Skip to content
Commit 7f95e4fb authored by Gregory Nutt's avatar Gregory Nutt
Browse files
Networking: Fix a major TCP bug introduced with commit...
Networking:  Fix a major TCP bug introduced with commit e71c09ce9777ff732cb60bd07fb43d85522f79d6.  Some connection logic was reorder -- setting the socket got moved BEFORE the point where the check was made if the socket was already connected.  The resulting behavior was odd:  Telnet would connect, but then when you exit and reconnect, it would fail to connect.  But then if try again, it would connect okay. So the symptom was connect-fail-connect-fail-...
parent ebf1e121
Loading
Loading
Loading
Loading
0% Loading or .
Please register or to comment
