Skip to content
Commits on Source (4)
...@@ -74,7 +74,14 @@ ...@@ -74,7 +74,14 @@
#define NRF52_GPIO0_DIR (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIR_OFFSET) #define NRF52_GPIO0_DIR (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIR_OFFSET)
#define NRF52_GPIO0_DIRSET (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIRSET_OFFSET) #define NRF52_GPIO0_DIRSET (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIRSET_OFFSET)
#define NRF52_GPIO0_DIRCLR (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIRCLR_OFFSET) #define NRF52_GPIO0_DIRCLR (NRF52_GPIO_P0_BASE + NRF52_GPIO_DIRCLR_OFFSET)
#define NRF52_GPIO0_CNF(n) (NRF52_GPIO_P0_BASE + NRF52_GPIO_PIN_CNF_OFFSET(n))
/* Register bit definitions *********************************************************/ /* Register bit definitions *********************************************************/
#define NRF52_GPIO_CNF_PULL_SHIFT (2)
#define NRF52_GPIO_CNF_PULL_MASK (0x3 << NRF52_GPIO_CNF_PULL_SHIFT)
# define NRF52_GPIO_CNF_PULL_DISABLED (0 << NRF52_GPIO_CNF_PULL_SHIFT)
# define NRF52_GPIO_CNF_PULL_DOWN (1 << NRF52_GPIO_CNF_PULL_SHIFT)
# define NRF52_GPIO_CNF_PULL_UP (3 << NRF52_GPIO_CNF_PULL_SHIFT)
#endif /* __ARCH_ARM_SRC_NRF52_CHIP_NRF52_GPIO_H */ #endif /* __ARCH_ARM_SRC_NRF52_CHIP_NRF52_GPIO_H */
...@@ -69,7 +69,7 @@ static inline void nrf52_gpio_input(unsigned int port, unsigned int pin) ...@@ -69,7 +69,7 @@ static inline void nrf52_gpio_input(unsigned int port, unsigned int pin)
if (port == 0) if (port == 0)
putreg32(1 << pin, NRF52_GPIO0_DIRCLR); putreg32(1U << pin, NRF52_GPIO0_DIRCLR);
...@@ -90,10 +90,43 @@ static inline void nrf52_gpio_output(nrf52_pinset_t cfgset, ...@@ -90,10 +90,43 @@ static inline void nrf52_gpio_output(nrf52_pinset_t cfgset,
putreg32(1 << pin, NRF52_GPIO0_DIRSET); putreg32(1U << pin, NRF52_GPIO0_DIRSET);
* Name: nrf52_gpio_mode
* Description:
* Configure a GPIO mode based on bit-encoded description of the pin.
static inline void nrf52_gpio_mode(nrf52_pinset_t cfgset,
uint32_t mode;
uint32_t regval;
mode = cfgset & GPIO_MODE_MASK;
regval = getreg32(NRF52_GPIO0_CNF(pin));
regval &= NRF52_GPIO_CNF_PULL_MASK;
if (mode == GPIO_PULLUP)
regval |= NRF52_GPIO_CNF_PULL_UP;
else if (mode == GPIO_PULLDOWN)
regval |= NRF52_GPIO_CNF_PULL_DOWN;
putreg32(regval, NRF52_GPIO0_CNF(pin));
* Public Functions * Public Functions
...@@ -131,7 +164,7 @@ int nrf52_gpio_config(nrf52_pinset_t cfgset) ...@@ -131,7 +164,7 @@ int nrf52_gpio_config(nrf52_pinset_t cfgset)
/* Set the mode bits */ /* Set the mode bits */
//nrf52_gpio_iocon(cfgset, port, pin); nrf52_gpio_mode(cfgset, port, pin);
/* Handle according to pin function */ /* Handle according to pin function */
...@@ -194,5 +227,11 @@ void nrf52_gpio_write(nrf52_pinset_t pinset, bool value) ...@@ -194,5 +227,11 @@ void nrf52_gpio_write(nrf52_pinset_t pinset, bool value)
bool nrf52_gpio_read(nrf52_pinset_t pinset) bool nrf52_gpio_read(nrf52_pinset_t pinset)
#warning Missing implementation! uint32_t regval;
unsigned int pin;
pin = (pinset & GPIO_PIN_MASK) >> GPIO_PIN_SHIFT;
regval = getreg32(NRF52_GPIO0_IN);
return (regval >> pin) & 1UL;
...@@ -112,9 +112,9 @@ ...@@ -112,9 +112,9 @@
#define GPIO_MODE_SHIFT (7) /* Bits 7-8: Pin pull-up mode */ #define GPIO_MODE_SHIFT (7) /* Bits 7-8: Pin pull-up mode */
#define GPIO_MODE_MASK (0x3 << GPIO_MODE_SHIFT) #define GPIO_MODE_MASK (0x3 << GPIO_MODE_SHIFT)
# define GPIO_FLOAT (GPIO_MODE_FLOAT << GPIO_MODE_SHIFT) /* Neither pull-up nor -down */ # define GPIO_FLOAT (0 << GPIO_MODE_SHIFT) /* Neither pull-up nor -down */
# define GPIO_PULLDOWN (GPIO_MODE_PULLDOWN << GPIO_MODE_SHIFT) /* Pull-down resistor enabled */ # define GPIO_PULLDOWN (1 << GPIO_MODE_SHIFT) /* Pull-down resistor enabled */
# define GPIO_PULLUP (GPIO_MODE_PULLUP << GPIO_MODE_SHIFT) /* Pull-up resistor enabled */ # define GPIO_PULLUP (2 << GPIO_MODE_SHIFT) /* Pull-up resistor enabled */
/* Initial value: V /* Initial value: V
* arch/arm/src/stm32/stm32_eth.c * arch/arm/src/stm32/stm32_eth.c
* Copyright (C) 2011-2012, 2014, 2016-2017 Gregory Nutt. All rights reserved. * Copyright (C) 2011-2012, 2014, 2016-2018 Gregory Nutt. All rights
* reserved.
* Author: Gregory Nutt <gnutt@nuttx.org> * Author: Gregory Nutt <gnutt@nuttx.org>
* Redistribution and use in source and binary forms, with or without * Redistribution and use in source and binary forms, with or without
...@@ -757,7 +758,7 @@ static inline void stm32_selectmii(void); ...@@ -757,7 +758,7 @@ static inline void stm32_selectmii(void);
static inline void stm32_selectrmii(void); static inline void stm32_selectrmii(void);
#endif #endif
static inline void stm32_ethgpioconfig(FAR struct stm32_ethmac_s *priv); static inline void stm32_ethgpioconfig(FAR struct stm32_ethmac_s *priv);
static void stm32_ethreset(FAR struct stm32_ethmac_s *priv); static int stm32_ethreset(FAR struct stm32_ethmac_s *priv);
static int stm32_macconfig(FAR struct stm32_ethmac_s *priv); static int stm32_macconfig(FAR struct stm32_ethmac_s *priv);
static void stm32_macaddress(FAR struct stm32_ethmac_s *priv); static void stm32_macaddress(FAR struct stm32_ethmac_s *priv);
#ifdef CONFIG_NET_ICMPv6 #ifdef CONFIG_NET_ICMPv6
...@@ -2392,6 +2393,7 @@ static int stm32_ifdown(struct net_driver_s *dev) ...@@ -2392,6 +2393,7 @@ static int stm32_ifdown(struct net_driver_s *dev)
FAR struct stm32_ethmac_s *priv = (FAR struct stm32_ethmac_s *)dev->d_private; FAR struct stm32_ethmac_s *priv = (FAR struct stm32_ethmac_s *)dev->d_private;
irqstate_t flags; irqstate_t flags;
int ret = OK;
ninfo("Taking the network down\n"); ninfo("Taking the network down\n");
...@@ -2410,13 +2412,18 @@ static int stm32_ifdown(struct net_driver_s *dev) ...@@ -2410,13 +2412,18 @@ static int stm32_ifdown(struct net_driver_s *dev)
* successfully brings the interface back up. * successfully brings the interface back up.
stm32_ethreset(priv); ret = stm32_ethreset(priv);
if (ret < 0)
nerr("ERROR: stm32_ethreset failed (timeout), "
"still assuming it's going down.\n");
/* Mark the device "down" */ /* Mark the device "down" */
priv->ifup = false; priv->ifup = false;
leave_critical_section(flags); leave_critical_section(flags);
return OK; return ret;
...@@ -3572,15 +3579,16 @@ static inline void stm32_ethgpioconfig(FAR struct stm32_ethmac_s *priv) ...@@ -3572,15 +3579,16 @@ static inline void stm32_ethgpioconfig(FAR struct stm32_ethmac_s *priv)
* priv - A reference to the private driver state structure * priv - A reference to the private driver state structure
* Returned Value: * Returned Value:
* None. * Zero on success, or a negated errno value on any failure.
* Assumptions: * Assumptions:
static void stm32_ethreset(FAR struct stm32_ethmac_s *priv) static int stm32_ethreset(FAR struct stm32_ethmac_s *priv)
uint32_t regval; uint32_t regval;
uint32_t retries;
/* Reset the Ethernet on the AHB bus (F1 Connectivity Line) or AHB1 bus (F2 /* Reset the Ethernet on the AHB bus (F1 Connectivity Line) or AHB1 bus (F2
* and F4) * and F4)
...@@ -3615,7 +3623,20 @@ static void stm32_ethreset(FAR struct stm32_ethmac_s *priv) ...@@ -3615,7 +3623,20 @@ static void stm32_ethreset(FAR struct stm32_ethmac_s *priv)
* after the reset operation has completed in all of the core clock domains. * after the reset operation has completed in all of the core clock domains.
while ((stm32_getreg(STM32_ETH_DMABMR) & ETH_DMABMR_SR) != 0); retries = 10;
while (((stm32_getreg(STM32_ETH_DMABMR) & ETH_DMABMR_SR) != 0) &&
retries > 0)
retries --;
up_mdelay(10);
if (retries == 0)
return -ETIMEDOUT;
return 0;
...@@ -3929,7 +3950,12 @@ static int stm32_ethconfig(FAR struct stm32_ethmac_s *priv) ...@@ -3929,7 +3950,12 @@ static int stm32_ethconfig(FAR struct stm32_ethmac_s *priv)
/* Reset the Ethernet block */ /* Reset the Ethernet block */
ninfo("Reset the Ethernet block\n"); ninfo("Reset the Ethernet block\n");
if (ret < 0)
nerr("ERROR: Reset of Ethernet block failed\n");
return ret;
/* Initialize the PHY */ /* Initialize the PHY */
...@@ -98,7 +98,19 @@ ...@@ -98,7 +98,19 @@
/* Button definitions *******************************************************/ /* Button definitions *******************************************************/
/* To be provided */ /* Board supports four buttons. */
#define BUTTON_BTN1 0
#define BUTTON_BTN2 1
#define BUTTON_BTN3 2
#define BUTTON_BTN4 3
#define NUM_BUTTONS 4
#define BUTTON_BTN1_BIT (1 << BUTTON_BTN1)
#define BUTTON_BTN2_BIT (1 << BUTTON_BTN2)
#define BUTTON_BTN3_BIT (1 << BUTTON_BTN3)
#define BUTTON_BTN4_BIT (1 << BUTTON_BTN4)
/* UART Pins ****************************************************************/ /* UART Pins ****************************************************************/
...@@ -48,4 +48,8 @@ else ...@@ -48,4 +48,8 @@ else
CSRCS += nrf52_userleds.c CSRCS += nrf52_userleds.c
endif endif
ifeq ($(CONFIG_ARCH_BUTTONS),y)
CSRCS += nrf52_buttons.c
endif
include $(TOPDIR)/configs/Board.mk include $(TOPDIR)/configs/Board.mk
...@@ -73,7 +73,12 @@ ...@@ -73,7 +73,12 @@
#define GPIO_LED4 (GPIO_OUTPUT | GPIO_VALUE_ONE | GPIO_PIN20) #define GPIO_LED4 (GPIO_OUTPUT | GPIO_VALUE_ONE | GPIO_PIN20)
/* to be provided */ /* Board supports four buttons. */
#define GPIO_BUTTON1 (GPIO_INPUT | GPIO_PULLUP | GPIO_PIN13)
#define GPIO_BUTTON2 (GPIO_INPUT | GPIO_PULLUP | GPIO_PIN14)
#define GPIO_BUTTON3 (GPIO_INPUT | GPIO_PULLUP | GPIO_PIN15)
#define GPIO_BUTTON4 (GPIO_INPUT | GPIO_PULLUP | GPIO_PIN16)
* Public Types * Public Types
* configs/nrf52-pca10400/src/nrf52_buttons.c
* Copyright (C) 2018 Gregory Nutt. All rights reserved.
* Author: Janne Rosberg <janne@offcode.fi>
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name NuttX nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* Included Files
#include <nuttx/config.h>
#include <stdint.h>
#include <errno.h>
#include <nuttx/arch.h>
#include <nuttx/board.h>
#include <arch/board/board.h>
#include "nrf52_gpio.h"
#include "nrf52-pca10040.h"
#ifdef CONFIG_ARCH_BUTTONS
* Private Data
/* Pin configuration for each PCA10400 button. This array is indexed by
* the BUTTON_* definitions in board.h
static const uint32_t g_buttons[NUM_BUTTONS] =
GPIO_BUTTON1,
GPIO_BUTTON2,
GPIO_BUTTON3,
GPIO_BUTTON4
* Public Functions
* Name: board_button_initialize
* Description:
* board_button_initialize() must be called to initialize button resources.
* After that, board_buttons() may be called to collect the current state
* of all buttons or board_button_irq() may be called to register button
* interrupt handlers.
void board_button_initialize(void)
int i;
/* Configure the GPIO pins as inputs. */
for (i = 0; i < NUM_BUTTONS; i++)
nrf52_gpio_config(g_buttons[i]);
* Name: board_buttons
uint32_t board_buttons(void)
uint32_t ret = 0;
/* Check that state of each key */
if (!nrf52_gpio_read(g_buttons[BUTTON_BTN1]))
ret |= BUTTON_BTN1_BIT;
if (!nrf52_gpio_read(g_buttons[BUTTON_BTN2]))
ret |= BUTTON_BTN2_BIT;
if (!nrf52_gpio_read(g_buttons[BUTTON_BTN3]))
ret |= BUTTON_BTN3_BIT;
if (!nrf52_gpio_read(g_buttons[BUTTON_BTN4]))
ret |= BUTTON_BTN4_BIT;
return ret;
* Button support.
* Description:
* After board_button_initialize() has been called, board_buttons() may be
* called to collect the state of all buttons. board_buttons() returns an
* 32-bit bit set with each bit associated with a button. See the
* BUTTON_*_BIT definitions in board.h for the meaning of each bit.
* board_button_irq() may be called to register an interrupt handler that
* will be called when a button is depressed or released. The ID value is
* a button enumeration value that uniquely identifies a button resource.
* See the BUTTON_* definitions in board.h for the meaning of enumeration
* value.
#ifdef CONFIG_ARCH_IRQBUTTONS
int board_button_irq(int id, xcpt_t irqhandler, FAR void *arg)
int ret = -ENOSYS;
#warning Missing Implementation!
return ret;
#endif
#endif /* CONFIG_ARCH_BUTTONS */
