Skip to content
GitLab
Explore
Sign in
xtof
JOSAST
Compare revisions
9fd844f07591041a4bc7aeffd5ad1674e1be6942 to 200ac5b77ae3ac1837dfceccd7ccc0050fad3be6
Commits on Source (2)
feat : add json library
· 53230656
xtof
authored
Jan 16, 2021
53230656
feat : add transfert to latmos
· 200ac5b7
xtof
authored
Jan 16, 2021
200ac5b7
Show whitespace changes
Inline
Side-by-side
ApplicationDatabaseSynchronisation/pom.xml
View file @
200ac5b7
@@ -53,8 +53,15 @@
<groupId>
com.jcraft
</groupId>
<artifactId>
jsch
</artifactId>
<version>
0.1.55
</version>
</dependency>
<!-- https://mvnrepository.com/artifact/commons-io/commons-io -->
<dependency>
<groupId>
commons-io
</groupId>
<artifactId>
commons-io
</artifactId>
<version>
2.6
</version>
</dependency>
</dependencies>
<build>
<plugins>
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/AmsatToUvsqsatSyncConfig.java
0 → 100644
View file @
200ac5b7
package
org.josast.databaseSync
public
class
public
String
login
public
String
password
public
String
sftpUrl
public
String
amsatDatabaseUrl
public
String
sshUrl
public
String
deltaTime
public
String
satelliteNasaId
* @return the login
public
String
getLogin
return
login
* @param login the login to set
public
void
setLogin
String
login
this
login
login
* @return the password
public
String
getPassword
return
password
* @param password the password to set
public
void
setPassword
String
password
this
password
password
* @return the sftpUrl
public
String
getSftpUrl
return
sftpUrl
* @param sftpUrl the sftpUrl to set
public
void
setSftpUrl
String
sftpUrl
this
sftpUrl
sftpUrl
* @return the amsatDatabaseUrl
public
String
getAmsatDatabaseUrl
return
amsatDatabaseUrl
* @param amsatDatabaseUrl the amsatDatabaseUrl to set
public
void
setAmsatDatabaseUrl
String
amsatDatabaseUrl
this
amsatDatabaseUrl
amsatDatabaseUrl
* @return the sshUrl
public
String
getSshUrl
return
sshUrl
* @param sshUrl the sshUrl to set
public
void
setSshUrl
String
sshUrl
this
sshUrl
sshUrl
* @return the deltaTime
public
String
getDeltaTime
return
deltaTime
* @param deltaTime the deltaTime to set
public
void
setDeltaTime
String
deltaTime
this
deltaTime
deltaTime
* @return the satelliteNasaId
public
String
getSatelliteNasaId
return
satelliteNasaId
* @param satelliteNasaId the satelliteNasaId to set
public
void
setSatelliteNasaId
String
satelliteNasaId
this
satelliteNasaId
satelliteNasaId
@Override
public
String
toString
return
"AmsatToUvsqsatSyncConfig [login="
login
", password="
password
", sftpUrl="
sftpUrl
", amsatDatabaseUrl="
amsatDatabaseUrl
", sshUrl="
sshUrl
", deltaTime="
deltaTime
", satelliteNasaId="
satelliteNasaId
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/AppSynchroAmsatToUvsqsat.java
0 → 100644
View file @
200ac5b7
package
import
java.io.IOException
import
java.nio.file.Files
import
java.nio.file.Path
import
java.nio.file.Paths
import
java.nio.file.StandardOpenOption
import
java.text.SimpleDateFormat
import
java.util.Date
import
java.util.TimeZone
import
java.util.logging.Logger
import
org.josast.databaseSync.config.ManageJSonConfigFile
import
org.json.JSONObject
public
class
private
static
Logger
appLogger
Logger
getLogger
"AmsatLogger"
private
static
long
MN
1000
60
private
Path
filepath
private
String
RepositoryPath
"config"
private
config
new
private
String
fileIn
null
SimpleDateFormat
formater
new
SimpleDateFormat
"yyyy-MM-dd-HH-mm-ss.SSS"
public
void
execute
formater
setTimeZone
TimeZone
getTimeZone
"UTC"
// lecture de la configuration
mjcf
new
config
mjcf
readJson
new
// Récupération des données
GetDataFromAmsatDatabase
dataAmsatDb
new
config
getAmsatDatabaseUrl
Date
endDate
new
Date
long
temp
endDate
getTime
MN
Integer
parseInt
config
getDeltaTime
Date
startDate
new
Date
temp
DataToExchange
results
dataAmsatDb
getTelemetrydata
startDate
endDate
Integer
parseInt
config
getSatelliteNasaId
// et écriture dans un fichier
if
results
null
// file format 2020-12-21-17-42-19.409-Data.json
String
creationdate
formater
format
startDate
fileIn
creationdate
"-Data.json"
DataToUVSQsatControlCenter
dtc
new
results
fileIn
dtc
save
// Envoie du fichier vers Latmos
SendSftp
sfp
new
SendSftp
config
getSftpUrl
config
getLogin
config
getPassword
String
remotefile
"/toLATMOS/json/"
fileIn
String
localfile
fileIn
sfp
upload
localfile
remotefile
System
out
println
"Upload"
// efface fichier local.
try
Files
delete
Paths
get
fileIn
catch
IOException
e
// TODO Auto-generated catch block
e
printStackTrace
System
exit
0
public
int
SaveConfigFile
tlmData
int
erreur
0
SimpleDateFormat
formater
new
SimpleDateFormat
Date
aujourdhui
new
Date
JSONObject
jasonObject
new
JSONObject
tlmData
String
creationdate
formater
format
aujourdhui
// AmsatToUvsqsatSyncConfig jasonObject2 = (AmsatToUvsqsatSyncConfig) toBean(jasonObject, new AmsatToUvsqsatSyncConfig());
filepath
Paths
get
this
RepositoryPath
"\\Data.json"
try
if
Files
exists
filepath
Files
createFile
filepath
Files
writeString
filepath
"\r\n"
StandardOpenOption
CREATE
Files
writeString
filepath
jasonObject
toString
"\r\n"
StandardOpenOption
CREATE
if
Files
size
filepath
10
appLogger
severe
"file not created "
erreur
1
catch
IOException
e
appLogger
severe
e
toString
erreur
1
return
erreur
public
static
void
main
String
args
app
new
app
execute
// app.initDirectory();
// AmsatToUvsqsatSyncConfig config = new AmsatToUvsqsatSyncConfig();
// config.setAmsatDatabaseUrl("AMSATDataBase");
// config.setDeltaTimeLong(10);
// config.setDeltaTime("10");
// config.setLogin("login");
// config.setPassword("password");
// config.setSftpUrl("URL SFTP");
// config.setSshUrl("SSH file");
// app.readJson( );
// app.saveTlmData(config);
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/DataToUVSQsatControlCenter.java
View file @
200ac5b7
@@ -5,52 +5,40 @@ import java.nio.charset.StandardCharsets;
import
java.nio.file.Files
import
java.nio.file.Path
import
java.nio.file.Paths
import
import
org.josast.SIDS.SIDSData
import
org.json.JSONArray
public
class
implements
Commande
private
SIDSData
sidsdata
private
static
Logger
appLogger
Logger
getLogger
"AmsatLogger"
private
DataToExchange
data
private
String
file
null
public
SIDSData
sidsdataIn
String
fileIn
public
DataToExchange
sidsdataIn
String
fileIn
sids
data
sidsdataIn
clone
data
sidsdataIn
clone
file
fileIn
@Override
public
void
excecute
// ObjectMapper mapper = new ObjectMapper();
DataToExchange
dte
new
DataToExchange
sidsdata
length
for
int
i
0
i
sidsdata
length
i
dte
i
new
DataToExchange
sidsdata
i
getSource
sidsdata
i
getTimestamp
sidsdata
i
getFrame
sidsdata
i
getLongitude
sidsdata
i
getLatitude
save
JSONArray
ja
new
JSONArray
dte
Path
path
Paths
get
file
public
void
save
JSONArray
ja
new
JSONArray
data
Path
path
Paths
get
file
try
Files
writeString
path
ja
toString
StandardCharsets
UTF_8
catch
IOException
ex
// Handle exception
appLogger
severe
"can not write "
file
ex
getMessage
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/GetDataFromAmsatDatabase.java
0 → 100644
View file @
200ac5b7
package
import
java.io.IOException
import
import
java.nio.file.Files
import
java.nio.file.Path
import
java.nio.file.Paths
import
import
java.util.Date
import
java.util.GregorianCalendar
import
java.util.Iterator
import
java.util.TimeZone
import
org.json.JSONArray
import
org.json.JSONObject
public
class
implements
Commande
private
String
file
null
private
String
urlDatabase
null
final
private
SimpleDateFormat
ISO8601DATEFORMAT
new
SimpleDateFormat
"yyyy-MM-dd'T'HH:mm:ss'Z'"
public
String
urlIn
urlDatabase
urlIn
ISO8601DATEFORMAT
setTimeZone
TimeZone
getTimeZone
"UTC"
public
DataToExchange
getTelemetrydata
Date
startdate
Date
endate
int
noradid
String
startDate
ISO8601DATEFORMAT
format
startdate
String
endDate
ISO8601DATEFORMAT
format
endate
DataToExchange
dte
null
// ?endTimeStamp=2021-10-08T15:00:00Z&noradID=1000&startTimeStamp=2021-09-08T13:00:00Z
String
url
urlDatabase
"?startTimeStamp="
startDate
"&endTimeStamp="
endDate
"&noradID="
noradid
HttpGetDatabasse
httpget
new
HttpGetDatabasse
String
results
httpget
sendGET
url
JSONArray
json
new
JSONArray
results
if
json
length
0
JSONObject
jsonObject
JSONObject
json
get
0
dte
new
DataToExchange
json
length
for
int
i
0
i
json
length
i
jsonObject
JSONObject
json
get
i
dte
i
new
DataToExchange
jsonObject
getString
"source"
jsonObject
getString
"timestamp"
jsonObject
getString
"frame"
jsonObject
getString
"latitude"
jsonObject
getString
"longitude"
return
dte
@Override
public
void
excecute
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/SendSftp.java
0 → 100644
View file @
200ac5b7
package
import
import
com.jcraft.jsch.ChannelSftp
import
com.jcraft.jsch.JSch
import
com.jcraft.jsch.JSchException
import
com.jcraft.jsch.Session
import
com.jcraft.jsch.SftpException
public
class
SendSftp
private
static
Logger
appLogger
Logger
getLogger
"AmsatLogger"
private
String
remoteHost
null
private
String
username
null
private
String
password
null
private
String
KnownHosts
"LATMOS_SSH"
private
ChannelSftp
channelSftp
null
public
SendSftp
String
remoteHost
String
username
String
password
super
this
remoteHost
remoteHost
this
username
username
this
password
password
channelSftp
setupJsch
public
ChannelSftp
setupJsch
Session
jschSession
null
ChannelSftp
channel
null
try
JSch
jsch
new
JSch
jsch
setKnownHosts
KnownHosts
jschSession
jsch
getSession
username
remoteHost
jschSession
setPassword
password
jschSession
connect
catch
Exception
e
appLogger
severe
"error connection to "
remoteHost
e
getMessage
try
channel
ChannelSftp
jschSession
openChannel
"sftp"
catch
JSchException
e
appLogger
severe
"error to open channel sftp "
e
getMessage
return
channel
public
void
upload
String
filein
String
fileout
try
channelSftp
connect
catch
JSchException
e
appLogger
severe
"error to connect channel "
e
getMessage
e
printStackTrace
try
channelSftp
put
filein
fileout
catch
SftpException
e
appLogger
severe
"error to send file "
e
getMessage
e
printStackTrace
System
out
println
"sentn"
channelSftp
exit
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/config/ManageFolder.java
0 → 100644
View file @
200ac5b7
package
import
java.io.IOException
import
java.nio.file.Files
import
java.nio.file.Path
import
java.nio.file.Paths
import
java.util.logging.Level
import
public
class
ManageFolder
private
static
Logger
appLogger
Logger
getLogger
"AmsatLogger"
private
String
RepositoryPath
null
private
String
defaultrepository
"data"
public
ManageFolder
RepositoryPath
System
getProperty
"user.dir"
defaultrepository
public
ManageFolder
String
path
if
path
null
RepositoryPath
System
getProperty
"user.dir"
defaultrepository
else
if
path
length
0
RepositoryPath
System
getProperty
"user.dir"
"\\+defaultrepository"
else
RepositoryPath
System
getProperty
"user.dir"
path
* @return the repositoryPath
public
String
getRepositoryPath
return
RepositoryPath
* @param repositoryPath the repositoryPath to set
public
void
setRepositoryPath
String
repositoryPath
RepositoryPath
repositoryPath
public
void
createdDirectories
Path
path
Paths
get
RepositoryPath
// if directory exists?
if
Files
exists
path
try
Files
createDirectories
path
appLogger
info
"directory created : "
RepositoryPath
catch
IOException
e
appLogger
log
Level
SEVERE
"cannot create outpout directorie "
e
toString
else
appLogger
info
"directory already exist : "
RepositoryPath
ApplicationDatabaseSynchronisation/src/main/java/org/josast/databaseSync/config/ManageJSonConfigFile.java
0 → 100644
View file @
200ac5b7
package
import
java.io.IOException
import
java.io.InputStream
import
java.lang.reflect.Field
import
java.nio.file.Files
import
java.nio.file.Path
import
java.nio.file.Paths
import
import
import
org.apache.commons.io.IOUtils
import
org.json.JSONException
import
org.json.JSONObject
public
class
private
static
Logger
appLogger
Logger
getLogger
"AmsatLogger"
private
String
configRepository
"config"
private
String
configName
"Data.json"
public
int
SaveConfigFile
Object
bean
ManageFolder
mn
new
ManageFolder
configRepository
mn
createdDirectories
Path
filepath
Paths
get
mn
getRepositoryPath
configName
int
erreur
0
JSONObject
jasonObject
new
JSONObject
bean
try
if
Files
exists
filepath
Files
createFile
filepath
Files
writeString
filepath
"\r\n"
StandardOpenOption
CREATE
Files
writeString
filepath
jasonObject
toString
"\r\n"
StandardOpenOption
CREATE
if
Files
size
filepath
10
appLogger
severe
"file not created "
erreur
1
catch
IOException
e
appLogger
severe
e
toString
erreur
1
return
erreur
public
Object
readJson
Object
object
Object
tempobject
null
String
RepositoryPath
System
getProperty
"user.dir"
configRepository
System
out
println
RepositoryPath
Path
filepath
Paths
get
RepositoryPath
configName
try
InputStream
is
Files
newInputStream
filepath
String
text
IOUtils
toString
is
"UTF-8"
JSONObject
myJsonObject
new
JSONObject
text
tempobject
toBean
myJsonObject
object
catch
IOException
JSONException
e
e
printStackTrace
appLogger
severe
"Erreor reading json file"
filepath
getFileName
return
tempobject
public
static
Object
toBean
JSONObject
jobject
Object
object
for
Field
field
object
getClass
getDeclaredFields
try
field
set
object
jobject
getString
field
getName
catch
IllegalArgumentException
IllegalAccessException
JSONException
e
e
printStackTrace
return
object
