Skip to content
GitLab
Explore
Sign in
xtof
AMSATLIST
Compare revisions
1feff60befc977917cc9b42e9109a8e087baea17 to f47246e903e8a7159b56f5f660526750cbdb01c0
Commits on Source (2)
Add google Analytics
· e3b3b757
xtof
authored
Nov 04, 2018
e3b3b757
Merge branch 'master' of
https://code.electrolab.fr/xtof/AMSATLIST
· f47246e9
xtof
authored
Nov 04, 2018
f47246e9
Hide whitespace changes
Inline
Side-by-side
Data/AmateurSatellites.xsd
View file @
f47246e9
<xs:schema
xmlns:xs=
"http://www.w3.org/2001/XMLSchema"
targetNamespace=
"http://www.josast.org/test/jaxb"
xmlns:tns=
elementFormDefault=
"qualified"
<xs:schema
attributeFormDefault=
"unqualified"
elementFormDefault=
"qualified"
xmlns:xs=
<xs:schema
"unqualified"
elementFormDefault=
"qualified"
xmlns:xs=
<xs:element
name=
"AmsatList"
type=
"AmsatListType"
<xs:element
name=
"AmsatList"
type=
"AmsatListType"
@@ -17,6 +25,7 @@
@@ -17,6 +25,7 @@
<xs:enumeration
value=
"230000"
<xs:enumeration
value=
"230000"
</xs:restriction>
</xs:restriction>
</xs:simpleType>
</xs:simpleType>
</xs:element>
<xs:element
name=
"Status"
<xs:element
name=
"Status"
<xs:simpleType>
<xs:simpleType>
@@ -37,7 +46,7 @@
@@ -37,7 +46,7 @@
</xs:simpleType>
</xs:simpleType>
</xs:element>
</xs:element>
<xs:element
name=
"Mode"
minOccurs=
"0"
<xs:element
name=
"Mode"
<xs:simpleType>
<xs:simpleType>
<xs:restriction
base=
"xs:string"
<xs:restriction
base=
"xs:string"
<xs:enumeration
value=
"SSB/CW"
<xs:enumeration
value=
"SSB/CW"
@@ -145,13 +154,19 @@
<xs:element
type=
"xs:string"
name=
"Title"
<xs:element
type=
"xs:string"
name=
"Title"
<xs:element
type=
"xs:string"
name=
"Value"
<xs:element
type=
"xs:string"
name=
"Value"
</xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:complexType
name=
"SoftwareURLType"
<xs:sequence>
<xs:element
type=
"xs:string"
name=
"Title"
<xs:element
type=
"xs:string"
name=
"Value"
</xs:sequence>
</xs:complexType>
</xs:complexType>
<xs:complexType
name=
"TelemetryDataType"
<xs:complexType
name=
"TelemetryDataType"
<xs:sequence>
<xs:sequence>
<xs:element
type=
"DescriptionURLType"
name=
"DescriptionURL"
maxOccurs=
"unbounded"
minOccurs=
"0"
<xs:element
type=
name=
"DescriptionURL"
maxOccurs=
"unbounded"
minOccurs=
"0"
<xs:element
type=
"ReportURLType"
name=
"ReportURL"
minOccurs=
"0"
<xs:element
type=
"ReportURLType"
name=
"ReportURL"
minOccurs=
"0"
<xs:element
type=
"xs:string"
name=
"ReportEmail"
minOccurs=
"0"
<xs:element
type=
"xs:string"
name=
"ReportEmail"
minOccurs=
"0"
<xs:element
type=
xs:string
name=
"SoftwareURL"
minOccurs=
"0"
<xs:element
type=
SoftwareURLType
name=
"SoftwareURL"
minOccurs=
"0"
<xs:element
type=
"xs:string"
name=
"Description"
minOccurs=
"0"
<xs:element
type=
"xs:string"
name=
"Description"
minOccurs=
"0"
</xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:complexType>
Templates/XSLT/HtmlFileDescription.xsl
View file @
f47246e9
@@ -6,6 +6,16 @@
@@ -6,6 +6,16 @@
<head>
<head>
<meta
charset=
"utf-8"
</meta>
<meta
charset=
"utf-8"
</meta>
<meta
http-equiv=
"X-UA-Compatible"
content=
"IE=edge,chrome=1"
</meta>
<meta
http-equiv=
"X-UA-Compatible"
content=
"IE=edge,chrome=1"
</meta>
<!-- Global site tag (gtag.js) - Google Analytics -->
<script
src=
"https://www.googletagmanager.com/gtag/js?id=UA-128629404-1"
async=
"true"
></script>
<script>
window.dataLayer = window.dataLayer || [];
function gtag(){dataLayer.push(arguments);}
gtag('js', new Date());
gtag('config', 'UA-128629404-1');
</script>
<title>
AMSAT SATELLITE LIST
</title>
<title>
</title>
<meta
name=
"description"
content=
></meta>
<meta
name=
"description"
content=
></meta>
<meta
name=
"viewport"
content=
"width=device-width, initial-scale=1"
></meta>
<meta
name=
"viewport"
content=
></meta>
@@ -45,7 +55,7 @@
@@ -45,7 +55,7 @@
<tr
class=
"c0"
<tr
class=
"c0"
<td><xsl:apply-templates
select=
"SatelliteInformationStatus"
</td>
select=
</td>
<td>
<a
href=
"SatellitePage/{NasaID}.htm"
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<a
href=
{Name}
.htm"
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
select=
"Status"
</td>
<td>
select=
"Status"
</td>
</tr>
</tr>
@@ -64,7 +74,7 @@
@@ -64,7 +74,7 @@
<tr
class=
"c0"
<tr
class=
"c0"
select=
</td>
select=
</td>
<td>
<a
href=
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<a
href=
{Name}
.htm"
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
select=
"Status"
</td>
<td>
select=
"Status"
</td>
<td>
select=
"RadioData/Beacons/Frequency"
</td>
<td>
select=
</td>
@@ -85,7 +95,7 @@
@@ -85,7 +95,7 @@
<tr
class=
"c0"
<tr
class=
"c0"
select=
</td>
select=
</td>
<td>
<a
href=
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<a
href=
{Name}
.htm"
><xsl:value-of
select=
"Name"
/></a></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
<xsl:value-of
select=
"NasaID"
/></td>
<td>
select=
"Status"
</td>
<td>
select=
"Status"
</td>
</tr>
</tr>
@@ -113,15 +123,7 @@
<script
src=
"initializr/js/plugins.js"
></script>
<script
src=
></script>
<script
src=
"initializr/js/main.js"
></script>
<script
src=
></script>
<!-- Google Analytics: change UA-XXXXX-X to be your site's ID. -->
<script>
(function(b,o,i,l,e,r){b.GoogleAnalyticsObject=l;b[l]||(b[l]=
function(){(b[l].q=b[l].q||[]).push(arguments)});b[l].l=+new Date;
e=o.createElement(i);r=o.getElementsByTagName(i)[0];
e.src='//www.google-analytics.com/analytics.js';
r.parentNode.insertBefore(e,r)}(window,document,'script','ga'));
ga('create','UA-XXXXX-X','auto');ga('send','pageview');
</script>
</body>
</body>
@@ -137,7 +139,7 @@
@@ -137,7 +139,7 @@
</xsl:template>
</xsl:template>
<xsl:template
match=
"Satellites"
<xsl:template
match=
"Satellites"
<xsl:result-document
format=
"html"
encoding=
"UTF-8"
href=
format=
"html"
encoding=
"UTF-8"
href=
{Name}
.htm"
<!--[if lt IE 7]> <html class="no-js lt-ie9 lt-ie8 lt-ie7" lang=""> <![endif]-->
<!--[if IE 7]> <html class="no-js lt-ie9 lt-ie8" lang=""> <![endif]-->
@@ -146,6 +148,16 @@
<head>
<head>
<script
async=
"true"
src=
></script>
<script>
</script>
<meta
charset=
"utf-8"
</meta>
<meta
charset=
"utf-8"
</meta>
<meta
http-equiv=
"X-UA-Compatible"
content=
"IE=edge,chrome=1"
</meta>
<meta
http-equiv=
"X-UA-Compatible"
content=
"IE=edge,chrome=1"
</meta>
<title><xsl:value-of
select=
"./Name"
/></title>
select=
"./Name"
/></title>
@@ -204,8 +216,13 @@
<h2>
Radio
</h2>
<h2>
Radio
</h2>
<h3>
Beacon
</h3>
<h3>
Beacon
</h3>
<td>
select=
"RadioData/Beacons"
/></td>
<td>
select=
"RadioData/Beacons"
/></td>
<h3>
Transponder
</h3>
<xsl:if
test=
"(RadioData/Transponders)"
<h3>
Transponder
</h3>
<td>
select=
"RadioData/Transponders"
/></td>
<td>
select=
/></td>
</xsl:if>
</section>
</section>
<section
class=
"Telemetry"
<section
class=
"Telemetry"
@@ -236,14 +253,7 @@
<script
src=
"//ajax.googleapis.com/ajax/libs/jquery/1.11.2/jquery.min.js"
></script>
<script
src=
></script>
<script
src=
"../initializr/js/plugins.js"
></script><script
src=
></script>
<script
src=
></script><script
src=
></script>
<script>
</script>
</body>
</body>
</html>
</html>
@@ -252,7 +262,7 @@
@@ -252,7 +262,7 @@
<xsl:template
match=
"RadioData/Beacons"
<xsl:template
match=
"RadioData/Beacons"
<h4>
Name :
<xsl:value-of
select=
"Name"
/></h4>
<h4>
Name :
<xsl:value-of
select=
"Name"
/></h4>
<li><b>
Frequency :
</b><xsl:value-of
select=
'format-number(number(Frequency), "###,###.##")'
<xsl:text>
Hz
</xsl:text>
</li>
<li><b>
Frequency :
</b><xsl:value-of
select=
div 1000000
<xsl:text>
M
Hz
</xsl:text>
</li>
<li><b>
Mode :
</b><xsl:apply-templates
select=
"Modes"
</li>
<li><b>
Mode :
select=
"Modes"
</li>
</xsl:template>
</xsl:template>
@@ -263,17 +273,17 @@
<xsl:template
match=
<xsl:template
match=
<h4>
Name :
<xsl:value-of
select=
"Name"
/></h4>
<h4>
Name :
<xsl:value-of
select=
"Name"
/></h4>
<li><b>
Uplink :
</b>
<xsl:value-of
select=
'format-number(number(FrequencyUplink/FrequencyBegin), "###,###.##")'
<xsl:text>
Hz
</xsl:text>
<li><b>
Uplink :
</b>
<xsl:value-of
select=
div 1000000
<xsl:text>
MHz
Hz
</xsl:text>
<xsl:if
test=
"FrequencyUplink/FrequencyEnd"
<xsl:if
test=
<xsl:text>
</xsl:text>
<xsl:text>
</xsl:text>
<xsl:value-of
select=
'format-number(number(FrequencyUplink/FrequencyEnd), "###,###.##")'
<xsl:text>
Hz
</xsl:text>
<xsl:value-of
select=
div 1000000
<xsl:text>
MHz
Hz
</xsl:text>
</xsl:if>
</li>
</xsl:if>
</li>
<li><b>
Downlink :
</b>
<xsl:value-of
select=
'format-number(number(FrequencyDownlink/FrequencyBegin), "###,###.##")'
<xsl:text>
Hz
</xsl:text>
<li><b>
Downlink :
</b>
<xsl:value-of
select=
div 1000000
<xsl:text>
M
Hz
</xsl:text>
<xsl:if
test=
"FrequencyDownlink/FrequencyEnd"
<xsl:if
test=
<xsl:text>
</xsl:text>
<xsl:text>
</xsl:text>
<xsl:value-of
select=
'format-number(number(FrequencyDownlink/FrequencyEnd), "###,###.##")'
<xsl:text>
Hz
</xsl:text>
<xsl:value-of
select=
div 1000000
<xsl:text>
M
Hz
</xsl:text>
</xsl:if>
</li>
</xsl:if>
</li>
<xsl:if
test=
"Inverted"
<xsl:if
test=
"Inverted"
<li><b>
Inverted :
select=
"Inverted"
/></li>
<li><b>
Inverted :
select=
"Inverted"
/></li>
@@ -293,20 +303,18 @@
<xsl:template
match=
"Information"
<xsl:template
match=
"Information"
<xsl:text>
Link :
</xsl:text>
<a
href=
"{./Value}"
><xsl:value-of
select=
"./Title"
/></a>
<xsl:for-each
select=
"Description"
<xsl:for-each
select=
"Description"
<xsl:choose>
<xsl:choose>
<xsl:when
test=
"contains(current()/@lang,'EN')"
<xsl:when
test=
<p>
<p>
<xsl:value-of
select=
"current()"
<br/>
<xsl:value-of
select=
"current()"
<br/>
</p>
</p>
</xsl:when>
</xsl:when>
</xsl:choose>
</xsl:choose>
</xsl:for-each>
<p>
</xsl:for-each>
<xsl:text>
Link :
</xsl:text>
<a
href=
"{Information/Value}"
><xsl:value-of
select=
"Information/DescTitle"
/></a>
</p>
</xsl:template>
</xsl:template>
Templates/XSLT/SplitAmsatListFile.xsl
View file @
f47246e9
@@ -5,7 +5,9 @@
@@ -5,7 +5,9 @@
<xsl:template
match=
<!-- Match the root -->
<xsl:template
match=
<xsl:for-each
select=
"AmsatList/Satellites"
<xsl:for-each
select=
method=
"xml"
href=
"satellite_{NasaID}_{Name}.xml"
method=
"xml"
href=
<AmsatList>
<xsl:copy-of
select=
<xsl:copy-of
select=
</AmsatList>
</xsl:result-document>
</xsl:for-each>
</xsl:for-each>
</xsl:template>
</xsl:template>
scripts/HtmlDescriptionPage.bat
View file @
f47246e9
java
-jar
C
:\projet\SaxonHE9
8
0
14
J
\saxon9he.jar
-s
:../data/AmateurSatellites.xml
-xsl
:../Templates/XSLT/HtmlFileDescription.xsl
-o
:../site/index.html
java
-jar
C
:\projet\SaxonHE9
8
0
14
J
\saxon9he.jar
-s
:../data/AmsatList.xml
-xsl
-o
:../site/index.html
\ No newline at end of file
