Skip to content
Commits on Source (2)
EESchema-LIBRARY Version 2.4
#encoding utf-8
# TSS-183A+
DEF TSS-183A+ U 0 40 Y Y 1 F N
F0 "U" -350 200 39 H V C CNN
F1 "TSS-183A+" 400 200 39 H V C CNN
F2 "" 0 0 50 H I C CNN
F3 "" 0 0 50 H I C CNN
DRAW
S -300 150 350 -150 0 1 0 N
P 2 0 1 0 -100 0 -150 0 N
P 2 0 1 0 100 0 150 0 N
P 4 0 1 0 -100 50 100 0 -100 -50 -100 50 N
X NC 1 50 -250 100 U 25 25 1 1 W
X RFIN 2 -400 0 100 R 25 25 1 1 I
X VG1 3 -150 -250 100 U 25 25 1 1 I
X VG2 4 150 -250 100 U 25 25 1 1 I
X RFOUT 5 450 0 100 L 25 25 1 1 O
X NC 6 -50 -250 100 U 25 25 1 1 W
X VDD2 7 150 250 100 D 25 25 1 1 W
X VDD1 8 -150 250 100 D 25 25 1 1 W
X GND 9 0 -250 100 U 25 25 1 1 W
ENDDRAW
ENDDEF
#End Library
#encoding utf-8
# SKY65013-70LF
DEF SKY65013-70LF U 0 40 Y N 1 F N
F0 "U" 0 100 25 H V C CNN
F1 "SKY65013-70LF" 0 150 25 H V C CNN
DRAW
P 4 0 1 0 -100 100 -100 -100 100 0 -100 100 N
X IN 1 -200 0 100 R 25 25 1 1 I
X GND 2 -50 -200 100 U 25 25 1 1 W
X OUT 3 200 0 100 L 25 25 1 1 O
X GND 4 50 -200 100 U 25 25 1 1 W
ENDDRAW
ENDDEF
#End Library
#encoding utf-8
# NB6N11S
DEF NB6N11S U 0 40 Y Y 1 F N
F0 "U" 350 -400 39 H V C CNN
F1 "NB6N11S" 400 100 39 H V C CNN
DRAW
S -250 150 250 -450 0 1 0 N
X Q0 1 350 -300 100 L 25 25 1 1 O
X ~D 10 -350 -300 100 R 25 25 1 1 I
X D 11 -350 0 100 R 25 25 1 1 I
X Vtd 12 -350 -100 100 R 25 25 1 1 P
X Vcc 13 -100 250 100 D 25 25 1 1 W
X Vcc 14 0 250 100 D 25 25 1 1 W
X Vcc 15 100 250 100 D 25 25 1 1 W
X Vcc 16 200 250 100 D 25 25 1 1 W
X pad 17 200 -550 100 U 25 25 1 1 W
X ~Q0 2 350 -200 100 L 25 25 1 1 O
X Q1 3 350 -100 100 L 25 25 1 1 O
X ~Q1 4 350 0 100 L 25 25 1 1 O
X Vcc 5 -200 250 100 D 25 25 1 1 W
X NC 6 -150 -550 100 U 25 25 1 1 N
X Vee 7 0 -550 100 U 25 25 1 1 W
X Vee 8 100 -550 100 U 25 25 1 1 W
X V~td 9 -350 -200 100 R 25 25 1 1 P
ENDDRAW
ENDDEF
#End Library
#encoding utf-8
# SN74LV4052A
DEF SN74LV4052A U 0 40 Y Y 1 F N
F0 "U" 250 -750 25 H V C CNN
F1 "SN74LV4052A" 250 -650 25 H V C CNN
F2 "SOIC:SOIC-16-Wide_8.7mm" 150 -850 50 H I C CNN
F3 "" 250 -750 50 H I C CNN
DRAW
S 150 -600 -150 250 0 1 0 N
X 2Y0 1 250 100 100 L 25 25 1 1 B
X A 10 -250 150 100 R 25 25 1 1 I
X 1Y3 11 250 -450 100 L 25 25 1 1 B
X 1Y0 12 250 -250 100 L 25 25 1 1 B
X COM1 13 -250 -350 100 R 25 25 1 1 B
X 1Y1 14 250 -300 100 L 25 25 1 1 B
X 1Y2 15 250 -400 100 L 25 25 1 1 B
X Vcc 16 0 350 100 D 25 25 1 1 W
X 2Y2 2 250 -50 100 L 25 25 1 1 B
X COM2 3 -250 0 100 R 25 25 1 1 B
X 2Y3 4 250 -100 100 L 25 25 1 1 B
X 2Y1 5 250 50 100 L 25 25 1 1 B
X INH 6 -250 200 100 R 25 25 1 1 I
X GND 7 -50 -700 100 U 25 25 1 1 W
X GND 8 50 -700 100 U 25 25 1 1 W
X B 9 -250 100 100 R 25 25 1 1 I
ENDDRAW
ENDDEF
#End Library
(module BergStack_61082-041400LF (layer F.Cu) (tedit 5D3386D7)
(fp_text reference REF** (at 0 -4) (layer F.SilkS)
(effects (font (size 0.635 0.635) (thickness 0.15)))
(fp_text value BergStack_61082-041400LF (at 0 -4) (layer F.Fab)
(effects (font (size 1 1) (thickness 0.15)))
(fp_line (start -10.9 -3) (end 10.9 -3) (layer F.SilkS) (width 0.15))
(fp_line (start 10.9 -3) (end 10.9 3) (layer F.SilkS) (width 0.15))
(fp_line (start 10.9 3) (end -10.9 3) (layer F.SilkS) (width 0.15))
(fp_line (start -10.9 3) (end -10.9 -3) (layer F.SilkS) (width 0.15))
(fp_line (start 9 -3) (end 9 -1) (layer F.SilkS) (width 0.15))
(fp_line (start 9 -1) (end 10.9 -1) (layer F.SilkS) (width 0.15))
(fp_line (start -9 -3) (end -9 -1) (layer F.SilkS) (width 0.15))
(fp_line (start -9 -1) (end -10.9 -1) (layer F.SilkS) (width 0.15))
(fp_circle (center 10 -2) (end 10.25 -2) (layer F.SilkS) (width 0.15))
(fp_circle (center 8.5 -4) (end 8.75 -4) (layer F.SilkS) (width 0.15))
(fp_line (start -11.25 -3.25) (end 11.25 -3.25) (layer F.CrtYd) (width 0.15))
(fp_line (start 11.25 -3.25) (end 11.25 3.25) (layer F.CrtYd) (width 0.15))
(fp_line (start 11.25 3.25) (end -11.25 3.25) (layer F.CrtYd) (width 0.15))
(fp_line (start -11.25 3.25) (end -11.25 -3.25) (layer F.CrtYd) (width 0.15))
(pad "" np_thru_hole circle (at 10.1 0) (size 1.2 1.2) (drill 1.2) (layers *.Cu *.Mask))
(pad "" np_thru_hole circle (at -10.1 0) (size 0.8 0.8) (drill 0.8) (layers *.Cu *.Mask))
(pad 1 smd rect (at 7.6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at 7.6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at 6.8 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at 6.8 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 5 smd rect (at 6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 6 smd rect (at 6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 7 smd rect (at 5.2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 8 smd rect (at 5.2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 9 smd rect (at 4.4 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 10 smd rect (at 4.4 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 11 smd rect (at 3.6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 12 smd rect (at 3.6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 13 smd rect (at 2.8 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 14 smd rect (at 2.8 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 15 smd rect (at 2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 16 smd rect (at 2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 17 smd rect (at 1.2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 18 smd rect (at 1.2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 19 smd rect (at 0.4 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 20 smd rect (at 0.4 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 21 smd rect (at -0.4 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 22 smd rect (at -0.4 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 23 smd rect (at -1.2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 24 smd rect (at -1.2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 25 smd rect (at -2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 26 smd rect (at -2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 27 smd rect (at -2.8 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 28 smd rect (at -2.8 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 29 smd rect (at -3.6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 30 smd rect (at -3.6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 31 smd rect (at -4.4 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 32 smd rect (at -4.4 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 33 smd rect (at -5.2 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 34 smd rect (at -5.2 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 35 smd rect (at -6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 36 smd rect (at -6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 37 smd rect (at -6.8 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 38 smd rect (at -6.8 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 39 smd rect (at -7.6 -2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(pad 40 smd rect (at -7.6 2.2) (size 0.5 2) (layers F.Cu F.Paste F.Mask))
(module DQ849 (layer F.Cu) (tedit 5D339F68)
(attr smd)
(fp_text reference REF** (at 0 -1.9525) (layer F.SilkS)
(fp_text value DQ849 (at 0 1.9525) (layer F.Fab)
(fp_line (start -0.5 -1.5) (end -1.5 -0.5) (layer F.Fab) (width 0.15))
(fp_line (start -1.5 -0.5) (end -1.5 1.5) (layer F.Fab) (width 0.15))
(fp_line (start -1.5 1.5) (end 1.5 1.5) (layer F.Fab) (width 0.15))
(fp_line (start 1.5 1.5) (end 1.5 -1.5) (layer F.Fab) (width 0.15))
(fp_line (start 1.5 -1.5) (end -0.5 -1.5) (layer F.Fab) (width 0.15))
(fp_line (start 0.99 -1.65) (end 1.65 -1.65) (layer F.SilkS) (width 0.15))
(fp_line (start 1.65 -1.65) (end 1.65 -0.99) (layer F.SilkS) (width 0.15))
(fp_line (start 0.99 1.65) (end 1.65 1.65) (layer F.SilkS) (width 0.15))
(fp_line (start 1.65 1.65) (end 1.65 0.99) (layer F.SilkS) (width 0.15))
(fp_line (start -0.99 1.65) (end -1.65 1.65) (layer F.SilkS) (width 0.15))
(fp_line (start -1.65 1.65) (end -1.65 0.99) (layer F.SilkS) (width 0.15))
(fp_line (start -0.99 -1.65) (end -1.705 -1.65) (layer F.SilkS) (width 0.15))
(fp_line (start -1.95 -1.95) (end 1.95 -1.95) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.95 -1.95) (end 1.95 1.95) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.95 1.95) (end -1.95 1.95) (layer F.CrtYd) (width 0.05))
(fp_line (start -1.95 1.95) (end -1.95 -1.95) (layer F.CrtYd) (width 0.05))
(fp_circle (center -2.75 -1) (end -3 -1) (layer F.SilkS) (width 0.15))
(pad 1 smd rect (at -1.495 -0.33 90) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at -1.495 0.33 90) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at -0.33 1.495) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at 0.33 1.495) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 5 smd rect (at 1.495 0.33 90) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 6 smd rect (at 1.495 -0.33 90) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 7 smd rect (at 0.33 -1.495) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 8 smd rect (at -0.33 -1.495) (size 0.3 0.81) (layers F.Cu F.Paste F.Mask))
(pad 9 smd rect (at -0.425 -0.425) (size 0.85 0.85) (layers F.Cu F.Paste F.Mask)
(solder_paste_margin -0.1))
(pad 9 smd rect (at -0.425 0.425) (size 0.85 0.85) (layers F.Cu F.Paste F.Mask)
(pad 9 smd rect (at 0.425 -0.425) (size 0.85 0.85) (layers F.Cu F.Paste F.Mask)
(pad 9 smd rect (at 0.425 0.425) (size 0.85 0.85) (layers F.Cu F.Paste F.Mask)
(pad 9 thru_hole circle (at -0.425 -0.425) (size 0.425 0.425) (drill 0.2125) (layers *.Cu *.Mask))
(pad 9 thru_hole circle (at -0.425 0.425) (size 0.425 0.425) (drill 0.2125) (layers *.Cu *.Mask))
(pad 9 thru_hole circle (at 0.425 -0.425) (size 0.425 0.425) (drill 0.2125) (layers *.Cu *.Mask))
(pad 9 thru_hole circle (at 0.425 0.425) (size 0.425 0.425) (drill 0.2125) (layers *.Cu *.Mask))
(module FV1206 (layer F.Cu) (tedit 5D338C7F)
(fp_text reference REF** (at 0 -3) (layer F.SilkS)
(fp_text value FV1206 (at 0 -3) (layer F.Fab)
(fp_circle (center -2.75 1.25) (end -2.75 1.5) (layer F.SilkS) (width 0.15))
(fp_line (start -2.25 -1) (end -0.5 -1) (layer F.SilkS) (width 0.15))
(fp_line (start 0.5 -1) (end 2.25 -1) (layer F.SilkS) (width 0.15))
(fp_line (start 2.25 1) (end 0.5 1) (layer F.SilkS) (width 0.15))
(fp_line (start -0.5 1) (end -2.25 1) (layer F.SilkS) (width 0.15))
(fp_line (start -1 -0.25) (end -0.5 -0.25) (layer F.SilkS) (width 0.15))
(fp_line (start -0.5 -0.25) (end -0.5 0.25) (layer F.SilkS) (width 0.15))
(fp_line (start -0.5 0.25) (end -1 0.25) (layer F.SilkS) (width 0.15))
(fp_line (start -1 0.25) (end -1 -0.25) (layer F.SilkS) (width 0.15))
(fp_line (start -2.5 -1.75) (end 2.75 -1.75) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.75 -1.75) (end 2.75 1.75) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.75 1.75) (end -2.5 1.75) (layer F.CrtYd) (width 0.15))
(fp_line (start -2.5 1.75) (end -2.5 -1.75) (layer F.CrtYd) (width 0.15))
(pad 1 smd rect (at -1.625 0) (size 1.04 1.8) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at 1.625 0) (size 1.04 1.8) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at 0 0.9275) (size 0.61 1.245) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at 0 -0.9275) (size 0.61 1.245) (layers F.Cu F.Paste F.Mask))
(module NB6N11S_QFN-16_EP_3x3_Pitch0.5mm (layer F.Cu) (tedit 5D5E64C4)
(attr smd)
(fp_text reference REF** (at 0 -1.975) (layer F.SilkS)
(fp_text value NB6N11S_QFN-16_EP_3x3_Pitch0.5mm (at 0 1.975) (layer F.Fab)
(fp_line (start 1.25 -1.65) (end 1.65 -1.65) (layer F.SilkS) (width 0.15))
(fp_line (start 1.65 -1.65) (end 1.65 -1.25) (layer F.SilkS) (width 0.15))
(fp_line (start 1.25 1.65) (end 1.65 1.65) (layer F.SilkS) (width 0.15))
(fp_line (start 1.65 1.65) (end 1.65 1.25) (layer F.SilkS) (width 0.15))
(fp_line (start -1.25 1.65) (end -1.65 1.65) (layer F.SilkS) (width 0.15))
(fp_line (start -1.65 1.65) (end -1.65 1.25) (layer F.SilkS) (width 0.15))
(fp_line (start -1.25 -1.65) (end -1.7 -1.65) (layer F.SilkS) (width 0.15))
(pad 1 smd rect (at -1.55 -0.75 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at -1.55 -0.25 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at -1.55 0.25 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at -1.55 0.75 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 5 smd rect (at -0.75 1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 6 smd rect (at -0.25 1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 7 smd rect (at 0.25 1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 8 smd rect (at 0.75 1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 9 smd rect (at 1.55 0.75 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 10 smd rect (at 1.55 0.25 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 11 smd rect (at 1.55 -0.25 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 12 smd rect (at 1.55 -0.75 90) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 13 smd rect (at 0.75 -1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 14 smd rect (at 0.25 -1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 15 smd rect (at -0.25 -1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 16 smd rect (at -0.75 -1.55) (size 0.3 0.9) (layers F.Cu F.Paste F.Mask))
(pad 17 smd rect (at -0.46 -0.46) (size 0.92 0.92) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at -0.46 0.46) (size 0.92 0.92) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at 0.46 -0.46) (size 0.92 0.92) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at 0.46 0.46) (size 0.92 0.92) (layers F.Cu F.Paste F.Mask)
(pad 17 thru_hole circle (at -0.46 -0.46) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at -0.46 0.46) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.46 -0.46) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.46 0.46) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(module QFN-16_EP_3x3_Pitch0.5mm (layer F.Cu) (tedit 5D5E6565)
(attr smd)
(fp_text value QFN-16_EP_3x3_Pitch0.5mm (at 0 1.9375) (layer F.Fab)
(fp_line (start -1.25 -1.65) (end -1.65 -1.65) (layer F.SilkS) (width 0.15))
(fp_line (start -1.9 -1.9) (end 1.9 -1.9) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.9 -1.9) (end 1.9 1.9) (layer F.CrtYd) (width 0.05))
(fp_line (start 1.9 1.9) (end -1.9 1.9) (layer F.CrtYd) (width 0.05))
(fp_line (start -1.9 1.9) (end -1.9 -1.9) (layer F.CrtYd) (width 0.05))
(fp_circle (center -2 -2) (end -2 -2.25) (layer F.SilkS) (width 0.15))
(pad 1 smd rect (at -1.575 -0.75 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 2 smd rect (at -1.575 -0.25 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at -1.575 0.25 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at -1.575 0.75 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 5 smd rect (at -0.75 1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 6 smd rect (at -0.25 1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 7 smd rect (at 0.25 1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 8 smd rect (at 0.75 1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 9 smd rect (at 1.575 0.75 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 10 smd rect (at 1.575 0.25 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 11 smd rect (at 1.575 -0.25 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 12 smd rect (at 1.575 -0.75 90) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 13 smd rect (at 0.75 -1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 14 smd rect (at 0.25 -1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 15 smd rect (at -0.25 -1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 16 smd rect (at -0.75 -1.575) (size 0.3 0.75) (layers F.Cu F.Paste F.Mask))
(pad 17 smd rect (at -0.4375 -0.4375) (size 0.875 0.875) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at -0.4375 0.4375) (size 0.875 0.875) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at 0.4375 -0.4375) (size 0.875 0.875) (layers F.Cu F.Paste F.Mask)
(pad 17 smd rect (at 0.4375 0.4375) (size 0.875 0.875) (layers F.Cu F.Paste F.Mask)
(pad 17 thru_hole circle (at -0.4375 -0.4375) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at -0.4375 0.4375) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.4375 -0.4375) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(pad 17 thru_hole circle (at 0.4375 0.4375) (size 0.46 0.46) (drill 0.254) (layers *.Cu *.Mask))
(module SOT89-SKY65013-70 (layer F.Cu) (tedit 5D34DE60)
(fp_text reference REF** (at 0 -5.75) (layer F.SilkS)
(fp_text value SOT89-SKY65013-70 (at 0 -5.75) (layer F.Fab)
(fp_line (start -2.5 -4.3) (end 2.5 -4.3) (layer F.SilkS) (width 0.15))
(fp_line (start 2.5 -4.3) (end 2.5 -0.5) (layer F.SilkS) (width 0.15))
(fp_line (start 2.5 -0.5) (end -2.5 -0.5) (layer F.SilkS) (width 0.15))
(fp_line (start -2.5 -0.5) (end -2.5 -4.3) (layer F.SilkS) (width 0.15))
(fp_line (start -2.5 -4.3) (end 2.5 -4.3) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.5 -4.3) (end 2.5 -0.5) (layer F.CrtYd) (width 0.15))
(fp_line (start 2.5 -0.5) (end -2.5 -0.5) (layer F.CrtYd) (width 0.15))
(fp_line (start -2.5 -0.5) (end -2.5 -4.3) (layer F.CrtYd) (width 0.15))
(fp_circle (center -2.9 -0.2) (end -2.7 -0.2) (layer F.SilkS) (width 0.15))
(pad 2 smd rect (at 0 -0.7) (size 0.5 1.4) (layers F.Cu F.Paste F.Mask))
(pad 3 smd rect (at 1.5 -0.7) (size 0.42 1.4) (layers F.Cu F.Paste F.Mask))
(pad 1 smd rect (at -1.5 -0.7) (size 0.42 1.4) (layers F.Cu F.Paste F.Mask))
(pad 4 smd rect (at 0 -3.2) (size 1.73 2.7) (layers F.Cu F.Paste F.Mask))
#encoding utf-8
# MINIC_LFCN
DEF MINIC_LFCN F 0 40 Y N 1 F N
F0 "F" 0 0 39 H V C CNN
F1 "MINIC_LFCN" 0 200 39 H V C CNN
F2 "" 100 0 60 H I C CNN
F3 "" 100 0 60 H I C CNN
DRAW
S -150 100 150 -50 0 1 0 N
P 2 0 1 0 -50 50 -100 50 N
P 3 0 1 0 -50 50 50 50 100 0 N
X RFIN 1 -250 50 100 R 25 25 0 0 P
X GND 2 0 -150 100 U 25 25 0 0 P
X RFOUT 3 250 50 100 L 25 25 0 0 P
X GND 4 50 -150 100 U 25 25 0 0 P
ENDDRAW
ENDDEF
#End Library
EESchema-LIBRARY Version 2.3 EESchema-LIBRARY Version 2.4
#encoding utf-8 #encoding utf-8
# ADF5355 # ADF5355
DEF ADF5355 U 0 40 Y Y 1 F N DEF ADF5355 U 0 40 Y Y 1 F N
F0 "U" 675 350 60 H V C CNN F0 "U" -450 300 39 H V C CNN
F1 "ADF5355" 250 -50 60 H V C CNN F1 "ADF5355" 500 300 39 H V C CNN
F2 "" 0 -175 60 H I C CNN F2 "" -100 -25 60 H I C CNN
F3 "" 0 -175 60 H I C CNN F3 "" -100 -25 60 H I C CNN
DRAW DRAW
S -200 300 725 -450 0 1 0 N S -350 300 300 -350 0 1 0 N
X CLK 1 -300 250 100 R 25 25 1 1 I X CLK 1 -400 150 50 R 25 25 1 1 I
X DATA 2 -300 200 100 R 25 25 1 1 I X Vrf 10 -150 -400 50 U 25 25 1 1 W
X LE 3 -300 150 100 R 25 25 1 1 I X RFoutA+ 11 -100 -400 50 U 25 25 1 1 O
X CE 4 -300 100 100 R 25 25 1 1 I X RFoutA- 12 -50 -400 50 U 25 25 1 1 O
X Avdd 5 200 400 100 D 25 25 1 1 W X Agndrf 13 0 -400 50 U 25 25 1 1 W
X Vp 6 375 400 100 D 25 25 1 1 W X RFoutB 14 50 -400 50 U 25 25 1 1 O
X CPout 7 -300 -200 100 R 25 25 1 1 O X Agndrf 15 100 -400 50 U 25 25 1 1 W
X CPgnd 8 0 -550 100 U 25 25 1 1 W X Avdd 16 150 -400 50 U 25 25 1 1 W
X Agnd 9 175 -550 100 U 25 25 1 1 W X Vvco 17 350 -200 50 L 25 25 1 1 W
X Vrf 10 250 400 100 D 25 25 1 1 W X Agndvco 18 350 -150 50 L 25 25 1 1 W
X VTune 20 -300 -275 100 R 25 25 1 1 I X Vregvco 19 350 -100 50 L 25 25 1 1 W
X MUXout 30 825 -75 100 L 25 25 1 1 O X DATA 2 -400 100 50 R 25 25 1 1 I
X SDgnd 30 50 -550 100 U 25 25 1 1 W X VTune 20 350 -50 50 L 25 25 1 1 I
X RFoutA+ 11 825 250 100 L 25 25 1 1 O X Agndvco 21 350 0 50 L 25 25 1 1 W
X Agndvco 21 450 -550 100 U 25 25 1 1 W X Rset 22 350 50 50 L 25 25 1 1 P
X RFoutA- 12 825 200 100 L 25 25 1 1 O X Vref 23 350 100 50 L 25 25 1 1 O
X Rset 22 825 -425 100 L 25 25 1 1 P X Vbias 24 350 150 50 L 25 25 1 1 O
X Creg2 32 825 -200 100 L 25 25 1 1 O X Creg1 25 150 350 50 D 25 25 1 1 O
X Agndrf 13 275 -550 100 U 25 25 1 1 W X PDBrf 26 100 350 50 D 25 25 1 1 I
X Vref 23 825 -300 100 L 25 25 1 1 O X Dvdd 27 50 350 50 D 25 25 1 1 W
X PAD 33 500 -550 100 U 25 25 1 1 W X REFinB 28 0 350 50 D 25 25 1 1 I
X RFoutB 14 825 75 100 L 25 25 1 1 O X REFinA 29 -50 350 50 D 25 25 1 1 I
X Vbias 24 825 -350 100 L 25 25 1 1 O X LE 3 -400 50 50 R 25 25 1 1 I
X Agndrf 15 225 -550 100 U 25 25 1 1 W X MUXout 30 -100 350 50 D 25 25 1 1 O
X Creg1 25 825 -250 100 L 25 25 1 1 O X SDgnd 31 -150 350 50 D 25 25 1 1 W
X Avdd 16 150 400 100 D 25 25 1 1 W X Creg2 32 -200 350 50 D 25 25 1 1 O
X PDBrf 26 -300 50 100 R 25 25 1 1 I X PAD 33 250 -400 50 U 25 25 1 1 W
X Vvco 17 425 400 100 D 25 25 1 1 W X CE 4 -400 0 50 R 25 25 1 1 I
X Dvdd 27 -50 400 100 D 25 25 1 1 W X Avdd 5 -400 -50 50 R 25 25 1 1 W
X Agndvco 18 400 -550 100 U 25 25 1 1 W X Vp 6 -400 -100 50 R 25 25 1 1 W
X REFinB 28 -300 -75 100 R 25 25 1 1 I X CPout 7 -400 -150 50 R 25 25 1 1 O
X Vregvco 19 475 400 100 D 25 25 1 1 W X CPgnd 8 -400 -200 50 R 25 25 1 1 W
X REFinA 29 -300 -25 100 R 25 25 1 1 I X Agnd 9 -200 -400 50 U 25 25 1 1 W
ENDDRAW ENDDRAW
ENDDEF ENDDEF
#End Library #End Library
...@@ -6,7 +6,7 @@ EESchema-LIBRARY Version 2.4 ...@@ -6,7 +6,7 @@ EESchema-LIBRARY Version 2.4
DEF BSS138 Q 0 0 Y N 1 F N DEF BSS138 Q 0 0 Y N 1 F N
F0 "Q" 200 75 50 H V L CNN F0 "Q" 200 75 50 H V L CNN
F1 "BSS138" 200 0 50 H V L CNN F1 "BSS138" 200 0 50 H V L CNN
F2 "TO_SOT_Packages_SMD:SOT-23" 200 -75 50 H I L CIN F2 "SOT:SOT-23" 200 -75 50 H I L CIN
F3 "" 0 0 50 H I L CNN F3 "" 0 0 50 H I L CNN
$FPLIST $FPLIST
SOT?23* SOT?23*
EESchema-LIBRARY Version 2.4 EESchema-LIBRARY Version 2.4
# BSS84
DEF BSS84 Q 0 0 Y N 1 F N
F0 "Q" -150 -50 25 H V C CNN
F1 "BSS84" -150 -100 25 H V C CNN
F2 "SOT:SOT-23" 0 0 50 H I C CNN
DRAW
C 25 0 90 0 1 0 N
P 2 0 1 0 0 -30 0 -50 N
P 2 0 1 0 0 20 0 -20 N
P 2 0 1 0 0 30 0 50 N
P 2 0 1 0 10 0 0 0 N
P 2 0 1 0 60 -20 80 10 N
P 2 0 1 0 60 10 100 10 N
P 3 0 1 0 -75 50 -25 50 -25 -50 N
P 3 0 1 0 0 -50 50 -50 50 -75 N
P 3 0 1 0 0 50 50 50 50 75 N
P 3 0 1 0 30 0 40 0 40 50 N
P 3 0 1 0 40 -50 80 -50 80 -20 N
P 3 0 1 0 80 10 80 50 40 50 N
P 4 0 1 0 10 20 10 -20 30 0 10 20 N
P 4 0 1 0 60 -20 90 -20 100 -20 80 10 N
X G 1 -150 50 100 R 25 25 1 1 I
X S 2 50 150 100 D 25 25 1 1 I
X D 3 50 -150 100 U 25 25 1 1 I
ENDDRAW
ENDDEF
# NTA4151P # NTA4151P
DEF NTA4151P Q 0 0 Y N 1 F N DEF NTA4151P Q 0 0 Y N 1 F N
