Skip to content
Snippets Groups Projects
Commit 8aa92af7 authored by patacongo's avatar patacongo
Browse files
Fix some Z16F serial bugs
git-svn-id: svn://svn.code.sf.net/p/nuttx/code/trunk@582 42af7a65-404d-4744-a932-0658087f49c3
parent 46f13906
No related branches found
No related tags found
...@@ -21,7 +21,7 @@ NuttX TODO List (Last updated January 6, 2008) ...@@ -21,7 +21,7 @@ NuttX TODO List (Last updated January 6, 2008)
(2) ARM/LPC214x (arch/arm/src/lpc214x/) (2) ARM/LPC214x (arch/arm/src/lpc214x/)
(4) pjrc-8052 / MCS51 (arch/pjrc-8051/) (4) pjrc-8052 / MCS51 (arch/pjrc-8051/)
(2) z80 (arch/z80/) (2) z80 (arch/z80/)
(1) z16 (arch/z16/) (2) z16 (arch/z16/)
o Task/Scheduler (sched/) o Task/Scheduler (sched/)
...@@ -373,3 +373,12 @@ o z16 (arch/z16) ...@@ -373,3 +373,12 @@ o z16 (arch/z16)
Status: Open Status: Open
Priority: Low, thought to be cosmetic. I think this is a consequence of Priority: Low, thought to be cosmetic. I think this is a consequence of
replacing vs. inserting the library. replacing vs. inserting the library.
Description: When the interrupt-driven serial driver is used, the system
hangs. This is because of TX ready (TRDE) interrupts that
get lost while interrupts are disabled. The existing
serial driver appears to be limited to hardware with a
latching, level-sensitive TX ready interrupt.
Status: Open
Priority: Medium. A polled, write-only serial driver is used in the
interim for system testing.
...@@ -68,6 +68,10 @@ ...@@ -68,6 +68,10 @@
extern _Erom unsigned long SYS_CLK_FREQ; extern _Erom unsigned long SYS_CLK_FREQ;
#define _DEFCLK ((unsigned long)&SYS_CLK_FREQ) #define _DEFCLK ((unsigned long)&SYS_CLK_FREQ)
#define STATE_DISABLED 0
#define STATE_RXENABLED 1
#define STATE_TXENABLED 2
* Private Types * Private Types
...@@ -246,7 +250,8 @@ static ubyte z16f_disableuartirq(struct uart_dev_s *dev) ...@@ -246,7 +250,8 @@ static ubyte z16f_disableuartirq(struct uart_dev_s *dev)
struct z16f_uart_s *priv = (struct z16f_uart_s*)dev->priv; struct z16f_uart_s *priv = (struct z16f_uart_s*)dev->priv;
irqstate_t flags = irqsave(); irqstate_t flags = irqsave();
ubyte state = priv->rxenabled ? 1 : 0 | priv->txenabled ? 2 : 0; ubyte state = priv->rxenabled ? STATE_RXENABLED : STATE_DISABLED | \
priv->txenabled ? STATE_TXENABLED : STATE_DISABLED;
z16f_txint(dev, FALSE); z16f_txint(dev, FALSE);
z16f_rxint(dev, FALSE); z16f_rxint(dev, FALSE);
...@@ -264,27 +269,29 @@ static void z16f_restoreuartirq(struct uart_dev_s *dev, ubyte state) ...@@ -264,27 +269,29 @@ static void z16f_restoreuartirq(struct uart_dev_s *dev, ubyte state)
z16f_txint(dev, (state & 2) ? TRUE : FALSE); z16f_txint(dev, (state & STATE_TXENABLED) ? TRUE : FALSE);
z16f_rxint(dev, (state & 1) ? TRUE : FALSE); z16f_rxint(dev, (state & STATE_RXENABLED) ? TRUE : FALSE);
irqrestore(flags); irqrestore(flags);
* Name: z16f_waittx * Name: z16f_consoleput
static void z16f_waittx(struct uart_dev_s *dev, boolean (*status)(struct uart_dev_s *)) static void z16f_consoleput(ubyte ch)
struct z16f_uart_s *priv = (struct z16f_uart_s*)CONSOLE_DEV.priv;
int tmp; int tmp;
for (tmp = 1000 ; tmp > 0 ; tmp--) for (tmp = 1000 ; tmp > 0 ; tmp--)
if (status(dev)) if (z16f_txready(&CONSOLE_DEV))
break; break;
putreg8(ch, priv->uartbase + Z16F_UART_TXD);
...@@ -379,23 +386,16 @@ static int z16f_attach(struct uart_dev_s *dev) ...@@ -379,23 +386,16 @@ static int z16f_attach(struct uart_dev_s *dev)
/* Attach the RX IRQ */ /* Attach the RX IRQ */
ret = irq_attach(priv->rxirq, z16f_rxinterrupt); ret = irq_attach(priv->rxirq, z16f_rxinterrupt);
if (ret != OK) if (ret == OK)
goto errout; /* Attach the TX IRQ */
/* Attach the TX IRQ */ ret = irq_attach(priv->txirq, z16f_txinterrupt);
if (ret != OK)
ret = irq_attach(priv->txirq, z16f_txinterrupt); {
if (ret != OK) irq_detach(priv->rxirq);
goto errout_with_rxirq;
return OK;
errout_with_rxirq:
errout:
return ret; return ret;
...@@ -598,7 +598,7 @@ static boolean z16f_rxavailable(struct uart_dev_s *dev) ...@@ -598,7 +598,7 @@ static boolean z16f_rxavailable(struct uart_dev_s *dev)
static void z16f_send(struct uart_dev_s *dev, int ch) static void z16f_send(struct uart_dev_s *dev, int ch)
putreg8(ch, priv->uartbase + Z16F_UART1_TXD); putreg8(ch, priv->uartbase + Z16F_UART_TXD);
...@@ -707,7 +707,6 @@ void up_serialinit(void) ...@@ -707,7 +707,6 @@ void up_serialinit(void)
int up_putc(int ch) int up_putc(int ch)
ubyte state; ubyte state;
/* Keep interrupts disabled so that we do not interfere with normal /* Keep interrupts disabled so that we do not interfere with normal
...@@ -722,20 +721,18 @@ int up_putc(int ch) ...@@ -722,20 +721,18 @@ int up_putc(int ch)
/* Add CR before LF */ /* Add CR before LF */
z16f_waittx(&CONSOLE_DEV, z16f_txready); z16f_consoleput('\r');
putreg8('\r', priv->uartbase + Z16F_UART_TXD);
/* Output the character */ /* Output the character */
z16f_waittx(&CONSOLE_DEV, z16f_txready); z16f_consoleput((ubyte)ch);
putreg8((ubyte)ch, priv->uartbase + Z16F_UART_TXD);
/* Now wait for all queue TX data to drain before restoring interrupts. The /* It is important to restore the TX interrupt while the send is pending.
* driver should receive one txdone interrupt which it may or may not ignore. * otherwise, TRDE interrupts can be lost since they do not pend after the
* TRDE false->true transition.
z16f_waittx(&CONSOLE_DEV, z16f_txempty);
z16f_restoreuartirq(&CONSOLE_DEV, state); z16f_restoreuartirq(&CONSOLE_DEV, state);
return ch; return ch;
* arch.h * arch.h
* Copyright (C) 2007 Gregory Nutt. All rights reserved. * Copyright (C) 2007, 2008 Gregory Nutt. All rights reserved.
* Author: Gregory Nutt <spudmonkey@racsa.co.cr> * Author: Gregory Nutt <spudmonkey@racsa.co.cr>
* Redistribution and use in source and binary forms, with or without * Redistribution and use in source and binary forms, with or without
...@@ -14,7 +14,7 @@ ...@@ -14,7 +14,7 @@
* notice, this list of conditions and the following disclaimer in * notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the * the documentation and/or other materials provided with the
* distribution. * distribution.
* 3. Neither the name Gregory Nutt nor the names of its contributors may be * 3. Neither the name NuttX nor the names of its contributors may be
* used to endorse or promote products derived from this software * used to endorse or promote products derived from this software
* without specific prior written permission. * without specific prior written permission.
...@@ -460,9 +460,7 @@ EXTERN void up_udelay(unsigned int microseconds); ...@@ -460,9 +460,7 @@ EXTERN void up_udelay(unsigned int microseconds);
# ifdef CONFIG_ARCH_LOWPUTC
EXTERN int up_putc(int ch); EXTERN int up_putc(int ch);
#endif
#undef EXTERN #undef EXTERN
#ifdef __cplusplus #ifdef __cplusplus
* lib_fflush.c * lib_fflush.c
...@@ -31,15 +31,15 @@ ...@@ -31,15 +31,15 @@
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE. * POSSIBILITY OF SUCH DAMAGE.
* Compilation Switches * Compilation Switches
* Included Files * Included Files
#include <nuttx/config.h> /* for CONFIG_STDIO_BUFFER_SIZE */ #include <nuttx/config.h> /* for CONFIG_STDIO_BUFFER_SIZE */
#include <stdio.h> #include <stdio.h>
...@@ -49,44 +49,44 @@ ...@@ -49,44 +49,44 @@
#include <nuttx/fs.h> #include <nuttx/fs.h>
#include "lib_internal.h" #include "lib_internal.h"
* Definitions * Definitions
* Private Type Declarations * Private Type Declarations
* Private Function Prototypes * Private Function Prototypes
* Global Constant Data * Global Constant Data
* Global Variables * Global Variables
* Private Constant Data * Private Constant Data
* Private Variables * Private Variables
* Global Functions * Global Functions
* Name: lib_fflushall * Name: lib_fflushall
* Description: * Description:
* Called by the OS when a task exits * Called by the OS when a task exits
void lib_flushall(FAR struct streamlist *list) void lib_flushall(FAR struct streamlist *list)
...@@ -115,9 +115,9 @@ void lib_flushall(FAR struct streamlist *list) ...@@ -115,9 +115,9 @@ void lib_flushall(FAR struct streamlist *list)
* Name: fflush * Name: fflush
int fflush(FILE *stream) int fflush(FILE *stream)
0% Loading or .
Please register or to comment
