_CCP1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_1)
# define GPIO_TIM3_CCP0 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTB | GPIO_PIN_2)
# define GPIO_TIM4_CCP1 (GPIO_FUNC_PFIO | GPIO_ALT_7 | GPIO_PORTC | GPIO_PIN_1)
# define GPIO_UART0_RX (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTA | GPIO_PIN_0)
# define GPIO_UART0_TX (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTA | GPIO_PIN_1)
# define GPIO_UART1_RX (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTA | GPIO_PIN_0)
# define GPIO_UART1_TX (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTA | GPIO_PIN_1)
# define GPIO_UART1_CTS_1 (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTF | GPIO_PIN_1)
# define GPIO_UART1_CTS_2 (GPIO_FUNC_PFINPUT | GPIO_ALT_8 | GPIO_PORTC | GPIO_PIN_5)
# define GPIO_UART1_RTS_1 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTF | GPIO_PIN_0)
# define GPIO_UART1_RTS_2 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_8 | GPIO_PORTC | GPIO_PIN_4)
# define GPIO_UART1_RX_1 (GPIO_FUNC_PFINPUT | GPIO_ALT_1 | GPIO_PORTB | GPIO_PIN_0)
# define GPIO_UART1_RX_2 (GPIO_FUNC_PFINPUT | GPIO_ALT_2 | GPIO_PORTC | GPIO_PIN_4)
# define GPIO_UART1_TX_1 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_1 | GPIO_PORTB | GPIO_PIN_1)
# define GPIO_UART1_TX_2 (GPIO_FUNC_PFOUTPUT | GPIO_ALT_2 | GPIO_PORTC | GPIO_PIN_5)
#else
# error "Unknown TIVA chip"
#endif
* Public Types
* Public Data
#endif
/* __ARCH_ARM_SRC_TIVA_CHIP_CC3200_PINMAP_H */
arch/arm/src/tiva/chip/cc3200_syscontrol.h
deleted
100644 → 0
View file @
49644be9
This diff is collapsed.
arch/arm/src/tiva/chip/cc3200_vectors.h
deleted
100644 → 0
View file @
49644be9
* arch/arm/src/tiva/chip/cc3200_vectors.h
* are met:
* distribution.
* Vectors
/* This file is included by tiva_vectors.S. It provides the macro VECTOR that
* supplies each Tiva vector in terms of a (lower-case) ISR label and an
* (upper-case) IRQ number as defined in arch/arm/include/tiva/tm4c_irq.h.
* tiva_vectors.S will define the VECTOR in different ways in order to generate
* the interrupt vectors and handlers in their final form.
/* If the common ARMv7-M vector handling is used, then all it needs is the following
* definition that provides the number of supported vectors.
# ifdef CONFIG_ARMV7M_CMNVECTOR
/* Reserve 155 interrupt table entries for I/O interrupts. */
ARMV7M_PERIPHERAL_INTERRUPTS
155
# else
VECTOR
tiva_gpioa
TIVA_IRQ_GPIOA
/* Vector 16: GPIO Port A */
VECTOR
tiva_gpiob
TIVA_IRQ_GPIOB
/* Vector 17: GPIO Port B */
VECTOR
tiva_gpioc
TIVA_IRQ_GPIOC
/* Vector 18: GPIO Port C */
VECTOR
tiva_gpiod
TIVA_IRQ_GPIOD
/* Vector 19: GPIO Port D */
UNUSED
TIVA_RESERVED_20
/* Vector 20: Reserved */
VECTOR
tiva_uart0
TIVA_IRQ_UART0
/* Vector 21: UART 0 */
VECTOR
tiva_uart1
TIVA_IRQ_UART1
/* Vector 22: UART 1 */
UNUSED
TIVA_RESERVED_23
/* Vector 23: Reserved */
VECTOR
tiva_i2c0
TIVA_IRQ_I2C0
/* Vector 24: I2C 0 */
UNUSED
TIVA_RESERVED_25
/* Vector 25: Reserved */
UNUSED
TIVA_RESERVED_26
/* Vector 26: Reserved */
UNUSED
TIVA_RESERVED_27
/* Vector 27: Reserved */
UNUSED
TIVA_RESERVED_28
/* Vector 28: Reserved */
UNUSED
TIVA_RESERVED_29
/* Vector 29: Reserved */
VECTOR
tiva_adc0
TIVA_IRQ_ADC0
/* Vector 30: ADC Sequence 0 */
VECTOR
tiva_adc1
TIVA_IRQ_ADC1
/* Vector 31: ADC Sequence 1 */
VECTOR
tiva_adc2
TIVA_IRQ_ADC2
/* Vector 32: ADC Sequence 2 */
VECTOR
tiva_adc3
TIVA_IRQ_ADC3
/* Vector 33: ADC Sequence 3 */
VECTOR
tiva_wdog
TIVA_IRQ_WDOG
/* Vector 34: Watchdog Timers 0 and 1 */
VECTOR
tiva_timer0a
TIVA_IRQ_TIMER0A
/* Vector 35: 16/32-Bit Timer 0 A */
VECTOR
tiva_timer0b
TIVA_IRQ_TIMER0B
/* Vector 36: 16/32-Bit Timer 0 B */
VECTOR
tiva_timer1a
TIVA_IRQ_TIMER1A
/* Vector 37: 16/32-Bit Timer 1 A */
VECTOR
tiva_timer1b
TIVA_IRQ_TIMER1B
/* Vector 38: 16/32-Bit Timer 1 B */
VECTOR
tiva_timer2a
TIVA_IRQ_TIMER2A
/* Vector 39: 16/32-Bit Timer 2 A */
VECTOR
tiva_timer2b
TIVA_IRQ_TIMER2B
/* Vector 40: 16/32-Bit Timer 2 B */
UNUSED
TIVA_RESERVED_41
/* Vector 41: Reserved */
UNUSED
TIVA_RESERVED_42
/* Vector 42: Reserved */
UNUSED
TIVA_RESERVED_43
/* Vector 43: Reserved */
VECTOR
tiva_syscon
TIVA_IRQ_SYSCON
/* Vector 44: System Control */
VECTOR
tiva_flashcon
TIVA_IRQ_FLASHCON
/* Vector 45: FLASH and EEPROM Control */
UNUSED
TIVA_RESERVED_46
/* Vector 46: Reserved */
UNUSED
TIVA_RESERVED_47
/* Vector 47: Reserved */
UNUSED
TIVA_RESERVED_48
/* Vector 48: Reserved */
UNUSED
TIVA_RESERVED_49
/* Vector 49: Reserved */
UNUSED
TIVA_RESERVED_50
/* Vector 50: Reserved */
VECTOR
tiva_timer3a
TIVA_IRQ_TIMER3A
/* Vector 51: 16/32-Bit Timer 3 A */
VECTOR
tiva_timer3b
TIVA_IRQ_TIMER3B
/* Vector 52: 16/32-Bit Timer 3 B */
UNUSED
TIVA_RESERVED_53
/* Vector 53: Reserved */
UNUSED
TIVA_RESERVED_54
/* Vector 54: Reserved */
UNUSED
TIVA_RESERVED_55
/* Vector 55: Reserved */
UNUSED
TIVA_RESERVED_56
/* Vector 56: Reserved */
UNUSED
TIVA_RESERVED_57
/* Vector 57: Reserved */
UNUSED
TIVA_RESERVED_58
/* Vector 58: Reserved */
VECTOR
tiva_hibernate
TIVA_IRQ_HIBERNATE
/* Vector 59: Hibernation Module */
UNUSED
TIVA_RESERVED_60
/* Vector 60: Reserved */
UNUSED
TIVA_RESERVED_61
/* Vector 61: Reserved */
VECTOR
tiva_udmasoft
TIVA_IRQ_UDMASOFT
/* Vector 62: uDMA Software */
VECTOR
tiva_udmaerro
TIVA_IRQ_UDMAERROR
/* Vector 63: uDMA Error */
UNUSED
TIVA_RESERVED_64
/* Vector 64: Reserved */
UNUSED
TIVA_RESERVED_65
/* Vector 65: Reserved */
UNUSED
TIVA_RESERVED_66
/* Vector 66: Reserved */
UNUSED
TIVA_RESERVED_67
/* Vector 67: Reserved */
VECTOR
tiva_i2s0
TIVA_IRQ_I2S0
/* Vector 68: I2S 0 */
VECTOR
tiva_epi
TIVA_IRQ_EPI
/* Vector 69: EPI */
UNUSED
TIVA_RESERVED_70
/* Vector 70: Reserved */
UNUSED
TIVA_RESERVED_71
/* Vector 71: Reserved */
UNUSED
TIVA_RESERVED_72
/* Vector 72: Reserved */
UNUSED
TIVA_RESERVED_73
/* Vector 73: Reserved */
UNUSED
TIVA_RESERVED_74
/* Vector 74: Reserved */
UNUSED
TIVA_RESERVED_75
/* Vector 75: Reserved */
UNUSED
TIVA_RESERVED_76
/* Vector 76: Reserved */
UNUSED
TIVA_RESERVED_77
/* Vector 77: Reserved */
UNUSED
TIVA_RESERVED_78
/* Vector 78: Reserved */
UNUSED
TIVA_RESERVED_79
/* Vector 79: Reserved */
UNUSED
TIVA_RESERVED_80
/* Vector 80: Reserved */
UNUSED
TIVA_RESERVED_81
/* Vector 81: Reserved */
UNUSED
TIVA_RESERVED_82
/* Vector 82: Reserved */
UNUSED
TIVA_RESERVED_83
/* Vector 83: Reserved */
UNUSED
TIVA_RESERVED_84
/* Vector 84: Reserved */
UNUSED
TIVA_RESERVED_85
/* Vector 85: Reserved */
UNUSED
TIVA_RESERVED_86
/* Vector 86: Reserved */
UNUSED
TIVA_RESERVED_87
/* Vector 87: Reserved */
UNUSED
TIVA_RESERVED_88
/* Vector 88: Reserved */
UNUSED
TIVA_RESERVED_89
/* Vector 89: Reserved */
UNUSED
TIVA_RESERVED_90
/* Vector 90: Reserved */
UNUSED
TIVA_RESERVED_91
/* Vector 91: Reserved */
UNUSED
TIVA_RESERVED_92
/* Vector 92: Reserved */
UNUSED
TIVA_RESERVED_93
/* Vector 93: Reserved */
UNUSED
TIVA_RESERVED_94
/* Vector 94: Reserved */
UNUSED
TIVA_RESERVED_95
/* Vector 95: Reserved */
UNUSED
TIVA_RESERVED_96
/* Vector 96: Reserved */
UNUSED
TIVA_RESERVED_97
/* Vector 97: Reserved */
UNUSED
TIVA_RESERVED_98
/* Vector 98: Reserved */
UNUSED
TIVA_RESERVED_99
/* Vector 99: Reserved */
UNUSED
TIVA_RESERVED_100
/* Vector 100: Reserved */
UNUSED
TIVA_RESERVED_101
/* Vector 101: Reserved */
UNUSED
TIVA_RESERVED_102
/* Vector 102: Reserved */
UNUSED
TIVA_RESERVED_103
/* Vector 103: Reserved */
UNUSED
TIVA_RESERVED_104
/* Vector 104: Reserved */
UNUSED
TIVA_RESERVED_105
/* Vector 105: Reserved */
UNUSED
TIVA_RESERVED_106
/* Vector 106: Reserved */
UNUSED
TIVA_RESERVED_107
/* Vector 107: Reserved */
UNUSED
TIVA_RESERVED_108
/* Vector 108: Reserved */
UNUSED
TIVA_RESERVED_109
/* Vector 109: Reserved */
UNUSED
TIVA_RESERVED_110
/* Vector 110: Reserved */
UNUSED
TIVA_RESERVED_111
/* Vector 111: Reserved */
UNUSED
TIVA_RESERVED_112
/* Vector 112: Reserved */
UNUSED
TIVA_RESERVED_113
/* Vector 113: Reserved */
UNUSED
TIVA_RESERVED_114
/* Vector 114: Reserved */
UNUSED
TIVA_RESERVED_115
/* Vector 115: Reserved */
UNUSED
TIVA_RESERVED_116
/* Vector 116: Reserved */
UNUSED
TIVA_RESERVED_117
/* Vector 117: Reserved */
UNUSED
TIVA_RESERVED_118
/* Vector 118: Reserved */
UNUSED
TIVA_RESERVED_119
/* Vector 119: Reserved */
UNUSED
TIVA_RESERVED_120
/* Vector 120: Reserved */
UNUSED
TIVA_RESERVED_121
/* Vector 121: Reserved */
VECTOR
tiva_system
TIVA_IRQ_SYSTEM
/* Vector 122: System Exception (imprecise) */
UNUSED
TIVA_RESERVED_123
/* Vector 123: Reserved */
UNUSED
TIVA_RESERVED_124
/* Vector 124: Reserved */
UNUSED
TIVA_RESERVED_125
/* Vector 125: Reserved */
UNUSED
TIVA_RESERVED_126
/* Vector 126: Reserved */
UNUSED
TIVA_RESERVED_127
/* Vector 127: Reserved */
UNUSED
TIVA_RESERVED_128
/* Vector 128: Reserved */
UNUSED
TIVA_RESERVED_129
/* Vector 129: Reserved */
UNUSED
TIVA_RESERVED_130
/* Vector 130: Reserved */
UNUSED
TIVA_RESERVED_131
/* Vector 131: Reserved */
UNUSED
TIVA_RESERVED_132
/* Vector 132: Reserved */
UNUSED
TIVA_RESERVED_133
/* Vector 133: Reserved */
UNUSED
TIVA_RESERVED_134
/* Vector 134: Reserved */
UNUSED
TIVA_RESERVED_135
/* Vector 135: Reserved */
UNUSED
TIVA_RESERVED_136
/* Vector 136: Reserved */
UNUSED
TIVA_RESERVED_137
/* Vector 137: Reserved */
UNUSED
TIVA_RESERVED_138
/* Vector 138: Reserved */
UNUSED
TIVA_RESERVED_139
/* Vector 139: Reserved */
UNUSED
TIVA_RESERVED_140
/* Vector 140: Reserved */
UNUSED
TIVA_RESERVED_141
/* Vector 141: Reserved */
UNUSED
TIVA_RESERVED_142
/* Vector 142: Reserved */
UNUSED
TIVA_RESERVED_143
/* Vector 143: Reserved */
UNUSED
TIVA_RESERVED_144
/* Vector 144: Reserved */
UNUSED
TIVA_RESERVED_145
/* Vector 145: Reserved */
UNUSED
TIVA_RESERVED_146
/* Vector 146: Reserved */
UNUSED
TIVA_RESERVED_147
/* Vector 147: Reserved */
UNUSED
TIVA_RESERVED_148
/* Vector 148: Reserved */
UNUSED
TIVA_RESERVED_149
/* Vector 149: Reserved */
UNUSED
TIVA_RESERVED_150
/* Vector 150: Reserved */
UNUSED
TIVA_RESERVED_151
/* Vector 151: Reserved */
UNUSED
TIVA_RESERVED_152
/* Vector 152: Reserved */
UNUSED
TIVA_RESERVED_153
/* Vector 153: Reserved */
UNUSED
TIVA_RESERVED_154
/* Vector 154: Reserved */
UNUSED
TIVA_RESERVED_155
/* Vector 155: Reserved */
UNUSED
TIVA_RESERVED_156
/* Vector 156: Reserved */
UNUSED
TIVA_RESERVED_157
/* Vector 157: Reserved */
UNUSED
TIVA_RESERVED_158
/* Vector 158: Reserved */
UNUSED
TIVA_RESERVED_159
/* Vector 159: Reserved */
UNUSED
TIVA_RESERVED_160
/* Vector 160: Reserved */
UNUSED
TIVA_RESERVED_161
/* Vector 161: Reserved */
UNUSED
TIVA_RESERVED_162
/* Vector 162: Reserved */
UNUSED
TIVA_RESERVED_163
/* Vector 163: Reserved */
UNUSED
TIVA_RESERVED_164
/* Vector 164: SHA HW */
UNUSED
TIVA_RESERVED_165
/* Vector 165: Reserved */
UNUSED
TIVA_RESERVED_166
/* Vector 166: Reserved */
UNUSED
TIVA_RESERVED_167
/* Vector 167: AES HW */
UNUSED
TIVA_RESERVED_168
/* Vector 168: Reserved */
UNUSED
TIVA_RESERVED_169
/* Vector 169: DES HW */
UNUSED
TIVA_RESERVED_170
/* Vector 170: Reserved */
UNUSED
TIVA_RESERVED_171
/* Vector 171: Reserved */
UNUSED
TIVA_RESERVED_172
/* Vector 172: Reserved */
UNUSED
TIVA_RESERVED_173
/* Vector 173: Reserved */
UNUSED
TIVA_RESERVED_174
/* Vector 174: Reserved */
UNUSED
TIVA_RESERVED_175
/* Vector 175: SDIO */
UNUSED
TIVA_RESERVED_176
/* Vector 176: Reserved */
UNUSED
TIVA_RESERVED_177
/* Vector 177: McASP 0 */
UNUSED
TIVA_RESERVED_178
/* Vector 178: Reserved */
UNUSED
TIVA_RESERVED_179
/* Vector 179: Camera A0 */
UNUSED
TIVA_RESERVED_180
/* Vector 180: Reserved */
UNUSED
TIVA_RESERVED_181
/* Vector 181: Reserved */
UNUSED
TIVA_RESERVED_182
/* Vector 182: Reserved */
UNUSED
TIVA_RESERVED_183
/* Vector 183: Reserved */
UNUSED
TIVA_RESERVED_184
/* Vector 184: RAM Err */
UNUSED
TIVA_RESERVED_185
/* Vector 185: Reserved */
UNUSED
TIVA_RESERVED_186
/* Vector 186: Reserved */
UNUSED
TIVA_RESERVED_187
/* Vector 187: NWP IC interocessor comm */
UNUSED
TIVA_RESERVED_188
/* Vector 188: Pwr, Rst, Clk */
UNUSED
TIVA_RESERVED_189
/* Vector 189: From Top Die */
UNUSED
TIVA_RESERVED_190
/* Vector 190: Reserved */
UNUSED
TIVA_RESERVED_191
/* Vector 191: SPI S0 */
UNUSED
TIVA_RESERVED_192
/* Vector 192: SPI A0 */
UNUSED
TIVA_RESERVED_193
/* Vector 193: SPI A1 */
UNUSED
TIVA_RESERVED_194
/* Vector 194: Reserved */
# endif
/* CONFIG_ARMV7M_CMNVECTOR */
#else
# error "Vectors not known for this Tiva chip"
#endif
/* defined(CONFIG_ARCH_CHIP_CC3200) */
arch/arm/src/tiva/chip/lm3s_flash.h
View file @
7d7b8a24
@@ -50,8 +50,7 @@
@@ -50,8 +50,7 @@
#if defined(CONFIG_ARCH_CHIP_LM3S6965) || defined(CONFIG_ARCH_CHIP_LM4F120) || \
defined(CONFIG_ARCH_CHIP_LM3S8962) || defined(CONFIG_ARCH_CHIP_LM3S9B96) || \
defined(CONFIG_ARCH_CHIP_TM4C123GH6ZRB) || defined(CONFIG_ARCH_CHIP_TM4C123GH6PMI) || \
/* These parts all support a 1KiB erase page size and a total FLASH memory size
* of 256Kib or 256 pages.
arch/arm/src/tiva/chip/tiva_memorymap.h
View file @
7d7b8a24
@@ -50,8 +50,6 @@
@@ -50,8 +50,6 @@
# include "chip/lm4f_memorymap.h"
#elif defined(CONFIG_ARCH_CHIP_TM4C)
# include "chip/tm4c_memorymap.h"
#elif defined(CONFIG_ARCH_CHIP_CC3200)
# include "chip/cc3200_memorymap.h"
#else
#else
# error "Unsupported Tiva/Stellaris memory map"
#endif
#endif
arch/arm/src/tiva/chip/tiva_pinmap.h
View file @
7d7b8a24
@@ -50,8 +50,6 @@
@@ -50,8 +50,6 @@
# include "chip/lm4f_pinmap.h"
# include "chip/tm4c_pinmap.h"
# include "chip/cc3200_pinmap.h"
#else
#else
# error "Unsupported Tiva/Stellaris PIN mapping"
#endif
#endif
Prev
1
2
3
4
5
6
7
8
15
Next
