This adds basic architectural support for the LPC546xx family and includes...
This adds basic architectural support for the LPC546xx family and includes support for the LPCXpresso-LPC54628 board. The basic NSH port is almost complete... still lacking GPIO support and LED support. There are still no significant drivers available. Squashed commit of the following: arch/arm/src/lpc54xx: Finish off some missing logic. Complete now execpt for GPIO and LED support. arch/arm/src/lpc54xx: Add lpc54_clrpend.c arch/arm/src/lpc54xx: Serial driver is complete and compiles. arch/arm/src/lpc54xx: Add beginning of a serial driver (still missing some logic) arch/arm/src/lpc54xx: Fleshes out low level USART intialization. arch/arm/src/lpc546xx/Kconfig: Add hooks to integrate with common seril upper half. arch/arm/src/lpc54xx: Beginning of USART console support. arch/arm/src/lpc54xx: Completes very basic clock configuration. arch/arm/src/lpc54xx: Add clocking logic (still not complete) arch/arm/src/lpc54xx: Beginning of PLL configuration logic. arch/arm/src/lpc54xx: Fix a few things from first compile attempt. Compilation cannot work until I at least finish the clock configuration logic. arch/arm/src/lpc54xx: Addes some SysTick logic. arch/arm/src/lpc54xx: Completes basic startup logic (sans clock configuration) and interrupt configuration. arch/arm/src/lpc54xx: Add generic ARMv7-M start-up logic (needs LPC54628 customizations); add emtpy file that will eventually hold the clock configuration logic. arch/arm/src/lpc54xx: Add (incomplete) SYSCON register definition header file. arch/arm/src/lpc54xx: Add FLEXCOMM header file. arch/arm/src/lpc54xx: Bring in tickless clock logic from LPC43; configs/lpcxpresso-lpc54628: mount procfs if enabled. arch/arm/src/lpc54xx: Add RIT clock definitions; add SysTick initialization (not finished) LPC54xx and LPCXpresso-LPC54628: add more boilerplate files and stubbed out files. arch/arm/src/lpc54xx: Add (incomplete) USART header file. Add another condition to a Kconfig; refresh a defconfig. arch/arm/src/lpc54xx/chip: Add LPC54628 memory map header files. configs/lpcxpresso-lpc54628: Add basic build files for the LPCXpresso-LPC54628 arch/: Basic build directory structure for the LPC54628
parent
ba64499b
