Skip to content
GitLab
Explore
Sign in
Adastra
meca_vol
Compare revisions
1c1d15bbcbe958e44641336266bad5cfe11f9079 to 3dc32fd1f1932a2d4b99a0e32c26163d1c6a6add
Commits on Source (2)
ajout de la fonction inv_ratioareasec_mach
· f079bc3e
pingu
authored
Sep 29, 2019
f079bc3e
· 3dc32fd1
pingu
authored
Sep 29, 2019
3dc32fd1
Hide whitespace changes
Inline
Side-by-side
Engineering_tools.py
View file @
3dc32fd1
HEAD
import
numpy
as
np
from
numpy
import
linalg
as
LA
def
initial_vel
latitude
retrograde
False
Initial velocity (m.s-1) depending on the launch point latitude (°)
T_side
86164.10
# sidereal day (s)
R_T
6378e3
# earth raduis (m)
initial_velocity
2
np
pi
T_side
R_T
np
cos
np
deg2rad
np
abs
latitude
if
retrograde
return
initial_velocity
else
return
initial_velocity
def
final_target_vel
h
a
inputs:
h: injection altitude (m)
a: orbit semi major axis (m)
output:
orbit absolute injection velocity (m.s-1)
mu
3.9860e14
# earth standard gravitatinal parameter (=G*M_earth) (m3.s-2)
R_T
6378e3
# earth raduis (m)
return
np
sqrt
2
mu
1
R_T
h
1
2
a
def
staging_optim
isp1
isp2
eps1
eps2
Vc
Mp
Optimise mass loading in the case of two stage rocket
inputs:
isp1, isp2 : specific impulse of the 1st and 2nd stage (s)
eps1, eps2 : structural coefficient of the 1st and 2nd stage (adimentional)
Vc : target critical velocity (m.s-1)
Mp : payload mass (Kg)
outputs:
M1 : mass of the 1st stage
M2 : mass of the 2nd stage
NB:
structure mass
structural coefficient = --------------------------------
structure mass + propellant mass
ctritical velocity = final velocity - initial velocity + losses
# Notation :
# Mt = total mass
# q1 = M1/Mt
# q2 = M2/Mt
# qp = Mp/Mt
# omega = qp + q2
g0
9.81
# standard gravity (m.s-2)
omega_tab
np
linspace
0.001
0.9
100
# array of omega to test
qp_tab
for
omega
in
omega_tab
q2
omega
eps1
1
omega
q2
np
power
q2
isp1
isp2
np
exp
Vc
g0
isp2
q2
1
q2
q2
1
q2
q2
omega
1
eps2
qp
omega
q2
qp_tab
append
qp
qp
max
qp_tab
omega
omega_tab
qp_tab
index
qp
q2
omega
qp
q1
1
q2
qp
M1
Mp
qp
q1
M2
Mp
qp
q2
return
M1
M2
def
standard_atmosphere
altitude
Compute atmospheric properties according to the International Standaard Atmosphere (ISA) model
input:
altitude (m)
outputs:
temperature (K)
pressure (Pa)
density (Kg.m-3)
assert
altitude
84852
str
altitude
is higher than max altitude of the ISA model
g0
9.81
r
287
# specific gas constant (J.Kg-1.K-1)
# ISA model
h0_tab
np
array
0
11e3
20e3
32e3
47e3
51e3
71e3
84852
# base altitude (m)
a_tab
np
array
6.5e-3
0
1e-3
2.8e-3
0
2.8e-3
2.0e-3
# lapse rate (K.m-1)
# the base properties of each range are tabulated to reduce computational cost
T0_tab
np
array
288.15
216.65
216.65
228.65
270.65
270.65
214.65
# base temperature (K)
P0_tab
np
array
101325
22632
5474.9
868.02
110.91
66.939
3.9564
# base pressure (Pa)
index
0
while
altitude
h0_tab
index
1
index
1
a
a_tab
index
T0
T0_tab
index
P0
P0_tab
index
T
T0
a
altitude
h0_tab
index
# Toussaint equation
if
T
T0
# isohermal region
P
P0
np
exp
g0
altitude
h0_tab
index
r
T
else
# gradient region
P
P0
np
power
T
T0
g0
a
r
rho
P
r
T
return
T
P
rho
def
laval_nozzle
Pt
Tt
Pamb
Ath
Ae
gamma
r
tolerance
1e-5
Compute the thrust assuming a started nozzle
inputs:
Pt : total pressure in the combustion chambre (Pa)
Tt : total temperature in the combustion chambre (K)
Pamb : ambient pressure (Pa)
Ath : throat section area (m2)
Ae : exit section area (m2)
gamma : ratio of specific heats (adimentional)
r : specific gas constant (J.Kg-1.K-1)
tolerance :
outputs:
Thrust (N)
Specific impulse (s)
N.B : Thrust = mass flow rate * exit velocity + (exit pressure - ambiant pressure) * exit area
assert
gamma
1
gamma must be > 1
g0
9.81
A_ratio
lambda
M
gamma
1
M
np
power
2
gamma
1
1
gamma
1
2
M
M
gamma
1
2
gamma
2
# compute the nozzle exit section area corresponding to the adapted regime
Madapted
np
sqrt
2
gamma
1
np
power
Pamb
Pt
1
gamma
gamma
1
Aadapted
Ath
A_ratio
Madapted
gamma
if
Aadapted
Ae
# the nozzle is under-expanded
# compute the exit Mach number iteratively using dichotomy algorithm
A_ratio_target
Ae
Ath
Me_upper
Madapted
Me_lower
1
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
while
np
abs
error
tolerance
if
error
0
Me_lower
Me
else
Me_upper
Me
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
Te
Tt
1
gamma
1
2
Me
Me
# exit static temperature
Pe
Pt
np
power
Tt
Te
gamma
1
gamma
# exit static pressure
elif
Aadapted
Ae
# the nozzle is over-expanded
Mshock
1
step
0.1
A_ratio_target
Ae
Ath
Me_upper
1
Me_lower
0
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
while
np
abs
error
tolerance
if
error
0
Me_lower
Me
else
Me_upper
Me
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
Te
Tt
1
gamma
1
2
Me
Me
Pe
Pt
np
power
Tt
Te
gamma
1
gamma
while
Pe
Pamb
1e-5
tolerance
Mshock_old
Mshock
Mshock
step
Pe_old
Pe
Pt_ratio
np
power
gamma
1
Mshock
Mshock
gamma
1
Mshock
Mshock
2
gamma
gamma
1
np
power
gamma
1
2
gamma
Mshock
Mshock
gamma
1
1
gamma
1
Pi
Pt
Pt_ratio
Ai
Ath
Pt_ratio
A_ratio_target
Ae
Ai
Me_upper
1
Me_lower
0
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
while
np
abs
error
tolerance
if
error
0
Me_lower
Me
else
Me_upper
Me
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
Te
Tt
1
gamma
1
2
Me
Me
Pe
Pi
np
power
Tt
Te
gamma
1
gamma
if
Pe
Pamb
and
A_ratio
Mshock
gamma
Ae
Ath
# the normal shock is outside the divergent and all the flow inside is supersonic
A_ratio_target
Ae
Ath
Me_upper
Mshock
Me_lower
1
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
while
np
abs
error
tolerance
if
error
0
Me_lower
Me
else
Me_upper
Me
Me
Me_upper
Me_lower
2
error
A_ratio_target
A_ratio
Me
gamma
Te
Tt
1
gamma
1
2
Me
Me
Pe
Pt
np
power
Tt
Te
gamma
1
gamma
break
if
Pe
Pamb
Pe
Pe_old
Mshock
Mshock_old
step
2
else
# the nozzle is adapted
Me
Madapted
Te
Tt
1
gamma
1
2
Me
Me
Pe
Pamb
Ve
Me
np
sqrt
gamma
r
Te
# exit velocity
# maximum mass flow rate in the case of a started nozzle
Q
np
power
2
gamma
1
gamma
1
2
gamma
1
np
sqrt
gamma
Tt
r
Pt
Ath
Thrust
Q
Ve
Pe
Pamb
Ae
isp
Thrust
Q
g0
return
Thrust
isp
def
adiabatic_flame
mech
T
P
X
Compute adiatabic flame temperature
inputs:
mech : chemical mechanism in cti format
T : initial temperature (K)
P : pressure (Pa)
X : initial chemical composition
# work in progress
def
injector
#%% Trajectory tools
def
solve_traj
#%% Astrodynamics tools
def
state_to_orbital_elem
r
v
Convert state vector to orbital elements
inputs:
r : coordinate vector (m)
v : velocity vector (m.s-1)
output: {
a
e
i
capital_omega
small_omega
nu
where:
a : semi_major axis (m)
e : eccentricity (adimentional)
i : inclination (deg)
capital_omega : argument of the ascending node (deg)
small_omega : argument of the perigee (deg)
nu : true anomaly (deg)
NB: - An internal quantity (small) is considered for the case of undefined
classical orbital elements. When an element is undefined it is set to
zero and other(s) following it are measured according to this convention
- The function stops when r and v are aligned
- This function is widely inspired by the Matlab function written by
Prof. Josep Masdemart from UPC
orbel
a
0
e
0
i
0
capital_omega
0
small_omega
0
nu
0
mu
3.9860e14
small
1e-10
h
np
cross
r
v
# angular momentum
rm
LA
norm
r
# module of the coordinate vector
vm
LA
norm
v
# module of the velocity vector
hm
LA
norm
h
# module of the angular momentum vector
if
hm
small
print
rectilinar or collision trajectory
return
n
np
array
h
1
h
0
0
nm
LA
norm
n
if
nm
small
n
np
array
1
0
0
nm
0
else
n
n
nm
nm
1
dotrv
np
dot
r
v
e
vm
vm
mu
rm
r
dotrv
v
mu
em
LA
norm
e
if
em
small
e
n
em
0
else
e
e
em
orbel
e
em
orbel
a
hm
hm
mu
1
em
em
aux
h
2
hm
if
np
abs
aux
1
aux
np
sign
aux
# all the angles are first computed in rad
orbel
i
np
arccos
aux
if
nm
small
aux
n
0
if
np
abs
aux
1
aux
np
sign
aux
orbel
capital_omega
np
arccos
aux
if
n
1
0
orbel
capital_omega
2
np
pi
orbel
capital_omega
if
em
small
aux
np
dot
e
n
if
np
abs
aux
1
aux
np
sign
aux
orbel
small_omega
np
arccos
aux
if
e
2
0
orbel
small_omega
2
np
pi
orbel
small_omega
aux
np
dot
e
r
rm
if
np
abs
aux
1
aux
np
sign
aux
orbel
nu
np
arccos
aux
if
em
small
if
dotrv
0
orbel
nu
2
np
pi
orbel
nu
else
ha
np
cross
e
r
if
np
dot
h
ha
0
orbel
nu
2
np
pi
orbel
nu
# convert the angles to deg
orbel
i
np
rad2deg
orbel
i
orbel
capital_omega
np
rad2deg
orbel
capital_omega
orbel
small_omega
np
rad2deg
orbel
small_omega
orbel
nu
np
rad2deg
orbel
nu
return
orbel
def
propagate_orbit
#%% Thermodynamic cycles
# the following functions provide the pressure, the mixuture composition
# and the initial temperature in the combustion chambre and properties of some
# components of the cycle.
def
pressure_fed
R
L
pi
Ltube
input
p_fp: pressure of the fed pressure tank
p_co: pressure of the oxizider tank
p_ca: pressure of the fuel tank
d_fp: denisty of the fed pressure fluid
d_ox: density of the oxidizer
d_fu: density of the fuel
rajouter valves et ou et lesquelles ??
définir tank He
définir pipe He -> heat exchanger
définir pipe heat exchanger -> comb
définir pipe heat exchanger -> carb
définir tank comb
définir tank carb
définir pipe comb -> output
définir pipe carb -> output
#vi = 0
t
0
dt
1e-1
tank_Hein
phe
vhe
0
dhe
rhe
0
rshe
lhe
che
tank_He
tank
tank_Hein
dt
tank_O2in
po
vo
do
co
ro
reo
tank_O2in
tank
p_fp
0
0
d_fp
tank_CH4in
pch
vch
dch
cch
rch
rech
tank_CH4
tank
p_fp
0
0
d_fp
pipeHeHe
pipes
p
v
d
mu
r
l
h
tank_
while
t
T
tank_He
tank
p_fp
0
0
t
dt
def
tank
p
v
d
dc
r
re
rs
l
c
dt
g
9.81
pi
3.1415926
input
p : pression d
entrée
v : vitesse d
entrée
d : densité d
entrée
dc : densité du contenant
r : rayon
re : rayon d
entrée
rs : rayon de sortie
l : longueur
c : capacité de remplissage
dt : pas de temps
output
ps : pression sortie
vs : vitesse sortie
dc : densité
cs : capacité remplissage
if
d_c
0
pe
p
d
v
2
2
1
re
2
r
2
ve
v
re
2
r
2
pm
pe
dc
d
dc
ve
2
2
1
d
dc
2
dc
l
g
1
2
c
vm
ve
d
dc
else
pm
p
d
g
h
8
mu
l
1
c
v
r
2
vm
v
ps
pm
dc
vm
2
2
1
r
2
rs
2
vs
vm
r
2
rs
2
cs
c
vs
dc
dt
pi
r
2
l
return
ps
vs
dc
cs
def
pipes
p
v
d
mu
r
l
h
g
9.81
input
p : pression d
entrée
v : vitesse d
entrée
d : densité d
entrée
mu : viscosité
r : rayon
l : longueur
h : longueur total projeté sur l
axe vertical
output
vs : vitesse sortie
pe
p
d
g
h
8
mu
l
v
r
2
ve
v
return
ps
vs
def
heat_exchanger
p
v
d
mu
r
l
L
g
9.81
input
p : pression d
entrée
v : vitesse d
entrée
d : densité d
entrée
mu: viscosité dynamique
r : rayon
l : longueur
axe vertical
L : chaleur latente de vaporisation
pe
p
d
g
h
8
mu
l
v
r
2
ve
v
#heat_exchanger
ps
p
L
d
S
l
vs
ve
return
ps
vs
def
valves
x
p
v
dp
pi
3.1415926
input
x: état imposé d
ouverture de la valve
p: pression d
entrée
v: vitesse d
entrée
dp: pressure drop
output
xs: état actuel d
ps: pression de sortie de valves
vs: vitesse d
entrée
ps
p
dp
#f(p,v,...)
vs
v
xs
x
return
xs
vs
ps
def
electric_turbo
def
closed_expander
def
dual_expander
def
open_expander
def
tap_off
def
gas_generator
def
ox_rich_staged_combust
def
full_flow_staged_combust
def
rsa
gamma
subsup
inputs
rsa : ratio des sections des aires
gamma : coefficient de Laplace
subsup : recherche d
un Mach sub ou supersonic (0|1)
Ce dernier input est lier à l
initialisation de la méthode.
np
float128
gamma
1.4
epsilon
1e-10
if
subsup
1
x
5
else
x
0.2
iter
0
while
x
epsilon
and
iter
20
iter
1
y
np
sqrt
2
gamma
1
1
gamma
1
x
2
2
gamma
1
gamma
1
x
2
rsa
xp
x
epsilon
yp
np
sqrt
2
gamma
1
1
gamma
1
xp
2
2
gamma
1
gamma
1
xp
2
rsa
x
x
epsilon
y
yp
y
#pour afficher chaque itération, décommenter
#print(x,y,iter)
return
x
import
numpy
as
np
import
numpy
as
np
from
numpy
import
linalg
as
LA
from
numpy
import
linalg
as
LA
@@ -564,3 +1126,33 @@ def ox_rich_staged_combust():
def
def
def
rsa
gamma
subsup
inputs
np
float128
gamma
1.4
epsilon
1e-10
if
subsup
1
x
5
else
x
0.2
iter
0
while
x
epsilon
and
iter
20
iter
1
y
np
sqrt
2
gamma
1
1
gamma
1
x
2
2
gamma
1
gamma
1
x
2
rsa
xp
x
epsilon
yp
np
sqrt
2
gamma
1
1
gamma
1
xp
2
2
gamma
1
gamma
1
xp
2
rsa
x
x
epsilon
y
yp
y
#print(x,y,iter)
return
x
1
