Big, very risky change: Remove all occurrences of up_maskack_irq() that...
Big, very risky change: Remove all occurrences of up_maskack_irq() that disable and enable interrupts with up_ack_irq() that only acknowledges the interrupts. This is only used in interrupt decoding logic. Also remove the logic that unconditionally re-enables interrupts with the interrupt exits. This interferes with the drivers ability to control the interrupt state. This is a necessary, sweeping, global change and unfortunately impossible to test.
Loading
