Skip to content
GitLab
Explore
Sign in
nats
kicad-components
Compare revisions
6d0c1ca9f315cce60c5ff47ca2f91fde377c6da7 to e8f883747504ce8f6b999aa5dbccef2e8b0fef12
Commits on Source (2)
added GVA-81+
· a50ebed9
Mehdi Khairy
authored
Jul 05, 2019
a50ebed9
Merge branch 'master' of code.electrolab.fr:nats/kicad-components
· e8f88374
Mehdi Khairy
authored
Jul 05, 2019
e8f88374
Show whitespace changes
Inline
Side-by-side
Amplifier/MiniCircuits/GVA.lib
0 → 100644
View file @
e8f88374
EESchema-LIBRARY Version 2.4
#encoding utf-8
# GVA-83+
DEF GVA-83+ U 0 40 Y N 1 F N
F0 "U" 0 150 25 H V C CNN
F1 "GVA-83+" 0 200 25 H V C CNN
F2 "MiniCircuits:DF782" -100 50 50 H I C CNN
F3 "" 0 0 50 H I C CNN
DRAW
P 4 0 1 0 -75 75 -75 -75 100 0 -75 75 N
X RFIN 1 -175 0 100 R 25 25 1 1 I
X GND 2 -25 -175 100 U 25 25 1 1 W
X RFOUTDC 3 200 0 100 L 25 25 1 1 O
X GND 4 25 -175 100 U 25 25 1 1 W
ENDDRAW
ENDDEF
#End Library
Pretty_Footprints/MiniCircuits.pretty/DF782.kicad_mod
0 → 100644
View file @
e8f88374
(module DF782 (layer F.Cu) (tedit 5D1F4917)
(fp_text reference REF** (at 0 -5) (layer F.SilkS)
(effects (font (size 0.635 0.635) (thickness 0.15)))
(fp_text value DF782 (at 0 -5) (layer F.Fab)
(effects (font (size 1 1) (thickness 0.15)))
(fp_line (start -2.8 -3.2) (end -2.8 -0.6) (layer F.SilkS) (width 0.15))
(fp_line (start -2.8 -0.6) (end 2.8 -0.6) (layer F.SilkS) (width 0.15))
(fp_line (start 2.8 -0.6) (end 2.8 -3.2) (layer F.SilkS) (width 0.15))
(fp_line (start 2.8 -3.2) (end -2.8 -3.2) (layer F.SilkS) (width 0.15))
(fp_circle (center -2.8 0.4) (end -2.8 0.2) (layer F.SilkS) (width 0.15))
(fp_line (start -3 -4.6) (end 3 -4.6) (layer F.CrtYd) (width 0.15))
(fp_line (start 3 -4.6) (end 3 0.9) (layer F.CrtYd) (width 0.15))
(fp_line (start 3 0.9) (end -3 0.9) (layer F.CrtYd) (width 0.15))
(fp_line (start -3 0.9) (end -3 -4.6) (layer F.CrtYd) (width 0.15))
(pad 1 smd rect (at -1.5 0) (size 0.71 1.5) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at 1.5 0) (size 0.71 1.5) (layers F.Cu F.Paste F.Mask))
(pad 2 smd custom (at 0 0) (size 0.71 1.5) (layers F.Cu F.Paste F.Mask)
(zone_connect 0)
(options (clearance outline) (anchor rect))
(primitives
(gr_poly (pts
(xy -0.46 0.75) (xy -0.46 -1.66) (xy -0.95 -2.41) (xy -0.95 -4.09) (xy -0.46 -4.58)
(xy 0.46 -4.58) (xy 0.95 -4.09) (xy 0.95 -2.413) (xy 0.46 -1.66) (xy 0.46 0.75)
) (width 0))
(pad 4 smd trapezoid (at 0 -4.33) (size 1.41 0.49) (rect_delta 0 0.49 ) (layers F.Cu F.Paste F.Mask))
