Commit 36461ffc authored by nats's avatar nats
added misc part
parent 4e37e19a
(module PinSocket_2x10_P2.54mm_Vertical (layer F.Cu) (tedit 5A19A427)
(descr "Through hole straight socket strip, 2x10, 2.54mm pitch, double cols (from Kicad 4.0.7), script generated")
(tags "Through hole socket strip THT 2x10 2.54mm double row")
(fp_text reference REF** (at -1.27 -2.77) (layer F.SilkS)
(effects (font (size 1 1) (thickness 0.15)))
(fp_text value PinSocket_2x10_P2.54mm_Vertical (at -1.27 25.63) (layer F.Fab)
(fp_line (start -3.81 -1.27) (end 0.27 -1.27) (layer F.Fab) (width 0.1))
(fp_line (start 0.27 -1.27) (end 1.27 -0.27) (layer F.Fab) (width 0.1))
(fp_line (start 1.27 -0.27) (end 1.27 24.13) (layer F.Fab) (width 0.1))
(fp_line (start 1.27 24.13) (end -3.81 24.13) (layer F.Fab) (width 0.1))
(fp_line (start -3.81 24.13) (end -3.81 -1.27) (layer F.Fab) (width 0.1))
(fp_line (start -3.87 -1.33) (end -1.27 -1.33) (layer F.SilkS) (width 0.12))
(fp_line (start -3.87 -1.33) (end -3.87 24.19) (layer F.SilkS) (width 0.12))
(fp_line (start -3.87 24.19) (end 1.33 24.19) (layer F.SilkS) (width 0.12))
(fp_line (start 1.33 1.27) (end 1.33 24.19) (layer F.SilkS) (width 0.12))
(fp_line (start -1.27 1.27) (end 1.33 1.27) (layer F.SilkS) (width 0.12))
(fp_line (start -1.27 -1.33) (end -1.27 1.27) (layer F.SilkS) (width 0.12))
(fp_line (start 1.33 -1.33) (end 1.33 0) (layer F.SilkS) (width 0.12))
(fp_line (start 0 -1.33) (end 1.33 -1.33) (layer F.SilkS) (width 0.12))
(fp_line (start -4.34 -1.8) (end 1.76 -1.8) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.76 -1.8) (end 1.76 24.6) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.76 24.6) (end -4.34 24.6) (layer F.CrtYd) (width 0.05))
(fp_line (start -4.34 24.6) (end -4.34 -1.8) (layer F.CrtYd) (width 0.05))
(pad 1 thru_hole rect (at 0 0) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 2 thru_hole oval (at -2.54 0) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 3 thru_hole oval (at 0 2.54) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 4 thru_hole oval (at -2.54 2.54) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 5 thru_hole oval (at 0 5.08) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 6 thru_hole oval (at -2.54 5.08) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 7 thru_hole oval (at 0 7.62) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 8 thru_hole oval (at -2.54 7.62) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 9 thru_hole oval (at 0 10.16) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 10 thru_hole oval (at -2.54 10.16) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 11 thru_hole oval (at 0 12.7) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 12 thru_hole oval (at -2.54 12.7) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 13 thru_hole oval (at 0 15.24) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 14 thru_hole oval (at -2.54 15.24) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 15 thru_hole oval (at 0 17.78) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 16 thru_hole oval (at -2.54 17.78) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 17 thru_hole oval (at 0 20.32) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 18 thru_hole oval (at -2.54 20.32) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 19 thru_hole oval (at 0 22.86) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(pad 20 thru_hole oval (at -2.54 22.86) (size 1.7 1.7) (drill 1) (layers *.Cu *.Mask))
(fp_text user %R (at -1.27 11.43 90) (layer F.Fab)
(model ${KISYS3DMOD}/Connector_PinSocket_2.54mm.3dshapes/PinSocket_2x10_P2.54mm_Vertical.wrl
(at (xyz 0 0 0))
(scale (xyz 1 1 1))
(rotate (xyz 0 0 0))
\ No newline at end of file
(module PowerPad_TSSOP_16 (layer F.Cu) (tedit 5CC4E3A8)
(attr smd)
(fp_text reference REF** (at -4 0 90) (layer F.SilkS)
(fp_text value PowerPad_TSSOP_16 (at 0 0) (layer F.Fab)
(fp_line (start -2.2 4.15) (end -3 3.35) (layer F.SilkS) (width 0.15))
(fp_line (start -3 3.35) (end -3 -4.15) (layer F.SilkS) (width 0.15))
(fp_line (start -3 -4.15) (end 3 -4.15) (layer F.SilkS) (width 0.15))
(fp_line (start 3 -4.15) (end 3 4.15) (layer F.SilkS) (width 0.15))
(fp_line (start 3 4.15) (end -2.2 4.15) (layer F.SilkS) (width 0.15))
(fp_line (start -3.15 -4.3) (end 3.15 -4.3) (layer F.CrtYd) (width 0.05))
(fp_line (start 3.15 -4.3) (end 3.15 4.3) (layer F.CrtYd) (width 0.05))
(fp_line (start 3.15 4.3) (end -3.15 4.3) (layer F.CrtYd) (width 0.05))
(fp_line (start -3.15 4.3) (end -3.15 -4.3) (layer F.CrtYd) (width 0.05))
(pad 16 smd rect (at -2.275 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 1 smd rect (at -2.275 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 15 smd rect (at -1.625 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at -1.625 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 14 smd rect (at -0.975 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at -0.975 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 13 smd rect (at -0.325 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at -0.325 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 12 smd rect (at 0.325 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 5 smd rect (at 0.325 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 11 smd rect (at 0.975 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 6 smd rect (at 0.975 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 10 smd rect (at 1.625 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 7 smd rect (at 1.625 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 9 smd rect (at 2.275 -2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 8 smd rect (at 2.275 2.9) (size 0.45 1.5) (layers F.Cu F.Paste F.Mask))
(pad 17 smd rect (at 0 0) (size 3.55 2.46) (layers F.Cu F.Paste F.Mask))
(module WE-HCI_SMD_5.6x5.3x4 (layer F.Cu) (tedit 5CC4D7DD)
(fp_text reference REF** (at -3.5 0 90) (layer F.SilkS)
(effects (font (size 0.635 0.635) (thickness 0.15)))
(fp_text value WE-HCI_SMD_5.6x5.3x4 (at 0 -0.5) (layer F.Fab)
(fp_line (start -2.6 -2.6) (end 2.6 -2.6) (layer F.SilkS) (width 0.15))
(fp_line (start 2.6 -2.6) (end 2.6 2.6) (layer F.SilkS) (width 0.15))
(fp_line (start 2.6 2.6) (end -2.6 2.6) (layer F.SilkS) (width 0.15))
(fp_line (start -2.6 2.6) (end -2.6 -2.6) (layer F.SilkS) (width 0.15))
(fp_line (start -2.6 -2.6) (end 2.6 -2.6) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.6 -2.6) (end 2.6 2.6) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.6 2.6) (end -2.6 2.6) (layer F.CrtYd) (width 0.15))
(fp_line (start -2.6 2.6) (end -2.6 -2.6) (layer F.CrtYd) (width 0.15))
(pad 1 smd rect (at 0 -2.05) (size 1.6 1.9) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at 0 2.05) (size 1.6 1.9) (layers F.Cu F.Paste F.Mask))
(module WE-LHMI_SMD_9.2x8.5x3 (layer F.Cu) (tedit 5CC4CB84)
(fp_text reference REF** (at 0 -5.8) (layer F.SilkS)
(fp_text value WE-LHMI_SMD_9.2x8.5x3 (at 0 -0.5) (layer F.Fab)
(fp_line (start 4.6 -4.3) (end 4.6 4.3) (layer F.SilkS) (width 0.15))
(fp_line (start 4.6 4.3) (end -4.6 4.3) (layer F.SilkS) (width 0.15))
(fp_line (start -4.6 4.3) (end -4.6 -4.3) (layer F.SilkS) (width 0.15))
(fp_line (start -4.6 -4.3) (end 4.6 -4.3) (layer F.SilkS) (width 0.15))
(fp_line (start -4.6 -4.3) (end 4.6 -4.3) (layer F.CrtYd) (width 0.15))
(fp_line (start 4.6 -4.3) (end 4.6 4.3) (layer F.CrtYd) (width 0.15))
(fp_line (start 4.6 4.3) (end -4.6 4.3) (layer F.CrtYd) (width 0.15))
(fp_line (start -4.6 4.3) (end -4.6 -4.2) (layer F.CrtYd) (width 0.15))
(fp_line (start -4.6 -4.2) (end -4.6 -4.3) (layer F.CrtYd) (width 0.15))
(fp_line (start -2 -4.2) (end -2 4.3) (layer F.SilkS) (width 0.15))
(fp_line (start 2 -4.3) (end 2 4.3) (layer F.SilkS) (width 0.15))
(fp_line (start 1.1 4.3) (end 2 3.4) (layer F.SilkS) (width 0.15))
(fp_line (start 0 4.3) (end 2 2.3) (layer F.SilkS) (width 0.15))
(fp_line (start -1 4.3) (end 2 1.3) (layer F.SilkS) (width 0.15))
(fp_line (start 0 -4.3) (end -2 -2.3) (layer F.SilkS) (width 0.15))
(fp_line (start -1.1 -4.3) (end -2 -3.4) (layer F.SilkS) (width 0.15))
(fp_line (start 1.1 -4.3) (end -2 -1.2) (layer F.SilkS) (width 0.15))
(pad 1 smd rect (at -3.62 0) (size 2.42 5.33) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at 3.62 0) (size 2.42 5.33) (layers F.Cu F.Paste F.Mask))
Markdown is supported
0%
or
Please register or to comment
