Skip to content
Snippets Groups Projects
Commit b10bc205 authored by patacongo's avatar patacongo
Browse files
Improve LPC17xx CAN interrupt handling; Additions to LPC17xx SPI driver
git-svn-id: svn://svn.code.sf.net/p/nuttx/code/trunk@4255 42af7a65-404d-4744-a932-0658087f49c3
parent a1e3f348
No related branches found
No related tags found
...@@ -216,12 +216,16 @@ int MAIN_NAME(int argc, char *argv[]) ...@@ -216,12 +216,16 @@ int MAIN_NAME(int argc, char *argv[])
message("ERROR: Data does not match. DLC=%d\n", msgdlc); message("ERROR: Data does not match. DLC=%d\n", msgdlc);
for (i = 0; i < msgdlc; i++) for (i = 0; i < msgdlc; i++)
message(" %d: TX %02x RX %02x\n", txmsg.cm_data[i], rxmsg.cm_data[i]); message(" %d: TX %02x RX %02x\n", i, txmsg.cm_data[i], rxmsg.cm_data[i]);
errval = 5; errval = 5;
goto errout_with_dev; goto errout_with_dev;
/* Report success */
message(" ID: %4d DLC: %d -- OK\n", msgid, msgdlc);
/* Set up for the next pass */ /* Set up for the next pass */
msgdata += msgdlc; msgdata += msgdlc;
0% Loading or .
Please register or to comment
