Skip to content
Snippets Groups Projects
Commit 929e4cdd authored by Gregory Nutt's avatar Gregory Nutt
Browse files
This cleans up most of the remaining SourceForge references
parent b2c2e134
No related branches found
No related tags found
...@@ -170,7 +170,7 @@ A: Here are four: ...@@ -170,7 +170,7 @@ A: Here are four:
This is documented in NuttX/configs/README.txt and This is documented in NuttX/configs/README.txt and
nuttx/Documentation/NuttxPortingGuide.html (Online at nuttx/Documentation/NuttxPortingGuide.html (Online at
http://nuttx.sourceforge.net/NuttxPortingGuide.html#apndxconfigs https://bitbucket.org/patacongo/nuttx/src/master/nuttx/Documentation/NuttxPortingGuide.html#apndxconfigs
under Build options). And in the apps/README.txt file. under Build options). And in the apps/README.txt file.
3) If you like the random collection of stuff in the apps/ directory 3) If you like the random collection of stuff in the apps/ directory
...@@ -25,7 +25,7 @@ ...@@ -25,7 +25,7 @@
Depending on the configuration, clicking the links will execute the CGI program from either: Depending on the configuration, clicking the links will execute the CGI program from either:
</p> </p>
<ol> <ol>
<li>An <a href="http://nuttx.sourceforge.net/NuttXNxFlat.html">NXFLAT</a> program residing <li>An <a href="https://bitbucket.org/patacongo/nuttx/src/master/nuttx/Documentation/NuttXNxFlat.html">NXFLAT</a> program residing
in a NuttX ROMFS file system, or</li> in a NuttX ROMFS file system, or</li>
<li>A built-in application managed by a NuttX BINFS file system.</li> <li>A built-in application managed by a NuttX BINFS file system.</li>
</ol> </ol>
0% Loading or .
Please register or to comment
