Skip to content
Snippets Groups Projects
Commit 645d02ac authored by Gregory Nutt's avatar Gregory Nutt
Browse files
USB monitor extended so that it can also be used with USB host trace data
parent 0f83209b
No related branches found
No related tags found
...@@ -641,4 +641,6 @@ ...@@ -641,4 +641,6 @@
a pthread, but we are stuck with that for now. The work-around a pthread, but we are stuck with that for now. The work-around
is the msconn now daemonizes itself so that it so taht the pthread is the msconn now daemonizes itself so that it so taht the pthread
is created in a different task group (2013-9-7). is created in a different task group (2013-9-7).
* apps/system/usbmonitor: The USB monitor has been extended so
that it can be used with USB device or host trace data (2013-9-9).
...@@ -6,12 +6,12 @@ ...@@ -6,12 +6,12 @@
config SYSTEM_USBMONITOR config SYSTEM_USBMONITOR
bool "USB Monitor" bool "USB Monitor"
default n default n
depends on USBDEV && USBDEV_TRACE depends on (USBDEV && USBDEV_TRACE) || (USBHOST && USBHOST_TRACE)
---help--- ---help---
If USB device tracing is enabled (USBDEV_TRACE), then this option If USB device tracing (USBDEV_TRACE) AND/OR USB host tracing
will select the USB monitor. The USB monitor is a daemon that will (USBHOST_TRACE) are enabled then this option will select the USB
periodically collect the buffered USB trace data and dump it to the monitor. The USB monitor is a daemon that will periodically collect
SYSLOG device. the buffered USB trace data and dump it to the SYSLOG device.
if SYSTEM_USBMONITOR if SYSTEM_USBMONITOR
...@@ -34,34 +34,37 @@ config SYSTEM_USBMONITOR_INTERVAL ...@@ -34,34 +34,37 @@ config SYSTEM_USBMONITOR_INTERVAL
The rate in seconds that the USB monitor will wait before dumping The rate in seconds that the USB monitor will wait before dumping
the next set of buffered USB trace data. Default: 2 seconds. the next set of buffered USB trace data. Default: 2 seconds.
if USBDEV && USBDEV_TRACE
config SYSTEM_USBMONITOR_TRACEINIT config SYSTEM_USBMONITOR_TRACEINIT
bool "Show initialization events" bool "Show USB device initialization events"
default n default n
Show initialization events Show initialization events
config SYSTEM_USBMONITOR_TRACECLASS config SYSTEM_USBMONITOR_TRACECLASS
bool "Show class driver events" bool "Show USB device class driver events"
default n default n
Show class driver events Show class driver events
config SYSTEM_USBMONITOR_TRACETRANSFERS config SYSTEM_USBMONITOR_TRACETRANSFERS
bool "Show data transfer events" bool "Show USB device data transfer events"
default n default n
Show data transfer events Show data transfer events
config SYSTEM_USBMONITOR_TRACECONTROLLER config SYSTEM_USBMONITOR_TRACECONTROLLER
bool "Show controller events" bool "Show USB device controller events"
default n default n
Show controller events Show controller events
config SYSTEM_USBMONITOR_TRACEINTERRUPTS config SYSTEM_USBMONITOR_TRACEINTERRUPTS
bool "Show interrupt-related events" bool "Show USB device interrupt-related events"
default n default n
Show interrupt-related events Show interrupt-related events
endif
endif endif
...@@ -48,6 +48,7 @@ ...@@ -48,6 +48,7 @@
#include <errno.h> #include <errno.h>
#include <nuttx/usb/usbdev_trace.h> #include <nuttx/usb/usbdev_trace.h>
#include <nuttx/usb/usbhost_trace.h>
#ifdef CONFIG_SYSTEM_USBMONITOR #ifdef CONFIG_SYSTEM_USBMONITOR
...@@ -71,46 +72,50 @@ ...@@ -71,46 +72,50 @@
# define CONFIG_SYSTEM_USBMONITOR_INTERVAL 2 # define CONFIG_SYSTEM_USBMONITOR_INTERVAL 2
#endif #endif
#ifdef CONFIG_SYSTEM_USBMONITOR_TRACEINIT /* USB device trace selection */
# define TRACE_INIT_BITS (TRACE_INIT_BIT)
#else
# define TRACE_INIT_BITS (0)
#endif
#define TRACE_ERROR_BITS (TRACE_DEVERROR_BIT|TRACE_CLSERROR_BIT)
#ifdef CONFIG_SYSTEM_USBMONITOR_TRACECLASS #ifdef USBDEV_TRACE
# define TRACE_CLASS_BITS (TRACE_CLASS_BIT|TRACE_CLASSAPI_BIT|\ # ifdef CONFIG_SYSTEM_USBMONITOR_TRACEINIT
TRACE_CLASSSTATE_BIT) # define TRACE_INIT_BITS (TRACE_INIT_BIT)
#else # else
# define TRACE_CLASS_BITS (0) # define TRACE_INIT_BITS (0)
#endif # endif
#ifdef CONFIG_SYSTEM_USBMONITOR_TRACETRANSFERS # define TRACE_ERROR_BITS (TRACE_DEVERROR_BIT|TRACE_CLSERROR_BIT)
# define TRACE_TRANSFER_BITS (TRACE_OUTREQQUEUED_BIT|TRACE_INREQQUEUED_BIT|\
TRACE_READ_BIT|TRACE_WRITE_BIT|\
TRACE_COMPLETE_BIT)
#else
# define TRACE_TRANSFER_BITS (0)
#endif
#ifdef CONFIG_SYSTEM_USBMONITOR_TRACECONTROLLER
# define TRACE_CONTROLLER_BITS (TRACE_EP_BIT|TRACE_DEV_BIT)
#else
# define TRACE_CONTROLLER_BITS (0)
#endif
#ifdef CONFIG_SYSTEM_USBMONITOR_TRACEINTERRUPTS # ifdef CONFIG_SYSTEM_USBMONITOR_TRACECLASS
# define TRACE_INTERRUPT_BITS (TRACE_INTENTRY_BIT|TRACE_INTDECODE_BIT|\ # define TRACE_CLASS_BITS (TRACE_CLASS_BIT|TRACE_CLASSAPI_BIT|\
TRACE_INTEXIT_BIT) TRACE_CLASSSTATE_BIT)
#else # else
# define TRACE_INTERRUPT_BITS (0) # define TRACE_CLASS_BITS (0)
# endif
# ifdef CONFIG_SYSTEM_USBMONITOR_TRACETRANSFERS
TRACE_COMPLETE_BIT)
# else
# endif
# ifdef CONFIG_SYSTEM_USBMONITOR_TRACECONTROLLER
# else
# endif
# ifdef CONFIG_SYSTEM_USBMONITOR_TRACEINTERRUPTS
TRACE_INTEXIT_BIT)
# else
# endif
# define TRACE_BITSET (TRACE_INIT_BITS|TRACE_ERROR_BITS|\
TRACE_CLASS_BITS|TRACE_TRANSFER_BITS|\
TRACE_CONTROLLER_BITS|TRACE_INTERRUPT_BITS)
#endif #endif
#define TRACE_BITSET (TRACE_INIT_BITS|TRACE_ERROR_BITS|\
* Private Types * Private Types
...@@ -132,11 +137,13 @@ static struct usbmon_state_s g_usbmonitor; ...@@ -132,11 +137,13 @@ static struct usbmon_state_s g_usbmonitor;
* Private Functions * Private Functions
#ifdef CONFIG_USBDEV_TRACE
static int usbmonitor_tracecallback(struct usbtrace_s *trace, void *arg) static int usbmonitor_tracecallback(struct usbtrace_s *trace, void *arg)
usbtrace_trprintf((trprintf_t)syslog, trace->event, trace->value); usbtrace_trprintf((trprintf_t)syslog, trace->event, trace->value);
return 0; return 0;
#endif
static int usbmonitor_daemon(int argc, char **argv) static int usbmonitor_daemon(int argc, char **argv)
...@@ -147,7 +154,12 @@ static int usbmonitor_daemon(int argc, char **argv) ...@@ -147,7 +154,12 @@ static int usbmonitor_daemon(int argc, char **argv)
while (!g_usbmonitor.stop) while (!g_usbmonitor.stop)
sleep(CONFIG_SYSTEM_USBMONITOR_INTERVAL); sleep(CONFIG_SYSTEM_USBMONITOR_INTERVAL);
(void)usbtrace_enumerate(usbmonitor_tracecallback, NULL); (void)usbtrace_enumerate(usbmonitor_tracecallback, NULL);
#endif
#ifdef CONFIG_USBHOST_TRACE
(void)usbhost_trdump();
#endif
/* Stopped */ /* Stopped */
...@@ -174,9 +186,11 @@ int usbmonitor_start(int argc, char **argv) ...@@ -174,9 +186,11 @@ int usbmonitor_start(int argc, char **argv)
/* No.. start it now */ /* No.. start it now */
/* First, initialize any USB tracing options that were requested */ /* First, initialize any USB tracing options that were requested */
usbtrace_enable(TRACE_BITSET); usbtrace_enable(TRACE_BITSET);
#endif
/* Then start the USB monitoring daemon */ /* Then start the USB monitoring daemon */
...@@ -222,9 +236,11 @@ int usbmonitor_stop(int argc, char **argv) ...@@ -222,9 +236,11 @@ int usbmonitor_stop(int argc, char **argv)
syslog(USBMON_PREFIX "Stopping: %d\n", g_usbmonitor.pid); syslog(USBMON_PREFIX "Stopping: %d\n", g_usbmonitor.pid);
g_usbmonitor.stop = true; g_usbmonitor.stop = true;
/* We may as well disable tracing since there is no listener */ /* We may as well disable tracing since there is no listener */
usbtrace_enable(0); usbtrace_enable(0);
#endif
syslog(USBMON_PREFIX "Stopped: %d\n", g_usbmonitor.pid); syslog(USBMON_PREFIX "Stopped: %d\n", g_usbmonitor.pid);
0% Loading or .
Please register or to comment
