Skip to content
Commit fa10927d authored by Gregory Nutt's avatar Gregory Nutt
Browse files
Stefan Kolb's change to the SAMV7 Oneshot Timer (commit...
Stefan Kolb's change to the SAMV7 Oneshot Timer (commit d44ecbcf) should also be applied to the SAM3/4 oneshot time since the drivers are identical.  Here are the commit commits from Stefan's original change:
"This is a fix to a problem in the handling of the oneshot timer. Due to a wrong assumption concerning the behavior directly after the start of the timer/counter the function sam_oneshot_cancel(…) calculates the wrong remaining time. The code assumes that the counter register is zero directly after the start of the timer, but this is not true. To start the time/counter a software trigger is invoked, this trigger starts the timer/count and sets the counter register to zero, but the reset of the counter register is not performed instantly. According to the datasheet: “The counter can be reset by a trigger. In this case, the counter value passes to zero on the next valid edge of the selected clock.” Thus the counter is set to zero between 0 and USEC_PER_TICK microseconds after the clock was started.
"In my fix I use the freerun count value to determine if at least one tick passed since the start of the timer and thus if the value of the oneshot counter is correct. I also tried to use the function up_timer_gettime(…) to achieve this but, at least if compiled with no optimization the problem vanishes without using the value of the function, the function call takes too long.
"Another problem treated in the fix is that if the oneshot timer/counter is canceled, we only know the remaining time with a precision of USEC_PER_TICK microseconds. This means the calculated remaining time is between 0 and USEC_PER_TICK microseconds  too long. To fix this I subtract one tick if the calculated remaining time is greater than one tick and otherwise set the remaining time to zero. By doing so the measured times are much more precise as without it."
parent 9071a22c
Loading
Loading
Loading
Loading
0% Loading or .
Please register or to comment
