Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
NuttX RTOS
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Deploy
Releases
Container Registry
Model registry
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
NuttX RTOS
Commits
e505df2e
Commit
e505df2e
authored
7 years ago
by
Gregory Nutt
Browse files
Options
Downloads
Patches
Plain Diff
tools/configure.c: Duplicate new functionaity added to configure.sh.
parent
10eed5de
No related branches found
No related tags found
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
tools/configure.c
+41
-12
41 additions, 12 deletions
tools/configure.c
tools/configure.sh
+3
-3
3 additions, 3 deletions
tools/configure.sh
with
44 additions
and
15 deletions
tools/configure.c
41
12
View file @
e505df2e
@@ -99,6 +99,7 @@ static char *g_srcdefconfig = NULL; /* Source defconfig file */
static
char
g_srcmakedefs
NULL
/* Source Make.defs file */
static
bool
g_winnative
false
/* True: Windows native configuration */
static
bool
g_oldnative
false
/* True: Was Windows native configuration */
static
bool
g_needapppath
true
/* Need to add app path to the .config file */
static
uint8_t
g_host
HOST_NOCHANGE
@@ -652,24 +653,35 @@ static void check_appdir(void)
if
g_appdir
/* No, was the path provided in the configuration? */
/* If no application directory was provided on the command line and we
* are switching between a windows native host and some other host then
* ignore any path to the apps/ directory in the defconfig file. It
* will most certainly not be in a usable form.
struct
variable_s
var
find_variable
"CONFIG_APP_DIR"
g_configvars
if
var
if
g_winnative
g_oldnative
debug
"check_appdir: Config file appdir=%s
\n
var
val
var
val
"<null>"
/* Yes.. does this directory exist? */
struct
variable_s
var
find_variable
"CONFIG_APPS_DIR"
g_configvars
if
var
val
verify_appdir
var
val
if
var
NULL
/* We are using the CONFIG_APP_DIR setting already
* in the defconfig file.
debug
\n
var
val
var
val
"<null>"
g_needapppath
false
return
if
var
val
verify_appdir
var
val
/* We are using the CONFIG_APPS_DIR setting already in the
* defconfig file.
g_needapppath
false
return
@@ -718,6 +730,23 @@ static void check_configuration(void)
if
var
var
val
strcmp
"y"
var
val
0
debug
"check_configuration: Windows native configuration
\n
g_oldnative
true
/* If we are going to some host other then windows native or to a windows
* native host, then don't ignore what is in the defconfig file.
if
g_host
HOST_NOCHANGE
/* Use whatever we found in the configuration file */
g_winnative
g_oldnative
else
if
g_host
HOST_WINDOWS
g_windows
WINDOWS_NATIVE
/* The new configuration is windows native */
g_winnative
true
This diff is collapsed.
tools/configure.sh
3
3
View file @
e505df2e
@@ -183,10 +183,10 @@ else
fi
fi
# If no
t
application direct
ion
was
specifi
ed on the command line and we are
# If no application direct
ory
was
provid
# switching between a windows native host and some other host then ignore the
# path to the apps/ direct
ion
in the defconfig file. It will most certainly
# not be a usable form
a
ory
# not be
in
a usable form.
defappdir
y
if
-z
appdir
-a
"X
$oldnative
$winnative
then
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
