Skip to content
Commits on Source (3)
...@@ -84,6 +84,7 @@ struct ieee802154_txdesc_s ...@@ -84,6 +84,7 @@ struct ieee802154_txdesc_s
enum ieee802154_frametype_e frametype; enum ieee802154_frametype_e frametype;
bool ackreq; /* Are we requesting an ACK? */
bool framepending; /* Did the ACK have the frame pending bit set */ bool framepending; /* Did the ACK have the frame pending bit set */
uint32_t purgetime; /* Time to purge transaction */ uint32_t purgetime; /* Time to purge transaction */
uint8_t retrycount; /* Number of remaining retries. Set to macMaxFrameRetries uint8_t retrycount; /* Number of remaining retries. Set to macMaxFrameRetries
...@@ -441,7 +441,7 @@ static void mac802154_notify_worker(FAR void *arg) ...@@ -441,7 +441,7 @@ static void mac802154_notify_worker(FAR void *arg)
if (cb->notify != NULL) if (cb->notify != NULL)
ret = cb->notify(cb, primitive); ret = cb->notify(cb, primitive);
if (ret <= 0) if (ret < 0)
ieee802154_primitive_free(primitive); ieee802154_primitive_free(primitive);
...@@ -258,6 +258,7 @@ int mac802154_req_data(MACHANDLE mac, ...@@ -258,6 +258,7 @@ int mac802154_req_data(MACHANDLE mac,
txdesc->conf->handle = meta->handle; txdesc->conf->handle = meta->handle;
txdesc->frame = frame; txdesc->frame = frame;
txdesc->frametype = IEEE802154_FRAME_DATA; txdesc->frametype = IEEE802154_FRAME_DATA;
txdesc->ackreq = meta->flags.ackreq;
/* If the TxOptions parameter specifies that a GTS transmission is required, /* If the TxOptions parameter specifies that a GTS transmission is required,
* the MAC sublayer will determine whether it has a valid GTS as described * the MAC sublayer will determine whether it has a valid GTS as described
...@@ -116,6 +116,7 @@ enum mac802154_operation_e ...@@ -116,6 +116,7 @@ enum mac802154_operation_e
MAC802154_OP_POLL, MAC802154_OP_POLL,
MAC802154_OP_SCAN, MAC802154_OP_SCAN,
MAC802154_OP_AUTOEXTRACT, MAC802154_OP_AUTOEXTRACT,
MAC802154_OP_RXENABLE,
/* The privmac structure holds the internal state of the MAC and is the /* The privmac structure holds the internal state of the MAC and is the
...@@ -701,7 +702,6 @@ static inline void mac802154_rxdisable(FAR struct ieee802154_privmac_s *priv) ...@@ -701,7 +702,6 @@ static inline void mac802154_rxdisable(FAR struct ieee802154_privmac_s *priv)
if (priv->nrxusers == 0) if (priv->nrxusers == 0)
wlinfo("Receiver disabled\n"); wlinfo("Receiver disabled\n");
priv->radio->rxenable(priv->radio, true);
priv->radio->rxenable(priv->radio, false); priv->radio->rxenable(priv->radio, false);
...@@ -51,11 +51,51 @@ ...@@ -51,11 +51,51 @@
#include <string.h> #include <string.h>
#include "mac802154.h" #include "mac802154.h"
#include "mac802154_internal.h"
#include <nuttx/wireless/ieee802154/ieee802154_mac.h> #include <nuttx/wireless/ieee802154/ieee802154_mac.h>
* Public MAC Functions * Private Function Prototypes
static void mac802154_rxenabletimeout(FAR void *arg);
* Private Functions
* Name: mac802154_rxenabletimeout
* Description:
* Function registered with MAC timer that gets called via the work queue to
* handle a timeout for extracting the Association Response from the Coordinator.
FAR struct ieee802154_privmac_s *priv = (FAR struct ieee802154_privmac_s *)arg;
while(mac802154_lock(priv, true) != 0);
if (priv->curr_op != MAC802154_OP_RXENABLE)
mac802154_unlock(priv);
return;
mac802154_rxdisable(priv);
priv->curr_op = MAC802154_OP_NONE;
mac802154_givesem(&priv->opsem);
* Public Functions
...@@ -72,9 +112,87 @@ ...@@ -72,9 +112,87 @@
int mac802154_req_rxenable(MACHANDLE mac, int mac802154_req_rxenable(MACHANDLE mac,
FAR struct ieee802154_rxenable_req_s *req) FAR struct ieee802154_rxenable_req_s *req)
#if 0
FAR struct ieee802154_privmac_s * priv = FAR struct ieee802154_privmac_s * priv =
(FAR struct ieee802154_privmac_s *)mac; (FAR struct ieee802154_privmac_s *)mac;
#endif int ret;
return -ENOTTY;
/* If this is a Beacon-enabled network */
if (priv->sfspec.sforder < 15)
return -EINVAL;
goto errout_with_sem;
/* Non-beacon enabled network */
else
if (req->rxon_dur > 0)
/* Get exlusive access to the operation sempaphore. This must happen before
* getting exclusive access to the MAC struct or else there could be a lockup
* condition. This would occur if another thread is using the cmdtrans but
* needs access to the MAC in order to unlock it.
ret = mac802154_takesem(&priv->opsem, true);
if (ret < 0)
return ret;
priv->curr_op = MAC802154_OP_RXENABLE;
/* Get exclusive access to the MAC */
ret = mac802154_lock(priv, true);
if (ret < 0)
/* Should only fail if interrupted by a signal */
wlwarn("WARNING: mac802154_takesem failed: %d\n", ret);
return ret;
mac802154_rxenable(priv);
if (req->rxon_dur != 0xFFFFFFFF)
mac802154_timerstart(priv, req->rxon_dur, mac802154_rxenabletimeout);
else
if (ret < 0)
return ret;
ret = -EINVAL;
mac802154_timercancel(priv);
return OK;
errout_with_sem:
return ret;
\ No newline at end of file
