This commit removes the ping6 command from NSH and replaces it with the...
This commit removes the ping6 command from NSH and replaces it with the apps/system/ping6 built-in command. The NSH ping6 command had to be removed because it violated the portable POSIX OS interface. The apps/system/ping6 command uses the sem-standard IPPROTO_ICMP6 socket interface. Squashed commit of the following: apps/system ping and ping6: Fix a backward test. apps/system/ping6: ping6 logic now builds without error. apps/system/ping and ping6: Minor clean-up to configuration settings. apps/system/ping6: Minor clean-up to be able to configure CONFIG_SYSTEM_PING6 apps/nshlib: Remove support for ping6 from NSH. apps/system/ping6: Add IPPROTO_ICMPv6 ping6. Initial commit is simply a clone of the IPPROTO_ICMP ping logic. Rename CONFIG_NET_ICMPv6_PING to CONFIG_NET_ICMPv6_SOCKET.
parent
bccf0092
