Skip to content
Snippets Groups Projects
Commit 607dd3be authored by Gregory Nutt's avatar Gregory Nutt
Browse files
Spell check TODO list
parent 9d475e4f
No related branches found
No related tags found
NuttX TODO List (Last updated March 31, 2016)
NuttX TODO List (Last updated May 27, 2016)
This file summarizes known NuttX bugs, limitations, inconsistencies with
standards, things that could be improved, and ideas for enhancements. This
TODO list does not include issues associated with individual boar ports. See
altheso individual README.txt files in the configs/ sub-directories for
issues reated to each board port.
also the individual README.txt files in the configs/ sub-directories for
issues related to each board port.
nuttx/
......@@ -70,7 +70,7 @@ o Task/Scheduler (sched/)
Title: GET_ENVIRON_PTR()
Description: get_environ_ptr() (sched/sched_getenvironptr.c) is not implemented.
The representation of the environment strings selected for
NutX is not compatible with the operation. Some significant
NuttX is not compatible with the operation. Some significant
re-design would be required to implement this function and that
effort is thought to be not worth the result.
Status: Open. No change is planned.
......@@ -81,7 +81,7 @@ o Task/Scheduler (sched/)
Status: Open
Priority: Low -- There is no plan to implement this.
Title: INCOMPATIBILITES WITH execv() AND execl()
Title: INCOMPATIBILITIES WITH execv() AND execl()
Description: Simplified 'execl()' and 'execv()' functions are provided by
NuttX. NuttX does not support processes and hence the concept
of overlaying a tasks process image with a new process image
......@@ -175,7 +175,7 @@ o Task/Scheduler (sched/)
Yahoo! Groups message 7726: "I think that the system
should be required to handle pthread_cancel safely in
all cases. In the NuttX model, a task is like a Unix
process and a pthread is like a Unix thread. Cancelling
process and a pthread is like a Unix thread. Canceling
threads should always be safe (or at least as unsafe) as
under Unix because the model is complete for pthreads...
......@@ -188,7 +188,7 @@ o Task/Scheduler (sched/)
"The patch I just incorporated is also insufficient. It
works only if the serial driver is shut down when the
thread is cancelled. But what if there are other open
thread is canceled. But what if there are other open
references to the driver? Then the driver will not be
shut down, the semaphores will not be re-initialized, and
the semaphore counts will still be off by one.
......@@ -202,7 +202,7 @@ o Task/Scheduler (sched/)
hooks so that given a semaphore it can traverse all
holders. What is needed would be logic so that given
a task, you can traverse all semaphores held by the task,
releasing each semaphore cound held by the exiting task.
releasing each semaphore count held by the exiting task.
Nothing like this exists now so that solution is not
imminent.
......@@ -228,16 +228,15 @@ o Task/Scheduler (sched/)
hidden behind simple accessor functions and so the internal
data structures can be changed if need with very little impact.
Explicity refereence to the list strucutre are hidden behnid
Explicitly reference to the list structure are hidden behind
the macro this_task().
Status: Open
Priority: Low. Things are just the way that we want them for the way
that NuttX is used today.
o Memory Managment (mm/)
o Memory Management (mm/)
Title: FREE MEMORY ON TASK EXIT
Description: Add an option to free all memory allocated by a task when the
......@@ -390,7 +389,7 @@ o pthreads (sched/pthreads)
Priority: Low -- about zero, probably not that useful. Priority inheritance is
already supported and is a much better solution. And it turns out
that priority protection is just about as complex as priority inheritance.
Exerpted from my post in a Linked-In discussion:
Excerpted from my post in a Linked-In discussion:
"I started to implement this HLS/"PCP" semaphore in an RTOS that I
work with (http://www.nuttx.org) and I discovered after doing the
......@@ -784,7 +783,7 @@ o Binary loaders (binfmt/)
to get fixed as needed for Windows native tool builds.
Title: TOOLCHAIN COMPATIBILITY PROBLEM
Descripton: The older 4.3.3 compiler generates GOTOFF relocations to the constant
Description: The older 4.3.3 compiler generates GOTOFF relocations to the constant
strings, like:
.L3:
......@@ -794,7 +793,7 @@ o Binary loaders (binfmt/)
.word .LC3(GOTOFF)
.word .LC4(GOTOFF)
Where .LC0, LC1, LC2, LC3, and .LC4 are the labels correponding to strings in
Where .LC0, LC1, LC2, LC3, and .LC4 are the labels corresponding to strings in
the .rodata.str1.1 section. One consequence of this is that .rodata must reside
in D-Space since it will addressed relative to the GOT (see the section entitled
"Read-Only Data in RAM" at
......@@ -880,7 +879,7 @@ o Network (net/, drivers/net)
RFC3678 (IGMPv3) suggests ioctl() commands to do this (SIOCSIPMSFILTER) but
also status that those APIs are historic. NuttX implements these ioctl
commands, but is non-standard because: (1) It does not support IGMPv3, and
(2) it looks up drivers by their device name (eg., "eth0") vs IP address.
(2) it looks up drivers by their device name (e.g., "eth0") vs IP address.
Linux uses setsockopt() to control multicast group membership using the
IP_ADD_MEMBERSHIP and IP_DROP_MEMBERSHIP options. It also looks up drivers
......@@ -896,7 +895,7 @@ o Network (net/, drivers/net)
that connection may time out. How should this be handled? Should the
connection be removed from the backlog if it is times out or is closed?
Or should it remain in the backlog with a status indication so that accept()
can fail when it encounteres the invalid connection?
can fail when it encounters the invalid connection?
Status: Open
Priority: Medium. Important on slow applications that will not accept
connections promptly.
......@@ -975,7 +974,7 @@ o Network (net/, drivers/net)
it is no longer needed. Perhaps there should be a delayed
call to unlink() (using a watchdog or the work queue). If
the driver is re-opened, the delayed unlink could be
cancelled? Needs more thought.
canceled? Needs more thought.
NOTE: This is not an issue for Unix domain streams sockets:
The end-of-life of the FIFO is well determined when sockets
are disconnected and support for that case is fully implemented.
......@@ -1020,7 +1019,7 @@ o USB (drivers/usbdev, drivers/usbhost)
that involves delays. This needs to be redesigned to eliminate these
delays. See logic conditioned on CONFIG_USBMSC_RACEWAR.
If queuing of stall requests is supported by DCD then this workaround
If queuing of stall requests is supported by the DCD then this workaround
is not required. In this case, (1) the stall is not sent until all
write requests preceding the stall request are sent, (2) the stall is
sent, and then after the stall is cleared, (3) all write requests
......@@ -1135,7 +1134,7 @@ o USB (drivers/usbdev, drivers/usbhost)
Priority: Medium-Low
Title: USB CDC/ACM HOST CLASS DRIVER
Desciption: A CDC/ACM host class driver has been added. This has been
Description: A CDC/ACM host class driver has been added. This has been
testing by running the USB CDC/ACM host on an Olimex
LPC1766STK and using the configs/stm3210e-eval/usbserial
configuration (using the CDC/ACM device side driver). There
......@@ -1374,7 +1373,7 @@ o File system / Generic drivers (fs/, drivers/)
Priority: Medium
Title: UNIFIED DESCRIPTOR REPRESENTATION
Descripton: There are two separate ranges of descriptors for file and
Description: There are two separate ranges of descriptors for file and
socket descriptors: if a descriptor is in one range then it is
recognized as a file descriptor; if it is in another range
then it is recognized as a socket descriptor. These separate
......@@ -1410,7 +1409,7 @@ o File system / Generic drivers (fs/, drivers/)
Status: Open
Priority: Low
Title: FAT LONG FILENAME COMPATIBILTY
Title: FAT LONG FILENAME COMPATIBILITY
Description: Recently there have been reports that file with long file
names created by NuttX don't have long file names when viewed
on Windows. The long file name support has been around for a
......@@ -1423,7 +1422,7 @@ o File system / Generic drivers (fs/, drivers/)
Description: I have seen cases where (1) long file names are enabled,
but (2) a short file name is created like:
nsh> echo "This is another thest" >/mnt/sdcard/another.txt
nsh> echo "This is another test" >/mnt/sdcard/another.txt
But then on subsequent 'ls' operations, the file does not appear:
......@@ -1472,7 +1471,7 @@ o File system / Generic drivers (fs/, drivers/)
4) When comparing the checksum in the long file name
entry with the checksum of the short file name, the
checksum fails and the entire directlry sequence is
checksum fails and the entire directory sequence is
ignored by readder() logic. This the file does not
appear in the 'ls'.
......@@ -1539,7 +1538,7 @@ o Graphics subsystem (graphics/)
Priority: Low, the need has not yet arisen.
Title: PER-WINDOW FRAMEBUFFERS
Description: One of the most awkard things to handle in the NX windowing
Description: One of the most awkward things to handle in the NX windowing
system is the re-draw callback. This is difficult because it
requires ad hoc, custom logic to be able to do the redrawing
in most cases.
......@@ -1765,7 +1764,7 @@ o ARM (arch/arm/)
But this has not been proven to be a solution.
UPDATE: Other ARM architectures have a similer issue.
UPDATE: Other ARM architectures have a similar issue.
Status: Open
Priority: Low. The conditions of continuous interrupts is really the problem.
......@@ -1823,7 +1822,7 @@ o NuttShell (NSH) (apps/nshlib)
Title: IFCONFIG AND MULTIPLE NETWORK INTERFACES
Descripton: The ifconfig command will not behave correctly if an interface
Description: The ifconfig command will not behave correctly if an interface
is provided and there are multiple interfaces. It should only
show status for the single interface on the command line; it will
still show status for all interfaces.
0% Loading or .
Please register or to comment
