Skip to content
Snippets Groups Projects
Commit 470ddbac authored by patacongo's avatar patacongo
Browse files
Add RTC register definitions
git-svn-id: svn://svn.code.sf.net/p/nuttx/code/trunk@2981 42af7a65-404d-4744-a932-0658087f49c3
parent 21238364
No related branches found
No related tags found
...@@ -48,10 +48,54 @@ ...@@ -48,10 +48,54 @@
/* Register offsets *****************************************************************/ /* Register offsets *****************************************************************/
#define AVR32_RTC_CTRL_OFFSET 0x00 /* Control Register */
#define AVR32_RTC_VAL_OFFSET 0x04 /* Value Register */
#define AVR32_RTC_TOP_OFFSET 0x08 /* Top Register */
#define AVR32_RTC_IER_OFFSET 0x10 /* Interrupt Enable Register */
#define AVR32_RTC_IDR_OFFSET 0x14 /* Interrupt Disable Register */
#define AVR32_RTC_IMR_OFFSET 0x18 /* Interrupt Mask Register */
#define AVR32_RTC_ISR_OFFSET 0x1c /* Interrupt Status Register */
#define AVR32_RTC_ICR_OFFSET 0x20 /* Interrupt Clear Register */
/* Register Addresses ***************************************************************/ /* Register Addresses ***************************************************************/
#define AVR32_RTC_CTRL (AVR32_RTC_BASE+AVR32_RTC_CTRL_OFFSET)
#define AVR32_RTC_VAL (AVR32_RTC_BASE+AVR32_RTC_VAL_OFFSET)
#define AVR32_RTC_TOP (AVR32_RTC_BASE+AVR32_RTC_TOP_OFFSET)
#define AVR32_RTC_IER (AVR32_RTC_BASE+AVR32_RTC_IER_OFFSET)
#define AVR32_RTC_IDR (AVR32_RTC_BASE+AVR32_RTC_IDR_OFFSET)
#define AVR32_RTC_IMR (AVR32_RTC_BASE+AVR32_RTC_IMR_OFFSET)
#define AVR32_RTC_ISR (AVR32_RTC_BASE+AVR32_RTC_ISR_OFFSET)
#define AVR32_RTC_ICR (AVR32_RTC_BASE+AVR32_RTC_ICR_OFFSET)
/* Register Bit-field Definitions ***************************************************/ /* Register Bit-field Definitions ***************************************************/
/* Control Register Bit-field Definitions */
#define RTC_CTRL_EN (1 << 0) /* Bit 0: Enable */
#define RTC_CTRL_PCLR (1 << 1) /* Bit 1: Prescaler Clear */
#define RTC_CTRL_WAKEN (1 << 2) /* Bit 2: Wakeup Enable */
#define RTC_CTRL_CLK32 (1 << 3) /* Bit 3: 32 KHz Oscillator Select */
#define RTC_CTRL_BUSY (1 << 4) /* Bit 4: RTC Busy */
#define RTC_CTRL_PSEL_SHIFT (8) /* Bits 8-11: Prescale Select */
#define RTC_CTRL_PSEL_MASK (15 << RTC_CTRL_PSEL_SHIFT)
#define RTC_CTRL_CLKEN (1 << 16) /* Bit 16: Clock Enable */
/* Value Register Bit-field Definitions */
/* This is a 32-bit data register and, hence, has no bit field */
/* Top Register Bit-field Definitions */
/* Interrupt Enable Register Bit-field Definitions
* Interrupt Disable Register Bit-field Definitions
* Interrupt Mask Register Bit-field Definitions
* Interrupt Status Register Bit-field Definitions
* Interrupt Clear Register Bit-field Definitions
#define RTC_INT_TOPI (1 << 0) /* Bit 0: Top interrupt */
* Public Types * Public Types
0% Loading or .
Please register or to comment
