Skip to content
Snippets Groups Projects
Commit b6c31e3f authored by Gregory Nutt's avatar Gregory Nutt
Browse files
NxWM::CTouchscreen: Add CONFIG_NXWM_TOUCHSCREEN_DEVINIT to suppress attempts...
NxWM::CTouchscreen: Add CONFIG_NXWM_TOUCHSCREEN_DEVINIT to suppress attempts to initialize the touchscreen from NxWM in the kernel build
parent 346abf47
No related branches found
No related tags found
...@@ -738,6 +738,22 @@ if NXWM_TOUCHSCREEN ...@@ -738,6 +738,22 @@ if NXWM_TOUCHSCREEN
comment "Touchscreen device settings" comment "Touchscreen device settings"
config NXWM_TOUCHSCREEN_DEVINIT
bool "Touchscreen Device Initialization"
default y
depends on !NUTTX_KERNEL
---help---
It this option is selected, then the NxWM:CTouchscreen listener
thread will call a function arch_tcinitialize(NXWM_TOUCHSCREEN_DEVNO)
in order to instantiate the touchscreen driver at path
NXWM_TOUCHSCREEN_DEVPATH. If NXWM_TOUCHSCREEN_DEVINIT is not
selected, then the NxWM:CTouchscreen listener thread will assume
that the driver has already been initialized at
NOTE that in the kernel build, all touchscreen initialize must be
performed in kernel logic prior to the execution of NxWM.
config NXWM_TOUCHSCREEN_DEVNO config NXWM_TOUCHSCREEN_DEVNO
int "Touchscreen Device Number" int "Touchscreen Device Number"
default 0 default 0
0% Loading or .
Please register or to comment
