Skip to content
Commit fd1de920 authored by Vytautas Lukenskas's avatar Vytautas Lukenskas Committed by Gregory Nutt
Browse files
There are some small problems in LPC43xx RS485 mode configuration. In...
There are some small problems in LPC43xx RS485 mode configuration. In particular: 1. UART0,2,3 do not have DTR pins (different from UART1), so, Kconfig needs to be adjusted. 2. lpc43_uart.c in RS485 mode only configures DIR pin, but doesn't enable pin output for UART0,2,3. 3. should be option to reverse DIR control pin output polarity. 4. lpc43xx/chip/lpc43_uart.h doesn't have USART3 definitions.  NOTE: I didn't modified and didn't tested USART1, as it has different hardware.  From Vytautas Lukenskas.
parent 937a83d9
Loading
Loading
Loading
Loading
0% Loading or .
Please register or to comment
