Skip to content
Unverified Commit 7c4bcb6f authored by wazo-community-zuul[bot]'s avatar wazo-community-zuul[bot] Committed by GitHub
Browse files
Merge pull request #137 from BnLG/n510
Gigaset N510 enhancements
This PR enhances Gigaset N510 plugin.
First, it enables firmware auto-update, thanks to properly formatted links provided by Gigaset.
As found in the documentation :
https://teamwork.gigaset.com/gigawiki/display/GPPPO/Direct+link+to+Firmware+file
While here, also update to last firmware version.
https://teamwork.gigaset.com/gigawiki/display/GPPPO/Firmware+N510+IP+PRO
It also properly assign each DECT to its SIP line only.
By default, on N510, all DECT ring / receive calls for all the 6 configured SIP accounts.
And all DECT make outgoing calls from the first configured SIP account.
Which does not make sense...
This PR then properly assign each DECT to its proper SIP account : first DECT to first SIP account, second DECT to second SIP account etc..
Which is then the expected behaviour...
Thank you 👍
Reviewed-by: Alexandre Fournier <None>
parents 672766c5 9633b5e9
0% or .
Please register or to comment
