Skip to content
GitLab
Explore
Sign in
Fabrice Salvaire
retrofit-singer
Compare revisions
713833341cd3addd2aeb0e1de85575318a8776a3 to 0a9257e65fb5b22d70f2a8249f0bd9678e75a4dd
Commits on Source (2)
fix
· 7ad987b9
Fabrice Salvaire
authored
Apr 27, 2021
7ad987b9
Merge branch 'fabrice-master-patch-85450' into 'master'
· 0a9257e6
Fabrice Salvaire
authored
Apr 27, 2021
fix See merge request
!1
0a9257e6
Show whitespace changes
Inline
Side-by-side
commercial-sewing-servo-motor.md
View file @
0a9257e6
@@ -3,11 +3,11 @@
@@ -3,11 +3,11 @@
## Motor and Driver Design
3-phase BLBC
3-phase BLBC
voltage: 220V
voltage: 220V
power: 400W, 550W 3/4hp, 750W 1hp
current: ~ 4A
current: ~ 4A
torque: ~ 1Nm soit 3kg pour une bielle de 30mm (1, 1.5, 2.5Nm)
speed: 5500rpm
speed: 5500rpm
diode bridge -> 560u -> 3x half-bridge IGBT with 15V gate driver
## Needle Position Sensor Design
@@ -17,12 +17,13 @@
@@ -17,12 +17,13 @@
2 cam discs for up and down position with optical fork
sensor frame is mounted on the machine or the table
sensor shaft is mounted on the threaded hole of the machine wheel
can require an adaptor
## Docs
## Docs
https://www.duerkopp-adler.com/commons/download/public/271/HVP-70-4-ED-2-CE_EN.pdf
https://www.duerkopp-adler.com/commons/download/public/271/HVP_70-4-ED-2-CE_FR.pdf
solenoid supply voltage 24 V or 30 V DC
https://globalsew.fr/wp-content/uploads/2017/01/SV-550-Manual.pdf
@@ -34,8 +35,8 @@
@@ -34,8 +35,8 @@
http://www.motor-chinese.com/product/Series-550-Sewing-machine-motor-Servo-motor-Induction-motor.html
Sewing Machine Servo Motor Circuit Board Repairing Tutorial
**avec video du pcb**
# 1
https://www.youtube.com/watch?v=VLQBiXaB66M
# 2
https://www.youtube.com/watch?v=XgmmhWFAbbY
## POWERMAX AHU27-55 (Moteur éléctronique pour machine à coudre industrielle)
