Skip to content
GitLab
Explore
Sign in
openEmbroidery
openEmbroidery_software
Compare revisions
9bbd62b78c22c919604b1f2bdb95d75d53fa0906 to 83fd57dd287beb33345e5de4a0276bde0d6abbde
Commits on Source (2)
fix a bug in deletion of selected stitch
· dc609a6a
authored
Dec 10, 2019
dc609a6a
add stitches reorder action in OE_actionStitchs (OE_actionMoveInListSelectedStitches)
· 83fd57dd
authored
Dec 11, 2019
add drag'n'drop stitch reorder within OE_ui_stitchlist
83fd57dd
Show whitespace changes
Inline
Side-by-side
include/OE_controller.h
View file @
83fd57dd
@@ -100,6 +100,8 @@ class OE_controller
bool
clearSelection
bool
clearSelection
BoundingBox
getSelectionBoundingBox
BoundingBox
bool
moveInListSelectedStitches
int
posPrevious
OE_actions
getLastAction
OE_actions
getLastAction
bool
editActionMovePointCurve
vector_2d
offset
bool
vector_2d
offset
bool
editActionMovePointLinkStitch
vector_2d
offset
bool
vector_2d
offset
include/actions/OE_actionsStitchs.h
View file @
83fd57dd
@@ -152,4 +152,21 @@ class OE_actionSetSelectedStitchPattern : public OE_actions
OE_actionSetSelectedFillStitchPattern
class
public
OE_actions
public:
OE_document
doc
int
posInsertion
virtual
virtual
void
undo
virtual
void
redo
protected:
std
list
OE_stitchs
actionStitches
std
list
OE_linkstitch
newLinkStitches
std
list
OE_linkstitch
oldLinkStitches
void
startNewBlock
std
list
OE_stitchs
list
OE_stitchs
stitch
src/OE_controller.cpp
View file @
83fd57dd
@@ -458,6 +458,16 @@ BoundingBox OE_controller::getSelectionBoundingBox()
return
boundingBox
return
boundingBox
bool
OE_controller
int
posPrevious
if
document
addAction
new
document
posPrevious
return
true
return
false
OE_actions
OE_controller
getLastAction
OE_actions
OE_controller
getLastAction
if
document
document
activeActionsStack
size
if
document
document
activeActionsStack
size
src/OE_interfaceDisplay.cpp
View file @
83fd57dd
@@ -357,7 +357,7 @@ void OE_interfaceDisplay::key(QKeyEvent* event)
else
if
event
key
Qt
Key_Delete
else
if
event
key
Qt
Key_Delete
//TODO create an action to delete all selected stitches
std
list
OE_stitchs
iterator
it
selectedStitch
e
s
begin
std
list
OE_stitchs
iterator
it
document
selectedStitchs
begin
controller
addAction
new
OE_actionDelStitch
document
it
controller
addAction
new
OE_actionDelStitch
document
it
update
update
emit
refreshStitchList
emit
refreshStitchList
src/actions/OE_actionsStitchs.cpp
View file @
83fd57dd
@@ -521,3 +521,162 @@ void OE_actionSetSelectedStitchPattern::redo()
active
true
active
true
///////// OE_actionShiftSelectedStitches ///////////////
OE_document
doc
int
posInsertion
OE_actions
doc
if
document
actionStitches
document
stitchs
std
list
OE_stitchs
tmpBeforeStitchList
std
list
OE_stitchs
tmpAfterStitchList
std
list
OE_stitchs
tmpSelectedStitchList
bool
selected
false
int
curIndex
0
// to always get good insertion point (just after a linkstitches)
posInsertion
posInsertion
1
//loop on every stitches, split before and after insertion and make a lists with selected ones
for
std
list
OE_stitchs
iterator
stitchIt
document
stitchs
begin
stitchIt
document
stitchs
end
stitchIt
curIndex
OE_linkstitch
linkStitch
dynamic_cast
OE_linkstitch
stitchIt
if
linkStitch
//check if the stitch is selected
auto
it
std
find
document
selectedStitchs
begin
document
selectedStitchs
end
stitchIt
if
it
document
selectedStitchs
end
//if we start a new selected block
if
selected
false
startNewBlock
stitchIt
selected
true
else
//if we start a new unselected block
if
selected
true
if
curIndex
posInsertion
startNewBlock
tmpBeforeStitchList
stitchIt
else
startNewBlock
tmpAfterStitchList
stitchIt
selected
false
//add the stitch to the corresponding list
if
selected
push_back
stitchIt
else
if
curIndex
posInsertion
//if we're before the insertion point
tmpBeforeStitchList
push_back
stitchIt
else
tmpAfterStitchList
push_back
stitchIt
//remove last linkstitch in each lists if needed
OE_linkstitch
linkStitch
dynamic_cast
OE_linkstitch
tmpBeforeStitchList
back
if
linkStitch
document
selectedStitchs
remove
linkStitch
oldLinkStitches
push_back
linkStitch
tmpBeforeStitchList
pop_back
linkStitch
dynamic_cast
OE_linkstitch
tmpAfterStitchList
back
if
linkStitch
document
selectedStitchs
remove
linkStitch
oldLinkStitches
push_back
linkStitch
tmpAfterStitchList
pop_back
linkStitch
dynamic_cast
OE_linkstitch
back
if
linkStitch
document
selectedStitchs
remove
linkStitch
oldLinkStitches
push_back
linkStitch
pop_back
//concatenate the lists
if
size
0
if
tmpBeforeStitchList
size
0
OE_linkstitch
link
new
OE_linkstitch
tmpBeforeStitchList
back
front
newLinkStitches
push_back
link
tmpBeforeStitchList
push_back
link
tmpBeforeStitchList
insert
tmpBeforeStitchList
end
begin
end
if
tmpAfterStitchList
size
0
OE_linkstitch
link
new
OE_linkstitch
tmpBeforeStitchList
back
tmpAfterStitchList
front
newLinkStitches
push_back
link
tmpBeforeStitchList
push_back
link
tmpBeforeStitchList
insert
tmpBeforeStitchList
end
tmpAfterStitchList
begin
tmpAfterStitchList
end
//then replace stitchlist in the document
document
stitchs
tmpBeforeStitchList
void
startNewBlock
std
list
OE_stitchs
list
OE_stitchs
stitch
if
list
size
0
//remove previous linkstitch
OE_linkstitch
linkStitch
dynamic_cast
OE_linkstitch
list
back
document
selectedStitchs
remove
linkStitch
oldLinkStitches
push_back
linkStitch
list
pop_back
//and make a new one
OE_linkstitch
link
new
OE_linkstitch
list
back
stitch
newLinkStitches
push_back
link
list
push_back
link
if
active
for
auto
stitch
oldLinkStitches
delete
stitch
else
for
auto
stitch
newLinkStitches
delete
stitch
void
undo
if
active
document
stitchs
switchVal
document
stitchs
actionStitches
active
false
void
redo
if
active
document
stitchs
switchVal
document
stitchs
actionStitches
active
true
src/qt/OE_ui_stitchlist.cpp
View file @
83fd57dd
@@ -152,6 +152,19 @@ void OE_ui_stitchList::handleSelectionChanged()
getInterfaceDisplay
update
getInterfaceDisplay
update
void
OE_ui_stitchList
dropEvent
QDropEvent
event
QModelIndex
index
indexAt
event
pos
DropIndicatorPosition
pos
this
dropIndicatorPosition
if
pos
BelowItem
getController
index
row
1
else
getController
index
row
getInterfaceDisplay
update
refreshStitches
void
OE_ui_stitchList
keyPressEvent
QKeyEvent
event
void
OE_ui_stitchList
keyPressEvent
QKeyEvent
event
if
event
key
Qt
Key_Right
if
event
key
Qt
Key_Right
src/qt/OE_ui_stitchlist.h
View file @
83fd57dd
@@ -29,6 +29,8 @@ private:
void
addItem
QColor
color
QIcon
icon
QIcon
type
QIcon
pattern
int
stitchCount
void
addItem
QColor
color
QIcon
icon
QIcon
type
QIcon
pattern
int
stitchCount
void
addItem
QColor
color
int
stitchCount
void
addItem
QColor
color
int
stitchCount
void
keyPressEvent
QKeyEvent
event
void
keyPressEvent
QKeyEvent
event
protected:
void
dropEvent
QDropEvent
event
private
slots
private
slots
void
on_refreshStitchList
void
void
on_refreshStitch
OE_stitchs
stitch
void
on_refreshStitch
OE_stitchs
stitch
