Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
K
kicad-components
Project
Project
Details
Activity
Releases
Cycle Analytics
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Charts
Issues
0
Issues
0
List
Board
Labels
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Charts
Registry
Registry
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Charts
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
nats
kicad-components
Commits
78c8bec4
Commit
78c8bec4
authored
Sep 26, 2019
by
Mehdi Khairy
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
adding a bunch of 3D models
parent
47db2da7
Changes
8
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
8 changed files
with
6418 additions
and
7 deletions
+6418
-7
2x2x0.75mm.step
3D_Models/Basic/2x2x0.75mm.step
+428
-0
3x3x0.85mm.step
3D_Models/Basic/3x3x0.85mm.step
+428
-0
5x5x1.3mm.step
3D_Models/Basic/5x5x1.3mm.step
+428
-0
142-0701-881.stp
3D_Models/Connectors_RF/142-0701-881.stp
+5112
-0
CINCH_142-0701-881.kicad_mod
...tprints/Connectors_RF.pretty/CINCH_142-0701-881.kicad_mod
+4
-4
DFN8_3x3mm.kicad_mod
Pretty_Footprints/QFN.pretty/DFN8_3x3mm.kicad_mod
+6
-1
PE42553QFN-4x4_EP_3x3_Pitch0.5mm.kicad_mod
...nts/QFN.pretty/PE42553QFN-4x4_EP_3x3_Pitch0.5mm.kicad_mod
+6
-1
SKY66292-11_QFN-4x4_EP_5x5_Pitch0.8mm.kicad_mod
...FN.pretty/SKY66292-11_QFN-4x4_EP_5x5_Pitch0.8mm.kicad_mod
+6
-1
No files found.
0 → 100644
View file @
78c8bec4
This diff is collapsed.
0 → 100644
View file @
78c8bec4
0 → 100644
View file @
78c8bec4
0 → 100644
View file @
78c8bec4
Pretty_Footprints/Connectors_RF.pretty/CINCH_142-0701-881.kicad_mod
View file @
78c8bec4
(module CINCH_142-0701-881 (layer F.Cu) (tedit 5
CDAB40D
D8C7C3A
(fp_text reference REF** (at 0 -4.25) (layer F.SilkS)
(effects (font (size 0.635 0.635) (thickness 0.15)))
@@ -16,9 +16,9 @@
@@ -16,9 +16,9 @@
(pad 1 smd rect (at 0 2.5) (size 1.1 5.08) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at 4.4 2.54) (size 1.5 5.08) (layers B.Cu B.Paste B.Mask))
(pad 2 smd rect (at -4.4 2.54) (size 1.5 5.08) (layers B.Cu B.Paste B.Mask))
(model ${CUSTLIB}/3D_Models/Connectors_RF/
SMA_CINCH_142-0701-801_complete.ste
p
142-0701-881.st
p
(offset (xyz 0 0.
4
0.4))
(offset (xyz 0 0.
35
0.4))
(scale (xyz 1 1 1))
(scale (xyz 1 1 1))
(rotate (xyz
90 -90
0))
(rotate (xyz
-90 0 -9
0))
View file @
78c8bec4
(module DFN8_3x3mm (layer F.Cu) (tedit 5
A242AC2
D8C77DB
(fp_text reference U** (at 0 -3.6) (layer F.SilkS)
(effects (font (size 1.2 1.2) (thickness 0.15)))
@@ -27,4 +27,9 @@
@@ -27,4 +27,9 @@
(pad 6 smd oval (at 1.6 0.25) (size 1 0.25) (layers F.Cu F.Paste F.Mask))
(pad 7 smd oval (at 1.6 -0.25) (size 1 0.25) (layers F.Cu F.Paste F.Mask))
(pad 8 smd oval (at 1.6 -0.75) (size 1 0.25) (layers F.Cu F.Paste F.Mask))
(model ${CUSTLIB}/3D_Models/Basic/3x3x0.85mm.step
(at (xyz 0 0 0))
(scale (xyz 1 1 1))
(rotate (xyz 0 0 0))
Pretty_Footprints/QFN.pretty/PE42553QFN-4x4_EP_3x3_Pitch0.5mm.kicad_mod
View file @
78c8bec4
(module PE42553QFN-4x4_EP_3x3_Pitch0.5mm (layer F.Cu) (tedit 5
CC03B49
D8C73AD
(attr smd)
(attr smd)
(fp_text reference REF** (at 0 -1.95) (layer F.SilkS)
(effects (font (size 1 1) (thickness 0.15)))
@@ -51,4 +51,9 @@
@@ -51,4 +51,9 @@
(pad 17 thru_hole circle (at -0.4375 0.4375) (size 0.4375 0.4375) (drill 0.3) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.4375 -0.4375) (size 0.4375 0.4375) (drill 0.3) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.4375 0.4375) (size 0.4375 0.4375) (drill 0.3) (layers *.Cu *.Mask))
(at (xyz 0 0 0))
(scale (xyz 1 1 1))
Pretty_Footprints/QFN.pretty/SKY66292-11_QFN-4x4_EP_5x5_Pitch0.8mm.kicad_mod
View file @
78c8bec4
(module SKY66292-11_QFN-4x4_EP_5x5_Pitch0.8mm (layer F.Cu) (tedit 5D
67A9A2
8C7576
(attr smd)
(attr smd)
(fp_text reference REF** (at 0 -2.3925) (layer F.SilkS)
@@ -65,4 +65,9 @@
@@ -65,4 +65,9 @@
(pad 17 thru_hole circle (at 0.956666 -0.956666) (size 0.478333 0.478333) (drill 0.25) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.956666 0) (size 0.478333 0.478333) (drill 0.25) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.956666 0.956666) (size 0.478333 0.478333) (drill 0.25) (layers *.Cu *.Mask))
(model ${CUSTLIB}/3D_Models/Basic/5x5x1.3mm.step
(at (xyz 0 0 0))
(scale (xyz 1 1 1))
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
